commit d4912215d1031e4fb3d1038d2e1857218dba0d0a upstream.
WARNING: CPU: 3 PID: 2840 at arch/x86/kvm/vmx.c:10966 nested_vmx_vmexit+0xdcd/0xde0 [kvm_intel]
CPU: 3 PID: 2840 Comm: qemu-system-x86 Tainted: G OE 4.12.0-rc3+ #23
RIP: 0010:nested_vmx_vmexit+0xdcd/0xde0 [kvm_intel]
Call Trace:
? kvm_check_async_pf_completion+0xef/0x120 [kvm]
? rcu_read_lock_sched_held+0x79/0x80
vmx_queue_exception+0x104/0x160 [kvm_intel]
? vmx_queue_exception+0x104/0x160 [kvm_intel]
kvm_arch_vcpu_ioctl_run+0x1171/0x1ce0 [kvm]
? kvm_arch_vcpu_load+0x47/0x240 [kvm]
? kvm_arch_vcpu_load+0x62/0x240 [kvm]
kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? __fget+0xf3/0x210
do_vfs_ioctl+0xa4/0x700
? __fget+0x114/0x210
SyS_ioctl+0x79/0x90
do_syscall_64+0x81/0x220
entry_SYSCALL64_slow_path+0x25/0x25
This is triggered occasionally by running both win7 and win2016 in L2, in
addition, EPT is disabled on both L1 and L2. It can't be reproduced easily.
Commit 0b6ac343fc (KVM: nVMX: Correct handling of exception injection) mentioned
that "KVM wants to inject page-faults which it got to the guest. This function
assumes it is called with the exit reason in vmcs02 being a #PF exception".
Commit e011c663 (KVM: nVMX: Check all exceptions for intercept during delivery to
L2) allows to check all exceptions for intercept during delivery to L2. However,
there is no guarantee the exit reason is exception currently, when there is an
external interrupt occurred on host, maybe a time interrupt for host which should
not be injected to guest, and somewhere queues an exception, then the function
nested_vmx_check_exception() will be called and the vmexit emulation codes will
try to emulate the "Acknowledge interrupt on exit" behavior, the warning is
triggered.
Reusing the exit reason from the L2->L0 vmexit is wrong in this case,
the reason must always be EXCEPTION_NMI when injecting an exception into
L1 as a nested vmexit.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Fixes: e011c663b9c7 ("KVM: nVMX: Check all exceptions for intercept during delivery to L2")
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit f0367ee1d64d27fa08be2407df5c125442e885e3 upstream.
Static checker noticed that base3 could be used uninitialized if the
segment was not present (useable). Random stack values probably would
not pass VMCS entry checks.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 1aa366163b8b ("KVM: x86 emulator: consolidate segment accessors")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
commit 34b0dadbdf698f9b277a31b2747b625b9a75ea1f upstream.
Static analysis noticed that pmu->nr_arch_gp_counters can be 32
(INTEL_PMC_MAX_GENERIC) and therefore cannot be used to shift 'int'.
I didn't add BUILD_BUG_ON for it as we have a better checker.
Fixes: 25462f7f5295 ("KVM: x86/vPMU: Define kvm_pmu_ops to support vPMU function dispatch")
commit 6ed071f051e12cf7baa1b69d3becb8f232fdfb7b upstream.
On AMD, the effect of set_nmi_mask called by emulate_iret_real and em_rsm
on hflags is reverted later on in x86_emulate_instruction where hflags are
overwritten with ctxt->emul_flags (the kvm_set_hflags call). This manifests
as a hang when rebooting Windows VMs with QEMU, OVMF, and >1 vcpu.
Instead of trying to merge ctxt->emul_flags into vcpu->arch.hflags after
an instruction is emulated, this commit deletes emul_flags altogether and
makes the emulator access vcpu->arch.hflags using two new accessors. This
way all changes, on the emulator side as well as in functions called from
the emulator and accessing vcpu state with emul_to_vcpu, are preserved.
More details on the bug and its manifestation with Windows and OVMF:
It's a KVM bug in the interaction between SMI/SMM and NMI, specific to AMD.
I believe that the SMM part explains why we started seeing this only with
OVMF.
KVM masks and unmasks NMI when entering and leaving SMM. When KVM emulates
the RSM instruction in em_rsm, the set_nmi_mask call doesn't stick because
later on in x86_emulate_instruction we overwrite arch.hflags with
ctxt->emul_flags, effectively reverting the effect of the set_nmi_mask call.
The AMD-specific hflag of interest here is HF_NMI_MASK.
When rebooting the system, Windows sends an NMI IPI to all but the current
cpu to shut them down. Only after all of them are parked in HLT will the
initiating cpu finish the restart. If NMI is masked, other cpus never get
the memo and the initiating cpu spins forever, waiting for
hal!HalpInterruptProcessorsStarted to drop. That's the symptom we observe.
Fixes: a584539b24b8 ("KVM: x86: pass the whole hflags field to emulator and back")
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
commit 335d2c2d192266358c5dfa64953a4c162f46e464 upstream.
Commit 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are
stuck in the kernel") added a helper function to determine if die() is
supported in cpu_ops. This function assumes a cpu will have a valid
cpu_ops entry, but that may not be the case for cpu0 is spin-table or
parking protocol is used to boot secondary cpus. In that case, there
is a NULL dereference if have_cpu_die() is called by cpu0. So add a
check for a valid cpu_ops before dereferencing it.
Fixes: 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are stuck in the kernel")
Signed-off-by: Mark Salter <msalter@redhat.com>
commit dbd68d8e84c606673ebbcf15862f8c155fa92326 upstream.
flush_tlb_page() passes a bogus range to flush_tlb_others() and
expects the latter to fix it up. native_flush_tlb_others() has the
fixup but Xen's version doesn't. Move the fixup to
flush_tlb_others().
AFAICS the only real effect is that, without this fix, Xen would
flush everything instead of just the one page on remote vCPUs in
when flush_tlb_page() was called.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Nadav Amit <namit@vmware.com>
Fixes: e7b52ffd45a6 ("x86/flush_tlb: try flush_tlb_single one by one in flush_tlb_range")
Link: http://lkml.kernel.org/r/10ed0e4dfea64daef10b87fb85df1746999b4dba.1492844372.git.luto@kernel.org
commit 5ed386ec09a5d75bcf073967e55e895c2607a5c3 upstream.
When this function fails it just sends a SIGSEGV signal to
user-space using force_sig(). This signal is missing
essential information about the cause, e.g. the trap_nr or
an error code.
Fix this by propagating the error to the only caller of
mpx_handle_bd_fault(), do_bounds(), which sends the correct
SIGSEGV signal to the process.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Fixes: fe3d197f84319 ('x86, mpx: On-demand kernel allocation of bounds tables')
Link: http://lkml.kernel.org/r/1491488362-27198-1-git-send-email-joro@8bytes.org
commit 8eabf42ae5237e6b699aeac687b5b629e3537c8d upstream.
Kernel text KASLR is separated into physical address and virtual
address randomization. And for virtual address randomization, we
only randomiza to get an offset between 16M and KERNEL_IMAGE_SIZE.
So the initial value of 'virt_addr' should be LOAD_PHYSICAL_ADDR,
but not the original kernel loading address 'output'.
The bug will cause kernel boot failure if kernel is loaded at a different
position than the address, 16M, which is decided at compiled time.
Kexec/kdump is such practical case.
To fix it, just assign LOAD_PHYSICAL_ADDR to virt_addr as initial
value.
Tested-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Baoquan He <bhe@redhat.com>
Fixes: 8391c73 ("x86/KASLR: Randomize virtual address separately")
Link: http://lkml.kernel.org/r/1498567146-11990-3-git-send-email-bhe@redhat.com
commit 9e25ebfe56ece7541cd10a20d715cbdd148a2e06 upstream.
The pmd containing memblock_limit is cleared by prepare_page_table()
which creates the opportunity for early_alloc() to allocate unmapped
memory if memblock_limit is not pmd aligned causing a boot-time hang.
Commit 965278dcb8ab ("ARM: 8356/1: mm: handle non-pmd-aligned end of RAM")
attempted to resolve this problem, but there is a path through the
adjust_lowmem_bounds() routine where if all memory regions start and
end on pmd-aligned addresses the memblock_limit will be set to
arm_lowmem_limit.
Since arm_lowmem_limit can be affected by the vmalloc early parameter,
the value of arm_lowmem_limit may not be pmd-aligned. This commit
corrects this oversight such that memblock_limit is always rounded
down to pmd-alignment.
Fixes: 965278dcb8ab ("ARM: 8356/1: mm: handle non-pmd-aligned end of RAM")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit cb7cf772d83d2d4e6995c5bb9e0fb59aea8f7080 upstream.
The BAD_MADT_GICC_ENTRY() macro checks if a GICC MADT entry passes
muster from an ACPI specification standpoint. Current macro detects the
MADT GICC entry length through ACPI firmware version (it changed from 76
to 80 bytes in the transition from ACPI 5.1 to ACPI 6.0 specification)
but always uses (erroneously) the ACPICA (latest) struct (ie struct
acpi_madt_generic_interrupt - that is 80-bytes long) length to check if
the current GICC entry memory record exceeds the MADT table end in
memory as defined by the MADT table header itself, which may result in
false negatives depending on the ACPI firmware version and how the MADT
entries are laid out in memory (ie on ACPI 5.1 firmware MADT GICC
entries are 76 bytes long, so by adding 80 to a GICC entry start address
in memory the resulting address may well be past the actual MADT end,
triggering a false negative).
Fix the BAD_MADT_GICC_ENTRY() macro by reshuffling the condition checks
and update them to always use the firmware version specific MADT GICC
entry length in order to carry out boundary checks.
Fixes: b6cfb277378e ("ACPI / ARM64: add BAD_MADT_GICC_ENTRY() macro")
Reported-by: Julien Grall <julien.grall@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Julien Grall <julien.grall@arm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Al Stone <ahs3@redhat.com>
commit 06e1a5cc570703796ff1bd3a712e8e3b15c6bb0d upstream.
The manufacturing information is stored in the EEPROM. This chip
is an AT24C64 not not (nor has it ever been) 24C02. This patch will
correctly address the EEPROM to read the entire contents and not just
256 bytes (of 0xff).
Fixes: 5e3447a29a38 ("ARM: dts: LogicPD Torpedo: Add AT24 EEPROM Support")
commit 04abaf07f6d5cdf22b7a478a86e706dfeeeef960 upstream.
Starting from commit 5de85b9d57ab ("PM / runtime: Re-init runtime PM
states at probe error and driver unbind") pm_runtime core now changes
device runtime_status back to after RPM_SUSPENDED after a probe defer.
Certain OMAP devices make use of "ti,no-idle-on-init" flag which causes
omap_device_enable to be called during the BUS_NOTIFY_ADD_DEVICE event
during probe, along with pm_runtime_set_active.
This call to pm_runtime_set_active typically will prevent a call to
pm_runtime_get in a driver probe function from re-enabling the
omap_device. However, in the case of a probe defer that happens before
the driver probe function is able to run, such as a missing pinctrl
states defer, pm_runtime_reinit will set the device as RPM_SUSPENDED and
then once driver probe is actually able to run, pm_runtime_get will see
the device as suspended and call through to the omap_device layer,
attempting to enable the already enabled omap_device and causing errors
like this:
omap-gpmc 50000000.gpmc: omap_device: omap_device_enable() called from
invalid state 1
omap-gpmc 50000000.gpmc: use pm_runtime_put_sync_suspend() in driver?
We can avoid this error by making sure the pm_runtime status of a device
matches the omap_device state before a probe attempt. By extending the
omap_device bus notifier to act on the BUS_NOTIFY_BIND_DRIVER event we
can check if a device is enabled in omap_device but with a pm_runtime
status of RPM_SUSPENDED and once again mark the device as RPM_ACTIVE to
avoid a second incorrect call to omap_device_enable.
Fixes: 5de85b9d57ab ("PM / runtime: Re-init runtime PM states at probe
Tested-by: Franklin S Cooper Jr. <fcooper@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
[ Upstream commit e991c24d68b8c0ba297eeb7af80b1e398e98c33f ]
We have quite a lot of code that depends on the order of the
__ctl_load inline assemby and subsequent memory accesses, like
e.g. disabling lowcore protection and the writing to lowcore.
Since the __ctl_load macro does not have memory barrier semantics, nor
any other dependencies the compiler is, theoretically, free to shuffle
code around. Or in other words: storing to lowcore could happen before
lowcore protection is disabled.
In order to avoid this class of potential bugs simply add a full
memory barrier to the __ctl_load macro.
[ Upstream commit 18e7a45af91acdde99d3aa1372cc40e1f8142f7b ]
As Peter suggested [1] rejecting non sampling PEBS events,
because they dont make any sense and could cause bugs
in the NMI handler [2].
[1] http://lkml.kernel.org/r/20170103094059.GC3093@worktop
[2] http://lkml.kernel.org/r/1482931866-6018-3-git-send-email-jolsa@kernel.org
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20170103142454.GA26251@krava
[ Upstream commit 453828625731d0ba7218242ef6ec88f59408f368 ]
info->si_addr is of type void __user *, so it should be compared against
something from the same address space.
This fixes the following sparse error:
arch/x86/mm/mpx.c:296:27: error: incompatible types in comparison expression (different address spaces)
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
[ Upstream commit 695085b4bc7603551db0b3da897b8bf9893ca218 ]
The Intel Denverton microserver uses a 25 MHz TSC crystal,
so we can derive its exact [*] TSC frequency
using CPUID and some arithmetic, eg.:
TSC: 1800 MHz (25000000 Hz * 216 / 3 / 1000000)
[*] 'exact' is only as good as the crystal, which should be +/- 20ppm
Signed-off-by: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/r/306899f94804aece6d8fa8b4223ede3b48dbb59c.1484287748.git.len.brown@intel.com
[ Upstream commit 41c066f2c4d436c535616fe182331766c57838f0 ]
When CONFIG_RANDOMIZE_MODULE_REGION_FULL=y, the offset between loaded
modules and the core kernel may exceed 4 GB, putting symbols exported
by the core kernel out of the reach of the ordinary adrp/add instruction
pairs used to generate relative symbol references. So make the adr_l
macro emit a movz/movk sequence instead when executing in module context.
While at it, remove the pointless special case for the stack pointer.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Upstream commit ad5013d5699d30ded0cdbbc68b93b2aa28222c6e ]
When x86_pmu.num_counters is 32 the shift of the integer constant 1 is
exceeding 32bit and therefor undefined behaviour.
Fix this by shifting 1ULL instead of 1.
Reported-by: CoverityScan CID#1192105 ("Bad bit shift operation")
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/20170111114310.17928-1-colin.king@canonical.com
code
[ Upstream commit 6d6daa20945f3f598e56e18d1f926c08754f5801 ]
hswep_uncore_cpu_init() uses a hardcoded physical package id 0 for the boot
cpu. This works as long as the boot CPU is actually on the physical package
0, which is normaly the case after power on / reboot.
But it fails with a NULL pointer dereference when a kdump kernel is started
on a secondary socket which has a different physical package id because the
locigal package translation for physical package 0 does not exist.
Use the logical package id of the boot cpu instead of hard coded 0.
[ tglx: Rewrote changelog once more ]
Fixes: cf6d445f6897 ("perf/x86/uncore: Track packages, not per CPU data")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Harish Chegondi <harish.chegondi@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1483628965-2890-1-git-send-email-prarit@redhat.com
[ Upstream commit 387bbc974f6adf91aa635090f73434ed10edd915 ]
We give up recovery on permanent error, simply shutdown the affected
devices and remove them. If the devices can't be put into quiet state,
they spew more traffic that is likely to cause another unexpected EEH
error. This was observed on "p8dtu2u" machine:
0002:00:00.0 PCI bridge: IBM Device 03dc
0002:01:00.0 Ethernet controller: Intel Corporation \
Ethernet Controller X710/X557-AT 10GBASE-T (rev 02)
0002:01:00.1 Ethernet controller: Intel Corporation \
0002:01:00.2 Ethernet controller: Intel Corporation \
0002:01:00.3 Ethernet controller: Intel Corporation \
On P8 PowerNV platform, the IO path is frozen when shutdowning the
devices, meaning the memory registers are inaccessible. It is why
the devices can't be put into quiet state before removing them.
This fixes the issue by enabling IO path prior to putting the devices
into quiet state.
Reported-by: Pridhiviraj Paidipeddi <ppaidipe@linux.vnet.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Acked-by: Russell Currey <ruscur@russell.cc>
[ Upstream commit 4e71de7986386d5fd3765458f27d612931f27f5e ]
The CPU hotplug function intel_pmu_cpu_starting() sets
cpu_hw_events.excl_thread_id unconditionally to 1 when the shared exclusive
counters data structure is already availabe for the sibling thread.
This works during the boot process because the first sibling gets threadid
0 assigned and the second sibling which shares the data structure gets 1.
But when the first thread of the core is offlined and onlined again it
shares the data structure with the second thread and gets exclusive thread
id 1 assigned as well.
Prevent this by checking the threadid of the already online thread.
[ tglx: Rewrote changelog ]
Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com>
Cc: NuoHan Qiao <qiaonuohan@huawei.com>
Cc: ak@linux.intel.com
Cc: peterz@infradead.org
Cc: kan.liang@intel.com
Cc: dave.hansen@linux.intel.com
Cc: eranian@google.com
Cc: qiaonuohan@huawei.com
Cc: davidcc@google.com
Cc: guohanjun@huawei.com
Link: http://lkml.kernel.org/r/1484536871-3131-1-git-send-email-zhouchengming1@huawei.com
[ Upstream commit ce2e852ecc9a42e4b8dabb46025cfef63209234a ]
emulator_fix_hypercall() replaces hypercall with vmcall instruction,
but it does not handle GP exception properly when writes the new instruction.
It can return X86EMUL_PROPAGATE_FAULT without setting exception information.
This leads to incorrect emulation and triggers
WARN_ON(ctxt->exception.vector > 0x1f) in x86_emulate_insn()
as discovered by syzkaller fuzzer:
WARNING: CPU: 2 PID: 18646 at arch/x86/kvm/emulate.c:5558
Call Trace:
warn_slowpath_null+0x2c/0x40 kernel/panic.c:582
x86_emulate_insn+0x16a5/0x4090 arch/x86/kvm/emulate.c:5572
x86_emulate_instruction+0x403/0x1cc0 arch/x86/kvm/x86.c:5618
emulate_instruction arch/x86/include/asm/kvm_host.h:1127 [inline]
handle_exception+0x594/0xfd0 arch/x86/kvm/vmx.c:5762
vmx_handle_exit+0x2b7/0x38b0 arch/x86/kvm/vmx.c:8625
vcpu_enter_guest arch/x86/kvm/x86.c:6888 [inline]
vcpu_run arch/x86/kvm/x86.c:6947 [inline]
Set exception information when write in emulator_fix_hypercall() fails.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: kvm@vger.kernel.org
Cc: syzkaller@googlegroups.com
[ Upstream commit feb3cbea0946c67060e2d5bcb7499b0a6f6700fe ]
OdroidC2 GbE link breaks under heavy tx transfer. This happens even if the
MAC does not enable Energy Efficient Ethernet (No Low Power state Idle on
the Tx path). The problem seems to come from the phy Rx path, entering the
LPI state.
Disabling EEE advertisement on the phy prevent this feature to be
negociated with the link partner and solve the issue.
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
[ Upstream commit 7a7dc961a28b965a0d0303c2e989df17b411708b ]
Error queues use a non-zero first word to detect if the queues are full.
Using pages that have not been zeroed may result in false positive
overflow events. These queues are set up once during boot so zeroing
all mondo and error queue pages is safe.
Note that the false positive overflow does not always occur because the
page allocation for these queues is so early in the boot cycle that
higher number CPUs get fresh pages. It is only when traps are serviced
with lower number CPUs who were given already used pages that this issue
is exposed.
Signed-off-by: Liam R. Howlett <Liam.Howlett@Oracle.com>
[ Upstream commit 047487241ff59374fded8c477f21453681f5995c ]
User processes trying to access an invalid memory address via PIO will
receive a SIGBUS signal instead of causing a panic. Memory errors will
receive a SIGKILL since a SIGBUS may result in a coredump which may
attempt to repeat the faulting access.
sync_global_pgds()
commit fc5f9d5f151c9fff21d3d1d2907b888a5aec3ff7 upstream.
Jeff Moyer reported that on his system with two memory regions 0~64G and
1T~1T+192G, and kernel option "memmap=192G!1024G" added, enabling KASLR
will make the system hang intermittently during boot. While adding 'nokaslr'
won't.
The back trace is:
Oops: 0000 [#1] SMP
RIP: memcpy_erms()
Call Trace:
pmem_rw_page()
bdev_read_page()
do_mpage_readpage()
mpage_readpages()
blkdev_readpages()
__do_page_cache_readahead()
force_page_cache_readahead()
page_cache_sync_readahead()
generic_file_read_iter()
blkdev_read_iter()
__vfs_read()
vfs_read()
SyS_read()
entry_SYSCALL_64_fastpath()
This crash happens because the for loop count calculation in sync_global_pgds()
is not correct. When a mapping area crosses PGD entries, we should
calculate the starting address of region which next PGD covers and assign
it to next for loop count, but not add PGDIR_SIZE directly. The old
code works right only if the mapping area is an exact multiple of PGDIR_SIZE,
otherwize the end region could be skipped so that it can't be synchronized
to all other processes from kernel PGD init_mm.pgd.
In Jeff's system, emulated pmem area [1024G, 1216G) is smaller than
PGDIR_SIZE. While 'nokaslr' works because PAGE_OFFSET is 1T aligned, it
makes this area be mapped inside one PGD entry. With KASLR enabled,
this area could cross two PGD entries, then the next PGD entry won't
be synced to all other processes. That is why we saw empty PGD.
Fix it.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Jinbum Park <jinb.park7@gmail.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Thomas Garnier <thgarnie@google.com>
Cc: Yasuaki Ishimatsu <yasu.isimatu@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1493864747-8506-1-git-send-email-bhe@redhat.com
commit d8550860d910c6b7b70f830f59003b33daaa52c9 upstream.
When the scheduler sets TIF_NEED_RESCHED & we call into the scheduler
from arch/mips/kernel/entry.S we disable interrupts. This is true
regardless of whether we reach work_resched from syscall_exit_work,
resume_userspace or by looping after calling schedule(). Although we
disable interrupts in these paths we don't call trace_hardirqs_off()
before calling into C code which may acquire locks, and we therefore
leave lockdep with an inconsistent view of whether interrupts are
disabled or not when CONFIG_PROVE_LOCKING & CONFIG_DEBUG_LOCKDEP are
both enabled.
Without tracing this interrupt state lockdep will print warnings such
as the following once a task returns from a syscall via
syscall_exit_partial with TIF_NEED_RESCHED set:
[ 49.927678] ------------[ cut here ]------------
[ 49.934445] WARNING: CPU: 0 PID: 1 at kernel/locking/lockdep.c:3687 check_flags.part.41+0x1dc/0x1e8
[ 49.946031] DEBUG_LOCKS_WARN_ON(current->hardirqs_enabled)
[ 49.946355] CPU: 0 PID: 1 Comm: init Not tainted 4.10.0-00439-gc9fd5d362289-dirty #197
[ 49.963505] Stack : 0000000000000000 ffffffff81bb5d6a 0000000000000006 ffffffff801ce9c4
[ 49.974431] 0000000000000000 0000000000000000 0000000000000000 000000000000004a
[ 49.985300] ffffffff80b7e487 ffffffff80a24498 a8000000ff160000 ffffffff80ede8b8
[ 49.996194] 0000000000000001 0000000000000000 0000000000000000 0000000077c8030c
[ 50.007063] 000000007fd8a510 ffffffff801cd45c 0000000000000000 a8000000ff127c88
[ 50.017945] 0000000000000000 ffffffff801cf928 0000000000000001 ffffffff80a24498
[ 50.028827] 0000000000000000 0000000000000001 0000000000000000 0000000000000000
[ 50.039688] 0000000000000000 a8000000ff127bd0 0000000000000000 ffffffff805509bc
[ 50.050575] 00000000140084e0 0000000000000000 0000000000000000 0000000000040a00
[ 50.061448] 0000000000000000 ffffffff8010e1b0 0000000000000000 ffffffff805509bc
[ 50.072327] ...
[ 50.076087] Call Trace:
[ 50.079869] [<ffffffff8010e1b0>] show_stack+0x80/0xa8
[ 50.086577] [<ffffffff805509bc>] dump_stack+0x10c/0x190
[ 50.093498] [<ffffffff8015dde0>] __warn+0xf0/0x108
[ 50.099889] [<ffffffff8015de34>] warn_slowpath_fmt+0x3c/0x48
[ 50.107241] [<ffffffff801c15b4>] check_flags.part.41+0x1dc/0x1e8
[ 50.114961] [<ffffffff801c239c>] lock_is_held_type+0x8c/0xb0
[ 50.122291] [<ffffffff809461b8>] __schedule+0x8c0/0x10f8
[ 50.129221] [<ffffffff80946a60>] schedule+0x30/0x98
[ 50.135659] [<ffffffff80106278>] work_resched+0x8/0x34
[ 50.142397] ---[ end trace 0cb4f6ef5b99fe21 ]---
[ 50.148405] possible reason: unannotated irqs-off.
[ 50.154600] irq event stamp: 400463
[ 50.159566] hardirqs last enabled at (400463): [<ffffffff8094edc8>] _raw_spin_unlock_irqrestore+0x40/0xa8
[ 50.171981] hardirqs last disabled at (400462): [<ffffffff8094eb98>] _raw_spin_lock_irqsave+0x30/0xb0
[ 50.183897] softirqs last enabled at (400450): [<ffffffff8016580c>] __do_softirq+0x4ac/0x6a8
[ 50.195015] softirqs last disabled at (400425): [<ffffffff80165e78>] irq_exit+0x110/0x128
Fix this by using the TRACE_IRQS_OFF macro to call trace_hardirqs_off()
when CONFIG_TRACE_IRQFLAGS is enabled. This is done before invoking
schedule() following the work_resched label because:
1) Interrupts are disabled regardless of the path we take to reach
work_resched() & schedule().
2) Performing the tracing here avoids the need to do it in paths which
disable interrupts but don't call out to C code before hitting a
path which uses the RESTORE_SOME macro that will call
trace_hardirqs_on() or trace_hardirqs_off() as appropriate.
We call trace_hardirqs_on() using the TRACE_IRQS_ON macro before calling
syscall_trace_leave() for similar reasons, ensuring that lockdep has a
consistent view of state after we re-enable interrupts.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15385/
commit 161c51ccb7a6faf45ffe09aa5cf1ad85ccdad503 upstream.
We allocate memory for a ready_count variable per-CPU, which is accessed
via a cached non-coherent TLB mapping to perform synchronisation between
threads within the core using LL/SC instructions. In order to ensure
that the variable is contained within its own data cache line we
allocate 2 lines worth of memory & align the resulting pointer to a line
boundary. This is however unnecessary, since kmalloc is guaranteed to
return memory which is at least cache-line aligned (see
ARCH_DMA_MINALIGN). Stop the redundant manual alignment.
Besides cleaning up the code & avoiding needless work, this has the side
effect of avoiding an arithmetic error found by Bryan on 64 bit systems
due to the 32 bit size of the former dlinesz. This led the ready_count
variable to have its upper 32b cleared erroneously for MIPS64 kernels,
causing problems when ready_count was later used on MIPS64 via cpuidle.
Fixes: 3179d37ee1ed ("MIPS: pm-cps: add PM state entry code for CPS systems")
Reported-by: Bryan O'Donoghue <bryan.odonoghue@imgtec.com>
Reviewed-by: Bryan O'Donoghue <bryan.odonoghue@imgtec.com>
Tested-by: Bryan O'Donoghue <bryan.odonoghue@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15383/
commit 854236363370995a609a10b03e35fd3dc5e9e4a1 upstream.
Since commit 81a76d7119f6 ("MIPS: Avoid using unwind_stack() with
usermode") show_backtrace() invokes the raw backtracer when
cp0_status & ST0_KSU indicates user mode to fix issues on EVA kernels
where user and kernel address spaces overlap.
However this is used by show_stack() which creates its own pt_regs on
the stack and leaves cp0_status uninitialised in most of the code paths.
This results in the non deterministic use of the raw back tracer
depending on the previous stack content.
show_stack() deals exclusively with kernel mode stacks anyway, so
explicitly initialise regs.cp0_status to KSU_KERNEL (i.e. 0) to ensure
we get a useful backtrace.
Fixes: 81a76d7119f6 ("MIPS: Avoid using unwind_stack() with usermode")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/16656/
commit 25d8b92e0af75d72ce8b99e63e5a449cc0888efa upstream.
In this sequence the 'move' is assumed in the delay slot of the 'beq',
but head.S is in reorder mode and the former gets pushed one 'nop'
farther by the assembler.
The corrected behavior made booting with an UHI supplied dtb erratic.
Fixes: 15f37e158892 ("MIPS: store the appended dtb address in a variable")
Signed-off-by: Karl Beldan <karl.beldan+oss@gmail.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Gorski <jogo@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/16614/
commit dbb236c1ceb697a559e0694ac4c9e7b9131d0b16 upstream.
Recently vDSO support for CLOCK_MONOTONIC_RAW was added in
49eea433b326 ("arm64: Add support for CLOCK_MONOTONIC_RAW in
clock_gettime() vDSO"). Noticing that the core timekeeping code
never set tkr_raw.xtime_nsec, the vDSO implementation didn't
bother exposing it via the data page and instead took the
unshifted tk->raw_time.tv_nsec value which was then immediately
shifted left in the vDSO code.
Unfortunately, by accellerating the MONOTONIC_RAW clockid, it
uncovered potential 1ns time inconsistencies caused by the
timekeeping core not handing sub-ns resolution.
Now that the core code has been fixed and is actually setting
tkr_raw.xtime_nsec, we need to take that into account in the
vDSO by adding it to the shifted raw_time value, in order to
fix the user-visible inconsistency. Rather than do that at each
use (and expand the data page in the process), instead perform
the shift/addition operation when populating the data page and
remove the shift from the vDSO code entirely.
[jstultz: minor whitespace tweak, tried to improve commit
message to make it more clear this fixes a regression]
Reported-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Tested-by: Daniel Mentz <danielmentz@google.com>
Acked-by: Kevin Brodsky <kevin.brodsky@arm.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Link: http://lkml.kernel.org/r/1496965462-20003-4-git-send-email-john.stultz@linaro.org
commit d89ba5353f301971dd7d2f9fdf25c4432728f38e upstream.
On Power9, trying to use data breakpoints throws the splat shown
below. This is because the check for a data breakpoint in DSISR is in
do_hash_page(), which is not called when in Radix mode.
Unable to handle kernel paging request for data at address 0xc000000000e19218
Faulting instruction address: 0xc0000000001155e8
cpu 0x0: Vector: 300 (Data Access) at [c0000000ef1e7b20]
pc: c0000000001155e8: find_pid_ns+0x48/0xe0
lr: c000000000116ac4: find_task_by_vpid+0x44/0x90
sp: c0000000ef1e7da0
msr: 9000000000009033
dar: c000000000e19218
dsisr: 400000
Move the check to handle_page_fault() so as to catch data breakpoints
in both Hash and Radix MMU modes.
We have to change the check in do_hash_page() against 0xa410 to use
0xa450, so as to include the value of (DSISR_DABRMATCH << 16).
There are two sites that call handle_page_fault() when in Radix, both
already pass DSISR in r4.
Fixes: caca285e5ab4 ("powerpc/mm/radix: Use STD_MMU_64 to properly isolate hash related code")
Reported-by: Shriya R. Kulkarni <shriykul@in.ibm.com>
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
[mpe: Fix the fall-through case on hash, we need to reload DSISR]
commit a9f8553e935f26cb5447f67e280946b0923cd2dc upstream.
This fixes a crash when function_graph and jprobes are used together.
This is essentially commit 237d28db036e ("ftrace/jprobes/x86: Fix
conflict between jprobes and function graph tracing"), but for powerpc.
Jprobes breaks function_graph tracing since the jprobe hook needs to use
jprobe_return(), which never returns back to the hook, but instead to
the original jprobe'd function. The solution is to momentarily pause
function_graph tracing before invoking the jprobe hook and re-enable it
when returning back to the original jprobe'd function.
Fixes: 6794c78243bf ("powerpc64: port of the function graph tracer")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit ca8efa1df1d15a1795a2da57f9f6aada6ed6b946 upstream.
This adds code to save the values of three SPRs (special-purpose
registers) used by userspace to control event-based branches (EBBs),
which are essentially interrupts that get delivered directly to
userspace. These registers are loaded up with guest values when
entering the guest, and their values are saved when exiting the
guest, but we were not saving the host values and restoring them
before going back to userspace.
On POWER8 this would only affect userspace programs which explicitly
request the use of EBBs and also use the KVM_RUN ioctl, since the
only source of EBBs on POWER8 is the PMU, and there is an explicit
enable bit in the PMU registers (and those PMU registers do get
properly context-switched between host and guest). On POWER9 there
is provision for externally-generated EBBs, and these are not subject
to the control in the PMU registers.
Since these registers only affect userspace, we can save them when
we first come in from userspace and restore them before returning to
userspace, rather than saving/restoring the host values on every
guest entry/exit. Similarly, we don't need to worry about their
values on offline secondary threads since they execute in the context
of the idle task, which never executes in userspace.
Fixes: b005255e12a3 ("KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs", 2014-01-08)
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit 46a704f8409f79fd66567ad3f8a7304830a84293 upstream.
If userspace attempts to call the KVM_RUN ioctl when it has hardware
transactional memory (HTM) enabled, the values that it has put in the
HTM-related SPRs TFHAR, TFIAR and TEXASR will get overwritten by
guest values. To fix this, we detect this condition and save those
SPR values in the thread struct, and disable HTM for the task. If
userspace goes to access those SPRs or the HTM facility in future,
a TM-unavailable interrupt will occur and the handler will reload
those SPRs and re-enable HTM.
If userspace has started a transaction and suspended it, we would
currently lose the transactional state in the guest entry path and
would almost certainly get a "TM Bad Thing" interrupt, which would
cause the host to crash. To avoid this, we detect this case and
return from the KVM_RUN ioctl with an EINVAL error, with the KVM
exit reason set to KVM_EXIT_FAIL_ENTRY.
commit addb63c18a0d52a9ce2611d039f981f7b6148d2b upstream.
For real-space designation asces the asce origin part is only a token.
The asce token origin must not be used to generate an effective
address for storage references. This however is erroneously done
within kvm_s390_shadow_tables().
Furthermore within the same function the wrong parts of virtual
addresses are used to generate a corresponding real address
(e.g. the region second index is used as region first index).
Both of the above can result in incorrect address translations. Only
for real space designations with a token origin of zero and addresses
below one megabyte the translation was correct.
Furthermore replace a "!asce.r" statement with a "!*fake" statement to
make it more obvious that a specific condition has nothing to do with
the architecture, but with the fake handling of real space designations.
Fixes: 3218f7094b6b ("s390/mm: support real-space for gmap shadows")
Cc: David Hildenbrand <david@redhat.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit fb3a5055cd7098f8d1dd0cd38d7172211113255f upstream.
Current DTLB load/store miss events (0x608/0x649) only counts 4K,2M and
4M page size.
Need to extend the events to support any page size (4K/2M/4M/1G).
The complete DTLB load/store miss events are:
DTLB_LOAD_MISSES.WALK_COMPLETED 0xe08
DTLB_STORE_MISSES.WALK_COMPLETED 0xe49
Signed-off-by: Kan Liang <Kan.liang@intel.com>
Link: http://lkml.kernel.org/r/20170619142609.11058-1-kan.liang@intel.com
commit bf05fc25f268cd62f147f368fe65ad3e5b04fe9f upstream.
When a kthread calls call_usermodehelper() the steps are:
1. allocate current->mm
2. load_elf_binary()
3. populate current->thread.regs
While doing this, interrupts are not disabled. If there is a perf
interrupt in the middle of this process (i.e. step 1 has completed
but not yet reached to step 3) and if perf tries to read userspace
regs, kernel oops with following log:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc0000000000da0fc
Call Trace:
perf_output_sample_regs+0x6c/0xd0
perf_output_sample+0x4e4/0x830
perf_event_output_forward+0x64/0x90
__perf_event_overflow+0x8c/0x1e0
record_and_restart+0x220/0x5c0
perf_event_interrupt+0x2d8/0x4d0
performance_monitor_exception+0x54/0x70
performance_monitor_common+0x158/0x160
--- interrupt: f01 at avtab_search_node+0x150/0x1a0
LR = avtab_search_node+0x100/0x1a0
load_elf_binary+0x6e8/0x15a0
search_binary_handler+0xe8/0x290
do_execveat_common.isra.14+0x5f4/0x840
call_usermodehelper_exec_async+0x170/0x210
ret_from_kernel_thread+0x5c/0x7c
Fix it by setting abi to PERF_SAMPLE_REGS_ABI_NONE when userspace
pt_regs are not set.
Fixes: ed4a4ef85cf5 ("powerpc/perf: Add support for sampling interrupt register state")
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit bcd7c45e0d5a82be9a64b90050f0e09d41a50758 upstream.
The .its targets require information about the kernel binary, such as
its entry point, which is extracted from the vmlinux ELF. We therefore
require that the ELF is built before the .its files are generated.
Declare this requirement in the Makefile such that make will ensure this
is always the case, otherwise in corner cases we can hit issues as the
.its is generated with an incorrect (either invalid or stale) entry
point.
Fixes: cf2a5e0bb4c6 ("MIPS: Support generating Flattened Image Trees (.itb)")
Patchwork: https://patchwork.linux-mips.org/patch/16179/
commit 1a73d9310e093fc3adffba4d0a67b9fab2ee3f63 upstream.
The code handling the pop76 opcode (ie. bnezc & jialc instructions) in
__compute_return_epc_for_insn() needs to set the value of $31 in the
jialc case, which is encoded with rs = 0. However its check to
differentiate bnezc (rs != 0) from jialc (rs = 0) was unfortunately
backwards, meaning that if we emulate a bnezc instruction we clobber $31
& if we emulate a jialc instruction it actually behaves like a jic
instruction.
Fix this by inverting the check of rs to match the way the instructions
are actually encoded.
Fixes: 28d6f93d201d ("MIPS: Emulate the new MIPS R6 BNEZC and JIALC instructions")
Patchwork: https://patchwork.linux-mips.org/patch/16178/
commit 861ce4a3244c21b0af64f880d5bfe5e6e2fb9e4a upstream.
'__vmalloc_start_set' currently only gets set in initmem_init() when
!CONFIG_NEED_MULTIPLE_NODES. This breaks detection of vmalloc address
with virt_addr_valid() with CONFIG_NEED_MULTIPLE_NODES=y, causing
a kernel crash:
[mm/usercopy] 517e1fbeb6: kernel BUG at arch/x86/mm/physaddr.c:78!
Set '__vmalloc_start_set' appropriately for that case as well.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Fixes: dc16ecf7fd1f ("x86-32: use specific __vmalloc_start_set flag in __virt_addr_valid")
Link: http://lkml.kernel.org/r/1494278596-30373-1-git-send-email-labbott@redhat.com
commit b5c3206190f1fddd100b3060eb15f0d775ffeab8 upstream.
My static checker complains that if "lvl" is ULONG_MAX (this is 64 bit)
then some of the strings will overflow. I don't know if that's possible
but it seems simple enough to make the buffers slightly larger.
Cc: Waldemar Brodkorb <wbx@openadk.org>
commit c0e7bb38c07cbd8269549ee0a0566021a3c729de upstream.
For most cases a protection exception in the host (e.g. copy
on write or dirty tracking) on the sie instruction will indicate
an instruction length of 4. Turns out that there are some corner
cases (e.g. runtime instrumentation) where this is not necessarily
true and the ILC is unpredictable.
Let's replace our 4 byte rewind_pad with 3 byte nops to prepare for
all possible ILCs.
commit e5c86679d5e864947a52fb31e45a425dea3e7fa9 upstream.
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
[ Upstream commit 78f824d4312a8944f5340c6b161bba3bf2c81096 ]
This is needed on HS38 cores, for setting up IO-Coherency aperture properly
The polling could perturb the caches and coherecy fabric which could be
wrong in the small window when Master is setting up IOC aperture etc
in arc_cache_init()
We do it only for ARCv2 based builds to not affect EZChip ARCompact
based platform.
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[ Upstream commit bf02454a741b58682a82c314a9a46bed930ed2f7 ]
For run-on-reset SMP configs, non master cores call a routine which
waits until Master gives it a "go" signal (currently using a shared
mem flag). The same routine then jumps off the well known entry point of
all non Master cores i.e. @first_lines_of_secondary
This patch moves out the last part into one single place in early boot
code.
This is better in terms of absraction (the wait API only waits) and
returns, leaving out the "jump off to" part.
In actual implementation this requires some restructuring of the early
boot code as well as Master now jumps to BSS setup explicitly,
vs. falling thru into it before.
Technically this patch doesn't cause any functional change, it just
moves the ugly #ifdef'ry from assembly code to "C"
[ Upstream commit 4180c4c170a5a33b9987b314d248a9d572d89ab0 ]
Some more atomic64 operations were missing and as a result frv
allmodconfig was failing. Add the missing operations.
Link: http://lkml.kernel.org/r/1485193844-12850-1-git-send-email-sudip.mukherjee@codethink.co.uk
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
[ Upstream commit 545d58f677b21401f6de1ac12c25cc109f903ace ]
The build of frv allmodconfig was failing with the error:
lib/atomic64_test.c:209:9: error:
implicit declaration of function 'atomic64_add_unless'
All the atomic64 operations were defined in frv, but
atomic64_add_unless() was not done.
Implement atomic64_add_unless() as done in other arches.
Link: http://lkml.kernel.org/r/1484781236-6698-1-git-send-email-sudipm.mukherjee@gmail.com
[ Upstream commit 3705ccfdd1e8b539225ce20e3925a945cc788d67 ]
When CONFIG_FPU is not enabled on arch/mn10300, <asm/switch_to.h> causes
a build error with a call to fpu_save():
kernel/built-in.o: In function `.L410':
core.c:(.sched.text+0x28a): undefined reference to `fpu_save'
Fix this by including <asm/fpu.h> in <asm/switch_to.h> so that an empty
static inline fpu_save() is defined.
Link: http://lkml.kernel.org/r/dc421c4f-4842-4429-1b99-92865c2f24b6@infradead.org
Reviewed-by: David Howells <dhowells@redhat.com>
