commit dffba9a31c7769be3231c420d4b364c92ba3f1ac upstream.
The compacted-format XSAVES area is determined at boot time and
never changed after. The field xsave.header.xcomp_bv indicates
which components are in the fixed XSAVES format.
In fpstate_init() we did not set xcomp_bv to reflect the XSAVES
format since at the time there is no valid data.
However, after we do copy_init_fpstate_to_fpregs() in fpu__clear(),
as in commit:
b22cbe404a9c x86/fpu: Fix invalid FPU ptrace state after execve()
and when __fpu_restore_sig() does fpu__restore() for a COMPAT-mode
app, a #GP occurs. This can be easily triggered by doing valgrind on
a COMPAT-mode "Hello World," as reported by Joakim Tjernlund and
others:
https://bugzilla.kernel.org/show_bug.cgi?id=190061
Fix it by setting xcomp_bv correctly.
This patch also moves the xcomp_bv initialization to the proper
place, which was in copyin_to_xsaves() as of:
4c833368f0bf x86/fpu: Set the xcomp_bv when we fake up a XSAVES area
which fixed the bug too, but it's more efficient and cleaner to
initialize things once per boot, not for every signal handling
operation.
Reported-by: Kevin Hao <haokexin@gmail.com>
Reported-by: Joakim Tjernlund <Joakim.Tjernlund@infinera.com>
Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Cc: haokexin@gmail.com
Link: http://lkml.kernel.org/r/1485212084-4418-1-git-send-email-yu-cheng.yu@intel.com
[ Combined it with 4c833368f0bf. ]
commit 08b259631b5a1d912af4832847b5642f377d9101 upstream.
After:
a33d331761bc ("x86/CPU/AMD: Fix Bulldozer topology")
our SMT scheduling topology for Fam17h systems is broken, because
the ThreadId is included in the ApicId when SMT is enabled.
So, without further decoding cpu_core_id is unique for each thread
rather than the same for threads on the same core. This didn't affect
systems with SMT disabled. Make cpu_core_id be what it is defined to be.
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170205105022.8705-2-bp@alien8.de
commit 79a8b9aa388b0620cc1d525d7c0f0d9a8a85e08e upstream.
Commit:
restored the initial approach we had with the Fam15h topology of
enumerating CU (Compute Unit) threads as cores. And this is still
correct - they're beefier than HT threads but still have some
shared functionality.
Our current approach has a problem with the Mad Max Steam game, for
example. Yves Dionne reported a certain "choppiness" while playing on
v4.9.5.
That problem stems most likely from the fact that the CU threads share
resources within one CU and when we schedule to a thread of a different
compute unit, this incurs latency due to migrating the working set to a
different CU through the caches.
When the thread siblings mask mirrors that aspect of the CUs and
threads, the scheduler pays attention to it and tries to schedule within
one CU first. Which takes care of the latency, of course.
Reported-by: Yves Dionne <yves.dionne@gmail.com>
Cc: Brice Goglin <Brice.Goglin@inria.fr>
Cc: Yazen Ghannam <yazen.ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170205105022.8705-1-bp@alien8.de
commit 146fbb766934dc003fcbf755b519acef683576bf upstream.
CONFIG_KASAN=y needs a lot of virtual memory mapped for its shadow.
In that case ptdump_walk_pgd_level_core() takes a lot of time to
walk across all page tables and doing this without
a rescheduling causes soft lockups:
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 23s! [swapper/0:1]
Call Trace:
ptdump_walk_pgd_level_core+0x40c/0x550
ptdump_walk_pgd_level_checkwx+0x17/0x20
mark_rodata_ro+0x13b/0x150
kernel_init+0x2f/0x120
ret_from_fork+0x2c/0x40
I guess that this issue might arise even without KASAN on huge machines
with several terabytes of RAM.
Stick cond_resched() in pgd loop to fix this.
Reported-by: Tobias Regnery <tobias.regnery@gmail.com>
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: kasan-dev@googlegroups.com
Cc: Alexander Potapenko <glider@google.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/r/20170210095405.31802-1-aryabinin@virtuozzo.com
commit 9b256714979fad61ae11d90b53cf67dd5e6484eb upstream.
The IPIs come in as HVI not EE, so we need to test the appropriate
SRR1 bits. The encoding is such that it won't have false positives
on P7 and P8 so we can just test it like that. We also need to handle
the icp-opal variant of the flush.
Fixes: d74361881f0d ("powerpc/xics: Add ICP OPAL backend")
commit 90c1e3c2fafec57fcb55b5d69bcf293b1a5fc8b3 upstream.
Three tiny changes to the ERAT flushing logic: First don't make
it depend on DD1. It hasn't been decided yet but we might run
DD2 in a mode that also requires explicit flushes for performance
reasons so make it unconditional. We also add a missing isync, and
finally remove the flush from _tlbiel_va as it is only necessary
for congruence-class invalidations (PID, LPID and full TLB), not
targetted invalidations.
Fixes: 96ed1fe511a8 ("powerpc/mm/radix: Invalidate ERAT on tlbiel for POWER9 DD1")
commit 97a98ae5b8acf08d07d972c087b2def060bc9b73 upstream.
Asynchronous external abort is coded differently in DFSR with LPAE enabled.
Fixes: 9254970c "ARM: 8447/1: catch pending imprecise abort on unmask".
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: Russell King <linux@armlinux.org.uk>
commit 7f59b319111bbc3a5f32730c8a43b201e9522f52 upstream.
GPIO4_11 is on pin 152(MX6DL_PAD_KEY_ROW2) and not on pin
151(MX6DL_PAD_KEY_ROW1).
I found the error while booting a mainline kernel on APF6S SoM and
noticed the following message:
[ 2.609337] imx6dl-pinctrl 20e0000.iomuxc: pin MX6DL_PAD_KEY_ROW1
already requested by 20a8000.gpio:105; cannot claim for 20a8000.gpio:107
[ 2.621884] imx6dl-pinctrl 20e0000.iomuxc: pin-151 (20a8000.gpio:107)
status -22
[ 2.629303] spi_imx 2008000.ecspi: Can't get CS GPIO 107
With this patch, the message is gone and spi_imx driver probes correctly.
Fixes: bb728d662bed ("ARM: dts: add gpio-ranges property to iMX GPIO controllers")
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
commit 228dbbfb5d77f8e047b2a1d78da14b7158433027 upstream.
Ensure that if userspace supplies insufficient data to
PTRACE_SETREGSET to fill all the registers, the thread's old
registers are preserved.
Fixes: 5be6f62b0059 ("ARM: 6883/1: ptrace: Migrate to regsets framework")
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
commit d966564fcdc19e13eb6ba1fbe6b8101070339c3d upstream.
This reverts commit 020eb3daaba2857b32c4cf4c82f503d6a00a67de.
Gabriel C reports that it causes his machine to not boot, and we haven't
tracked down the reason for it yet. Since the bug it fixes has been
around for a longish time, we're better off reverting the fix for now.
Gabriel says:
"It hangs early and freezes with a lot RCU warnings.
I bisected it down to :
> Ruslan Ruslichenko (1):
> x86/ioapic: Restore IO-APIC irq_chip retrigger callback
Reverting this one fixes the problem for me..
The box is a PRIMERGY TX200 S5 , 2 socket , 2 x E5520 CPU(s) installed"
and Ruslan and Thomas are currently stumped.
Reported-and-bisected-by: Gabriel C <nix.or.die@gmail.com>
Cc: Ruslan Ruslichenko <rruslich@cisco.com>
commit a524c218bc94c705886a0e0fedeee45d1931da32 upstream.
Reported-by: Jo-Philipp Wich <jo@mein.io>
Fixes: 9aed02feae57bf7 ("ARC: [arcompact] handle unaligned access delay slot")
Cc: linux-snps-arc@lists.infradead.org
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit aaaec6fc755447a1d056765b11b24d8ff2b81366 upstream.
The recent commit which prevents double activation of interrupts unearthed
interesting code in x86. The code (ab)uses irq_domain_activate_irq() to
reconfigure an already activated interrupt. That trips over the prevention
code now.
Fix it by deactivating the interrupt before activating the new configuration.
Fixes: 08d85f3ea99f1 "irqdomain: Avoid activating interrupts more than once"
Reported-and-tested-by: Mike Galbraith <efault@gmx.de>
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1701311901580.3457@nanos
commit 00c87e9a70a17b355b81c36adedf05e84f54e10d upstream.
Saving unsupported state prevents migration when the new host does not
support a XSAVE feature of the original host, even if the feature is not
exposed to the guest.
We've masked host features with guest-visible features before, with
4344ee981e21 ("KVM: x86: only copy XSAVE state for the supported
features") and dropped it when implementing XSAVES. Do it again.
Fixes: df1daba7d1cb ("KVM: x86: support XSAVES usage in the host")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 1aa6cfd33df492939b0be15ebdbcff1f8ae5ddb6 upstream.
The recent conversion to the hotplug state machine kept two mechanisms from
the original code:
1) The first_init logic which adds the number of online CPUs in a package
to the refcount. That's wrong because the callbacks are executed for
all online CPUs.
Remove it so the refcounting is correct.
2) The on_each_cpu() call to undo box->init() in the error handling
path. That's bogus because when the prepare callback fails no box has
been initialized yet.
Remove it.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Yasuaki Ishimatsu <yasu.isimatu@gmail.com>
Fixes: 1a246b9f58c6 ("perf/x86/intel/uncore: Convert to hotplug state machine")
Link: http://lkml.kernel.org/r/20170131230141.298032324@linutronix.de
commit a0615a16f7d0ceb5804d295203c302d496d8ee91 upstream.
When setting a 2MB pte, radix__map_kernel_page() is using the address
ptep = (pte_t *)pudp;
Fix this conversion to use pmdp instead. Use pmdp_ptep() to do this
instead of casting the pointer.
Fixes: 2bfd65e45e87 ("powerpc/mm/radix: Add radix callbacks for early init routines")
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Reza Arbab <arbab@linux.vnet.ibm.com>
commit b5fa0f7f88edcde37df1807fdf9ff10ec787a60e upstream.
Anton says: In commit 4db7327194db ("powerpc: Add option to use jump
label for cpu_has_feature()") and commit c12e6f24d413 ("powerpc: Add
option to use jump label for mmu_has_feature()") we added:
BUILD_BUG_ON(!__builtin_constant_p(feature))
to cpu_has_feature() and mmu_has_feature() in order to catch usage
issues (such as cpu_has_feature(cpu_has_feature(X), which has happened
once in the past). Unfortunately LLVM isn't smart enough to resolve
this, and it errors out.
I work around it in my clang/LLVM builds of the kernel, but I have just
discovered that it causes a lot of issues for the bcc (eBPF) trace tool
(which uses LLVM).
For now just #ifdef it away for clang builds.
Fixes: 4db7327194db ("powerpc: Add option to use jump label for cpu_has_feature()")
Fixes: c12e6f24d413 ("powerpc: Add option to use jump label for mmu_has_feature()")
Reported-by: Anton Blanchard <anton@samba.org>
Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit af2b7fa17eb92e52b65f96604448ff7a2a89ee99 upstream.
prom_init.c calls 'instance-to-package' twice, but the return
is not checked during prom_find_boot_cpu(). The result is then
passed to prom_getprop(), which could be PROM_ERROR. Add a return check
to prevent this.
This was found on a pasemi system, where CFE doesn't have a working
'instance-to package' prom call.
Before Commit 5c0484e25ec0 ('powerpc: Endian safe trampoline') the area
around addr 0 was mostly 0's and this doesn't cause a problem. Once the
macro 'FIXUP_ENDIAN' has been added to head_64.S, the low memory area
now has non-zero values, which cause the prom_getprop() call
to hang.
mpe: Also confirmed that under SLOF if 'instance-to-package' did fail
with PROM_ERROR we would crash in SLOF. So the bug is not specific to
CFE, it's just that other open firmwares don't trigger it because they
have a working 'instance-to-package'.
Fixes: 5c0484e25ec0 ("powerpc: Endian safe trampoline")
Signed-off-by: Darren Stevens <darren@stevens-zone.net>
commit f05fea5b3574a5926c53865eea27139bb40b2f2b upstream.
In __eeh_clear_pe_frozen_state(), we should pass the flag's value
instead of its address to eeh_unfreeze_pe(). The isolated flag is
cleared if no error returned from __eeh_clear_pe_frozen_state(). We
never observed the error from the function. So the isolated flag should
have been always cleared, no real issue is caused because of the misused
@flag.
This fixes the code by passing the value of @flag to eeh_unfreeze_pe().
Fixes: 5cfb20b96f6 ("powerpc/eeh: Emulate EEH recovery for VFIO devices")
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 11e3b725cfc282efe9d4a354153e99d86a16af08 upstream.
Update the ARMv8 Crypto Extensions and the plain NEON AES implementations
in CBC and CTR modes to return the next IV back to the skcipher API client.
This is necessary for chaining to work correctly.
Note that for CTR, this is only done if the request is a round multiple of
the block size, since otherwise, chaining is impossible anyway.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 4b3e6f2ef3722f1a6a97b6034ed492c1a21fd4ae upstream.
Commit bf15f86b343ed8 ("xtensa: initialize MMU before jumping to reset
vector") calls MMU management functions even when CONFIG_MMU is not
selected. That breaks noMMU build on cores with MMU.
Don't manage MMU when CONFIG_MMU is not selected.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit bf29bddf0417a4783da3b24e8c9e017ac649326f upstream.
Commit:
129766708 ("x86/efi: Only map RAM into EFI page tables if in mixed-mode")
stopped creating 1:1 mappings for all RAM, when running in native 64-bit mode.
It turns out though that there are 64-bit EFI implementations in the wild
(this particular problem has been reported on a Lenovo Yoga 710-11IKB),
which still make use of the first physical page for their own private use,
even though they explicitly mark it EFI_CONVENTIONAL_MEMORY in the memory
map.
In case there is no mapping for this particular frame in the EFI pagetables,
as soon as firmware tries to make use of it, a triple fault occurs and the
system reboots (in case of the Yoga 710-11IKB this is very early during bootup).
Fix that by always mapping the first page of physical memory into the EFI
pagetables. We're free to hand this page to the BIOS, as trim_bios_range()
will reserve the first page and isolate it away from memory allocators anyway.
Note that just reverting 129766708 alone is not enough on v4.9-rc1+ to fix the
regression on affected hardware, as this commit:
ab72a27da ("x86/efi: Consolidate region mapping logic")
later made the first physical frame not to be mapped anyway.
Reported-by: Hanka Pavlikova <hanka@ucw.cz>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Vojtech Pavlik <vojtech@ucw.cz>
Cc: Waiman Long <waiman.long@hpe.com>
Cc: linux-efi@vger.kernel.org
Fixes: 129766708 ("x86/efi: Only map RAM into EFI page tables if in mixed-mode")
Link: http://lkml.kernel.org/r/20170127222552.22336-1-matt@codeblueprint.co.uk
[ Tidied up the changelog and the comment. ]
commit 63d762b88cb5510f2bfdb5112ced18cde867ae61 upstream.
There is an off-by-one error so we don't unregister priv->pdev_mux[0].
Also it's slightly simpler as a while loop instead of a for loop.
Fixes: 58cbbee2391c ("x86/platform/mellanox: Introduce support for Mellanox systems platform")
Acked-by: Vadim Pasternak <vadimp@mellanox.com>
commit 2ad5d52d42810bed95100a3d912679d8864421ec upstream.
In swab.h the "#if BITS_PER_LONG > 32" breaks compiling userspace programs if
BITS_PER_LONG is #defined by userspace with the sizeof() compiler builtin.
Solve this problem by using __BITS_PER_LONG instead. Since we now
#include asm/bitsperlong.h avoid further potential userspace pollution
by moving the #define of SHIFT_PER_LONG to bitops.h which is not
exported to userspace.
This patch unbreaks compiling qemu on hppa/parisc.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 9aed02feae57bf7a40cb04ea0e3017cb7a998db4 upstream.
After emulating an unaligned access in delay slot of a branch, we
pretend as the delay slot never happened - so return back to actual
branch target (or next PC if branch was not taken).
Curently we did this by handling STATUS32.DE, we also need to clear the
BTA.T bit, which is disregarded when returning from original misaligned
exception, but could cause weirdness if it took the interrupt return
path (in case interrupt was acive too)
One ARC700 customer ran into this when enabling unaligned access fixup
for kernel mode accesses as well
commit 36425cd67052e3becf325fd4d3ba5691791ef7e4 upstream.
commit 3c7c7a2fc8811bc ("ARC: Don't use "+l" inline asm constraint")
modified the inline assembly to setup LP_COUNT register manually and NOT
rely on gcc to do it (with the +l inline assembler contraint hint, now
being retired in the compiler)
However the fix was flawed as we didn't add LP_COUNT to asm clobber list,
meaning gcc doesn't know that LP_COUNT or zero-delay-loops are in action
in the inline asm.
This resulted in some fun - as nested ZOL loops were being generared
| mov lp_count,250000 ;16 # tmp235,
| lp .L__GCC__LP14 # <======= OUTER LOOP (gcc generated)
| .L14:
| ld r2, [r5] # MEM[(volatile u32 *)prephitmp_43], w
| dmb 1
| breq r2, -1, @.L21 #, w,,
| bbit0 r2,1,@.L13 # w,,
| ld r4,[r7] ;25 # loops_per_jiffy, loops_per_jiffy
| mpymu r3,r4,r6 #, loops_per_jiffy, tmp234
| mov lp_count, r3 # <====== INNER LOOP (from inline asm)
| lp 1f
| nop
| 1:
| nop_s
| .L__GCC__LP14: ; loop end, start is @.L14 #,
This caused issues with drivers relying on sane behaviour of udelay
friends.
With LP_COUNT added to clobber list, gcc doesn't generate the outer
loop in say above case.
Addresses STAR 9001146134
Reported-by: Joao Pinto <jpinto@synopsys.com>
Fixes: 3c7c7a2fc8811bc ("ARC: Don't use "+l" inline asm constraint")
commit 9dce990d2cf57b5ed4e71a9cdbd7eae4335111ff upstream.
convert_vx_to_fp() is adapted to handle only a specified number of
registers rather than unconditionally handling all of them: other
callers of this function are adapted appropriately.
Based on an initial patch by Dave Martin.
Reported-by: Dave Martin <Dave.Martin@arm.com>
commit 0d6da872d3e4a60f43c295386d7ff9a4cdcd57e9 upstream.
The last pgtable rework silently disabled the CMMA unused state by
setting a local pte variable (a parameter) instead of propagating it
back into the caller. Fix it.
Fixes: ebde765c0e85 ("s390/mm: uninline ptep_xxx functions from pgtable.h")
Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit fd7c99142d77dc4a851879a66715abf12a3193fb upstream.
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
commit ae7871be189cb41184f1e05742b4a99e2c59774d upstream.
Convert the flag swiotlb_force from an int to an enum, to prepare for
the advent of more possible values.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 524dabe1c68e0bca25ce7b108099e5d89472a101 upstream.
Commit b67a8b29df introduced logic to skip swiotlb allocation when all memory
is DMA accessible anyway.
While this is a great idea, __dma_alloc still calls swiotlb code unconditionally
to allocate memory when there is no CMA memory available. The swiotlb code is
called to ensure that we at least try get_free_pages().
Without initialization, swiotlb allocation code tries to access io_tlb_list
which is NULL. That results in a stack trace like this:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
[<ffff00000845b908>] swiotlb_tbl_map_single+0xd0/0x2b0
[<ffff00000845be94>] swiotlb_alloc_coherent+0x10c/0x198
[<ffff000008099dc0>] __dma_alloc+0x68/0x1a8
[<ffff000000a1b410>] drm_gem_cma_create+0x98/0x108 [drm]
[<ffff000000abcaac>] drm_fbdev_cma_create_with_funcs+0xbc/0x368 [drm_kms_helper]
[<ffff000000abcd84>] drm_fbdev_cma_create+0x2c/0x40 [drm_kms_helper]
[<ffff000000abc040>] drm_fb_helper_initial_config+0x238/0x410 [drm_kms_helper]
[<ffff000000abce88>] drm_fbdev_cma_init_with_funcs+0x98/0x160 [drm_kms_helper]
[<ffff000000abcf90>] drm_fbdev_cma_init+0x40/0x58 [drm_kms_helper]
[<ffff000000b47980>] vc4_kms_load+0x90/0xf0 [vc4]
[<ffff000000b46a94>] vc4_drm_bind+0xec/0x168 [vc4]
Thankfully swiotlb code just learned how to not do allocations with the FORCE_NO
option. This patch configures the swiotlb code to use that if we decide not to
initialize the swiotlb framework.
Fixes: b67a8b29df ("arm64: mm: only initialize swiotlb when necessary")
CC: Jisheng Zhang <jszhang@marvell.com>
CC: Geert Uytterhoeven <geert+renesas@glider.be>
CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 1c8a946bf3754a59cba1fc373949a8114bfe5aaa upstream.
The arm64 __page_to_voff() macro takes a parameter called 'page', and
also refers to 'struct page'. Thus, if the value passed in is not
called 'page', we'll refer to the wrong struct name (which might not
exist).
Fixes: 3fa72fe9c614 ("arm64: mm: fix __page_to_voff definition")
Acked-by: Mark Rutland <mark.rutland@arm.com>
Suggested-by: Volodymyr Babchuk <Volodymyr_Babchuk@epam.com>
Signed-off-by: Oleksandr Andrushchenko <Oleksandr_Andrushchenko@epam.com>
commit 90f92c631b210c1e97080b53a9d863783281a932 upstream.
The following patch was sketched by Russell in response to my
crashes on the PB11MPCore after the patch for software-based
priviledged no access support for ARMv8.1. See this thread:
http://marc.info/?l=linux-arm-kernel&m=144051749807214&w=2
I am unsure what is going on, I suspect everyone involved in
the discussion is. I just want to repost this to get the
discussion restarted, as I still have to apply this patch
with every kernel iteration to get my PB11MPCore Realview
running.
Testing by Neil Armstrong on the Oxnas NAS has revealed that
this bug exist also on that widely deployed hardware, so
we are probably currently regressing all ARM11MPCore systems.
Fixes: a5e090acbf54 ("ARM: software-based priviledged-no-access support")
Tested-by: Neil Armstrong <narmstrong@baylibre.com>
commit f0e8faa7a5e894b0fc99d24be1b18685a92ea466 upstream.
This function clearly never worked and always returns true,
as pointed out by gcc-7:
arch/arm/mach-ux500/pm.c: In function 'prcmu_is_cpu_in_wfi':
arch/arm/mach-ux500/pm.c:137:212: error: ?:
using integer constants in boolean context, the expression
will always evaluate to 'true' [-Werror=int-in-bool-context]
With the added braces, the condition actually makes sense.
Fixes: 34fe6f107eab ("mfd : Check if the other db8500 core is in WFI")
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 1ea6af3216b092ec97129ac81bd95cf254c4b140 upstream.
This fixes commit ab8dd3aed011 ("ARM: DTS: Add minimal Support for
Logic PD DM3730 SOM-LV") where the Card Detect and Write Protect
pins were improperly configured.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730 SOM-LV")
commit 6ab5c2b662e2dcbb964099bf7f19e9dbc9ae5a41 upstream.
This patch fixes the following error:
sgtl5000 0-000a: Error reading chip id -6
imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
imx-sgtl5000 sound: snd_soc_register_card failed (-517)
The problem was that the pinctrl group was linked to the sound driver
instead of the codec node. Since the codec is probed first, the sys_mclk
was missing and it would therefore fail to initialize.
Fixes: b32e700256bc ("ARM: dts: imx: add Boundary Devices Nitrogen6_Max board")
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
commit 3d37d41a148c32389ed360e10a9f8a7cd37ce166 upstream.
Commit d1f3156fc8c7 ("ARM: dts: omap2: Remove skeleton.dtsi usage")
removed the skeleton.dtsi usage since we want to get rid of it.
But this can cause issues when booting a kernel with a boot-loader
that doesn't create a chosen node if this isn't present in the DTB
since the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info.
Fixes: d1f3156fc8c7 ("ARM: dts: omap2: Remove skeleton.dtsi usage")
Reported-by: Pali Rohar <pali.rohar@gmail.com>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
commit 23ab4c6183ac0679d80888b5c4cc1d528fcc21c2 upstream.
Commit 008a2ebcd677 ("ARM: dts: omap3: Remove skeleton.dtsi usage")
Fixes: 008a2ebcd677 ("ARM: dts: omap3: Remove skeleton.dtsi usage")
commit ce95077d0cdfcc8e40dea10a1680249831ccec77 upstream.
Commit 75813028bbd7 ("ARM: dts: am4372: Remove skeleton.dtsi usage")
Fixes: 75813028bbd7 ("ARM: dts: am4372: Remove skeleton.dtsi usage")
commit c9faa84cb9c34852ad70cb175457ae21fc06f39b upstream.
Commit 76a8548ea987 ("ARM: dts: omap5: Remove skeleton.dtsi usage")
Fixes: 76a8548ea987 ("ARM: dts: omap5: Remove skeleton.dtsi usage")
commit 6c565d1a63ce241a0100f5d327c48dde87b4df76 upstream.
Commit da6269e7e3dd ("ARM: dts: omap4: Remove skeleton.dtsi usage")
Fixes: da6269e7e3dd ("ARM: dts: omap4: Remove skeleton.dtsi usage")
commit 1d8d6d3f2f7d553c479f24ab93767974a8c2dfad upstream.
Commit f8bf01611c99 ("ARM: dts: am33xx: Remove skeleton.dtsi usage")
Fixes: f8bf01611c99 ("ARM: dts: am33xx: Remove skeleton.dtsi usage")
commit 9536fd30d41ae4f30d04762676e5f5f602e16aa8 upstream.
Commit 76155b378c59 ("ARM: dts: dm814x: Remove skeleton.dtsi usage")
Fixes: 76155b378c59 ("ARM: dts: dm814x: Remove skeleton.dtsi usage")
commit 6ed80b3a232e61da6d0189bbbe2b2b9afaefe3b3 upstream.
Commit 06bfb9c19957 ("ARM: dts: dm816x: Remove skeleton.dtsi usage")
Fixes: 06bfb9c19957 ("ARM: dts: dm816x: Remove skeleton.dtsi usage")
commit 7f6c857b12911ed56b2056f9d5491e16b5fc95ea upstream.
Commit 55871eb6e2cc ("ARM: dts: dra7: Remove skeleton.dtsi usage")
Fixes: 55871eb6e2cc ("ARM: dts: dra7: Remove skeleton.dtsi usage")
commit ad9e202aa1ce571b1d7fed969d06f66067f8a086 upstream.
We cannot preserve partial fields for hardware breakpoints, because
the values written by userspace to the hardware breakpoint
registers can't subsequently be recovered intact from the hardware.
So, just reject attempts to write incomplete fields with -EINVAL.
Fixes: 478fcb2cdb23 ("arm64: Debugging support")
Acked-by: Will Deacon <Will.Deacon@arm.com>
commit aeb1f39d814b2e21e5e5706a48834bfd553d0059 upstream.
This patch adds an explicit __reserved[] field to user_fpsimd_state
to replace what was previously unnamed padding.
This ensures that data in this region are propagated across
assignment rather than being left possibly uninitialised at the
destination.
Fixes: 60ffc30d5652 ("arm64: Exception handling")
commit a672401c00f82e4e19704aff361d9bad18003714 upstream.
Fixes: 5d220ff9420f ("arm64: Better native ptrace support for compat tasks")
commit 9dd73f72f218320c6c90da5f834996e7360dc227 upstream.
Fixes: 766a85d7bc5d ("arm64: ptrace: add NT_ARM_SYSTEM_CALL regset")
commit 9a17b876b573441bfb3387ad55d98bf7184daf9d upstream.
commit 7d9e8f71b989230bc613d121ca38507d34ada849 upstream.
Generally, taking an unexpected exception should be a fatal event, and
bad_mode is intended to cater for this. However, it should be possible
to contain unexpected synchronous exceptions from EL0 without bringing
the kernel down, by sending a SIGILL to the task.
We tried to apply this approach in commit 9955ac47f4ba1c95 ("arm64:
don't kill the kernel on a bad esr from el0"), by sending a signal for
any bad_mode call resulting from an EL0 exception.
However, this also applies to other unexpected exceptions, such as
SError and FIQ. The entry paths for these exceptions branch to bad_mode
without configuring the link register, and have no kernel_exit. Thus, if
we take one of these exceptions from EL0, bad_mode will eventually
return to the original user link register value.
This patch fixes this by introducing a new bad_el0_sync handler to cater
for the recoverable case, and restoring bad_mode to its original state,
whereby it calls panic() and never returns. The recoverable case
branches to bad_el0_sync with a bl, and returns to userspace via the
usual ret_to_user mechanism.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Fixes: 9955ac47f4ba1c95 ("arm64: don't kill the kernel on a bad esr from el0")
Reported-by: Mark Salter <msalter@redhat.com>
