commit ff45000fcb56b5b0f1a14a865d3541746d838a0a upstream.
The boot wrapper performs its own relocations and does not require
PT_INTERP segment. However currently we don't tell the linker that.
Prior to binutils 2.28 that works OK. But since binutils commit
1a9ccd70f9a7 ("Fix the linker so that it will not silently generate ELF
binaries with invalid program headers. Fix readelf to report such
invalid binaries.") binutils tries to create a program header segment
due to PT_INTERP, and the link fails because there is no space for it:
ld: arch/powerpc/boot/zImage.pseries: Not enough room for program headers, try linking with -N
ld: final link failed: Bad value
So tell the linker not to do that, by passing --no-dynamic-linker.
Reported-by: Anton Blanchard <anton@samba.org>
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
[mpe: Drop dependency on ld-version.sh and massage change log]
commit 6dff5b67054e17c91bd630bcdda17cfca5aa4215 upstream.
GCC 5 generates different code for this bootwrapper null check that
causes the PS3 to hang very early in its bootup. This check is of
limited value, so just get rid of it.
Signed-off-by: Geoff Levand <geoff@infradead.org>
commit f87f253bac3ce4a4eb2a60a1ae604d74e65f9042 upstream.
From 80f23935cadb ("powerpc: Convert cmp to cmpd in idle enter sequence"):
PowerPC's "cmp" instruction has four operands. Normally people write
"cmpw" or "cmpd" for the second cmp operand 0 or 1. But, frequently
people forget, and write "cmp" with just three operands.
With older binutils this is silently accepted as if this was "cmpw",
while often "cmpd" is wanted. With newer binutils GAS will complain
about this for 64-bit code. For 32-bit code it still silently assumes
"cmpw" is what is meant.
In this case, cmpwi is called for, so this is just a build fix for
new toolchains.
commit 9d85eb9119f4eeeb48e87adfcd71f752655700e9 upstream.
The logical package management has several issues:
- The APIC ids provided by ACPI are not required to be the same as the
initial APIC id which can be retrieved by CPUID. The APIC ids provided
by ACPI are those which are written by the BIOS into the APIC. The
initial id is set by hardware and can not be changed. The hardware
provided ids contain the real hardware package information.
Especially AMD sets the effective APIC id different from the hardware id
as they need to reserve space for the IOAPIC ids starting at id 0.
As a consequence those machines trigger the currently active firmware
bug printouts in dmesg, These are obviously wrong.
- Virtual machines have their own interesting of enumerating APICs and
packages which are not reliably covered by the current implementation.
The sizing of the mapping array has been tweaked to be generously large to
handle systems which provide a wrong core count when HT is disabled so the
whole magic which checks for space in the physical hotplug case is not
needed anymore.
Simplify the whole machinery and do the mapping when the CPU starts and the
CPUID derived physical package information is available. This solves the
observed problems on AMD machines and works for the virtualization issues
as well.
Remove the extra call from XEN cpu bringup code as it is not longer
required.
Fixes: d49597fd3bc7 ("x86/cpu: Deal with broken firmware (VMWare/XEN)")
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: M. Vefa Bicakci <m.v.b@runbox.com>
Cc: xen-devel <xen-devel@lists.xen.org>
Cc: Charles (Chas) Williams <ciwillia@brocade.com>
Cc: Alok Kataria <akataria@vmware.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1612121102260.3429@nanos
to it
commit 847fa1a6d3d00f3bdf68ef5fa4a786f644a0dd67 upstream.
With new binutils, gcc may get smart with its optimization and change a jmp
from a 5 byte jump to a 2 byte one even though it was jumping to a global
function. But that global function existed within a 2 byte radius, and gcc
was able to optimize it. Unfortunately, that jump was also being modified
when function graph tracing begins. Since ftrace expected that jump to be 5
bytes, but it was only two, it overwrote code after the jump, causing a
crash.
This was fixed for x86_64 with commit 8329e818f149, with the same subject as
this commit, but nothing was done for x86_32.
Fixes: d61f82d06672 ("ftrace: use dynamic patching for updating mcount calls")
Reported-by: Colin Ian King <colin.king@canonical.com>
Tested-by: Colin Ian King <colin.king@canonical.com>
commit ef85b67385436ddc1998f45f1d6a210f935b3388 upstream.
When L2 exits to L0 due to "exception or NMI", software exceptions
(#BP and #OF) for which L1 has requested an intercept should be
handled by L1 rather than L0. Previously, only hardware exceptions
were forwarded to L1.
Signed-off-by: Jim Mattson <jmattson@google.com>
commit f064a0de1579fabded8990bed93971e30deb9ecb upstream.
The hashed page table MMU in POWER processors can update the R
(reference) and C (change) bits in a HPTE at any time until the
HPTE has been invalidated and the TLB invalidation sequence has
completed. In kvmppc_h_protect, which implements the H_PROTECT
hypercall, we read the HPTE, modify the second doubleword,
invalidate the HPTE in memory, do the TLB invalidation sequence,
and then write the modified value of the second doubleword back
to memory. In doing so we could overwrite an R/C bit update done
by hardware between when we read the HPTE and when the TLB
invalidation completed. To fix this we re-read the second
doubleword after the TLB invalidation and OR in the (possibly)
new values of R and C. We can use an OR since hardware only ever
sets R and C, never clears them.
This race was found by code inspection. In principle this bug could
cause occasional guest memory corruption under host memory pressure.
Fixes: a8606e20e41a ("KVM: PPC: Handle some PAPR hcalls in the kernel", 2011-06-29)
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 upstream.
When switching from/to a guest that has a transaction in progress,
we need to save/restore the checkpointed register state. Although
XER is part of the CPU state that gets checkpointed, the code that
does this saving and restoring doesn't save/restore XER.
This fixes it by saving and restoring the XER. To allow userspace
to read/write the checkpointed XER value, we also add a new ONE_REG
specifier.
The visible effect of this bug is that the guest may see its XER
value being corrupted when it uses transactions.
Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support")
Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit")
Reviewed-by: Thomas Huth <thuth@redhat.com>
commit 21cbe3cc8a48ff17059912e019fbde28ed54745a upstream.
The ARMv8 architecture allows the cycle counter to be configured
by setting PMSELR_EL0.SEL==0x1f and then accessing PMXEVTYPER_EL0,
hence accessing PMCCFILTR_EL0. But it disallows the use of
PMSELR_EL0.SEL==0x1f to access the cycle counter itself through
PMXEVCNTR_EL0.
Linux itself doesn't violate this rule, but we may end up with
PMSELR_EL0.SEL being set to 0x1f when we enter a guest. If that
guest accesses PMXEVCNTR_EL0, the access may UNDEF at EL1,
despite the guest not having done anything wrong.
In order to avoid this unfortunate course of events (haha!), let's
sanitize PMSELR_EL0 on guest entry. This ensures that the guest
won't explode unexpectedly.
Acked-by: Will Deacon <will.deacon@arm.com>
commit 9f88eb4df728aebcd2ddd154d99f1d75b428b897 upstream.
When re-adding crash kernel memory within setup_resources() the
function memblock_add() is used. That function will add memory by
default to node "MAX_NUMNODES" instead of node 0, like the memory
detection code does. In case of !NUMA this will trigger this warning
when the kernel generates the vmemmap:
Usage of MAX_NUMNODES is deprecated. Use NUMA_NO_NODE instead
WARNING: CPU: 0 PID: 0 at mm/memblock.c:1261 memblock_virt_alloc_internal+0x76/0x220
CPU: 0 PID: 0 Comm: swapper Not tainted 4.9.0-rc6 #16
Call Trace:
[<0000000000d0b2e8>] memblock_virt_alloc_try_nid+0x88/0xc8
[<000000000083c8ea>] __earlyonly_bootmem_alloc.constprop.1+0x42/0x50
[<000000000083e7f4>] vmemmap_populate+0x1ac/0x1e0
[<0000000000840136>] sparse_mem_map_populate+0x46/0x68
[<0000000000d0c59c>] sparse_init+0x184/0x238
[<0000000000cf45f6>] paging_init+0xbe/0xf8
[<0000000000cf1d4a>] setup_arch+0xa02/0xae0
[<0000000000ced75a>] start_kernel+0x72/0x450
[<0000000000100020>] _stext+0x20/0x80
If NUMA is selected numa_setup_memory() will fix the node assignments
before the vmemmap will be populated; so this warning will only appear
if NUMA is not selected.
To fix this simply use memblock_add_node() and re-add crash kernel
memory explicitly to node 0.
Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Fixes: 4e042af463f8 ("s390/kexec: fix crash on resize of reserved memory")
commit 08fe007968b2b45e831daf74899f79a54d73f773 upstream.
An ARC700 customer reported linux boot crashes when upgrading to bigger
L1 dcache (64K from 32K). Turns out they had an aliasing VIPT config and
current code only assumed 2 colours, while theirs had 4. So default to 4
colours and complain if there are fewer. Ideally this needs to be a
Kconfig option, but heck that's too much of hassle for a single user.
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 5e6b9a89afceadb1ee45472098f7d20af260335c upstream.
Add the VDD_GPU regulator (a GPIO-enabled PWM regulator) to the Jetson
TX1 board. This addition allows the GPU to be used provided the
bootloader properly enabled the GPU node.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[as pointed out by Thierry on IRC, nobody has reported a bug
in the field, but using a new bootloader with a .dtb that
has the incorrect data, it will crash on boot]
Fixes: 336f79c7b6d7 ("arm64: tegra: Add NVIDIA Jetson TX1 Developer Kit support")
commit 834fcd298003c10ce450e66960c78893cb1cc4b5 upstream.
If the pmu registration fails the registered hotplug callbacks are not
removed. Wrong in any case, but fatal in case of a modular driver.
Replace the nonsensical state names with proper ones while at it.
Fixes: 77c34ef1c319 ("perf/x86/intel/cstate: Convert Intel CSTATE to hotplug state machine")
Cc: Sebastian Siewior <bigeasy@linutronix.de>
commit b0c1ef52959582144bbea9a2b37db7f4c9e399f7 upstream.
An earlier patch allowed enabling PT and LBR at the same
time on Goldmont. However it also allowed enabling BTS and LBR
at the same time, which is still not supported. Fix this by
bypassing the check only for PT.
Cc: alexander.shishkin@intel.com
Cc: kan.liang@intel.com
Fixes: ccbebba4c6bf ("perf/x86/intel/pt: Bypass PT vs. LBR exclusivity if the core supports it")
Link: http://lkml.kernel.org/r/20161209001417.4713-1-andi@firstfloor.org
commit 334bb773876403eae3457d81be0b8ea70f8e4ccc upstream.
Commit 4efca4ed ("kbuild: modversions for EXPORT_SYMBOL() for asm") adds
modversion support for symbols exported from asm files. Architectures
must include C-style declarations for those symbols in asm/asm-prototypes.h
in order for them to be versioned.
Add these declarations for x86, and an architecture-independent file that
can be used for common symbols.
With f27c2f6 reverting 8ab2ae6 ("default exported asm symbols to zero") we
produce a scary warning on x86, this commit fixes that.
Signed-off-by: Adam Borowski <kilobyte@angband.pl>
Tested-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Nicholas Piggin <npiggin@gmail.com>
Tested-by: Peter Wu <peter@lekensteyn.nl>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 24d5373dda7c00a438d26016bce140299fae675e upstream.
The function xen_guest_init is using __alloc_percpu with an alignment
which are not power of two.
However, the percpu allocator never supported alignments which are not power
of two and has always behaved incorectly in thise case.
Commit 3ca45a4 "percpu: ensure requested alignment is power of two"
introduced a check which trigger a warning [1] when booting linux-next
on Xen. But in reality this bug was always present.
This can be fixed by replacing the call to __alloc_percpu with
alloc_percpu. The latter will use an alignment which are a power of two.
[1]
[ 0.023921] illegal size (48) or align (48) for percpu allocation
[ 0.024167] ------------[ cut here ]------------
[ 0.024344] WARNING: CPU: 0 PID: 1 at linux/mm/percpu.c:892 pcpu_alloc+0x88/0x6c0
[ 0.024584] Modules linked in:
[ 0.024708]
[ 0.024804] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
4.9.0-rc7-next-20161128 #473
[ 0.025012] Hardware name: Foundation-v8A (DT)
[ 0.025162] task: ffff80003d870000 task.stack: ffff80003d844000
[ 0.025351] PC is at pcpu_alloc+0x88/0x6c0
[ 0.025490] LR is at pcpu_alloc+0x88/0x6c0
[ 0.025624] pc : [<ffff00000818e678>] lr : [<ffff00000818e678>]
pstate: 60000045
[ 0.025830] sp : ffff80003d847cd0
[ 0.025946] x29: ffff80003d847cd0 x28: 0000000000000000
[ 0.026147] x27: 0000000000000000 x26: 0000000000000000
[ 0.026348] x25: 0000000000000000 x24: 0000000000000000
[ 0.026549] x23: 0000000000000000 x22: 00000000024000c0
[ 0.026752] x21: ffff000008e97000 x20: 0000000000000000
[ 0.026953] x19: 0000000000000030 x18: 0000000000000010
[ 0.027155] x17: 0000000000000a3f x16: 00000000deadbeef
[ 0.027357] x15: 0000000000000006 x14: ffff000088f79c3f
[ 0.027573] x13: ffff000008f79c4d x12: 0000000000000041
[ 0.027782] x11: 0000000000000006 x10: 0000000000000042
[ 0.027995] x9 : ffff80003d847a40 x8 : 6f697461636f6c6c
[ 0.028208] x7 : 6120757063726570 x6 : ffff000008f79c84
[ 0.028419] x5 : 0000000000000005 x4 : 0000000000000000
[ 0.028628] x3 : 0000000000000000 x2 : 000000000000017f
[ 0.028840] x1 : ffff80003d870000 x0 : 0000000000000035
[ 0.029056]
[ 0.029152] ---[ end trace 0000000000000000 ]---
[ 0.029297] Call trace:
[ 0.029403] Exception stack(0xffff80003d847b00 to
0xffff80003d847c30)
[ 0.029621] 7b00: 0000000000000030 0001000000000000
ffff80003d847cd0 ffff00000818e678
[ 0.029901] 7b20: 0000000000000002 0000000000000004
ffff000008f7c060 0000000000000035
[ 0.030153] 7b40: ffff000008f79000 ffff000008c4cd88
ffff80003d847bf0 ffff000008101778
[ 0.030402] 7b60: 0000000000000030 0000000000000000
ffff000008e97000 00000000024000c0
[ 0.030647] 7b80: 0000000000000000 0000000000000000
[ 0.030895] 7ba0: 0000000000000035 ffff80003d870000
000000000000017f 0000000000000000
[ 0.031144] 7bc0: 0000000000000000 0000000000000005
ffff000008f79c84 6120757063726570
[ 0.031394] 7be0: 6f697461636f6c6c ffff80003d847a40
0000000000000042 0000000000000006
[ 0.031643] 7c00: 0000000000000041 ffff000008f79c4d
ffff000088f79c3f 0000000000000006
[ 0.031877] 7c20: 00000000deadbeef 0000000000000a3f
[ 0.032051] [<ffff00000818e678>] pcpu_alloc+0x88/0x6c0
[ 0.032229] [<ffff00000818ece8>] __alloc_percpu+0x18/0x20
[ 0.032409] [<ffff000008d9606c>] xen_guest_init+0x174/0x2f4
[ 0.032591] [<ffff0000080830f8>] do_one_initcall+0x38/0x130
[ 0.032783] [<ffff000008d90c34>] kernel_init_freeable+0xe0/0x248
[ 0.032995] [<ffff00000899a890>] kernel_init+0x10/0x100
[ 0.033172] [<ffff000008082ec0>] ret_from_fork+0x10/0x50
Reported-by: Wei Chen <wei.chen@arm.com>
Link: https://lkml.org/lkml/2016/11/28/669
Signed-off-by: Julien Grall <julien.grall@arm.com>
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
commit 84d77d3f06e7e8dea057d10e8ec77ad71f721be3 upstream.
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Reported-by: Andy Lutomirski <luto@amacapital.net>
Pull MIPS fixes from Ralf Baechle:
"Two more MIPS fixes for 4.9:
- RTC: Return -ENODEV so an external RTC will be tried
- Fix mask of GPE frequency
These two have been tested on Imagination's automated test system and
also both received positive reviews on the linux-mips mailing list"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: Lantiq: Fix mask of GPE frequency
MIPS: Return -ENODEV from weak implementation of rtc_mips_set_time
The hardware documentation says bit 11:10 are used for the GPE
frequency selection. Fix the mask in the define to match these bits.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reviewed-by: Thomas Langer <thomas.langer@intel.com>
Cc: linux-mips@linux-mips.org
Cc: john@phrozen.org
Patchwork: https://patchwork.linux-mips.org/patch/14648/
The sync_cmos_clock function in kernel/time/ntp.c first tries to update
the internal clock of the cpu by calling the "update_persistent_clock64"
architecture specific function. If this returns -ENODEV, it then tries
to update an external RTC using "rtc_set_ntp_time".
On the mips architecture, the weak implementation of the underlying
function would return 0 if it wasn't overridden. This meant that the
sync_cmos_clock function would never try to update an external RTC
(if both CONFIG_GENERIC_CMOS_UPDATE and CONFIG_RTC_SYSTOHC are
configured)
Returning -ENODEV instead, means that an external RTC will be tried.
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz>
Reviewed-by: Richard Laing <richard.laing@alliedtelesis.co.nz>
Reviewed-by: Scott Parlane <scott.parlane@alliedtelesis.co.nz>
Reviewed-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Patchwork: https://patchwork.linux-mips.org/patch/14649/
Pull ARM SoC fixes from Olof Johansson:
"Final batch of SoC fixes
A few fixes that have trickled in over the last week, all fixing minor
errors in devicetrees -- UART pin assignment on Allwinner H3,
correcting number of SATA ports on a Marvell-based Linkstation
platform and a display clock fix for Freescale/NXP i.MX7D that fixes a
freeze when starting up X"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: orion5x: fix number of sata port for linkstation ls-gl
ARM: dts: imx7d: fix LCDIF clock assignment
dts: sun8i-h3: correct UART3 pin definitions
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k fixes from Geert Uytterhoeven:
- build fix for drivers calling ndelay() in a conditional block without
curly braces
- defconfig updates
* tag 'm68k-for-v4.9-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Fix ndelay() macro
m68k/defconfig: Update defconfigs for v4.9-rc1
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes from Helge Deller:
"Three important fixes for the parisc architecture.
Dave provided two patches: One which purges the TLB before setting a
PTE entry and a second one which drops unnecessary TLB flushes. Both
patches have been tested for one week on the debian buildd servers and
prevent random segmentation faults.
The patch from me fixes a crash at boot inside the TLB measuring code
on SMP machines with PA8000-PA8700 CPUs (specifically A500-44 and
J5000 servers)"
* 'parisc-4.9-5' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix TLB related boot crash on SMP machines
parisc: Remove unnecessary TLB purges from flush_dcache_page_asm and flush_icache_page_asm
parisc: Purge TLB before setting PTE
At bootup we run measurements to calculate the best threshold for when we
should be using full TLB flushes instead of just flushing a specific amount of
TLB entries. This performance test is run over the kernel text segment.
But running this TLB performance test on the kernel text segment turned out to
crash some SMP machines when the kernel text pages were mapped as huge pages.
To avoid those crashes this patch simply skips this test on some SMP machines
and calculates an optimal threshold based on the maximum number of available
TLB entries and number of online CPUs.
On a technical side, this seems to happen:
The TLB measurement code uses flush_tlb_kernel_range() to flush specific TLB
entries with a page size of 4k (pdtlb 0(sr1,addr)). On UP systems this purge
instruction seems to work without problems even if the pages were mapped as
huge pages. But on SMP systems the TLB purge instruction is broadcasted to
other CPUs. Those CPUs then crash the machine because the page size is not as
expected. C8000 machines with PA8800/PA8900 CPUs were not affected by this
problem, because the required cache coherency prohibits to use huge pages at
all. Sadly I didn't found any documentation about this behaviour, so this
finding is purely based on testing with phyiscal SMP machines (A500-44 and
J5000, both were 2-way boxes).
Cc: <stable@vger.kernel.org> # v3.18+
Signed-off-by: Helge Deller <deller@gmx.de>
Bug report from Debian [0] shows there's minor changed model of
Linkstation LS-GL that uses the 2nd SATA port of the SoC.
So it's necessary to enable two SATA ports, though for that specific
model only the 2nd one is used.
[0] https://bugs.debian.org/845611
Fixes: b1742ffa9ddb ("ARM: dts: orion5x: add device tree for buffalo linkstation ls-gl")
Reported-by: Ryan Tandy <ryan@nardis.ca>
Tested-by: Ryan Tandy <ryan@nardis.ca>
Signed-off-by: Roger Shimizu <rogershimizu@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The eLCDIF IP of the i.MX 7 SoC knows multiple clocks and lists them
separately:
Clock Clock Root Description
apb_clk MAIN_AXI_CLK_ROOT AXI clock
pix_clk LCDIF_PIXEL_CLK_ROOT Pixel clock
ipg_clk_s MAIN_AXI_CLK_ROOT Peripheral access clock
All of them are switched by a single gate, which is part of the
IMX7D_LCDIF_PIXEL_ROOT_CLK clock. Hence using that clock also for
the AXI bus clock (clock-name "axi") makes sure the gate gets
enabled when accessing registers.
There seem to be no separate AXI display clock, and the clock is
optional. Hence remove the dummy clock.
This fixes kernel freezes when starting the X-Server (which
disables/re-enables the display controller).
Fixes: e8ed73f691bd ("ARM: dts: imx7d: add lcdif support")
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
In a previous commit, I made a copy/paste error in the pinmux
definitions of UART3: PG{13,14} instead of PA{13,14}. This commit takes
care of that. I have tested this commit on Orange Pi PC and Orange Pi
Plus, and it works for these boards.
Fixes: e3d11d3c45c5 ("dts: sun8i-h3: add pinmux definitions for
UART2-3")
Signed-off-by: Jorik Jonker <jorik@kippendief.biz>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Pull x86 fixes from Ingo Molnar:
"Misc fixes: a core dumping crash fix, a guess-unwinder regression fix,
plus three build warning fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/unwind: Fix guess-unwinder regression
x86/build: Annotate die() with noreturn to fix build warning on clang
x86/platform/olpc: Fix resume handler build warning
x86/apic/uv: Silence a shift wrapping warning
x86/coredump: Always use user_regs_struct for compat_elf_gregset_t
We have four routines in pacache.S that use temporary alias pages:
copy_user_page_asm(), clear_user_page_asm(), flush_dcache_page_asm() and
flush_icache_page_asm(). copy_user_page_asm() and clear_user_page_asm()
don't purge the TLB entry used for the operation.
flush_dcache_page_asm() and flush_icache_page_asm do purge the entry.
Presumably, this was thought to optimize TLB use. However, the
operation is quite heavy weight on PA 1.X processors as we need to take
the TLB lock and a TLB broadcast is sent to all processors.
This patch removes the purges from flush_dcache_page_asm() and
flush_icache_page_asm.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: <stable@vger.kernel.org> # v3.16+
The attached change interchanges the order of purging the TLB and
setting the corresponding page table entry. TLB purges are strongly
ordered. It occurred to me one night that setting the PTE first might
have subtle ordering issues on SMP machines and cause random memory
corruption.
A TLB lock guards the insertion of user TLB entries. So after the TLB
is purged, a new entry can't be inserted until the lock is released.
This ensures that the new PTE value is used when the lock is released.
Since making this change, no random segmentation faults have been
observed on the Debian hppa buildd servers.
Lukasz reported that perf stat counters overflow handling is broken on KNL/SLM.
Both these parts have full_width_write set, and that does indeed have
a problem. In order to deal with counter wrap, we must sample the
counter at at least half the counter period (see also the sampling
theorem) such that we can unambiguously reconstruct the count.
However commit:
069e0c3c4058 ("perf/x86/intel: Support full width counting")
sets the sampling interval to the full period, not half.
Fixing that exposes another issue, in that we must not sign extend the
delta value when we shift it right; the counter cannot have
decremented after all.
With both these issues fixed, counter overflow functions correctly
again.
Reported-by: Lukasz Odzioba <lukasz.odzioba@intel.com>
Tested-by: Liang, Kan <kan.liang@intel.com>
Tested-by: Odzioba, Lukasz <lukasz.odzioba@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: stable@vger.kernel.org
Fixes: 069e0c3c4058 ("perf/x86/intel: Support full width counting")
The Knights Mill is enough close to Knights Landing so the path reuses
C-state residency support of the latter.
Signed-off-by: Piotr Luc <piotr.luc@intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20161201000853.18260-1-piotr.luc@intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
"Four fixes, the first for code we merged this cycle and three that are
also going to stable:
- On 64-bit Book3E we were not placing the .text section where we
said we would in the asm.
- We broke building the boot wrapper on some 32-bit toolchains.
- Lazy icache flushing was broken on pre-POWER5 machines.
- One of the error paths in our EEH code would lead to a deadlock.
Thanks to: Andrew Donnellan, Ben Hutchings, Benjamin Herrenschmidt,
Nicholas Piggin"
* tag 'powerpc-4.9-7' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/64: Fix placement of .text to be immediately following .head.text
powerpc/eeh: Fix deadlock when PE frozen state can't be cleared
powerpc/mm: Fix lazy icache flush on pre-POWER5
powerpc/boot: Fix build failure in 32-bit boot wrapper
Pull ARM SoC fixes from Arnd Bergmann:
"This should be the last set of bugfixes for arm-soc in v4.9. None of
these are critical regressions, but it would be nice to still get them
merged.
- On the Juno platform, the idle latency was described wrong, leading
to suboptimal cpuidle tuning.
- Also on the same platform, PCI I/O space was set up incorrectly and
could not work.
- On the sti platform, a syntactically incorrect DT entry caused
warnings.
- The newly added 'gr8' platform has somewhat confusing file names,
which we rename for consistency"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dts: juno: fix cluster sleep state entry latency on all SoC versions
arm64: dts: juno: Correct PCI IO window
ARM: dts: STiH407-family: fix i2c nodes
ARM: gr8: Rename the DTSI and relevant DTS
The core and the cluster sleep state entry latencies can't be same as
cluster sleep involves more work compared to core level e.g. shared
cache maintenance.
Experiments have shown on an average about 100us more latency for the
cluster sleep state compared to the core level sleep. This patch fixes
the entry latency for the cluster sleep state.
Fixes: 28e10a8f3a03 ("arm64: dts: juno: Add idle-states to device tree")
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: "Jon Medhurst (Tixy)" <tixy@linaro.org>
Reviewed-by: Liviu Dudau <Liviu.Dudau@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Do not introduce any additional alignment. Placement of text section
will be set by fixed section macros. Without this, output section
alignment defaults to 4096, which makes BookE text section start at
0x1000 when it is expected to start at 0x100.
This was introduced by commit 57f266497d81 ("powerpc: Use gas sections
for arranging exception vectors") and was caught with the scripted head
section checker (not yet merged).
Fixes: 57f266497d81 ("powerpc: Use gas sections for arranging exception vectors")
In eeh_reset_device(), we take the pci_rescan_remove_lock immediately after
after we call eeh_reset_pe() to reset the PCI controller. We then call
eeh_clear_pe_frozen_state(), which can return an error. In this case, we
bail out of eeh_reset_device() without calling pci_unlock_rescan_remove().
Add a call to pci_unlock_rescan_remove() in the eeh_clear_pe_frozen_state()
error path so that we don't cause a deadlock later on.
Reported-by: Pradipta Ghosh <pradghos@in.ibm.com>
Fixes: 78954700631f ("powerpc/eeh: Avoid I/O access during PE reset")
Cc: stable@vger.kernel.org # v3.16+
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Acked-by: Russell Currey <ruscur@russell.cc>
The PCIe root complex on Juno translates the MMIO mapped
at 0x5f800000 to the PIO address range starting at 0
(which is common because PIO addresses are generally < 64k).
Correct the DT to reflect this.
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
commit 1c3c90930392 broke PAE40. Macro pfn_pte(pfn, prot) creates paddr
from pfn, but the page shift was getting truncated to 32 bits since we lost
the proper cast to 64 bits (for PAE400
Instead of reverting that commit, use a better helper which is 32/64 bits
safe just like ARM implementation.
Fixes: 1c3c90930392 ("ARC: mm: fix build breakage with STRICT_MM_TYPECHECKS")
Cc: <stable@vger.kernel.org> #4.4+
Signed-off-by: Yuriy Kolerov <yuriy.kolerov@synopsys.com>
[vgupta: massaged changelog]
On 64-bit CPUs with no-execute support and non-snooping icache, such as
970 or POWER4, we have a software mechanism to ensure coherency of the
cache (using exec faults when needed).
This was broken due to a logic error when the code was rewritten
from assembly to C, previously the assembly code did:
BEGIN_FTR_SECTION
mr r4,r30
mr r5,r7
bl hash_page_do_lazy_icache
END_FTR_SECTION(CPU_FTR_NOEXECUTE|CPU_FTR_COHERENT_ICACHE, CPU_FTR_NOEXECUTE)
Which tests that:
(cpu_features & (NOEXECUTE | COHERENT_ICACHE)) == NOEXECUTE
Which says that the current cpu does have NOEXECUTE, but does not have
COHERENT_ICACHE.
Fixes: 91f1da99792a ("powerpc/mm: Convert 4k hash insert to C")
Fixes: 89ff725051d1 ("powerpc/mm: Convert __hash_page_64K to C")
Fixes: a43c0eb8364c ("powerpc/mm: Convert 4k insert from asm to C")
Cc: stable@vger.kernel.org # v4.5+
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[mpe: Change log verbosification]
Apparenty this is coming in the way of gcc fix which inhibits the usage
of LP_COUNT as a gpr.
OPAL is not callable from 32-bit mode and the assembly code for it
may not even build (depending on how binutils was configured).
References: https://buildd.debian.org/status/fetch.php?pkg=linux&arch=powerpcspe&ver=4.8.7-1&stamp=1479203712
Fixes: 656ad58ef19e ("powerpc/boot: Add OPAL console to epapr wrappers")
Cc: stable@vger.kernel.org # v4.8+
My attempt at fixing some KASAN false positive warnings was rather brain
dead, and it broke the guess unwinder. With frame pointers disabled,
/proc/<pid>/stack is broken:
# cat /proc/1/stack
[<ffffffffffffffff>] 0xffffffffffffffff
Restore the code flow to more closely resemble its previous state, while
still using READ_ONCE_NOCHECK() macros to silence KASAN false positives.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: c2d75e03d630 ("x86/unwind: Prevent KASAN false positive warnings in guess unwinder")
Link: http://lkml.kernel.org/r/b824f92c2c22eca5ec95ac56bd2a7c84cf0b9df9.1480309971.git.jpoimboe@redhat.com
Fixes below warning with clang:
In file included from ../arch/x86/tools/relocs_64.c:17:
../arch/x86/tools/relocs.c:977:6: warning: variable 'do_reloc' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Link: http://lkml.kernel.org/r/20161126222229.673-1-pefoley2@pefoley.com
Fix:
arch/x86/platform/olpc/olpc-xo15-sci.c:199:12: warning: ‘xo15_sci_resume’
defined but not used [-Wunused-function]
static int xo15_sci_resume(struct device *dev)
which I see in randconfig builds here.
Link: http://lkml.kernel.org/r/20161126142706.13602-1-bp@alien8.de
"Another round of MIPS fixes for 4.9:
- Fix unreadable output in __do_page_fault due to the KERN_CONT
patchset
- Correctly handle MIPS R6 fixes to the c0_wired register"
MIPS: mm: Fix output of __do_page_fault
MIPS: Mask out limit field when calculating wired entry count
Pull ARM fix from Russell King:
"This resolves the ksyms issues by reverting the commit which
introduced the breakage"
There was what I consider to be a better fix, but it's late in the rc
game, so I'll take the revert.
* 'fixes' of git://git.armlinux.org.uk/~rmk/linux-arm:
Revert "arm: move exports to definitions"
Pull KVM fixes from Radim Krčmář:
"Four fixes for bugs found by syzkaller on x86, all for stable"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: check for pic and ioapic presence before use
KVM: x86: fix out-of-bounds accesses of rtc_eoi map
KVM: x86: drop error recovery in em_jmp_far and em_ret_far
KVM: x86: fix out-of-bounds access in lapic
"Fixes marked for stable:
- Set missing wakeup bit in LPCR on POWER9
- Fix the early OPAL console wrappers
- Fixup kernel read only mapping
Fixes for code merged this cycle:
- Fix missing CRCs, add more asm-prototypes.h declarations"
* tag 'powerpc-4.9-6' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
powerpc/mm: Fixup kernel read only mapping
powerpc/boot: Fix the early OPAL console wrappers
powerpc: Fix missing CRCs, add more asm-prototypes.h declarations
powerpc: Set missing wakeup bit in LPCR on POWER9
