commit a4866aa812518ed1a37d8ea0c881dc946409de94 upstream.
Under CONFIG_STRICT_DEVMEM, reading System RAM through /dev/mem is
disallowed. However, on x86, the first 1MB was always allowed for BIOS
and similar things, regardless of it actually being System RAM. It was
possible for heap to end up getting allocated in low 1MB RAM, and then
read by things like x86info or dd, which would trip hardened usercopy:
usercopy: kernel memory exposure attempt detected from ffff880000090000 (dma-kmalloc-256) (4096 bytes)
This changes the x86 exception for the low 1MB by reading back zeros for
System RAM areas instead of blindly allowing them. More work is needed to
extend this to mmap, but currently mmap doesn't go through usercopy, so
hardened usercopy won't Oops the kernel.
Reported-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Tested-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Cc: Brad Spengler <spender@grsecurity.net>
commit cc272163ea554a97dac180fa8dd6cd54c2810bd1 upstream.
This patch fixes the following warning message seen when booting the
kernel as Dom0 with Xen on Intel machines.
[0.003000] [Firmware Bug]: CPU1: APIC id mismatch. Firmware: 0 APIC: 1]
The code generating the warning in validate_apic_and_package_id() matches
cpu_data(cpu).apicid (initialized in init_intel()->
detect_extended_topology() using cpuid) against the apicid returned from
xen_apic_read(). Now, xen_apic_read() makes a hypercall to retrieve apicid
for the boot cpu but returns 0 otherwise. Hence the warning gets thrown
for all but the boot cpu.
The idea behind xen_apic_read() returning 0 for apicid is that the
guests (even Dom0) should not need to know what physical processor their
vcpus are running on. This is because we currently do not have topology
information in Xen and also because xen allows more vcpus than physical
processors. However, boot cpu's apicid is required for loading
xen-acpi-processor driver on AMD machines. Look at following patch for
details:
commit 558daa289a40 ("xen/apic: Return the APIC ID (and version) for CPU
0.")
So to get rid of the warning, this patch modifies
xen_cpu_present_to_apicid() to return cpu_data(cpu).apicid instead of
calling xen_apic_read().
The warning is not seen on AMD machines because init_amd() populates
cpu_data(cpu).apicid by calling hard_smp_processor_id()->xen_apic_read()
as opposed to using apicid from cpuid as is done on Intel machines.
Signed-off-by: Mohit Gambhir <mohit.gambhir@oracle.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 3f795cef0ecdf9bc980dd058d49bdab4b19af1d3 upstream.
This fixes a bug in which the upper 32-bits of a 64-bit value which is
read by get_user() was lost on a 32-bit kernel.
While touching this code, split out pre-loading of %sr2 space register
and clean up code indent.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 06ce521af9558814b8606c0476c54497cf83a653 upstream.
handle_vmon gets a reference on VMXON region page,
but does not release it. Release the reference.
Found by syzkaller; based on a patch by Dmitry.
[bwh: Backported to 3.16: use skip_emulated_instruction()]
This reverts commit 362721c4957dcda7b1fbd45380e7a6617a1d077c which is
commit 6c356eda225e3ee134ed4176b9ae3a76f793f4dd upstream.
It shouldn't have been included in a stable release.
Reported-by: Amit Pundir <amit.pundir@linaro.org>
Cc: Felix Fietkau <nbd@nbd.name>
Cc: John Crispin <john@phrozen.org>
Cc: James Hogan <james.hogan@imgtec.com>
commit 409c1b250e30ad0e48b4d15d7319b4e18c046c4f upstream.
The patch 554bfeceb8a22d448cd986fc9efce25e833278a1 ("parisc: Fix access
fault handling in pa_memcpy()") reimplements the pa_memcpy function.
Unfortunatelly, it makes the kernel unbootable. The crash happens in the
function ide_complete_cmd where memcpy is called with the same source
and destination address.
This patch fixes a few bugs in pa_memcpy:
* When jumping to .Lcopy_loop_16 for the first time, don't skip the
instruction "ldi 31,t0" (this bug made the kernel unbootable)
* Use the COND macro when comparing length, so that the comparison is
64-bit (a theoretical issue, in case the length is greater than
0xffffffff)
* Don't use the COND macro after the "extru" instruction (the PA-RISC
specification says that the upper 32-bits of extru result are undefined,
although they are set to zero in practice)
* Fix exception addresses in .Lcopy16_fault and .Lcopy8_fault
* Rename .Lcopy_loop_4 to .Lcopy_loop_8 (so that it is consistent with
.Lcopy8_fault)
Fixes: 554bfeceb8a2 ("parisc: Fix access fault handling in pa_memcpy()")
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 6fdc6dd90272ce7e75d744f71535cfbd8d77da81 upstream.
The vsyscall32 sysctl can racy against a concurrent fork when it switches
from disabled to enabled:
arch_setup_additional_pages()
if (vdso32_enabled)
--> No mapping
sysctl.vsysscall32()
--> vdso32_enabled = true
create_elf_tables()
ARCH_DLINFO_IA32
if (vdso32_enabled) {
--> Add VDSO entry with NULL pointer
Make ARCH_DLINFO_IA32 check whether the VDSO mapping has been set up for
the newly forked process or not.
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Mathias Krause <minipli@googlemail.com>
Link: http://lkml.kernel.org/r/20170410151723.602367196@linutronix.de
commit c06989da39cdb10604d572c8c7ea8c8c97f3c483 upstream.
vdso_enabled can be set to arbitrary integer values via the kernel command
line 'vdso32=' parameter or via 'sysctl abi.vsyscall32'.
load_vdso32() only maps VDSO if vdso_enabled == 1, but ARCH_DLINFO_IA32
merily checks for vdso_enabled != 0. As a consequence the AT_SYSINFO_EHDR
auxiliary vector for the VDSO_ENTRY is emitted with a NULL pointer which
causes a segfault when the application tries to use the VDSO.
Restrict the valid arguments on the command line and the sysctl to 0 and 1.
Fixes: b0b49f2673f0 ("x86, vdso: Remove compat vdso support")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Roland McGrath <roland@redhat.com>
Link: http://lkml.kernel.org/r/1491424561-7187-1-git-send-email-minipli@googlemail.com
Link: http://lkml.kernel.org/r/20170410151723.518412863@linutronix.de
commit 11e63f6d920d6f2dfd3cd421e939a4aec9a58dcd upstream.
Before we rework the "pmem api" to stop abusing __copy_user_nocache()
for memcpy_to_pmem() we need to fix cases where we may strand dirty data
in the cpu cache. The problem occurs when copy_from_iter_pmem() is used
for arbitrary data transfers from userspace. There is no guarantee that
these transfers, performed by dax_iomap_actor(), will have aligned
destinations or aligned transfer lengths. Backstop the usage
__copy_user_nocache() with explicit cache management in these unaligned
cases.
Yes, copy_from_iter_pmem() is now too big for an inline, but addressing
that is saved for a later patch that moves the entirety of the "pmem
api" into the pmem driver directly.
Fixes: 5de490daec8b ("pmem: add copy_from_iter_pmem() and clear_pmem()")
Cc: <x86@kernel.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
commit cfac6dfa42bddfa9711b20d486e521d1a41ab09f upstream.
Put the right values from the original siginfo into the
userspace compat-siginfo.
This fixes the 32-bit MPX "tabletest" testcase on 64-bit kernels.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: a4455082dc6f0 ('x86/signals: Add missing signal_compat code for x86 features')
Link: http://lkml.kernel.org/r/1491322501-5054-1-git-send-email-joro@8bytes.org
commit 6f6266a561306e206e0e31a5038f029b6a7b1d89 upstream.
Reserving a runtime region results in splitting the EFI memory
descriptors for the runtime region. This results in runtime region
descriptors with bogus memory mappings, leading to interesting crashes
like the following during a kexec:
general protection fault: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.11.0-rc1 #53
Hardware name: Wiwynn Leopard-Orv2/Leopard-DDR BW, BIOS LBM05 09/30/2016
RIP: 0010:virt_efi_set_variable()
Call Trace:
efi_delete_dummy_variable()
efi_enter_virtual_mode()
start_kernel()
? set_init_arg()
x86_64_start_reservations()
x86_64_start_kernel()
start_cpu()
Kernel panic - not syncing: Fatal exception
Runtime regions will not be freed and do not need to be reserved, so
skip the memmap modification in this case.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Dave Young <dyoung@redhat.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: linux-efi@vger.kernel.org
Fixes: 8e80632fb23f ("efi/esrt: Use efi_mem_reserve() and avoid a kmalloc()")
Link: http://lkml.kernel.org/r/20170412152719.9779-2-matt@codeblueprint.co.uk
commit f2200ac311302fcdca6556fd0c5127eab6c65a3e upstream.
When the perf_branch_entry::{in_tx,abort,cycles} fields were added,
intel_pmu_lbr_read_32() wasn't updated to initialize them.
Fixes: 135c5612c460 ("perf/x86/intel: Support Haswell/v4 LBR format")
commit c25f8064c1d5731a2ce5664def890140dcdd3e5c upstream.
Commit dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
changed both the normal and vectored interrupt handlers. Unfortunately
the vectored version, "except_vec_vi_handler", was incorrectly modified
to unconditionally jal to plat_irq_dispatch, rather than doing a jalr to
the vectored handler that has been set up. This is ok for many platforms
which set the vectored handler to plat_irq_dispatch anyway, but will
cause problems with platforms that use other handlers.
Fixes: dda45f701c9d ("MIPS: Switch to the irq_stack in interrupts")
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15110/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 3cc3434fd6307d06b53b98ce83e76bf9807689b9 upstream.
Since do_IRQ is now invoked on a separate IRQ stack, we select
HAVE_IRQ_EXIT_ON_IRQ_STACK so that softirq's may be invoked directly
from irq_exit(), rather than requiring do_softirq_own_stack.
Acked-by: Jason A. Donenfeld <jason@zx2c4.com>
Patchwork: https://patchwork.linux-mips.org/patch/14744/
commit dda45f701c9d7ad4ac0bb446e3a96f6df9a468d9 upstream.
When enterring interrupt context via handle_int or except_vec_vi, switch
to the irq_stack of the current CPU if it is not already in use.
The current stack pointer is masked with the thread size and compared to
the base or the irq stack. If it does not match then the stack pointer
is set to the top of that stack, otherwise this is a nested irq being
handled on the irq stack so the stack pointer should be left as it was.
The in-use stack pointer is placed in the callee saved register s1. It
will be saved to the stack when plat_irq_dispatch is invoked and can be
restored once control returns here.
Patchwork: https://patchwork.linux-mips.org/patch/14743/
commit 510d86362a27577f5ee23f46cfb354ad49731e61 upstream.
The SAVE_SOME macro is used to save the execution context on all
exceptions.
If an exception occurs while executing user code, the stack is switched
to the kernel's stack for the current task, and register $28 is switched
to point to the current_thread_info, which is at the bottom of the stack
region.
If the exception occurs while executing kernel code, the stack is left,
and this change ensures that register $28 is not updated. This is the
correct behaviour when the kernel can be executing on the separate irq
stack, because the thread_info will not be at the base of it.
With this change, register $28 is only switched to it's kernel
conventional usage of the currrent thread info pointer at the point at
which execution enters kernel space. Doing it on every exception was
redundant, but OK without an IRQ stack, but will be erroneous once that
is introduced.
Patchwork: https://patchwork.linux-mips.org/patch/14742/
commit d42d8d106b0275b027c1e8992c42aecf933436ea upstream.
Within unwind stack, check if the stack pointer being unwound is within
the CPU's irq_stack and if so use that page rather than the task's stack
page.
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: Maciej W. Rozycki <macro@imgtec.com>
Cc: Marcin Nowakowski <marcin.nowakowski@imgtec.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Patchwork: https://patchwork.linux-mips.org/patch/14741/
commit fe8bd18ffea5327344d4ec2bf11f47951212abd0 upstream.
Allocate a per-cpu irq stack for use within interrupt handlers.
Also add a utility function on_irq_stack to determine if a given stack
pointer is within the irq stack for that cpu.
Cc: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Patchwork: https://patchwork.linux-mips.org/patch/14740/
[ Upstream commit bba8376aea1dcbbe22bbda118c52abee317c7609 ]
The reboot quirk for ASUS EeeBook X205TA contains a typo in
DMI_PRODUCT_NAME, improperly referring to X205TAW instead of
X205TA, which prevents the quirk from being triggered. The
model X205TAW already has a reboot quirk of its own.
This fix simply removes the inappropriate final letter W.
Fixes: 90b28ded88dd ("x86/reboot/quirks: Add ASUS EeeBook X205TA reboot quirk")
Signed-off-by: Matjaz Hegedic <matjaz.hegedic@gmail.com>
Link: http://lkml.kernel.org/r/1489064417-7445-1-git-send-email-matjaz.hegedic@gmail.com
[ Upstream commit 3b3e78552d3077ec70d2640e629e07e3ab416a6a ]
Without the parameter reboot=a, ASUS EeeBook X205TA/W will hang
when it should reboot. This adds the appropriate quirk, thus
fixing the problem.
Link: http://lkml.kernel.org/r/1488737804-20681-1-git-send-email-matjaz.hegedic@gmail.com
[ Upstream commit 90b28ded88dda8bea82b4a86923e73ba0746d884 ]
Without the parameter reboot=a, ASUS EeeBook X205TA will hang when it should reboot.
This adds the appropriate quirk, thus fixing the problem.
[ Upstream commit 82bcd087029f6056506ea929f11af02622230901 ]
This patch adds a Qualcomm specific quirk to the arm_smccc_smc call.
On Qualcomm ARM64 platforms, the SMC call can return before it has
completed. If this occurs, the call can be restarted, but it requires
using the returned session ID value from the interrupted SMC call.
The quirk stores off the session ID from the interrupted call in the
quirk structure so that it can be used by the caller.
This patch folds in a fix given by Sricharan R:
https://lkml.org/lkml/2016/9/28/272
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
[ Upstream commit 680a0873e193bae666439f4b5e32c758e68f114c ]
This patch adds a quirk parameter to the arm_smccc_(smc/hvc) calls.
The quirk structure allows for specialized SMC operations due to SoC
specific requirements. The current arm_smccc_(smc/hvc) is renamed and
macros are used instead to specify the standard arm_smccc_(smc/hvc) or
the arm_smccc_(smc/hvc)_quirk function.
This patch and partial implementation was suggested by Will Deacon.
[ Upstream commit 8413299cb3933dade6186bbee8363f190032107e ]
Since v4.10-rc1, the following logs appears in loop :
[ 801.953836] usb usb6-port1: Cannot enable. Maybe the USB cable is bad?
[ 801.960455] xhci-hcd xhci-hcd.0.auto: Cannot set link state.
[ 801.966611] usb usb6-port1: cannot disable (err = -32)
[ 806.083772] usb usb6-port1: Cannot enable. Maybe the USB cable is bad?
[ 806.090370] xhci-hcd xhci-hcd.0.auto: Cannot set link state.
[ 806.096494] usb usb6-port1: cannot disable (err = -32)
After analysis, xhci try to set link in U3 and returns an error.
Using snps,dis_u3_susphy_quirk fix this issue.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
[ Upstream commit 7e431af8fa0b9ed9d74378c99514856211cb9db8 ]
Add PM support for DA850 device-tree boot.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit dfd1972c2b464c10fb585c4c60b594e09d181a01 ]
Use a local "struct device *dev" for brevity. No functional change
intended.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[ Upstream commit 093d24a204425f71f4f106b7e62c8df4b456e1cc ]
Currently we use one shared global acpi_pci_root_ops structure to keep
controller-specific ops. We pass its pointer to acpi_pci_root_create() and
associate it with a host bridge instance for good. Such a design implies
serious drawback. Any potential manipulation on the single system-wide
acpi_pci_root_ops leads to kernel crash. The structure content is not
really changing even across multiple host bridges creation; thus it was not
an issue so far.
In preparation for adding ECAM quirks mechanism (where controller-specific
PCI ops may be different for each host bridge) allocate new
acpi_pci_root_ops and fill in with data for each bridge. Now it is safe to
have different controller-specific info. As a consequence free
acpi_pci_root_ops when host bridge is released.
No functional changes in this patch.
Signed-off-by: Tomasz Nowicki <tn@semihalf.com>
[ Upstream commit f65e786604b34d0b599b8c01ecca28be2d746290 ]
The string for the am max transmissions quirk property
is not correct -> fix it.
Signed-off-by: John Garry <john.garry@huawei.com>
Reviewed-by: Xiang Chen <chenxiang66@hisilicon.com>
Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
commit 0be032c190abcdcfa948082b6a1e0d461184ba4d upstream.
If scache.waysize is 0, r4k___flush_cache_all() will do nothing and
then cause bugs. BTW, though vcache.waysize isn't being used by now,
we also fix its calculation.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Steven J . Hill <Steven.Hill@caviumnetworks.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/15756/
commit 0115f6cbf26663c86496bc56eeea293f85b77897 upstream.
On VTLB+FTLB platforms (such as Loongson-3A R2), FTLB's pagesize is
usually configured the same as PAGE_SIZE. In such a case, Huge page
entry is not suitable to write in FTLB.
Unfortunately, when a huge page is created, its page table entries
haven't created immediately. Then the TLB refill handler will fetch an
invalid page table entry which has no "HUGE" bit, and this entry may be
written to FTLB. Since it is invalid, TLB load/store handler will then
use tlbwi to write the valid entry at the same place. However, the
valid entry is a huge page entry which isn't suitable for FTLB.
Our solution is to modify build_huge_handler_tail. Flush the invalid
old entry (whether it is in FTLB or VTLB, this is in order to reduce
branches) and use tlbwr to write the valid new entry.
Signed-off-by: Rui Wang <wangr@lemote.com>
Cc: Huacai Chen <chenhc@lemote.com>
Patchwork: https://patchwork.linux-mips.org/patch/15754/
commit 033cffeedbd11c140952b98e8639bf652091a17d upstream.
Loongson-3A R2 and newer CPU have FTLB, but Config0.MT is 1, so add
MIPS_CPU_FTLB to the CPU options.
Patchwork: https://patchwork.linux-mips.org/patch/15752/
commit 5a34133167dce36666ea054e30a561b7f4413b7f upstream.
Loongson-3's micro TLB (ITLB) is not strictly a subset of JTLB. That
means: when a JTLB entry is replaced by hardware, there may be an old
valid entry exists in ITLB. So, a TLB miss exception may occur while
handle_ri_rdhwr() is running because it try to access EPC's content.
However, handle_ri_rdhwr() doesn't clear EXL, which makes a TLB Refill
exception be treated as a TLB Invalid exception and tlbp may fail. In
this case, if FTLB (which is usually set-associative instead of set-
associative) is enabled, a tlbp failure will cause an invalid tlbwi,
which will hang the whole system.
This patch rename handle_ri_rdhwr_vivt to handle_ri_rdhwr_tlbp and use
it for Loongson-3. It try to solve the same problem described as below,
but more straightforwards.
https://patchwork.linux-mips.org/patch/12591/
I think Loongson-2 has the same problem, but it has no FTLB, so we just
keep it as is.
Cc: Rui Wang <wangr@lemote.com>
Patchwork: https://patchwork.linux-mips.org/patch/15753/
commit 6ef90877eee63a0d03e83183bb44b64229b624e6 upstream.
Commit 08b3c894e565 ("MIPS: lantiq: Disable xbar fpi burst mode")
accidentally requested the resources from the pmu address region
instead of the xbar registers region, but the check for the return
value of request_mem_region() was wrong. Commit 98ea51cb0c8c ("MIPS:
Lantiq: Fix another request_mem_region() return code check") fixed the
check of the return value of request_mem_region() which made the kernel
panics.
This patch now makes use of the correct memory region for the cross bar.
Fixes: 08b3c894e565 ("MIPS: lantiq: Disable xbar fpi burst mode")
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Cc: james.hogan@imgtec.com
Cc: arnd@arndb.de
Cc: sergei.shtylyov@cogentembedded.com
Cc: john@phrozen.org
Patchwork: https://patchwork.linux-mips.org/patch/15751
commit 4b5347a24a0f2d3272032c120664b484478455de upstream.
When building for microMIPS we need to ensure that the assembler always
knows that there is code at the target of a branch or jump. Recent
toolchains will fail to link a microMIPS kernel when this isn't the case
due to what it thinks is a branch to non-microMIPS code.
mips-mti-linux-gnu-ld kernel/built-in.o: .spinlock.text+0x2fc: Unsupported branch between ISA modes.
mips-mti-linux-gnu-ld final link failed: Bad value
This is due to inline assembly labels in spinlock.h not being followed
by an instruction mnemonic, either due to a .subsection pseudo-op or the
end of the inline asm block.
Fix this with a .insn direction after such labels.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Reviewed-by: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15325/
commit 7c5a3d813050ee235817b0220dd8c42359a9efd8 upstream.
There are two copy & paste errors in the definition of the 5GHz LNA and
second ethernet pinmux.
Fixes: f576fb6a0700 ("MIPS: ralink: cleanup the soc specific pinmux data")
Signed-off-by: John Crispin <john@phrozen.org>
Signed-off-by: Daniel Golle <daniel@makrotopia.org>
Patchwork: https://patchwork.linux-mips.org/patch/15328/
commit 2e6c7747730296a6d4fd700894286db1132598c4 upstream.
When a 32-bit kernel is configured to support MIPS64r6 (CPU_MIPS64_R6),
MIPS_O32_FP64_SUPPORT won't be selected as it should be because
MIPS32_O32 is disabled (o32 is already the default ABI available on
32-bit kernels).
This results in userland FP breakage as CP0_Status.FR is read-only 1
since r6 (when an FPU is present) so __enable_fpu() will fail to clear
FR. This causes the FPU emulator to get used which will incorrectly
emulate 32-bit FPU registers.
Force o32 fp64 support in this case by also selecting
MIPS_O32_FP64_SUPPORT from CPU_MIPS64_R6 if 32BIT.
Fixes: 4e9d324d4288 ("MIPS: Require O32 FP64 support for MIPS64 with O32 compat")
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15310/
commit d09c5373e8e4eaaa09233552cbf75dc4c4f21203 upstream.
Commit fd2d2b191fe7 ("s390: get_user() should zero on failure")
intended to fix s390's get_user() implementation which did not zero
the target operand if the read from user space faulted. Unfortunately
the patch has no effect: the corresponding inline assembly specifies
that the operand is only written to ("=") and the previous value is
discarded.
Therefore the compiler is free to and actually does omit the zero
initialization.
To fix this simply change the contraint modifier to "+", so the
compiler cannot omit the initialization anymore.
Fixes: c9ca78415ac1 ("s390/uaccess: provide inline variants of get_user/put_user")
Fixes: fd2d2b191fe7 ("s390: get_user() should zero on failure")
commit d82c0d12c92705ef468683c9b7a8298dd61ed191 upstream.
Reorder the operations in decompress_kernel() to ensure initrd is moved
to a safe location before the bss section is zeroed.
During decompression bss can overlap with the initrd and this can
corrupt the initrd contents depending on the size of the compressed
kernel (which affects where the initrd is placed by the bootloader) and
the size of the bss section of the decompressor.
Also use the correct initrd size when checking for overlaps with
parmblock.
Fixes: 06c0dd72aea3 ([S390] fix boot failures with compressed kernels)
Reviewed-by: Joy Latten <joy.latten@canonical.com>
Reviewed-by: Vineetha HariPai <vineetha.hari.pai@canonical.com>
Signed-off-by: Marcelo Henrique Cerri <marcelo.cerri@canonical.com>
commit 2b83878dd74a7c73bedcb6600663c1c46836e8af upstream.
When __pa is applied to virtual address in uncached KSEG region the
result is incorrect. Fix it by checking if the original address is in
the uncached KSEG and adjusting the result. It looks better than masking
off bits because pfn_valid would correctly work with new __pa results
and it may be made working in noMMU case, once we get definition for
uncached memory view.
This is required for the dma_common_mmap and DMA debug code to work
correctly: they both indirectly use __pa with coherent DMA addresses.
In case of DMA debug the visible effect is false reports that an address
mapped for DMA is accessed by CPU.
Tested-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 921d701e6f31e1ffaca3560416af1aa04edb4c4f upstream.
Make sure to reserve the boot memory for the flattened device tree.
Otherwise it might get overwritten, e.g. when initial_boot_params is
copied, leading to a corrupted FDT and a boot hang/crash:
bootconsole [early0] enabled
Early console on uart16650 initialized at 0xf8001600
OF: fdt: Error -11 processing FDT
Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree!
---[ end Kernel panic - not syncing: setup_cpuinfo: No CPU found in devicetree!
Guenter Roeck says:
> I think I found the problem. In unflatten_and_copy_device_tree(), with added
> debug information:
> OF: fdt: initial_boot_params=c861e400, dt=c861f000 size=28874 (0x70ca)
> ... and then initial_boot_params is copied to dt, which results in corrupted
> fdt since the memory overlaps. Looks like the initial_boot_params memory
> is not reserved and (re-)allocated by early_init_dt_alloc_memory_arch().
Reported-by: Guenter Roeck <linux@roeck-us.net>
Reference: http://lkml.kernel.org/r/20170226210338.GA19476@roeck-us.net
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Ley Foon Tan <ley.foon.tan@intel.com>
commit 4749228f022893faf54a3dbc70796f78b7d4f342 upstream.
In crc32c_vpmsum() we call enable_kernel_altivec() without first
disabling preemption, which is not allowed:
WARNING: CPU: 9 PID: 2949 at ../arch/powerpc/kernel/process.c:277 enable_kernel_altivec+0x100/0x120
Modules linked in: dm_thin_pool dm_persistent_data dm_bio_prison dm_bufio libcrc32c vmx_crypto ...
CPU: 9 PID: 2949 Comm: docker Not tainted 4.11.0-rc5-compiler_gcc-6.3.1-00033-g308ac7563944 #381
NIP [c00000000001e320] enable_kernel_altivec+0x100/0x120
LR [d000000003df0910] crc32c_vpmsum+0x108/0x150 [crc32c_vpmsum]
Call Trace:
0xc138fd09 (unreliable)
crc32c_vpmsum_update+0x3c/0x60 [crc32c_vpmsum]
crypto_shash_update+0x88/0x1c0
crc32c+0x64/0x90 [libcrc32c]
dm_bm_checksum+0x48/0x80 [dm_persistent_data]
sb_check+0x84/0x120 [dm_thin_pool]
dm_bm_validate_buffer.isra.0+0xc0/0x1b0 [dm_persistent_data]
dm_bm_read_lock+0x80/0xf0 [dm_persistent_data]
__create_persistent_data_objects+0x16c/0x810 [dm_thin_pool]
dm_pool_metadata_open+0xb0/0x1a0 [dm_thin_pool]
pool_ctr+0x4cc/0xb60 [dm_thin_pool]
dm_table_add_target+0x16c/0x3c0
table_load+0x184/0x400
ctl_ioctl+0x2f0/0x560
dm_ctl_ioctl+0x38/0x50
do_vfs_ioctl+0xd8/0x920
SyS_ioctl+0x68/0xc0
system_call+0x38/0xfc
It used to be sufficient just to call pagefault_disable(), because that
also disabled preemption. But the two were decoupled in commit 8222dbe21e79
("sched/preempt, mm/fault: Decouple preemption from the page fault
logic") in mid 2015.
So add the missing preempt_disable/enable(). We should also call
disable_kernel_fp(), although it does nothing by default, there is a
debug switch to make it active and all enables should be paired with
disables.
Fixes: 6dd7a82cc54e ("crypto: powerpc - Add POWER8 optimised crc32c")
commit 48fe9e9488743eec9b7c1addd3c93f12f2123d54 upstream.
In the past, there was only one load-with-reservation instruction,
lwarx, and if a program attempted a lwarx on a misaligned address, it
would take an alignment interrupt and the kernel handler would emulate
it as though it was lwzx, which was not really correct, but benign since
it is loading the right amount of data, and the lwarx should be paired
with a stwcx. to the same address, which would also cause an alignment
interrupt which would result in a SIGBUS being delivered to the process.
We now have 5 different sizes of load-with-reservation instruction. Of
those, lharx and ldarx cause an immediate SIGBUS by luck since their
entries in aligninfo[] overlap instructions which were not fixed up, but
lqarx overlaps with lhz and will be emulated as such. lbarx can never
generate an alignment interrupt since it only operates on 1 byte.
To straighten this out and fix the lqarx case, this adds code to detect
the l[hwdq]arx instructions and return without fixing them up, resulting
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit 8f5f525d5b83f7d76a6baf9c4e94d4bf312ea7f6 upstream.
When the kernel is compiled to use 64bit ABIv2 the _GLOBAL() macro does
not include a global entry point. A function's global entry point is
used when the function is called from a different TOC context and in the
kernel this typically means a call from a module into the vmlinux (or
vice-versa).
There are a few exported asm functions declared with _GLOBAL() and
calling them from a module will likely crash the kernel since any TOC
relative load will yield garbage.
flush_icache_range() and flush_dcache_range() are both exported to
modules, and use the TOC, so must use _GLOBAL_TOC().
Fixes: 721aeaa9fdf3 ("powerpc: Build little endian ppc64 kernel with ABIv2")
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
commit 88b1bf7268f56887ca88eb09c6fb0f4fc970121a upstream.
Commit 4c6d9acce1f4 ("powerpc/mm: Add hooks for cxl") converted local
TLB invalidates to global if the cxl driver is active. This is necessary
because the CAPP snoops invalidations to forward them to the PSL on the
cxl adapter. However one path was forgotten. native_flush_hash_range()
still does local TLB invalidates, as found out the hard way recently.
This patch fixes it by following the same logic as previously: if the
cxl driver is active, the local TLB invalidates are 'upgraded' to
global.
Fixes: 4c6d9acce1f4 ("powerpc/mm: Add hooks for cxl")
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 7ed23e1bae8bf7e37fd555066550a00b95a3a98b upstream.
On Power8 & Power9 the early CPU inititialisation in __init_HFSCR()
turns on HFSCR[TM] (Hypervisor Facility Status and Control Register
[Transactional Memory]), but that doesn't take into account that TM
might be disabled by CPU features, or disabled by the kernel being built
with CONFIG_PPC_TRANSACTIONAL_MEM=n.
So later in boot, when we have setup the CPU features, clear HSCR[TM] if
the TM CPU feature has been disabled. We use CPU_FTR_TM_COMP to account
for the CONFIG_PPC_TRANSACTIONAL_MEM=n case.
Without this a KVM guest might try use TM, even if told not to, and
cause an oops in the host kernel. Typically the oops is seen in
__kvmppc_vcore_entry() and may or may not be fatal to the host, but is
always bad news.
In practice all shipping CPU revisions do support TM, and all host
kernels we are aware of build with TM support enabled, so no one should
actually be able to hit this in the wild.
Fixes: 2a3563b023e5 ("powerpc: Setup in HFSCR for POWER8")
Tested-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
[mpe: Rewrite change log with input from Sam, add Fixes/stable]
commit b884a190afcecdbef34ca508ea5ee88bb7c77861 upstream.
The rapf copy loops in the Meta usercopy code is missing some extable
entries for HTP cores with unaligned access checking enabled, where
faults occur on the instruction immediately after the faulting access.
Add the fixup labels and extable entries for these cases so that corner
case user copy failures don't cause kernel crashes.
Fixes: 373cd784d0fc ("metag: Memory handling")
Cc: linux-metag@vger.kernel.org
commit 2c0b1df88b987a12d95ea1d6beaf01894f3cc725 upstream.
The fixup code to rewind the source pointer in
__asm_copy_from_user_{32,64}bit_rapf_loop() always rewound the source by
a single unit (4 or 8 bytes), however this is insufficient if the fault
didn't occur on the first load in the loop, as the source pointer will
have been incremented but nothing will have been stored until all 4
register [pairs] are loaded.
Read the LSM_STEP field of TXSTATUS (which is already loaded into a
register), a bit like the copy_to_user versions, to determine how many
iterations of MGET[DL] have taken place, all of which need rewinding.
commit fd40eee1290ad7add7aa665e3ce6b0f9fe9734b4 upstream.
The fixup code for the copy_to_user rapf loops reads TXStatus.LSM_STEP
to decide how far to rewind the source pointer. There is a special case
for the last execution of an MGETL/MGETD, since it leaves LSM_STEP=0
even though the number of MGETLs/MGETDs attempted was 4. This uses ADDZ
which is conditional upon the Z condition flag, but the AND instruction
which masked the TXStatus.LSM_STEP field didn't set the condition flags
based on the result.
Fix that now by using ANDS which does set the flags, and also marking
the condition codes as clobbered by the inline assembly.
commit 563ddc1076109f2b3f88e6d355eab7b6fd4662cb upstream.
Currently we try to zero the destination for a failed read from userland
in fixup code in the usercopy.c macros. The rest of the destination
buffer is then zeroed from __copy_user_zeroing(), which is used for both
copy_from_user() and __copy_from_user().
Unfortunately we fail to zero in the fixup code as D1Ar1 is set to 0
before the fixup code entry labels, and __copy_from_user() shouldn't even
be zeroing the rest of the buffer.
Move the zeroing out into copy_from_user() and rename
__copy_user_zeroing() to raw_copy_from_user() since it no longer does
any zeroing. This also conveniently matches the name needed for
RAW_COPY_USER support in a later patch.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit fb8ea062a8f2e85256e13f55696c5c5f0dfdcc8b upstream.
When copying to userland on Meta, if any faults are encountered
immediately abort the copy instead of continuing on and repeatedly
faulting, and worse potentially copying further bytes successfully to
subsequent valid pages.
