We should now use dev_set_drvdata to set the driver driver_data field.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/747/
Broken by d63c63e889bbeeaa461a8addf1245f89f3ce4ece (lmo) rsp.
f1e39a4a616cd9981a9decfd5332fd07a01abb8b (kernel.org).
Patchwork: http://patchwork.linux-mips.org/patch/746/
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: Loongson: Switch from flatmem to sparsemem
MIPS: Loongson: Disallow 4kB pages
MIPS: Add missing definition for MADV_HWPOISON.
MIPS: Fix build error if __xchg() is not getting inlined.
MIPS: IP22/IP28 Disable early printk to fix boot problems on some systems.
With flatmem hibernation for Loongson will fail, and there are also some
other problems such as broken files when using NFS or CIFS / Samba.
The config help of sparsemem says:
"This option provides some potential performance benefits, along with
decreased code complexity."
So to avoid the potential problems of FLATMEM, we disable FLATMEM directly
and use SPARSEMEM instead.
Related email thread:
http://groups.google.com/group/loongson-dev/browse_thread/thread/b6b65890ec2b0f24/feb43e5aa7f55d9b?show_docid=feb43e5aa7f55d9b
Reported-by: Tatu Kilappa <tatu.kilappa@gmail.com>
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/737/
Cc: linux-mips@linux-mips.org
Cc: zhangfx@lemote.com
Currently, with PAGE_SIZE_4KB, the kernel for loongson will hang on:
Kernel panic - not syncing: Attempted to kill init!
The possible reason is the cache aliases problem:
Loongson 2F has 64kb, 4 way L1 Cache, the way size is 16kb, which is bigger
then 4kb. so, If using 4kb page size, there is cache aliases problem.
To avoid this kind of problem, extra cache flushing. The 2nd possible
solution is 16kb page size which avoids cache aliases without the need for
extra cache flushes. So we disable 4kB pages until the aliasing issue is
solved.
Patchwork: http://patchwork.linux-mips.org/patch/736/
Thanks to Joseph S. Myers for reporting this.
Cc: "Joseph S. Myers" <joseph@codesourcery.com>
Patchwork: http://patchwork.linux-mips.org/patch/723/
If __xchg() is not getting inlined the outline version of the function
will have a reference to __xchg_called_with_bad_pointer() which does not
exist remaining. Fixed by using BUILD_BUG_ON() to check for allowable
operand sizes.
Patchwork: http://patchwork.linux-mips.org/patch/705/
Some Debian users have reported that the kernel hangs early during boot on
some IP22 systems. Thomas Bogendoerfer found that this is due to a "bad
interaction between CONFIG_EARLY_PRINTK and overwritten prom memory during
early boot". Since there's no fix yet, disable CONFIG_EARLY_PRINTK for now.
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/702/
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6:
alpha: Fixup last users of irq_chip->typename
Alpha: Rearrange thread info flags fixing two regressions
arch/alpha/kernel: Add kmalloc NULL tests
arch/alpha/kernel/sys_ruffian.c: Use DIV_ROUND_CLOSEST
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
Cc: Richard Henderson <rth@twiddle.net>
Cc: linux-alpha@vger.kernel.org
Signed-off-by: Matt Turner <mattst88@gmail.com>
The removal of the TIF_NOTIFY_RESUME flag, commit a583f1b54249b
"remove unused TIF_NOTIFY_RESUME flag," resulted in incorrect
setting of the unaligned access control flags by the prctl syscall.
The re-addition of the TIF_NOTIFY_RESUME flag, commit d0420c83f39f
"KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]"
further caused problems, namely incorrect operands to assembler code
as evidenced by:
AS arch/alpha/kernel/entry.o
arch/alpha/kernel/entry.S: Assembler messages:
arch/alpha/kernel/entry.S:326: Warning: operand out of range
(0x0000000000000406 is not between 0x0000000000000000 and
0x00000000000000ff)
Both regressions fixed by (1) rearranging TIF_NOTIFY_RESUME flag to be
in lower 8 bits of the thread info flags, and (2) making sure that
ALPHA_UAC_SHIFT matches the rearrangement of the thread info flags.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: David Howells <dhowells@redhat.com>,
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin:
Blackfin: fix SMP build error in start_thread()
Blackfin: fix memset in smp_send_reschedule() and -stop()
Blackfin: fix typo in ptrace poking
Blackfin: check for anomaly 05000475
Blackfin: work around testset anomaly 05000477
Blackfin: update anomaly lists
Blackfin: fix cache Kconfig typo
Blackfin: fix suspend/resume failure with some on-chip ROMs
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] Update mach-types
ARM: 5793/1: ARM: Check put_user fail in do_signal when enable OABI_COMPAT
MAINTAINERS: add maintainer information for AMBA primecell drivers
[ARM] pxa/spitz: fix compile regression on spitz
ARM: PNX4008: i2c-pnx: use the same dev_id for request_irq and free_irq
[ARM] pxa/cpufreq: fix index assignments for end marker
ARM: PNX4008: fix watchdog device driver name
[ARM] kmap: fix build errors with DEBUG_HIGHMEM enabled
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Fix DEBUG_HIGHMEM build break from d4515646699
Code was added to mm/higmem.c that depends on several
kmap types that powerpc does not support. We add dummy
invalid definitions for KM_NMI, KM_NM_PTE, and KM_IRQ_PTE.
According to list discussion, this fix should not be needed
anymore starting with 2.6.33. The code is commented to this
effect so hopefully we will remember to remove this.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sunsu: Use sunserial_console_termios() in sunsu_console_setup().
sunsu: Pass true 'ignore_line' to console match when RSC or LOM console.
serial: suncore: Fix RSC/LOM handling in sunserial_console_termios().
serial: suncore: Add 'ignore_line' argument to sunserial_console_match().
sunsu: Fix detection of SU ports which are RSC console or control.
sunsab: Do not set sunsab_reg.cons right before registering minors.
sparc64: Fix definition of VMEMMAP_SIZE.
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Enable ACPI PDC handshake for VIA/Centaur CPUs
Check that the result of kmalloc is not NULL before passing it to other
functions.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
when != x != NULL
when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
// </smpl>
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
// <smpl>
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
// </smpl>
kernel unwinding is broken with gcc >= 4.x. Part of the problem is that
binutils seems very sensitive to where the unwind information is stored.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Commit d5ce528c8e46fa5afb9 (Blackfin: convert irq/process to asm-generic)
incorrectly merged the smp and non-smp cases of start_thread() causing the
L1 stack to be setup on the SMP port instead of the UP port.
Signed-off-by: Graf Yang <graf.yang@analog.com>
To set zeroes the sizeof the struct should be used rather
than sizeof the pointer, kzalloc does that.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Commit c014e15a2f667f9 (Blackfin: convert ptrace to new memory functions)
introduced a copy & paste typo in the ptrace poke data/text handling. The
access_process_vm() function call was telling it to read instead of write.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
Parts that have on-chip L2 SRAM cannot safely utilize writeback caching
mode, so reject any attempts to use it.
Ironically, the atomic testset instruction cannot be interrupted else it
will produce incorrect results. So disable interrupts to help it out.
Add some recently documented anomalies (473, 474, 475, 477). Also stick
a "do not edit" notice in here so people know these are copies of some
master version.
The Kconfig option is "BFIN_EXTMEM_WRITETHROUGH", not "..._WRITETROUGH".
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Some Blackfin on-chip ROMs utilize some MDMA channels during the suspend
and resume process, but don't clean up after themselves. So manually
clear all DMA channels when resuming since no DMA could have been running
at this point in time. Now Linux should be able to work regardless of any
laziness on the part of the on-chip ROM or boot loader.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
In commit 0de51088e6a82bc8413d3ca9e28bbca2788b5b53, we introduced the
use of acpi-cpufreq on VIA/Centaur CPU's by removing a vendor check for
VENDOR_INTEL. However, as it turns out, at least the Nano CPU's also
need the PDC (processor driver capabilities) handshake in order to
activate the methods required for acpi-cpufreq.
Since arch_acpi_processor_init_pdc() contains another vendor check for
Intel, the PDC is not initialized on VIA CPU's. The resulting behavior
of a current mainline kernel on such systems is: acpi-cpufreq
loads and it indicates CPU frequency changes. However, the CPU stays at
a single frequency
This trivial patch ensures that init_intel_pdc() is called on Intel and
VIA/Centaur CPU's alike.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
Signed-off-by: Dave Jones <davej@redhat.com>
This was the cause of various boot failures on V480, V880, etc.
systems.
Kernel image memory was being overwritten because the vmemmap[]
array was being sized to small. So if you had physical memory
addresses past a certain point, the early bootup would spam
all over variables in the kernel data section.
The vmemmap mappings map page structs, not page struct pointers.
And that was the key thinko in the macro definition.
This was fixable thanks to the help, reports, and tireless patience
of Hermann Lauer.
Reported-by: Hermann Lauer <Hermann.Lauer@iwr.uni-heidelberg.de>
Using OABI, the call to put_user in do_signal can fail causing the
calling app to hang.
The solution is to check if put_user fails and force the app to
seg fault in that case.
Tested with multiple sleeping apps/threads (using the nanosleep syscall)
and suspend/resume.
Signed-off-by: janboe <janboe.ye at gmail.com>
Signed-off-by: Jean Pihet <jpihet@mvista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
If CONFIG_AKITA is not set, spitz fails to compile. It worked ok in
rc5. Fix is one more ifdef...
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Stanislav Brabec <utx@penguin.cz>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
I stumbled over two small things regarding the .index field assignment
in the dynamically created cpu frequency tables for pxa2xx and pxa3xx.
Even though that doesn't currently cause any problem, it should still be
fixed in case the logic in the CPUFREQ core changes.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
d451564 broke ARM by requiring KM_IRQ_PTE, KM_NMI and KM_NMI_PTE to
always be defined. Solve this by providing invalid definitions for
these constants, but only if CONFIG_DEBUG_HIGHMEM is enabled.
[CPUFREQ] Fix stale cpufreq_cpu_governor pointer
[CPUFREQ] Resolve time unit thinko in ondemand/conservative govs
[CPUFREQ] speedstep-ich: fix error caused by 394122ab144dae4b276d74644a2f11c44a60ac5c
[CPUFREQ] Fix use after free on governor restore
[CPUFREQ] acpi-cpufreq: blacklist Intel 0f68: Fix HT detection and put in notification message
[CPUFREQ] powernow-k8: Fix test in get_transition_latency()
[CPUFREQ] longhaul: select Longhaul version 2 for capable CPUs
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6:
OMAP: cs should be positive in gpmc_cs_free()
omap: fix unlikely(x) < y
omap3: clock: Fixed dpll3_m2x2 rate calculation
omap3: clock: Fix the DPLL freqsel computations
omap: Fix keymap for zoom2 according to matrix keypad framwork
The index `cs' is signed, test whether it is negative before we release
gpmc_cs_mem[cs].
The closing parenthesis was not in the right location.
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh/for-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Fixup last users of irq_chip->typename
uio: pm_runtime_disable is needed if failed
"[CPUFREQ] cpumask: avoid playing with cpus_allowed in speedstep-ich.c"
changed the code to mistakenly pass the current cpu as the "processor"
argument of speedstep_get_frequency(), whereas it should be the type of
the processor.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14340
Based on a patch by Dave Mueller.
Acked-by: Dominik Brodowski <linux@brodo.de>
Reported-by: Dave Mueller <dave.mueller@gmx.ch>
Cc: <stable@kernel.org>
Removing the SMT/HT check, since the Errata doesn't mention
Hyper-Threading.
Adding in a printk, so that the user knows why acpi-cpufreq refuses to
load. Also, once system is blacklisted, don't repeat checks to see if
blacklisted. This also causes the message to only be printed once,
rather than for each CPU.
Signed-off-by: John L. Villalovos <john.l.villalovos@intel.com>
Not makes it a bool before the comparison.
There is a typo in the longhaul detection code so only Longhaul v1 or Longhaul v3
is selected. The Longhaul v2 is not selected even for CPUs which are capable of.
Tested on PCChips Giga Pro board. Frequency changes work and the Longhaul v2
detects that the board is not capable of changing CPU voltage.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: linux-sh@vger.kernel.org
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Current calculation does not take into account any changes to M2 divisor, and
thus when we change VDD2 OPP, dpll3_m2x2 rate does not change. Fixed by
re-routing dpll3_m2x2 parent to dpll3_m2.
Signed-off-by: Tero Kristo <tero.kristo@nokia.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
