At boot time we round the memblock limit down to section size in an
attempt to ensure that we will have mapped this RAM with section
mappings prior to allocating from it. When mapping RAM we iterate over
PMD-sized chunks, creating these section mappings.
Section mappings are only created when the end of a chunk is aligned to
section size. Unfortunately, with classic page tables (where PMD_SIZE is
2 * SECTION_SIZE) this means that if a chunk is between 1M and 2M in
size the first 1M will not be mapped despite having been accounted for
in the memblock limit. This has been observed to result in page tables
being allocated from unmapped memory, causing boot-time hangs.
This patch modifies the memblock limit rounding to always round down to
PMD_SIZE instead of SECTION_SIZE. For classic MMU this means that we
will round the memblock limit down to a 2M boundary, matching the limits
on section mappings, and preventing allocations from unmapped memory.
For LPAE there should be no change as PMD_SIZE == SECTION_SIZE.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Stefan Agner <stefan@agner.ch>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Steve Capper <steve.capper@linaro.org>
Add the three I2C instances I2C1-I2C3 which were still missing.
Implements SoC bus support to export SoC specific information. Read
the unique SoC ID from the Vybrid On Chip One Time Programmable (OCOTP)
controller, SoC specific information from the Miscellaneous System
Control Module (MSCM), revision from the ROM revision register and
expose it via the SoC bus infrastructure.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add a device tree node for the On-Chip One Time Programmable
Controller (OCOTP).
This is the 4.0.2 stable release
commit f4831605f2dacd12730fe73961c77253cc2ea425 upstream.
time_init invokes timer64_init (which is __init annotation)
since all of these are invoked at init time, lets maintain
consistency by ensuring time_init is marked appropriately
as well.
This fixes the following warning with CONFIG_DEBUG_SECTION_MISMATCH=y
WARNING: vmlinux.o(.text+0x3bfc): Section mismatch in reference from the function time_init() to the function .init.text:timer64_init()
The function time_init() references
the function __init timer64_init().
This is often because time_init lacks a __init
annotation or the annotation of timer64_init is wrong.
Fixes: 546a39546c64 ("C6X: time management")
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Mark Salter <msalter@redhat.com>
commit 24e94454c8cb6a13634f5a2f5a01da53a546a58d upstream.
- don't lock lp->lock in the iss_net_timer for the call of iss_net_poll,
it will lock it itself;
- invert order of lp->lock and opened_lock acquisition in the
iss_net_open to make it consistent with iss_net_poll;
- replace spin_lock with spin_lock_bh when acquiring locks used in
iss_net_timer from non-atomic context;
- replace spin_lock_irqsave with spin_lock_bh in the iss_net_start_xmit
as the driver doesn't use lp->lock in the hard IRQ context;
- replace __SPIN_LOCK_UNLOCKED(lp.lock) with spin_lock_init, otherwise
lockdep is unhappy about using non-static key.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 01e84c70fe40c8111f960987bcf7f931842e6d07 upstream.
xtensa actually uses sync_file_range2 implementation, so it should
define __NR_sync_file_range2 as other architectures that use that
function. That fixes userspace interface (that apparently never worked)
and avoids special-casing xtensa in libc implementations.
See the thread ending at
http://lists.busybox.net/pipermail/uclibc/2015-February/048833.html
for more details.
commit 4949009eb8d40a441dcddcd96e101e77d31cf1b2 upstream.
LCD driver is always built for the XTFPGA platform, but its base address
is not configurable, and is wrong for ML605/KC705. Its initialization
locks up KC705 board hardware.
Make the whole driver optional, and its base address and bus width
configurable. Implement 4-bit bus access method.
commit 7261b956b276aa97fbf60d00f1d7717d2ea6ee78 upstream.
The patch to add it_page_shift incorrectly changed the increment of
uaddr to use it_page_shift, rather then (1 << it_page_shift).
This broke booting on at least some Cell blades, as the iommu was
basically non-functional.
Fixes: 3a553170d35d ("powerpc/iommu: Add it_page_shift field to determine iommu page size")
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit b0dd00addc5035f87ec9c5820dacc1ebc7fcb3e6 upstream.
The conversion from __get_cpu_var() to this_cpu_ptr() in iic_setup_cpu()
is wrong. It causes an oops at boot.
We need the per-cpu address of struct cpu_iic, not cpu_iic.regs->prio.
Sparse noticed this, because we pass a non-iomem pointer to out_be64(),
but we obviously don't check the sparse results often enough.
Fixes: 69111bac42f5 ("powerpc: Replace __get_cpu_var uses")
commit f7e9e358362557c3aa2c1ec47490f29fe880a09e upstream.
This problem appears to have been introduced in 2.6.29 by commit
93197a36a9c1 "Rewrite sysfs processor cache info code".
This caused lscpu to error out on at least e500v2 devices, eg:
error: cannot open /sys/devices/system/cpu/cpu0/cache/index2/size: No such file or directory
Some embedded powerpc systems use cache-size in DTS for the unified L2
cache size, not d-cache-size, so we need to allow for both DTS names.
Added a new CACHE_TYPE_UNIFIED_D cache_type_info structure to handle
this.
Fixes: 93197a36a9c1 ("powerpc: Rewrite sysfs processor cache info code")
Signed-off-by: Dave Olson <olson@cumulusnetworks.com>
commit 027fa02f84e851e21daffdf8900d6117071890f8 upstream.
If M64 has been supported, the prefetchable 64-bits memory resources
shouldn't be mapped to the corresponding PE# via M32DT. Unfortunately,
we're doing that in pnv_ioda_setup_pe_seg() wrongly. The issue was
introduced by commit 262af55 ("powerpc/powernv: Enable M64 aperatus
for PHB3"). The patch fixes the issue by simply skipping M64 resources
when updating to M32DT.
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 905e8c5dcaa147163672b06fe9dcb5abaacbc711 upstream.
When running a compat (AArch32) userspace on Cortex-A53, a load at EL0
from a virtual address that matches the bottom 32 bits of the virtual
address used by a recent load at (AArch64) EL1 might return incorrect
data.
This patch works around the issue by writing to the contextidr_el1
register on the exception return path when returning to a 32-bit task.
This workaround is patched in at runtime based on the MIDR value of the
processor.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit 137650aad96c9594683445e41afa8ac5a2097520 upstream.
Currently we only perform alternative patching for kernels built with
CONFIG_SMP, as we call apply_alternatives_all() in smp.c, which is only
built for CONFIG_SMP. Thus !SMP kernels may not have necessary
alternatives patched in.
This patch ensures that we call apply_alternatives_all() once all CPUs
are booted, even for !SMP kernels, by having the smp_init_cpus() stub
call this for !SMP kernels via up_late_init. A new wrapper,
do_post_cpus_up_work, is added so we can hook other calls here later
(e.g. boot mode logging).
Cc: Andre Przywara <andre.przywara@arm.com>
Fixes: e039ee4ee3fcf174 ("arm64: add alternative runtime patching")
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit ad08fd494bf00c03ae372e0bbd9cefa37bf608d6 upstream.
Commit f4f75ad5 ("efi: efistub: Convert into static library")
introduced a static library for EFI stub, libstub.
The EFI libstub directory is referenced by the kernel build system via
a obj subdirectory rule in:
drivers/firmware/efi/Makefile
Unfortunately, arm64 also references the EFI libstub via:
libs-$(CONFIG_EFI_STUB) += drivers/firmware/efi/libstub/
If we're unlucky, the kernel build system can enter libstub via two
simultaneous threads resulting in build failures such as:
fixdep: error opening depfile: drivers/firmware/efi/libstub/.efi-stub-helper.o.d: No such file or directory
scripts/Makefile.build:257: recipe for target 'drivers/firmware/efi/libstub/efi-stub-helper.o' failed
make[1]: *** [drivers/firmware/efi/libstub/efi-stub-helper.o] Error 2
Makefile:939: recipe for target 'drivers/firmware/efi/libstub' failed
make: *** [drivers/firmware/efi/libstub] Error 2
make: *** Waiting for unfinished jobs....
This patch adjusts the arm64 Makefile to reference the compiled library
explicitly (as is currently done in x86), rather than the directory.
Fixes: f4f75ad5 efi: efistub: Convert into static library
Signed-off-by: Steve Capper <steve.capper@linaro.org>
commit 91d57155dc5ab4b311624b7ee570339b6af19ad5 upstream.
After writing the page tables, we use __inval_cache_range to invalidate
any stale cache entries. Strongly Ordered memory accesses are not
ordered w.r.t. cache maintenance instructions, and hence explicit memory
barriers are required to provide this ordering. However,
__inval_cache_range was written to be used on Normal Cacheable memory
once the MMU and caches are on, and does not have any barriers prior to
the DC instructions.
This patch adds a DMB between the page tables being written and the
corresponding cachelines being invalidated, ensuring that the
invalidation makes the new data visible to subsequent cacheable
accesses. A barrier is not required before the prior invalidate as we do
not access the page table memory area prior to this, and earlier
barriers in preserve_boot_args and set_cpu_boot_mode_flag ensures
ordering w.r.t. any stores performed prior to entering Linux.
Fixes: c218bca74eeafa2f ("arm64: Relax the kernel cache requirements for boot")
commit 6d1966dfd6e0ad2f8aa4b664ae1a62e33abe1998 upstream.
Register MIDR_EL1 is masked to get variant and revision fields, then
compared against midr_range_min and midr_range_max when checking
whether CPU is affected by any particular erratum. However, variant
and revision fields in MIDR_EL1 are separated by 16 bits, so the min
and max of midr range should be constructed accordingly, otherwise
the patch will not be applied when variant field is non-0.
Acked-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Bo Yan <byan@nvidia.com>
[will: use MIDR_VARIANT_SHIFT to construct upper bound]
commit 9a5cbce421a283e6aea3c4007f141735bf9da8c3 upstream.
We cap 32bit userspace backtraces to PERF_MAX_STACK_DEPTH
(currently 127), but we forgot to do the same for 64bit backtraces.
commit 7e9e20b1faab02357501553d7f4e3efec1b4cfd3 upstream.
Resolve a merge conflict with mmc refactoring aaa25a5a33cb ("ARM: dts:
unuse the slot-node and deprecate the supports-highspeed for dw-mmc in
exynos") by dropping the slot@0 nodes, moving its bus-width property to
the mmc node and replacing supports-highspeed with cap-{mmc,sd}-highspeed,
matching exynos5250-snow.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Fixes: 53dd4138bb0a ("ARM: dts: Add exynos5250-spring device tree")
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
commit a74cd13b807029397f7232449df929bac11fb228 upstream.
Fix Dove's register addresses of uart2 and uart3 nodes that seem to
be broken since ages due to a copy-and-paste error.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 98b80987c940956da48f0c703f60340128bb8521 upstream.
After 57a38effa598 (net: phy: micrel: disable broadcast for KSZ8081/KSZ8091)
the macb1 interface refuses to work properly because it tries
to cling to address 0 which isn't able to communicate in broadcast with
the mac anymore. The micrel phy on the board is actually configured
to show up at address 1.
Adding the phy node and its real address fixes the issue.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Johan Hovold <johan@kernel.org>
commit 4e330ae4ab2915444f1e6dca1358a910aa259362 upstream.
There are two PMICs on Cragganmore, currently one dynamically assign
its IRQ base and the other uses a fixed base. It is possible for the
statically assigned PMIC to fail if its IRQ is taken by the dynamically
assigned one. Fix this by statically assigning both the IRQ bases.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
commit 548ae94c1cc7fc120848757249b9a542b1080ffb upstream.
On Armada 38x SoCs, under heavy I/O load, the system hangs when CPU
Idle is enabled. Waiting for a solution to this issue, this patch
disables the CPU Idle support for this SoC.
As CPU Hot plug support also uses some of the CPU Idle functions it is
also affected by the same issue. This patch disables it also for the
Armada 38x SoCs.
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
commit 8defb3367fcd19d1af64c07792aade0747b54e0f upstream.
Usually ELF_ET_DYN_BASE is 2/3 of TASK_SIZE. With 3G/1G user/kernel
split this is not so, because 2*TASK_SIZE overflows 32 bits,
so the actual value of ELF_ET_DYN_BASE is:
(2 * TASK_SIZE / 3) = 0x2a000000
When ASLR is disabled PIE binaries will load at ELF_ET_DYN_BASE address.
On 32bit platforms AddressSanitzer uses addresses [0x20000000 - 0x40000000]
for shadow memory [1]. So ASan doesn't work for PIE binaries when ASLR disabled
as it fails to map shadow memory.
Also after Kees's 'split ET_DYN ASLR from mmap ASLR' patchset PIE binaries
has a high chance of loading somewhere in between [0x2a000000 - 0x40000000]
even if ASLR enabled. This makes ASan with PIE absolutely incompatible.
Fix overflow by dividing TASK_SIZE prior to multiplying.
After this patch ELF_ET_DYN_BASE equals to (for CONFIG_VMSPLIT_3G=y):
(TASK_SIZE / 3 * 2) = 0x7f555554
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerAlgorithm#Mapping
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reported-by: Maria Guseva <m.guseva@samsung.com>
commit 767bf7e7a1e82a81c59778348d156993d0a6175d upstream.
Normally, when a CPU wants to clear a cache line to zero in the external
L2 cache, it would generate bus cycles to write each word as it would do
with any other data access.
However, a Cortex A9 connected to a L2C-310 has a specific feature where
the CPU can detect this operation, and signal that it wants to zero an
entire cache line. This feature, known as Full Line of Zeros (FLZ),
involves a non-standard AXI signalling mechanism which only the L2C-310
can properly interpret.
There are separate enable bits in both the L2C-310 and the Cortex A9 -
the L2C-310 needs to be enabled and have the FLZ enable bit set in the
auxiliary control register before the Cortex A9 has this feature
enabled.
Unfortunately, the suspend code was not respecting this - it's not
obvious from the code:
swsusp_arch_suspend()
cpu_suspend() /* saves the Cortex A9 auxiliary control register */
arch_save_image()
soft_restart() /* turns off FLZ in Cortex A9, and disables L2C */
cpu_resume() /* restores the Cortex A9 registers, inc auxcr */
At this point, we end up with the L2C disabled, but the Cortex A9 with
FLZ enabled - which means any memset() or zeroing of a full cache line
will fail to take effect.
A similar issue exists in the resume path, but it's slightly more
complex:
arch_save_image() /* image with A9 auxcr saved */
swsusp_arch_resume()
call_with_stack()
arch_restore_image() /* restores image with A9 auxcr saved above */
Again, here we end up with the L2C disabled, but Cortex A9 FLZ enabled.
There's no need to turn off the L2C in either of these two paths; there
are benefits from not doing so - for example, the page copies will be
faster with the L2C enabled.
Hence, fix this by providing a variant of soft_restart() which can be
used without turning the L2 cache controller off, and use it in both
of these paths to keep the L2C enabled across the respective resume
transitions.
Fixes: 8ef418c7178f ("ARM: l2c: trial at enabling some Cortex-A9 optimisations")
Reported-by: Sean Cross <xobs@kosagi.com>
Tested-by: Sean Cross <xobs@kosagi.com>
commit a843d00d038b11267279e3b5388222320f9ddc1d upstream.
We found that TLB mismatch not only happens after kernel resume, but
also happens during snapshot restore. So move it to the beginning of
swsusp_arch_suspend().
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/9621/
commit 0add9c2f1cff9f3f1f2eb7e9babefa872a9d14b9 upstream.
HPET irq is routed to i8259 and then to MIPS CPU irq (cascade). After
commit a3e6c1eff5 (MIPS: IRQ: Fix disable_irq on CPU IRQs), if without
IRQF_NO_SUSPEND in cascade_irqaction, HPET interrupts will lost during
suspend. The result is machine cannot be waken up.
Patchwork: https://patchwork.linux-mips.org/patch/9528/
commit 6eae35485b26f9e51ab896eb8a936bed9908fdf6 upstream.
When emulating a regular lh/lw/lhu/sh/sw we need to use the appropriate
instruction if we are in EVA mode. This is necessary for userspace
applications which trigger alignment exceptions. In such case, the
userspace load/store instruction needs to be emulated with the correct
eva/non-eva instruction by the kernel emulator.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Fixes: c1771216ab48 ("MIPS: kernel: unaligned: Handle unaligned accesses for EVA")
Patchwork: https://patchwork.linux-mips.org/patch/9503/
commit 3563c32d6532ece53c9dd8905a8e41983ef9952f upstream.
It's best to surround such complex macros with do {} while statements
so they can appear as independent logical blocks when used within other
control blocks.
Patchwork: https://patchwork.linux-mips.org/patch/9502/
commit eeb538950367e3966cbf0237ab1a1dc30e059818 upstream.
Commit c1771216ab48 ("MIPS: kernel: unaligned: Handle unaligned
accesses for EVA") allowed unaligned accesses to be emulated for
EVA. However, when emulating regular load/store unaligned accesses,
we need to use the appropriate "address space" instructions for that.
Previously, an unaligned load/store instruction in kernel space would
have used the corresponding EVA instructions to emulate it which led to
segmentation faults because of the address translation that happens
with EVA instructions. This is now fixed by using the EVA instruction
only when emulating EVA unaligned accesses.
Patchwork: https://patchwork.linux-mips.org/patch/9501/
commit 60cd7e08e453bc6828ac4b539f949e4acd80f143 upstream.
Introduce new macros for kernel load/store variants which will be
used to perform regular kernel space load/store operations in EVA
mode.
Patchwork: https://patchwork.linux-mips.org/patch/9500/
commit f7f8aea4b97c4d48e42f02cb37026bee445f239f upstream.
memsize denotes the amount of RAM we can access from kseg{0,1} and
that should be up to 256M. In case the bootloader reports a value
higher than that (perhaps reporting all the available RAM) it's best
if we fix it ourselves and just warn the user about that. This is
usually a problem with the bootloader and/or its environment.
[ralf@linux-mips.org: Remove useless parens as suggested bei Sergei.
Reformat long pr_warn statement to fit into 80 column limit.]
Patchwork: https://patchwork.linux-mips.org/patch/9362/
commit acaf6a97d623af123314c2f8ce4cf7254f6b2fc1 upstream.
The lose_fpu() function only disables the FPU in CP0_Status.CU1 if the
FPU is in use and MSA isn't enabled.
This isn't necessarily a problem because KSTK_STATUS(current), the
version of CP0_Status stored on the kernel stack on entry from user
mode, does always get updated and gets restored when returning to user
mode, but I don't think it was intended, and it is inconsistent with the
case of only the FPU being in use. Sometimes leaving the FPU enabled may
also mask kernel bugs where FPU operations are executed when the FPU
might not be enabled.
So lets disable the FPU in the MSA case too.
Fixes: 33c771ba5c5d ("MIPS: save/disable MSA in lose_fpu")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9323/
commit 98119ad53376885819d93dfb8737b6a9a61ca0ba upstream.
Guest user mode can generate a guest MSA Disabled exception on an MSA
capable core by simply trying to execute an MSA instruction. Since this
exception is unknown to KVM it will be passed on to the guest kernel.
However guest Linux kernels prior to v3.15 do not set up an exception
handler for the MSA Disabled exception as they don't support any MSA
capable cores. This results in a guest OS panic.
Since an older processor ID may be being emulated, and MSA support is
not advertised to the guest, the correct behaviour is to generate a
Reserved Instruction exception in the guest kernel so it can send the
guest process an illegal instruction signal (SIGILL), as would happen
with a non-MSA-capable core.
Fix this as minimally as reasonably possible by preventing
kvm_mips_check_privilege() from relaying MSA Disabled exceptions from
guest user mode to the guest kernel, and handling the MSA Disabled
exception by emulating a Reserved Instruction exception in the guest,
via a new handle_msa_disabled() KVM callback.
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
commit 085e68eeafbf76e21848ad5bafaecec88a11dd64 upstream.
The host's decision to enable machine check exceptions should remain
in force during non-root mode. KVM was writing 0 to cr4 on VCPU reset
and passed a slightly-modified 0 to the vmcs.guest_cr4 value.
Tested: Built.
On earlier version, tested by injecting machine check
while a guest is spinning.
Before the change, if guest CR4.MCE==0, then the machine check is
escalated to Catastrophic Error (CATERR) and the machine dies.
If guest CR4.MCE==1, then the machine check causes VMEXIT and is
handled normally by host Linux. After the change, injecting a machine
check causes normal Linux machine check handling.
Signed-off-by: Ben Serebrin <serebrin@google.com>
Reviewed-by: Venkatesh Srinivas <venkateshs@google.com>
commit fd1d0ddf2ae92fb3df42ed476939861806c5d785 upstream.
When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently
only check it against a fixed limit, which historically is set
to 127. With the new dynamic IRQ allocation the effective limit may
actually be smaller (64).
So when now a malicious or buggy userland injects a SPI in that
range, we spill over on our VGIC bitmaps and bytemaps memory.
I could trigger a host kernel NULL pointer dereference with current
mainline by injecting some bogus IRQ number from a hacked kvmtool:
DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1)
DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1)
DEBUG: IRQ #114 still in the game, writing to bytemap now...
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ffffffc07652e000
[00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000
Internal error: Oops: 96000006 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027
Hardware name: FVP Base (DT)
task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000
PC is at kvm_vgic_inject_irq+0x234/0x310
LR is at kvm_vgic_inject_irq+0x30c/0x310
pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145
So this patch fixes this by checking the SPI number against the
actual limit. Also we remove the former legacy hard limit of
127 in the ioctl code.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
[maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__,
as suggested by Christopher Covington]
commit d74419495633493c9cd3f2bbeb7f3529d0edded6 upstream.
Sebastian reported a crash caused by a jump label mismatch after resume.
This happens because we do not save the kernel text section during suspend
and therefore also do not restore it during resume, but use the kernel image
that restores the old system.
This means that after a suspend/resume cycle we lost all modifications done
to the kernel text section.
The reason for this is the pfn_is_nosave() function, which incorrectly
returns that read-only pages don't need to be saved. This is incorrect since
we mark the kernel text section read-only.
We still need to make sure to not save and restore pages contained within
NSS and DCSS segment.
To fix this add an extra case for the kernel text section and only save
those pages if they are not contained within an NSS segment.
Fixes the following crash (and the above bugs as well):
Jump label code mismatch at netif_receive_skb_internal+0x28/0xd0
Found: c0 04 00 00 00 00
Expected: c0 f4 00 00 00 11
New: c0 04 00 00 00 00
Kernel panic - not syncing: Corrupted kernel text
CPU: 0 PID: 9 Comm: migration/0 Not tainted 3.19.0-01975-gb1b096e70f23 #4
Call Trace:
[<0000000000113972>] show_stack+0x72/0xf0
[<000000000081f15e>] dump_stack+0x6e/0x90
[<000000000081c4e8>] panic+0x108/0x2b0
[<000000000081be64>] jump_label_bug.isra.2+0x104/0x108
[<0000000000112176>] __jump_label_transform+0x9e/0xd0
[<00000000001121e6>] __sm_arch_jump_label_transform+0x3e/0x50
[<00000000001d1136>] multi_cpu_stop+0x12e/0x170
[<00000000001d1472>] cpu_stopper_thread+0xb2/0x168
[<000000000015d2ac>] smpboot_thread_fn+0x134/0x1b0
[<0000000000158baa>] kthread+0x10a/0x110
[<0000000000824a86>] kernel_thread_starter+0x6/0xc
Reported-and-tested-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
commit 94aa033efcac47b09db22cb561e135baf37b7887 upstream.
This fixes a bug introduced with commit c05c4186bbe4 ("KVM: s390:
add floating irq controller").
get_all_floating_irqs() does copy_to_user() while holding
a spin lock. Let's fix this by filling a temporary buffer
first and copy it to userspace after giving up the lock.
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit b75f4c9afac2604feb971441116c07a24ecca1ec upstream.
s390 documentation requires words 0 and 10-15 to be reserved and stored as
zeros. As we fill out all other fields, we can memset the full structure.
Signed-off-by: Ekaterina Tumanova <tumanova@linux.vnet.ibm.com>
commit 15462e37ca848abac7477dece65f8af25febd744 upstream.
The reinjection of an I/O interrupt can fail if the list is at the limit
and between the dequeue and the reinjection, another I/O interrupt is
injected (e.g. if user space floods kvm with I/O interrupts).
This patch avoids this memory leak and returns -EFAULT in this special
case. This error is not recoverable, so let's fail hard. This can later
be avoided by not dequeuing the interrupt but working directly on the
locked list.
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
commit 261520dcfcba93ca5dfe671b88ffab038cd940c8 upstream.
If the I/O interrupt could not be written to the guest provided
area (e.g. access exception), a program exception was injected into the
guest but "inti" wasn't freed, therefore resulting in a memory leak.
In addition, the I/O interrupt wasn't reinjected. Therefore the dequeued
interrupt is lost.
This patch fixes the problem while cleaning up the function and making the
cc and rc logic easier to handle.
commit 50c6a665b383cb5839e45d04e36faeeefaffa052 upstream.
Commit dc6c9a35b66b5 ("mm: account pmd page tables to the process")
added a counter that is incremented whenever a PMD is allocated and
decremented whenever a PMD is freed. For hugepages on PPC, common code
is used to allocated PMDs, but arch-specific code is used to free PMDs.
This results in kernel output such as "BUG: non-zero nr_pmds on freeing
mm: 1" when using hugepages.
Update the PPC hugepage PMD freeing code to decrement the count, just
as the above commit did for free_pmd_range().
Fixes: dc6c9a35b66b5 ("mm: account pmd page tables to the process")
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 9e9c3fe40bcd28e3f98f0ad8408435f4503f2781 upstream.
kvm_init_msr_list is currently called before hardware_setup. As a result,
vmx_mpx_supported always returns false when kvm_init_msr_list checks whether to
save MSR_IA32_BNDCFGS.
Move kvm_init_msr_list after vmx_hardware_setup is called to fix this issue.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
Message-Id: <1428864435-4732-1-git-send-email-namit@cs.technion.ac.il>
commit d869844bd081081bf537e806a44811884230643e upstream.
Commit cae2a173fe94 ("x86: clean up/fix 'copy_in_user()' tail zeroing")
fixed the failure case tail zeroing of one special case of the x86-64
generic user-copy routine, namely when used for the user-to-user case
("copy_in_user()").
But in the process it broke an even more unusual case: using the user
copy routine for kernel-to-kernel copying.
Now, normally kernel-kernel copies are obviously done using memcpy(),
but we have a couple of special cases when we use the user-copy
functions. One is when we pass a kernel buffer to a regular user-buffer
routine, using set_fs(KERNEL_DS). That's a "normal" case, and continued
to work fine, because it never takes any faults (with the possible
exception of a silent and successful vmalloc fault).
But Jan Beulich pointed out another, very unusual, special case: when we
use the user-copy routines not because it's a path that expects a user
pointer, but for a couple of ftrace/kgdb cases that want to do a kernel
copy, but do so using "unsafe" buffers, and use the user-copy routine to
gracefully handle faults. IOW, for probe_kernel_write().
And that broke for the case of a faulting kernel destination, because we
saw the kernel destination and wanted to try to clear the tail of the
buffer. Which doesn't work, since that's what faults.
This only triggers for things like kgdb and ftrace users (eg trying
setting a breakpoint on read-only memory), but it's definitely a bug.
The fix is to not compare against the kernel address start (TASK_SIZE),
but instead use the same limits "access_ok()" uses.
Reported-and-tested-by: Jan Beulich <jbeulich@suse.com>
commit 517e6341fa123ec3a2f9ea78ad547be910529881 upstream.
Ingo reported that cycles:pp didn't work for him on some machines.
It turns out that in this commit:
af4bdcf675cf perf/x86/intel: Disallow flags for most Core2/Atom/Nehalem/Westmere events
Andi forgot to explicitly allow that event when he
disabled event flags for PEBS on those uarchs.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Fixes: af4bdcf675cf ("perf/x86/intel: Disallow flags for most Core2/Atom/Nehalem/Westmere events")
commit f8e617f4582995f7c25ef25b4167213120ad122b upstream.
To fully take advantage of MWAIT, apparently the CLFLUSH instruction needs
another quirk on certain CPUs: proper barriers around it on certain machines.
On a Q6600 SMP system, pipe-test scheduling performance, cross core,
improves significantly:
3.8.13 487.2 KHz 1.000
3.13.0-master 415.5 KHz .852
3.13.0-master+ 415.2 KHz .852 + restore mwait_idle
3.13.0-master++ 488.5 KHz 1.002 + restore mwait_idle + IPI fix
Since X86_BUG_CLFLUSH_MONITOR is already a quirk, don't create a separate
quirk for the extra smp_mb()s.
Signed-off-by: Mike Galbraith <bitbucket@online.de>
Cc: Ian Malone <ibmalone@gmail.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/1390061684.5566.4.camel@marge.simpson.net
[ Ported to recent kernel, added comments about the quirk. ]
savings and to improve performance
commit b253149b843f89cd300cbdbea27ce1f847506f99 upstream.
In Linux-3.9 we removed the mwait_idle() loop:
69fb3676df33 ("x86 idle: remove mwait_idle() and "idle=mwait" cmdline param")
The reasoning was that modern machines should be sufficiently
happy during the boot process using the default_idle() HALT
loop, until cpuidle loads and either acpi_idle or intel_idle
invoke the newer MWAIT-with-hints idle loop.
But two machines reported problems:
1. Certain Core2-era machines support MWAIT-C1 and HALT only.
MWAIT-C1 is preferred for optimal power and performance.
But if they support just C1, cpuidle never loads and
so they use the boot-time default idle loop forever.
2. Some laptops will boot-hang if HALT is used,
but will boot successfully if MWAIT is used.
This appears to be a hidden assumption in BIOS SMI,
that is presumably valid on the proprietary OS
where the BIOS was validated.
https://bugzilla.kernel.org/show_bug.cgi?id=60770
So here we effectively revert the patch above, restoring
the mwait_idle() loop. However, we don't bother restoring
the idle=mwait cmdline parameter, since it appears to add
no value.
Maintainer notes:
For 3.9, simply revert 69fb3676df
for 3.10, patch -F3 applies, fuzz needed due to __cpuinit use in
context For 3.11, 3.12, 3.13, this patch applies cleanly
Tested-by: Mike Galbraith <bitbucket@online.de>
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Mike Galbraith <bitbucket@online.de>
Link: http://lkml.kernel.org/r/345254a551eb5a6a866e048d7ab570fd2193aca4.1389763084.git.len.brown@intel.com
[ Ported to recent kernels. ]
commit 80f7fdb1c7f0f9266421f823964fd1962681f6ce upstream.
If we were migrated right after __getcpu, but before reading the
migration_count, we wouldn't notice that we read TSC of a different
VCPU, nor that KVM's bug made pvti invalid, as only migration_count
on source VCPU is increased.
Change vdso instead of updating migration_count on destination.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Fixes: 0a4e6be9ca17 ("x86: kvm: Revert "remove sched notifier for cross-cpu migrations"")
Message-Id: <1428000263-11892-1-git-send-email-rkrcmar@redhat.com>
commit 0a4e6be9ca17c54817cf814b4b5aa60478c6df27 upstream.
The following point:
2. per-CPU pvclock time info is updated if the
underlying CPU changes.
Is not true anymore since "KVM: x86: update pvclock area conditionally,
on cpu migration".
Add task migration notification back.
Problem noticed by Andy Lutomirski.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
