path: root/arch
2012-02-24Merge tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreamingLinus Torvalds
This is the arch/c6x part of commit 7c43185138cf ("Kbuild: Use dtc's -d (dependency) option") which was dropped because c6x had not yet been merged at the time. * tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: Kbuild: Use dtc's -d (dependency) option
2012-02-24Merge tag 'rmobile-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
SH/R-Mobile fixes for 3.3-rc5 * tag 'rmobile-for-linus' of git://github.com/pmundt/linux-sh: arch/arm/mach-shmobile/board-ag5evm.c: included linux/dma-mapping.h twice ARM: mach-shmobile: r8a7779 PFC IPSR4 fix ARM: mach-shmobile: sh73a0 PSTR 32-bit access fix ARM: mach-shmobile: add GPIO-to-IRQ translation to sh7372 ARM: mach-shmobile: clock-sh73a0: add DSIxPHY clock support arm: fix compile failure in mach-shmobile/board-ag5evm.c ARM: mach-shmobile: mackerel: add ak4642 amixer settings on comment ARM: mach-shmobile: mackerel: use renesas_usbhs instead of r8a66597_hcd ARM: mach-shmobile: simplify MMCIF DMA configuration ARM: mach-shmobile: IRQ driven GPIO key support for Kota2 ARM: mach-shmobile: sh73a0 IRQ sparse alloc fix ARM: mach-shmobile: sh73a0 PINT IRQ base fix
2012-02-24Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
SuperH fixes for 3.3-rc5 * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: sh: Fix sh2a build error for CONFIG_CACHE_WRITETHROUGH sh: modify a resource of sh_eth_giga1_resources in board-sh7757lcr arch/sh: remove references to cpu_*_map. sh: Fix typo in pci-sh7780.c sh: add platform_device for SPI1 in setup-sh7757 sh: modify resource for SPI0 in setup-sh7757 sh: se7724: fix compile breakage sh: clkfwk: bugfix: use clk_reparent() for div6 clocks sh: clock-sh7724: fixup sh_fsi clock settings sh: sh7757lcr: update to the new MMCIF DMA configuration sh: fix the sh_mmcif_plat_data in board-sh7757lcr video: pvr2fb: Fix up spurious section mismatch warnings. sh: Defer to asm-generic/device.h.
2012-02-24arch/arm/mach-shmobile/board-ag5evm.c: included linux/dma-mapping.h twiceDanny Kukawka
arch/arm/mach-shmobile/board-ag5evm.c: included 'linux/dma-mapping.h' twice, remove the duplicate. Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24ARM: mach-shmobile: r8a7779 PFC IPSR4 fixMagnus Damm
Fix the bit field width information for the IPSR4 register in the r8a7779 pin function controller (PFC). Without this fix the Marzen board fails to receive data over the serial console due to misconfigured pin function for the RX pin. Signed-off-by: Magnus Damm <damm@opensource.se> Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Tested-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24ARM: mach-shmobile: sh73a0 PSTR 32-bit access fixMagnus Damm
Convert the sh73a0 SMP code to use 32-bit PSTR access. This fixes wakeup from deep sleep for sh73a0 secondary CPUs. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux into ↵Paul Mundt
rmobile-fixes-for-linus
2012-02-24sh: Fix sh2a build error for CONFIG_CACHE_WRITETHROUGHPhil Edworthy
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24sh: modify a resource of sh_eth_giga1_resources in board-sh7757lcrShimoda, Yoshihiro
The latest sh_eth driver needs a resource of TSU in the channel 1, if the controller has TSU registers. So, this patch adds the resource. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24arch/sh: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while; time for the final push. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul Mundt <lethal@linux-sh.org> Cc: linux-sh@vger.kernel.org Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-24sh: Fix typo in pci-sh7780.cMasanari Iida
Correct spelling "erorr" to "error" in arch/sh/drivers/pci/pci-sh7780.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-02-23Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc BenH says: 'Here are a few more powerpc bits for you. A stupid regression I introduced with my previous commit to "fix" program check exceptions (brown paper bag for me), fix the cpuidle default, a bug fix for something that isn't strictly speaking a regression but some upstream changes causes it to show in lockdep now while it didn't before, and finally a trivial one for rusty to make his life easier later on removing the old cpumask cruft. ' * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix various issues with return to userspace cpuidle: Default y on powerpc pSeries powerpc: Fix program check handling when lockdep is enabled powerpc: Remove references to cpu_*_map
2012-02-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu It contains 3 important fixes for ColdFire based machines: - fix processes getting stuck when running from strace - fix kernel vmalloced pages not being visible in all kernel contexts - fix shared user pages sometimes being visible in another process context * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: Do not set global share for non-kernel shared pages m68k: Add shared bit to Coldfire kernel page entries m68knommu: fix syscall tracing stuck process
2012-02-22powerpc: Fix various issues with return to userspaceBenjamin Herrenschmidt
We have a few problems when returning to userspace. This is a quick set of fixes for 3.3, I'll look into a more comprehensive rework for 3.4. This fixes: - We kept interrupts soft-disabled when schedule'ing or calling do_signal when returning to userspace as a result of a hardware interrupt. - Rename do_signal to do_notify_resume like all other archs (and do_signal_pending back to do_signal, which it was before Roland changed it). - Add the missing call to key_replace_session_keyring() to do_notify_resume(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> ---
2012-02-22powerpc: Fix program check handling when lockdep is enabledMichael Ellerman
In commit 54321242afe ("Disable interrupts early in Program Check"), we switched from enabling to disabling interrupts in program_check_common. Whereas ENABLE_INTS leaves r3 untouched, if lockdep is enabled DISABLE_INTS calls into lockdep code and will clobber r3. That means we pass a bogus struct pt_regs* into program_check_exception() and all hell breaks loose. So load our regs pointer into r3 after we call DISABLE_INTS. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-22powerpc: Remove references to cpu_*_mapRusty Russell
This has been obsolescent for a while; time for the final push. In adjacent context, replaced old cpus_* with cpumask_*. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-21Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
A few more things this time around. The only thing warranting some commentry is the modpost change, which allows folk building a Thumb2 enabled kernel to see section mismatch warnings. This is why many weren't noticed with OMAP. * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM/audit: include audit header and fix audit arch ARM: OMAP: fix voltage domain build errors with PM_OPP disabled ARM/PCI: Remove ARM's duplicate definition of 'pcibios_max_latency' ARM: 7336/1: smp_twd: Don't register CPUFREQ notifiers if local timers are not initialised ARM: 7327/1: need to include asm/system.h in asm/processor.h ARM: 7326/2: PL330: fix null pointer dereference in pl330_chan_ctrl() ARM: 7164/3: PL330: Fix the size of the dst_cache_ctrl field ARM: 7325/1: fix v7 boot with lockdep enabled ARM: 7324/1: modpost: Fix section warnings for ARM for many compilers ARM: 7323/1: Do not allow ARM_LPAE on pre-ARMv7 architectures
2012-02-21sys_poll: fix incorrect type for 'timeout' parameterLinus Torvalds
The 'poll()' system call timeout parameter is supposed to be 'int', not 'long'. Now, the reason this matters is that right now 32-bit compat mode is broken on at least x86-64, because the 32-bit code just calls 'sys_poll()' directly on x86-64, and the 32-bit argument will have been zero-extended, turning a signed 'int' into a large unsigned 'long' value. We could just introduce a 'compat_sys_poll()' function for this, and that may eventually be what we have to do, but since the actual standard poll() semantics is *supposed* to be 'int', and since at least on x86-64 glibc sign-extends the argument before invocing the system call (so nobody can actually use a 64-bit timeout value in user space _anyway_, even in 64-bit binaries), the simpler solution would seem to be to just fix the definition of the system call to match what it should have been from the very start. If it turns out that somebody somehow circumvents the user-level libc 64-bit sign extension and actually uses a large unsigned 64-bit timeout despite that not being how poll() is supposed to work, we will need to do the compat_sys_poll() approach. Reported-by: Thomas Meyer <thomas@m3y3r.de> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-21ARM/audit: include audit header and fix audit archEric Paris
Both bugs being fixed were introduced in: 29ef73b7a823b77a7cd0bdd7d7cded3fb6c2587b Include linux/audit.h to fix below build errors: CC arch/arm/kernel/ptrace.o arch/arm/kernel/ptrace.c: In function 'syscall_trace': arch/arm/kernel/ptrace.c:919: error: implicit declaration of function 'audit_syscall_exit' arch/arm/kernel/ptrace.c:921: error: implicit declaration of function 'audit_syscall_entry' arch/arm/kernel/ptrace.c:921: error: 'AUDIT_ARCH_ARMEB' undeclared (first use in this function) arch/arm/kernel/ptrace.c:921: error: (Each undeclared identifier is reported only once arch/arm/kernel/ptrace.c:921: error: for each function it appears in.) make[1]: *** [arch/arm/kernel/ptrace.o] Error 1 make: *** [arch/arm/kernel] Error 2 This part of the patch is: Reported-by: Axel Lin <axel.lin@gmail.com> Reported-by: Peter Ujfalusi <peter.ujfalusi@ti.com> (They both provided patches to fix it) This patch also (at the request of the list) fixes the fact that ARM has both LE and BE versions however the audit code was called as if it was always BE. If audit userspace were to try to interpret the bits it got from a LE system it would obviously do so incorrectly. Fix this by using the right arch flag on the right system. This part of the patch is: Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21ARM: OMAP: fix voltage domain build errors with PM_OPP disabledRussell King
The voltage domain code wants the voltage tables, which are in the opp*.c files. These files aren't built when PM_OPP is disabled, causing the following build errors at link time: twl-common.c:(.init.text+0x2e48): undefined reference to `omap34xx_vddmpu_volt_data' twl-common.c:(.init.text+0x2e4c): undefined reference to `omap34xx_vddcore_volt_data' twl-common.c:(.init.text+0x2e5c): undefined reference to `omap36xx_vddmpu_volt_data' twl-common.c:(.init.text+0x2e60): undefined reference to `omap36xx_vddcore_volt_data' twl-common.c:(.init.text+0x2830): undefined reference to `omap44xx_vdd_mpu_volt_data' twl-common.c:(.init.text+0x283c): undefined reference to `omap44xx_vdd_iva_volt_data' twl-common.c:(.init.text+0x2844): undefined reference to `omap44xx_vdd_core_volt_data' Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21ARM/PCI: Remove ARM's duplicate definition of 'pcibios_max_latency'Myron Stowe
The patch series to re-factor PCI's 'latency timer' setup (re: http://marc.info/?l=linux-kernel&m=131983853831049&w=2) forgot to remove the ARM specific definition of 'pcibios_max_latency' once such had been moved into the pci core resulting in ARM related compile errors - drivers/built-in.o:(.data+0x230): multiple definition of `pcibios_max_latency' arch/arm/common/built-in.o:(.data+0x40c): first defined here make[1]: *** [vmlinux.o] Error 1 In the series, patch 2/16 (commit 168c8619fd8) converted the ARM specific version of 'pcibios_set_master()' to a non-inlined version. This was done in preperation for hosting it up into PCI's core, which was done in patch 10/16 (commit 96c5590058d) of the series (and where the removal of ARM's 'pcibios_max_latency' was overlooked). Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-21ARM: 7336/1: smp_twd: Don't register CPUFREQ notifiers if local timers are ↵Santosh Shilimkar
not initialised Current ARM local timer code registers CPUFREQ notifiers even in case the twd_timer_setup() isn't called. That seems to be wrong and would eventually lead to kernel crash on the CPU frequency transitions on the SOCs where the local timer doesn't exist or broken because of hardware BUG. Fix it by testing twd_evt and *__this_cpu_ptr(twd_evt). The issue was observed with v3.3-rc3 and building an OMAP2+ kernel on OMAP3 SOC which doesn't have TWD. Below is the dump for reference : Unable to handle kernel paging request at virtual address 007e900 pgd = cdc20000 [007e9000] *pgd=00000000 Internal error: Oops: 5 [#1] SMP Modules linked in: CPU: 0 Not tainted (3.3.0-rc3-pm+debug+initramfs #9) PC is at twd_update_frequency+0x34/0x48 LR is at twd_update_frequency+0x10/0x48 pc : [<c001382c>] lr : [<c0013808>] psr: 60000093 sp : ce311dd8 ip : 00000000 fp : 00000000 r10: 00000000 r9 : 00000001 r8 : ce310000 r7 : c0440458 r6 : c00137f8 r5 : 00000000 r4 : c0947a74 r3 : 00000000 r2 : 007e9000 r1 : 00000000 r0 : 00000000 Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment usr Control: 10c5387d Table: 8dc20019 DAC: 00000015 Process sh (pid: 599, stack limit = 0xce3102f8) Stack: (0xce311dd8 to 0xce312000) 1dc0: 6000c 1de0: 00000001 00000002 00000000 00000000 00000000 00000000 00000 1e00: ffffffff c093d8f0 00000000 ce311ebc 00000001 00000001 ce310 1e20: c001386c c0437c4c c0e95b60 c0e95ba8 00000001 c0e95bf8 ffff4 1e40: 00000000 00000000 c005ef74 ce310000 c0435cf0 ce311ebc 00000 1e60: ce352b40 0007a120 c08d5108 c08ba040 c08ba040 c005f030 00000 1e80: c08bc554 c032fe2c 0007a120 c08d4b64 ce352b40 c08d8618 ffff8 1ea0: c08ba040 c033364c ce311ecc c0433b50 00000002 ffffffea c0330 1ec0: 0007a120 0007a120 22222201 00000000 22222222 00000000 ce357 1ee0: ce3d6000 cdc2aed8 ce352ba0 c0470164 00000002 c032f47c 00034 1f00: c0331cac ce352b40 00000007 c032f6d0 ce352bbc 0003d090 c0930 1f20: c093d8bc c03306a4 00000007 ce311f80 00000007 cdc2aec0 ce358 1f40: ce8d20c0 00000007 b6fe5000 ce311f80 00000007 ce310000 0000c 1f60: c000de74 ce987400 ce8d20c0 b6fe5000 00000000 00000000 0000c 1f80: 00000000 00000000 001fbac8 00000000 00000007 001fbac8 00004 1fa0: c000df04 c000dd60 00000007 001fbac8 00000001 b6fe5000 00000 1fc0: 00000007 001fbac8 00000007 00000004 b6fe5000 00000000 00202 1fe0: 00000000 beb565f8 00101ffc 00008e8c 60000010 00000001 00000 [<c001382c>] (twd_update_frequency+0x34/0x48) from [<c008ac4c>] ) [<c008ac4c>] (smp_call_function_single+0x17c/0x1c8) from [<c0013) [<c0013890>] (twd_cpufreq_transition+0x24/0x30) from [<c0437c4c>) [<c0437c4c>] (notifier_call_chain+0x44/0x84) from [<c005efe4>] () [<c005efe4>] (__srcu_notifier_call_chain+0x70/0xa4) from [<c005f) [<c005f030>] (srcu_notifier_call_chain+0x18/0x20) from [<c032fe2) [<c032fe2c>] (cpufreq_notify_transition+0xc8/0x1b0) from [<c0333) [<c033364c>] (omap_target+0x1b4/0x28c) from [<c032f47c>] (__cpuf) [<c032f47c>] (__cpufreq_driver_target+0x50/0x64) from [<c0331d24) [<c0331d24>] (cpufreq_set+0x78/0x98) from [<c032f6d0>] (store_sc) [<c032f6d0>] (store_scaling_setspeed+0x5c/0x74) from [<c03306a4>) [<c03306a4>] (store+0x58/0x74) from [<c014d868>] (sysfs_write_fi) [<c014d868>] (sysfs_write_file+0x80/0xb4) from [<c00f2c2c>] (vfs) [<c00f2c2c>] (vfs_write+0xa8/0x138) from [<c00f2e9c>] (sys_write) [<c00f2e9c>] (sys_write+0x40/0x6c) from [<c000dd60>] (ret_fast_s) Code: e594300c e792210c e1a01000 e5840004 (e7930002) ---[ end trace 5da3b5167c1ecdda ]--- Reported-by: Kevin Hilman <khilman@ti.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-20i387: export 'fpu_owner_task' per-cpu variableLinus Torvalds
(And define it properly for x86-32, which had its 'current_task' declaration in separate from x86-64) Bitten by my dislike for modules on the machines I use, and the fact that apparently nobody else actually wanted to test the patches I sent out. Snif. Nobody else cares. Anyway, we probably should uninline the 'kernel_fpu_begin()' function that is what modules actually use and that references this, but this is the minimal fix for now. Reported-by: Josh Boyer <jwboyer@gmail.com> Reported-and-tested-by: Jongman Heo <jongman.heo@samsung.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] correct ktime to tod clock comparator conversion [S390] 3215 deadlock with tty_wakeup [S390] incorrect PageTables counter for kvm page tables [S390] idle: avoid RCU usage in extended quiescent state
2012-02-20i387: support lazy restore of FPU stateLinus Torvalds
This makes us recognize when we try to restore FPU state that matches what we already have in the FPU on this CPU, and avoids the restore entirely if so. To do this, we add two new data fields: - a percpu 'fpu_owner_task' variable that gets written any time we update the "has_fpu" field, and thus acts as a kind of back-pointer to the task that owns the CPU. The exception is when we save the FPU state as part of a context switch - if the save can keep the FPU state around, we leave the 'fpu_owner_task' variable pointing at the task whose FP state still remains on the CPU. - a per-thread 'last_cpu' field, that indicates which CPU that thread used its FPU on last. We update this on every context switch (writing an invalid CPU number if the last context switch didn't leave the FPU in a lazily usable state), so we know that *that* thread has done nothing else with the FPU since. These two fields together can be used when next switching back to the task to see if the CPU still matches: if 'fpu_owner_task' matches the task we are switching to, we know that no other task (or kernel FPU usage) touched the FPU on this CPU in the meantime, and if the current CPU number matches the 'last_cpu' field, we know that this thread did no other FP work on any other CPU, so the FPU state on the CPU must match what was saved on last context switch. In that case, we can avoid the 'f[x]rstor' entirely, and just clear the CR0.TS bit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-20i387: use 'restore_fpu_checking()' directly in task switching codeLinus Torvalds
This inlines what is usually just a couple of instructions, but more importantly it also fixes the theoretical error case (can that FPU restore really ever fail? Maybe we should remove the checking). We can't start sending signals from within the scheduler, we're much too deep in the kernel and are holding the runqueue lock etc. So don't bother even trying. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-20i387: fix up some fpu_counter confusionLinus Torvalds
This makes sure we clear the FPU usage counter for newly created tasks, just so that we start off in a known state (for example, don't try to preload the FPU state on the first task switch etc). It also fixes a thinko in when we increment the fpu_counter at task switch time, introduced by commit 34ddc81a230b ("i387: re-introduce FPU state preloading at context switch time"). We should increment the *new* task fpu_counter, not the old task, and only if we decide to use that state (whether lazily or preloaded). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-18Merge tag 'fixes-3.3-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc These are the bug fixes that have accumulated since 3.3-rc3 in arm-soc. The majority of them are regression fixes for stuff that broke during the merge 3.3 window. The notable ones are: * The at91 ata drivers both broke because of an earlier cleanup patch that some other patches were based on. Jean-Christophe decided to remove the legacy at91_ide driver and fix the new-style at91-pata driver while keeping the cleanup patch. I almost rejected the patches for being too late and too big but in the end decided to accept them because they fix a regression. * A patch fixing build breakage from the sysdev-to-device conversion colliding with other changes touches a number of mach-s3c files. * b0654037 "ARM: orion: Fix Orion5x GPIO regression from MPP cleanup" is a mechanical change that unfortunately touches a lot of lines that should up in the diffstat. * tag 'fixes-3.3-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) ARM: at91: drop ide driver in favor of the pata one pata/at91: use newly introduced SMC accessors ARM: at91: add accessor to manage SMC ARM: at91:rtc/rtc-at91sam9: ioremap register bank ARM: at91: USB AT91 gadget registration for module ep93xx: fix build of vision_ep93xx.c ARM: OMAP2xxx: PM: fix OMAP2xxx-specific UART idle bug in v3.3 ARM: orion: Fix USB phy for orion5x. ARM: orion: Fix Orion5x GPIO regression from MPP cleanup ARM: EXYNOS: Add cpu-offset property in gic device tree node ARM: EXYNOS: Bring exynos4-dt up to date ARM: OMAP3: cm-t35: fix section mismatch warning ARM: OMAP2: Fix the OMAP2 only build break seen with 2011+ ARM tool-chains ARM: tegra: paz00: fix wrong UART port on mini-pcie plug ARM: tegra: paz00: fix wrong SD1 power gpio i2c: tegra: Add devexit_p() for remove ARM: EXYNOS: Correct M-5MOLS sensor clock frequency on Universal C210 board ARM: EXYNOS: Correct framebuffer window size on Nuri board ARM: SAMSUNG: Fix missing api-change from subsys_interface change ARM: EXYNOS: Fix "warning: initialization from incompatible pointer type" ...
2012-02-18Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Here are a few more fixes for powerpc. Some are regressions, the rest is simple/obvious/nasty enough that I deemed it good to go now. Here's also step one of deprecating legacy iSeries support: we are removing it from the main defconfig. Nobody seems to be using it anymore and the code is nasty to maintain, (involves horrible hacks in various low level areas of the kernel) so we plan to actually rip it out at some point. For now let's just avoid building it by default. Stephen will proceed to do the actual removal later (probably 3.4 or 3.5). * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/perf: power_pmu_start restores incorrect values, breaking frequency events powerpc/adb: Use set_current_state() powerpc: Disable interrupts early in Program Check powerpc: Remove legacy iSeries from ppc64_defconfig powerpc/fsl/pci: Fix PCIe fixup regression powerpc: Fix kernel log of oops/panic instruction dump
2012-02-18i387: re-introduce FPU state preloading at context switch timeLinus Torvalds
After all the FPU state cleanups and finally finding the problem that caused all our FPU save/restore problems, this re-introduces the preloading of FPU state that was removed in commit b3b0870ef3ff ("i387: do not preload FPU state at task switch time"). However, instead of simply reverting the removal, this reimplements preloading with several fixes, most notably - properly abstracted as a true FPU state switch, rather than as open-coded save and restore with various hacks. In particular, implementing it as a proper FPU state switch allows us to optimize the CR0.TS flag accesses: there is no reason to set the TS bit only to then almost immediately clear it again. CR0 accesses are quite slow and expensive, don't flip the bit back and forth for no good reason. - Make sure that the same model works for both x86-32 and x86-64, so that there are no gratuitous differences between the two due to the way they save and restore segment state differently due to architectural differences that really don't matter to the FPU state. - Avoid exposing the "preload" state to the context switch routines, and in particular allow the concept of lazy state restore: if nothing else has used the FPU in the meantime, and the process is still on the same CPU, we can avoid restoring state from memory entirely, just re-expose the state that is still in the FPU unit. That optimized lazy restore isn't actually implemented here, but the infrastructure is set up for it. Of course, older CPU's that use 'fnsave' to save the state cannot take advantage of this, since the state saving also trashes the state. In other words, there is now an actual _design_ to the FPU state saving, rather than just random historical baggage. Hopefully it's easier to follow as a result. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-18i387: move TS_USEDFPU flag from thread_info to task_structLinus Torvalds
This moves the bit that indicates whether a thread has ownership of the FPU from the TS_USEDFPU bit in thread_info->status to a word of its own (called 'has_fpu') in task_struct->thread.has_fpu. This fixes two independent bugs at the same time: - changing 'thread_info->status' from the scheduler causes nasty problems for the other users of that variable, since it is defined to be thread-synchronous (that's what the "TS_" part of the naming was supposed to indicate). So perfectly valid code could (and did) do ti->status |= TS_RESTORE_SIGMASK; and the compiler was free to do that as separate load, or and store instructions. Which can cause problems with preemption, since a task switch could happen in between, and change the TS_USEDFPU bit. The change to TS_USEDFPU would be overwritten by the final store. In practice, this seldom happened, though, because the 'status' field was seldom used more than once, so gcc would generally tend to generate code that used a read-modify-write instruction and thus happened to avoid this problem - RMW instructions are naturally low fat and preemption-safe. - On x86-32, the current_thread_info() pointer would, during interrupts and softirqs, point to a *copy* of the real thread_info, because x86-32 uses %esp to calculate the thread_info address, and thus the separate irq (and softirq) stacks would cause these kinds of odd thread_info copy aliases. This is normally not a problem, since interrupts aren't supposed to look at thread information anyway (what thread is running at interrupt time really isn't very well-defined), but it confused the heck out of irq_fpu_usable() and the code that tried to squirrel away the FPU state. (It also caused untold confusion for us poor kernel developers). It also turns out that using 'task_struct' is actually much more natural for most of the call sites that care about the FPU state, since they tend to work with the task struct for other reasons anyway (ie scheduling). And the FPU data that we are going to save/restore is found there too. Thanks to Arjan Van De Ven <arjan@linux.intel.com> for pointing us to the %esp issue. Cc: Arjan van de Ven <arjan@linux.intel.com> Reported-and-tested-by: Raphael Prevost <raphael@buro.asia> Acked-and-tested-by: Suresh Siddha <suresh.b.siddha@intel.com> Tested-by: Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-17[S390] correct ktime to tod clock comparator conversionMartin Schwidefsky
The conversion of the ktime to a value suitable for the clock comparator does not take changes to wall_to_monotonic into account. In fact the conversion just needs the boot clock (sched_clock_base_cc) and the total_sleep_time. This is applicable to 3.2+ kernels. CC: stable@vger.kernel.org Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-02-17[S390] incorrect PageTables counter for kvm page tablesMartin Schwidefsky
The page_table_free_pgste function is used for kvm processes to free page tables that have the pgste extension. It calls pgtable_page_ctor instead of pgtable_page_dtor which increases NR_PAGETABLE instead of decreasing it. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-02-17[S390] idle: avoid RCU usage in extended quiescent stateHeiko Carstens
Avoid calling wake_up() from our NMI "bottom halve" from RCU extended quiescent state in idle. wake_up() has RCU read-side critical sections but this will be completely ignored by RCU if the cpu is in extended quiescent state. Which means that whatever object is being accessed from within the read-side critical section can be freed concurrently from a different cpu. So make sure we leave extended quiescent state before calling wake_up(). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-02-16i387: move AMD K7/K8 fpu fxsave/fxrstor workaround from save to restoreLinus Torvalds
The AMD K7/K8 CPUs don't save/restore FDP/FIP/FOP unless an exception is pending. In order to not leak FIP state from one process to another, we need to do a floating point load after the fxsave of the old process, and before the fxrstor of the new FPU state. That resets the state to the (uninteresting) kernel load, rather than some potentially sensitive user information. We used to do this directly after the FPU state save, but that is actually very inconvenient, since it (a) corrupts what is potentially perfectly good FPU state that we might want to lazy avoid restoring later and (b) on x86-64 it resulted in a very annoying ordering constraint, where "__unlazy_fpu()" in the task switch needs to be delayed until after the DS segment has been reloaded just to get the new DS value. Coupling it to the fxrstor instead of the fxsave automatically avoids both of these issues, and also ensures that we only do it when actually necessary (the FP state after a save may never actually get used). It's simply a much more natural place for the leaked state cleanup. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-16i387: do not preload FPU state at task switch timeLinus Torvalds
Yes, taking the trap to re-load the FPU/MMX state is expensive, but so is spending several days looking for a bug in the state save/restore code. And the preload code has some rather subtle interactions with both paravirtualization support and segment state restore, so it's not nearly as simple as it should be. Also, now that we no longer necessarily depend on a single bit (ie TS_USEDFPU) for keeping track of the state of the FPU, we migth be able to do better. If we are really switching between two processes that keep touching the FP state, save/restore is inevitable, but in the case of having one process that does most of the FPU usage, we may actually be able to do much better than the preloading. In particular, we may be able to keep track of which CPU the process ran on last, and also per CPU keep track of which process' FP state that CPU has. For modern CPU's that don't destroy the FPU contents on save time, that would allow us to do a lazy restore by just re-enabling the existing FPU state - with no restore cost at all! Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-16i387: don't ever touch TS_USEDFPU directly, use helper functionsLinus Torvalds
This creates three helper functions that do the TS_USEDFPU accesses, and makes everybody that used to do it by hand use those helpers instead. In addition, there's a couple of helper functions for the "change both CR0.TS and TS_USEDFPU at the same time" case, and the places that do that together have been changed to use those. That means that we have fewer random places that open-code this situation. The intent is partly to clarify the code without actually changing any semantics yet (since we clearly still have some hard to reproduce bug in this area), but also to make it much easier to use another approach entirely to caching the CR0.TS bit for software accesses. Right now we use a bit in the thread-info 'status' variable (this patch does not change that), but we might want to make it a full field of its own or even make it a per-cpu variable. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-16i387: move TS_USEDFPU clearing out of __save_init_fpu and into callersLinus Torvalds
Touching TS_USEDFPU without touching CR0.TS is confusing, so don't do it. By moving it into the callers, we always do the TS_USEDFPU next to the CR0.TS accesses in the source code, and it's much easier to see how the two go hand in hand. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-16i387: fix x86-64 preemption-unsafe user stack save/restoreLinus Torvalds
Commit 5b1cbac37798 ("i387: make irq_fpu_usable() tests more robust") added a sanity check to the #NM handler to verify that we never cause the "Device Not Available" exception in kernel mode. However, that check actually pinpointed a (fundamental) race where we do cause that exception as part of the signal stack FPU state save/restore code. Because we use the floating point instructions themselves to save and restore state directly from user mode, we cannot do that atomically with testing the TS_USEDFPU bit: the user mode access itself may cause a page fault, which causes a task switch, which saves and restores the FP/MMX state from the kernel buffers. This kind of "recursive" FP state save is fine per se, but it means that when the signal stack save/restore gets restarted, it will now take the '#NM' exception we originally tried to avoid. With preemption this can happen even without the page fault - but because of the user access, we cannot just disable preemption around the save/restore instruction. There are various ways to solve this, including using the "enable/disable_page_fault()" helpers to not allow page faults at all during the sequence, and fall back to copying things by hand without the use of the native FP state save/restore instructions. However, the simplest thing to do is to just allow the #NM from kernel space, but fix the race in setting and clearing CR0.TS that this all exposed: the TS bit changes and the TS_USEDFPU bit absolutely have to be atomic wrt scheduling, so while the actual state save/restore can be interrupted and restarted, the act of actually clearing/setting CR0.TS and the TS_USEDFPU bit together must not. Instead of just adding random "preempt_disable/enable()" calls to what is already excessively ugly code, this introduces some helper functions that mostly mirror the "kernel_fpu_begin/end()" functionality, just for the user state instead. Those helper functions should probably eventually replace the other ad-hoc CR0.TS and TS_USEDFPU tests too, but I'll need to think about it some more: the task switching functionality in particular needs to expose the difference between the 'prev' and 'next' threads, while the new helper functions intentionally were written to only work with 'current'. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-16powerpc/perf: power_pmu_start restores incorrect values, breaking frequency ↵Anton Blanchard
events perf on POWER stopped working after commit e050e3f0a71b (perf: Fix broken interrupt rate throttling). That patch exposed a bug in the POWER perf_events code. Since the PMCs count upwards and take an exception when the top bit is set, we want to write 0x80000000 - left in power_pmu_start. We were instead programming in left which effectively disables the counter until we eventually hit 0x80000000. This could take seconds or longer. With the patch applied I get the expected number of samples: SAMPLE events: 9948 Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org>
2012-02-16powerpc: Disable interrupts early in Program CheckBenjamin Herrenschmidt
Program Check exceptions are the result of WARNs, BUGs, some type of breakpoints, kprobe, and other illegal instructions. We want interrupts (and thus preemption) to remain disabled while doing the initial stage of testing the reason and branching off to a debugger or kprobe, so we are still on the original CPU which makes debugging easier in various cases. This is how the code was intended, hence the local_irq_enable() right in the middle of program_check_exception(). However, the assembly exception prologue for that exception was incorrectly marked as enabling interrupts, which defeats that (and records a redundant enable with lockdep). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-16powerpc: Remove legacy iSeries from ppc64_defconfigStephen Rothwell
Since we are heading towards removing the Legacy iSeries platform, start by no longer building it for ppc64_defconfig. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-16powerpc/fsl/pci: Fix PCIe fixup regressionBenjamin Herrenschmidt
Upstream changes to the way PHB resources are registered broke the resource fixup for FSL boards. We can no longer rely on the resource pointer array for the PHB's pci_bus structure, so let's leave it alone and go straight for the PHB resources instead. This also makes the code generally more readable. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-16powerpc: Fix kernel log of oops/panic instruction dumpIra Snyder
A kernel oops/panic prints an instruction dump showing several instructions before and after the instruction which caused the oops/panic. The code intended that the faulting instruction be enclosed in angle brackets, however a bug caused the faulting instruction to be interpreted by printk() as the message log level. To fix this, the KERN_CONT log level is added before the actual text of the printed message. === Before the patch === [ 1081.587266] Instruction dump: [ 1081.590236] 7c000110 7c0000f8 5400077c 552907f6 7d290378 992b0003 4e800020 38000001 [ 1081.598034] 3d20c03a 9009a114 7c0004ac 39200000 [ 1081.602500] 4e800020 3803ffd0 2b800009 <4>[ 1081.587266] Instruction dump: <4>[ 1081.590236] 7c000110 7c0000f8 5400077c 552907f6 7d290378 992b0003 4e800020 38000001 <4>[ 1081.598034] 3d20c03a 9009a114 7c0004ac 39200000 <98090000>[ 1081.602500] 4e800020 3803ffd0 2b800009 === After the patch === [ 51.385216] Instruction dump: [ 51.388186] 7c000110 7c0000f8 5400077c 552907f6 7d290378 992b0003 4e800020 38000001 [ 51.395986] 3d20c03a 9009a114 7c0004ac 39200000 <98090000> 4e800020 3803ffd0 2b800009 <4>[ 51.385216] Instruction dump: <4>[ 51.388186] 7c000110 7c0000f8 5400077c 552907f6 7d290378 992b0003 4e800020 38000001 <4>[ 51.395986] 3d20c03a 9009a114 7c0004ac 39200000 <98090000> 4e800020 3803ffd0 2b800009 Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-15ARM: 7327/1: need to include asm/system.h in asm/processor.hOlof Johansson
For files that include asm/processor.h but not asm/system.h: arch/arm/mach-msm/include/mach/uncompress.h: In function 'putc': arch/arm/mach-msm/include/mach/uncompress.h:48:3: error: implicit declaration of function 'smp_mb' [-Werror=implicit-function-declaration] In this case, smp_mb() is from the cpu_relax() call in the msm putc(). It likely went uncaught when the uncompress.h change went in since the defconfig didn't enable that code path, but later changes (e76f4750f4: ARM: debug: arrange Kconfig options more logically) resulted in the option being on for msm_defconfig and thus exposed it. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-15ARM: 7326/2: PL330: fix null pointer dereference in pl330_chan_ctrl()Javi Merino
This fixes the thrd->req_running field being accessed before thrd is checked for null. The error was introduced in abb959f: ARM: 7237/1: PL330: Fix driver freeze Reference: <1326458191-23492-1-git-send-email-mans.rullgard@linaro.org> Cc: stable@kernel.org Signed-off-by: Mans Rullgard <mans.rullgard@linaro.org> Acked-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-15ARM: 7164/3: PL330: Fix the size of the dst_cache_ctrl fieldJavi Merino
dst_cache_ctrl affects bits 3, 1 and 0 of AWCACHE but it is a 3-bit field in the Channel Control Register (see Table 3-21 of the DMA-330 Technical Reference Manual) and should be programmed as such. Reference: <1320244259-10496-3-git-send-email-javi.merino@arm.com> Signed-off-by: Javi Merino <javi.merino@arm.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-15ARM: 7325/1: fix v7 boot with lockdep enabledRabin Vincent
Bootup with lockdep enabled has been broken on v7 since b46c0f74657d ("ARM: 7321/1: cache-v7: Disable preemption when reading CCSIDR"). This is because v7_setup (which is called very early during boot) calls v7_flush_dcache_all, and the save_and_disable_irqs added by that patch ends up attempting to call into lockdep C code (trace_hardirqs_off()) when we are in no position to execute it (no stack, MMU off). Fix this by using a notrace variant of save_and_disable_irqs. The code already uses the notrace variant of restore_irqs. Reviewed-by: Nicolas Pitre <nico@linaro.org> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-15i387: fix sense of sanity checkLinus Torvalds
The check for save_init_fpu() (introduced in commit 5b1cbac37798: "i387: make irq_fpu_usable() tests more robust") was the wrong way around, but I hadn't noticed, because my "tests" were bogus: the FPU exceptions are disabled by default, so even doing a divide by zero never actually triggers this code at all unless you do extra work to enable them. So if anybody did enable them, they'd get one spurious warning. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-15ARM: 7323/1: Do not allow ARM_LPAE on pre-ARMv7 architecturesCatalin Marinas
This patch expands the Kconfig dependencies for ARM_LPAE to not allow enabling when architectures other than ARMv7 are built into the kernel. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
