Disable stuff which is known to have issues on RT
We can't deal with the cpumask allocations which happen in atomic
context (see arch/x86/kernel/apic/io_apic.c) on RT right now.
Restrict the preempt disabled regions to the actual floating point
operations and enable preemption for the administrative actions.
This is necessary on RT to avoid that kfree and other operations are
called with preemption disabled.
Reported-and-tested-by: Carsten Emde <cbe@osadl.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: stable-rt@vger.kernel.org
In fact, with migrate_disable() existing one could play games with
kmap_atomic. You could save/restore the kmap_atomic slots on context
switch (if there are any in use of course), this should be esp easy now
that we have a kmap_atomic stack.
Something like the below.. it wants replacing all the preempt_disable()
stuff with pagefault_disable() && migrate_disable() of course, but then
you can flip kmaps around like below.
[dvhart@linux.intel.com: build fix]
Link: http://lkml.kernel.org/r/1311842631.5890.208.camel@twins
Normally the x86-64 trap handlers for debug/int 3/stack fault run
on a special interrupt stack to make them more robust
when dealing with kernel code.
The PREEMPT_RT kernel can sleep in locks even while allocating
GFP_ATOMIC memory. When one of these trap handlers needs to send
real time signals for ptrace it allocates memory and could then
try to to schedule. But it is not allowed to schedule on a
IST stack. This can cause warnings and hangs.
This patch disables the IST stacks for these handlers for PREEMPT_RT
kernel. Instead let them run on the normal process stack.
The kernel only really needs the ISTs here to make kernel debuggers more
robust in case someone sets a break point somewhere where the stack is
invalid. But there are no kernel debuggers in the standard kernel
that do this.
It also means kprobes cannot be set in situations with invalid stack;
but that sounds like a reasonable restriction.
The stack fault change could minimally impact oops quality, but not very
much because stack faults are fairly rare.
A better solution would be to use similar logic as the NMI "paranoid"
path: check if signal is for user space, if yes go back to entry.S, switch stack,
call sync_regs, then do the signal sending etc.
But this patch is much simpler and should work too with minimal impact.
Signed-off-by: Andi Kleen <ak@suse.de>
Simplifies the separation of anon_rw_semaphores and rw_semaphores for
-rt.
CPU bringup calls into the random pool to initialize the stack
canary. During boot that works nicely even on RT as the might sleep
checks are disabled. During CPU hotplug the might sleep checks
trigger. Making the locks in random raw is a major PITA, so avoid the
call on RT is the only sensible solution. This is basically the same
randomness which we get during boot where the random pool has no
entropy and we rely on the TSC randomnness.
Reported-by: Carsten Emde <carsten.emde@osadl.org>
mce_timer is started in atomic contexts of cpu bringup. This results
in might_sleep() warnings on RT. Convert mce_timer to a hrtimer to
avoid this.
Without this patch, ARM can not use SPLIT_PTLOCK_CPUS if
PREEMPT_RT_FULL=y because vectors_user_mapping() creates a
VM_ALWAYSDUMP mapping of the vector page (address 0xffff0000), but no
ptl->lock has been allocated for the page. An attempt to coredump
that page will result in a kernel NULL pointer dereference when
follow_page() attempts to lock the page.
The call tree to the NULL pointer dereference is:
do_notify_resume()
get_signal_to_deliver()
do_coredump()
elf_core_dump()
get_dump_page()
__get_user_pages()
follow_page()
pte_offset_map_lock() <----- a #define
rt_spin_lock()
The underlying problem is exposed by mm-shrink-the-page-frame-to-rt-size.patch.
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Cc: Frank <Frank_Rowand@sonyusa.com>
Link: http://lkml.kernel.org/r/4E87C535.2030907@am.sony.com
Use the local_irq_*_nort() variants.
Preemption must be disabled before enabling interrupts in do_trap
on x86_64 because the stack in use for int3 and debug is a per CPU
stack set by th IST. But 32bit does not have an IST and the stack
still belongs to the current task and there is no problem in scheduling
out the task.
Keep preemption enabled on X86_32 when enabling interrupts for
do_trap().
The name of the function is changed from preempt_conditional_sti/cli()
to conditional_sti/cli_ist(), to annotate that this function is used
when the stack is on the IST.
With threaded interrupts we might see an interrupt in progress on
migration. Do not unmask it when this is the case.
The machine might survive that problem and be at least in a state
which allows us to get more information about the problem.
Wrap the test for pagefault_disabled() into a helper, this allows us
to remove the need for current->pagefault_disabled on !-rt kernels.
Link: http://lkml.kernel.org/n/tip-3yy517m8zsi9fpsf14xfaqkw@git.kernel.org
Necessary for decoupling pagefault disable from preempt count.
Setup and remove the interrupt handler in clock event mode selection.
This avoids calling the (shared) interrupt handler when the device is
not used.
Signed-off-by: Benedikt Spranger <b.spranger@linutronix.de>
On x86_64 we must disable preemption before we enable interrupts
for stack faults, int3 and debugging, because the current task is using
a per CPU debug stack defined by the IST. If we schedule out, another task
can come in and use the same stack and cause the stack to be corrupted
and crash the kernel on return.
When CONFIG_PREEMPT_RT_FULL is enabled, spin_locks become mutexes, and
one of these is the spin lock used in signal handling.
Some of the debug code (int3) causes do_trap() to send a signal.
This function calls a spin lock that has been converted to a mutex
and has the possibility to sleep. If this happens, the above issues with
the corrupted stack is possible.
Instead of calling the signal right away, for PREEMPT_RT and x86_64,
the signal information is stored on the stacks task_struct and
TIF_NOTIFY_RESUME is set. Then on exit of the trap, the signal resume
code will send the signal when preemption is enabled.
[ rostedt: Switched from #ifdef CONFIG_PREEMPT_RT_FULL to
ARCH_RT_DELAYS_SIGNAL_SEND and added comments to the code. ]
Coccinelle based conversion.
The arm boot_lock is used by the secondary processor startup code. The locking
task is the idle thread, which has idle->sched_class == &idle_sched_class.
idle_sched_class->enqueue_task == NULL, so if the idle task blocks on the
lock, the attempt to wake it when the lock becomes available will fail:
try_to_wake_up()
activate_task()
enqueue_task()
p->sched_class->enqueue_task(rq, p, flags)
Fix by converting boot_lock to a raw spin lock.
Link: http://lkml.kernel.org/r/4E77B952.3010606@am.sony.com
All timer interrupts and the perf interrupt are marked NO_THREAD, so
its safe to allow forced interrupt threading.
PMU interrupt must not be threaded. Remove IRQF_DISABLED while at it
as we run all handlers with interrupts disabled anyway.
The update of the vdso data happens under xtime_lock, so adding a
nested lock is pointless. Just use a seqcount to sync the readers.
Changing the sequence count in update_vsyscall_tz() is completely
pointless.
The vdso code copies the data unprotected. There is no point to change
this as sys_tz is nowhere protected at all. See sys_gettimeofday().
All interrupts which must be non threaded are marked
IRQF_NO_THREAD. So it's safe to allow force threaded handlers.
IPI handlers cannot be threaded. Remove the obsolete IRQF_DISABLED
flag (see commit e58aa3d2) while at it.
Cascade handlers must run in hard interrupt context.
Cascade interrupt must run in hard interrupt context.
MSI based per cpu timers lose interrupts when intel_idle() is enabled
- independent of the c-state. With idle=poll the problem cannot be
observed. We have no idea yet, whether this is a W510 specific issue
or a general chipset oddity. Blacklist the known problem machine.
The CONFIG_PREEMPT=n section of setup_singlestep() contains:
preempt_enable_no_resched();
That's bogus as it is asymetric - no preempt_disable() - and it just
never blew up because preempt_enable_no_resched() is a NOP when
CONFIG_PREEMPT=n. Remove it.
Interrupts notify the idle exit state before calling irq_enter(). But
the notifier code calls rcu_read_lock() and this is not allowed while
rcu is in an extended quiescent state. We need to wait for
rcu_irq_enter() to be called before doing so otherwise this results in
a grumpy RCU:
[ 0.099991] WARNING: at include/linux/rcupdate.h:194 __atomic_notifier_call_chain+0xd2/0x110()
[ 0.099991] Hardware name: AMD690VM-FMH
[ 0.099991] Modules linked in:
[ 0.099991] Pid: 0, comm: swapper Not tainted 3.0.0-rc6+ #255
[ 0.099991] Call Trace:
[ 0.099991] <IRQ> [<ffffffff81051c8a>] warn_slowpath_common+0x7a/0xb0
[ 0.099991] [<ffffffff81051cd5>] warn_slowpath_null+0x15/0x20
[ 0.099991] [<ffffffff817d6fa2>] __atomic_notifier_call_chain+0xd2/0x110
[ 0.099991] [<ffffffff817d6ff1>] atomic_notifier_call_chain+0x11/0x20
[ 0.099991] [<ffffffff81001873>] exit_idle+0x43/0x50
[ 0.099991] [<ffffffff81020439>] smp_apic_timer_interrupt+0x39/0xa0
[ 0.099991] [<ffffffff817da253>] apic_timer_interrupt+0x13/0x20
[ 0.099991] <EOI> [<ffffffff8100ae67>] ? default_idle+0xa7/0x350
[ 0.099991] [<ffffffff8100ae65>] ? default_idle+0xa5/0x350
[ 0.099991] [<ffffffff8100b19b>] amd_e400_idle+0x8b/0x110
[ 0.099991] [<ffffffff810cb01f>] ? rcu_enter_nohz+0x8f/0x160
[ 0.099991] [<ffffffff810019a0>] cpu_idle+0xb0/0x110
[ 0.099991] [<ffffffff817a7505>] rest_init+0xe5/0x140
[ 0.099991] [<ffffffff817a7468>] ? rest_init+0x48/0x140
[ 0.099991] [<ffffffff81cc5ca3>] start_kernel+0x3d1/0x3dc
[ 0.099991] [<ffffffff81cc5321>] x86_64_start_reservations+0x131/0x135
[ 0.099991] [<ffffffff81cc5412>] x86_64_start_kernel+0xed/0xf4
Link: http://lkml.kernel.org/r/20110929194047.GA10247@linux.vnet.ibm.com
Cc: Andy Henroid <andrew.d.henroid@intel.com>
commit 78c5c68a4cf4329d17abfa469345ddf323d4fd62 upstream.
The code for "powersurge" SMP would kick in and cause a crash
at boot due to the lack of a NULL test.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Reported-by: Adam Conrad <adconrad@ubuntu.com>
Tested-by: Adam Conrad <adconrad@ubuntu.com>
commit e0adb9902fb338a9fe634c3c2a3e474075c733ba upstream.
Newer version of binutils are more strict about specifying the
correct options to enable certain classes of instructions.
The sparc32 build is done for v7 in order to support sun4c systems
which lack hardware integer multiply and divide instructions.
So we have to pass -Av8 when building the assembler routines that
use these instructions and get patched into the kernel when we find
out that we have a v8 capable cpu.
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 87e24f4b67e68d9fd8df16e0bf9c66d1ad2a2533 upstream.
Verified using the below proglet.. before:
[root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 0
remote write
Performance counter stats for './numa 0':
2,101,554 node-stores
2,096,931 node-store-misses
5.021546079 seconds time elapsed
[root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 1
local write
Performance counter stats for './numa 1':
501,137 node-stores
199 node-store-misses
5.124451068 seconds time elapsed
After:
remote write
2,107,516 node-stores
2,097,187 node-store-misses
5.012755149 seconds time elapsed
local write
2,063,355 node-stores
165 node-store-misses
5.082091494 seconds time elapsed
#define _GNU_SOURCE
#include <sched.h>
#include <stdio.h>
#include <errno.h>
#include <sys/mman.h>
#include <sys/types.h>
#include <dirent.h>
#include <signal.h>
#include <unistd.h>
#include <numaif.h>
#include <stdlib.h>
#define SIZE (32*1024*1024)
volatile int done;
void sig_done(int sig)
done = 1;
int main(int argc, char **argv)
cpu_set_t *mask, *mask2;
size_t size;
int i, err, t;
int nrcpus = 1024;
char *mem;
unsigned long nodemask = 0x01; /* node 0 */
DIR *node;
struct dirent *de;
int read = 0;
int local = 0;
if (argc < 2) {
printf("usage: %s [0-3]\n", argv[0]);
printf(" bit0 - local/remote\n");
printf(" bit1 - read/write\n");
exit(0);
switch (atoi(argv[1])) {
case 0:
printf("remote write\n");
break;
case 1:
printf("local write\n");
local = 1;
break;
case 2:
printf("remote read\n");
read = 1;
break;
case 3:
printf("local read\n");
local = 1;
read = 1;
break;
mask = CPU_ALLOC(nrcpus);
size = CPU_ALLOC_SIZE(nrcpus);
CPU_ZERO_S(size, mask);
node = opendir("/sys/devices/system/node/node0/");
if (!node)
perror("opendir");
while ((de = readdir(node))) {
int cpu;
if (sscanf(de->d_name, "cpu%d", &cpu) == 1)
CPU_SET_S(cpu, size, mask);
closedir(node);
mask2 = CPU_ALLOC(nrcpus);
CPU_ZERO_S(size, mask2);
for (i = 0; i < size; i++)
CPU_SET_S(i, size, mask2);
CPU_XOR_S(size, mask2, mask2, mask); // invert
if (!local)
mask = mask2;
err = sched_setaffinity(0, size, mask);
if (err)
perror("sched_setaffinity");
mem = mmap(0, SIZE, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0);
err = mbind(mem, SIZE, MPOL_BIND, &nodemask, 8*sizeof(nodemask), MPOL_MF_MOVE);
if (err)
perror("mbind");
signal(SIGALRM, sig_done);
alarm(5);
if (!read) {
while (!done) {
for (i = 0; i < SIZE; i++)
mem[i] = 0x01;
} else {
while (!done) {
t += *(volatile char *)(mem + i);
return 0;
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-tq73sxus35xmqpojf7ootxgs@git.kernel.org
commit a7f4255f906f60f72e00aad2fb000939449ff32e upstream.
Commit f0fbf0abc093 ("x86: integrate delay functions") converted
delay_tsc() into a random delay generator for 64 bit. The reason is
that it merged the mostly identical versions of delay_32.c and
delay_64.c. Though the subtle difference of the result was:
static void delay_tsc(unsigned long loops)
- unsigned bclock, now;
+ unsigned long bclock, now;
Now the function uses rdtscl() which returns the lower 32bit of the
TSC. On 32bit that's not problematic as unsigned long is 32bit. On 64
bit this fails when the lower 32bit are close to wrap around when
bclock is read, because the following check
if ((now - bclock) >= loops)
break;
evaluated to true on 64bit for e.g. bclock = 0xffffffff and now = 0
because the unsigned long (now - bclock) of these values results in
0xffffffff00000001 which is definitely larger than the loops
value. That explains Tvortkos observation:
"Because I am seeing udelay(500) (_occasionally_) being short, and
that by delaying for some duration between 0us (yep) and 491us."
Make those variables explicitely u32 again, so this works for both 32
and 64 bit.
Reported-by: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
commit 134d12fae0bb8f3d60dc7440a9e1950bb5427167 upstream.
For some weird (freudian?) reason, commit 435792d "ARM: OMAP: make
iommu subsys_initcall to fix builtin omap3isp" unintentionally changed
the mailbox's initcall instead of the iommu's.
Fix that.
Reported-by: Fernando Guzman Lugo <fernando.lugo@ti.com>
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 3f31ae121348afd9ed39700ea2a63c17cd7eeed1 upstream.
xscale2 PMUs indicate overflow not via the PMU control register, but by
a separate overflow FLAG register instead.
This patch fixes the xscale2 PMU code to use this register to detect
to overflow and ensures that we clear any pending overflow when
disabling a counter.
