commit 9661d5bcd058fe15b4138a00d96bd36516134543 upstream.
When hot-adding/removing memory, sync_global_pgds() is called
for synchronizing PGD to PGD entries of all processes MM. But
when hot-removing memory, sync_global_pgds() does not work
correctly.
At first, sync_global_pgds() checks whether target PGD is none
or not. And if PGD is none, the PGD is skipped. But when
hot-removing memory, PGD may be none since PGD may be cleared by
free_pud_table(). So when sync_global_pgds() is called after
hot-removing memory, sync_global_pgds() should not skip PGD even
if the PGD is none. And sync_global_pgds() must clear PGD
Currently sync_global_pgds() does not clear PGD entries of all
processes MM when hot-removing memory. So when hot adding
memory which is same memory range as removed memory after
hot-removing memory, following call traces are shown:
kernel BUG at arch/x86/mm/init_64.c:206!
[<ffffffff815e0c80>] kernel_physical_mapping_init+0x1b2/0x1d2
[<ffffffff815ced94>] init_memory_mapping+0x1d4/0x380
[<ffffffff8104aebd>] arch_add_memory+0x3d/0xd0
[<ffffffff815d03d9>] add_memory+0xb9/0x1b0
[<ffffffff81352415>] acpi_memory_device_add+0x1af/0x28e
[<ffffffff81325dc4>] acpi_bus_device_attach+0x8c/0xf0
[<ffffffff813413b9>] acpi_ns_walk_namespace+0xc8/0x17f
[<ffffffff81325d38>] ? acpi_bus_type_and_status+0xb7/0xb7
[<ffffffff813418ed>] acpi_walk_namespace+0x95/0xc5
[<ffffffff81326b4c>] acpi_bus_scan+0x9a/0xc2
[<ffffffff81326bff>] acpi_scan_bus_device_check+0x8b/0x12e
[<ffffffff81326cb5>] acpi_scan_device_check+0x13/0x15
[<ffffffff81320122>] acpi_os_execute_deferred+0x25/0x32
[<ffffffff8107e02b>] process_one_work+0x17b/0x460
[<ffffffff8107edfb>] worker_thread+0x11b/0x400
[<ffffffff8107ece0>] ? rescuer_thread+0x400/0x400
[<ffffffff81085aef>] kthread+0xcf/0xe0
[<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140
[<ffffffff815fc76c>] ret_from_fork+0x7c/0xb0
This patch clears PGD entries of all processes MM when
sync_global_pgds() is called after hot-removing memory
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Vlastimil Babka <vbabka@suse.com>
commit 5255e0a79fcc0ff47b387af92bd9ef5729b1b859 upstream.
When hot-adding memory after hot-removing memory, following call
traces are shown:
The patch-set fixes the issue.
This patch (of 2):
remove_pagetable() gets start argument and passes the argument
to sync_global_pgds(). In this case, the argument must not be
modified. If the argument is modified and passed to
sync_global_pgds(), sync_global_pgds() does not correctly
synchronize PGD to PGD entries of all processes MM since
synchronized range of memory [start, end] is wrong.
Unfortunately the start argument is modified in
remove_pagetable(). So this patch fixes the issue.
commit 4be4de7ef9fd3a4d77320d4713970299ffecd286 upstream.
Replace the current canonical address check with the new function which is
identical.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit 7e46dddd6f6cd5dbf3c7bd04a7e75d19475ac9f2 upstream.
Commit d1442d85cc30 ("KVM: x86: Handle errors when RIP is set during far
jumps") introduced a bug that caused the fix to be incomplete. Due to
incorrect evaluation, far jump to segment with L bit cleared (i.e., 32-bit
segment) and RIP with any of the high bits set (i.e, RIP[63:32] != 0) set may
not trigger #GP. As we know, this imposes a security problem.
In addition, the condition for two warnings was incorrect.
Fixes: d1442d85cc30ea75f7d399474ca738e0bc96f715
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[Add #ifdef CONFIG_X86_64 to avoid complaints of undefined behavior. - Paolo]
commit cbdb967af3d54993f5814f1cee0ed311a055377d upstream.
This is needed to avoid the possibility that the guest triggers
an infinite stream of #DB exceptions (CVE-2015-8104).
VMX is not affected: because it does not save DR6 in the VMCS,
it already intercepts #DB unconditionally.
Reported-by: Jan Beulich <jbeulich@suse.com>
commit 54a20552e1eae07aa240fa370a0293e006b5faed upstream.
It was found that a guest can DoS a host by triggering an infinite
stream of "alignment check" (#AC) exceptions. This causes the
microcode to enter an infinite loop where the core never receives
another interrupt. The host kernel panics pretty quickly due to the
effects (CVE-2015-5307).
Signed-off-by: Eric Northup <digitaleric@google.com>
commit c9cdd085bb75226879fd468b88e2e7eb467325b7 upstream.
Defining XE, XM and VE vector numbers.
commit d836ace65ee98d7079bc3c5afdbcc0e27dca20a3 upstream.
DSA expects the host_dev pointer to be the device structure associated
with the MDIO bus controller driver. First commit breaking that was
c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO
driver"), and then, it got completely under the radar for a while.
Reported-by: Frans van de Wiel <fvdw@fvdw.eu>
Fixes: c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO driver")
CC: stable@vger.kernel.org
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 733187e29576041ceccf3b82092ca900fc929170 upstream.
commit f13c13a00512 (powerpc: Stop using non-architected shared_proc
field in lppaca) fixed a potential issue with shared/dedicated
partition detection. The old method of detection relied on an
unarchitected field (shared_proc), and this patch switched
to using something architected (a non zero yield_count).
Unfortunately the assertion in the Linux header that yield_count
is only non zero on shared processor partitions is not true. It
turns out dedicated processor partitions can increment yield_count
and as such we falsely detect dedicated partitions as shared.
Fix the comment, and switch back to using the old method.
commit 9702970c7bd3e2d6fecb642a190269131d4ac16c upstream.
This reverts commit e306dfd06fcb44d21c80acb8e5a88d55f3d1cf63.
With this patch applied, we were the only architecture making this sort
of adjustment to the PC calculation in the unwinder. This causes
problems for ftrace, where the PC values are matched against the
contents of the stack frames in the callchain and fail to match any
records after the address adjustment.
Whilst there has been some effort to change ftrace to workaround this,
those patches are not yet ready for mainline and, since we're the odd
architecture in this regard, let's just step in line with other
architectures (like arch/arm/) for now.
commit 8832317f662c06f5c06e638f57bfe89a71c9b266 upstream.
Currently we do not validate rtas.entry before calling enter_rtas(). This
leads to a kernel oops when user space calls rtas system call on a powernv
platform (see below). This patch adds code to validate rtas.entry before
making enter_rtas() call.
Oops: Exception in kernel mode, sig: 4 [#1]
SMP NR_CPUS=1024 NUMA PowerNV
task: c000000004294b80 ti: c0000007e1a78000 task.ti: c0000007e1a78000
NIP: 0000000000000000 LR: 0000000000009c14 CTR: c000000000423140
REGS: c0000007e1a7b920 TRAP: 0e40 Not tainted (3.18.17-340.el7_1.pkvm3_1_0.2400.1.ppc64le)
MSR: 1000000000081000 <HV,ME> CR: 00000000 XER: 00000000
CFAR: c000000000009c0c SOFTE: 0
NIP [0000000000000000] (null)
LR [0000000000009c14] 0x9c14
Call Trace:
[c0000007e1a7bba0] [c00000000041a7f4] avc_has_perm_noaudit+0x54/0x110 (unreliable)
[c0000007e1a7bd80] [c00000000002ddc0] ppc_rtas+0x150/0x2d0
[c0000007e1a7be30] [c000000000009358] syscall_exit+0x0/0x98
Fixes: 55190f88789a ("powerpc: Add skeleton PowerNV platform")
Reported-by: NAGESWARA R. SASTRY <nasastry@in.ibm.com>
Signed-off-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com>
[mpe: Reword change log, trim oops, and add stable + fixes]
commit b6dd8e0719c0d2d01429639a11b7bc2677de240c upstream.
Commit df057cc7b4fa ("arm64: errata: add module build workaround for
erratum #843419") sets CFLAGS_MODULE to ensure that the large memory
model is used by the compiler when building kernel modules.
However, CFLAGS_MODULE is an environment variable and intended to be
overridden on the command line, which appears to be the case with the
Ubuntu kernel packaging system, so use KBUILD_CFLAGS_MODULE instead.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: df057cc7b4fa ("arm64: errata: add module build workaround for erratum #843419")
Reported-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
commit a66d7f724a96d6fd279bfbd2ee488def6b081bea upstream.
Some of the crypto algorithms write to the initialization vector,
but no space has been allocated for it. This clobbers adjacent memory.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
commit 8474ba74193d302e8340dddd1e16c85cc4b98caf upstream.
Make sure the compiler does not modify arguments of syscall functions.
This can happen if the compiler generates a tailcall to another
function. For example, without asmlinkage_protect sys_openat is compiled
into this function:
sys_openat:
clr.l %d0
move.w 18(%sp),%d0
move.l %d0,16(%sp)
jbra do_sys_open
Note how the fourth argument is modified in place, modifying the register
%d4 that gets restored from this stack slot when the function returns to
user-space. The caller may expect the register to be unmodified across
system calls.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit 569ba74a7ba69f46ce2950bf085b37fea2408385 upstream.
This is the arm64 portion of commit 45cac65b0fcd ("readahead: fault
retry breaks mmap file read random detection"), which was absent from
the initial port and has since gone unnoticed. The original commit says:
> .fault now can retry. The retry can break state machine of .fault. In
> filemap_fault, if page is miss, ra->mmap_miss is increased. In the second
> try, since the page is in page cache now, ra->mmap_miss is decreased. And
> these are done in one fault, so we can't detect random mmap file access.
> Add a new flag to indicate .fault is tried once. In the second try, skip
> ra->mmap_miss decreasing. The filemap_fault state machine is ok with it.
With this change, Mark reports that:
> Random read improves by 250%, sequential read improves by 40%, and
> random write by 400% to an eMMC device with dm crypto wrapped around it.
Cc: Shaohua Li <shli@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Signed-off-by: Riley Andrews <riandrews@android.com>
commit 53960059d56ecef67d4ddd546731623641a3d2d1 upstream.
If there is a DMA zone (usually 24bit = 16MB I believe), but no DMA32
zone, as is the case for some 32-bit kernels, then massage_gfp_flags()
will cause DMA memory allocated for devices with a 32..63-bit
coherent_dma_mask to fall back to using __GFP_DMA, even though there may
only be 32-bits of physical address available anyway.
Correct that case to compare against a mask the size of phys_addr_t
instead of always using a 64-bit mask.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Fixes: a2e715a86c6d ("MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask.")
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9610/
commit 2ab08ee9f0a4eba27c7c4ce0b6d5118e8a18554b upstream.
Both already use asm-generic/barrier.h as per their
include/asm/Kbuild. Remove the stale files.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-c7vlkshl3tblim0o8z2p70kt@git.kernel.org
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: linux-hexagon@vger.kernel.org
commit 1de7da377bd880ff23917f78924d0e908329d978 upstream.
Move the barriers functions that depend on the atomic implementation
into the atomic implementation.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com> [for arch/arc bits]
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.786183683@infradead.org
commit 93ea02bb84354370e51de803a9405f171f3edf88 upstream.
We're going to be adding a few new barrier primitives, and in order to
avoid endless duplication make more agressive use of
asm-generic/barrier.h.
Change the asm-generic/barrier.h such that it allows partial barrier
definitions and fills out the rest with defaults.
There are a few architectures (m32r, m68k) that could probably
do away with their barrier.h file entirely but are kept for now due to
their unconventional nop() implementation.
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org
commit 0b34a166f291d255755be46e43ed5497cdd194f2 upstream.
Currently there is a number of issues preventing PVHVM Xen guests from
doing successful kexec/kdump:
- Bound event channels.
- Registered vcpu_info.
- PIRQ/emuirq mappings.
- shared_info frame after XENMAPSPACE_shared_info operation.
- Active grant mappings.
Basically, newly booted kernel stumbles upon already set up Xen
interfaces and there is no way to reestablish them. In Xen-4.7 a new
feature called 'soft reset' is coming. A guest performing kexec/kdump
operation is supposed to call SCHEDOP_shutdown hypercall with
SHUTDOWN_soft_reset reason before jumping to new kernel. Hypervisor
(with some help from toolstack) will do full domain cleanup (but
keeping its memory and vCPU contexts intact) returning the guest to
the state it had when it was first booted and thus allowing it to
start over.
Doing SHUTDOWN_soft_reset on Xen hypervisors which don't support it is
probably OK as by default all unknown shutdown reasons cause domain
destroy with a message in toolstack log: 'Unknown shutdown reason code
5. Destroying domain.' which gives a clue to what the problem is and
eliminates false expectations.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit ab76f7b4ab2397ffdd2f1eb07c55697d19991d10 upstream.
Unused space between the end of __ex_table and the start of
rodata can be left W+x in the kernel page tables. Extend the
setting of the NX bit to cover this gap by starting from
text_end rather than rodata_start.
Before:
---[ High Kernel Mapping ]---
0xffffffff80000000-0xffffffff81000000 16M pmd
0xffffffff81000000-0xffffffff81600000 6M ro PSE GLB x pmd
0xffffffff81600000-0xffffffff81754000 1360K ro GLB x pte
0xffffffff81754000-0xffffffff81800000 688K RW GLB x pte
0xffffffff81800000-0xffffffff81a00000 2M ro PSE GLB NX pmd
0xffffffff81a00000-0xffffffff81b3b000 1260K ro GLB NX pte
0xffffffff81b3b000-0xffffffff82000000 4884K RW GLB NX pte
0xffffffff82000000-0xffffffff82200000 2M RW PSE GLB NX pmd
0xffffffff82200000-0xffffffffa0000000 478M pmd
After:
0xffffffff81754000-0xffffffff81800000 688K RW GLB NX pte
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Link: http://lkml.kernel.org/r/1443704662-3138-1-git-send-email-sds@tycho.nsa.gov
commit 03da3ff1cfcd7774c8780d2547ba0d995f7dc03d upstream.
In 2007, commit 07190a08eef36 ("Mark TSC on GeodeLX reliable")
bypassed verification of the TSC on Geode LX. However, this code
(now in the check_system_tsc_reliable() function in
arch/x86/kernel/tsc.c) was only present if CONFIG_MGEODE_LX was
set.
OpenWRT has recently started building its generic Geode target
for Geode GX, not LX, to include support for additional
platforms. This broke the timekeeping on LX-based devices,
because the TSC wasn't marked as reliable:
https://dev.openwrt.org/ticket/20531
By adding a runtime check on is_geode_lx(), we can also include
the fix if CONFIG_MGEODEGX1 or CONFIG_X86_GENERIC are set, thus
fixing the problem.
Cc: Andres Salomon <dilinger@queued.net>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Link: http://lkml.kernel.org/r/1442409003.131189.87.camel@infradead.org
commit 5d7c631d926b59aa16f3c56eaeb83f1036c81dc7 upstream.
The APIC LVTT register is MMIO mapped but the TSC_DEADLINE register is an
MSR. The write to the TSC_DEADLINE MSR is not serializing, so it's not
guaranteed that the write to LVTT has reached the APIC before the
TSC_DEADLINE MSR is written. In such a case the write to the MSR is
ignored and as a consequence the local timer interrupt never fires.
The SDM decribes this issue for xAPIC and x2APIC modes. The
serialization methods recommended by the SDM differ.
xAPIC:
"1. Memory-mapped write to LVT Timer Register, setting bits 18:17 to 10b.
2. WRMSR to the IA32_TSC_DEADLINE MSR a value much larger than current time-stamp counter.
3. If RDMSR of the IA32_TSC_DEADLINE MSR returns zero, go to step 2.
4. WRMSR to the IA32_TSC_DEADLINE MSR the desired deadline."
x2APIC:
"To allow for efficient access to the APIC registers in x2APIC mode,
the serializing semantics of WRMSR are relaxed when writing to the
APIC registers. Thus, system software should not use 'WRMSR to APIC
registers in x2APIC mode' as a serializing instruction. Read and write
accesses to the APIC registers will occur in program order. A WRMSR to
an APIC register may complete before all preceding stores are globally
visible; software can prevent this by inserting a serializing
instruction, an SFENCE, or an MFENCE before the WRMSR."
The xAPIC method is to just wait for the memory mapped write to hit
the LVTT by checking whether the MSR write has reached the hardware.
There is no reason why a proper MFENCE after the memory mapped write would
not do the same. Andi Kleen confirmed that MFENCE is sufficient for the
xAPIC case as well.
Issue MFENCE before writing to the TSC_DEADLINE MSR. This can be done
unconditionally as all CPUs which have TSC_DEADLINE also have MFENCE
support.
[ tglx: Massaged the changelog ]
Signed-off-by: Shaohua Li <shli@fb.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: <Kernel-team@fb.com>
Cc: <lenb@kernel.org>
Cc: <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/20150909041352.GA2059853@devbig257.prn2.facebook.com
commit 1dbdad75074d16c3e3005180f81a01cdc04a7872 upstream.
The i2c5 pinctrl offsets are wrong. If the bootloader doesn't set the
pins up, communication with tca6424a doesn't work (controller timeouts)
and it is not possible to enable HDMI.
Fixes: 9be495c42609 ("ARM: dts: omap5-evm: Add I2c pinctrl data")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
commit a077224fd35b2f7fbc93f14cf67074fc792fbac2 upstream.
While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 9b55613f42e8d40d5c9ccb8970bde6af4764b2ab upstream.
When a kernel is built covering ARMv6 to ARMv7, we omit to clear the
IT state when entering a signal handler. This can cause the first
few instructions to be conditionally executed depending on the parent
context.
In any case, the original test for >= ARMv7 is broken - ARMv6 can have
Thumb-2 support as well, and an ARMv6T2 specific build would omit this
code too.
Relax the test back to ARMv6 or greater. This results in us always
clearing the IT state bits in the PSR, even on CPUs where these bits
are reserved. However, they're reserved for the IT state, so this
should cause no harm.
Fixes: d71e1352e240 ("Clear the IT state when invoking a Thumb-2 signal handler")
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
commit 6ecf830e5029598732e04067e325d946097519cb upstream.
The ARM architecture reference specifies that the IT state bits in the
PSR must be all zeros in ARM mode or behavior is unspecified. On the
Qualcomm Snapdragon S4/Krait architecture CPUs the processor continues
to consider the IT state bits while in ARM mode. This makes it so
that some instructions are skipped by the CPU.
Signed-off-by: T.J. Purtell <tj@mobisocial.us>
[rmk+kernel@arm.linux.org.uk: fixed whitespace formatting in patch]
commit d2922422c48df93f3edff7d872ee4f3191fefb08 upstream.
The cpu feature flags are not ever going to change, so warning
everytime can cause a lot of kernel log spam
(in our case more than 10GB/hour).
The warning seems to only occur when nested virtualization is
enabled, so it's probably triggered by a KVM bug. This is a
sensible and safe change anyway, and the KVM bug fix might not
be suitable for stable releases anyway.
Signed-off-by: Dirk Mueller <dmueller@suse.com>
commit fc57a7c68020dcf954428869eafd934c0ab1536f upstream.
PARAVIRT_ADJUST_EXCEPTION_FRAME generates this code (using nmi as an
example, trimmed for readability):
ff 15 00 00 00 00 callq *0x0(%rip) # 2796 <nmi+0x6>
2792: R_X86_64_PC32 pv_irq_ops+0x2c
That's a call through a function pointer to regular C function that
does nothing on native boots, but that function isn't protected
against kprobes, isn't marked notrace, and is certainly not
guaranteed to preserve any registers if the compiler is feeling
perverse. This is bad news for a CLBR_NONE operation.
Of course, if everything works correctly, once paravirt ops are
patched, it gets nopped out, but what if we hit this code before
paravirt ops are patched in? This can potentially cause breakage
that is very difficult to debug.
A more subtle failure is possible here, too: if _paravirt_nop uses
the stack at all (even just to push RBP), it will overwrite the "NMI
executing" variable if it's called in the NMI prologue.
The Xen case, perhaps surprisingly, is fine, because it's already
written in asm.
Fix all of the cases that default to paravirt_nop (including
adjust_exception_frame) with a big hammer: replace paravirt_nop with
an asm function that is just a ret instruction.
The Xen case may have other problems, so document them.
This is part of a fix for some random crashes that Sasha saw.
Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/8f5d2ba295f9d73751c33d97fda03e0495d9ade0.1442791737.git.luto@kernel.org
commit 83c133cf11fb0e68a51681447e372489f052d40e upstream.
The NMI entry code that switches to the normal kernel stack needs to
be very careful not to clobber any extra stack slots on the NMI
stack. The code is fine under the assumption that SWAPGS is just a
normal instruction, but that assumption isn't really true. Use
SWAPGS_UNSAFE_STACK instead.
Fixes: 9b6e6a8334d5 ("x86/nmi/64: Switch stacks on userspace NMI entry")
Link: http://lkml.kernel.org/r/974bc40edffdb5c2950a5c4977f821a446b76178.1442791737.git.luto@kernel.org
commit e297c939b745e420ef0b9dc989cb87bda617b399 upstream.
This fixes a race which can result in the same virtual IRQ number
being assigned to two different MSI interrupts. The most visible
consequence of that is usually a warning and stack trace from the
sysfs code about an attempt to create a duplicate entry in sysfs.
The race happens when one CPU (say CPU 0) is disposing of an MSI
while another CPU (say CPU 1) is setting up an MSI. CPU 0 calls
(for example) pnv_teardown_msi_irqs(), which calls
msi_bitmap_free_hwirqs() to indicate that the MSI (i.e. its
hardware IRQ number) is no longer in use. Then, before CPU 0 gets
to calling irq_dispose_mapping() to free up the virtal IRQ number,
CPU 1 comes in and calls msi_bitmap_alloc_hwirqs() to allocate an
MSI, and gets the same hardware IRQ number that CPU 0 just freed.
CPU 1 then calls irq_create_mapping() to get a virtual IRQ number,
which sees that there is currently a mapping for that hardware IRQ
number and returns the corresponding virtual IRQ number (which is
the same virtual IRQ number that CPU 0 was using). CPU 0 then
calls irq_dispose_mapping() and frees that virtual IRQ number.
Now, if another CPU comes along and calls irq_create_mapping(), it
is likely to get the virtual IRQ number that was just freed,
resulting in the same virtual IRQ number apparently being used for
two different hardware interrupts.
To fix this race, we just move the call to msi_bitmap_free_hwirqs()
to after the call to irq_dispose_mapping(). Since virq_to_hw()
doesn't work for the virtual IRQ number after irq_dispose_mapping()
has been called, we need to call it before irq_dispose_mapping() and
remember the result for the msi_bitmap_free_hwirqs() call.
The pattern of calling msi_bitmap_free_hwirqs() before
irq_dispose_mapping() appears in 5 places under arch/powerpc, and
appears to have originated in commit 05af7bd2d75e ("[POWERPC] MPIC
U3/U4 MSI backend") from 2007.
Fixes: 05af7bd2d75e ("[POWERPC] MPIC U3/U4 MSI backend")
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
commit 810bc075f78ff2c221536eb3008eac6a492dba2d upstream.
We have a tricky bug in the nested NMI code: if we see RSP
pointing to the NMI stack on NMI entry from kernel mode, we
assume that we are executing a nested NMI.
This isn't quite true. A malicious userspace program can point
RSP at the NMI stack, issue SYSCALL, and arrange for an NMI to
happen while RSP is still pointing at the NMI stack.
Fix it with a sneaky trick. Set DF in the region of code that
the RSP check is intended to detect. IRET will clear DF
atomically.
( Note: other than paravirt, there's little need for all this
complexity. We could check RIP instead of RSP. )
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Borislav Petkov <bp@suse.de>
commit a27507ca2d796cfa8d907de31ad730359c8a6d06 upstream.
Check the repeat_nmi .. end_repeat_nmi special case first. The
next patch will rework the RSP check and, as a side effect, the
RSP check will no longer detect repeat_nmi .. end_repeat_nmi, so
we'll need this ordering of the checks.
Note: this is more subtle than it appears. The check for
repeat_nmi .. end_repeat_nmi jumps straight out of the NMI code
instead of adjusting the "iret" frame to force a repeat. This
is necessary, because the code between repeat_nmi and
end_repeat_nmi sets "NMI executing" and then writes to the
"iret" frame itself. If a nested NMI comes in and modifies the
"iret" frame while repeat_nmi is also modifying it, we'll end up
with garbage. The old code got this right, as does the new
code, but the new code is a bit more explicit.
If we were to move the check right after the "NMI executing"
check, then we'd get it wrong and have random crashes.
( Because the "NMI executing" check would jump to the code that would
modify the "iret" frame without checking if the interrupted NMI was
currently modifying it. )
commit 0b22930ebad563ae97ff3f8d7b9f12060b4c6e6b upstream.
I found the nested NMI documentation to be difficult to follow.
Improve the comments.
commit b1b4e435e4ef7de77f07bf2a42c8380b960c2d44 upstream.
When detecting a serial port on newer PA-RISC machines (with iosapic) we have a
long way to go to find the right IRQ line, registering it, then registering the
serial port and the irq handler for the serial port. During this phase spurious
interrupts for the serial port may happen which then crashes the kernel because
the action handler might not have been set up yet.
So, basically it's a race condition between the serial port hardware and the
CPU which sets up the necessary fields in the irq sructs. The main reason for
this race is, that we unmask the serial port irqs too early without having set
up everything properly before (which isn't easily possible because we need the
IRQ number to register the serial ports).
This patch is a work-around for this problem. It adds checks to the CPU irq
handler to verify if the IRQ action field has been initialized already. If not,
we just skip this interrupt (which isn't critical for a serial port at bootup).
The real fix would probably involve rewriting all PA-RISC specific IRQ code
(for CPU, IOSAPIC, GSC and EISA) to use IRQ domains with proper parenting of
the irq chips and proper irq enabling along this line.
This bug has been in the PA-RISC port since the beginning, but the crashes
happened very rarely with currently used hardware. But on the latest machine
which I bought (a C8000 workstation), which uses the fastest CPUs (4 x PA8900,
1GHz) and which has the largest possible L1 cache size (64MB each), the kernel
crashed at every boot because of this race. So, without this patch the machine
would currently be unuseable.
For the record, here is the flow logic:
1. serial_init_chip() in 8250_gsc.c calls iosapic_serial_irq().
2. iosapic_serial_irq() calls txn_alloc_irq() to find the irq.
3. iosapic_serial_irq() calls cpu_claim_irq() to register the CPU irq
4. cpu_claim_irq() unmasks the CPU irq (which it shouldn't!)
5. serial_init_chip() then registers the 8250 port.
Problems:
- In step 4 the CPU irq shouldn't have been registered yet, but after step 5
- If serial irq happens between 4 and 5 have finished, the kernel will crash
Signed-off-by: Helge Deller <deller@gmx.de>
commit 9962eea9e55f797f05f20ba6448929cab2a9f018 upstream.
The variable pmd_idx is not initialized for the first iteration of the
for loop.
Assign the proper value which indexes the start address.
Fixes: 719272c45b82 'x86, mm: only call early_ioremap_page_table_range_init() once'
Signed-off-by: Minfei Huang <mnfhuang@gmail.com>
Cc: tony.luck@intel.com
Cc: wangnan0@huawei.com
Cc: david.vrabel@citrix.com
Reviewed-by: yinghai@kernel.org
Link: http://lkml.kernel.org/r/1436703522-29552-1-git-send-email-mhuang@redhat.com
commit 36b35d5d807b7e57aff7d08e63de8b17731ee211 upstream.
If we had secondary hash flag set, we ended up modifying hash value in
the updatepp code path. Hence with a failed updatepp we will be using
a wrong hash value for the following hash insert. Fix this by
recomputing hash before insert.
Without this patch we can end up with using wrong slot number in linux
pte. That can result in us missing an hash pte update or invalidate
which can cause memory corruption or even machine check.
Fixes: 6d492ecc6489 ("powerpc/THP: Add code to handle HPTE faults for hugepages")
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Paul Mackerras <paulus@samba.org>
commit 1c2cb594441d02815d304cccec9742ff5c707495 upstream.
The EPOW interrupt handler uses rtas_get_sensor(), which in turn
uses rtas_busy_delay() to wait for RTAS becoming ready in case it
is necessary. But rtas_busy_delay() is annotated with might_sleep()
and thus may not be used by interrupts handlers like the EPOW handler!
This leads to the following BUG when CONFIG_DEBUG_ATOMIC_SLEEP is
enabled:
BUG: sleeping function called from invalid context at arch/powerpc/kernel/rtas.c:496
in_atomic(): 1, irqs_disabled(): 1, pid: 0, name: swapper/1
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.2.0-rc2-thuth #6
Call Trace:
[c00000007ffe7b90] [c000000000807670] dump_stack+0xa0/0xdc (unreliable)
[c00000007ffe7bc0] [c0000000000e1f14] ___might_sleep+0x134/0x180
[c00000007ffe7c20] [c00000000002aec0] rtas_busy_delay+0x30/0xd0
[c00000007ffe7c50] [c00000000002bde4] rtas_get_sensor+0x74/0xe0
[c00000007ffe7ce0] [c000000000083264] ras_epow_interrupt+0x44/0x450
[c00000007ffe7d90] [c000000000120260] handle_irq_event_percpu+0xa0/0x300
[c00000007ffe7e70] [c000000000120524] handle_irq_event+0x64/0xc0
[c00000007ffe7eb0] [c000000000124dbc] handle_fasteoi_irq+0xec/0x260
[c00000007ffe7ef0] [c00000000011f4f0] generic_handle_irq+0x50/0x80
[c00000007ffe7f20] [c000000000010f3c] __do_irq+0x8c/0x200
[c00000007ffe7f90] [c0000000000236cc] call_do_irq+0x14/0x24
[c00000007e6f39e0] [c000000000011144] do_IRQ+0x94/0x110
[c00000007e6f3a30] [c000000000002594] hardware_interrupt_common+0x114/0x180
Fix this issue by introducing a new rtas_get_sensor_fast() function
that does not use rtas_busy_delay() - and thus can only be used for
sensors that do not cause a BUSY condition - known as "fast" sensors.
The EPOW sensor is defined to be "fast" in sPAPR - mpe.
Fixes: 587f83e8dd50 ("powerpc/pseries: Use rtas_get_sensor in RAS code")
Signed-off-by: Thomas Huth <thuth@redhat.com>
Reviewed-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
commit 74b5037baa2011a2799e2c43adde7d171b072f9e upstream.
The powerpc kernel can be built to have either a 4K PAGE_SIZE or a 64K
PAGE_SIZE.
However when built with a 4K PAGE_SIZE there is an additional config
option which can be enabled, PPC_HAS_HASH_64K, which means the kernel
also knows how to hash a 64K page even though the base PAGE_SIZE is 4K.
This is used in one obscure configuration, to support 64K pages for SPU
local store on the Cell processor when the rest of the kernel is using
4K pages.
In this configuration, pte_pagesize_index() is defined to just pass
through its arguments to get_slice_psize(). However pte_pagesize_index()
is called for both user and kernel addresses, whereas get_slice_psize()
only knows how to handle user addresses.
This has been broken forever, however until recently it happened to
work. That was because in get_slice_psize() the large kernel address
would cause the right shift of the slice mask to return zero.
However in commit 7aa0727f3302 ("powerpc/mm: Increase the slice range to
64TB"), the get_slice_psize() code was changed so that instead of a
right shift we do an array lookup based on the address. When passed a
kernel address this means we index way off the end of the slice array
and return random junk.
That is only fatal if we happen to hit something non-zero, but when we
do return a non-zero value we confuse the MMU code and eventually cause
a check stop.
This fix is ugly, but simple. When we're called for a kernel address we
return 4K, which is always correct in this configuration, otherwise we
use the slice mask.
Fixes: 7aa0727f3302 ("powerpc/mm: Increase the slice range to 64TB")
Reported-by: Cyril Bur <cyrilbur@gmail.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit c4cbba9fa078f55d9f6d081dbb4aec7cf969e7c7 upstream.
When running a guest with the architected timer disabled (with QEMU and
the kernel_irqchip=off option, for example), it is important to make
sure the timer gets turned off. Otherwise, the guest may try to
enable it anyway, leading to a screaming HW interrupt.
The fix is to unconditionally turn off the virtual timer on guest
exit.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
commit df057cc7b4fa59e9b55f07ffdb6c62bf02e99a00 upstream.
Cortex-A53 processors <= r0p4 are affected by erratum #843419 which can
lead to a memory access using an incorrect address in certain sequences
headed by an ADRP instruction.
There is a linker fix to generate veneers for ADRP instructions, but
this doesn't work for kernel modules which are built as unlinked ELF
objects.
This patch adds a new config option for the erratum which, when enabled,
builds kernel modules with the mcmodel=large flag. This uses absolute
addressing for all kernel symbols, thereby removing the use of ADRP as
a PC-relative form of addressing. The ADRP relocs are removed from the
module loader so that we fail to load any potentially affected modules.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit d10bcd473301888f957ec4b6b12aa3621be78d59 upstream.
When entering the kernel at EL2, we fail to initialise the MDCR_EL2
register which controls debug access and PMU capabilities at EL1.
This patch ensures that the register is initialised so that all traps
are disabled and all the PMU counters are available to the host. When a
guest is scheduled, KVM takes care to configure trapping appropriately.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
commit bdec97a855ef1e239f130f7a11584721c9a1bf04 upstream.
When saving/restoring the VFP registers from a compat (AArch32)
signal frame, we rely on the compat registers forming a prefix of the
native register file and therefore make use of copy_{to,from}_user to
transfer between the native fpsimd_state and the compat_vfp_sigframe.
Unfortunately, this doesn't work so well in a big-endian environment.
Our fpsimd save/restore code operates directly on 128-bit quantities
(Q registers) whereas the compat_vfp_sigframe represents the registers
as an array of 64-bit (D) registers. The architecture packs the compat D
registers into the Q registers, with the least significant bytes holding
the lower register. Consequently, we need to swap the 64-bit halves when
converting between these two representations on a big-endian machine.
This patch replaces the __copy_{to,from}_user invocations in our
compat VFP signal handling code with explicit __put_user loops that
operate on 64-bit values and swap them accordingly.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
commit bf0c4e04732479f650ff59d1ee82de761c0071f0 upstream.
Move the poison pointer offset to 0xdead000000000000, a
recognized value that is not mappable by user-space exploits.
Signed-off-by: Thierry Strudel <tstrudel@google.com>
Signed-off-by: Jeff Vander Stoep <jeffv@google.com>
commit b9e23f321940d2db2c9def8ff723b8464fb86343 upstream.
Legacy IPs like PWMSS, present under l4per2_7xx_clkdm, cannot support
smart-idle when its clock domain is in HW_AUTO on DRA7 SoCs. Hence,
program clock domain to SW_WKUP.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
Reviewed-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit 77d6273e79e3a86552fcf10cdd31a69b46ed2ce6 upstream.
call12 can't be safely used as the first call in the inline function,
because the compiler does not extend the stack frame of the bounding
function accordingly, which may result in corruption of local variables.
If a call needs to be done, do call8 first followed by call12.
For pure assembly code in _switch_to increase stack frame size of the
bounding function.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 4229fb12a03e5da5882b420b0aa4a02e77447b86 upstream.
Userspace return code may skip restoring THREADPTR register if there are
no registers that need to be zeroed. This leads to spurious failures in
libc NPTL tests.
Always restore THREADPTR on return to userspace.
commit 6f691251c0350ac52a007c54bf3ef62e9d8cdc5e upstream.
We got the bug that qemu complained with "KVM: unknown exit, hardware
reason 31" and KVM shown these info:
[84245.284948] EPT: Misconfiguration.
[84245.285056] EPT: GPA: 0xfeda848
[84245.285154] ept_misconfig_inspect_spte: spte 0x5eaef50107 level 4
[84245.285344] ept_misconfig_inspect_spte: spte 0x5f5fadc107 level 3
[84245.285532] ept_misconfig_inspect_spte: spte 0x5141d18107 level 2
[84245.285723] ept_misconfig_inspect_spte: spte 0x52e40dad77 level 1
This is because we got a mmio #PF and the handler see the mmio spte becomes
normal (points to the ram page)
However, this is valid after introducing fast mmio spte invalidation which
increases the generation-number instead of zapping mmio sptes, a example
is as follows:
1. QEMU drops mmio region by adding a new memslot
2. invalidate all mmio sptes
3.
VCPU 0 VCPU 1
access the invalid mmio spte
access the region originally was MMIO before
set the spte to the normal ram map
mmio #PF
check the spte and see it becomes normal ram mapping !!!
This patch fixes the bug just by dropping the check in mmio handler, it's
good for backport. Full check will be introduced in later patches
Reported-by: Pavel Shirshov <ru.pchel@gmail.com>
Tested-by: Pavel Shirshov <ru.pchel@gmail.com>
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Cc: stable@vger.kernel.org
commit 71c6da846be478a61556717ef1ee1cea91f5d6a8 upstream.
Currently context size (cra_ctxsize) doesn't specified for
ghash_async_alg. Which means it's zero. Thus crypto_create_tfm()
doesn't allocate needed space for ghash_async_ctx, so any
read/write to ctx (e.g. in ghash_async_init_tfm()) is not valid.
Signed-off-by: Andrey Ryabinin <aryabinin@odin.com>
commit 126c69a0bd0e441bf6766a5d9bf20de011be9f68 upstream.
When injecting a fault into a misbehaving 32bit guest, it seems
rather idiotic to also inject a 64bit fault that is only going
to corrupt the guest state. This leads to a situation where we
perform an illegal exception return at EL2 causing the host
to crash instead of killing the guest.
Just fix the stupid bug that has been there from day 1.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
