[ Upstream commit 093758e3daede29cb4ce6aedb111becf9d4bfc57 ]
This commit is a guesswork, but it seems to make sense to drop this
break, as otherwise the following line is never executed and becomes
dead code. And that following line actually saves the result of
local calculation by the pointer given in function argument. So the
proposed change makes sense if this code in the whole makes sense (but I
am unable to analyze it in the whole).
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81641
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
[ Upstream commit 4ec1b01029b4facb651b8ef70bc20a4be4cebc63 ]
The LDC handshake could have been asynchronously triggered
after ldc_bind() enables the ldc_rx() receive interrupt-handler
(and thus intercepts incoming control packets)
and before vio_port_up() calls ldc_connect(). If that is the case,
ldc_connect() should return 0 and let the state-machine
progress.
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Acked-by: Karl Volz <karl.volz@oracle.com>
[ Upstream commit 4ca9a23765da3260058db3431faf5b4efd8cf926 ]
Based almost entirely upon a patch by Christopher Alexander Tobias
Schulze.
In commit db64fe02258f1507e13fe5212a989922323685ce ("mm: rewrite vmap
layer") lazy VMAP tlb flushing was added to the vmalloc layer. This
causes problems on sparc64.
Sparc64 has two VMAP mapped regions and they are not contiguous with
eachother. First we have the malloc mapping area, then another
unrelated region, then the vmalloc region.
This "another unrelated region" is where the firmware is mapped.
If the lazy TLB flushing logic in the vmalloc code triggers after
we've had both a module unload and a vfree or similar, it will pass an
address range that goes from somewhere inside the malloc region to
somewhere inside the vmalloc region, and thus covering the
openfirmware area entirely.
The sparc64 kernel learns about openfirmware's dynamic mappings in
this region early in the boot, and then services TLB misses in this
area. But openfirmware has some locked TLB entries which are not
mentioned in those dynamic mappings and we should thus not disturb
them.
These huge lazy TLB flush ranges causes those openfirmware locked TLB
entries to be removed, resulting in all kinds of problems including
hard hangs and crashes during reboot/reset.
Besides causing problems like this, such huge TLB flush ranges are
also incredibly inefficient. A plea has been made with the author of
the VMAP lazy TLB flushing code, but for now we'll put a safety guard
into our flush_tlb_kernel_range() implementation.
Since the implementation has become non-trivial, stop defining it as a
macro and instead make it a function in a C source file.
[ Upstream commit 18f38132528c3e603c66ea464727b29e9bbcb91b ]
The assumption was that update_mmu_cache() (and the equivalent for PMDs) would
only be called when the PTE being installed will be accessible by the user.
This is not true for code paths originating from remove_migration_pte().
There are dire consequences for placing a non-valid PTE into the TSB. The TLB
miss frramework assumes thatwhen a TSB entry matches we can just load it into
the TLB and return from the TLB miss trap.
So if a non-valid PTE is in there, we will deadlock taking the TLB miss over
and over, never satisfying the miss.
Just exit early from update_mmu_cache() and friends in this situation.
Based upon a report and patch from Christopher Alexander Tobias Schulze.
[ Upstream commit 5aa4ecfd0ddb1e6dcd1c886e6c49677550f581aa ]
This is the prevent previous stores from overlapping the block stores
done by the memcpy loop.
Based upon a glibc patch by Jose E. Marchesi
[ Upstream commit b18eb2d779240631a098626cb6841ee2dd34fda0 ]
Access to the TSB hash tables during TLB misses requires that there be
an atomic 128-bit quad load available so that we fetch a matching TAG
and DATA field at the same time.
On cpus prior to UltraSPARC-III only virtual address based quad loads
are available. UltraSPARC-III and later provide physical address
based variants which are easier to use.
When we only have virtual address based quad loads available this
means that we have to lock the TSB into the TLB at a fixed virtual
address on each cpu when it runs that process. We can't just access
the PAGE_OFFSET based aliased mapping of these TSBs because we cannot
take a recursive TLB miss inside of the TLB miss handler without
risking running out of hardware trap levels (some trap combinations
can be deep, such as those generated by register window spill and fill
traps).
Without huge pages it's working perfectly fine, but when the huge TSB
got added another chunk of fixed virtual address space was not
allocated for this second TSB mapping.
So we were mapping both the 8K and 4MB TSBs to the same exact virtual
address, causing multiple TLB matches which gives undefined behavior.
addresses.
[ Upstream commit e5c460f46ae7ee94831cb55cb980f942aa9e5a85 ]
This was found using Dave Jone's trinity tool.
When a user process which is 32-bit performs a load or a store, the
cpu chops off the top 32-bits of the effective address before
translating it.
This is because we run 32-bit tasks with the PSTATE_AM (address
masking) bit set.
We can't run the kernel with that bit set, so when the kernel accesses
userspace no address masking occurs.
Since a 32-bit process will have no mappings in that region we will
properly fault, so we don't try to handle this using access_ok(),
which can safely just be a NOP on sparc64.
Real faults from 32-bit processes should never generate such addresses
so a bug check was added long ago, and it barks in the logs if this
happens.
But it also barks when a kernel user access causes this condition, and
that _can_ happen. For example, if a pointer passed into a system call
is "0xfffffffc" and the kernel access 4 bytes offset from that pointer.
Just handle such faults normally via the exception entries.
[ Upstream commit 70ffc6ebaead783ac8dafb1e87df0039bb043596 ]
Make get_user_insn() able to cope with huge PMDs.
Next, make do_fault_siginfo() more robust when get_user_insn() can't
actually fetch the instruction. In particular, use the MMU announced
fault address when that happens, instead of calling
compute_effective_address() and computing garbage.
[ Upstream commit d037d16372bbe4d580342bebbb8826821ad9edf0 ]
If we have a 32-bit task we must chop off the top 32-bits of the
64-bit value just as the cpu would.
[ Upstream commit 49b6c01f4c1de3b5e5427ac5aba80f9f6d27837a ]
One more place where we must not be able
to be preempted or to be interrupted in RT.
Always actually disable interrupts during
synchronization cycle.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
[ Upstream commit aa3449ee9c87d9b7660dd1493248abcc57769e31 ]
Only the second argument, 'op', is signed.
commit 8762e5092828c4dc0f49da5a47a644c670df77f3 upstream.
init_espfix_ap() is currently off by one level when informing hypervisor
that allocated pages will be used for ministacks' page tables.
The most immediate effect of this on a PV guest is that if
'stack_page = __get_free_page()' returns a non-zeroed-out page the hypervisor
will refuse to use it for a page table (which it shouldn't be anyway). This will
result in warnings by both Xen and Linux.
More importantly, a subsequent write to that page (again, by a PV guest) is
likely to result in fatal page fault.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/1404926298-5565-1-git-send-email-boris.ostrovsky@oracle.com
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 7209a75d2009dbf7745e2fd354abf25c3deb3ca3 upstream.
This moves the espfix64 logic into native_iret. To make this work,
it gets rid of the native patch for INTERRUPT_RETURN:
INTERRUPT_RETURN on native kernels is now 'jmp native_iret'.
This changes the 16-bit SS behavior on Xen from OOPSing to leaking
some bits of the Xen hypervisor's RSP (I think).
[ hpa: this is a nonzero cost on native, but probably not enough to
measure. Xen needs to fix this in their own code, probably doing
something equivalent to espfix64. ]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/7b8f1d8ef6597cb16ae004a43c56980a7de3cf94.1406129132.git.luto@amacapital.net
commit 34273f41d57ee8d854dcd2a1d754cbb546cb548f upstream.
Embedded systems, which may be very memory-size-sensitive, are
extremely unlikely to ever encounter any 16-bit software, so make it
a CONFIG_EXPERT option to turn off support for any 16-bit software
whatsoever.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
commit 197725de65477bc8509b41388157c1a2283542bb upstream.
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML
build which had broken due to the non-existence of init_espfix_bsp()
in UML: since UML uses its own Kconfig, this option does not appear in
the UML build.
This also makes it possible to make support for 16-bit segments a
configuration option, for the people who want to minimize the size of
the kernel.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Richard Weinberger <richard@nod.at>
commit 20b68535cd27183ebd3651ff313afb2b97dac941 upstream.
Header guard is #ifndef, not #ifdef...
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit e1fe9ed8d2a4937510d0d60e20705035c2609aea upstream.
Sparse warns that the percpu variables aren't declared before they are
defined. Rather than hacking around it, move espfix definitions into
a proper header file.
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream.
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 7ed6fb9b5a5510e4ef78ab27419184741169978a upstream.
This reverts commit fa81511bb0bbb2b1aace3695ce869da9762624ff in
preparation of merging in the proper fix (espfix64).
commit 811a2407a3cf7bbd027fbe92d73416f17485a3d8 upstream.
On LPAE, each level 1 (pgd) page table entry maps 1GiB, and the level 2
(pmd) entries map 2MiB.
When the identity mapping is created on LPAE, the pgd pointers are copied
from the swapper_pg_dir. If we find that we need to modify the contents
of a pmd, we allocate a new empty pmd table and insert it into the
appropriate 1GB slot, before then filling it with the identity mapping.
However, if the 1GB slot covers the kernel lowmem mappings, we obliterate
those mappings.
When replacing a PMD, first copy the old PMD contents to the new PMD, so
that we preserve the existing mappings, particularly the mappings of the
kernel itself.
[rewrote commit message and added code comment -- rmk]
Fixes: ae2de101739c ("ARM: LPAE: Add identity mapping support for the 3-level page table format")
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
commit c7fb93ec51d462ec3540a729ba446663c26a0505 upstream.
The PE/COFF headers currently describe only the initialised-data
portions of the image, and result in no space being allocated for the
uninitialised-data portions. Consequently, the EFI boot stub will end
up overwriting unexpected areas of memory, with unpredictable results.
Fix by including a .bss section in the PE/COFF headers (functionally
equivalent to the init_size field in the bzImage header).
Signed-off-by: Michael Brown <mbrown@fensystems.co.uk>
Cc: Thomas Bächler <thomas@archlinux.org>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit dab6cf55f81a6e16b8147aed9a843e1691dcd318 upstream.
The PSW mask check of the PTRACE_POKEUSR_AREA command is incorrect.
The PSW_MASK_USER define contains the PSW_MASK_ASC bits, the ptrace
interface accepts all combinations for the address-space-control
bits. To protect the kernel space the PSW mask check in ptrace needs
to reject the address-space-control bit combination for home space.
Fixes CVE-2014-3534
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 8142b215501f8b291a108a202b3a053a265b03dd upstream.
Commit 554086d ("x86_32, entry: Do syscall exit work on badsys
(CVE-2014-4508)") introduced a regression in the x86_32 syscall entry
code, resulting in syscall() not returning proper errors for undefined
syscalls on CPUs supporting the sysenter feature.
The following code:
> int result = syscall(666);
> printf("result=%d errno=%d error=%s\n", result, errno, strerror(errno));
results in:
> result=666 errno=0 error=Success
Obviously, the syscall return value is the called syscall number, but it
should have been an ENOSYS error. When run under ptrace it behaves
correctly, which makes it hard to debug in the wild:
> result=-1 errno=38 error=Function not implemented
The %eax register is the return value register. For debugging via ptrace
the syscall entry code stores the complete register context on the
stack. The badsys handlers only store the ENOSYS error code in the
ptrace register set and do not set %eax like a regular syscall handler
would. The old resume_userspace call chain contains code that clobbers
%eax and it restores %eax from the ptrace registers afterwards. The same
goes for the ptrace-enabled call chain. When ptrace is not used, the
syscall return value is the passed-in syscall number from the untouched
%eax register.
Use %eax as the return value register in syscall_badsys and
sysenter_badsys, like a real syscall handler does, and have the caller
push the value onto the stack for ptrace access.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Link: http://lkml.kernel.org/r/alpine.LNX.2.11.1407221022380.31021@titan.int.lan.stealer.net
Reviewed-and-tested-by: Andy Lutomirski <luto@amacapital.net>
commit 20dbea494543aefaace874cc3ec93a39b94b1ec4 upstream.
The sa_restorer field in struct sigaction is obsolete and no longer in
the parisc implementation. However, the core code assumes the field is
present if SA_RESTORER is defined. So, the define needs to be removed.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit a4b6cb735b25aa84a462a1985e3e43bebaf5beb4 upstream.
This patch adds implementation of GET_THREAD_AREA ptrace request type. This
is required by GDB to debug NPTL applications.
Signed-off-by: Anton Kolesov <Anton.Kolesov@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc upstream.
The optimistic spin code assumes regular stores and cmpxchg() play nice;
this is found to not be true for at least: parisc, sparc32, tile32,
metag-lock1, arc-!llsc and hexagon.
There is further wreckage, but this in particular seemed easy to
trigger, so blacklist this.
Opt in for known good archs.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net
commit b292d7a10487aee6e74b1c18b8d95b92f40d4a4f upstream.
Currently, any NMI is falsely handled by a NMI handler of NMI watchdog
if CondChgd bit in MSR_CORE_PERF_GLOBAL_STATUS MSR is set.
For example, we use external NMI to make system panic to get crash
dump, but in this case, the external NMI is falsely handled do to the
issue.
This commit deals with the issue simply by ignoring CondChgd bit.
Here is explanation in detail.
On x86 NMI watchdog uses performance monitoring feature to
periodically signal NMI each time performance counter gets overflowed.
intel_pmu_handle_irq() is called as a NMI_LOCAL handler from a NMI
handler of NMI watchdog, perf_event_nmi_handler(). It identifies an
owner of a given NMI by looking at overflow status bits in
MSR_CORE_PERF_GLOBAL_STATUS MSR. If some of the bits are set, then it
handles the given NMI as its own NMI.
The problem is that the intel_pmu_handle_irq() doesn't distinguish
CondChgd bit from other bits. Unlike the other status bits, CondChgd
bit doesn't represent overflow status for performance counters. Thus,
CondChgd bit cannot be thought of as a mark indicating a given NMI is
NMI watchdog's.
As a result, if CondChgd bit is set, any NMI is falsely handled by the
NMI handler of NMI watchdog. Also, if type of the falsely handled NMI
is either NMI_UNKNOWN, NMI_SERR or NMI_IO_CHECK, the corresponding
action is never performed until CondChgd bit is cleared.
I noticed this behavior on systems with Ivy Bridge processors: Intel
Xeon CPU E5-2630 v2 and Intel Xeon CPU E7-8890 v2. On both systems,
CondChgd bit in MSR_CORE_PERF_GLOBAL_STATUS MSR has already been set
in the beginning at boot. Then the CondChgd bit is immediately cleared
by next wrmsr to MSR_CORE_PERF_GLOBAL_CTRL MSR and appears to remain
0.
On the other hand, on older processors such as Nehalem, Xeon E7540,
CondChgd bit is not set in the beginning at boot.
I'm not sure about exact behavior of CondChgd bit, in particular when
this bit is set. Although I read Intel System Programmer's Manual to
figure out that, the descriptions I found are:
In 18.9.1:
"The MSR_PERF_GLOBAL_STATUS MSR also provides a ¡sticky bit¢ to
indicate changes to the state of performancmonitoring hardware"
In Table 35-2 IA-32 Architectural MSRs
63 CondChg: status bits of this register has changed.
These are different from the bahviour I see on the actual system as I
explained above.
At least, I think ignoring CondChgd bit should be enough for NMI
watchdog perspective.
Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20140625.103503.409316067.d.hatayama@jp.fujitsu.com
commit c81c8a1eeede61e92a15103748c23d100880cc8a upstream.
In __ioremap_caller() (the guts of ioremap), we loop over the range of
pfns being remapped and checks each one individually with page_is_ram().
For large ioremaps, this can be very slow. For example, we have a
device with a 256 GiB PCI BAR, and ioremapping this BAR can take 20+
seconds -- sometimes long enough to trigger the soft lockup detector!
Internally, page_is_ram() calls walk_system_ram_range() on a single
page. Instead, we can make a single call to walk_system_ram_range()
from __ioremap_caller(), and do our further checks only for any RAM
pages that we find. For the common case of MMIO, this saves an enormous
amount of work, since the range being ioremapped doesn't intersect
system RAM at all.
With this change, ioremap on our 256 GiB BAR takes less than 1 second.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Link: http://lkml.kernel.org/r/1399054721-1331-1-git-send-email-roland@kernel.org
commit df9e4d1c39c472cb44d81ab2ed2db503fc486e3b upstream.
Signed-off-by: Lennox Wu <lennox.wu@gmail.com>
commit 5fbbf8a1a93452b26e7791cf32cefce62b0a480b upstream.
The modifications include:
1. Kconfig of Score: we don't support ioremap
2. Missed headfile including
3. There are some errors in other people's commit not checked by us, we fix it now
3.1 arch/score/kernel/entry.S: wrong instructions
3.2 arch/score/kernel/process.c : just some typos
commit 1ed62ca648557b884d117a4a8bbcf2ae4e2d1153 upstream.
commit ae49b83dcacfb69e22092cab688c415c2f2d870c upstream.
Generate mandatory global variables _sdata in file vmlinux.lds.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
commit fa2ec3ea10bd377f9d55772b1dab65178425a1a2 upstream.
include/linux/sched.h implements TASK_SIZE_OF as TASK_SIZE if it
is not set by the architecture headers. TASK_SIZE uses the
current task to determine the size of the virtual address space.
On a 64-bit kernel this will cause reading /proc/pid/pagemap of a
64-bit process from a 32-bit process to return EOF when it reads
past 0xffffffff.
Implement TASK_SIZE_OF exactly the same as TASK_SIZE with
test_tsk_thread_flag instead of test_thread_flag.
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Will Deacon <will.deacon@arm.com>
commit cfe82d4f45c7cc39332a2be7c4c1d3bf279bbd3d upstream.
Byte-to-bit-count computation is only partly converted to big-endian and is
mixing in CPU-endian values. Problem was noticed by sparce with warning:
CHECK arch/x86/crypto/sha512_ssse3_glue.c
arch/x86/crypto/sha512_ssse3_glue.c:144:19: warning: restricted __be64 degrades to integer
arch/x86/crypto/sha512_ssse3_glue.c:144:17: warning: incorrect type in assignment (different base types)
arch/x86/crypto/sha512_ssse3_glue.c:144:17: expected restricted __be64 <noident>
arch/x86/crypto/sha512_ssse3_glue.c:144:17: got unsigned long long
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Acked-by: Tim Chen <tim.c.chen@linux.intel.com>
commit b50a6c584bb47b370f84bfd746770c0bbe7129b7 upstream.
On POWER8 when switching to a KVM guest we set bits in MMCR2 to freeze
the PMU counters. Aside from on boot they are then never reset,
resulting in stuck perf counters for any user in the guest or host.
We now set MMCR2 to 0 whenever enabling the PMU, which provides a sane
state for perf to use the PMU counters under either the guest or the
host.
This was manifesting as a bug with ppc64_cpu --frequency:
$ sudo ppc64_cpu --frequency
WARNING: couldn't run on cpu 0
WARNING: couldn't run on cpu 8
WARNING: couldn't run on cpu 144
WARNING: couldn't run on cpu 152
min: 18446744073.710 GHz (cpu -1)
max: 0.000 GHz (cpu -1)
avg: 0.000 GHz
The command uses a perf counter to measure CPU cycles over a fixed
amount of time, in order to approximate the frequency of the machine.
The counters were returning zero once a guest was started, regardless of
weather it was still running or had been shut down.
By dumping the value of MMCR2, it was observed that once a guest is
running MMCR2 is set to 1s - which stops counters from running:
$ sudo sh -c 'echo p > /proc/sysrq-trigger'
CPU: 0 PMU registers, ppmu = POWER8 n_counters = 6
PMC1: 5b635e38 PMC2: 00000000 PMC3: 00000000 PMC4: 00000000
PMC5: 1bf5a646 PMC6: 5793d378 PMC7: deadbeef PMC8: deadbeef
MMCR0: 0000000080000000 MMCR1: 000000001e000000 MMCRA: 0000040000000000
MMCR2: fffffffffffffc00 EBBHR: 0000000000000000
EBBRR: 0000000000000000 BESCR: 0000000000000000
SIAR: 00000000000a51cc SDAR: c00000000fc40000 SIER: 0000000001000000
This is done unconditionally in book3s_hv_interrupts.S upon entering the
guest, and the original value is only save/restored if the host has
indicated it was using the PMU. This is okay, however the user of the
PMU needs to ensure that it is in a defined state when it starts using
it.
Fixes: e05b9b9e5c10 ("powerpc/perf: Power8 PMU support")
Signed-off-by: Joel Stanley <joel@jms.id.au>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
commit 4d9690dd56b0d18f2af8a9d4a279cb205aae3345 upstream.
Instead of separate bits for every POWER8 PMU feature, have a single one
for v2.07 of the architecture.
This saves us adding a MMCR2 define for a future patch.
commit f56029410a13cae3652d1f34788045c40a13ffc7 upstream.
We are seeing a lot of PMU warnings on POWER8:
Can't find PMC that caused IRQ
Looking closer, the active PMC is 0 at this point and we took a PMU
exception on the transition from negative to 0. Some versions of POWER8
have an issue where they edge detect and not level detect PMC overflows.
A number of places program the PMC with (0x80000000 - period_left),
where period_left can be negative. We can either fix all of these or
just ensure that period_left is always >= 1.
This patch takes the second option.
commit eadcc7208a2237016be7bdff4551ba7614da85c8 upstream.
commit 1ff38c56cbd095c4c0dfa581a859ba3557830f78 upstream.
Need include "asm/pgtable.h" to include "asm-generic/pgtable-nopmd.h",
so can let 'pmd_t' defined. The related error with allmodconfig:
CC arch/unicore32/mm/alignment.o
In file included from arch/unicore32/mm/alignment.c:24:
arch/unicore32/include/asm/tlbflush.h:135: error: expected .). before .*. token
arch/unicore32/include/asm/tlbflush.h:154: error: expected .). before .*. token
In file included from arch/unicore32/mm/alignment.c:27:
arch/unicore32/mm/mm.h:15: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token
arch/unicore32/mm/mm.h:20: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token
arch/unicore32/mm/mm.h:25: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token
make[1]: *** [arch/unicore32/mm/alignment.o] Error 1
make: *** [arch/unicore32/mm] Error 2
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Acked-by: Xuetao Guan <gxt@mprc.pku.edu.cn>
Signed-off-by: Xuetao Guan <gxt@mprc.pku.edu.cn>
commit 7cb060a91c0efc5ff94f83c6df3ed705e143cdb9 upstream.
KVM does not really do much with the PAT, so this went unnoticed for a
long time. It is exposed however if you try to do rdmsr on the PAT
register.
Reported-by: Valentine Sinitsyn <valentine.sinitsyn@gmail.com>
commit 682367c494869008eb89ef733f196e99415ae862 upstream.
Recent Intel CPUs have 10 variable range MTRRs. Since operating systems
sometime make assumptions on CPUs while they ignore capability MSRs, it is
better for KVM to be consistent with recent CPUs. Reporting more MTRRs than
actually supported has no functional implications.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit 3906c2b53cd23c2ae03e6ce41432c8e7f0a3cbbb upstream.
The value of ESR has been stored into x1, and should be directly pass to
do_sp_pc_abort function, "MOV x1, x25" is an extra operation and do_sp_pc_abort
will get the wrong value of ESR.
Signed-off-by: ChiaHao <andy.jhshiu@gmail.com>
Cc: <stable@vger.kernel.org>
commit c021f241f4fab2bb4fc4120a38a828a03dd3f970 upstream.
Fix a parser-bug in the omap2 muxing code where muxtable-entries will be
wrongly selected if the requested muxname is a *prefix* of their
m0-entry and they have a matching mN-entry. Fix by additionally checking
that the length of the m0_entry is equal.
For example muxing of "dss_data2.dss_data2" on omap32xx will fail
because the prefix "dss_data2" will match the mux-entries "dss_data2" as
well as "dss_data20", with the suffix "dss_data2" matching m0 (for
dss_data2) and m4 (for dss_data20). Thus both are recognized as signal
path candidates:
Relevant muxentries from mux34xx.c:
_OMAP3_MUXENTRY(DSS_DATA20, 90,
"dss_data20", NULL, "mcspi3_somi", "dss_data2",
"gpio_90", NULL, NULL, "safe_mode"),
_OMAP3_MUXENTRY(DSS_DATA2, 72,
"dss_data2", NULL, NULL, NULL,
"gpio_72", NULL, NULL, "safe_mode"),
This will result in a failure to mux the pin at all:
_omap_mux_get_by_name: Multiple signal paths (2) for dss_data2.dss_data2
Patch should apply to linus' latest master down to rather old linux-2.6
trees.
Signed-off-by: David R. Piegdon <lkml@p23q.org>
Cc: stable@vger.kernel.org
[tony@atomide.com: updated description to include full description]
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream.
The 'sysret' fastpath does not correctly restore even all regular
registers, much less any segment registers or reflags values. That is
very much part of why it's faster than 'iret'.
Normally that isn't a problem, because the normal ptrace() interface
catches the process using the signal handler infrastructure, which
always returns with an iret.
However, some paths can get caught using ptrace_event() instead of the
signal path, and for those we need to make sure that we aren't going to
return to user space using 'sysret'. Otherwise the modifications that
may have been done to the register set by the tracer wouldn't
necessarily take effect.
Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from
arch_ptrace_stop_needed() which is invoked from ptrace_stop().
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 8c9eb041cf76038eb3b62ee259607eec9b89f48d upstream.
kvm_arch_vcpu_free() is called in 2 code paths:
1) kvm_vm_ioctl()
kvm_vm_ioctl_create_vcpu()
kvm_arch_vcpu_destroy()
2) kvm_put_kvm()
kvm_destroy_vm()
kvm_arch_destroy_vm()
kvm_mips_free_vcpus()
Neither of the paths handles VCPU free. We need to do it in
kvm_arch_vcpu_free() corresponding to the memory allocation in
kvm_arch_vcpu_create().
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
commit c6c0a6637f9da54f9472144d44f71cf847f92e20 upstream.
The kfree() function already NULL checks the parameter so remove the
redundant NULL checks before kfree() calls in arch/mips/kvm/.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: Sanjay Lal <sanjayl@kymasys.com>
commit dd58a092c4202f2bd490adab7285b3ff77f8e467 upstream.
The Vector Crypto category instructions are supported by current POWER8
chips, advertise them to userspace using a specific bit to properly
differentiate with chips of the same architecture level that might not
have them.
commit b69a1da94f3d1589d1942b5d1b384d8cfaac4500 upstream.
Commit cd64d1697cf0 ("powerpc: mtmsrd not defined") added a check for
CONFIG_PPC_CPU were a check for CONFIG_PPC_FPU was clearly intended.
Fixes: cd64d1697cf0 ("powerpc: mtmsrd not defined")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit 6e0fdf9af216887e0032c19d276889aad41cad00 upstream.
Commit b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling
perf_event_do_pending") added a check for CONFIG_PMAC were a check for
CONFIG_PPC_PMAC was clearly intended.
Fixes: b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling perf_event_do_pending")
commit 5d73320a96fcce80286f1447864c481b5f0b96fa upstream.
commit 8f9c0119d7ba (compat: fs: Generic compat_sys_sendfile
implementation) changed the PowerPC 64bit sendfile call from
sys_sendile64 to sys_sendfile.
Unfortunately this broke sendfile of lengths greater than 2G because
sys_sendfile caps at MAX_NON_LFS. Restore what we had previously which
fixes the bug.
