path: root/block/Makefile
2010-04-28blkdev: move blkdev_issue helper functions to separate fileDmitry Monakhov
Move blkdev_issue_discard from blk-barrier.c because it is not barrier related. Later the file will be populated by other helpers. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-03blkio: Introduce blkio controller cgroup interfaceVivek Goyal
o This is basic implementation of blkio controller cgroup interface. This is the common interface visible to user space and should be used by different IO control policies as we implement those. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-03block: remove the anticipatory IO schedulerJens Axboe
AS is mostly a subset of CFQ, so there's little point in still providing this separate IO scheduler. Hopefully at some point we can get down to one single IO scheduler again, at least this brings us closer by having only one intelligent IO scheduler. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11block: add blk-iopoll, a NAPI like approach for block devicesJens Axboe
This borrows some code from NAPI and implements a polled completion mode for block devices. The idea is the same as NAPI - instead of doing the command completion when the irq occurs, schedule a dedicated softirq in the hopes that we will complete more IO when the iopoll handler is invoked. Devices have a budget of commands assigned, and will stay in polled mode as long as they continue to consume their budget from the iopoll softirq handler. If they do not, the device is set back to interrupt completion mode. This patch holds the core bits for blk-iopoll, device driver support sold separately. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: get rid of queue-private command filterJens Axboe
The initial patches to support this through sysfs export were broken and have been if 0'ed out in any release. So lets just kill the code and reclaim some space in struct request_queue, if anyone would later like to fixup the sysfs bits, the git history can easily restore the removed bits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-09tracing/blktrace: move the tracing file to kernel/traceFrederic Weisbecker
Impact: cleanup Move blktrace.c to kernel/trace, also move its config entry. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: split softirq handling into blk-softirq.cJens Axboe
2008-07-03allow userspace to modify scsi command filter on per device basisAdel Gadllah
This patch exports the per-gendisk command filter to user space through sysfs, so it can be changed by the system administrator. All users of the old cmd filter have been converted to use the new one. Original patch from Peter Jones. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: ll_rw_blk.c split, add blk-merge.cJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: first step of splitting ll_rw_blk, rename itJens Axboe
Then we retain history in blk-core.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[BLOCK] Only include the compat ioctl code if CONFIG_BLOCK is setJens Axboe
Add an extra CONFIG_BLOCK_COMPAT that we can use in the Makefile Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move common block ioctls to compat_blkdev_ioctlArnd Bergmann
Make compat_blkdev_ioctl and blkdev_ioctl reflect the respective native versions. This is somewhat more efficient and makes it easier to keep the two in sync. Also get rid of the bogus handling for broken_blkgetsize and the duplicate entry for BLKRASET. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16bsg: support for full generic block layer SG v3Jens Axboe
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-04[BLOCK] Move all core block layer code to new block/ directoryJens Axboe
drivers/block/ is right now a mix of core and driver parts. Lets move the core parts to a new top level directory. Al will move the fs/ related block parts to block/ next. Signed-off-by: Jens Axboe <axboe@suse.de>
