All Freescale Vybrid SoC include a Cortex-A5 core which supports
ARM's standard PMU (performance monitoring unit). Include the
monitoring unit into the Cortex-A5 base device tree vf500.dtsi.
This is the 4.1.12 stable release
commit c56dadf39761a6157239cac39e3988998c994f98 upstream.
Function should_resched() is equal to (!preempt_count() && need_resched()).
In preemptive kernel preempt_count here is non-zero because of vc->lock.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Alexander Graf <agraf@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Link: http://lkml.kernel.org/r/20150715095203.12246.72922.stgit@buzz
commit 1a541b4e3cd6f5795022514114854b3e1345f24e upstream.
6910fa1 ("arm64: enable PTE type bit in the mask for pte_modify") fixes
a problem whereby a large block of PROT_NONE mapped memory is
incorrectly mapped as block descriptors when mprotect is called.
Unfortunately, a subtle bug was introduced by this fix to the THP logic.
If one mmaps a large block of memory, then faults it such that it is
collapsed into THPs; resulting calls to mprotect on this area of memory
will lead to incorrect table descriptors being written instead of block
descriptors. This is because pmd_modify calls pte_modify which is now
allowed to modify the type of the page table entry.
This patch reverts commit 6910fa16dbe142f6a0fd0fd7c249f9883ff7fc8a, and
fixes the problem it was trying to address by adjusting PAGE_NONE to
represent a table entry. Thus no change in pte type is required when
moving from PROT_NONE to a different protection.
Fixes: 6910fa16dbe1 ("arm64: enable PTE type bit in the mask for pte_modify")
Cc: <stable@vger.kernel.org> # 4.0+
Cc: Feng Kan <fkan@apm.com>
Reported-by: Ganapatrao Kulkarni <Ganapatrao.Kulkarni@caviumnetworks.com>
Tested-by: Ganapatrao Kulkarni <gkulkarni@caviumnetworks.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
[SteveC: backported 1a541b4e3cd6f5795022514114854b3e1345f24e to 4.1 and
4.2 stable. Just one minor fix to second part to allow patch to apply
cleanly, no logic changed.]
Signed-off-by: Steve Capper <steve.capper@linaro.org>
commit fe32d3cd5e8eb0f82e459763374aa80797023403 upstream.
These functions check should_resched() before unlocking spinlock/bh-enable:
preempt_count always non-zero => should_resched() always returns false.
cond_resched_lock() worked iff spin_needbreak is set.
This patch adds argument "preempt_offset" to should_resched().
preempt_count offset constants for that:
PREEMPT_DISABLE_OFFSET - offset after preempt_disable()
PREEMPT_LOCK_OFFSET - offset after spin_lock()
SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable()
SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh()
Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers")
Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit b6dd8e0719c0d2d01429639a11b7bc2677de240c upstream.
Commit df057cc7b4fa ("arm64: errata: add module build workaround for
erratum #843419") sets CFLAGS_MODULE to ensure that the large memory
model is used by the compiler when building kernel modules.
However, CFLAGS_MODULE is an environment variable and intended to be
overridden on the command line, which appears to be the case with the
Ubuntu kernel packaging system, so use KBUILD_CFLAGS_MODULE instead.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: df057cc7b4fa ("arm64: errata: add module build workaround for erratum #843419")
Reported-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
commit a66d7f724a96d6fd279bfbd2ee488def6b081bea upstream.
Some of the crypto algorithms write to the initialization vector,
but no space has been allocated for it. This clobbers adjacent memory.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
The current pinmux disables the output driver of the backlight
GPIO pin. This is fine for most GPIO's, however, if the backlight
pin has been enabled in the boot loader, this can lead to fickers
on the display during boot.
Enable the output driver by default.
The values which we used so far used to be a mix between the values
of the Linux 3.0 based BSP and the values used in the upstream kernel
tree. The origin of both value is likely not related to Vybrid and
just wrong (see the corsponding Freescale Community thread). The
reset values seem to be the better bet. Performance mesurement did
not show any impact or at best very marginal improvement.
This is the 4.1.11 stable release
commit fc2ca674470bbfe11d72a20a3f19fd3dc43bfca0 upstream.
Commit 3adeb2566b9b ("MIPS: Loongson: Improve LEFI firmware interface")
made the number of UARTs dynamic if LEFI_FIRMWARE_INTERFACE is configured.
Unfortunately, it did not initialize the number of UARTs if
LEFI_FIRMWARE_INTERFACE is not configured. As a result, the Fulong2e
system has no console.
Fixes: 3adeb2566b9b ("MIPS: Loongson: Improve LEFI firmware interface")
Acked-by: Huacai Chen <chenhc@lemote.com>
Tested-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/11076/
commit 8474ba74193d302e8340dddd1e16c85cc4b98caf upstream.
Make sure the compiler does not modify arguments of syscall functions.
This can happen if the compiler generates a tailcall to another
function. For example, without asmlinkage_protect sys_openat is compiled
into this function:
sys_openat:
clr.l %d0
move.w 18(%sp),%d0
move.l %d0,16(%sp)
jbra do_sys_open
Note how the fourth argument is modified in place, modifying the register
%d4 that gets restored from this stack slot when the function returns to
user-space. The caller may expect the register to be unmodified across
system calls.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit 569ba74a7ba69f46ce2950bf085b37fea2408385 upstream.
This is the arm64 portion of commit 45cac65b0fcd ("readahead: fault
retry breaks mmap file read random detection"), which was absent from
the initial port and has since gone unnoticed. The original commit says:
> .fault now can retry. The retry can break state machine of .fault. In
> filemap_fault, if page is miss, ra->mmap_miss is increased. In the second
> try, since the page is in page cache now, ra->mmap_miss is decreased. And
> these are done in one fault, so we can't detect random mmap file access.
> Add a new flag to indicate .fault is tried once. In the second try, skip
> ra->mmap_miss decreasing. The filemap_fault state machine is ok with it.
With this change, Mark reports that:
> Random read improves by 250%, sequential read improves by 40%, and
> random write by 400% to an eMMC device with dm crypto wrapped around it.
Cc: Shaohua Li <shli@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Signed-off-by: Riley Andrews <riandrews@android.com>
commit ee556d00cf20012e889344a0adbbf809ab5015a3 upstream.
When function graph tracer is enabled, the following operation
will trigger panic:
mount -t debugfs nodev /sys/kernel
echo next_tgid > /sys/kernel/tracing/set_ftrace_filter
echo function_graph > /sys/kernel/tracing/current_tracer
ls /proc/
[ 198.501417] Unable to handle kernel paging request at virtual address cb88537fdc8ba316
[ 198.506126] pgd = ffffffc008f79000
[ 198.509363] [cb88537fdc8ba316] *pgd=00000000488c6003, *pud=00000000488c6003, *pmd=0000000000000000
[ 198.517726] Internal error: Oops: 94000005 [#1] SMP
[ 198.518798] Modules linked in:
[ 198.520582] CPU: 1 PID: 1388 Comm: ls Tainted: G
[ 198.521800] Hardware name: linux,dummy-virt (DT)
[ 198.522852] task: ffffffc0fa9e8000 ti: ffffffc0f9ab0000 task.ti: ffffffc0f9ab0000
[ 198.524306] PC is at next_tgid+0x30/0x100
[ 198.525205] LR is at return_to_handler+0x0/0x20
[ 198.526090] pc : [<ffffffc0002a1070>] lr : [<ffffffc0000907c0>] pstate: 60000145
[ 198.527392] sp : ffffffc0f9ab3d40
[ 198.528084] x29: ffffffc0f9ab3d40 x28: ffffffc0f9ab0000
[ 198.529406] x27: ffffffc000d6a000 x26: ffffffc000b786e8
[ 198.530659] x25: ffffffc0002a1900 x24: ffffffc0faf16c00
[ 198.531942] x23: ffffffc0f9ab3ea0 x22: 0000000000000002
[ 198.533202] x21: ffffffc000d85050 x20: 0000000000000002
[ 198.534446] x19: 0000000000000002 x18: 0000000000000000
[ 198.535719] x17: 000000000049fa08 x16: ffffffc000242efc
[ 198.537030] x15: 0000007fa472b54c x14: ffffffffff000000
[ 198.538347] x13: ffffffc0fada84a0 x12: 0000000000000001
[ 198.539634] x11: ffffffc0f9ab3d70 x10: ffffffc0f9ab3d70
[ 198.540915] x9 : ffffffc0000907c0 x8 : ffffffc0f9ab3d40
[ 198.542215] x7 : 0000002e330f08f0 x6 : 0000000000000015
[ 198.543508] x5 : 0000000000000f08 x4 : ffffffc0f9835ec0
[ 198.544792] x3 : cb88537fdc8ba316 x2 : cb88537fdc8ba306
[ 198.546108] x1 : 0000000000000002 x0 : ffffffc000d85050
[ 198.547432]
[ 198.547920] Process ls (pid: 1388, stack limit = 0xffffffc0f9ab0020)
[ 198.549170] Stack: (0xffffffc0f9ab3d40 to 0xffffffc0f9ab4000)
[ 198.582568] Call trace:
[ 198.583313] [<ffffffc0002a1070>] next_tgid+0x30/0x100
[ 198.584359] [<ffffffc0000907bc>] ftrace_graph_caller+0x6c/0x70
[ 198.585503] [<ffffffc0000907bc>] ftrace_graph_caller+0x6c/0x70
[ 198.586574] [<ffffffc0000907bc>] ftrace_graph_caller+0x6c/0x70
[ 198.587660] [<ffffffc0000907bc>] ftrace_graph_caller+0x6c/0x70
[ 198.588896] Code: aa0003f5 2a0103f4 b4000102 91004043 (885f7c60)
[ 198.591092] ---[ end trace 6a346f8f20949ac8 ]---
This is because when using function graph tracer, if the traced
function return value is in multi regs ([x0-x7]), return_to_handler
may corrupt them. So in return_to_handler, the parameter regs should
be protected properly.
Signed-off-by: Li Bin <huawei.libin@huawei.com>
Acked-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
commit 0ce3cc008ec04258b6a6314b09f1a6012810881a upstream.
The new Properties Table feature introduced in UEFIv2.5 may
split memory regions that cover PE/COFF memory images into
separate code and data regions. Since these regions only differ
in the type (runtime code vs runtime data) and the permission
bits, but not in the memory type attributes (UC/WC/WT/WB), the
spec does not require them to be aligned to 64 KB.
Since the relative offset of PE/COFF .text and .data segments
cannot be changed on the fly, this means that we can no longer
pad out those regions to be mappable using 64 KB pages.
Unfortunately, there is no annotation in the UEFI memory map
that identifies data regions that were split off from a code
region, so we must apply this logic to all adjacent runtime
regions whose attributes only differ in the permission bits.
So instead of rounding each memory region to 64 KB alignment at
both ends, only round down regions that are not directly
preceded by another runtime region with the same type
attributes. Since the UEFI spec does not mandate that the memory
map be sorted, this means we also need to sort it first.
Note that this change will result in all EFI_MEMORY_RUNTIME
regions whose start addresses are not aligned to the OS page
size to be mapped with executable permissions (i.e., on kernels
compiled with 64 KB pages). However, since these mappings are
only active during the time that UEFI Runtime Services are being
invoked, the window for abuse is rather small.
Tested-by: Mark Salter <msalter@redhat.com>
Tested-by: Mark Rutland <mark.rutland@arm.com> [UEFI 2.4 only]
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Reviewed-by: Mark Salter <msalter@redhat.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Link: http://lkml.kernel.org/r/1443218539-7610-3-git-send-email-matt@codeblueprint.co.uk
commit e297c939b745e420ef0b9dc989cb87bda617b399 upstream.
This fixes a race which can result in the same virtual IRQ number
being assigned to two different MSI interrupts. The most visible
consequence of that is usually a warning and stack trace from the
sysfs code about an attempt to create a duplicate entry in sysfs.
The race happens when one CPU (say CPU 0) is disposing of an MSI
while another CPU (say CPU 1) is setting up an MSI. CPU 0 calls
(for example) pnv_teardown_msi_irqs(), which calls
msi_bitmap_free_hwirqs() to indicate that the MSI (i.e. its
hardware IRQ number) is no longer in use. Then, before CPU 0 gets
to calling irq_dispose_mapping() to free up the virtal IRQ number,
CPU 1 comes in and calls msi_bitmap_alloc_hwirqs() to allocate an
MSI, and gets the same hardware IRQ number that CPU 0 just freed.
CPU 1 then calls irq_create_mapping() to get a virtual IRQ number,
which sees that there is currently a mapping for that hardware IRQ
number and returns the corresponding virtual IRQ number (which is
the same virtual IRQ number that CPU 0 was using). CPU 0 then
calls irq_dispose_mapping() and frees that virtual IRQ number.
Now, if another CPU comes along and calls irq_create_mapping(), it
is likely to get the virtual IRQ number that was just freed,
resulting in the same virtual IRQ number apparently being used for
two different hardware interrupts.
To fix this race, we just move the call to msi_bitmap_free_hwirqs()
to after the call to irq_dispose_mapping(). Since virq_to_hw()
doesn't work for the virtual IRQ number after irq_dispose_mapping()
has been called, we need to call it before irq_dispose_mapping() and
remember the result for the msi_bitmap_free_hwirqs() call.
The pattern of calling msi_bitmap_free_hwirqs() before
irq_dispose_mapping() appears in 5 places under arch/powerpc, and
appears to have originated in commit 05af7bd2d75e ("[POWERPC] MPIC
U3/U4 MSI backend") from 2007.
Fixes: 05af7bd2d75e ("[POWERPC] MPIC U3/U4 MSI backend")
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
commit 53960059d56ecef67d4ddd546731623641a3d2d1 upstream.
If there is a DMA zone (usually 24bit = 16MB I believe), but no DMA32
zone, as is the case for some 32-bit kernels, then massage_gfp_flags()
will cause DMA memory allocated for devices with a 32..63-bit
coherent_dma_mask to fall back to using __GFP_DMA, even though there may
only be 32-bits of physical address available anyway.
Correct that case to compare against a mask the size of phys_addr_t
instead of always using a 64-bit mask.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Fixes: a2e715a86c6d ("MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask.")
Patchwork: https://patchwork.linux-mips.org/patch/9610/
commit cf75eb15be2bdd054a76aeef6458beaa4a6ab770 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 94d76946859b4bcfa0da373357f14feda2af0622 upstream.
commit aca45c0e95dad1c4ba4d38da192756b0e10cbbbd upstream.
commit adc0b7fbf6fe9967505c0254d9535ec7288186ae upstream.
my gcc 5.1 used an ldgr instruction with a register != 0,2,4,6 for
spilling/filling into a floating point register in our decompressor.
This will cause an AFP-register data exception as the decompressor
did not setup the additional floating point registers via cr0.
That causes a program check loop that looked like a hang with
one "Uncompressing Linux... " message (directly booted via kvm)
or a loop of "Uncompressing Linux... " messages (when booted via
zipl boot loader).
The offending code in my build was
48e400: e3 c0 af ff ff 71 lay %r12,-1(%r10)
-->48e406: b3 c1 00 1c ldgr %f1,%r12
48e40a: ec 6c 01 22 02 7f clij %r6,2,12,0x48e64e
but gcc could do spilling into an fpr at any function. We can
simply disable floating point support at that early stage.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit 8d4bd0ed0439dfc780aab801a085961925ed6838 upstream.
The uc_sigmask in the ucontext structure is an array of words to keep
the 64 signal bits (or 1024 if you ask glibc but the kernel sigset_t
only has 64 bits).
For 64 bit the sigset_t contains a single 8 byte word, but for 31 bit
there are two 4 byte words. The compat signal handler code uses a
simple copy of the 64 bit sigset_t to the 31 bit compat_sigset_t.
As s390 is a big-endian architecture this is incorrect, the two words
in the 31 bit sigset_t array need to be swapped.
Reported-by: Stefan Liebler <stli@linux.vnet.ibm.com>
commit 0b34a166f291d255755be46e43ed5497cdd194f2 upstream.
Currently there is a number of issues preventing PVHVM Xen guests from
doing successful kexec/kdump:
- Bound event channels.
- Registered vcpu_info.
- PIRQ/emuirq mappings.
- shared_info frame after XENMAPSPACE_shared_info operation.
- Active grant mappings.
Basically, newly booted kernel stumbles upon already set up Xen
interfaces and there is no way to reestablish them. In Xen-4.7 a new
feature called 'soft reset' is coming. A guest performing kexec/kdump
operation is supposed to call SCHEDOP_shutdown hypercall with
SHUTDOWN_soft_reset reason before jumping to new kernel. Hypervisor
(with some help from toolstack) will do full domain cleanup (but
keeping its memory and vCPU contexts intact) returning the guest to
the state it had when it was first booted and thus allowing it to
start over.
Doing SHUTDOWN_soft_reset on Xen hypervisors which don't support it is
probably OK as by default all unknown shutdown reasons cause domain
destroy with a message in toolstack log: 'Unknown shutdown reason code
5. Destroying domain.' which gives a clue to what the problem is and
eliminates false expectations.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit ab76f7b4ab2397ffdd2f1eb07c55697d19991d10 upstream.
Unused space between the end of __ex_table and the start of
rodata can be left W+x in the kernel page tables. Extend the
setting of the NX bit to cover this gap by starting from
text_end rather than rodata_start.
Before:
---[ High Kernel Mapping ]---
0xffffffff80000000-0xffffffff81000000 16M pmd
0xffffffff81000000-0xffffffff81600000 6M ro PSE GLB x pmd
0xffffffff81600000-0xffffffff81754000 1360K ro GLB x pte
0xffffffff81754000-0xffffffff81800000 688K RW GLB x pte
0xffffffff81800000-0xffffffff81a00000 2M ro PSE GLB NX pmd
0xffffffff81a00000-0xffffffff81b3b000 1260K ro GLB NX pte
0xffffffff81b3b000-0xffffffff82000000 4884K RW GLB NX pte
0xffffffff82000000-0xffffffff82200000 2M RW PSE GLB NX pmd
0xffffffff82200000-0xffffffffa0000000 478M pmd
After:
0xffffffff81754000-0xffffffff81800000 688K RW GLB NX pte
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Link: http://lkml.kernel.org/r/1443704662-3138-1-git-send-email-sds@tycho.nsa.gov
commit eddd3826a1a0190e5235703d1e666affa4d13b96 upstream.
Dmitry Vyukov reported the following using trinity and the memory
error detector AddressSanitizer
(https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel).
[ 124.575597] ERROR: AddressSanitizer: heap-buffer-overflow on
address ffff88002e280000
[ 124.576801] ffff88002e280000 is located 131938492886538 bytes to
the left of 28857600-byte region [ffffffff81282e0a, ffffffff82e0830a)
[ 124.578633] Accessed by thread T10915:
[ 124.579295] inlined in describe_heap_address
./arch/x86/mm/asan/report.c:164
[ 124.579295] #0 ffffffff810dd277 in asan_report_error
./arch/x86/mm/asan/report.c:278
[ 124.580137] #1 ffffffff810dc6a0 in asan_check_region
./arch/x86/mm/asan/asan.c:37
[ 124.581050] #2 ffffffff810dd423 in __tsan_read8 ??:0
[ 124.581893] #3 ffffffff8107c093 in get_wchan
./arch/x86/kernel/process_64.c:444
The address checks in the 64bit implementation of get_wchan() are
wrong in several ways:
- The lower bound of the stack is not the start of the stack
page. It's the start of the stack page plus sizeof (struct
thread_info)
- The upper bound must be:
top_of_stack - TOP_OF_KERNEL_STACK_PADDING - 2 * sizeof(unsigned long).
The 2 * sizeof(unsigned long) is required because the stack pointer
points at the frame pointer. The layout on the stack is: ... IP FP
... IP FP. So we need to make sure that both IP and FP are in the
bounds.
Fix the bound checks and get rid of the mix of numeric constants, u64
and unsigned long. Making all unsigned long allows us to use the same
function for 32bit as well.
Use READ_ONCE() when accessing the stack. This does not prevent a
concurrent wakeup of the task and the stack changing, but at least it
avoids TOCTOU.
Also check task state at the end of the loop. Again that does not
prevent concurrent changes, but it avoids walking for nothing.
Add proper comments while at it.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Based-on-patch-from: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
Reviewed-by: Borislav Petkov <bp@alien8.de>
Reviewed-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: kasan-dev <kasan-dev@googlegroups.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
Link: http://lkml.kernel.org/r/20150930083302.694788319@linutronix.de
commit e3c41e37b0f4b18cbd4dac76cbeece5a7558b909 upstream.
The original bug is a page fault crash that sometimes happens
on big machines when preparing ELF headers:
BUG: unable to handle kernel paging request at ffffc90613fc9000
IP: [<ffffffff8103d645>] prepare_elf64_ram_headers_callback+0x165/0x260
The bug is caused by us under-counting the number of memory ranges
and subsequently not allocating enough ELF header space for them.
The bug is typically masked on smaller systems, because the ELF header
allocation is rounded up to the next page.
This patch modifies the code in fill_up_crash_elf_data() by using
walk_system_ram_res() instead of walk_system_ram_range() to correctly
count the max number of crash memory ranges. That's because the
walk_system_ram_range() filters out small memory regions that
reside in the same page, but walk_system_ram_res() does not.
Here's how I found the bug:
After tracing prepare_elf64_headers() and prepare_elf64_ram_headers_callback(),
the code uses walk_system_ram_res() to fill-in crash memory regions information
to the program header, so it counts those small memory regions that
reside in a page area.
But, when the kernel was using walk_system_ram_range() in
fill_up_crash_elf_data() to count the number of crash memory regions,
it filters out small regions.
I printed those small memory regions, for example:
kexec: Get nr_ram ranges. vaddr=0xffff880077592258 paddr=0x77592258, sz=0xdc0
Based on the code in walk_system_ram_range(), this memory region
will be filtered out:
pfn = (0x77592258 + 0x1000 - 1) >> 12 = 0x77593
end_pfn = (0x77592258 + 0xfc0 -1 + 1) >> 12 = 0x77593
end_pfn - pfn = 0x77593 - 0x77593 = 0 <=== if (end_pfn > pfn) is FALSE
So, the max_nr_ranges that's counted by the kernel doesn't include
small memory regions - causing us to under-allocate the required space.
That causes the page fault crash that happens in a later code path
when preparing ELF headers.
This bug is not easy to reproduce on small machines that have few
CPUs, because the allocated page aligned ELF buffer has more free
space to cover those small memory regions' PT_LOAD headers.
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
Cc: Baoquan He <bhe@redhat.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: kexec@lists.infradead.org
Link: http://lkml.kernel.org/r/1443531537-29436-1-git-send-email-jlee@suse.com
instead of top-down
commit a5caa209ba9c29c6421292e7879d2387a2ef39c9 upstream.
Beginning with UEFI v2.5 EFI_PROPERTIES_TABLE was introduced
that signals that the firmware PE/COFF loader supports splitting
code and data sections of PE/COFF images into separate EFI
memory map entries. This allows the kernel to map those regions
with strict memory protections, e.g. EFI_MEMORY_RO for code,
EFI_MEMORY_XP for data, etc.
Unfortunately, an unwritten requirement of this new feature is
that the regions need to be mapped with the same offsets
relative to each other as observed in the EFI memory map. If
this is not done crashes like this may occur,
BUG: unable to handle kernel paging request at fffffffefe6086dd
IP: [<fffffffefe6086dd>] 0xfffffffefe6086dd
Call Trace:
[<ffffffff8104c90e>] efi_call+0x7e/0x100
[<ffffffff81602091>] ? virt_efi_set_variable+0x61/0x90
[<ffffffff8104c583>] efi_delete_dummy_variable+0x63/0x70
[<ffffffff81f4e4aa>] efi_enter_virtual_mode+0x383/0x392
[<ffffffff81f37e1b>] start_kernel+0x38a/0x417
[<ffffffff81f37495>] x86_64_start_reservations+0x2a/0x2c
[<ffffffff81f37582>] x86_64_start_kernel+0xeb/0xef
Here 0xfffffffefe6086dd refers to an address the firmware
expects to be mapped but which the OS never claimed was mapped.
The issue is that included in these regions are relative
addresses to other regions which were emitted by the firmware
toolchain before the "splitting" of sections occurred at
runtime.
Needless to say, we don't satisfy this unwritten requirement on
x86_64 and instead map the EFI memory map entries in reverse
order. The above crash is almost certainly triggerable with any
kernel newer than v3.13 because that's when we rewrote the EFI
runtime region mapping code, in commit d2f7cbe7b26a ("x86/efi:
Runtime services virtual mapping"). For kernel versions before
v3.13 things may work by pure luck depending on the
fragmentation of the kernel virtual address space at the time we
map the EFI regions.
Instead of mapping the EFI memory map entries in reverse order,
where entry N has a higher virtual address than entry N+1, map
them in the same order as they appear in the EFI memory map to
preserve this relative offset between regions.
This patch has been kept as small as possible with the intention
that it should be applied aggressively to stable and
distribution kernels. It is very much a bugfix rather than
support for a new feature, since when EFI_PROPERTIES_TABLE is
enabled we must map things as outlined above to even boot - we
have no way of asking the firmware not to split the code/data
regions.
In fact, this patch doesn't even make use of the more strict
memory protections available in UEFI v2.5. That will come later.
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chun-Yi <jlee@suse.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: James Bottomley <JBottomley@Odin.com>
Cc: Lee, Chun-Yi <jlee@suse.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Peter Jones <pjones@redhat.com>
Link: http://lkml.kernel.org/r/1443218539-7610-2-git-send-email-matt@codeblueprint.co.uk
commit d2922422c48df93f3edff7d872ee4f3191fefb08 upstream.
The cpu feature flags are not ever going to change, so warning
everytime can cause a lot of kernel log spam
(in our case more than 10GB/hour).
The warning seems to only occur when nested virtualization is
enabled, so it's probably triggered by a KVM bug. This is a
sensible and safe change anyway, and the KVM bug fix might not
be suitable for stable releases anyway.
Signed-off-by: Dirk Mueller <dmueller@suse.com>
commit 83c133cf11fb0e68a51681447e372489f052d40e upstream.
The NMI entry code that switches to the normal kernel stack needs to
be very careful not to clobber any extra stack slots on the NMI
stack. The code is fine under the assumption that SWAPGS is just a
normal instruction, but that assumption isn't really true. Use
SWAPGS_UNSAFE_STACK instead.
This is part of a fix for some random crashes that Sasha saw.
Fixes: 9b6e6a8334d5 ("x86/nmi/64: Switch stacks on userspace NMI entry")
Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/974bc40edffdb5c2950a5c4977f821a446b76178.1442791737.git.luto@kernel.org
commit fc57a7c68020dcf954428869eafd934c0ab1536f upstream.
PARAVIRT_ADJUST_EXCEPTION_FRAME generates this code (using nmi as an
example, trimmed for readability):
ff 15 00 00 00 00 callq *0x0(%rip) # 2796 <nmi+0x6>
2792: R_X86_64_PC32 pv_irq_ops+0x2c
That's a call through a function pointer to regular C function that
does nothing on native boots, but that function isn't protected
against kprobes, isn't marked notrace, and is certainly not
guaranteed to preserve any registers if the compiler is feeling
perverse. This is bad news for a CLBR_NONE operation.
Of course, if everything works correctly, once paravirt ops are
patched, it gets nopped out, but what if we hit this code before
paravirt ops are patched in? This can potentially cause breakage
that is very difficult to debug.
A more subtle failure is possible here, too: if _paravirt_nop uses
the stack at all (even just to push RBP), it will overwrite the "NMI
executing" variable if it's called in the NMI prologue.
The Xen case, perhaps surprisingly, is fine, because it's already
written in asm.
Fix all of the cases that default to paravirt_nop (including
adjust_exception_frame) with a big hammer: replace paravirt_nop with
an asm function that is just a ret instruction.
The Xen case may have other problems, so document them.
Link: http://lkml.kernel.org/r/8f5d2ba295f9d73751c33d97fda03e0495d9ade0.1442791737.git.luto@kernel.org
commit 03da3ff1cfcd7774c8780d2547ba0d995f7dc03d upstream.
In 2007, commit 07190a08eef36 ("Mark TSC on GeodeLX reliable")
bypassed verification of the TSC on Geode LX. However, this code
(now in the check_system_tsc_reliable() function in
arch/x86/kernel/tsc.c) was only present if CONFIG_MGEODE_LX was
set.
OpenWRT has recently started building its generic Geode target
for Geode GX, not LX, to include support for additional
platforms. This broke the timekeeping on LX-based devices,
because the TSC wasn't marked as reliable:
https://dev.openwrt.org/ticket/20531
By adding a runtime check on is_geode_lx(), we can also include
the fix if CONFIG_MGEODEGX1 or CONFIG_X86_GENERIC are set, thus
fixing the problem.
Cc: Andres Salomon <dilinger@queued.net>
Cc: Marcelo Tosatti <marcelo@kvack.org>
Link: http://lkml.kernel.org/r/1442409003.131189.87.camel@infradead.org
commit 66c117d7fa2ae429911e60d84bf31a90b2b96189 upstream.
Richard reported the following crash:
[ 0.036000] BUG: unable to handle kernel paging request at 55501e06
[ 0.036000] IP: [<c0aae48b>] common_interrupt+0xb/0x38
[ 0.036000] Call Trace:
[ 0.036000] [<c0409c80>] ? add_nops+0x90/0xa0
[ 0.036000] [<c040a054>] apply_alternatives+0x274/0x630
Chuck decoded:
" 0: 8d 90 90 83 04 24 lea 0x24048390(%eax),%edx
6: 80 fc 0f cmp $0xf,%ah
9: a8 0f test $0xf,%al
>> b: a0 06 1e 50 55 mov 0x55501e06,%al
10: 57 push %edi
11: 56 push %esi
Interrupt 0x30 occurred while the alternatives code was replacing the
initial 0x90,0x90,0x90 NOPs (from the ASM_CLAC macro) with the
optimized version, 0x8d,0x76,0x00. Only the first byte has been
replaced so far, and it makes a mess out of the insn decoding."
optimize_nops() is buggy in two aspects:
- It's not disabling interrupts across the modification
- It's lacking a sync_core() call
Add both.
Fixes: 4fd4b6e5537c 'x86/alternatives: Use optimized NOPs for padding'
Reported-and-tested-by: "Richard W.M. Jones" <rjones@redhat.com>
Cc: Richard W.M. Jones <rjones@redhat.com>
Cc: Chuck Ebbert <cebbert.lkml@gmail.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1509031232340.15006@nanos
commit 5d7c631d926b59aa16f3c56eaeb83f1036c81dc7 upstream.
The APIC LVTT register is MMIO mapped but the TSC_DEADLINE register is an
MSR. The write to the TSC_DEADLINE MSR is not serializing, so it's not
guaranteed that the write to LVTT has reached the APIC before the
TSC_DEADLINE MSR is written. In such a case the write to the MSR is
ignored and as a consequence the local timer interrupt never fires.
The SDM decribes this issue for xAPIC and x2APIC modes. The
serialization methods recommended by the SDM differ.
xAPIC:
"1. Memory-mapped write to LVT Timer Register, setting bits 18:17 to 10b.
2. WRMSR to the IA32_TSC_DEADLINE MSR a value much larger than current time-stamp counter.
3. If RDMSR of the IA32_TSC_DEADLINE MSR returns zero, go to step 2.
4. WRMSR to the IA32_TSC_DEADLINE MSR the desired deadline."
x2APIC:
"To allow for efficient access to the APIC registers in x2APIC mode,
the serializing semantics of WRMSR are relaxed when writing to the
APIC registers. Thus, system software should not use 'WRMSR to APIC
registers in x2APIC mode' as a serializing instruction. Read and write
accesses to the APIC registers will occur in program order. A WRMSR to
an APIC register may complete before all preceding stores are globally
visible; software can prevent this by inserting a serializing
instruction, an SFENCE, or an MFENCE before the WRMSR."
The xAPIC method is to just wait for the memory mapped write to hit
the LVTT by checking whether the MSR write has reached the hardware.
There is no reason why a proper MFENCE after the memory mapped write would
not do the same. Andi Kleen confirmed that MFENCE is sufficient for the
xAPIC case as well.
Issue MFENCE before writing to the TSC_DEADLINE MSR. This can be done
unconditionally as all CPUs which have TSC_DEADLINE also have MFENCE
support.
[ tglx: Massaged the changelog ]
Signed-off-by: Shaohua Li <shli@fb.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: <Kernel-team@fb.com>
Cc: <lenb@kernel.org>
Cc: <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/20150909041352.GA2059853@devbig257.prn2.facebook.com
commit 0af822110871400908d5b6f83a8908c45f881d8f upstream.
This fixes a duplicated pin control causing this error:
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_GPIO_1 already
requested by regulators:regulator@2; cannot claim for 2184000.usb
imx6q-pinctrl 20e0000.iomuxc: pin-137 (2184000.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 137
(MX6Q_PAD_GPIO_1) from group usbotggrp on device 20e0000.iomuxc
imx_usb 2184000.usb: Error applying setting, reverse things
back
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_EIM_D31 already
requested by regulators:regulator@1; cannot claim for 2184200.usb
imx6q-pinctrl 20e0000.iomuxc: pin-52 (2184200.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 52 (MX6Q_PAD_EIM_D31)
from group usbh1grp on device 20e0000.iomuxc
imx_usb 2184200.usb: Error applying setting, reverse things
back
Signed-off-by: Felipe F. Tonello <eu@felipetonello.com>
Fixes: e2047e33f2bd ("ARM: dts: add initial Rex Pro board support")
commit 833b5794e3303cc97a0d2d4ba97f26cc9d9b4b79 upstream.
The cpu booting of exynos5422 has been still broken since we discussed
it in last year[1]. This patch is inspired from Odroid XU3
code (Actually, it was from samsung exynos vendor kernel)[2]. This weird
reset code was founded exynos5420 octa cores series SoCs and only
required for the first boot core is the Little core (Cortex A7).
Some of the exynos5420 boards and all of the exynos5422 boards will require
this code.
There is two ways to check the little core is the first cpu. One is
checking GPG2CON[1] GPIO value and the other is checking the cluster
number of the first cpu. I selected the latter because it's more easier
than the former.
[1] http://lists.infradead.org/pipermail/linux-arm-kernel/2015-June/350632.html
[2] https://patchwork.kernel.org/patch/6782891/
Cc: Kevin Hilman <khilman@kernel.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Signed-off-by: Chanho Park <parkch98@gmail.com>
[k.kozlowski: Adding stable for v4.1+, reformat comment]
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit 3a2fa775bd1d0579113666c1a2e37654a34018a0 upstream.
Let's fix pinmux address of gpio 170 used by tfp410 powerdown-gpio.
According to the OMAP35x Technical Reference Manual
CONTROL_PADCONF_I2C3_SDA[15:0] 0x480021C4 mode0: i2c3_sda
CONTROL_PADCONF_I2C3_SDA[31:16] 0x480021C4 mode4: gpio_170
the pinmux address of gpio 170 must be 0x480021C6.
The former wrong address broke i2c3 (used by hdmi ddc), resulting in
kernel message:
omap_i2c 48060000.i2c: controller timed out
Fixes: 8cecf52befd7 ("ARM: omap3-beagle.dts: add display information")
Signed-off-by: Carl Frederik Werner <frederik@cfbw.eu>
commit 1dbdad75074d16c3e3005180f81a01cdc04a7872 upstream.
The i2c5 pinctrl offsets are wrong. If the bootloader doesn't set the
pins up, communication with tca6424a doesn't work (controller timeouts)
and it is not possible to enable HDMI.
Fixes: 9be495c42609 ("ARM: dts: omap5-evm: Add I2c pinctrl data")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
commit 7ae85dc7687c7e7119053d83d02c560ea217b772 upstream.
In (23a4e40 arm: kgdb: Handle read-only text / modules) we moved to
using patch_text() to set breakpoints so that we could handle the case
when we had CONFIG_DEBUG_RODATA. That patch used patch_text().
Unfortunately, patch_text() assumes that we're not in atomic context
when it runs since it needs to grab a mutex and also wait for other
CPUs to stop (which it does with a completion).
This would result in a stack crawl if you had
CONFIG_DEBUG_ATOMIC_SLEEP and tried to set a breakpoint in kgdb. The
crawl looked something like:
BUG: scheduling while atomic: swapper/0/0/0x00010007
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.2.0-rc7-00133-geb63b34 #1073
Hardware name: Rockchip (Device Tree)
(unwind_backtrace) from [<c00133d4>] (show_stack+0x20/0x24)
(show_stack) from [<c05400e8>] (dump_stack+0x84/0xb8)
(dump_stack) from [<c004913c>] (__schedule_bug+0x54/0x6c)
(__schedule_bug) from [<c054065c>] (__schedule+0x80/0x668)
(__schedule) from [<c0540cfc>] (schedule+0xb8/0xd4)
(schedule) from [<c0543a3c>] (schedule_timeout+0x2c/0x234)
(schedule_timeout) from [<c05417c0>] (wait_for_common+0xf4/0x188)
(wait_for_common) from [<c0541874>] (wait_for_completion+0x20/0x24)
(wait_for_completion) from [<c00a0104>] (__stop_cpus+0x58/0x70)
(__stop_cpus) from [<c00a0580>] (stop_cpus+0x3c/0x54)
(stop_cpus) from [<c00a06c4>] (__stop_machine+0xcc/0xe8)
(__stop_machine) from [<c00a0714>] (stop_machine+0x34/0x44)
(stop_machine) from [<c00173e8>] (patch_text+0x28/0x34)
(patch_text) from [<c001733c>] (kgdb_arch_set_breakpoint+0x40/0x4c)
(kgdb_arch_set_breakpoint) from [<c00a0d68>] (kgdb_validate_break_address+0x2c/0x60)
(kgdb_validate_break_address) from [<c00a0e90>] (dbg_set_sw_break+0x1c/0xdc)
(dbg_set_sw_break) from [<c00a2e88>] (gdb_serial_stub+0x9c4/0xba4)
(gdb_serial_stub) from [<c00a11cc>] (kgdb_cpu_enter+0x1f8/0x60c)
(kgdb_cpu_enter) from [<c00a18cc>] (kgdb_handle_exception+0x19c/0x1d0)
(kgdb_handle_exception) from [<c0016f7c>] (kgdb_compiled_brk_fn+0x30/0x3c)
(kgdb_compiled_brk_fn) from [<c00091a4>] (do_undefinstr+0x1a4/0x20c)
(do_undefinstr) from [<c001400c>] (__und_svc_finish+0x0/0x34)
It turns out that when we're in kgdb all the CPUs are stopped anyway
so there's no reason we should be calling patch_text(). We can
instead directly call __patch_text() which assumes that CPUs have
already been stopped.
Fixes: 23a4e4050ba9 ("arm: kgdb: Handle read-only text / modules")
Reported-by: Aapo Vienamo <avienamo@nvidia.com>
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
commit a077224fd35b2f7fbc93f14cf67074fc792fbac2 upstream.
While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Acked-by: Nicolas Pitre <nico@linaro.org>
commit 9b55613f42e8d40d5c9ccb8970bde6af4764b2ab upstream.
When a kernel is built covering ARMv6 to ARMv7, we omit to clear the
IT state when entering a signal handler. This can cause the first
few instructions to be conditionally executed depending on the parent
context.
In any case, the original test for >= ARMv7 is broken - ARMv6 can have
Thumb-2 support as well, and an ARMv6T2 specific build would omit this
code too.
Relax the test back to ARMv6 or greater. This results in us always
clearing the IT state bits in the PSR, even on CPUs where these bits
are reserved. However, they're reserved for the IT state, so this
should cause no harm.
Fixes: d71e1352e240 ("Clear the IT state when invoking a Thumb-2 signal handler")
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
commit ebfb4988f0378e2ac3b4a0aa1ea20d724293f392 upstream.
Sasha reported that we can get here with .idx==-1, and
cpuc->event_constraints unallocated.
Suggested-by: Stephane Eranian <eranian@google.com>
Fixes: b371b5943178 ("perf/x86: Fix event/group validation")
commit 7e022e717f54897e396504306d0c9b61452adf4e upstream.
In guest_exit_cont we call kvmhv_commence_exit which expects the trap
number as the argument. However r3 doesn't contain the trap number at
this point and as a result we would be calling the function with a
spurious trap number.
Fix this by copying r12 into r3 before calling kvmhv_commence_exit as
r12 contains the trap number.
Fixes: eddb60fb1443
Signed-off-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
commit 3eb4ee68254235e4f47bc0410538fcdaede39589 upstream.
Access to the kvm->buses (like with the kvm_io_bus_read() and -write()
functions) has to be protected via the kvm->srcu lock.
The kvmppc_h_logical_ci_load() and -store() functions are missing
this lock so far, so let's add it there, too.
This fixes the problem that the kernel reports "suspicious RCU usage"
when lock debugging is enabled.
Fixes: 99342cf8044420eebdf9297ca03a14cb6a7085a1
Signed-off-by: Thomas Huth <thuth@redhat.com>
commit 688bc577ac42ae3d07c889a1f0a72f0b23763d58 upstream.
When running a guest with the architected timer disabled (with QEMU and
the kernel_irqchip=off option, for example), it is important to make
sure the timer gets turned off. Otherwise, the guest may try to
enable it anyway, leading to a screaming HW interrupt.
The fix is to unconditionally turn off the virtual timer on guest
exit.
commit 04bb92e4b4cf06a66889d37b892b78f926faa9d4 upstream.
Reference SDM 28.1:
The current VPID is 0000H in the following situations:
- Outside VMX operation. (This includes operation in system-management
mode under the default treatment of SMIs and SMM with VMX operation;
see Section 34.14.)
- In VMX root operation.
- In VMX non-root operation when the “enable VPID” VM-execution control
is 0.
The VPID should never be 0000H in non-root operation when "enable VPID"
VM-execution control is 1. However, commit 34a1cd60 ("kvm: x86: vmx:
move some vmx setting from vmx_init() to hardware_setup()") remove the
codes which reserve 0000H for VMX root operation.
This patch fix it by again reserving 0000H for VMX root operation.
Fixes: 34a1cd60d17f62c1f077c1478a6c2ca8c3d17af4
Reported-by: Wincy Van <fanwenyi0529@gmail.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit ca09f02f122b2ecb0f5ddfc5fd47b29ed657d4fd upstream.
A critical bug has been found in device memory stage1 translation for
VMs with more then 4GB of address space. Once vm_pgoff size is smaller
then pa (which is true for LPAE case, u32 and u64 respectively) some
more significant bits of pa may be lost as a shift operation is performed
on u32 and later cast onto u64.
Example: vm_pgoff(u32)=0x00210030, PAGE_SHIFT=12
expected pa(u64): 0x0000002010030000
produced pa(u64): 0x0000000010030000
The fix is to change the order of operations (casting first onto phys_addr_t
and then shifting).
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
[maz: fixed changelog and patch formatting]
Signed-off-by: Marek Majtyka <marek.majtyka@tieto.com>
The wake-up key is high active, hence mux a pull-down py default.
Note that there is already a pull-down on the Colibri Evaluation
Board, but not on the Iris or Viola Carrier Board.
Some pins used for the second, external ethernet PHY are multiplexed
to multiple pads on the module. Add those to the pinctrl node of the
ethernet to make sure that these pads are properly disabled and no
conflicts with other pinmux specifications arise.
Don't overwrite the pinmux in the carrier board device tree for
standart Colibri UARTs.
Add more Gadget ConfigFS compatible Gadget drivers. This would
make the kernel about 90k bigger, to avoid this, define the whole
Gadget ConfigFS as module (which shrinks the kernel by ~40k).
