path: root/arch
2014-06-29Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another round of ARM fixes. The largest change here is the L2 changes to work around problems for the Armada 37x/380 devices, where most of the size comes down to comments rather than code. The other significant fix here is for the ptrace code, to ensure that rewritten syscalls work as intended. This was pointed out by Kees Cook, but Will Deacon reworked the patch to be more elegant. The remainder are fairly trivial changes" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8087/1: ptrace: reload syscall number after secure_computing() check ARM: 8086/1: Set memblock limit for nommu ARM: 8085/1: sa1100: collie: add top boot mtd partition ARM: 8084/1: sa1100: collie: revert back to cfi_probe ARM: 8080/1: mcpm.h: remove unused variable declaration ARM: 8076/1: mm: add support for HW coherent systems in PL310 cache
2014-06-29ARM: 8087/1: ptrace: reload syscall number after secure_computing() checkWill Deacon
On the syscall tracing path, we call out to secure_computing() to allow seccomp to check the syscall number being attempted. As part of this, a SIGTRAP may be sent to the tracer and the syscall could be re-written by a subsequent SET_SYSCALL ptrace request. Unfortunately, this new syscall is ignored by the current code unless TIF_SYSCALL_TRACE is also set on the current thread. This patch slightly reworks the enter path of the syscall tracing code so that we always reload the syscall number from current_thread_info()->syscall after the potential ptrace traps. Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8086/1: Set memblock limit for nommuLaura Abbott
Commit 1c2f87c (ARM: 8025/1: Get rid of meminfo) changed find_limits to use memblock_get_current_limit for calculating the max_low pfn. nommu targets never actually set a limit on memblock though which means memblock_get_current_limit will just return the default value. Set the memblock_limit to be the end of DDR to make sure bounds are calculated correctly. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8085/1: sa1100: collie: add top boot mtd partitionAndrea Adami
The CFI mapping is now perfect so we can expose the top block, read only. There isn't much to read, though, just the sharpsl_params values. Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8084/1: sa1100: collie: revert back to cfi_probeAndrea Adami
Reverts commit d26b17edafc45187c30cae134a5e5429d58ad676 ARM: sa1100: collie.c: fall back to jedec_probe flash detection Unfortunately the detection was challenged on the defective unit used for tests: one of the NOR chips did not respond to the CFI query. Moreover that bad device needed extra delays on erase-suspend/resume cycles. Tested personally on 3 different units and with feedback of two other users. Signed-off-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8080/1: mcpm.h: remove unused variable declarationNicolas Pitre
The sync_phys variable has been replaced by link time computation in mcpm_head.S before the code was submitted upstream. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-29ARM: 8076/1: mm: add support for HW coherent systems in PL310 cacheThomas Petazzoni
When a PL310 cache is used on a system that provides hardware coherency, the outer cache sync operation is useless, and can be skipped. Moreover, on some systems, it is harmful as it causes deadlocks between the Marvell coherency mechanism, the Marvell PCIe controller and the Cortex-A9. To avoid this, this commit introduces a new Device Tree property 'arm,io-coherent' for the L2 cache controller node, valid only for the PL310 cache. It identifies the usage of the PL310 cache in an I/O coherent configuration. Internally, it makes the driver disable the outer cache sync operation. Note that technically speaking, a fully coherent system wouldn't require any of the other .outer_cache operations. However, in practice, when booting secondary CPUs, these are not yet coherent, and therefore a set of cache maintenance operations are necessary at this point. This explains why we keep the other .outer_cache operations and only ->sync is disabled. While in theory any write to a PL310 register could cause the deadlock, in practice, disabling ->sync is sufficient to workaround the deadlock, since the other cache maintenance operations are only used in very specific situations. Contrary to previous versions of this patch, this new version does not simply NULL-ify the ->sync member, because the l2c_init_data structures are now 'const' and therefore cannot be modified, which is a good thing. Therefore, this patch introduces a separate l2c_init_data instance, called of_l2c310_coherent_data. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-27Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "A pile of fixes related to the VDSO, EFI and 32-bit badsys handling. It turns out that removing the section headers from the VDSO breaks gdb, so this puts back most of them. A very simple typo broke rt_sigreturn on some versions of glibc, with obviously disastrous results. The rest is pretty much fixes for the corresponding fallout. The EFI fixes fixes an arithmetic overflow on 32-bit systems and quiets some build warnings. Finally, when invoking an invalid system call number on x86-32, we bypass a bunch of handling, which can make the audit code oops" * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi-pstore: Fix an overflow on 32-bit builds x86/vdso: Error out in vdso2c if DT_RELA is present x86/vdso: Move DISABLE_BRANCH_PROFILING into the vdso makefile x86_32, signal: Fix vdso rt_sigreturn x86_32, entry: Do syscall exit work on badsys (CVE-2014-4508) x86/vdso: Create .build-id links for unstripped vdso files x86/vdso: Remove some redundant in-memory section headers x86/vdso: Improve the fake section headers x86/vdso2c: Use better macros for ELF bitness x86/vdso: Discard the __bug_table section efi: Fix compiler warnings (unused, const, type)
2014-06-27Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "This is dominated by a large number of changes necessary for the MIPS BPF code. code. Aside of that there are - a fix for the MSC system controller support code. - a Turbochannel fix. - a recordmcount fix that's MIPS-specific. - barrier fixes to smp-cps / pm-cps after unrelated changes elsewhere in the kernel. - revert support for MSA registers in the signal frames. The reverted patch did modify the signal stack frame which of course is inacceptable. - fix math-emu build breakage with older compilers. - some related cleanup. - fix Lasat build error if CONFIG_CRC32 isn't set to y by the user" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (27 commits) MIPS: Lasat: Fix build error if CRC32 is not enabled. TC: Handle device_register() errors. MIPS: MSC: Prevent out-of-bounds writes to MIPS SC ioremap'd region MIPS: bpf: Fix stack space allocation for BPF memwords on MIPS64 MIPS: BPF: Use 32 or 64-bit load instruction to load an address to register MIPS: bpf: Fix PKT_TYPE case for big-endian cores MIPS: BPF: Prevent kernel fall over for >=32bit shifts MIPS: bpf: Drop update_on_xread and always initialize the X register MIPS: bpf: Fix is_range() semantics MIPS: bpf: Use pr_debug instead of pr_warn for unhandled opcodes MIPS: bpf: Fix return values for VLAN_TAG_PRESENT case MIPS: bpf: Use correct mask for VLAN_TAG case MIPS: bpf: Fix branch conditional for BPF_J{GT/GE} cases MIPS: bpf: Add SEEN_SKB to flags when looking for the PKT_TYPE MIPS: bpf: Use 'andi' instead of 'and' for the VLAN cases MIPS: bpf: Return error code if the offset is a negative number MIPS: bpf: Use the LO register to get division's quotient MIPS: mm: uasm: Fix lh micro-assembler instruction MIPS: uasm: Add SLT uasm instruction MIPS: uasm: Add s3s1s2 instruction builder ...
2014-06-27Merge tag 'arc-fixes-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: "Some SMP changes, a ptrace request for NPTL debugging, bunch of build breakages/warnings" * tag 'arc-fixes-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARC: [SMP] Enable icache coherency ARC: [SMP] Fix IPI IRQ registration ARC: Implement ptrace(PTRACE_GET_THREAD_AREA) ARC: optimize kernel bss clearing in early boot code ARC: Fix build breakage for !CONFIG_ARC_DW2_UNWIND ARC: fix build warning in devtree ARC: remove checks for CONFIG_ARC_MMU_V4
2014-06-26MIPS: Lasat: Fix build error if CRC32 is not enabled.Ralf Baechle
Kconfig doesn't select CRC32 so it's possible to build a Lasat kernel without CONFIG_CRC32 resulting in a build error: LD vmlinux arch/mips/built-in.o: In function `lasat_init_board_info': (.text+0x22c): undefined reference to `crc32_le' arch/mips/built-in.o: In function `lasat_write_eeprom_info': (.text+0x7fc): undefined reference to `crc32_le' make: *** [vmlinux] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: MSC: Prevent out-of-bounds writes to MIPS SC ioremap'd regionMarkos Chandras
Previously, the lower limit for the MIPS SC initialization loop was set incorrectly allowing one extra loop leading to writes beyond the MSC ioremap'd space. More precisely, the value of the 'imp' in the last loop increased beyond the msc_irqmap_t boundaries and as a result of which, the 'n' variable was loaded with an incorrect value. This value was used later on to calculate the offset in the MSC01_IC_SUP which led to random crashes like the following one: CPU 0 Unable to handle kernel paging request at virtual address e75c0200, epc == 8058dba4, ra == 8058db90 [...] Call Trace: [<8058dba4>] init_msc_irqs+0x104/0x154 [<8058b5bc>] arch_init_irq+0xd8/0x154 [<805897b0>] start_kernel+0x220/0x36c Kernel panic - not syncing: Attempted to kill the idle task! This patch fixes the problem Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: stable@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7118/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Fix stack space allocation for BPF memwords on MIPS64Markos Chandras
When allocating stack space for BPF memwords we need to use the appropriate 32 or 64-bit instruction to avoid losing the top 32 bits of the stack pointer. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7135/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: BPF: Use 32 or 64-bit load instruction to load an address to registerMarkos Chandras
When loading a pointer to register we need to use the appropriate 32 or 64bit instruction to preserve the pointers' top 32bits. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7180/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Fix PKT_TYPE case for big-endian coresMarkos Chandras
The skb->pkt_type field is defined as follows: u8 pkt_type:3, fclone:2, ipvs_property:1, peeked:1, nf_trace:1 resulting to the following layout in big-endian systems [pkt_type][fclone][ipvs_propery][peeked][nf_trace] ^ ^ | | LSB MSB As a result, the existing code did not work because it was trying to match pkt_type == 7 whereas in reality it is 7<<5 on big-endian systems. This has been fixed in the interpreter in 0dcceabb0c1bf2d4c12a748df9933fad303072a7 "net: filter: fix SKF_AD_PKTTYPE extension on big-endian" The fix is to look for 7<<5 on big-endian systems for the pkt_type field, and shift by 5 so the packet type will be at the lower 3 bits of the A register. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7132/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: BPF: Prevent kernel fall over for >=32bit shiftsMarkos Chandras
Remove BUG_ON() if the shift immediate is >=32 to avoid kernel crashes due to malicious user input. If the shift immediate is >= 32, we simply load the destination register with 0 since only 32-bit instructions are used by JIT so this will do the correct thing even on MIPS64. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7179/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Drop update_on_xread and always initialize the X registerMarkos Chandras
Previously, update_on_xread() only set the reset flag if SEEN_X hasn't been set already. However, SEEN_X is used to indicate that X is used as destination or source register so there are some cases where X is only used as source register and we really need to make sure that it has been initialized in time. As a result of which, drop this function and always set X to zero if it's used in any of the opcodes. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7133/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Fix is_range() semanticsMarkos Chandras
is_range() was meant to check whether the number is within the s16 range or not. However the return values and consumers expected the exact opposite. We fix that by inverting the logic in the function to return 'true' for < s16 and 'false' for > s16. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reported-by: Alexei Starovoitov <ast@plumgrid.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7131/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Use pr_debug instead of pr_warn for unhandled opcodesMarkos Chandras
We should prevent spamming the logs during normal execution of bpf-jit. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Suggested-by: Alexei Starovoitov <ast@plumgrid.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7129/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Fix return values for VLAN_TAG_PRESENT caseMarkos Chandras
If VLAN_TAG_PRESENT is not zero, then return 1 as expected by classic BPF. Otherwise return 0. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7128/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Use correct mask for VLAN_TAG caseMarkos Chandras
Using VLAN_VID_MASK is not correct to get the vlan tag. Use ~VLAN_PRESENT_MASK instead and make sure it's u16 so the top 16-bits will be removed. This will ensure that the emit_andi() code will not treat this as a big 32-bit unsigned value. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7127/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Fix branch conditional for BPF_J{GT/GE} casesMarkos Chandras
The sltiu and sltu instructions will set the scratch register to 1 if A <= X|K so fix the emitted branch conditional to check for scratch != zero rather than scratch >= zero which would complicate the resuling branch logic given that MIPS does not have a BGT or BGET instructions to compare general purpose registers directly. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7126/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Add SEEN_SKB to flags when looking for the PKT_TYPEMarkos Chandras
The SKF_AD_PKTTYPE uses the skb pointer so make sure it's in the flags so it will be initialized in time. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7125/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Use 'andi' instead of 'and' for the VLAN casesMarkos Chandras
The VLAN_VID_MASK and VLAN_TAG_PRESENT are immediates, so using 'and' which expects 3 registers will produce wrong results. Fix this by using the 'andi' instruction. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7124/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Return error code if the offset is a negative numberMarkos Chandras
Previously, the negative offset was not checked leading to failures due to trying to load data beyond the skb struct boundaries. Until we have proper asm helpers in place, it's best if we return ENOSUPP if K is negative when trying to JIT the filter or 0 during runtime if we do an indirect load where the value of X is unknown during build time. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: David S. Miller <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7123/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: bpf: Use the LO register to get division's quotientMarkos Chandras
Reading from the HI register to get the division result is wrong. The quotient is placed in the LO register. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: netdev@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7122/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: mm: uasm: Fix lh micro-assembler instructionMarkos Chandras
Commit d6b3314b49e12e8c349deb4ca28e7028db00728f "MIPS: uasm: Add lh uam instruction" added the 'lh' micro-assembler instruction but it used the 'lw' opcode for it. Fix it by using the correct 'lh' opcode. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7121/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: uasm: Add SLT uasm instructionMarkos Chandras
It will be used later on by bpf-jit Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/7120/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: uasm: Add s3s1s2 instruction builderMarkos Chandras
It will be used later on by the SLT instruction. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7119/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: BPF JIT: Fix build error.Daniel Borkmann
mips: allmodconfig fails in 3.16-rc1 with lots of undefined symbols. arch/mips/net/bpf_jit.c: In function 'is_load_to_a': arch/mips/net/bpf_jit.c:559:7: error: 'BPF_S_LD_W_LEN' undeclared (first use in this function) arch/mips/net/bpf_jit.c:559:7: note: each undeclared identifier is reported only once for each function it appears in arch/mips/net/bpf_jit.c:560:7: error: 'BPF_S_LD_W_ABS' undeclared (first use in this function) [...] The reason behind this is that 3480593131e0 ("net: filter: get rid of BPF_S_* enum") was routed via net-next tree, that takes all BPF-related changes, at a time where MIPS BPF JIT was not part of net-next, while c6610de353da ("MIPS: net: Add BPF JIT") was routed via mips arch tree and went into mainline within the same merge window. Thus, fix it up by converting BPF_S_* in a similar fashion as in 3480593131e0 for MIPS. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Cc: Linux MIPS Mailing List <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/7099/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26Revert "MIPS: Save/restore MSA context around signals"Paul Burton
This reverts commit eec43a224cf1 "MIPS: Save/restore MSA context around signals" and the MSA parts of ca750649e08c "MIPS: kernel: signal: Prevent save/restore FPU context in user memory" (the restore path of which appears incorrect anyway...). The reverted patch took care not to break compatibility with userland users of struct sigcontext, but inadvertantly changed the offset of the uc_sigmask field of struct ucontext. Thus Linux v3.15 breaks the userland ABI. The MSA context will need to be saved via some other opt-in mechanism, but for now revert the change to reduce the fallout. This will have minimal impact upon use of MSA since the only supported CPU which includes it (the P5600) is 32-bit and therefore requires that the experimental CONFIG_MIPS_O32_FP64_SUPPORT Kconfig option be selected before the kernel will set FR=1 for a task, a requirement for MSA use. Thus the users of MSA are limited to known small groups of people & this patch won't be breaking any previously working MSA-using userland outside of experimental settings. [ralf@linux-mips.org: Fixed rejects.] Cc: stable@vger.kernel.org Reported-by: Joseph S. Myers <joseph@codesourcery.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7107/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: math-emu: Reduce code duplication.Ralf Baechle
The fix in the preceeding commit did do exactly the same thing in two places showing some code cleanup was due. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26ARC: [SMP] Enable icache coherencyVineet Gupta
icaches are not snooped hence not cohrent in SMP setups which means kernel has to do cross core calls to ensure the same. The leaf routine __ic_line_inv_vaddr() now does cross core calls. __sync_icache_dcache() is affected due to this: * local dcache line flushed ahead of remote icache inv requests * can't disable interrupts anymore, since __ic_line_inv_vaddr()->on_each_cpu() can deadlock. | WARNING: CPU: 0 PID: 1 at kernel/smp.c:374 | smp_call_function_many+0x25a/0x2c4() | | init_kprobes+0x90/0xc8 | register_kprobe+0x1d6/0x510 | __sync_icache_dcache+0x28/0x80 | | DISABLE IRQ | | __ic_line_inv_vaddr | on_each_cpu | smp_call_function_many+0x25a/0x2c4 --> WARN | __ic_line_inv_vaddr_local | __dc_line_op * TODO: Needs to use mask of relevant CPUs to avoid broadcasting Signed-off-by: Noam Camus <noamc@ezchip.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-06-26ARC: [SMP] Fix IPI IRQ registrationNoam Camus
Handle it just like timer. Current request_percpu_irq() would fail on non-boot cpus and thus IRQ will remian unmasked on those cpus. [vgupta: fix changelong] Signed-off-by: Noam Camus <noamc@ezchip.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-06-26ARC: Implement ptrace(PTRACE_GET_THREAD_AREA)Anton Kolesov
This patch adds implementation of GET_THREAD_AREA ptrace request type. This is required by GDB to debug NPTL applications. Signed-off-by: Anton Kolesov <Anton.Kolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-06-26ARC: optimize kernel bss clearing in early boot codeVineet Gupta
using ARC ZOL which reduces tot num of instructions by half Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-06-26ARC: Fix build breakage for !CONFIG_ARC_DW2_UNWINDVineet Gupta
Fixes: ec7ac6afd07b (ARC: switch to generic ENTRY/END assembler annotations) Reported-by: Anton Kolesov <akolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2014-06-25Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A new set of bug fixes for 3.16, containing patches for seven platforms: at91: - drivers/misc fix for Kconfig PWM symbol - correction of several values in DT after conversion to CCF - fix at91sam9261/at91sam9261ek mistake in slow crystal vs. slow RC osc imx: - Use GPIO for card CD/WP on imx51-babbage and eukrea-mbimxsd51, because controller base CD/WP is not working in esdhc driver due to runtime PM support - A couple of random ventana gw5xxx board fixes - Add IMX_IPUV3_CORE back to defconfig, which gets lost when moving IPUv3 driver out of staging tree - Fix enet/fec clock selection on imx6sl - Fix display node on imx53-m53evk board - A couple of Cubox-i updates from Russell, which were omitted from the merge window due to dependency integrator: - fix an OF-related regression against 3.15 mvebu: - mvebu (v7) - Fix broken SoC ID detection - Select ARM_CPU_SUSPEND for v7 - Remove armada38x compatible string (no users yet) - Enable Dove SoC in mvebu_v7_defconfig - kirkwood - Fix phy-connection-type on GuruPlug board qcom: - enable gsbi driver in defconfig - fix section mismatch warning in serial driver samsung: - use WFI macro in platform_do_lowpower because exynos cpuhotplug includes a hardcoded WFI instruction and it causes compile error in Thumb-2 mode. - fix GIC reg sizes for exynos4 SoCs - remove reset timer counter value during boot and resume for mct to fix a big jump in printk timestamps - fix pm code to check cortex-A9 for another exynos SoCs - don't rely on firmware's secondary_cpu_start for mcpm sti: - Ethernet clocks were wrongly defined for STiH415/416 platforms - STiH416 B2020 revision E DTS file name contained uppercase, change to lowercase" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits) ARM: at91/dt: sam9261: remove slow RC osc ARM: at91/dt: define sam9261ek slow crystal frequency ARM: at91/dt: sam9261: correctly define mainck ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT values ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT values misc: atmel_pwm: fix Kconfig symbols ARM: integrator: fix OF-related regression ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard ARM: dts: kirkwood: fix phy-connection-type for Guruplug ARM: EXYNOS: Don't rely on firmware's secondary_cpu_start for mcpm ARM: dts: imx51-eukrea-mbimxsd51-baseboard: unbreak esdhc. ARM: dts: imx51-babbage: Fix esdhc setup ARM: dts: mx5: Move the display out of soc {} node ARM: dts: mx5: Fix IPU port node placement ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms ARM: mvebu: Fix broken SoC ID detection ARM: imx_v6_v7_defconfig: Enable CONFIG_IMX_IPUV3_CORE ARM: multi_v7_defconfig: Add QCOM GSBI driver ARM: stih41x: Rename stih416-b2020-revE.dts to stih416-b2020e.dts tty: serial: msm: Fix section mismatch warning ...
2014-06-25Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesArnd Bergmann
Merge "First AT91 fixes batch for 3.16" from Nicolas Ferre: - drivers/misc fix for Kconfig PWM symbol - correction of several values in DT after conversion to CCF - fix at91sam9261/at91sam9261ek mistake in slow crystal vs. slow RC osc * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/dt: sam9261: remove slow RC osc ARM: at91/dt: define sam9261ek slow crystal frequency ARM: at91/dt: sam9261: correctly define mainck ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT values ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT values misc: atmel_pwm: fix Kconfig symbols
2014-06-25Merge tag 'mvebu-fixes-3.16' of git://git.infradead.org/linux-mvebu into fixesArnd Bergmann
Merge "mvebu fixes for v3.16" from Jason Cooper: - mvebu - Fix broken SoC ID detection - Select ARM_CPU_SUSPEND for v7 - Remove armada38x compatible string (no users yet) - kirkwood - Fix phy-connection-type on GuruPlug board * tag 'mvebu-fixes-3.16' of git://git.infradead.org/linux-mvebu: ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard ARM: dts: kirkwood: fix phy-connection-type for Guruplug ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms ARM: mvebu: Fix broken SoC ID detection
2014-06-25ARM: at91/dt: sam9261: remove slow RC oscAlexandre Belloni
The at91sam9261 doesn't actually have a slow RC oscillator, remove it from the dtsi. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-06-25ARM: at91/dt: define sam9261ek slow crystal frequencyAlexandre Belloni
Define at91sam9261ek's slow crystal frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-06-25ARM: at91/dt: sam9261: correctly define mainckAlexandre Belloni
mainck (CKGR_MCFR register) is actually using main_osc (CKGR_MOR register). Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-06-25ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT valuesAlexandre Belloni
ICPLL can only take 0 or 1, it got mixed with OUT which can be in the [0-3] range. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-06-25ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT valuesAlexandre Belloni
2014-06-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes and cleanups from Ben Herrenschmidt: "Here are a handful or two of powerpc fixes and simple/trivial cleanups. A bunch of them fix ftrace with the new ABI v2 in Little Endian, the rest is a scattering of fairly simple things" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Don't skip ePAPR spin-table CPUs powerpc/module: Fix TOC symbol CRC powerpc/powernv: Remove OPAL v1 takeover powerpc/kmemleak: Do not scan the DART table selftests/powerpc: Use the test harness for the TM DSCR test powerpc/cell: cbe_thermal.c: Cleaning up a variable is of the wrong type powerpc/kprobes: Fix jprobes on ABI v2 (LE) powerpc/ftrace: Use pr_fmt() to namespace error messages powerpc/ftrace: Fix nop of modules on 64bit LE (ABIv2) powerpc/ftrace: Fix inverted check of create_branch() powerpc/ftrace: Fix typo in mask of opcode powerpc: Add ppc_global_function_entry() powerpc/macintosh/smu.c: Fix closing brace followed by if powerpc: Remove __arch_swab* powerpc: Remove ancient DEBUG_SIG code powerpc/kerenl: Enable EEH for IO accessors
2014-06-25powerpc: Don't skip ePAPR spin-table CPUsScott Wood
Commit 59a53afe70fd530040bdc69581f03d880157f15a "powerpc: Don't setup CPUs with bad status" broke ePAPR SMP booting. ePAPR says that CPUs that aren't presently running shall have status of disabled, with enable-method being used to determine whether the CPU can be enabled. Fix by checking for spin-table, which is currently the only supported enable-method. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Emil Medve <Emilian.Medve@Freescale.com> Cc: stable@vger.kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-06-25powerpc/module: Fix TOC symbol CRCLaurent Dufour
The commit 71ec7c55ed91 introduced the magic symbol ".TOC." for ELFv2 ABI. This symbol is built manually and has no CRC value computed. A zero value is put in the CRC section to avoid modpost complaining about a missing CRC. Unfortunately, this breaks the kernel module loading when the kernel is relocated (kdump case for instance) because of the relocation applied to the kcrctab values. This patch compute a CRC value for the TOC symbol which will match the one compute by the kernel when it is relocated - aka '0 - relocate_start' done in maybe_relocated called by check_version (module.c). Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Cc: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-06-25powerpc/powernv: Remove OPAL v1 takeoverMichael Ellerman
In commit 27f4488872d9 "Add OPAL takeover from PowerVM" we added support for "takeover" on OPAL v1 machines. This was a mode of operation where we would boot under pHyp, and query for the presence of OPAL. If detected we would then do a special sequence to take over the machine, and the kernel would end up running in hypervisor mode. OPAL v1 was never a supported product, and was never shipped outside IBM. As far as we know no one is still using it. Newer versions of OPAL do not use the takeover mechanism. Although the query for OPAL should be harmless on machines with newer OPAL, we have seen a machine where it causes a crash in Open Firmware. The code in early_init_devtree() to copy boot_command_line into cmd_line was added in commit 817c21ad9a1f "Get kernel command line accross OPAL takeover", and AFAIK is only used by takeover, so should also be removed. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-06-24Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A number of low impact fixes, the most noticable one is the thumb2 frame pointer fix. We also fix a regression caused during this merge window with ARM925 CPUs running with caches disabled, and fix a number of warnings" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: arm925: ensure assembly sets up writethrough mapping ARM: perf: fix compiler warning with gcc 4.6.4 (and tidy code) ARM: l2c: fix dependencies on PL310 errata symbols ARM: 8069/1: Make thread_save_fp macro aware of THUMB2 mode ARM: 8068/1: scoop: Remove unused variable
