[ Upstream commit 39b4954c0a1556f8f7f1fdcf59a227117fcd8a0b ]
MD's rdev_set_badblocks() expects that badblocks_set() returns 1 if
badblocks are disabled, otherwise, rdev_set_badblocks() will record
superblock changes and return success in that case and md will fail to
report an IO error which it should.
This bug has existed since badblocks were introduced in commit
9e0e252a048b ("badblocks: Add core badblock management code").
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Acked-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
This patch suppresses gcc 7 warnings about falling through in switch
statements when building with W=1. From the gcc documentation: The
-Wimplicit-fallthrough=3 warning is enabled by -Wextra. See also
https://gcc.gnu.org/onlinedocs/gcc-7.1.0/gcc/Warning-Options.html.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
When bandblocks_set acknowledges a range or badblocks_clear a range,
it's possible all badblocks are acknowledged. We should update
unacked_exist if this occurs.
Reviewed-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Tested-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Current bad block clear implementation assumes the range to clear
overlaps with at least one bad block already stored. If given range to
clear precedes first bad block in a list, the first entry is incorrectly
updated.
Check not only if stored block end is past clear block end but also if
stored block start is before clear block end.
Signed-off-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Acked-by: NeilBrown <neilb@suse.com>
Provide a devres interface for initializing a badblocks instance. The
pmem driver has several scenarios where it will be beneficial to have
this structure automatically freed when the device is disabled / fails
probe.
The badblocks list attached to a gendisk is allocated by the driver
which equates to the driver owning the lifetime of the object. Do not
automatically free it in del_gendisk(). This is in preparation for
expanding the use of badblocks in libnvdimm drivers and introducing
devm_init_badblocks().
For symmetry with badblocks_init() make it clear that this path only
destroys incremental allocations of a badblocks instance, and does not
free the badblocks instance itself.
Take the core badblocks implementation from md, and make it generally
available. This follows the same style as kernel implementations of
linked lists, rb-trees etc, where you can have a structure that can be
embedded anywhere, and accessor functions to manipulate the data.
The only changes in this copy of the code are ones to generalize
function/variable names from md-specific ones. Also add init and free
functions.
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
