path: root/arch
2016-11-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "One NULL pointer dereference, and two fixes for regressions introduced during the merge window. The rest are fixes for MIPS, s390 and nested VMX" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: x86: Check memopp before dereference (CVE-2016-8630) kvm: nVMX: VMCLEAR an active shadow VMCS after last use KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCK KVM: x86: fix wbinvd_dirty_mask use-after-free kvm/x86: Show WRMSR data is in hex kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID types KVM: document lock orders KVM: fix OOPS on flush_work KVM: s390: Fix STHYI buffer alignment for diag224 KVM: MIPS: Precalculate MMIO load resume PC KVM: MIPS: Make ERET handle ERL before EXL KVM: MIPS: Fix lazy user ASID regenerate for SMP
2016-11-04Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "A set of MIPS fixes for 4.9: - lots of fixes for printk continuations - six fixes for FP related code. - fix max_low_pfn with disabled highmem - fix KASLR handling of NULL FDT and KASLR for generic kernels - fix build of compressed image - provide default mips_cpc_default_phys_base to ignore CPC - fix reboot on Malta" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Fix max_low_pfn with disabled highmem MIPS: Correct MIPS I FP sigcontext layout MIPS: Fix ISA I/II FP signal context offsets MIPS: Remove FIR from ISA I FP signal context MIPS: Fix ISA I FP sigcontext access violation handling MIPS: Fix FCSR Cause bit handling for correct SIGFPE issue MIPS: ptrace: Also initialize the FP context on individual FCSR writes MIPS: dump_tlb: Fix printk continuations MIPS: Fix __show_regs() output MIPS: traps: Fix output of show_code MIPS: traps: Fix output of show_stacktrace MIPS: traps: Fix output of show_backtrace MIPS: Fix build of compressed image MIPS: generic: Fix KASLR for generic kernel. MIPS: KASLR: Fix handling of NULL FDT MIPS: Malta: Fixup reboot MIPS: CPC: Provide default mips_cpc_default_phys_base to ignore CPC
2016-11-04Merge branch 'parisc-4.9-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc updates from Helge Deller: "The first three patches are trivial and add some required KERN_CONT, ignore the new pkey syscalls on parisc and use the LINUX_GATEWAY_ADDR define instead of hardcoded values. The two patches from Dave Anglin are important. The first one avoids trashing the sr2 and sr3 space registers in the Light-weight syscall path. Especially the usage of sr3 is critical since it may get trashed by the interrupt handler. The second patch is even more important and tagged for stable series. It protects one critical section in the syscall entry path by disabling local interrupts. Without disabling interrupts, the sr7 space register may not be in sync with the current stack setup and thus an incoming hardware interrupt may destroy memory in random userspace areas" * 'parisc-4.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Ignore the pkey system calls for now parisc: Use LINUX_GATEWAY_ADDR define instead of hardcoded value parisc: Ensure consistent state when switching to kernel stack at syscall entry parisc: Avoid trashing sr2 and sr3 in LWS code parisc: use KERN_CONT when printing device inventory
2016-11-04MIPS: Fix max_low_pfn with disabled highmemJames Hogan
When low memory doesn't reach HIGHMEM_START (e.g. up to 256MB at PA=0 is common) and highmem is present above HIGHMEM_START (e.g. on Malta the RAM overlayed by the IO region is aliased at PA=0x90000000), max_low_pfn will be initially calculated very large and then clipped down to HIGHMEM_START. This causes crashes when reading /sys/kernel/mm/page_idle/bitmap (i.e. CONFIG_IDLE_PAGE_TRACKING=y) when highmem is disabled. pfn_valid() will compare against max_mapnr which is derived from max_low_pfn when there is no highend_pfn set up, and will return true for PFNs right up to HIGHMEM_START, even though they are beyond the end of low memory and no page structs will actually exist for these PFNs. This is fixed by skipping high memory regions when initially calculating max_low_pfn if highmem is disabled, so it doesn't get clipped too high. We also clip regions which overlap the highmem boundary when highmem is disabled, so that max_pfn doesn't extend into highmem either. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14490/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Correct MIPS I FP sigcontext layoutMaciej W. Rozycki
Complement commit 80cbfad79096 ("MIPS: Correct MIPS I FP context layout") and correct the way Floating Point General registers are stored in a signal context with MIPS I hardware. Use the S.D and L.D assembly macros to have pairs of SWC1 instructions and pairs of LWC1 instructions produced, respectively, in an arrangement which makes the memory representation of floating-point data passed compatible with that used by hardware SDC1 and LDC1 instructions, where available, regardless of the hardware endianness used. This matches the layout used by r4k_fpu.S, ensuring run-time compatibility for MIPS I software across all o32 hardware platforms. Define an EX2 macro to handle exceptions from both hardware instructions implicitly produced from S.D and L.D assembly macros. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14477/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Fix ISA I/II FP signal context offsetsMaciej W. Rozycki
Fix a regression introduced with commit 2db9ca0a3551 ("MIPS: Use struct mips_abi offsets to save FP context") for MIPS I/I FP signal contexts, by converting save/restore code to the updated internal API. Start FGR offsets from 0 rather than SC_FPREGS from $a0 and use $a1 rather than the offset of SC_FPC_CSR from $a0 for the Floating Point Control/Status Register (FCSR). Document the new internal API and adjust assembly code formatting for consistency. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14476/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Remove FIR from ISA I FP signal contextMaciej W. Rozycki
Complement commit e50c0a8fa60d ("Support the MIPS32 / MIPS64 DSP ASE.") and remove the Floating Point Implementation Register (FIR) from the FP register set recorded in a signal context with MIPS I processors too, in line with the change applied to r4k_fpu.S. The `sc_fpc_eir' slot is unused according to our current ABI and the FIR register is read-only and always directly accessible from user software. [ralf@linux-mips.org: This is also required because the next commit depends on it.] Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14475/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Fix ISA I FP sigcontext access violation handlingMaciej W. Rozycki
Complement commit 0ae8dceaebe3 ("Merge with 2.3.10.") and use the local `fault' handler to recover from FP sigcontext access violation faults, like corresponding code does in r4k_fpu.S. The `bad_stack' handler is in syscall.c and is not suitable here as we want to propagate the error condition up through the caller rather than killing the thread outright. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14474/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Fix FCSR Cause bit handling for correct SIGFPE issueMaciej W. Rozycki
Sanitize FCSR Cause bit handling, following a trail of past attempts: * commit 4249548454f7 ("MIPS: ptrace: Fix FP context restoration FCSR regression"), * commit 443c44032a54 ("MIPS: Always clear FCSR cause bits after emulation"), * commit 64bedffe4968 ("MIPS: Clear [MSA]FPE CSR.Cause after notify_die()"), * commit b1442d39fac2 ("MIPS: Prevent user from setting FCSR cause bits"), * commit b54d2901517d ("Properly handle branch delay slots in connection with signals."). Specifically do not mask these bits out in ptrace(2) processing and send a SIGFPE signal instead whenever a matching pair of an FCSR Cause and Enable bit is seen as execution of an affected context is about to resume. Only then clear Cause bits, and even then do not clear any bits that are set but masked with the respective Enable bits. Adjust Cause bit clearing throughout code likewise, except within the FPU emulator proper where they are set according to IEEE 754 exceptions raised as the operation emulated executed. Do so so that any IEEE 754 exceptions subject to their default handling are recorded like with operations executed by FPU hardware. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14460/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: ptrace: Also initialize the FP context on individual FCSR writesMaciej W. Rozycki
Complement commit ac9ad83bc318 ("MIPS: prevent FP context set via ptrace being discarded") and also initialize the FP context whenever FCSR alone is written with a PTRACE_POKEUSR request addressing FPC_CSR, rather than along with the full FPU register set in the case of the PTRACE_SETFPREGS request. Signed-off-by: Maciej W. Rozycki <macro@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14459/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: dump_tlb: Fix printk continuationsJames Hogan
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines") the output from TLB dumps on MIPS has been pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to provide the appropriate markers & restore the expected output. Continuation is also used for the second line of each TLB entry printed in dump_tlb.c even though it has a newline, since it is a continuation of the interpretation of the same TLB entry. For example: [ 46.371884] Index: 0 pgmask=16kb va=77654000 asid=73 gid=00 [ri=0 xi=0 pa=ffc18000 c=5 d=0 v=1 g=0] [ri=0 xi=0 pa=ffc1c000 c=5 d=0 v=1 g=0] [ 46.385380] Index: 12 pgmask=16kb va=004b4000 asid=73 gid=00 [ri=0 xi=0 pa=00000000 c=0 d=0 v=0 g=0] [ri=0 xi=0 pa=ffb00000 c=5 d=1 v=1 g=0] Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14444/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Fix __show_regs() outputPaul Burton
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines") the output from __show_regs() on MIPS has been pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to provide the appropriate markers & restore the expected register output. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14432/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: traps: Fix output of show_codeMatt Redfearn
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines") the output from show_code on MIPS has been pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to provide the appropriate markers & restore the expected output. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14431/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: traps: Fix output of show_stacktraceMatt Redfearn
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines") the output from show_stacktrace on MIPS has been pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to provide the appropriate markers & restore the expected output. Also start a new line with printk such that the presence of timing information does not interfere with output. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14430/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: traps: Fix output of show_backtraceMatt Redfearn
Since commit 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines") the output from show_backtrace on MIPS has been pretty unreadable due to the lack of KERN_CONT markers. Use pr_cont to provide the appropriate markers & restore the expected output. Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Maciej W. Rozycki <macro@imgtec.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14429/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Fix build of compressed imageMatt Redfearn
Changes introduced to arch/mips/Makefile for the generic kernel resulted in build errors when making a compressed image if platform-y has multiple values, like this: make[2]: *** No rule to make target `alchemy/'. make[1]: *** [vmlinuz] Error 2 make[1]: Target `_all' not remade because of errors. make: *** [sub-make] Error 2 make: Target `_all' not remade because of errors. Fix this by quoting $(platform-y) as it is passed to the Makefile in arch/mips/boot/compressed/Makefile Reported-by: kernelci.org bot <bot@kernelci.org> Link: https://storage.kernelci.org/next/next-20161017/mips-gpr_defconfig/build.log Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14405/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: generic: Fix KASLR for generic kernel.Matt Redfearn
The KASLR code requires that the plat_get_fdt() function return the address of the device tree, and it must be available early in the boot, before prom_init() is called. Move the code determining the address of the device tree into plat_get_fdt, and call that from prom_init(). The fdt pointer will be set up by plat_get_fdt() called from relocate_kernel initially and once the relocated kernel has started, prom_init() will use it again to determine the address in the relocated image. Fixes: eed0eabd12ef ("MIPS: generic: Introduce generic DT-based board support") Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14415/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: KASLR: Fix handling of NULL FDTMatt Redfearn
If platform code returns a NULL pointer to the FDT, initial_boot_params will not get set to a valid pointer and attempting to find the /chosen node in it will cause a NULL pointer dereference and the kernel to crash immediately on startup - with no output to the console. Fix this by checking that initial_boot_params is valid before using it. Fixes: 405bc8fd12f5 ("MIPS: Kernel: Implement KASLR using CONFIG_RELOCATABLE") Cc: stable@vger.kernel.org # 4.7+ Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/14414/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: Malta: Fixup rebootPaul Burton
Commit 10b6ea0959de ("MIPS: Malta: Use syscon-reboot driver to reboot") converted the Malta board to use the generic syscon-reboot driver to handle reboots, but incorrectly used the value 0x4d rather than 0x42 as the magic to write to the reboot register. I also incorrectly believed that syscon/regmap would default to native endianness, but this isn't the case. Force this by specifying with a native-endian property in the devicetree. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Fixes: 10b6ea0959de ("MIPS: Malta: Use syscon-reboot driver to reboot") Reported-by: Guenter Roeck <linux@roeck-us.net> Cc: linux-mips@linux-mips.org Tested-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Maciej W. Rozycki <macro@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/14396/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-04MIPS: CPC: Provide default mips_cpc_default_phys_base to ignore CPCPaul Burton
Provide a default implementation of mips_cpc_default_phys_base() which simply returns 0, and adjust mips_cpc_phys_base() to allow for mips_cpc_default_phys_base() returning 0. This allows kernels which include CPC support to be built without platform code & simply ignore the CPC if it wasn't already enabled by the bootloader. This fixes link failures such as the following from generic defconfigs: arch/mips/built-in.o: In function `mips_cpc_phys_base': arch/mips/kernel/mips-cpc.c:47: undefined reference to `mips_cpc_default_phys_base' [ralf@linux-mips.org: changed prototype for coding style compliance.] Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14401/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-11-02parisc: Ignore the pkey system calls for nowHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de>
2016-11-02parisc: Use LINUX_GATEWAY_ADDR define instead of hardcoded valueHelge Deller
LINUX_GATEWAY_ADDR is defined in unistd.h. Let's use it. Signed-off-by: Helge Deller <deller@gmx.de>
2016-11-02parisc: Ensure consistent state when switching to kernel stack at syscall entryJohn David Anglin
We have one critical section in the syscall entry path in which we switch from the userspace stack to kernel stack. In the event of an external interrupt, the interrupt code distinguishes between those two states by analyzing the value of sr7. If sr7 is zero, it uses the kernel stack. Therefore it's important, that the value of sr7 is in sync with the currently enabled stack. This patch now disables interrupts while executing the critical section. This prevents the interrupt handler to possibly see an inconsistent state which in the worst case can lead to crashes. Interestingly, in the syscall exit path interrupts were already disabled in the critical section which switches back to the userspace stack. Cc: <stable@vger.kernel.org> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2016-11-02parisc: Avoid trashing sr2 and sr3 in LWS codeJohn David Anglin
There is no need to trash sr2 and sr3 in the Light-weight syscall (LWS). sr2 already points to kernel space (it's zero in userspace, otherwise syscalls wouldn't work), and since the LWS code is executed in userspace, we can simply ignore to preload sr3. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2016-11-02parisc: use KERN_CONT when printing device inventoryHelge Deller
Recent changes to printk require KERN_CONT uses to continue logging messages. So add KERN_CONT to output of device inventory. Signed-off-by: Helge Deller <deller@gmx.de>
2016-11-02kvm: x86: Check memopp before dereference (CVE-2016-8630)Owen Hofmann
Commit 41061cdb98 ("KVM: emulate: do not initialize memopp") removes a check for non-NULL under incorrect assumptions. An undefined instruction with a ModR/M byte with Mod=0 and R/M-5 (e.g. 0xc7 0x15) will attempt to dereference a null pointer here. Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Message-Id: <1477592752-126650-2-git-send-email-osh@google.com> Signed-off-by: Owen Hofmann <osh@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-11-02kvm: nVMX: VMCLEAR an active shadow VMCS after last useJim Mattson
After a successful VM-entry with the "VMCS shadowing" VM-execution control set, the shadow VMCS referenced by the VMCS link pointer field in the current VMCS becomes active on the logical processor. A VMCS that is made active on more than one logical processor may become corrupted. Therefore, before an active VMCS can be migrated to another logical processor, the first logical processor must execute a VMCLEAR for the active VMCS. VMCLEAR both ensures that all VMCS data are written to memory and makes the VMCS inactive. Signed-off-by: Jim Mattson <jmattson@google.com> Reviewed-By: David Matlack <dmatlack@google.com> Message-Id: <1477668579-22555-1-git-send-email-jmattson@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-11-02KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCKPaolo Bonzini
Since commit a545ab6a0085 ("kvm: x86: add tsc_offset field to struct kvm_vcpu_arch", 2016-09-07) the offset between host and L1 TSC is cached and need not be fished out of the VMCS or VMCB. This means that we can implement adjust_tsc_offset_guest and read_l1_tsc entirely in generic code. The simplification is particularly significant for VMX code, where vmx->nested.vmcs01_tsc_offset was duplicating what is now in vcpu->arch.tsc_offset. Therefore the vmcs01_tsc_offset can be dropped completely. More importantly, this fixes KVM_GET_CLOCK/KVM_SET_CLOCK which, after commit 108b249c453d ("KVM: x86: introduce get_kvmclock_ns", 2016-09-01) called read_l1_tsc while the VMCS was not loaded. It thus returned bogus values on Intel CPUs. Fixes: 108b249c453dd7132599ab6dc7e435a7036c193f Reported-by: Roman Kagan <rkagan@virtuozzo.com> Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-10-31Merge branch 'fixes' of git://git.armlinux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A fix for a regression on ARMv4T CPUs, and wiring up the new pkey syscalls for ARM" * 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm: ARM: wire up new pkey syscalls ARM: fix oops when using older ARMv4T CPUs
2016-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: "Several sparc64 bug fixes here: 1) Make the user copy routines on sparc64 return a properly accurate residual length when an exception occurs. 2) We can get enormous kernel TLB range flush requests from vmalloc unmaps, so handle these more gracefully by doing full flushes instead of going page-by-page. 3) Cope properly with negative branch offsets in sparc jump-label support, from James Clarke. 4) Some old-style decl GCC warning fixups from Tobias Klauser" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Handle extremely large kernel TLB range flushes more gracefully. sparc64: Fix illegal relative branches in hypervisor patched TLB cross-call code. sparc64: Fix instruction count in comment for __hypervisor_flush_tlb_pending. sparc64: Handle extremely large kernel TSB range flushes sanely. sparc: Handle negative offsets in arch_jump_label_transform sparc64: Fix illegal relative branches in hypervisor patched TLB code. sparc64: Delete now unused user copy fixup functions. sparc64: Delete now unused user copy assembler helpers. sparc64: Convert U3copy_{from,to}_user to accurate exception reporting. sparc64: Convert NG2copy_{from,to}_user to accurate exception reporting. sparc64: Convert NGcopy_{from,to}_user to accurate exception reporting. sparc64: Convert NG4copy_{from,to}_user to accurate exception reporting. sparc64: Convert U1copy_{from,to}_user to accurate exception reporting. sparc64: Convert GENcopy_{from,to}_user to accurate exception reporting. sparc64: Convert copy_in_user to accurate exception reporting. sparc64: Prepare to move to more saner user copy exception handling. sparc64: Delete __ret_efault. sparc32: Fix old style declaration GCC warnings sparc64: Fix old style declaration GCC warnings sparc64: Setup a scheduling domain for highest level cache.
2016-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Lots of fixes, mostly drivers as is usually the case. 1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey Khoroshilov. 2) Fix element timeouts in netfilter's nft_dynset, from Anders K. Pedersen. 3) Don't put aead_req crypto struct on the stack in mac80211, from Ard Biesheuvel. 4) Several uninitialized variable warning fixes from Arnd Bergmann. 5) Fix memory leak in cxgb4, from Colin Ian King. 6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann. 7) Several VRF semantic fixes from David Ahern. 8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper. 9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet. 10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev. 11) Fix stale link state during failover in NCSCI driver, from Gavin Shan. 12) Fix netdev lower adjacency list traversal, from Ido Schimmel. 13) Propvide proper handle when emitting notifications of filter deletes, from Jamal Hadi Salim. 14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen. 15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac. 16) Several routing offload fixes in mlxsw driver, from Jiri Pirko. 17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy. 18) Validate chunk len before using it in SCTP, from Marcelo Ricardo Leitner. 19) Revert a netns locking change that causes regressions, from Paul Moore. 20) Add recursion limit to GRO handling, from Sabrina Dubroca. 21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon. 22) Avoid accessing stale vxlan/geneve socket in data path, from Pravin Shelar" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits) geneve: avoid using stale geneve socket. vxlan: avoid using stale vxlan socket. qede: Fix out-of-bound fastpath memory access net: phy: dp83848: add dp83822 PHY support enic: fix rq disable tipc: fix broadcast link synchronization problem ibmvnic: Fix missing brackets in init_sub_crq_irqs ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context" arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold net/mlx4_en: Save slave ethtool stats command net/mlx4_en: Fix potential deadlock in port statistics flow net/mlx4: Fix firmware command timeout during interrupt test net/mlx4_core: Do not access comm channel if it has not yet been initialized net/mlx4_en: Fix panic during reboot net/mlx4_en: Process all completions in RX rings after port goes up net/mlx4_en: Resolve dividing by zero in 32-bit system net/mlx4_core: Change the default value of enable_qos net/mlx4_core: Avoid setting ports to auto when only one port type is supported net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec ...
2016-10-29arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofoldIvan Vecera
Commit 01cfbad "ipv4: Update parameters for csum_tcpudp_magic to their original types" changed parameters for csum_tcpudp_magic and csum_tcpudp_nofold for many platforms but not for PowerPC. Fixes: 01cfbad "ipv4: Update parameters for csum_tcpudp_magic to their original types" Cc: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-29Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 bugfix from Thomas Gleixner: "A single bugfix for the recent changes related to registering the boot cpu when this has not happened before prefill_possible_map(). The main problem with this change got fixed already, but we missed the case where the local APIC is not yet mapped, when prefill_possible_map() is invoked, so the registration of the boot cpu which has the APIC bit set in CPUID will explode. I should have seen that issue earlier, but all I can do now is feeling embarassed" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/smpboot: Init apic mapping before usage
2016-10-29Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We haven't seen a whole lot of fixes for the first two weeks since the merge window, but here is the batch that we have at the moment. Nothing sticks out as particularly bad or scary, it's mostly a handful of smaller fixes to several platforms. The Uniphier reset controller changes could probably have been delayed to 4.10, but they're not scary and just plumbing up driver changes that went in during the merge window. We're also adding another maintainer to Marvell Berlin platforms, to help out when Sebastian is too busy. Yay teamwork!" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: mach-imx6q: Fix the PHY ID mask for AR8031 ARM: dts: vf610: fix IRQ flag of global timer ARM: imx: gpc: Fix the imx_gpc_genpd_init() error path ARM: imx: gpc: Initialize all power domains arm64: dts: Updated NAND DT properties for NS2 SVK arm64: dts: uniphier: change MIO node to SD control node ARM: dts: uniphier: change MIO node to SD control node reset: uniphier: rename MIO reset to SD reset for Pro5, PXs2, LD20 SoCs arm64: uniphier: select ARCH_HAS_RESET_CONTROLLER ARM: uniphier: select ARCH_HAS_RESET_CONTROLLER arm64: dts: Add timer erratum property for LS2080A and LS1043A arm64: dts: rockchip: remove the abuse of keep-power-in-suspend ARM: multi_v7_defconfig: Enable Intel e1000e driver MAINTAINERS: add myself as Marvell berlin SoC maintainer bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TEST ARM: dts: fix the SD card on the Snowball arm64: dts: rockchip: remove always-on and boot-on from vcc_sd arm64: dts: marvell: fix clocksource for CP110 master SPI0 ARM: mvebu: Select corediv clk for all mvebu v7 SoC
2016-10-29Merge tag 'v4.9-rockchip-dts64-fixes1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into fixes Correct regulator handling on Rockchip arm64 boards to make bind/unbind calls work correctly and remove a sdio-only property from non-sdio mmc hosts, that accidentially was added there. * tag 'v4.9-rockchip-dts64-fixes1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip: arm64: dts: rockchip: remove the abuse of keep-power-in-suspend arm64: dts: rockchip: remove always-on and boot-on from vcc_sd Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-29Merge tag 'arm-soc/for-4.9/devicetree-arm64-fixes' of ↵Olof Johansson
http://github.com/Broadcom/stblinux into fixes This pull request contains a single fix for Broadcom ARM64-based SoCs: - Ray adds the required bus width and OOB sector size properties to the Northstar 2 SVK reference board in order for the NAND controller to work properly * tag 'arm-soc/for-4.9/devicetree-arm64-fixes' of http://github.com/Broadcom/stblinux: arm64: dts: Updated NAND DT properties for NS2 SVK Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-29Merge tag 'imx-fixes-4.9' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes The i.MX fixes for 4.9: - A couple of patches from Fabio to fix the GPC power domain regression which is caused by PM Domain core change 0159ec670763dd ("PM / Domains: Verify the PM domain is present when adding a provider"), and a related kernel crash seen with multi_v7_defconfig build. - Correct the PHY ID mask for AR8031 to match phy driver code. - Apply new added timer erratum A008585 for LS1043A and LS2080A SoC. - Correct vf610 global timer IRQ flag to avoid warning from gic driver after commit 992345a58e0c ("irqchip/gic: WARN if setting the interrupt type for a PPI fails"). * tag 'imx-fixes-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: ARM: imx: mach-imx6q: Fix the PHY ID mask for AR8031 ARM: dts: vf610: fix IRQ flag of global timer ARM: imx: gpc: Fix the imx_gpc_genpd_init() error path ARM: imx: gpc: Initialize all power domains arm64: dts: Add timer erratum property for LS2080A and LS1043A Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-29Merge tag 'uniphier-fixes-v4.9' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier into fixes UniPhier ARM SoC fixes for v4.9 - Add "select ARCH_HAS_RESET_CONTROLLER" in Kconfig - Rename wrongly-named mioctrl to sdctrl * tag 'uniphier-fixes-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-uniphier: arm64: dts: uniphier: change MIO node to SD control node ARM: dts: uniphier: change MIO node to SD control node reset: uniphier: rename MIO reset to SD reset for Pro5, PXs2, LD20 SoCs arm64: uniphier: select ARCH_HAS_RESET_CONTROLLER ARM: uniphier: select ARCH_HAS_RESET_CONTROLLER Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-29x86/smpboot: Init apic mapping before usageThomas Gleixner
The recent changes, which forced the registration of the boot cpu on UP systems, which do not have ACPI tables, have been fixed for systems w/o local APIC, but left a wreckage for systems which have neither ACPI nor mptables, but the CPU has an APIC, e.g. virtualbox. The boot process crashes in prefill_possible_map() as it wants to register the boot cpu, which needs to access the local apic, but the local APIC is not yet mapped. There is no reason why init_apic_mapping() can't be invoked before prefill_possible_map(). So instead of playing another silly early mapping game, as the ACPI/mptables code does, we just move init_apic_mapping() before the call to prefill_possible_map(). In hindsight, I should have noticed that combination earlier. Sorry for the churn (also in stable)! Fixes: ff8560512b8d ("x86/boot/smp: Don't try to poke disabled/non-existent APIC") Reported-and-debugged-by: Michal Necasek <michal.necasek@oracle.com> Reported-and-tested-by: Wolfgang Bauer <wbauer@tmo.at> Cc: prarit@redhat.com Cc: ville.syrjala@linux.intel.com Cc: michael.thayer@oracle.com Cc: knut.osmundsen@oracle.com Cc: frank.mehnert@oracle.com Cc: Borislav Petkov <bp@alien8.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1610282114380.5053@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-28Merge tag 'acpi-4.9-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI fixes from Rafael Wysocki: "These fix recent ACPICA regressions, an older PCI IRQ management regression, and an incorrect return value of a function in the APEI code. Specifics: - Fix three ACPICA issues related to the interpreter locking and introduced by recent changes in that area (Lv Zheng). - Fix a PCI IRQ management regression introduced during the 4.7 cycle and related to the configuration of shared IRQs on systems with an ISA bus (Sinan Kaya). - Fix up a return value of one function in the APEI code (Punit Agrawal)" * tag 'acpi-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPICA: Dispatcher: Fix interpreter locking around acpi_ev_initialize_region() ACPICA: Dispatcher: Fix an unbalanced lock exit path in acpi_ds_auto_serialize_method() ACPICA: Dispatcher: Fix order issue of method termination ACPI / APEI: Fix incorrect return value of ghes_proc() ACPI/PCI: pci_link: Include PIRQ_PENALTY_PCI_USING for ISA IRQs ACPI/PCI: pci_link: penalize SCI correctly ACPI/PCI/IRQ: assign ISA IRQ directly during early boot stages
2016-10-28Merge tag 'arc-4.9-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC updates from Vineet Gupta: - support IDU intc for UP builds - support gz, lzma compressed uImage [Daniel Mentz] - adjust /proc/cpuinfo for non-continuous cpu ids [Noam Camus] - syscall for userspace cmpxchg assist for configs lacking hardware atomics - rework of boot log printing mainly for identifying older arc700 cores - retiring some old code, build toggles * tag 'arc-4.9-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: module: print pretty section names ARC: module: elide loop to save reference to .eh_frame ARC: mm: retire ARC_DBG_TLB_MISS_COUNT... ARC: build: retire old toggles ARC: boot log: refactor cpu name/release printing ARC: boot log: remove awkward space comma from MMU line ARC: boot log: don't assume SWAPE instruction support ARC: boot log: refactor printing abt features not captured in BCRs ARCv2: boot log: print IOC exists as well as enabled status ARCv2: IOC: use @ioc_enable not @ioc_exist where intended ARC: syscall for userspace cmpxchg assist ARC: fix build warning in elf.h ARC: Adjust cpuinfo for non-continuous cpu ids ARC: [build] Support gz, lzma compressed uImage ARCv2: intc: untangle SMP, MCIP and IDU
2016-10-28Merge tag 'powerpc-4.9-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: "Fixes marked for stable: - Convert cmp to cmpd in idle enter sequence (Segher Boessenkool) - cxl: Fix leaking pid refs in some error paths (Vaibhav Jain) - Re-fix race condition between going idle and entering guest (Paul Mackerras) - Fix race condition in setting lock bit in idle/wakeup code (Paul Mackerras) - radix: Use tlbiel only if we ever ran on the current cpu (Aneesh Kumar K.V) - relocation, register save fixes for system reset interrupt (Nicholas Piggin) Fixes for code merged this cycle: - Fix CONFIG_ALIVEC typo in restore_tm_state() (Valentin Rothberg) - KVM: PPC: Book3S HV: Fix build error when SMP=n (Michael Ellerman)" * tag 'powerpc-4.9-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc/64s: relocation, register save fixes for system reset interrupt powerpc/mm/radix: Use tlbiel only if we ever ran on the current cpu powerpc/process: Fix CONFIG_ALIVEC typo in restore_tm_state() powerpc/64: Fix race condition in setting lock bit in idle/wakeup code powerpc/64: Re-fix race condition between going idle and entering guest cxl: Fix leaking pid refs in some error paths powerpc: Convert cmp to cmpd in idle enter sequence KVM: PPC: Book3S HV: Fix build error when SMP=n
2016-10-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc kernel fixes: a virtualization environment related fix, an uncore PMU driver removal handling fix, a PowerPC fix and new events for Knights Landing" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel: Honour the CPUID for number of fixed counters in hypervisors perf/powerpc: Don't call perf_event_disable() from atomic context perf/core: Protect PMU device removal with a 'pmu_bus_running' check, to fix CONFIG_DEBUG_TEST_DRIVER_REMOVE=y kernel panic perf/x86/intel/cstate: Add C-state residency events for Knights Landing
2016-10-28Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Will Deacon: "Three arm64 fixes for -rc3. They're all pretty straightforward: a couple of NUMA issues from the Huawei folks and a thinko in __page_to_voff that seems to be benign, but is certainly better off fixed. Summary: - couple of NUMA fixes - thinko in __page_to_voff" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: mm: fix __page_to_voff definition arm64/numa: fix incorrect log for memory-less node arm64/numa: fix pcpu_cpu_distance() to get correct CPU proximity
2016-10-28Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: three build fixes, an unwinder fix and a microcode loader fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/microcode/AMD: Fix more fallout from CONFIG_RANDOMIZE_MEMORY=y x86: Fix export for mcount and __fentry__ x86/quirks: Hide maybe-uninitialized warning x86/build: Fix build with older GCC versions x86/unwind: Fix empty stack dereference in guess unwinder
2016-10-28ARC: module: print pretty section namesVineet Gupta
Now that we have referece to section name string table in apply_relocate_add(), use it to - print the name of section being relocated - print symbol with NULL name (since it refers to a section) before | Section to fixup 7000a060 | ========================================================= | rela->r_off | rela->addend | sym->st_value | ADDR | VALUE | ========================================================= | 1c 0 7000e000 7000a07c 7000e000 [] | 40 0 7000a000 7000a0a0 7000a000 [] after | Section to fixup .eh_frame @7000a060 | ========================================================= | r_off r_add st_value ADDRESS VALUE | ========================================================= | 1c 0 7000e000 7000a07c 7000e000 [.init.text] | 40 0 7000a000 7000a0a0 7000a000 [.exit.text] Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-10-28ARC: module: elide loop to save reference to .eh_frameVineet Gupta
The loop was really needed in .debug_frame regime where wanted make it as SH_ALLOC so that apply_relocate_add() would process it. That's not needed for .eh_frame, so we check this in apply_relocate_add() which gets called for each section. Note that we need to save reference to "section name strings" section in module_frob_arch_sections() since apply_relocate_add() doesn't get that Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-10-28ARC: mm: retire ARC_DBG_TLB_MISS_COUNT...Vineet Gupta
... given that we have perf counters abel to do the same thing non intrusively Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-10-28ARC: build: retire old togglesVineet Gupta
These are really ancient toggles and tools no longer require them to be passed. This paves way for deprecating them in long run. Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2016-10-28ARC: boot log: refactor cpu name/release printingVineet Gupta
The motivation is to identify ARC750 vs. ARC770 (we currently print generic "ARC700"). A given ARC700 release could be 750 or 770, with same ARCNUM (or family identifier which is unfortunate). The existing arc_cpu_tbl[] kept a single concatenated string for core name and release which thus doesn't work for 750 vs. 770 identification. So split this into 2 tables, one with core names and other with release. And while we are at it, get rid of the range checking for family numbers. We just document the known to exist cores running Linux and ditch others. With this in place, we add detection of ARC750 which is - cores 0x33 and before - cores 0x34 and later with MMUv2 Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
