path: root/arch
2014-11-09Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - enable bpf syscall for compat - cpu_suspend fix when checking the idle state type - defconfig update * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: defconfig: update defconfig for 3.18 arm64: compat: Enable bpf syscall arm64: psci: fix cpu_suspend to check idle state type for index
2014-11-09Merge tag 'armsoc-for-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another quiet week: - a fix to silence edma probe error on non-supported platforms from Arnd - a fix to enable the PL clock for Parallella, to make mainline usable with the SDK. - a somewhat verbose fix for the PLL clock tree on VF610 - enabling of SD/MMC on one of the VF610-based boards (for testing) - a fix for i.MX where CONFIG_SPI used to be implicitly enabled and now needs to be added to the defconfig instead - another maintainer added for bcm2835: Lee Jones" * tag 'armsoc-for-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: zynq: Enable PL clocks for Parallella dma: edma: move device registration to platform code ARM: dts: vf610: add SD node to cosmic dts MAINTAINERS: update bcm2835 entry ARM: imx: Fix the removal of CONFIG_SPI option ARM: imx: clk-vf610: define PLL's clock tree
2014-11-08ARM: dts: zynq: Enable PL clocks for ParallellaAndreas Färber
The Parallella board comes with a U-Boot bootloader that loads one of two predefined FPGA bitstreams before booting the kernel. Both define an AXI interface to the on-board Epiphany processor. Enable clocks FCLK0..FCLK3 for the Programmable Logic by default. Otherwise accessing, e.g., the ESYSRESET register freezes the board, as seen with the Epiphany SDK tools e-reset and e-hw-rev, using /dev/mem. Cc: <stable@vger.kernel.org> # 3.17.x Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-07Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This weeks' round of MIPS bug fixes for 3.18: - wire up the bpf syscall - fix TLB dump output for R3000 class TLBs - fix strnlen_user return value if no NUL character was found. - fix build with binutils 2.24.51+. While there is no binutils 2.25 release yet, toolchains derived from binutils 2.24.51+ are already in common use. - the Octeon GPIO code forgot to offline GPIO IRQs. - fix build error for XLP. - fix possible BUG assertion with EVA for CMA" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Fix build with binutils 2.24.51+ MIPS: R3000: Fix debug output for Virtual page number MIPS: Fix strnlen_user() return value in case of overlong strings. MIPS: CMA: Do not reserve memory if not required MIPS: Wire up bpf syscall. MIPS/Xlp: Remove the dead function destroy_irq() to fix build error MIPS: Octeon: Make Octeon GPIO IRQ chip CPU hotplug-aware
2014-11-07MIPS: Fix build with binutils 2.24.51+Manuel Lauss
Starting with version 2.24.51.20140728 MIPS binutils complain loudly about mixing soft-float and hard-float object files, leading to this build failure since GCC is invoked with "-msoft-float" on MIPS: {standard input}: Warning: .gnu_attribute 4,3 requires `softfloat' LD arch/mips/alchemy/common/built-in.o mipsel-softfloat-linux-gnu-ld: Warning: arch/mips/alchemy/common/built-in.o uses -msoft-float (set by arch/mips/alchemy/common/prom.o), arch/mips/alchemy/common/sleeper.o uses -mhard-float To fix this, we detect if GAS is new enough to support "-msoft-float" command option, and if it does, we can let GCC pass it to GAS; but then we also need to sprinkle the files which make use of floating point registers with the necessary ".set hardfloat" directives. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Matthew Fortune <Matthew.Fortune@imgtec.com> Cc: Markos Chandras <Markos.Chandras@imgtec.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/8355/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-06MIPS: R3000: Fix debug output for Virtual page numberIsamu Mogi
Virtual page number of R3000 in entryhi is 20 bit from MSB. But in dump_tlb(), the bit mask to read it from entryhi is 19 bit (0xffffe000). The patch fixes that to 0xfffff000. Signed-off-by: Isamu Mogi <isamu@leafytree.jp> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/8290/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-05dma: edma: move device registration to platform codeArnd Bergmann
The horrible split between the low-level part of the edma support and the dmaengine front-end driver causes problems on multiplatform kernels. This is an attempt to improve the situation slightly by only registering the dmaengine devices that are actually present. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: add missing include of linux/dma-mapping.h] Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "One small improvement for the cputime accounting, two bug fixes and an update for the default configuration files" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/ftrace: add ftrace_graph_is_dead() check s390: update default configuration s390/vdso: fix stack corruption s390/time: use stck clock fast for do_account_vtime
2014-11-05ARM: dts: vf610: add SD node to cosmic dtsOlof Johansson
Driver has been there since a while back, but the dts never seems to have been updated with the node (nor pinctrl). Do so now. Cc: Matt Porter <mporter@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-05arm64: defconfig: update defconfig for 3.18Will Deacon
This patch enables a few things missing from our defconfig: - PCI and MSI, including support for the x-gene host controller - BPF JIT - SPI, GPIO and MMC for Seattle - GPIO for x-gene - USB for Juno - RTC It also removes HMC_DRV, which was being built as a module for some reason. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-11-05arm64: compat: Enable bpf syscallCatalin Marinas
Following the arm32 commit 2d605a302972 (ARM: enable bpf syscall), wire this syscall for arm64 compat as well. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-11-04Merge tag 'imx-fixes-3.18-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes Merge "ARM: imx: fixes for 3.18, 2nd round" from Shawn Guo: "This is the second round of i.MX fixes for 3.18. The clk-vf610 fix is relatively big, because it needs some adaption to the change made by offending commit dc4805c2e78b (ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver). And it should have been sent to you for earlier -rc inclusion, but unfortunately it got delayed for some time because Stefan wasn't aware of my email address change." The i.MX fixes for 3.18, 2nd round: - Fix a regression on Vybrid platform which is caused by commit dc4805c2e78b (ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver), and results in a missing configuration on PLL clocks. - Fix a regression with i.MX defconfig files where CONFIG_SPI option gets lost accidentally. * tag 'imx-fixes-3.18-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (460 commits) ARM: imx: Fix the removal of CONFIG_SPI option ARM: imx: clk-vf610: define PLL's clock tree + Linux 3.18-rc3 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc fixes from Michael Ellerman: "Some more powerpc fixes if you please" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc: use device_online/offline() instead of cpu_up/down() powerpc/powernv: Properly fix LPC debugfs endianness powerpc: do_notify_resume can be called with bad thread_info flags argument powerpc/fadump: Fix endianess issues in firmware assisted dump handling powerpc: Fix section mismatch warning
2014-11-04MIPS: Fix strnlen_user() return value in case of overlong strings.Ralf Baechle
We were returning maxlen like the userland strnlen if no '\0' character was encountered while the kernel version is expected to return a value larger than maxlen. Fixed to return maxlen + 1. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-04ARM: imx: Fix the removal of CONFIG_SPI optionFabio Estevam
Since 64546e9fe3a5b8c ("ARM: imx_v6_v7_defconfig updates") and commit 0650f855d2e4b0b9 ("ARM: imx_v4_v5_defconfig: Select CONFIG_IMX_WEIM") CONFIG_SPI selection was dropped by savedefconfig for imx_v4_v5_defconfig and imx_v6_v7_defconfig. In order to keep the same behaviour as previous kernel versions and avoid regressions, let's add CONFIG_SPI option back. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-11-04ARM: imx: clk-vf610: define PLL's clock treeimx-fixes-3.18-2Stefan Agner
So far, the required PLL's (PLL1/PLL2/PLL5) have been initialized by boot loader and the kernel code defined fixed rates according to those default configurations. Beginning with the USB PLL7 the code started to initialize the PLL's itself (using imx_clk_pllv3). However, since commit dc4805c2e78ba5a22ea1632f3e3e4ee601a1743b (ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver) imx_clk_pllv3 no longer takes care of the ENABLE and BYPASS bits, hence the USB PLL were not configured correctly anymore. This patch not only fixes those USB PLL's, but also makes use of the imx_clk_pllv3 for all PLL's and alignes the code with the PLL support of the i.MX6 series. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-11-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k update from Geert Uytterhoeven. Just wiring up the bpf system call. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Wire up bpf
2014-11-03Merge tag 'armsoc-for-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A surprisingly small batch of fixes for -rc3. Suspiciously small, I'd say. Anyway, most of this are a few defconfig updates. Some for omap to deal with kernel binary size (moving ipv6 to module, etc). A larger one for socfpga that refreshes with some churn, but also turns on a few options that makes the newly-added board in my bootfarm usable for testing. OMAP3 will also now warn when booted with legacy (non-DT) boot protocols, hopefully encouraging those who still care about some of those platforms to submit DT support and report bugs where needed. Nothing stops working though, this is just to warn for future deprecation. Beyond this, very few actual bugfixes. A PXA fix for DEBUG_LL boot hangs, a missing terminting entry in a dt_match array on RealView a MTD fix on OMAP with NAND" [ Obviously missed rc3, will make rc4 instead ;) ] * tag 'armsoc-for-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: drop list entry for davinci ARM: OMAP2+: Warn about deprecated legacy booting mode ARM: omap2plus_defconfig: Fix errors with NAND BCH ARM: multi_v7_defconfig: fix support for APQ8084 soc: versatile: Add terminating entry for realview_soc_of_match ARM: ixp4xx: remove compilation warnings in io.h MAINTAINERS: Add Soren as reviewer for Zynq ARM: omap2plus_defconfig: Fix bloat caused by having ipv6 built-in ARM: socfpga_defconfig: Update defconfig for SoCFPGA ARM: pxa: fix hang on startup with DEBUG_LL
2014-11-02Merge tag 'fixes-against-v3.18-rc2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v3.18-rc2" from Tony Lindgren: Few fixes for omaps to enable NAND BCH so devices won't produce errors when booted with omap2plus_defconfig, and reduce bloat by making IPV6 a loadable module. Also let's add a warning about legacy boot being deprecated for omap3. We now have things working with device tree, and only omap3 is still booting in legacy mode. So hopefully this warning will help move the remaining legacy mode users to boot with device tree. As the total reduction of code and static data is somewhere around 20000 lines of code once we remove omap3 legacy mode booting, we really do want to make omap3 to boot also in device tree mode only over the next few merge cycles. * tag 'fixes-against-v3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (407 commits) ARM: OMAP2+: Warn about deprecated legacy booting mode ARM: omap2plus_defconfig: Fix errors with NAND BCH ARM: omap2plus_defconfig: Fix bloat caused by having ipv6 built-in + Linux 3.18-rc2 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-02Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: - add the new bpf syscall to ARM. - drop a redundant return statement in __iommu_alloc_remap() - fix a performance issue noticed by Thomas Petazzoni with kmap_atomic(). - fix an issue with the L2 cache OF parsing code which caused it to incorrectly print warnings on each boot, and make the warning text more consistent with the rest of the code * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8180/1: mm: implement no-highmem fast path in kmap_atomic_pfn() ARM: 8183/1: l2c: Improve l2c310_of_parse() error message ARM: 8181/1: Drop extra return statement ARM: 8182/1: l2c: Make l2x0_cache_size_of_parse() return 'int' ARM: enable bpf syscall
2014-11-02Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "A small set of x86 fixes. The most serious is an SRCU lockdep fix. A bit late - needed some time to test the SRCU fix, which only came in on Friday" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: vmx: defer load of APIC access page address during reset KVM: nVMX: Disable preemption while reading from shadow VMCS KVM: x86: Fix far-jump to non-canonical check KVM: emulator: fix execution close to the segment limit KVM: emulator: fix error code for __linearize
2014-11-02KVM: vmx: defer load of APIC access page address during resetPaolo Bonzini
Most call paths to vmx_vcpu_reset do not hold the SRCU lock. Defer loading the APIC access page to the next vmentry. This avoids the following lockdep splat: [ INFO: suspicious RCU usage. ] 3.18.0-rc2-test2+ #70 Not tainted ------------------------------- include/linux/kvm_host.h:474 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by qemu-system-x86/2371: #0: (&vcpu->mutex){+.+...}, at: [<ffffffffa037d800>] vcpu_load+0x20/0xd0 [kvm] stack backtrace: CPU: 4 PID: 2371 Comm: qemu-system-x86 Not tainted 3.18.0-rc2-test2+ #70 Hardware name: Dell Inc. OptiPlex 9010/0M9KCM, BIOS A12 01/10/2013 0000000000000001 ffff880209983ca8 ffffffff816f514f 0000000000000000 ffff8802099b8990 ffff880209983cd8 ffffffff810bd687 00000000000fee00 ffff880208a2c000 ffff880208a10000 ffff88020ef50040 ffff880209983d08 Call Trace: [<ffffffff816f514f>] dump_stack+0x4e/0x71 [<ffffffff810bd687>] lockdep_rcu_suspicious+0xe7/0x120 [<ffffffffa037d055>] gfn_to_memslot+0xd5/0xe0 [kvm] [<ffffffffa03807d3>] __gfn_to_pfn+0x33/0x60 [kvm] [<ffffffffa0380885>] gfn_to_page+0x25/0x90 [kvm] [<ffffffffa038aeec>] kvm_vcpu_reload_apic_access_page+0x3c/0x80 [kvm] [<ffffffffa08f0a9c>] vmx_vcpu_reset+0x20c/0x460 [kvm_intel] [<ffffffffa039ab8e>] kvm_vcpu_reset+0x15e/0x1b0 [kvm] [<ffffffffa039ac0c>] kvm_arch_vcpu_setup+0x2c/0x50 [kvm] [<ffffffffa037f7e0>] kvm_vm_ioctl+0x1d0/0x780 [kvm] [<ffffffff810bc664>] ? __lock_is_held+0x54/0x80 [<ffffffff812231f0>] do_vfs_ioctl+0x300/0x520 [<ffffffff8122ee45>] ? __fget+0x5/0x250 [<ffffffff8122f0fa>] ? __fget_light+0x2a/0xe0 [<ffffffff81223491>] SyS_ioctl+0x81/0xa0 [<ffffffff816fed6d>] system_call_fastpath+0x16/0x1b Reported-by: Takashi Iwai <tiwai@suse.de> Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com> Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com> Tested-by: Wanpeng Li <wanpeng.li@linux.intel.com> Fixes: 38b9917350cb2946e368ba684cfc33d1672f104e Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-02KVM: nVMX: Disable preemption while reading from shadow VMCSJan Kiszka
In order to access the shadow VMCS, we need to load it. At this point, vmx->loaded_vmcs->vmcs and the actually loaded one start to differ. If we now get preempted by Linux, vmx_vcpu_put and, on return, the vmx_vcpu_load will work against the wrong vmcs. That can cause copy_shadow_to_vmcs12 to corrupt the vmcs12 state. Fix the issue by disabling preemption during the copy operation. copy_vmcs12_to_shadow is safe from this issue as it is executed by vmx_vcpu_run when preemption is already disabled before vmentry. This bug is exposed by running Jailhouse within KVM on CPUs with shadow VMCS support. Jailhouse never expects an interrupt pending vmexit, but the bug can cause it if, after copy_shadow_to_vmcs12 is preempted, the active VMCS happens to have the virtual interrupt pending flag set in the CPU-based execution controls. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-02KVM: x86: Fix far-jump to non-canonical checkNadav Amit
Commit d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far jumps") introduced a bug that caused the fix to be incomplete. Due to incorrect evaluation, far jump to segment with L bit cleared (i.e., 32-bit segment) and RIP with any of the high bits set (i.e, RIP[63:32] != 0) set may not trigger #GP. As we know, this imposes a security problem. In addition, the condition for two warnings was incorrect. Fixes: d1442d85cc30ea75f7d399474ca738e0bc96f715 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> [Add #ifdef CONFIG_X86_64 to avoid complaints of undefined behavior. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-02powerpc: use device_online/offline() instead of cpu_up/down()Dan Streetman
In powerpc pseries platform dlpar operations, use device_online() and device_offline() instead of cpu_up() and cpu_down(). Calling cpu_up/down() directly does not update the cpu device offline field, which is used to online/offline a cpu from sysfs. Calling device_online/offline() instead keeps the sysfs cpu online value correct. The hotplug lock, which is required to be held when calling device_online/offline(), is already held when dlpar_online/offline_cpu() are called, since they are called only from cpu_probe|release_store(). This patch fixes errors on phyp (PowerVM) systems that have cpu(s) added/removed using dlpar operations; without this patch, the /sys/devices/system/cpu/cpuN/online nodes do not correctly show the online state of added/removed cpus. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com> Fixes: 0902a9044fa5 ("Driver core: Use generic offline/online for CPU offline/online") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-31x86_64, entry: Fix out of bounds read on sysenterAndy Lutomirski
Rusty noticed a Really Bad Bug (tm) in my NT fix. The entry code reads out of bounds, causing the NT fix to be unreliable. But, and this is much, much worse, if your stack is somehow just below the top of the direct map (or a hole), you read out of bounds and crash. Excerpt from the crash: [ 1.129513] RSP: 0018:ffff88001da4bf88 EFLAGS: 00010296 2b:* f7 84 24 90 00 00 00 testl $0x4000,0x90(%rsp) That read is deterministically above the top of the stack. I thought I even single-stepped through this code when I wrote it to check the offset, but I clearly screwed it up. Fixes: 8c7aa698baca ("x86_64, entry: Filter RFLAGS.NT on entry from userspace") Reported-by: Rusty Russell <rusty@ozlabs.org> Cc: stable@vger.kernel.org Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A bit has accumulated, but it's been a week or so since my last batch of post-merge-window fixes, so... 1) Missing module license in netfilter reject module, from Pablo. Lots of people ran into this. 2) Off by one in mac80211 baserate calculation, from Karl Beldan. 3) Fix incorrect return value from ax88179_178a driver's set_mac_addr op, which broke use of it with bonding. From Ian Morgan. 4) Checking of skb_gso_segment()'s return value was not all encompassing, it can return an SKB pointer, a pointer error, or NULL. Fix from Florian Westphal. This is crummy, and longer term will be fixed to just return error pointers or a real SKB. 6) Encapsulation offloads not being handled by skb_gso_transport_seglen(). From Florian Westphal. 7) Fix deadlock in TIPC stack, from Ying Xue. 8) Fix performance regression from using rhashtable for netlink sockets. The problem was the synchronize_net() invoked for every socket destroy. From Thomas Graf. 9) Fix bug in eBPF verifier, and remove the strong dependency of BPF on NET. From Alexei Starovoitov. 10) In qdisc_create(), use the correct interface to allocate ->cpu_bstats, otherwise the u64_stats_sync member isn't initialized properly. From Sabrina Dubroca. 11) Off by one in ip_set_nfnl_get_byindex(), from Dan Carpenter. 12) nf_tables_newchain() was erroneously expecting error pointers from netdev_alloc_pcpu_stats(). It only returna a valid pointer or NULL. From Sabrina Dubroca. 13) Fix use-after-free in _decode_session6(), from Li RongQing. 14) When we set the TX flow hash on a socket, we mistakenly do so before we've nailed down the final source port. Move the setting deeper to fix this. From Sathya Perla. 15) NAPI budget accounting in amd-xgbe driver was counting descriptors instead of full packets, fix from Thomas Lendacky. 16) Fix total_data_buflen calculation in hyperv driver, from Haiyang Zhang. 17) Fix bcma driver build with OF_ADDRESS disabled, from Hauke Mehrtens. 18) Fix mis-use of per-cpu memory in TCP md5 code. The problem is that something that ends up being vmalloc memory can't be passed to the crypto hash routines via scatter-gather lists. From Eric Dumazet. 19) Fix regression in promiscuous mode enabling in cdc-ether, from Olivier Blin. 20) Bucket eviction and frag entry killing can race with eachother, causing an unlink of the object from the wrong list. Fix from Nikolay Aleksandrov. 21) Missing initialization of spinlock in cxgb4 driver, from Anish Bhatt. 22) Do not cache ipv4 routing failures, otherwise if the sysctl for forwarding is subsequently enabled this won't be seen. From Nicolas Cavallari" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (131 commits) drivers: net: cpsw: Support ALLMULTI and fix IFF_PROMISC in switch mode drivers: net: cpsw: Fix broken loop condition in switch mode net: ethtool: Return -EOPNOTSUPP if user space tries to read EEPROM with lengh 0 stmmac: pci: set default of the filter bins net: smc91x: Fix gpios for device tree based booting mpls: Allow mpls_gso to be built as module mpls: Fix mpls_gso handler. r8152: stop submitting intr for -EPROTO netfilter: nft_reject_bridge: restrict reject to prerouting and input netfilter: nft_reject_bridge: don't use IP stack to reject traffic netfilter: nf_reject_ipv6: split nf_send_reset6() in smaller functions netfilter: nf_reject_ipv4: split nf_send_reset() in smaller functions netfilter: nf_tables_bridge: update hook_mask to allow {pre,post}routing drivers/net: macvtap and tun depend on INET drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets drivers/net: Disable UFO through virtio net: skb_fclone_busy() needs to detect orphaned skb gre: Use inner mac length when computing tunnel length mlx4: Avoid leaking steering rules on flow creation error flow net/mlx4_en: Don't attempt to TX offload the outer UDP checksum for VXLAN ...
2014-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc update from David Miller: "Two changes: 1) It makes no sense to execute a VTOC partition table request in the Sun virtual block device driver and fail to load if it doesn't succeed because a) we don't use the result at all and b) it won't succeed if there is an EFI partition on the disk, for example. We read the partition table via the normal means in the block layer anyways, so this is really completely useless, so just remove it. From Dwight Engen. 2) Hook up new bpf system call" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sunvdc: don't call VD_OP_GET_VTOC sparc: Hook up bpf system call.
2014-10-31Merge tag 'microblaze-3.18-rc3' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull Microblaze updates from Michal Simek: - wire-up new bpf syscall - fix PCI bug - fix Kconfig warning * tag 'microblaze-3.18-rc3' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Wire up bpf syscall microblaze: Fix IO space breakage after of_pci_range_to_resource() change microblaze: Fix missing NR_CPUS in menuconfig
2014-10-31Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Fixes from all around the place: - hyper-V 32-bit PAE guest kernel fix - two IRQ allocation fixes on certain x86 boards - intel-mid boot crash fix - intel-quark quirk - /proc/interrupts duplicate irq chip name fix - cma boot crash fix - syscall audit fix - boot crash fix with certain TSC configurations (seen on Qemu) - smpboot.c build warning fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, pageattr: Prevent overflow in slow_virt_to_phys() for X86_PAE ACPI, irq, x86: Return IRQ instead of GSI in mp_register_gsi() x86, intel-mid: Create IRQs for APB timers and RTC timers x86: Don't enable F00F workaround on Intel Quark processors x86/irq: Fix XT-PIC-XT-PIC in /proc/interrupts x86, cma: Reserve DMA contiguous area after initmem_init() i386/audit: stop scribbling on the stack frame x86, apic: Handle a bad TSC more gracefully x86: ACPI: Do not translate GSI number if IOAPIC is disabled x86/smpboot: Move data structure to its primary usage scope
2014-10-31Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Various scheduler fixes all over the place: three SCHED_DL fixes, three sched/numa fixes, two generic race fixes and a comment fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/dl: Fix preemption checks sched: Update comments for CLONE_NEWNS sched: stop the unbound recursion in preempt_schedule_context() sched/fair: Fix division by zero sysctl_numa_balancing_scan_size sched/fair: Care divide error in update_task_scan_period() sched/numa: Fix unsafe get_task_struct() in task_numa_assign() sched/deadline: Fix races between rt_mutex_setprio() and dl_task_timer() sched/deadline: Don't replenish from a !SCHED_DEADLINE entity sched: Fix race between task_group and sched_task_group
2014-10-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus on the kernel side: - a revert for a newly introduced PMU driver which isn't complete yet and where we ran out of time with fixes (to be tried again in v3.19) - this makes up for a large chunk of the diffstat. - compilation warning fixes - a printk message fix - event_idx usage fixes/cleanups" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Trivial typo fix for --demangle perf tools: Fix report -F dso_from for data without branch info perf tools: Fix report -F dso_to for data without branch info perf tools: Fix report -F symbol_from for data without branch info perf tools: Fix report -F symbol_to for data without branch info perf tools: Fix report -F mispredict for data without branch info perf tools: Fix report -F in_tx for data without branch info perf tools: Fix report -F abort for data without branch info perf tools: Make CPUINFO_PROC an array to support different kernel versions perf callchain: Use global caching provided by libunwind perf/x86/intel: Revert incomplete and undocumented Broadwell client support perf/x86: Fix compile warnings for intel_uncore perf: Fix typos in sample code in the perf_event.h header perf: Fix and clean up initialization of pmu::event_idx perf: Fix bogus kernel printk perf diff: Add missing hists__init() call at tool start
2014-10-31net: smc91x: Fix gpios for device tree based bootingTony Lindgren
With legacy booting, the platform init code was taking care of the configuring of GPIOs. With device tree based booting, things may or may not work depending what bootloader has configured or if the legacy platform code gets called. Let's add support for the pwrdn and reset GPIOs to the smc91x driver to fix the issues of smc91x not working properly when booted in device tree mode. And let's change n900 to use these settings as some versions of the bootloader do not configure things properly causing errors. Reported-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-31powerpc/powernv: Properly fix LPC debugfs endiannessBenjamin Herrenschmidt
Endian is hard, especially when I designed a stupid FW interface, and I should know better... oh well, this is attempt #2 at fixing this properly. This time it seems to work with all access sizes and I can run my flashing tool (which exercises all sort of access sizes and types to access the SPI controller in the BMC) just fine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: stable@vger.kernel.org Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-31powerpc: do_notify_resume can be called with bad thread_info flags argumentAnton Blanchard
Back in 7230c5644188 ("powerpc: Rework lazy-interrupt handling") we added a call out to restore_interrupts() (written in c) before calling do_notify_resume: bl restore_interrupts addi r3,r1,STACK_FRAME_OVERHEAD bl do_notify_resume Unfortunately do_notify_resume takes two arguments, the second one being the thread_info flags: void do_notify_resume(struct pt_regs *regs, unsigned long thread_info_flags) We do populate r4 (the second argument) earlier, but restore_interrupts() is free to muck it up all it wants. My guess is the gcc compiler gods shone down on us and its register allocator never used r4. Sometimes, rarely, luck is on our side. LLVM on the other hand did trample r4. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@vger.kernel.org Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-30arm64: psci: fix cpu_suspend to check idle state type for indexAmit Daniel Kachhap
This fix rectifies the psci cpu_suspend implementation to check the PSCI power state parameter type field associated with the requested idle state index. Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-10-30powerpc/fadump: Fix endianess issues in firmware assisted dump handlingHari Bathini
Firmware-assisted dump (fadump) kernel code is not endian safe. The below patch fixes this issue. Tested this patch with upstream kernel. Below output shows crash tool successfully opening LE fadump vmcore. # crash vmlinux vmcore GNU gdb (GDB) 7.6 This GDB was configured as "powerpc64le-unknown-linux-gnu"... KERNEL: vmlinux DUMPFILE: vmcore CPUS: 16 DATE: Wed Dec 31 19:00:00 1969 UPTIME: 00:03:28 LOAD AVERAGE: 0.46, 0.86, 0.41 TASKS: 268 NODENAME: linux-dhr2 RELEASE: 3.17.0-rc5-7-default VERSION: #6 SMP Tue Sep 30 01:06:34 EDT 2014 MACHINE: ppc64le (4116 Mhz) MEMORY: 40 GB PANIC: "Oops: Kernel access of bad area, sig: 11 [#1]" (check log for details) PID: 6223 COMMAND: "bash" TASK: c0000009661b2500 [THREAD_INFO: c000000967ac0000] CPU: 2 STATE: TASK_RUNNING (PANIC) Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com> [mpe: Make the comment in pSeries_lpar_hptab_clear() clearer] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-30powerpc: Fix section mismatch warningFabian Frederick
Add __init to MMU_setup() which uses __initdata boot_command_line. Also MMU_setup() is only called from MMU_init(), which is also __init. Warning appeared since commit 3e47d1474c2b. Fixes: 3e47d1474c2b ("powerpc: Remove powerpc specific cmd_line") Signed-off-by: Fabian Frederick <fabf@skynet.be> [mpe: Update changelog] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-29Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "21 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (21 commits) mm/balloon_compaction: fix deflation when compaction is disabled sh: fix sh770x SCIF memory regions zram: avoid NULL pointer access in concurrent situation mm/slab_common: don't check for duplicate cache names ocfs2: fix d_splice_alias() return code checking mm: rmap: split out page_remove_file_rmap() mm: memcontrol: fix missed end-writeback page accounting mm: page-writeback: inline account_page_dirtied() into single caller lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}() drivers/rtc/rtc-bq32k.c: fix register value memory-hotplug: clear pgdat which is allocated by bootmem in try_offline_node() drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock kernel/kmod: fix use-after-free of the sub_info structure drivers/rtc/rtc-pm8xxx.c: rework to support pm8941 rtc mm, thp: fix collapsing of hugepages on madvise drivers: of: add return value to of_reserved_mem_device_init() mm: free compound page with correct order gcov: add ARM64 to GCOV_PROFILE_ALL fsnotify: next_i is freed during fsnotify_unmount_inodes. mm/compaction.c: avoid premature range skip in isolate_migratepages_range ...
2014-10-29sh: fix sh770x SCIF memory regionsAndriy Skulysh
Resources scif1_resources & scif2_resources overlap. Actual SCIF region size is 0x10. This is regression from commit d850acf975be ("sh: Declare SCIF register base and IRQ as resources") Signed-off-by: Andriy Skulysh <askulysh@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29ARM: OMAP2+: Warn about deprecated legacy booting modeTony Lindgren
We're moving omaps to use device tree based booting and already have omap2, omap4, omap5, am335x and am437x booting in device tree only mode. Only omap3 still has legacy booting still around and we really want to make that device tree only. So let's add a warning about deprecated legacy booting so we get people to upgrade their boards to use device tree based booting and find out about any remaining issues. Note that for most boards we already have the .dts file and those can be booted with without changing the bootloader using the appended DTB mode. Acked-By: Sebastian Reichel <sre@kernel.org> Reviewed-by: Aaro Koskinen <aaro.koskinen@iki.fi> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-29ARM: omap2plus_defconfig: Fix errors with NAND BCHTony Lindgren
Looks like we need to have BCH enabled to get NAND working and to avoid getting: nand: error: CONFIG_MTD_NAND_ECC_BCH not enabled Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "There's some bug fixes or cleanups to facilitate fixes, a MAINTAINERS update, and a new syscall (bpf)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc/numa: ensure per-cpu NUMA mappings are correct on topology update powerpc/numa: use cached value of update->cpu in update_cpu_topology cxl: Fix PSL error due to duplicate segment table entries powerpc/mm: Use appropriate ESID mask in copro_calculate_slb() cxl: Refactor cxl_load_segment() and find_free_sste() cxl: Disable secondary hash in segment table Revert "powerpc/powernv: Fix endian bug in LPC bus debugfs accessors" powernv: Use _GLOBAL_TOC for opal wrappers powerpc: Wire up sys_bpf() syscall MAINTAINERS: nx-842 driver maintainer change powerpc/mm: Remove redundant #if case powerpc/mm: Fix build error with hugetlfs disabled
2014-10-29ARM: 8180/1: mm: implement no-highmem fast path in kmap_atomic_pfn()Thomas Petazzoni
Since CONFIG_HIGHMEM got enabled on ARMv5 Kirkwood, we have noticed a very significant drop in networking performance. The test were conducted on an OpenBlocks A7 board. Without this patch, the outgoing performance measured with iperf are: - highmem OFF, TSO OFF 544 Mbit/s - highmem OFF, TSO ON 942 Mbit/s - highmem ON, TSO OFF 306 Mbit/s - highmem ON, TSO ON 246 Mbit/s On this Kirkwood platform, the L2 cache is a Feroceon cache, and with this cache, all the range operations have to be done on virtual addresses and not physical addresses. Therefore, whenever CONFIG_HIGHMEM is enabled, the cache maintenance operations call kmap_atomic_pfn() and kunmap_atomic(). However, kmap_atomic_pfn() does not implement the same fast path for non-highmem pages as the one implemented in kmap_atomic(), and this is one of the reason for the performance drop. While this patch does not fully restore the performances, it clearly improves them a lot: without patch with patch - highmem ON, TSO OFF 306 Mbit/s 387 Mbit/s - highmem ON, TSO ON 246 Mbit/s 434 Mbit/s We're still far from the !CONFIG_HIGHMEM performances, but it does improve a bit the situation. Thanks a lot to Ezequiel Garcia and Gregory Clement for all the testing work around this topic. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-10-29ARM: 8183/1: l2c: Improve l2c310_of_parse() error messageFabio Estevam
Russell King suggested [1]: "I'd ask for one change. Please make all these messages start with "L2C-310 OF" not "PL310 OF:". The device is described in ARM documentation as a L2C-310 not PL310. (Also note the : is dropped too - most of the other messages don't have the : either.) The: "PL310 OF: cache setting yield illegal associativity PL310 OF: -1073346556 calculated, only 8 and 16 legal" message could also be changed to something like: "L2C-310 OF cache associativity %d invalid, only 8 or 16 permittedn" [1] http://www.spinics.net/lists/arm-kernel/msg372776.html Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-10-29ARM: 8181/1: Drop extra return statementLaura Abbott
Commit 513510ddba9650fc7da456eefeb0ead7632324f6 (common: dma-mapping: introduce common remapping functions) managed to end up with an extra return statement from the original patch. Drop it. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-10-29KVM: emulator: fix execution close to the segment limitPaolo Bonzini
Emulation of code that is 14 bytes to the segment limit or closer (e.g. RIP = 0xFFFFFFF2 after reset) is broken because we try to read as many as 15 bytes from the beginning of the instruction, and __linearize fails when the passed (address, size) pair reaches out of the segment. To fix this, let __linearize return the maximum accessible size (clamped to 2^32-1) for usage in __do_insn_fetch_bytes, and avoid the limit check by passing zero for the desired size. For expand-down segments, __linearize is performing a redundant check. (u32)(addr.ea + size - 1) <= lim can only happen if addr.ea is close to 4GB; in this case, addr.ea + size - 1 will also fail the check against the upper bound of the segment (which is provided by the D/B bit). After eliminating the redundant check, it is simple to compute the *max_size for expand-down segments too. Now that the limit check is done in __do_insn_fetch_bytes, we want to inject a general protection fault there if size < op_size (like __linearize would have done), instead of just aborting. This fixes booting Tiano Core from emulated flash with EPT disabled. Cc: stable@vger.kernel.org Fixes: 719d5a9b2487e0562f178f61e323c3dc18a8b200 Reported-by: Borislav Petkov <bp@suse.de> Tested-by: Borislav Petkov <bp@suse.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-29KVM: emulator: fix error code for __linearizePaolo Bonzini
The error code for #GP and #SS is zero when the segment is used to access an operand or an instruction. It is only non-zero when a segment register is being loaded; for limit checks this means cases such as: * for #GP, when RIP is beyond the limit on a far call (before the first instruction is executed). We do not implement this check, but it would be in em_jmp_far/em_call_far. * for #SS, if the new stack overflows during an inter-privilege-level call to a non-conforming code segment. We do not implement stack switching at all. So use an error code of zero. Reviewed-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-29ARM: 8182/1: l2c: Make l2x0_cache_size_of_parse() return 'int'Fabio Estevam
Since commit f3354ab67476dc80 ("ARM: 8169/1: l2c: parse cache properties from ePAPR definitions") the following error is seen on imx6q: [ 0.000000] PL310 OF: cache setting yield illegal associativity [ 0.000000] PL310 OF: -2147097556 calculated, only 8 and 16 legal As imx6q does not pass the "cache-size" and "cache-sets" properties in DT, the function l2x0_cache_size_of_parse() returns early and keep the 'associativity' pointer uninitialized. To fix this problem, return error codes inside l2x0_cache_size_of_parse() and only use the 'associativity' pointer result if l2x0_cache_size_of_parse() succeeds. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-10-29perf/x86/intel: Revert incomplete and undocumented Broadwell client supportIngo Molnar
These patches: 86a349a28b24 ("perf/x86/intel: Add Broadwell core support") c46e665f0377 ("perf/x86: Add INST_RETIRED.ALL workarounds") fdda3c4aacec ("perf/x86/intel: Use Broadwell cache event list for Haswell") introduced magic constants and unexplained changes: https://lkml.org/lkml/2014/10/28/1128 https://lkml.org/lkml/2014/10/27/325 https://lkml.org/lkml/2014/8/27/546 https://lkml.org/lkml/2014/10/28/546 Peter Zijlstra has attempted to help out, to clean up the mess: https://lkml.org/lkml/2014/10/28/543 But has not received helpful and constructive replies which makes me doubt wether it can all be finished in time until v3.18 is released. Despite various review feedback the author (Andi Kleen) has answered only few of the review questions and has generally been uncooperative, only giving replies when prompted repeatedly, and only giving minimal answers instead of constructively explaining and helping along the effort. That kind of behavior is not acceptable. There's also a boot crash on Intel E5-1630 v3 CPUs reported for another commit from Andi Kleen: e735b9db12d7 ("perf/x86/intel/uncore: Add Haswell-EP uncore support") https://lkml.org/lkml/2014/10/22/730 Which is not yet resolved. The uncore driver is independent in theory, but the crash makes me worry about how well all these patches were tested and makes me uneasy about the level of interminging that the Broadwell and Haswell code has received by the commits above. As a first step to resolve the mess revert the Broadwell client commits back to the v3.17 version, before we run out of time and problematic code hits a stable upstream kernel. ( If the Haswell-EP crash is not resolved via a simple fix then we'll have to revert the Haswell-EP uncore driver as well. ) The Broadwell client series has to be submitted in a clean fashion, with single, well documented changes per patch. If they are submitted in time and are accepted during review then they can possibly go into v3.19 but will need additional scrutiny due to the rocky history of this patch set. Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: eranian@google.com Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1409683455-29168-3-git-send-email-andi@firstfloor.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
