In the branch emulation for floating-point exceptions, __compute_return_epc
must determine for bc1f et al which condition code bit to test. This is
based on bits <4:2> of the rt field. The switch statement to distinguish
bc1f et al needs to use only the two low bits of rt, but the old code tests
on the whole rt field. This patch masks off the proper bits.
Signed-off-by: Win Treese <treese@acm.org>
Fix the cache index value in tx49_blast_icache32_page_indexed().
This is damage by de62893bc0725f8b5f0445250577cd7a10b2d8f8 commit.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
As it turned out after recent SCSI changes, strncpy() was broken -
it mixed up the return values from __stxncpy() in registers $24 and $27.
Thanks to Mathieu Chouquet-Stringer for tracking down the problem
and providing an excellent test case.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
We do this by removing a micro-optimization that tries to avoid grabbing
the iommu_bitmap_lock spinlock and using a bus-locked operation.
This still races with other simultaneous alloc_iommu or free_iommu(size
> 1) which both use bus-unlocked operations.
The end result of this race is eventually ending
up with an iommu_gart_bitmap that has bits errornously set all over,
making large contiguous iommu space allocations fail with 'PCI-DMA:
Out of IOMMU space'.
Signed-off-by: Mike Waychison <mikew@google.com>
Signed-off-by: Andi Kleen <ak@suse.de>
pages
This quietens warnings and actually fixes a bug. The unwind tables would
come out wrong without -32, causing pthread cancellation during them
to crash in the gcc runtime.
The problem seems to only happen with newer binutils
(it doesn't happen with 2.16.91.0.2 but happens wit 2.16.91.0.5)
Thanks to Brian Baker @ HP for test case and initial analysis.
Cc: brian.b@hp.com
hi,
The motivation behind the patch below was to address messages in
/var/log/messages such as:
Jan 31 10:54:15 mets kernel: audit(:0): major=252 name_count=0: freeing
multiple contexts (1)
Jan 31 10:54:15 mets kernel: audit(:0): major=113 name_count=0: freeing
multiple contexts (2)
I can reproduce by running 'get-edid' from:
http://john.fremlin.de/programs/linux/read-edid/.
These messages come about in the log b/c the vm86 calls do not exit via
the normal system call exit paths and thus do not call
'audit_syscall_exit'. The next system call will then free the context for
itself and for the vm86 context, thus generating the above messages. This
patch addresses the issue by simply adding a call to 'audit_syscall_exit'
from the vm86 code.
Besides fixing the above error messages the patch also now allows vm86
system calls to become auditable. This is useful since strace does not
appear to properly record the return values from sys_vm86.
I think this patch is also a step in the right direction in terms of
cleaning up some core auditing code. If we can correct any other paths
that do not properly call the audit exit and entries points, then we can
also eliminate the notion of context chaining.
I've tested this patch by verifying that the log messages no longer
appear, and that the audit records for sys_vm86 appear to be correct.
Also, 'read_edid' produces itentical output.
thanks,
-Jason
Signed-off-by: Jason Baron <jbaron@redhat.com>
Fix the "apm: set display: Interface not engaged" error on Armada laptops
again.
Jordan said:
I think this is fine. It seems to me that this may be the fault of one or
both of the APM solutions handling this situation in a non-standard way, but
since APM is used very little on the Geode, and I have direct access to our
BIOS folks, if this problem comes up with a customer again, we'll solve it
from the firmware.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: "Jordan Crouse" <jordan.crouse@amd.com>
Cc: Zachary Amsden <zach@vmware.com>
AMD K7/K8 CPUs only save/restore the FOP/FIP/FDP x87 registers in FXSAVE
when an exception is pending. This means the value leak through context
switches and allow processes to observe some x87 instruction state of
other processes.
This was actually documented by AMD, but nobody recognized it as being
different from Intel before.
The fix first adds an optimization: instead of unconditionally calling
FNCLEX after each FXSAVE test if ES is pending and skip it when not
needed. Then do a x87 load from a kernel variable to clear FOP/FIP/FDP.
This means other processes always will only see a constant value defined
by the kernel in their FP state.
I took some pain to make sure to chose a variable that's already in L1
during context switch to make the overhead of this low.
Also alternative() is used to patch away the new code on CPUs who don't
need it.
Patch for both i386/x86-64.
The problem was discovered originally by Jan Beulich. Richard Brunner
provided the basic code for the workarounds, with contribution from Jan.
This is CVE-2006-1056
Cc: richard.brunner@amd.com
Cc: jbeulich@novell.com
I've encountered two problems with 2.6.16 and newer kernels on my API CS20
(dual 833MHz Alpha 21264b processors). The first is the kernel OOPSing
because of a NULL pointer dereference while trying to populate SysFS with the
CPU information. The other is that only one processor was being brought up.
I've included a small Alpha-specific patch that fixes both problems.
The first problem was caused by the CPUs never being properly registered using
register_cpu(), the way it's done on other architectures.
The second problem has to do with the removal of hwrpb_cpu_present_mask in
arch/alpha/kernel/smp.c. In setup_smp() in the 2.6.15 kernel sources,
hwrpb_cpu_present_mask has a bit set for each processor that is probed, and
afterwards cpu_present_mask is set to the cpumask for the boot CPU. In the
same function of the same file in the 2.6.16 sources, instead of
hwrpb_cpu_present_mask being set, cpu_possible_map is updated for each probed
CPU. cpu_present_mask is still set to the cpumask of the boot CPU afterwards.
The problem lies in include/asm-alpha/smp.h, where cpu_possible_map is
#define'd to be cpu_present_mask.
Cleanups from: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
- cpu_present_mask and cpu_possible_map are essentially the same thing
on alpha, as it doesn't support CPU hotplug;
- allocate "struct cpu" only for present CPUs, like sparc64 does.
Static array of "struct cpu" is just a waste of memory.
Signed-off-by: Brian Uhrain <buhrain@rosettastone.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
SMP kernel
This patch fixes a boot problem of the m32r SMP kernel 2.6.16-rc1-mm3 or
later.
In this patch, cpu_possible_map is statically initialized, and cpu_present_map
is also copied from cpu_possible_map in smp_prepare_cpus(), because the m32r
architecture has not supported CPU hotplug yet.
Signed-off-by: Hayato Fujiwara <fujiwara.hayato@renesas.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Update {get,put}_user macros for m32r kernel.
- Modify get_user to use __get_user_asm macro, instead of __get_user_x macro.
- Remove arch/m32r/lib/{get,put}user.S.
- Some cosmetic updates.
I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's
security problem in {get,put}_user macros.
There were no address checking for user space access in {get,put}_user macros.
Cc: NIIBE Yutaka <gniibe@fsij.org>
*) When setting a sighandler using sigaction() call, if the flag
SA_ONSTACK is set and no alternate stack is provided via sigaltstack(),
the kernel still try to install the alternate stack. This behavior is
the opposite of the one which is documented in Single Unix
Specifications V3.
*) Also when setting an alternate stack using sigaltstack() with the
flag SS_DISABLE, the kernel try to install the alternate stack on
signal delivery.
These two use cases makes the process crash at signal delivery.
This fixes it.
Signed-off-by: Laurent Meyer <meyerlau@fr.ibm.com>
Since the powerpc 64k pages patch went in, systems that have SLBs
(like Power4 iSeries) needed to have slb_initialize called to set up
some variables for the SLB miss handler. This was not being called
on the boot processor on iSeries, so on single cpu iSeries machines,
we would get apparent memory curruption as soon as we entered user mode.
This patch fixes that by calling slb_initialize on the boot cpu if the
processor has an SLB.
(CVE-2006-0744)
Intel EM64T CPUs handle uncanonical return addresses differently from
AMD CPUs.
The exception is reported in the SYSRET, not the next instruction.
Thgis leads to the kernel exception handler running on the user stack
with the wrong GS because the kernel didn't expect exceptions on this
instruction.
This version of the patch has the teething problems that plagued an
earlier version fixed.
This is CVE-2006-0744
Thanks to Ernie Petrides and Asit B. Mallick for analysis and initial
patches.
Just call IRET always, no need for any special cases.
Needed for the next bug fix.
[CPUFREQ] Fix the p4-clockmod N60 errata workaround.
Fix the code to disable freqs less than 2GHz in N60 errata.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
[CPUFREQ] Mark longhaul driver as broken.
This seems to work for a short period of time, but when
used in conjunction with a userspace governor that changes
the frequency regularly, it's only a matter of time before
everything just locks up.
We used to assume that a DMA mapping request with a NULL dev was for
ISA DMA. This assumption was broken at some point. Now we explicitly
pass the detected ISA PCI device in the floppy setup.
Fix bug identified by Linus Torvalds <torvalds@osdl.org>: the `out'
instruction depends upon the state of memory_data[], so we need to tell gcc
that before executing it. (The opcode, not gcc).
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=5553
Thanks to Antonio Ospite <ospite@studenti.unina.it> for testing.
Cc: Dave Jones <davej@codemonkey.org.uk>
Attached patch fixes invalid pointer arithmetic in DMI code to make onboard
device discovery working again.
akpm: bug has been present since dmi_find_device() was added in 2.6.14.
Affects ipmi only (I think) - the symptoms weren't described.
akpm: changed to use pointer arithmetic rather than open-coded sizeof.
Signed-off-by: Andrey Panin <pazke@donpac.ru>
Cc: Corey Minyard <minyard@acm.org>
From Dave Johnson <djohnson+linuxmips@sw.starentnetworks.com>:
sb1250_gettimeoffset() simply reads the current cpu 0 timer remaining
value, however once this counter reaches 0 and the interrupt is raised,
it immediately resets and begins to count down again.
If sb1250_gettimeoffset() is called on cpu 1 via do_gettimeofday() after
the timer has reset but prior to cpu 0 processing the interrupt and
taking write_seqlock() in timer_interrupt() it will return a full value
(or close to it) causing time to jump backwards 1ms. Once cpu 0 handles
the interrupt and timer_interrupt() gets far enough along it will jump
forward 1ms.
Fix this problem by implementing mips_hpt_*() on sb1250 using a spare
timer unrelated to the existing periodic interrupt timers. It runs at
1Mhz with a full 23bit counter. This eliminated the custom
do_gettimeoffset() for sb1250 and allowed use of the generic
fixed_rate_gettimeoffset() using mips_hpt_*() and timerhi/timerlo.
The timers need to be loaded with 1 less than the desired interval not
the interval itself.
* do_timer() expects the arch-specific handler to take the lock as it
modifies jiffies[_64] and xtime.
* writing timerhi/lo in timer_interrupt() will mess up
fixed_rate_gettimeoffset() which reads timerhi/lo.
Signed-off-by: Matej Kupljen <matej.kupljen@ultra.si>
If dcache_size != icache_size or dcache_size != scache_size, or
set-associative cache, icache/scache does not flushed properly. Make
blast_?cache_page_indexed() masks its index value correctly. Also,
use physical address for physically indexed pcache/scache.
This breaks the kernel build if sgiwd93 was configured as a module.
Bryce reported a bug wherein offlining CPU0 (on x86 box) and then
subsequently onlining it resulted in a lockup.
On x86, CPU0 is never offlined. The subsequent attempt to online CPU0
doesn't take that into account. It actually tries to bootup the already
booted CPU. Following patch fixes the problem (as acknowledged by Bryce).
Please consider for inclusion in 2.6.16.
Check if cpu is already online.
Signed-off-by: Srivatsa Vaddagiri <vatsa@in.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge:
powerpc: update defconfigs
[PATCH] powerpc: properly configure DDR/P5IOC children devs
[PATCH] powerpc: remove duplicate EXPORT_SYMBOLS
[PATCH] powerpc: RTC memory corruption
[PATCH] powerpc: enable NAP only on cpus who support it to avoid memory corruption
[PATCH] powerpc: Clarify wording for CRASH_DUMP Kconfig option
[PATCH] powerpc/64: enable CONFIG_BLK_DEV_SL82C105
[PATCH] powerpc: correct cacheflush loop in zImage
powerpc: Fix problem with time going backwards
powerpc: Disallow lparcfg being a module
The dynamic add path for PCI Host Bridges can fail to configure children
adapters under P5IOC controllers. It fails to properly fixup bus/device
resources, and it fails to properly enable EEH. Both of these steps
need to occur before any children devices are enabled in
pci_bus_add_devices().
Signed-off-by: John Rose <johnrose@austin.ibm.com>
remove warnings when building a 64bit kernel.
smp_call_function triggers also with 32bit kernel.
WARNING: vmlinux: duplicate symbol 'smp_call_function' previous definition was in vmlinux
arch/powerpc/kernel/ppc_ksyms.c:164:EXPORT_SYMBOL(smp_call_function);
arch/powerpc/kernel/smp.c:300:EXPORT_SYMBOL(smp_call_function);
WARNING: vmlinux: duplicate symbol 'ioremap' previous definition was in vmlinux
arch/powerpc/kernel/ppc_ksyms.c:113:EXPORT_SYMBOL(ioremap);
arch/powerpc/mm/pgtable_64.c:321:EXPORT_SYMBOL(ioremap);
WARNING: vmlinux: duplicate symbol '__ioremap' previous definition was in vmlinux
arch/powerpc/kernel/ppc_ksyms.c:117:EXPORT_SYMBOL(__ioremap);
arch/powerpc/mm/pgtable_64.c:322:EXPORT_SYMBOL(__ioremap);
WARNING: vmlinux: duplicate symbol 'iounmap' previous definition was in vmlinux
arch/powerpc/kernel/ppc_ksyms.c:118:EXPORT_SYMBOL(iounmap);
arch/powerpc/mm/pgtable_64.c:323:EXPORT_SYMBOL(iounmap);
Signed-off-by: Olaf Hering <olh@suse.de>
We should be memset'ing the data we are pointing to, not the pointer
itself. This is in an error path so we probably don't hit it much.
Signed-off-by: Michael Neuling <mikey@neuling.org>
corruption
This patch fixes incorrect setting of powersave_nap to 1 on all
PowerMacs, potentially causing memory corruption on some models. This
bug was introuced by me during the 32/64 bits merge.
The wording of the CRASH_DUMP Kconfig option is not very clear. It gives you a
kernel that can be used _as_ the kdump kernel, not a kernel that can boot into
a kdump kernel.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Enable the onboard IDE driver for p610, p615 and p630.
They have the CD connected to this card. All other RS/6000 systems with this
controller have no connectors and dont need this option.
Correct the loop for cacheflush. No idea where I copied the code from,
but the original does not work correct. Maybe the flush is not needed.
The recent changes to keep gettimeofday in sync with xtime had the side
effect that it was occasionally possible for the time reported by
gettimeofday to go back by a microsecond. There were two reasons:
(1) when we recalculated the offsets used by gettimeofday every 2^31
timebase ticks, we lost an accumulated fractional microsecond, and
(2) because the update is done some time after the notional start of
jiffy, if ntp is slowing the clock, it is possible to see time go backwards
when the timebase factor gets reduced.
This fixes it by (a) slowing the gettimeofday clock by about 1us in
2^31 timebase ticks (a factor of less than 1 in 3.7 million), and (b)
adjusting the timebase offsets in the rare case that the gettimeofday
result could possibly go backwards (i.e. when ntp is slowing the clock
and the timer interrupt is late). In this case the adjustment will
reduce to zero eventually because of (a).
Patch from Ben Dooks
arch/arm/kernel/setup.c declares mem_fclk_21285 when
this is already declared in include/asm-arm/system.h
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
arch/arm/kernel/compat.c exports two functions,
convert_to_tag_list and squash_mem_tags which
are not defined in any header files, and not
used outside arch/arm/kernel.
Fix the following warnings from sparse:
arch/arm/kernel/process.c:86:6: warning: symbol 'default_idle' was not declared. Should it be static?
arch/arm/kernel/process.c:378:5: warning: symbol 'dump_fpu' was not declared. Should it be static?
Include <linux/elfcore.h> for dump_fpu() decleration, and
make default_idle() static as it is not used outside the file.
Patch from Albrecht Dreß
Add DMA resources to s3c2410 spi platform devices - dma_(alloc|free)_coherent should now work as expected.
Signed-off-by: Albrecht Dreß <albrecht.dress@lios-tech.com>
Patch from Pavel Machek
Enable frontlight during collie bootup, so that display is actually
readable in anything other than bright sunlight.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
lapic_shutdown() re-enables interrupts which is un-desirable for panic
case, so use local_irq_save() and local_irq_restore() to keep the irqs
disabled for kexec on panic case, and close a possible race window while
kdump shutdown as shown in this stack trace
-- BUG: spinlock lockup on CPU#1, bash/4396, c52781a0
[<c01c1870>] _raw_spin_lock+0xb7/0xd2
[<c029e148>] _spin_lock+0x6/0x8
[<c011b33f>] scheduler_tick+0xe7/0x328
[<c0128a7c>] update_process_times+0x51/0x5d
[<c0114592>] smp_apic_timer_interrupt+0x4f/0x58
[<c01141ff>] lapic_shutdown+0x76/0x7e
[<c0104d7c>] apic_timer_interrupt+0x1c/0x30
[<c0116659>] machine_crash_shutdown+0x83/0xaa
[<c013cc36>] crash_kexec+0xc1/0xe3
[<c013cc22>] crash_kexec+0xad/0xe3
[<c0215280>] __handle_sysrq+0x84/0xfd
[<c018d937>] write_sysrq_trigger+0x2c/0x35
[<c015e47b>] vfs_write+0xa2/0x13b
[<c015ea73>] sys_write+0x3b/0x64
[<c0103c69>] syscall_call+0x7/0xb
Signed-off-by: Maneesh Soni <maneesh@in.ibm.com>
This reverts commit c33d4568aca9028a22857f94f5e0850012b6444b.
Andrew Clayton and Hugh Dickins report that it's broken for them and
causes strange page table and slab corruption, and spontaneous reboots.
Let's get it right next time.
Cc: Andrew Clayton <andrew@rootshell.co.uk>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Andi Kleen <ak@suse.de>
The lparcfg code needs several things which are pretty arcane internal
details and which we don't want to export, which means that lparcfg
doesn't work when built as a module. This makes it a bool instead of
a tristate in the Kconfig so that users can't try to build it as a
module.
EM64T CPUs have somewhat weird error reporting for non canonical RIPs in
SYSRET.
We can't handle any exceptions there because the exception handler would
end up running on the user stack which is unsafe.
To avoid problems any code that might end up with a user touched pt_regs
should return using int_ret_from_syscall. int_ret_from_syscall ends up
using IRET, which allows safe exceptions.
Cc: Ernie Petrides <petrides@redhat.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] iwmmxt thread state alignment
[ARM] 3350/1: Enable 1-wire on ARM
[ARM] 3356/1: Workaround for the ARM1136 I-cache invalidation problem
[ARM] 3355/1: NSLU2: remove propmt depends
[ARM] 3354/1: NAS100d: fix power led handling
[ARM] Fix muldi3.S
