objtool ports introduced in v4.9.106 were not totally complete. Therefore
they resulted in issues like:
module: overflow in relocation type 10 val XXXXXXXXXXX
‘usbcore’ likely not compiled with -mcmodel=kernel
‘scsi_mod’ likely not compiled with -mcmodel=kernel
Missing part was the complete backport of commit e390f9a.
Original notes by Josh Poimboeuf:
The '__unreachable' and '__func_stack_frame_non_standard' sections are
only used at compile time. They're discarded for vmlinux but they
should also be discarded for modules.
Since this is a recurring pattern, prefix the section names with
".discard.". It's a nice convention and vmlinux.lds.h already discards
such sections.
Also remove the 'a' (allocatable) flag from the __unreachable section
since it doesn't make sense for a discarded section.
Signed-off-by: Philip Müller <philm@manjaro.org>
Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends")
Link: https://gitlab.manjaro.org/packages/core/linux49/issues/2
Fix an additional misuse of X86_FEATURE_SSBD in
guest_cpuid_has_spec_ctrl(). This function was introduced in the
backport of SSBD support to 4.9 and is not present upstream, so it was
not fixed by commit 43462d908821 "KVM: VMX: Expose SSBD properly to
guests."
Fixes: 52817587e706 ("x86/cpufeatures: Disentangle SSBD enumeration")
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: kvm@vger.kernel.org
commit 79db795833bf5c3e798bcd7a5aeeee3fb0505927 upstream.
%g4 and %g5 are fixed registers used by the kernel for the thread
pointer and the per-cpu offset. Use %o4 and %g7 instead.
Diagnosis by Anthony Yznaga.
Fixes: 1b4af13ff2cc ("sparc64: Add __multi3 for gcc 7.x and later.")
Reported-by: Anatoly Pugachev <matorola@gmail.com>
Tested-by: Anatoly Pugachev <matorola@gmail.com>
commit 0fde7ad71ee371ede73b3f326e58f9e8d102feb6 upstream.
arch/sparc/kernel/ds.c: In function ‘register_services’:
arch/sparc/kernel/ds.c:912:3: error: ‘strcpy’: writing at least 1 byte
into a region of size 0 overflows the destination
commit 28e4213dd331e944e7fca1954a946829162ed9d4 upstream.
Having PR_FP_MODE_FRE (i.e. Config5.FRE) set without PR_FP_MODE_FR (i.e.
Status.FR) is not supported as the lone purpose of Config5.FRE is to
emulate Status.FR=0 handling on FPU hardware that has Status.FR=1
hardwired[1][2]. Also we do not handle this case elsewhere, and assume
throughout our code that TIF_HYBRID_FPREGS and TIF_32BIT_FPREGS cannot
be set both at once for a task, leading to inconsistent behaviour if
this does happen.
Return unsuccessfully then from prctl(2) PR_SET_FP_MODE calls requesting
PR_FP_MODE_FRE to be set with PR_FP_MODE_FR clear. This corresponds to
modes allowed by `mips_set_personality_fp'.
References:
[1] "MIPS Architecture For Programmers, Vol. III: MIPS32 / microMIPS32
Privileged Resource Architecture", Imagination Technologies,
Document Number: MD00090, Revision 6.02, July 10, 2015, Table 9.69
"Config5 Register Field Descriptions", p. 262
[2] "MIPS Architecture For Programmers, Volume III: MIPS64 / microMIPS64
Document Number: MD00091, Revision 6.03, December 22, 2015, Table
9.72 "Config5 Register Field Descriptions", p. 288
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Signed-off-by: Maciej W. Rozycki <macro@mips.com>
Cc: linux-mips@linux-mips.org
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/19327/
Signed-off-by: James Hogan <jhogan@kernel.org>
commit c7e814628df65f424fe197dde73bfc67e4a244d7 upstream.
Use 64-bit accesses for 64-bit floating-point general registers with
PTRACE_PEEKUSR, removing the truncation of their upper halves in the
FR=1 mode, caused by commit bbd426f542cb ("MIPS: Simplify FP context
access"), which inadvertently switched them to using 32-bit accesses.
The PTRACE_POKEUSR side is fine as it's never been broken and continues
using 64-bit accesses.
Fixes: bbd426f542cb ("MIPS: Simplify FP context access")
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/19334/
commit a048a07d7f4535baa4cbad6bc024f175317ab938 upstream.
On some CPUs we can prevent a vulnerability related to store-to-load
forwarding by preventing store forwarding between privilege domains,
by inserting a barrier in kernel entry and exit paths.
This is known to be the case on at least Power7, Power8 and Power9
powerpc CPUs.
Barriers must be inserted generally before the first load after moving
to a higher privilege, and after the last store before moving to a
lower privilege, HV and PR privilege transitions must be protected.
Barriers are added as patch sections, with all kernel/hypervisor entry
points patched, and the exit points to lower privilge levels patched
similarly to the RFI flush patching.
Firmware advertisement is not implemented yet, so CPU flush types
are hard coded.
Thanks to Michal Suchánek for bug fixes and review.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
Signed-off-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Michal Suchánek <msuchanek@suse.de>
commit 501a78cbc17c329fabf8e9750a1e9ab810c88a0e upstream.
The recent LPM changes to setup_rfi_flush() are causing some section
mismatch warnings because we removed the __init annotation on
setup_rfi_flush():
The function setup_rfi_flush() references
the function __init ppc64_bolted_size().
the function __init memblock_alloc_base().
The references are actually in init_fallback_flush(), but that is
inlined into setup_rfi_flush().
These references are safe because:
- only pseries calls setup_rfi_flush() at runtime
- pseries always passes L1D_FLUSH_FALLBACK at boot
- so the fallback flush area will always be allocated
- so the check in init_fallback_flush() will always return early:
/* Only allocate the fallback flush area once (at boot time). */
if (l1d_flush_fallback_area)
return;
- and therefore we won't actually call the freed init routines.
We should rework the code to make it safer by default rather than
relying on the above, but for now as a quick-fix just add a __ref
annotation to squash the warning.
Fixes: abf110f3e1ce ("powerpc/rfi-flush: Make it possible to call setup_rfi_flush() again")
commit 6232774f1599028a15418179d17f7df47ede770a upstream.
After migration the security feature flags might have changed (e.g.,
destination system with unpatched firmware), but some flags are not
set/clear again in init_cpu_char_feature_flags() because it assumes
the security flags to be the defaults.
Additionally, if the H_GET_CPU_CHARACTERISTICS hypercall fails then
init_cpu_char_feature_flags() does not run again, which potentially
might leave the system in an insecure or sub-optimal configuration.
So, just restore the security feature flags to the defaults assumed
by init_cpu_char_feature_flags() so it can set/clear them correctly,
and to ensure safe settings are in place in case the hypercall fail.
Fixes: f636c14790ea ("powerpc/pseries: Set or clear security feature flags")
Depends-on: 19887d6a28e2 ("powerpc: Move default security feature flags")
commit e7347a86830f38dc3e40c8f7e28c04412b12a2e7 upstream.
This moves the definition of the default security feature flags
(i.e., enabled by default) closer to the security feature flags.
This can be used to restore current flags to the default flags.
commit 0f9bdfe3c77091e8704d2e510eb7c2c2c6cde524 upstream.
The H_CPU_BEHAV_* flags should be checked for in the 'behaviour' field
of 'struct h_cpu_char_result' -- 'character' is for H_CPU_CHAR_*
flags.
Found by playing around with QEMU's implementation of the hypercall:
H_CPU_CHAR=0xf000000000000000
H_CPU_BEHAV=0x0000000000000000
This clears H_CPU_BEHAV_FAVOUR_SECURITY and H_CPU_BEHAV_L1D_FLUSH_PR
so pseries_setup_rfi_flush() disables 'rfi_flush'; and it also
clears H_CPU_CHAR_L1D_THREAD_PRIV flag. So there is no RFI flush
mitigation at all for cpu_show_meltdown() to report; but currently
it does:
Original kernel:
# cat /sys/devices/system/cpu/vulnerabilities/meltdown
Mitigation: RFI Flush
Patched kernel:
Not affected
H_CPU_CHAR=0x0000000000000000
H_CPU_BEHAV=0xf000000000000000
This sets H_CPU_BEHAV_BNDS_CHK_SPEC_BAR so cpu_show_spectre_v1() should
report vulnerable; but currently it doesn't:
Original kernel:
# cat /sys/devices/system/cpu/vulnerabilities/spectre_v1
Not affected
Patched kernel:
Vulnerable
Brown-paper-bag-by: Michael Ellerman <mpe@ellerman.id.au>
commit d6fbe1c55c55c6937cbea3531af7da84ab7473c3 upstream.
Add a definition for cpu_show_spectre_v2() to override the generic
version. This has several permuations, though in practice some may not
occur we cater for any combination.
The most verbose is:
Mitigation: Indirect branch serialisation (kernel only), Indirect
branch cache disabled, ori31 speculation barrier enabled
We don't treat the ori31 speculation barrier as a mitigation on its
own, because it has to be *used* by code in order to be a mitigation
and we don't know if userspace is doing that. So if that's all we see
we say:
Vulnerable, ori31 speculation barrier enabled
commit 56986016cb8cd9050e601831fe89f332b4e3c46e upstream.
Add a definition for cpu_show_spectre_v1() to override the generic
version. Currently this just prints "Not affected" or "Vulnerable"
based on the firmware flag.
Although the kernel does have array_index_nospec() in a few places, we
haven't yet audited all the powerpc code to see where it's necessary,
so for now we don't list that as a mitigation.
commit 2e4a16161fcd324b1f9bf6cb6856529f7eaf0689 upstream.
Now that we have the security flags we can simplify the code in
pseries_setup_rfi_flush() because the security flags have pessimistic
defaults.
commit 37c0bdd00d3ae83369ab60a6712c28e11e6458d5 upstream.
Now that we have the security flags we can significantly simplify the
code in pnv_setup_rfi_flush(), because we can use the flags instead of
checking device tree properties and because the security flags have
pessimistic defaults.
commit ff348355e9c72493947be337bb4fae4fc1a41eba upstream.
Now that we have the security feature flags we can make the
information displayed in the "meltdown" file more informative.
commit 8ad33041563a10b34988800c682ada14b2612533 upstream.
This landed in setup_64.c for no good reason other than we had nowhere
else to put it. Now that we have a security-related file, that is a
better place for it so move it.
[mpe: Add extern for rfi_flush to fix bisection break]
commit 77addf6e95c8689e478d607176b399a6242a777e upstream.
Now that we have feature flags for security related things, set or
clear them based on what we see in the device tree provided by
firmware.
commit f636c14790ead6cc22cf62279b1f8d7e11a67116 upstream.
clear them based on what we receive from the hypercall.
commit 9a868f634349e62922c226834aa23e3d1329ae7f upstream.
This commit adds security feature flags to reflect the settings we
receive from firmware regarding Spectre/Meltdown mitigations.
The feature names reflect the names we are given by firmware on bare
metal machines. See the hostboot source for details.
Arguably these could be firmware features, but that then requires them
to be read early in boot so they're available prior to asm feature
patching, but we don't actually want to use them for patching. We may
also want to dynamically update them in future, which would be
incompatible with the way firmware features work (at the moment at
least). So for now just make them separate flags.
commit c4bc36628d7f8b664657d8bd6ad1c44c177880b7 upstream.
Add some additional values which have been defined for the
H_GET_CPU_CHARACTERISTICS hypercall.
commit 921bc6cf807ceb2ab8005319cf39f33494d6b100 upstream.
We might have migrated to a machine that uses a different flush type,
or doesn't need flushing at all.
commit 0063d61ccfc011f379a31acaeba6de7c926fed2c upstream.
Currently the rfi-flush messages print 'Using <type> flush' for all
enabled_flush_types, but that is not necessarily true -- as now the
fallback flush is always enabled on pseries, but the fixup function
overwrites its nop/branch slot with other flush types, if available.
So, replace the 'Using <type> flush' messages with '<type> flush is
available'.
Also, print the patched flush types in the fixup function, so users
can know what is (not) being used (e.g., the slower, fallback flush,
or no flush type at all if flush is disabled via the debugfs switch).
Suggested-by: Michael Ellerman <mpe@ellerman.id.au>
commit 84749a58b6e382f109abf1e734bc4dd43c2c25bb upstream.
This ensures the fallback flush area is always allocated on pseries,
so in case a LPAR is migrated from a patched to an unpatched system,
it is possible to enable the fallback flush in the target system.
commit abf110f3e1cea40f5ea15e85f5d67c39c14568a7 upstream.
For PowerVM migration we want to be able to call setup_rfi_flush()
again after we've migrated the partition.
To support that we need to check that we're not trying to allocate the
fallback flush area after memblock has gone away (i.e., boot-time only).
commit 1e2a9fc7496955faacbbed49461d611b704a7505 upstream.
rfi_flush_enable() includes a check to see if we're already
enabled (or disabled), and in that case does nothing.
But that means calling setup_rfi_flush() a 2nd time doesn't actually
work, which is a bit confusing.
Move that check into the debugfs code, where it really belongs.
commit eb0a2d2620ae431c543963c8c7f08f597366fc60 upstream.
Some versions of firmware will have a setting that can be configured
to disable the RFI flush, add support for it.
Fixes: 6e032b350cd1 ("powerpc/powernv: Check device-tree for RFI flush settings")
commit 582605a429e20ae68fd0b041b2e840af296edd08 upstream.
Fixes: 8989d56878a7 ("powerpc/pseries: Query hypervisor for RFI flush settings")
The backport of the RFI flush support, done by me, has a minor bug in
that the code is inside an #ifdef CONFIG_HARDLOCKUP_DETECTOR, which is
incorrect.
This doesn't matter with common configs because we enable
HARDLOCKUP_DETECTOR, but with future patches it will break the build.
So fix it.
Fixes: c3b82ebee6e0 ("powerpc/64s: Add support for RFI flush of L1-D cache")
commit 63a1e1c95e60e798fa09ab3c536fb555aa5bbf2b upstream.
Currently, cpus_set_cap() calls static_branch_enable_cpuslocked(), which
must take the jump_label mutex.
We call cpus_set_cap() in the secondary bringup path, from the idle
thread where interrupts are disabled. Taking a mutex in this path "is a
NONO" regardless of whether it's contended, and something we must avoid.
We didn't spot this until recently, as ___might_sleep() won't warn for
this case until all CPUs have been brought up.
This patch avoids taking the mutex in the secondary bringup path. The
poking of static keys is deferred until enable_cpu_capabilities(), which
runs in a suitable context on the boot CPU. To account for the static
keys being set later, cpus_have_const_cap() is updated to use another
static key to check whether the const cap keys have been initialised,
falling back to the caps bitmap until this is the case.
This means that users of cpus_have_const_cap() gain should only gain a
single additional NOP in the fast path once the const caps are
initialised, but should always see the current cap value.
The hyp code should never dereference the caps array, since the caps are
initialized before we run the module initcall to initialise hyp. A check
is added to the hyp init code to document this requirement.
This change will sidestep a number of issues when the upcoming hotplug
locking rework is merged.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Marc Zyniger <marc.zyngier@arm.com>
Reviewed-by: Suzuki Poulose <suzuki.poulose@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Sebastian Sewior <bigeasy@linutronix.de>
[4.9: this avoids an IPI before GICv3 is up, preventing a boot time crash]
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
commit a4023f682739439b434165b54af7cb3676a4766e upstream.
The hypervisor may not have full access to the kernel data structures
and hence cannot safely use cpus_have_cap() helper for checking the
system capability. Add a safe helper for hypervisors to check a constant
system capability, which *doesn't* fall back to checking the bitmap
maintained by the kernel. With this, make the cpus_have_cap() only
check the bitmask and force constant cap checks to use the new API
for quicker checks.
Cc: Robert Ritcher <rritcher@cavium.com>
Cc: Tirumalesh Chalamarla <tchalamarla@cavium.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
[4.9: restore cpus_have_const_cap() to previously-backported code]
Upstream commit: def9331a12977770cc6132d79f8e6565871e8e38 ("x86/amd:
don't set X86_BUG_SYSRET_SS_ATTRS when running under Xen")
When running as Xen pv guest X86_BUG_SYSRET_SS_ATTRS must not be set
on AMD cpus.
This bug/feature bit is kind of special as it will be used very early
when switching threads. Setting the bit and clearing it a little bit
later leaves a critical window where things can go wrong. This time
window has enlarged a little bit by using setup_clear_cpu_cap() instead
of the hypervisor's set_cpu_features callback. It seems this larger
window now makes it rather easy to hit the problem.
The proper solution is to never set the bit in case of Xen.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Upstream commit: 0808e80cb760de2733c0527d2090ed2205a1eef8 ("xen: set
cpu capabilities from xen_start_kernel()")
There is no need to set the same capabilities for each cpu
individually. This can easily be done for all cpus when starting the
kernel.
Revert commit 944e0fc51a89c9827b98813d65dc083274777c7f ("x86/amd: don't
set X86_BUG_SYSRET_SS_ATTRS when running under Xen") as it is lacking
a prerequisite patch and is making things worse.
commit faf37c44a105f3608115785f17cbbf3500f8bc71 upstream.
Clear the PCR (Processor Compatibility Register) on boot to ensure we
are not running in a compatibility mode.
We've seen this cause problems when a crash (and kdump) occurs while
running compat mode guests. The kdump kernel then runs with the PCR
set and causes problems. The symptom in the kdump kernel (also seen in
petitboot after fast-reboot) is early userspace programs taking
sigills on newer instructions (seen in libc).
Cc: stable@vger.kernel.org
commit 32c3fa7cdf0c4a3eb8405fc3e13398de019e828b upstream.
For LSE atomics that read and write a register operand, we need to
ensure that these operands are annotated as "early clobber" if the
register is written before all of the input operands have been consumed.
Failure to do so can result in the compiler allocating the same register
to both operands, leading to splats such as:
Unable to handle kernel paging request at virtual address 11111122222221
x1 : 1111111122222222 x0 : 1111111122222221
Process swapper/0 (pid: 1, stack limit = 0x000000008209f908)
Call trace:
test_atomic64+0x1360/0x155c
where x0 has been allocated as both the value to be stored and also the
atomic_t pointer.
This patch adds the missing clobbers.
Cc: Dave Martin <dave.martin@arm.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Reported-by: Mark Salter <msalter@redhat.com>
Not needed in mainline as this function got rewritten in 4.12
This enables objtool to grok the iret in the middle of a C function.
This matches commit 76846bf3cb09 ("x86/asm: Add unwind hint annotations
to sync_core()")
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit c207aee48037abca71c669cbec407b9891965c34 upstream.
In preparation for an objtool rewrite which will have broader checks,
whitelist functions and files which cause problems because they do
unusual things with the stack.
These whitelists serve as a TODO list for which functions and files
don't yet have undwarf unwinder coverage. Eventually most of the
whitelists can be removed in favor of manual CFI hint annotations or
objtool improvements.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/7f934a5d707a574bda33ea282e9478e627fb1829.1498659915.git.jpoimboe@redhat.com
There are pros and cons of dealing with tools in the kernel directory.
The pros are the fact that development happens fast, and new features
can be added to the kernel and the tools at the same times. The cons
are when dealing with backported kernel patches, it can be necessary to
backport parts of the tool changes as well.
For 4.9.y so far, we have backported individual patches. That quickly
breaks down when there are minor differences between how backports were
handled, so grabbing 40+ patch long series can be difficult, not
impossible, but really frustrating to attempt.
To help mitigate this mess, here's a single big patch to sync up the
objtool logic to the 4.14.47 version of the tool. From this point
forward (after some other minor header file patches are applied), the
tool should be in sync and much easier to maintain over time.
This has survivied my limited testing, and as the codebase is identical
to 4.14.47, I'm pretty comfortable dropping this big change in here in
4.9.y. Hopefully all goes well...
commit d1091c7fa3d52ebce4dd3f15d04155b3469b2f90 upstream.
The BUG() macro's use of __builtin_unreachable() via the unreachable()
macro tells gcc that the instruction is a dead end, and that it's safe
to assume the current code path will not execute past the previous
instruction.
On x86, the BUG() macro is implemented with the 'ud2' instruction. When
objtool's branch analysis sees that instruction, it knows the current
code path has come to a dead end.
Peter Zijlstra has been working on a patch to change the WARN macros to
use 'ud2'. That patch will break objtool's assumption that 'ud2' is
always a dead end.
Generally it's best for objtool to avoid making those kinds of
assumptions anyway. The more ignorant it is of kernel code internals,
the better.
So create a more generic way for objtool to detect dead ends by adding
an annotation to the unreachable() macro. The annotation stores a
pointer to the end of the unreachable code path in an '__unreachable'
section. Objtool can read that section to find the dead ends.
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: http://lkml.kernel.org/r/41a6d33971462ebd944a1c60ad4bf5be86c17b77.1487712920.git.jpoimboe@redhat.com
[ Upstream commit d4b78db6ac3e084e2bdc57d5518bd247c727f396 ]
The HDMI encoder is connected to the RGB output of the DU, which is
port@0, not port@1. Fix the incorrect DT description.
Fixes: c5af8a4248d3 ("ARM: dts: porter: add DU DT support")
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit 2bada7ac1fdcbf79a9689bd2ff65fa515ca7a31f ]
The missing last digit of the CONFIG values is added. Looks like a typo
of some sort when comparing to the downstream dt. This fixes
intermittent behavior behaviour of the ethernet controllers.
Signed-off-by: Aapo Vienamo <aapo@tuxera.com>
[ Upstream commit bee3204ec3c49f6f53add9c3962c9012a5c036fa ]
Currently the kdump kernel becomes very slow if 'noapic' is specified.
Normal kernel doesn't have this bug.
Kernel parameter 'noapic' is used to disable IO-APIC in system for
testing or special purpose. Here the root cause is that in kdump
kernel LAPIC is disabled since commit:
522e664644 ("x86/apic: Disable I/O APIC before shutdown of the local APIC")
In this case we need set up through-local-APIC on boot CPU in
setup_local_APIC().
In normal kernel the legacy irq mode is enabled by the BIOS. If
it is virtual wire mode, the local-APIC has been enabled and set as
through-local-APIC.
Though we fixed the regression introduced by commit 522e664644,
to further improve robustness set up the through-local-APIC mode
explicitly, do not rely on the default boot IRQ mode.
Signed-off-by: Baoquan He <bhe@redhat.com>
Reviewed-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: douly.fnst@cn.fujitsu.com
Cc: joro@8bytes.org
Cc: prarit@redhat.com
Cc: uobergfe@redhat.com
Link: http://lkml.kernel.org/r/20180214054656.3780-7-bhe@redhat.com
[ Rewrote the changelog. ]
[ Upstream commit db6775ca6e0353d2618ca7d5e210fc36ad43bbd4 ]
Using a period after a newline causes bad output.
Fixes: 64b139f97c01 ("MIPS: OCTEON: irq: add CIB and other fixes")
Patchwork: https://patchwork.linux-mips.org/patch/17886/
[ Upstream commit 79c81facdc0b43b1cef37b8d5689a8c8b78f8be0 ]
Since 517e7a1537a ("ASoC: bcm2835: move to use the clock framework")
the bcm2835-i2s requires a clock as DT property. Unfortunately
the necessary DT change has never been applied. While we are at it
also fix the first PCM register range to cover the PCM_GRAY register.
Fixes: 517e7a1537a ("ASoC: bcm2835: move to use the clock framework")
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Eric Anholt <eric@anholt.net>
Tested-by: Matthias Reichl <hias@horus.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
[ Upstream commit 0a5169add90e43ab45ab1ba34223b8583fcaf675 ]
IRQ parameters for the SoC devices connected directly to I/O APIC lines
(without PCI IRQ routing) may be specified in the Device Tree.
Called from DT IRQ parser, irq_create_fwspec_mapping() calls
irq_domain_alloc_irqs() with a pointer to irq_fwspec structure as @arg.
But x86-specific DT IRQ allocation code casts @arg to of_phandle_args
structure pointer and crashes trying to read the IRQ parameters. The
function was not converted when the mapping descriptor was changed to
irq_fwspec in the generic irqdomain code.
Fixes: 11e4438ee330 ("irqdomain: Introduce a firmware-specific IRQ specifier structure")
Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Link: https://lkml.kernel.org/r/a234dee27ea60ce76141872da0d6bdb378b2a9ee.1520450752.git.ivan.gorinov@intel.com
[ Upstream commit 628df9dc5ad886b0a9b33c75a7b09710eb859ca1 ]
Commit 08d53aa58cb1 added CRC32 calculation in early_init_dt_verify() and
checking in late initcall of_fdt_raw_init(), making early_init_dt_verify()
mandatory.
The required call to early_init_dt_verify() was not added to the
x86-specific implementation, causing failure to create the sysfs entry in
of_fdt_raw_init().
Fixes: 08d53aa58cb1 ("of/fdt: export fdt blob as /sys/firmware/fdt")
Link: https://lkml.kernel.org/r/c8c7e941efc63b5d25ebf9b6350b0f3df38f6098.1520450752.git.ivan.gorinov@intel.com
[ Upstream commit e723795c702b52cfceb3bb3faa63059eb4658313 ]
Set correct clocks and interrupt values.
Fixes the incorrect SPI master configuration. This is
mandatory to make the SPI5 interface functional.
Signed-off-by: Ilia Lin <ilialin@codeaurora.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
[ Upstream commit d31fc13fdcb20e1c317f9a7dd6273c18fbd58308 ]
There is a bug when reading event->count with large PEBS enabled.
Here is an example:
# ./read_count
0x71f0
0x122c0
0x1000000001c54
0x100000001257d
0x200000000bdc5
In fixed period mode, the auto-reload mechanism could be enabled for
PEBS events, but the calculation of event->count does not take the
auto-reload values into account.
Anyone who reads event->count will get the wrong result, e.g x86_pmu_read().
This bug was introduced with the auto-reload mechanism enabled since
commit:
851559e35fd5 ("perf/x86/intel: Use the PEBS auto reload mechanism when possible")
Introduce intel_pmu_save_and_restart_reload() to calculate the
event->count only for auto-reload.
Since the counter increments a negative counter value and overflows on
the sign switch, giving the interval:
[-period, 0]
the difference between two consequtive reads is:
A) value2 - value1;
when no overflows have happened in between,
B) (0 - value1) + (value2 - (-period));
when one overflow happened in between,
C) (0 - value1) + (n - 1) * (period) + (value2 - (-period));
when @n overflows happened in between.
Here A) is the obvious difference, B) is the extension to the discrete
interval, where the first term is to the top of the interval and the
second term is from the bottom of the next interval and C) the extension
to multiple intervals, where the middle term is the whole intervals
covered.
The equation for all cases is:
value2 - value1 + n * period
Previously the event->count is updated right before the sample output.
But for case A, there is no PEBS record ready. It needs to be specially
handled.
Remove the auto-reload code from x86_perf_event_set_period() since
we'll not longer call that function in this case.
Based-on-code-from: Peter Zijlstra (Intel) <peterz@infradead.org>
Signed-off-by: Kan Liang <kan.liang@linux.intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: acme@kernel.org
Fixes: 851559e35fd5 ("perf/x86/intel: Use the PEBS auto reload mechanism when possible")
Link: http://lkml.kernel.org/r/1518474035-21006-2-git-send-email-kan.liang@linux.intel.com
[ Upstream commit f605cfca8c39ffa2b98c06d2b9f30ba64f1e54e3 ]
Large fixed period values could be truncated on Broadwell, for example:
perf record -e cycles -c 10000000000
Here the fixed period is 0x2540BE400, but the period which finally applied is
0x540BE400 - which is wrong.
The reason is that x86_pmu::limit_period() uses an u32 parameter, so the
high 32 bits of 'period' get truncated.
This bug was introduced in:
commit 294fe0f52a44 ("perf/x86/intel: Add INST_RETIRED.ALL workarounds")
It's safe to use u64 instead of u32:
- Although the 'left' is s64, the value of 'left' must be positive when
calling limit_period().
- bdw_limit_period() only modifies the lowest 6 bits, it doesn't touch
the higher 32 bits.
Fixes: 294fe0f52a44 ("perf/x86/intel: Add INST_RETIRED.ALL workarounds")
Link: http://lkml.kernel.org/r/1519926894-3520-1-git-send-email-kan.liang@linux.intel.com
[ Rewrote unacceptably bad changelog. ]
