commit f3747379accba8e95d70cec0eae0582c8c182050 upstream.
SYSENTER emulation is broken in several ways:
1. It misses the case of 16-bit code segments completely (CVE-2015-0239).
2. MSR_IA32_SYSENTER_CS is checked in 64-bit mode incorrectly (bits 0 and 1 can
still be set without causing #GP).
3. MSR_IA32_SYSENTER_EIP and MSR_IA32_SYSENTER_ESP are not masked in
legacy-mode.
4. There is some unneeded code.
Fix it.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
[zhangzhiqiang: backport to 3.10:
- adjust context
- in 3.10 context "ctxt->eflags &= ~(EFLG_VM | EFLG_IF | EFLG_RF)" is replaced by
"ctxt->eflags &= ~(EFLG_VM | EFLG_IF)" in upstream, which was changed by another commit.
- After the above adjustments, becomes same to the original patch:
https://github.com/torvalds/linux/commit/f3747379accba8e95d70cec0eae0582c8c182050
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
commit 80313b3078fcd2ca51970880d90757f05879a193 upstream.
The ASRock Q1900DC-ITX mainboard (Baytrail-D) hangs randomly in
both BIOS and UEFI mode while rebooting unless reboot=pci is
used. Add a quirk to reboot via the pci method.
The problem is very intermittent and hard to debug, it might succeed
rebooting just fine 40 times in a row - but fails half a dozen times
the next day. It seems to be slightly less common in BIOS CSM mode
than native UEFI (with the CSM disabled), but it does happen in either
mode. Since I've started testing this patch in late january, rebooting
has been 100% reliable.
Most of the time it already hangs during POST, but occasionally it
might even make it through the bootloader and the kernel might even
start booting, but then hangs before the mode switch. The same symptoms
occur with grub-efi, gummiboot and grub-pc, just as well as (at least)
kernel 3.16-3.19 and 4.0-rc6 (I haven't tried older kernels than 3.16).
Upgrading to the most current mainboard firmware of the ASRock
Q1900DC-ITX, version 1.20, does not improve the situation.
( Searching the web seems to suggest that other Bay Trail-D mainboards
might be affected as well. )
Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/20150330224427.0fb58e42@mir
commit 6914e1e3f63caa829431160f0f7093292daef2d5 upstream.
The regfile provided to SA_SIGINFO signal handler as ucontext was off by
one due to pt_regs gutter cleanups in 2013.
Before handling signal, user pt_regs are copied onto user_regs_struct and copied
back later. Both structs are binary compatible. This was all fine until
commit 2fa919045b72 (ARC: pt_regs update #2) which removed the empty stack slot
at top of pt_regs (corresponding to first pad) and made the corresponding
fixup in struct user_regs_struct (the pad in there was moved out of
@scratch - not removed altogether as it is part of ptrace ABI)
struct user_regs_struct {
+ long pad;
struct {
- long pad;
long bta, lp_start, lp_end,....
} scratch;
This meant that now user_regs_struct was off by 1 reg w.r.t pt_regs and
signal code needs to user_regs_struct.scratch to reflect it as pt_regs,
which is what this commit does.
This problem was hidden for 2 years, because both save/restore, despite
using wrong location, were using the same location. Only an interim
inspection (reproducer below) exposed the issue.
void handle_segv(int signo, siginfo_t *info, void *context)
ucontext_t *uc = context;
struct user_regs_struct *regs = &(uc->uc_mcontext.regs);
printf("regs %x %x\n", <=== prints 7 8 (vs. 8 9)
regs->scratch.r8, regs->scratch.r9);
int main()
struct sigaction sa;
sa.sa_sigaction = handle_segv;
sa.sa_flags = SA_SIGINFO;
sigemptyset(&sa.sa_mask);
sigaction(SIGSEGV, &sa, NULL);
asm volatile(
"mov r7, 7 \n"
"mov r8, 8 \n"
"mov r9, 9 \n"
"mov r10, 10 \n"
:::"r7","r8","r9","r10");
*((unsigned int*)0x10) = 0;
Fixes: 2fa919045b72ec892e "ARC: pt_regs update #2: Remove unused gutter at start of pt_regs"
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit aadca6fa4068ad1f92c492bc8507b7ed350825a2 upstream.
Certec BPC600 needs reboot=pci to actually reboot.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Li Aubrey <aubrey.li@linux.intel.com>
Cc: Dave Jones <davej@redhat.com>
Link: http://lkml.kernel.org/r/1399446114-2147-1-git-send-email-christian.gmeiner@gmail.com
commit e56e57f6613d5ed5c3127419341d1aa989a11971 upstream.
Grouping them by vendor should make it easier to spot duplicates.
Signed-off-by: Dave Jones <davej@fedoraproject.org>
Link: http://lkml.kernel.org/r/20131001203655.GA10719@redhat.com
commit b5eafc6f07c95e9f3dd047e72737449cb03c9956 upstream.
Two entries for the same system type were added, with two different vendor
names: 'Dell' and 'Dell, Inc.'.
Since a prefix match is being used by the DMI parsing code, we can eliminate
the latter as redundant.
Reported-by: "H. Peter Anvin" <hpa@zytor.com>
Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com>
Cc: holt@sgi.com
Link: http://lkml.kernel.org/r/1380216643-4683-1-git-send-email-masoud.sharbiani@gmail.com
commit f6ff04149637723261aa4738958b0098b929ee9e upstream.
We currently use the device tree update code in the kernel after resuming
from a suspend operation to re-sync the kernels view of the device tree with
that of the hypervisor. The code as it stands is not endian safe as it relies
on parsing buffers returned by RTAS calls that thusly contains data in big
endian format.
This patch annotates variables and structure members with __be types as well
as performing necessary byte swaps to cpu endian for data that needs to be
parsed.
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: Cyril Bur <cyrilbur@gmail.com>
commit e53f21bce4d35a93b23d8fa1a840860f6c74f59e upstream.
The idle_task_exit() function may call switch_mm() with next ==
&init_mm. On arm64, init_mm.pgd cannot be used for user mappings, so
this patch simply sets the reserved TTBR0.
Reported-by: Jon Medhurst (Tixy) <tixy@linaro.org>
Tested-by: Jon Medhurst (Tixy) <tixy@linaro.org>
commit d97eb8966c91f2c9d05f0a22eb89ed5b76d966d1 upstream.
When an interrupt is migrated away from a cpu it will stay
in its vector_irq array until smp_irq_move_cleanup_interrupt
succeeded. The cfg->move_in_progress flag is cleared already
when the IPI was sent.
When the interrupt is destroyed after migration its 'struct
irq_desc' is freed and the vector_irq arrays are cleaned up.
But since cfg->move_in_progress is already 0 the references
at cpus before the last migration will not be cleared. So
this would leave a reference to an already destroyed irq
alive.
When the cpu is taken down at this point, the
check_irq_vectors_for_cpu_disable() function finds a valid irq
number in the vector_irq array, but gets NULL for its
descriptor and dereferences it, causing a kernel panic.
This has been observed on real systems at shutdown. Add a
check to check_irq_vectors_for_cpu_disable() for a valid
'struct irq_desc' to prevent this issue.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Reviewed-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Jan Beulich <JBeulich@suse.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: alnovak@suse.com
Cc: joro@8bytes.org
Link: http://lkml.kernel.org/r/20150204132754.GA10078@suse.de
commit 1028ccf560b97adbf272381a61a67e17d44d1054 upstream.
Declaring sys_call_table as a pointer causes the compiler to generate
the wrong lookup code in arch_syscall_addr().
<arch_syscall_addr>:
lis r9,-16384
rlwinm r3,r3,2,0,29
- lwz r11,30640(r9)
- lwzx r3,r11,r3
+ addi r9,r9,30640
+ lwzx r3,r9,r3
blr
The actual sys_call_table symbol, declared in assembler, is an
array. If we lie about that to the compiler we get the wrong code
generated, as above.
This definition seems only to be used by the syscall tracing code in
kernel/trace/trace_syscalls.c. With this patch I can successfully use
the syscall tracepoints:
bash-3815 [002] .... 333.239082: sys_write -> 0x2
bash-3815 [002] .... 333.239087: sys_dup2(oldfd: a, newfd: 1)
bash-3815 [002] .... 333.239088: sys_dup2 -> 0x1
bash-3815 [002] .... 333.239092: sys_fcntl(fd: a, cmd: 1, arg: 0)
bash-3815 [002] .... 333.239093: sys_fcntl -> 0x1
bash-3815 [002] .... 333.239094: sys_close(fd: a)
bash-3815 [002] .... 333.239094: sys_close -> 0x0
Signed-off-by: Romeo Cane <romeo.cane.ext@coriant.com>
commit f84598bd7c851f8b0bf8cd0d7c3be0d73c432ff4 upstream.
mc_saved_tmp is a static array allocated on the stack, we need to make
sure mc_saved_count stays within its bounds, otherwise we're overflowing
the stack in _save_mc(). A specially crafted microcode header could lead
to a kernel crash or potentially kernel execution.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/1422964824-22056-1-git-send-email-quentin.casasnovas@oracle.com
commit 875ebe940d77a41682c367ad799b4f39f128d3fa upstream.
Anton has a busy ppc64le KVM box where guests sometimes hit the infamous
"kernel BUG at kernel/smpboot.c:134!" issue during boot:
BUG_ON(td->cpu != smp_processor_id());
Basically a per CPU hotplug thread scheduled on the wrong CPU. The oops
output confirms it:
CPU: 0
Comm: watchdog/130
The problem is that we aren't ensuring the CPU active bit is set for the
secondary before allowing the master to continue on. The master unparks
the secondary CPU's kthreads and the scheduler looks for a CPU to run
on. It calls select_task_rq() and realises the suggested CPU is not in
the cpus_allowed mask. It then ends up in select_fallback_rq(), and
since the active bit isnt't set we choose some other CPU to run on.
This seems to have been introduced by 6acbfb96976f "sched: Fix hotplug
vs. set_cpus_allowed_ptr()", which changed from setting active before
online to setting active after online. However that was in turn fixing a
bug where other code assumed an active CPU was also online, so we can't
just revert that fix.
The simplest fix is just to spin waiting for both active & online to be
set. We already have a barrier prior to set_cpu_online() (which also
sets active), to ensure all other setup is completed before online &
active are set.
Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()")
commit ded9477984690d026e46dd75e8157392cea3f13f upstream.
For LPAE, we have the following means for encoding writable or dirty
ptes:
L_PTE_DIRTY L_PTE_RDONLY
!pte_dirty && !pte_write 0 1
!pte_dirty && pte_write 0 1
pte_dirty && !pte_write 1 1
pte_dirty && pte_write 1 0
So we can't distinguish between writeable clean ptes and read only
ptes. This can cause problems with ptes being incorrectly flagged as
read only when they are writeable but not dirty.
This patch renumbers L_PTE_RDONLY from AP[2] to a software bit #58,
and adds additional logic to set AP[2] whenever the pte is read only
or not dirty. That way we can distinguish between clean writeable ptes
and read only ptes.
HugeTLB pages will use this new logic automatically.
We need to add some logic to Transparent HugePages to ensure that they
correctly interpret the revised pgprot permissions (L_PTE_RDONLY has
moved and no longer matches PMD_SECT_AP2). In the process of revising
THP, the names of the PMD software bits have been prefixed with L_ to
make them easier to distinguish from their hardware bit counterparts.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Jiri Slaby <jslaby@suse.cz> [dump.c is not in 3.12]
commit f2950706871c4b6e8c0f0d7c3f62d35930b8de63 upstream.
Long descriptors on ARM are 64 bits, and some pte functions such as
pte_dirty return a bitwise-and of a flag with the pte value. If the
flag to be tested resides in the upper 32 bits of the pte, then we run
into the danger of the result being dropped if downcast.
For example:
gather_stats(page, md, pte_dirty(*pte), 1);
where pte_dirty(*pte) is downcast to an int.
This patch introduces a new macro pte_isset which performs the bitwise
and, then performs a double logical invert (where needed) to ensure
predictable downcasting. The logical inverse pte_isclear is also
introduced.
Equivalent pmd functions for Transparent HugePages have also been
added.
commit efea3403d4b7c6d1dd5d5ac3234c161e8b314d66 upstream.
The definition of virt_addr_valid is that virt_addr_valid should
return true if and only if virt_to_page returns a valid pointer.
The current definition of virt_addr_valid only checks against the
virtual address range. There's no guarantee that just because a
virtual address falls bewteen PAGE_OFFSET and high_memory the
associated physical memory has a valid backing struct page. Follow
the example of other architectures and convert to pfn_valid to
verify that the virtual address is actually valid. The check for
an address between PAGE_OFFSET and high_memory is still necessary
as vmalloc/highmem addresses are not valid with virt_to_page.
Cc: Nicolas Pitre <nico@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
in atomic_cmpxchg().
commit 4dcc1cf7316a26e112f5c9fcca531ff98ef44700 upstream.
For atomic_cmpxchg(), the type of 'oldval' need be 'int' to match the
type of "*ptr" (used by 'ldrex' instruction) and 'old' (used by 'teq'
instruction).
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit 237f12337cfa2175474e4dd015bc07a25eb9080d upstream.
atomic* value is signed value, and atomic* functions need also process
signed value (parameter value, and return value), so 32-bit arm need
use 'long long' instead of 'u64'.
After replacement, it will also fix a bug for atomic64_add_negative():
"u64 is never less than 0".
The modifications are:
in vim, use "1,% s/\<u64\>/long long/g" command.
remove '__aligned(8)' which is useless for 64-bit.
be sure of 80 column limitation after replacement.
commit e8ef060b37c2d3cc5fd0c0edbe4e42ec1cb9768b upstream.
This allows the sdplite/Zebu images to run on OSCI simulation platform
Cc: <stable@vger.kernel.org> #3.10, 3.12, 3.14, 3.16
commit 63328070eff2f4fd730c86966a0dbc976147c39f upstream.
Currently BUG() uses .word or .hword to create the necessary illegal
instructions. However if we are building BE8 then these get swapped
by the linker into different illegal instructions in the text. This
means that the BUG() macro does not get trapped properly.
Change to using <asm/opcodes.h> to provide the necessary ARM instruction
building as we cannot rely on gcc/gas having the `.inst` instructions
which where added to try and resolve this issue (reported by Dave Martin
<Dave.Martin@arm.com>).
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
commit ebc0c74e76cec9c4dd860eb0ca1c0b39dc63c482 upstream.
Order of registers has changed in GDB moving from 6.8 to 7.5. This patch
updates KGDB to work properly with GDB 7.5, though makes it incompatible
with 6.8.
Signed-off-by: Anton Kolesov <Anton.Kolesov@synopsys.com>
commit 5c05483e2db91890faa9a7be0a831701a3f442d6 upstream.
There are certain test configuration of virtual platform which don't
have any real console device (uart/pgu). So add tty0 as a fallback console
device to allow system to boot and be accessible via telnet
Otherwise with ttyS0 as only console, but 8250 disabled in kernel build,
init chokes.
Reported-by: Anton Kolesov <akolesov@synopsys.com>
commit 85101af13bb854a6572fa540df7c7201958624b9 upstream.
ABIv2 kernels are failing to backtrace through the kernel. An example:
39.30% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
__GI___libc_read
The problem is in valid_next_sp() where we check that the new stack
pointer is at least STACK_FRAME_OVERHEAD below the previous one.
ABIv1 has a minimum stack frame size of 112 bytes consisting of 48 bytes
and 64 bytes of parameter save area. ABIv2 changes that to 32 bytes
with no paramter save area.
STACK_FRAME_OVERHEAD is in theory the minimum stack frame size,
but we over 240 uses of it, some of which assume that it includes
space for the parameter area.
We need to work through all our stack defines and rationalise them
but let's fix perf now by creating STACK_FRAME_MIN_SIZE and using
in valid_next_sp(). This fixes the issue:
30.64% readseek2_proce [kernel.kallsyms] [k] find_get_entry
--- find_get_entry
pagecache_get_page
generic_file_read_iter
new_sync_read
vfs_read
sys_read
syscall_exit
__GI___libc_read
Cc: stable@vger.kernel.org # 3.16+
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit bcec7c8da6b092b1ff3327fd83c2193adb12f684 upstream.
Get rid of the WANT_COMPAT_REG_H test and instead define both the 32-
and 64-bit register offset definitions at the same time with
MIPS{32,64}_ prefixes, then define the existing EF_* names to the
correct definitions for the kernel's bitness.
This patch is a prerequisite of the following bug fix patch.
Signed-off-by: Alex Smith <alex@alex-smith.me.uk>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7451/
commit cc824534d4fef0e46e4486d5c1e10d3c6b1ebadc upstream.
Looks like MUSB cable removal can cause wake-up interrupts to
stop working for device tree based booting at least for UART3
even as nothing is dynamically remuxed. This can be fixed by
calling reconfigure_io_chain() for device tree based booting
in hwmod code. Note that we already do that for legacy booting
if the legacy mux is configured.
My guess is that this is related to UART3 and MUSB ULPI
hsusb0_data0 and hsusb0_data1 support for Carkit mode that
somehow affect the configured IO chain for UART3 and require
rearming the wake-up interrupts.
In general, for device tree based booting, pinctrl-single
calls the rearm hook that in turn calls reconfigure_io_chain
so calling reconfigure_io_chain should not be needed from the
hwmod code for other events.
So let's limit the hwmod rearming of iochain only to
HWMOD_FORCE_MSTANDBY where MUSB is currently the only user
of it. If we see other devices needing similar changes we can
add more checks for it.
Cc: Paul Walmsley <paul@pwsan.com>
commit eadcc7208a2237016be7bdff4551ba7614da85c8 upstream.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 4b353a706a86598ba47307c47301c3c428b79e09 upstream.
On OMAP4 panda board, there have been several bug reports about boot
hang and lock-ups with CPU_IDLE enabled. The root cause of the issue
is missing interrupts while in idle state. Commit cb7094e8 {cpuidle / omap4 :
use CPUIDLE_FLAG_TIMER_STOP flag} moved the broadcast notifiers to common
code for right reasons but on OMAP4 which suffers from a nasty ROM code
bug with GIC, commit ff999b8a {ARM: OMAP4460: Workaround for ROM bug ..},
we loose interrupts which leads to issues like lock-up, hangs etc.
Patch reverts commit cb7094 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP
flag} and 54769d6 {cpuidle: OMAP4: remove timer broadcast initialization} to
avoid the issue. With this change, OMAP4 panda boards, the mentioned
issues are getting fixed. We no longer loose interrupts which was the cause
of the regression.
Fixes: cb7094e8 (cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag)
Fixes: ff999b8a (cpuidle: OMAP4: remove timer broadcast initialization)
Cc: Roger Quadros <rogerq@ti.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Reported-tested-by: Roger Quadros <rogerq@ti.com>
Reported-tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
commit 3901c1124ec5099254a9396085f7798153a7293f upstream.
An additional testcase found an issue with the last
series of patches applied: the fallback solution may
not save the iv value after operation. This very small
fix just makes sure the iv is copied back to the
walk/desc struct.
Cc: <stable@vger.kernel.org> # 3.14+
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
to be update
commit 9a0133613e4412b2caaaf0d9dd81f213bcededf1 upstream.
Since v1:
Edited the comment according to Srivatsa's suggestion.
During the testing, we encounter below WARN followed by Oops:
WARNING: at kernel/sched/core.c:6218
NIP [c000000000101660] .build_sched_domains+0x11d0/0x1200
LR [c000000000101358] .build_sched_domains+0xec8/0x1200
PACATMSCRATCH [800000000000f032]
Call Trace:
[c00000001b103850] [c000000000101358] .build_sched_domains+0xec8/0x1200
[c00000001b1039a0] [c00000000010aad4] .partition_sched_domains+0x484/0x510
[c00000001b103aa0] [c00000000016d0a8] .rebuild_sched_domains+0x68/0xa0
[c00000001b103b30] [c00000000005cbf0] .topology_work_fn+0x10/0x30
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c00000000045c000] .__bitmap_weight+0x60/0xf0
LR [c00000000010132c] .build_sched_domains+0xe9c/0x1200
PACATMSCRATCH [8000000000029032]
Call Trace:
[c00000001b1037a0] [c000000000288ff4] .kmem_cache_alloc_node_trace+0x184/0x3a0
[c00000001b103850] [c00000000010132c] .build_sched_domains+0xe9c/0x1200
This was caused by that 'sd->groups == NULL' after building groups, which
was caused by the empty 'sd->span'.
The cpu's domain contained nothing because the cpu was assigned to a wrong
node, due to the following unfortunate sequence of events:
1. The hypervisor sent a topology update to the guest OS, to notify changes
to the cpu-node mapping. However, the update was actually redundant - i.e.,
the "new" mapping was exactly the same as the old one.
2. Due to this, the 'updated_cpus' mask turned out to be empty after exiting
the 'for-loop' in arch_update_cpu_topology().
3. So we ended up calling stop-machine() with an empty cpumask list, which made
stop-machine internally elect cpumask_first(cpu_online_mask), i.e., CPU0 as
the cpu to run the payload (the update_cpu_topology() function).
4. This causes update_cpu_topology() to be run by CPU0. And since 'updates'
is kzalloc()'ed inside arch_update_cpu_topology(), update_cpu_topology()
finds update->cpu as well as update->new_nid to be 0. In other words, we
end up assigning CPU0 (and eventually its siblings) to node 0, incorrectly.
Along with the following wrong updating, it causes the sched-domain rebuild
code to break and crash the system.
Fix this by skipping the topology update in cases where we find that
the topology has not actually changed in reality (ie., spurious updates).
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Paul Mackerras <paulus@samba.org>
CC: Nathan Fontenot <nfont@linux.vnet.ibm.com>
CC: Stephen Rothwell <sfr@canb.auug.org.au>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Robert Jennings <rcj@linux.vnet.ibm.com>
CC: Jesse Larrew <jlarrew@linux.vnet.ibm.com>
CC: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
CC: Alistair Popple <alistair@popple.id.au>
Suggested-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Signed-off-by: Michael Wang <wangyun@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 84e871660bebfddb9a62ebd6f19d02536e782f0a upstream.
at91rm9200 standby and suspend to ram has been broken since
00482a4078f4. It is wrongly using AT91_BASE_SYS which is a physical address
and actually doesn't correspond to any register on at91rm9200.
Use the correct at91_ramc_base[0] instead.
Fixes: 00482a4078f4 (ARM: at91: implement the standby function for pm/cpuidle)
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit e893286918d2cde3a94850d8f7101cd1039e0c62 upstream.
On gcc5 the kernel does not link:
ld: .eh_frame_hdr table[4] FDE at 0000000000000648 overlaps table[5] FDE at 0000000000000670.
Because prior GCC versions always emitted NOPs on ALIGN directives, but
gcc5 started omitting them.
.LSTARTFDEDLSI1 says:
/* HACK: The dwarf2 unwind routines will subtract 1 from the
return address to get an address in the middle of the
presumed call instruction. Since we didn't get here via
a call, we need to include the nop before the real start
to make up for it. */
.long .LSTART_sigreturn-1-. /* PC-relative start address */
But commit 69d0627a7f6e ("x86 vDSO: reorder vdso32 code") from 2.6.25
replaced .org __kernel_vsyscall+32,0x90 by ALIGN right before
__kernel_sigreturn.
Of course, ALIGN need not generate any NOP in there. Esp. gcc5 collapses
vclock_gettime.o and int80.o together with no generated NOPs as "ALIGN".
So fix this by adding to that point at least a single NOP and make the
function ALIGN possibly with more NOPs then.
Kudos for reporting and diagnosing should go to Richard.
Reported-by: Richard Biener <rguenther@suse.de>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/1425543211-12542-1-git-send-email-jslaby@suse.cz
commit f4c3686386393c120710dd34df2a74183ab805fd upstream.
drop_fpu() does clear_used_math() and usually this is correct
because tsk == current.
However switch_fpu_finish()->restore_fpu_checking() is called before
__switch_to() updates the "current_task" variable. If it fails,
we will wrongly clear the PF_USED_MATH flag of the previous task.
So use clear_stopped_child_used_math() instead.
Cc: Pekka Riikonen <priikone@iki.fi>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Link: http://lkml.kernel.org/r/20150309171041.GB11388@redhat.com
__restore_xstate_sig()
commit a7c80ebcac3068b1c3cb27d538d29558c30010c8 upstream.
math_state_restore() assumes it is called with irqs disabled,
but this is not true if the caller is __restore_xstate_sig().
This means that if ia32_fxstate == T and __copy_from_user()
fails, __restore_xstate_sig() returns with irqs disabled too.
This triggers:
BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:41
dump_stack
___might_sleep
? _raw_spin_unlock_irqrestore
__might_sleep
down_read
print_vma_addr
signal_fault
sys32_rt_sigreturn
Change __restore_xstate_sig() to call set_used_math()
unconditionally. This avoids enabling and disabling interrupts
in math_state_restore(). If copy_from_user() fails, we can
simply do fpu_finit() by hand.
[ Note: this is only the first step. math_state_restore() should
not check used_math(), it should set this flag. While
init_fpu() should simply die. ]
Link: http://lkml.kernel.org/r/20150307153844.GB25954@redhat.com
commit ccfe8c3f7e52ae83155cb038753f4c75b774ca8a upstream.
The kernel crypto API logic requires the caller to provide the
length of (ciphertext || authentication tag) as cryptlen for the
AEAD decryption operation. Thus, the cipher implementation must
calculate the size of the plaintext output itself and cannot simply use
cryptlen.
The RFC4106 GCM decryption operation tries to overwrite cryptlen memory
in req->dst. As the destination buffer for decryption only needs to hold
the plaintext memory but cryptlen references the input buffer holding
(ciphertext || authentication tag), the assumption of the destination
buffer length in RFC4106 GCM operation leads to a too large size. This
patch simply uses the already calculated plaintext size.
In addition, this patch fixes the offset calculation of the AAD buffer
pointer: as mentioned before, cryptlen already includes the size of the
tag. Thus, the tag does not need to be added. With the addition, the AAD
will be written beyond the already allocated buffer.
Note, this fixes a kernel crash that can be triggered from user space
via AF_ALG(aead) -- simply use the libkcapi test application
from [1] and update it to use rfc4106-gcm-aes.
Using [1], the changes were tested using CAVS vectors to demonstrate
that the crypto operation still delivers the right results.
[1] http://www.chronox.de/libkcapi.html
CC: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Stephan Mueller <smueller@chronox.de>
commit bb344ca5b90df62b1a3b7a35c6a9d00b306a170d upstream.
Commit 746c9e9f92dd "of/base: Fix PowerPC address parsing hack" limited
the applicability of the workaround whereby a missing ranges is treated
as an empty ranges. This workaround was hiding a bug in the etsec2
device tree nodes, which have children with reg, but did not have
ranges.
Reported-by: Alexander Graf <agraf@suse.de>
[ Upstream commit 2077cef4d5c29cf886192ec32066f783d6a80db8 ]
Firstly, handle zero length calls properly. Believe it or not there
are a few of these happening during early boot.
Next, we can't just drop to a memcpy() call in the forward copy case
where dst <= src. The reason is that the cache initializing stores
used in the Niagara memcpy() implementations can end up clearing out
cache lines before we've sourced their original contents completely.
For example, considering NG4memcpy, the main unrolled loop begins like
this:
load src + 0x00
load src + 0x08
load src + 0x10
load src + 0x18
load src + 0x20
store dst + 0x00
Assume dst is 64 byte aligned and let's say that dst is src - 8 for
this memcpy() call. That store at the end there is the one to the
first line in the cache line, thus clearing the whole line, which thus
clobbers "src + 0x28" before it even gets loaded.
To avoid this, just fall through to a simple copy only mildly
optimized for the case where src and dst are 8 byte aligned and the
length is a multiple of 8 as well. We could get fancy and call
GENmemcpy() but this is good enough for how this thing is actually
used.
Reported-by: David Ahern <david.ahern@oracle.com>
Reported-by: Bob Picco <bpicco@meloft.net>
[ Upstream commit 31aaa98c248da766ece922bbbe8cc78cfd0bc920 ]
With the increase in number of CPUs calls to functions that dump
output to console (e.g., arch_trigger_all_cpu_backtrace) can take
a long time to complete. If IRQs are disabled eventually the NMI
watchdog kicks in and creates more havoc. Avoid by telling the NMI
watchdog everything is ok.
Signed-off-by: David Ahern <david.ahern@oracle.com>
[ Upstream commit d51291cb8f32bfae6b331e1838651f3ddefa73a5 ]
Currently perf-stat (aka, counting mode) does not work:
$ perf stat ls
Performance counter stats for 'ls':
1.585665 task-clock (msec) # 0.580 CPUs utilized
24 context-switches # 0.015 M/sec
0 cpu-migrations # 0.000 K/sec
86 page-faults # 0.054 M/sec
<not supported> cycles
<not supported> stalled-cycles-frontend
<not supported> stalled-cycles-backend
<not supported> instructions
<not supported> branches
<not supported> branch-misses
0.002735100 seconds time elapsed
The reason is that state is never reset (stays with PERF_HES_UPTODATE set).
Add a call to sparc_pmu_enable_event during the added_event handling.
Clean up the encoding since pmu_start calls sparc_pmu_enable_event which
does the same. Passing PERF_EF_RELOAD to sparc_pmu_start means the call
to sparc_perf_event_set_period can be removed as well.
With this patch:
$ perf stat ls
1.552890 task-clock (msec) # 0.552 CPUs utilized
86 page-faults # 0.055 M/sec
5,748,997 cycles # 3.702 GHz
<not supported> stalled-cycles-frontend:HG
<not supported> stalled-cycles-backend:HG
1,684,362 instructions:HG # 0.29 insns per cycle
295,133 branches:HG # 190.054 M/sec
28,007 branch-misses:HG # 9.49% of all branches
0.002815665 seconds time elapsed
Acked-by: Bob Picco <bob.picco@oracle.com>
[ Upstream commit 5b0d4b5514bbcce69b516d0742f2cfc84ebd6db3 ]
perf_pmu_disable is called by core perf code before pmu->del and the
enable function is called by core perf code afterwards. No need to
call again within sparc_pmu_del.
Ditto for pmu->add and sparc_pmu_add.
[ Upstream commit 53eb2516972b8c4628651dfcb926cb9ef8b2864a ]
A bug was reported that the semtimedop() system call was always
failing eith ENOSYS.
Since SEMCTL is defined as 3, and SEMTIMEDOP is defined as 4,
the comparison "call <= SEMCTL" will always prevent SEMTIMEDOP
from getting through to the semaphore ops switch statement.
This is corrected by changing the comparison to "call <= SEMTIMEDOP".
Orabug: 20633375
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit 66d0f7ec9f1038452178b1993fc07fd96d30fd38 ]
Load balancing can be triggered in the critical sections protected by
srmmu_context_spinlock in destroy_context() and switch_mm() and can hang
the cpu waiting for the rq lock of another cpu that in turn has called
switch_mm hangning on srmmu_context_spinlock leading to deadlock.
So, disable interrupt while taking srmmu_context_spinlock in
destroy_context() and switch_mm() so we don't deadlock.
See also commit 77b838fa1ef0 ("[SPARC64]: destroy_context() needs to disable
interrupts.")
Signed-off-by: Andreas Larsson <andreas@gaisler.com>
commit 61f77eda9bbf0d2e922197ed2dcf88638a639ce5 upstream.
Currently we have many duplicates in definitions around
follow_huge_addr(), follow_huge_pmd(), and follow_huge_pud(), so this
patch tries to remove the m. The basic idea is to put the default
implementation for these functions in mm/hugetlb.c as weak symbols
(regardless of CONFIG_ARCH_WANT_GENERAL_HUGETL B), and to implement
arch-specific code only when the arch needs it.
For follow_huge_addr(), only powerpc and ia64 have their own
implementation, and in all other architectures this function just returns
ERR_PTR(-EINVAL). So this patch sets returning ERR_PTR(-EINVAL) as
default.
As for follow_huge_(pmd|pud)(), if (pmd|pud)_huge() is implemented to
always return 0 in your architecture (like in ia64 or sparc,) it's never
called (the callsite is optimized away) no matter how implemented it is.
So in such architectures, we don't need arch-specific implementation.
In some architecture (like mips, s390 and tile,) their current
arch-specific follow_huge_(pmd|pud)() are effectively identical with the
common code, so this patch lets these architecture use the common code.
One exception is metag, where pmd_huge() could return non-zero but it
expects follow_huge_pmd() to always return NULL. This means that we need
arch-specific implementation which returns NULL. This behavior looks
strange to me (because non-zero pmd_huge() implies that the architecture
supports PMD-based hugepage, so follow_huge_pmd() can/should return some
relevant value,) but that's beyond this cleanup patch, so let's keep it.
Justification of non-trivial changes:
- in s390, follow_huge_pmd() checks !MACHINE_HAS_HPAGE at first, and this
patch removes the check. This is OK because we can assume MACHINE_HAS_HPAGE
is true when follow_huge_pmd() can be called (note that pmd_huge() has
the same check and always returns 0 for !MACHINE_HAS_HPAGE.)
- in s390 and mips, we use HPAGE_MASK instead of PMD_MASK as done in common
code. This patch forces these archs use PMD_MASK, but it's OK because
they are identical in both archs.
In s390, both of HPAGE_SHIFT and PMD_SHIFT are 20.
In mips, HPAGE_SHIFT is defined as (PAGE_SHIFT + PAGE_SHIFT - 3) and
PMD_SHIFT is define as (PAGE_SHIFT + PAGE_SHIFT + PTE_ORDER - 3), but
PTE_ORDER is always 0, so these are identical.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Steve Capper <steve.capper@linaro.org>
commit e262eb9381ad51b5de7a9e762ee773bbd25ce650 upstream.
Fix misspelled define.
Fixes: 33692f27597f ("vm: add VM_FAULT_SIGSEGV handling support")
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
commit 7fb08eca45270d0ae86e1ad9d39c40b7a55d0190 upstream.
This replaces four copies in various stages of mm_fault_error() handling
with just a single one. It will also allow for more natural placement
of the unlocking after some further cleanup.
commit 13648b0118a24f4fc76c34e6c7b6ccf447e46a2a upstream.
/proc/<pid>/maps currently don't annotate stack vma with "[stack]"
This is because KSTK_ESP ie expected to return usermode SP of tsk while
currently it returns the kernel mode SP of a sleeping tsk.
While the fix is trivial, we also need to adjust the ARC kernel stack
unwinder to not use KSTK_SP and friends any more.
Reported-and-suggested-by: Alexey Brodkin <abrodkin@synopsys.com>
commit b3cffac04eca9af46e1e23560a8ee22b1bd36d43 upstream.
Currently the guest exit trace event saves the VCPU pointer to the
structure, and the guest PC is retrieved by dereferencing it when the
event is printed rather than directly from the trace record. This isn't
safe as the printing may occur long afterwards, after the PC has changed
and potentially after the VCPU has been freed. Usually this results in
the same (wrong) PC being printed for multiple trace events. It also
isn't portable as userland has no way to access the VCPU data structure
when interpreting the trace record itself.
Lets save the actual PC in the structure so that the correct value is
accessible later.
Fixes: 669e846e6c4e ("KVM/MIPS32: MIPS arch specific APIs for KVM")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 4ff6f8e61eb7f96d3ca535c6d240f863ccd6fb7d upstream.
This has been broken for a long time: it broke first in 2.6.35, then was
almost fixed in 2.6.36 but this one-liner slipped through the cracks.
The bug shows up as an infinite loop in Windows 7 (and newer) boot on
32-bit hosts without EPT.
Windows uses CMPXCHG8B to write to page tables, which causes a
page fault if running without EPT; the emulator is then called from
kvm_mmu_page_fault. The loop then happens if the higher 4 bytes are
not 0; the common case for this is that the NX bit (bit 63) is 1.
Fixes: 6550e1f165f384f3a46b60a1be9aba4bc3c2adad
Fixes: 16518d5ada690643453eb0aef3cc7841d3623c2d
Reported-by: Erik Rull <erik.rull@rdsoftware.de>
Tested-by: Erik Rull <erik.rull@rdsoftware.de>
commit 956421fbb74c3a6261903f3836c0740187cf038b upstream.
'ret_from_fork' checks TIF_IA32 to determine whether 'pt_regs' and
the related state make sense for 'ret_from_sys_call'. This is
entirely the wrong check. TS_COMPAT would make a little more
sense, but there's really no point in keeping this optimization
at all.
This fixes a return to the wrong user CS if we came from int
0x80 in a 64-bit task.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/4710be56d76ef994ddf59087aad98c000fbab9a4.1424989793.git.luto@amacapital.net
[ Backported from tip:x86/asm. ]
commit 3ce465e04bfd8de9956d515d6e9587faac3375dc upstream.
Export the _save_fp asm function used by the lose_fpu(1) macro to GPL
modules so that KVM can make use of it when it is built as a module.
This fixes the following build error when CONFIG_KVM=m due to commit
f798217dfd03 ("KVM: MIPS: Don't leak FPU/DSP to guest"):
ERROR: "_save_fp" [arch/mips/kvm/kvm.ko] undefined!
Fixes: f798217dfd03 (KVM: MIPS: Don't leak FPU/DSP to guest)
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9260/
[james.hogan@imgtec.com: Only export when CPU_R4K_FPU=y prior to v3.16,
so as not to break the Octeon build which excludes FPU support. KVM
depends on MIPS32r2 anyway.]
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream.
The issue is that the stack for processes is not properly randomized on
64 bit architectures due to an integer overflow.
The affected function is randomize_stack_top() in file
"fs/binfmt_elf.c":
static unsigned long randomize_stack_top(unsigned long stack_top)
unsigned int random_variable = 0;
if ((current->flags & PF_RANDOMIZE) &&
!(current->personality & ADDR_NO_RANDOMIZE)) {
random_variable = get_random_int() & STACK_RND_MASK;
random_variable <<= PAGE_SHIFT;
return PAGE_ALIGN(stack_top) + random_variable;
return PAGE_ALIGN(stack_top) - random_variable;
Note that, it declares the "random_variable" variable as "unsigned int".
Since the result of the shifting operation between STACK_RND_MASK (which
is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64):
then the two leftmost bits are dropped when storing the result in the
"random_variable". This variable shall be at least 34 bits long to hold
the (22+12) result.
These two dropped bits have an impact on the entropy of process stack.
Concretely, the total stack entropy is reduced by four: from 2^28 to
2^30 (One fourth of expected entropy).
This patch restores back the entropy by correcting the types involved
in the operations in the functions randomize_stack_top() and
stack_maxrandom_size().
The successful fix can be tested with:
$ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done
7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack]
7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack]
7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack]
7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack]
Once corrected, the leading bytes should be between 7ffc and 7fff,
rather than always being 7fff.
Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es>
Signed-off-by: Ismael Ripoll <iripoll@upv.es>
[ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ]
Fixes: CVE-2015-1593
Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net
