[ Upstream commit 901932a3f9b2b80352896be946c6d577c0a9652c ]
The initializing of q->root_blkg is currently outside of queue lock
and rcu, so the blkg may be destroied before the initializing, which
may cause dangling/null references. On the other side, the destroys
of blkg are protected by queue lock or rcu. Put the initializing
inside the queue lock and rcu to make it safer.
Signed-off-by: Jiang Biao <jiang.biao2@zte.com.cn>
Signed-off-by: Wen Yang <wen.yang99@zte.com.cn>
CC: Tejun Heo <tj@kernel.org>
CC: Jens Axboe <axboe@kernel.dk>
[ Upstream commit 946b81da114b8ba5c74bb01e57c0c6eca2bdc801 ]
As described in the comment of blkcg_activate_policy(),
*Update of each blkg is protected by both queue and blkcg locks so
that holding either lock and testing blkcg_policy_enabled() is
always enough for dereferencing policy data.*
with queue lock held, there is no need to hold blkcg lock in
blkcg_deactivate_policy(). Similar case is in
blkcg_activate_policy(), which has removed holding of blkcg lock in
commit 4c55f4f9ad3001ac1fefdd8d8ca7641d18558e23.
this patch fix two errors, firstly avoid kfree blk_root, secondly not
free(blkcg) ,if blkcg alloc fail(blkcg == NULL), just unlock that mutex;
Signed-off-by: weiping zhang <zhangweiping@didichuxing.com>
Since the introduction of .init_rq_fn() and .exit_rq_fn() it is
essential that the memory allocated for struct request_queue
stays around until all blk_exit_rl() calls have finished. Hence
make blk_init_rl() take a reference on struct request_queue.
This patch fixes the following crash:
general protection fault: 0000 [#2] SMP
CPU: 3 PID: 28 Comm: ksoftirqd/3 Tainted: G D 4.12.0-rc2-dbg+ #2
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.0.0-prebuilt.qemu-project.org 04/01/2014
task: ffff88013a108040 task.stack: ffffc9000071c000
RIP: 0010:free_request_size+0x1a/0x30
RSP: 0018:ffffc9000071fd38 EFLAGS: 00010202
RAX: 6b6b6b6b6b6b6b6b RBX: ffff880067362a88 RCX: 0000000000000003
RDX: ffff880067464178 RSI: ffff880067362a88 RDI: ffff880135ea4418
RBP: ffffc9000071fd40 R08: 0000000000000000 R09: 0000000100180009
R10: ffffc9000071fd38 R11: ffffffff81110800 R12: ffff88006752d3d8
R13: ffff88006752d3d8 R14: ffff88013a108040 R15: 000000000000000a
FS: 0000000000000000(0000) GS:ffff88013fd80000(0000) knlGS:0000000000000000
CR2: 00007fa8ec1edb00 CR3: 0000000138ee8000 CR4: 00000000001406e0
Call Trace:
mempool_destroy.part.10+0x21/0x40
mempool_destroy+0xe/0x10
blk_exit_rl+0x12/0x20
blkg_free+0x4d/0xa0
__blkg_release_rcu+0x59/0x170
rcu_process_callbacks+0x260/0x4e0
__do_softirq+0x116/0x250
smpboot_thread_fn+0x123/0x1e0
kthread+0x109/0x140
ret_from_fork+0x31/0x40
Fixes: commit e9c787e65c0c ("scsi: allocate scsi_cmnd structures as part of struct request")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Cc: Jan Kara <jack@suse.cz>
Cc: <stable@vger.kernel.org> # v4.11+
Signed-off-by: Jens Axboe <axboe@fb.com>
blkg_conf_prep() currently calls blkg_lookup_create() while holding
request queue spinlock. This means allocating memory for struct
blkcg_gq has to be made non-blocking. This causes occasional -ENOMEM
failures in call paths like below:
pcpu_alloc+0x68f/0x710
__alloc_percpu_gfp+0xd/0x10
__percpu_counter_init+0x55/0xc0
cfq_pd_alloc+0x3b2/0x4e0
blkg_alloc+0x187/0x230
blkg_create+0x489/0x670
blkg_lookup_create+0x9a/0x230
blkg_conf_prep+0x1fb/0x240
__cfqg_set_weight_device.isra.105+0x5c/0x180
cfq_set_weight_on_dfl+0x69/0xc0
cgroup_file_write+0x39/0x1c0
kernfs_fop_write+0x13f/0x1d0
__vfs_write+0x23/0x120
vfs_write+0xc2/0x1f0
SyS_write+0x44/0xb0
entry_SYSCALL_64_fastpath+0x18/0xad
In the code path above, percpu allocator cannot call vmalloc() due to
queue spinlock.
A failure in this call path gives grief to tools which are trying to
configure io weights. We see occasional failures happen shortly after
reboots even when system is not under any memory pressure. Machines
with a lot of cpus are more vulnerable to this condition.
Do struct blkcg_gq allocations outside the queue spinlock to allow
blocking during memory allocations.
Suggested-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
I inadvertently applied the v5 version of this patch, whereas
the agreed upon version was v5. Revert this one so we can apply
the right one.
This reverts commit 7fc6b87a9ff537e7df32b1278118ce9c5bcd6788.
SyS_write+0x44/0xb0
queue spinlock.
Update blkg_create() function to temporarily drop the rcu and queue
locks when it is allowed by gfp mask.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
If blkg_create fails, new_blkg passed as an argument will
be freed by blkg_create, so there is no need to free it again.
Signed-off-by: Hou Tao <houtao1@huawei.com>
We will want to have struct backing_dev_info allocated separately from
struct request_queue. As the first step add pointer to backing_dev_info
to request_queue and convert all users touching it. No functional
changes in this patch.
There's no potential harm in quiescing the queue, but it also doesn't
buy us anything. And we can't run the queue async for policy
deactivate, since we could be in the path of tearing the queue down.
If we schedule an async run of the queue at that time, we're racing
with queue teardown AFTER having we've already torn most of it down.
Reported-by: Omar Sandoval <osandov@fb.com>
Fixes: 4d199c6f1c84 ("blk-cgroup: ensure that we clear the stop bit on quiesced queues")
Tested-by: Omar Sandoval <osandov@fb.com>
If we call blk_mq_quiesce_queue() on a queue, we must remember to
pair that with something that clears the stopped by on the
queues later on.
This adds a set of hooks that intercepts the blk-mq path of
allocating/inserting/issuing/completing requests, allowing
us to develop a scheduler within that framework.
We reuse the existing elevator scheduler API on the registration
side, but augment that with the scheduler flagging support for
the blk-mq interfce, and with a separate set of ops hooks for MQ
devices.
We split driver and scheduler tags, so we can run the scheduling
independently of device queue depth.
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
blkcg allocates some per-cgroup data structures with GFP_NOWAIT and
when that fails falls back to operations which aren't specific to the
cgroup. Occassional failures are expected under pressure and falling
back to non-cgroup operation is the right thing to do.
Unfortunately, I forgot to add __GFP_NOWARN to these allocations and
these expected failures end up creating a lot of noise. Add
__GFP_NOWARN.
Reported-by: Marc MERLIN <marc@merlins.org>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Unlocking a mutex twice is wrong. Hence modify blkcg_policy_register()
such that blkcg_pol_mutex is unlocked once if cpd == NULL. This patch
avoids that smatch reports the following error:
block/blk-cgroup.c:1378: blkcg_policy_register() error: double unlock 'mutex:&blkcg_pol_mutex'
Fixes: 06b285bd1125 ("blkcg: fix blkcg_policy_data allocation bug")
Cc: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org> # v4.2+
Detected by sparse.
get_disk(),get_gendisk() calls have non explicit side effect: they
increase the reference on the disk owner module.
The following is the correct sequence how to get a disk reference and
to put it:
disk = get_gendisk(...);
/* use disk */
owner = disk->fops->owner;
put_disk(disk);
module_put(owner);
fs/block_dev.c is aware of this required module_put() call, but f.e.
blkg_conf_finish(), which is located in block/blk-cgroup.c, does not put
a module reference. To see a leakage in action cgroups throttle config
can be used. In the following script I'm removing throttle for /dev/ram0
(actually this is NOP, because throttle was never set for this device):
# lsmod | grep brd
brd 5175 0
# i=100; while [ $i -gt 0 ]; do echo "1:0 0" > \
/sys/fs/cgroup/blkio/blkio.throttle.read_bps_device; i=$(($i - 1)); \
done
# lsmod | grep brd
brd 5175 100
Now brd module has 100 references.
The issue is fixed by calling module_put() just right away put_disk().
Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com>
Cc: Gi-Oh Kim <gi-oh.kim@profitbricks.com>
Cc: linux-block@vger.kernel.org
enabling
Consider the following v2 hierarchy.
P0 (+memory) --- P1 (-memory) --- A
\- B
P0 has memory enabled in its subtree_control while P1 doesn't. If
both A and B contain processes, they would belong to the memory css of
P1. Now if memory is enabled on P1's subtree_control, memory csses
should be created on both A and B and A's processes should be moved to
the former and B's processes the latter. IOW, enabling controllers
can cause atomic migrations into different csses.
The core cgroup migration logic has been updated accordingly but the
controller migration methods haven't and still assume that all tasks
migrate to a single target css; furthermore, the methods were fed the
css in which subtree_control was updated which is the parent of the
target csses. pids controller depends on the migration methods to
move charges and this made the controller attribute charges to the
wrong csses often triggering the following warning by driving a
counter negative.
WARNING: CPU: 1 PID: 1 at kernel/cgroup_pids.c:97 pids_cancel.constprop.6+0x31/0x40()
Modules linked in:
CPU: 1 PID: 1 Comm: systemd Not tainted 4.4.0-rc1+ #29
ffffffff81f65382 ffff88007c043b90 ffffffff81551ffc 0000000000000000
ffff88007c043bc8 ffffffff810de202 ffff88007a752000 ffff88007a29ab00
ffff88007c043c80 ffff88007a1d8400 0000000000000001 ffff88007c043bd8
Call Trace:
[<ffffffff81551ffc>] dump_stack+0x4e/0x82
[<ffffffff810de202>] warn_slowpath_common+0x82/0xc0
[<ffffffff810de2fa>] warn_slowpath_null+0x1a/0x20
[<ffffffff8118e031>] pids_cancel.constprop.6+0x31/0x40
[<ffffffff8118e0fd>] pids_can_attach+0x6d/0xf0
[<ffffffff81188a4c>] cgroup_taskset_migrate+0x6c/0x330
[<ffffffff81188e05>] cgroup_migrate+0xf5/0x190
[<ffffffff81189016>] cgroup_attach_task+0x176/0x200
[<ffffffff8118949d>] __cgroup_procs_write+0x2ad/0x460
[<ffffffff81189684>] cgroup_procs_write+0x14/0x20
[<ffffffff811854e5>] cgroup_file_write+0x35/0x1c0
[<ffffffff812e26f1>] kernfs_fop_write+0x141/0x190
[<ffffffff81265f88>] __vfs_write+0x28/0xe0
[<ffffffff812666fc>] vfs_write+0xac/0x1a0
[<ffffffff81267019>] SyS_write+0x49/0xb0
[<ffffffff81bcef32>] entry_SYSCALL_64_fastpath+0x12/0x76
This patch fixes the bug by removing @css parameter from the three
migration methods, ->can_attach, ->cancel_attach() and ->attach() and
updating cgroup_taskset iteration helpers also return the destination
css in addition to the task being migrated. All controllers are
updated accordingly.
* Controllers which don't care whether there are one or multiple
target csses can be converted trivially. cpu, io, freezer, perf,
netclassid and netprio fall in this category.
* cpuset's current implementation assumes that there's single source
and destination and thus doesn't support v2 hierarchy already. The
only change made by this patchset is how that single destination css
is obtained.
* memory migration path already doesn't do anything on v2. How the
single destination css is obtained is updated and the prep stage of
mem_cgroup_can_attach() is reordered to accomodate the change.
* pids is the only controller which was affected by this bug. It now
correctly handles multi-destination migrations and no longer causes
counter underflow from incorrect accounting.
Reported-and-tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Cc: Aleksa Sarai <cyphar@cyphar.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"The cgroup core saw several significant updates this cycle:
- percpu_rwsem for threadgroup locking is reinstated. This was
temporarily dropped due to down_write latency issues. Oleg's
rework of percpu_rwsem which is scheduled to be merged in this
merge window resolves the issue.
- On the v2 hierarchy, when controllers are enabled and disabled, all
operations are atomic and can fail and revert cleanly. This allows
->can_attach() failure which is necessary for cpu RT slices.
- Tasks now stay associated with the original cgroups after exit
until released. This allows tracking resources held by zombies
(e.g. pids) and makes it easy to find out where zombies came from
on the v2 hierarchy. The pids controller was broken before these
changes as zombies escaped the limits; unfortunately, updating this
behavior required too many invasive changes and I don't think it's
a good idea to backport them, so the pids controller on 4.3, the
first version which included the pids controller, will stay broken
at least until I'm sure about the cgroup core changes.
- Optimization of a couple common tests using static_key"
* 'for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (38 commits)
cgroup: fix race condition around termination check in css_task_iter_next()
blkcg: don't create "io.stat" on the root cgroup
cgroup: drop cgroup__DEVEL__legacy_files_on_dfl
cgroup: replace error handling in cgroup_init() with WARN_ON()s
cgroup: add cgroup_subsys->free() method and use it to fix pids controller
cgroup: keep zombies associated with their original cgroups
cgroup: make css_set_rwsem a spinlock and rename it to css_set_lock
cgroup: don't hold css_set_rwsem across css task iteration
cgroup: reorganize css_task_iter functions
cgroup: factor out css_set_move_task()
cgroup: keep css_set and task lists in chronological order
cgroup: make cgroup_destroy_locked() test cgroup_is_populated()
cgroup: make css_sets pin the associated cgroups
cgroup: relocate cgroup_[try]get/put()
cgroup: move check_for_release() invocation
cgroup: replace cgroup_has_tasks() with cgroup_is_populated()
cgroup: make cgroup->nr_populated count the number of populated css_sets
cgroup: remove an unused parameter from cgroup_task_migrate()
cgroup: fix too early usage of static_branch_disable()
cgroup: make cgroup_update_dfl_csses() migrate all target processes atomically
The stat files on the root cgroup shows stats for the whole system and
usually don't contain any information which isn't available through
the usual system monitoring mechanisms. Some controllers skip
collecting these duplicate stats to optimize cases where cgroup isn't
used and later try to emulate the result on demand.
This leads to complexities and subtle differences in the information
shown through different channels. This is entirely unnecessary and
cgroup v2 is dropping stat files which are duplicate from all
controllers. This patch removes "io.stat" from the root hierarchy.
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: Vivek Goyal <vgoyal@redhat.com>
Pull block updates from Jens Axboe:
"This is a bit bigger than it should be, but I could (did) not want to
send it off last week due to both wanting extra testing, and expecting
a fix for the bounce regression as well. In any case, this contains:
- Fix for the blk-merge.c compilation warning on gcc 5.x from me.
- A set of back/front SG gap merge fixes, from me and from Sagi.
This ensures that we honor SG gapping for integrity payloads as
well.
- Two small fixes for null_blk from Matias, fixing a leak and a
capacity propagation issue.
- A blkcg fix from Tejun, fixing a NULL dereference.
- A fast clone optimization from Ming, fixing a performance
regression since the arbitrarily sized bio's were introduced.
- Also from Ming, a regression fix for bouncing IOs"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: fix bounce_end_io
block: blk-merge: fast-clone bio when splitting rw bios
block: blkg_destroy_all() should clear q->root_blkg and ->root_rl.blkg
block: Copy a user iovec if it includes gaps
block: Refuse adding appending a gapped integrity page to a bio
block: Refuse request/bio merges with gaps in the integrity payload
block: Check for gaps on front and back merges
null_blk: fix wrong capacity when bs is not 512 bytes
null_blk: fix memory leak on cleanup
block: fix bogus compiler warnings in blk-merge.c
While making the root blkg unconditional, ec13b1d6f0a0 ("blkcg: always
create the blkcg_gq for the root blkcg") removed the part which clears
q->root_blkg and ->root_rl.blkg during q exit. This leaves the two
pointers dangling after blkg_destroy_all(). blk-throttle exit path
performs blkg traversals and dereferences ->root_blkg and can lead to
the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000558
IP: [<ffffffff81389746>] __blkg_lookup+0x26/0x70
task: ffff88001b4e2580 ti: ffff88001ac0c000 task.ti: ffff88001ac0c000
RIP: 0010:[<ffffffff81389746>] [<ffffffff81389746>] __blkg_lookup+0x26/0x70
Call Trace:
[<ffffffff8138d14a>] blk_throtl_drain+0x5a/0x110
[<ffffffff8138a108>] blkcg_drain_queue+0x18/0x20
[<ffffffff81369a70>] __blk_drain_queue+0xc0/0x170
[<ffffffff8136a101>] blk_queue_bypass_start+0x61/0x80
[<ffffffff81388c59>] blkcg_deactivate_policy+0x39/0x100
[<ffffffff8138d328>] blk_throtl_exit+0x38/0x50
[<ffffffff8138a14e>] blkcg_exit_queue+0x3e/0x50
[<ffffffff8137016e>] blk_release_queue+0x1e/0xc0
While the bug is a straigh-forward use-after-free bug, it is tricky to
reproduce because blkg release is RCU protected and the rest of exit
path usually finishes before RCU grace period.
This patch fixes the bug by updating blkg_destro_all() to clear
q->root_blkg and ->root_rl.blkg.
Reported-by: "Richard W.M. Jones" <rjones@redhat.com>
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Link: http://lkml.kernel.org/g/CA+5PVA5rzQ0s4723n5rHBcxQa9t0cW8BPPBekr_9aMRoWt2aYg@mail.gmail.com
Fixes: ec13b1d6f0a0 ("blkcg: always create the blkcg_gq for the root blkcg")
Cc: stable@vger.kernel.org # v4.2+
Tested-by: Richard W.M. Jones <rjones@redhat.com>
cgroup is trying to make interface consistent across different
controllers. For weight based resource control, the knob should have
the range [1, 10000] and default to 100. This patch updates
cfq-iosched so that the weight range conforms. The internal
calculations have enough range and the widening of the weight range
shouldn't cause any problem.
* blkcg_policy->cpd_bind_fn() is added. If present, this is invoked
when blkcg is attached to a hierarchy.
* cfq_cpd_init() is updated to use the new default value on the
unified hierarchy.
* cfq_cpd_bind() callback is implemented to clear per-blkg configs and
apply the default config matching the hierarchy type.
* cfqd->root_group->[leaf_]weight initialization in cfq_init_queue()
is moved into !CONFIG_CFQ_GROUP_IOSCHED block. cfq_cpd_bind() is
now responsible for initializing the initial weights when blkcg is
enabled.
Cc: Arianna Avanzini <avanzini.arianna@gmail.com>
blkcg interface grew to be the biggest of all controllers and
unfortunately most inconsistent too. The interface files are
inconsistent with a number of cloes duplicates. Some files have
recursive variants while others don't. There's distinction between
normal and leaf weights which isn't intuitive and there are a lot of
stat knobs which don't make much sense outside of debugging and expose
too much implementation details to userland.
In the unified hierarchy, everything is always hierarchical and
internal nodes can't have tasks rendering the two structural issues
twisting the current interface. The interface has to be updated in a
significant anyway and this is a good chance to revamp it as a whole.
This patch implements blkcg interface for the unified hierarchy.
* (from a previous patch) blkcg is identified by "io" instead of
"blkio" on the unified hierarchy. Given that the whole interface is
updated anyway, the rename shouldn't carry noticeable conversion
overhead.
* The original interface consisted of 27 files is replaced with the
following three files.
blkio.stat : per-blkcg stats
blkio.weight : per-cgroup and per-cgroup-queue weight settings
blkio.max : per-cgroup-queue bps and iops max limits
Documentation/cgroups/unified-hierarchy.txt updated accordingly.
v2: blkcg_policy->dfl_cftypes wasn't removed on
blkcg_policy_unregister() corrupting the cftypes list. Fixed.
* Export blkg_dev_name()
* Drop unnecessary @cft from __cfq_set_weight().
Currently, blkg_conf_prep() expects input to be of the following form
MAJ:MIN NUM
and reads the NUM part into blkg_conf_ctx->v. This is quite
restrictive and gets in the way in implementing blkcg interface for
the unified hierarchy. This patch updates blkg_conf_prep() so that it
expects
MAJ:MIN BODY_STR
where BODY_STR is an arbitrary string. blkg_conf_ctx->v is replaced
with ->body which is a char pointer pointing to the start of BODY_STR.
Parsing of the body is moved to blkg_conf_prep()'s callers.
To allow using, for example, strsep() on blkg_conf_ctx->val, it is a
non-const pointer and to accommodate that const is dropped from @input
too.
This doesn't cause any behavior changes.
blkcg is about to grow interface for the unified hierarchy. Add
legacy to existing cftypes.
* blkcg_policy->cftypes -> blkcg_policy->legacy_cftypes
* blk-cgroup.c:blkcg_files -> blkcg_legacy_files
* cfq-iosched.c:cfq_blkcg_files -> cfq_blkcg_legacy_files
* blk-throttle.c:throtl_files -> throtl_legacy_files
Pure renames. No functional change.
blkio interface has become messy over time and is currently the
largest. In addition to the inconsistent naming scheme, it has
multiple stat files which report more or less the same thing, a number
of debug stat files which expose internal details which shouldn't have
been part of the public interface in the first place, recursive and
non-recursive stats and leaf and non-leaf knobs.
Both recursive vs. non-recursive and leaf vs. non-leaf distinctions
don't make any sense on the unified hierarchy as only leaf cgroups can
contain processes. cgroups is going through a major interface
revision with the unified hierarchy involving significant fundamental
usage changes and given that a significant portion of the interface
doesn't make sense anymore, it's a good time to reorganize the
interface.
As the first step, this patch renames the external visible subsystem
name from "blkio" to "io". This is more concise, matches the other
two major subsystem names, "cpu" and "memory", and better suited as
blkcg will be involved in anything writeback related too whether an
actual block device is involved or not.
As the subsystem legacy_name is set to "blkio", the only userland
visible change outside the unified hierarchy is that blkcg is reported
as "io" instead of "blkio" in the subsystem initialized message during
boot. On the unified hierarchy, blkcg now appears as "io".
Cc: Li Zefan <lizefan@huawei.com>
Cc: cgroups@vger.kernel.org
blkcg currently returns -EINVAL for most errors which can be pretty
confusing given that the failure modes are quite varied. Update the
error returns so that
* -EINVAL only for syntactic errors.
* -ERANGE if the value is out of range.
* -ENODEV if the target device can't be found.
* -EOPNOTSUPP if the policy is not enabled on the target device.
The recent percpu conversion of blkg_rwstat triggered the following
warning in certain configurations.
block/blk-cgroup.c:654:1: warning: the frame size of 1360 bytes is larger than 1024 bytes
This is because blkg_rwstat now contains four percpu_counter which can
be pretty big depending on debug options although it shouldn't be a
problem in production configs. This patch removes one of the two
local blkg_rwstat variables used by blkg_rwstat_recursive_sum() to
reduce stack usage.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Link: http://article.gmane.org/gmane.linux.kernel.cgroups/13835
Currently, both cfq-iosched and blk-throttle keep track of
io_service_bytes and io_serviced stats. While keeping track of them
separately may be useful during development, it doesn't make much
sense otherwise. Also, blk-throttle was counting bio's as IOs while
cfq-iosched request's, which is more confusing than informative.
This patch adds ->stat_bytes and ->stat_ios to blkg (blkcg_gq),
removes the counterparts from cfq-iosched and blk-throttle and let
them print from the common blkg counters. The common counters are
incremented during bio issue in blkcg_bio_issue_check().
The outputs are still filtered by whether the policy has
blkg_policy_data on a given blkg, so cfq's output won't show up if it
has never been used for a given blkg. The only times when the outputs
would differ significantly are when policies are attached on the fly
or elevators are switched back and forth. Those are quite exceptional
operations and I don't think they warrant keeping separate counters.
v3: Update blkio-controller.txt accordingly.
v2: Account IOs during bio issues instead of request completions so
that bio-based drivers can be handled the same way.
Currently, blkg_[rw]stat_recursive_sum() assume that the target
counter is located in pd (blkg_policy_data); however, some counters
are planned to be moved to blkg (blkcg_gq).
This patch updates blkg_[rw]stat_recursive_sum() to take blkg and
blkg_policy pointers instead of pd. If policy is NULL, it indexes
into blkg. If non-NULL, into the blkg's pd of the policy.
The existing usages are updated to maintain the current behaviors.
blkcg_[rw]stat are used as stat counters for blkcg policies. It isn't
per-cpu by itself and blk-throttle makes it per-cpu by wrapping around
it. This patch makes blkcg_[rw]stat per-cpu and drop the ad-hoc
per-cpu wrapping in blk-throttle.
* blkg_[rw]stat->cnt is replaced with cpu_cnt which is struct
percpu_counter. This makes syncp unnecessary as remote accesses are
handled by percpu_counter itself.
* blkg_[rw]stat_init() can now fail due to percpu allocation failure
and thus are updated to return int.
* percpu_counters need explicit freeing. blkg_[rw]stat_exit() added.
* As blkg_rwstat->cpu_cnt[] can't be read directly anymore, reading
and summing results are stored in ->aux_cnt[] instead.
* Custom per-cpu stat implementation in blk-throttle is removed.
This makes all blkcg stat counters per-cpu without complicating policy
implmentations.
cgroup stats are local to each cgroup and doesn't propagate to
ancestors by default. When recursive stats are necessary, the sum is
calculated over all the descendants. This initially was for backward
compatibility to support both group-local and recursive stats but this
mode of operation makes general sense as stat update is much hotter
thafn reporting those stats.
This however ends up losing recursive stats when a child is removed.
To work around this, cfq-iosched adds its stats to its parent
cfq_group->dead_stats which is summed up together when calculating
recursive stats.
It's planned that the core stats will be moved to blkcg_gq, so we want
to move the mechanism for keeping track of the stats of dead children
from cfq to blkcg core. This patch adds blkg_[rw]stat->aux_cnt which
are atomic64_t's keeping track of auxiliary counts which are excluded
when reading local counts but included for recursive.
blkg_[rw]stat_merge() which were used by cfq to implement dead_stats
are replaced by blkg_[rw]stat_add_aux(), and cfq now forwards stats of
a dead cgroup to the aux counts of parent->stats instead of separate
->dead_stats.
This will also help making blkg_[rw]stats per-cpu.
blkg (blkcg_gq) currently is created by blkcg policies invoking
blkg_lookup_create() which ends up repeating about the same code in
different policies. Theoretically, this can avoid the overhead of
looking and/or creating blkg's if blkcg is enabled but no policy is in
use; however, the cost of blkg lookup / creation is very low
especially if only the root blkcg is in use which is highly likely if
no blkcg policy is in active use - it boils down to a single very
predictable conditional and surrounding RCU protection.
This patch consolidates blkg creation to a new function
blkcg_bio_issue_check() which is called during bio issue from
generic_make_request_checks(). blkcg_bio_issue_check() is now the
only function which tries to create missing blkg's. The subsequent
policy and request_list operations just perform blkg_lookup() and if
missing falls back to the root.
* blk_get_rl() no longer tries to create blkg. It uses blkg_lookup()
instead of blkg_lookup_create().
* blk_throtl_bio() is now called from blkcg_bio_issue_check() with rcu
read locked and blkg already looked up. Both throtl_lookup_tg() and
throtl_lookup_create_tg() are dropped.
* cfq is similarly updated. cfq_lookup_create_cfqg() is replaced with
cfq_lookup_cfqg()which uses blkg_lookup().
This consolidates blkg handling and avoids unnecessary blkg creation
retries under memory pressure. In addition, this provides a common
bio entry point into blkcg where things like common accounting can be
performed.
v2: Build fixes for !CONFIG_CFQ_GROUP_IOSCHED and
!CONFIG_BLK_DEV_THROTTLING.
blkg_lookup() checks whether the target queue is bypassing and, if
not, calls __blkg_lookup() which first checks the lookup hint and then
performs radix tree walk. The operations upto hint checking are
trivial and there are many users of this function. This patch inlines
blkg_lookup() and the fast path part of __blkg_lookup(). The radix
tree lookup and hint update are now in blkg_lookup_slowpath().
This will help consolidating blkg handling by easing moving root blkcg
short-circuit to inlined lookup fast path.
Each active policy has a cpd (blkcg_policy_data) on each blkcg. The
cpd's were allocated by blkcg core and each policy could request to
allocate extra space at the end by setting blkcg_policy->cpd_size
larger than the size of cpd.
This is a bit unusual but blkg (blkcg_gq) policy data used to be
handled this way too so it made sense to be consistent; however, blkg
policy data switched to alloc/free callbacks.
This patch makes similar changes to cpd handling.
blkcg_policy->cpd_alloc/free_fn() are added to replace ->cpd_size. As
cpd allocation is now done from policy side, it can simply allocate a
larger area which embeds cpd at the beginning.
As ->cpd_alloc_fn() may be able to perform all necessary
initializations, this patch makes ->cpd_init_fn() optional.
* Rename blkcg->pd[] to blkcg->cpd[] so that cpd is consistently used
for blkcg_policy_data.
* Make blkcg_policy->cpd_init_fn() take blkcg_policy_data instead of
blkcg. This makes it consistent with blkg_policy_data methods and
to-be-added cpd alloc/free methods.
* blkcg_policy_data->blkcg and cpd_to_blkcg() added so that
cpd_init_fn() can determine the associated blkcg from
blkcg_policy_data.
v2: blkcg_policy_data->blkcg initializations were missing. Added.
The newly added ->pd_alloc_fn() and ->pd_free_fn() deal with pd
(blkg_policy_data) while the older ones use blkg (blkcg_gq). As using
blkg doesn't make sense for ->pd_alloc_fn() and after allocation pd
can always be mapped to blkg and given that these are policy-specific
methods, it makes sense to converge on pd.
This patch makes all methods deal with pd instead of blkg. Most
conversions are trivial. In blk-cgroup.c, a couple method invocation
sites now test whether pd exists instead of policy state for
consistency. This shouldn't cause any behavioral differences.
With the recent addition of alloc and free methods, things became
messier. This patch reorganizes them according to the followings.
* ->pd_alloc_fn()
Responsible for allocation and static initializations - the ones
which can be done independent of where the pd might be attached.
* ->pd_init_fn()
Initializations which require the knowledge of where the pd is
attached.
* ->pd_free_fn()
The counter part of pd_alloc_fn(). Static de-init and freeing.
This leaves ->pd_exit_fn() without any users. Removed.
While at it, collapse an one liner function throtl_pd_exit(), which
has only one user, into its user.
A blkg (blkcg_gq) represents the relationship between a cgroup and
request_queue. Each active policy has a pd (blkg_policy_data) on each
blkg. The pd's were allocated by blkcg core and each policy could
request to allocate extra space at the end by setting
blkcg_policy->pd_size larger than the size of pd.
This is a bit unusual but was done this way mostly to simplify error
handling and all the existing use cases could be handled this way;
however, this is becoming too restrictive now that percpu memory can
be allocated without blocking.
This introduces two new mandatory blkcg_policy methods - pd_alloc_fn()
and pd_free_fn() - which are used to allocate and release pd for a
given policy. As pd allocation is now done from policy side, it can
simply allocate a larger area which embeds pd at the beginning. This
change makes ->pd_size pointless. Removed.
blkg_create() allows NULL ->pd_init_fn() but blkcg_activate_policy()
doesn't. As both in-kernel policies implement ->pd_init_fn, it
currently doesn't break anything. Update blkcg_activate_policy() so
that its behavior is consistent with blkg_create().
When a policy gets activated, it needs to allocate and install its
policy data on all existing blkg's (blkcg_gq's). Because blkg
iteration is protected by a spinlock, it currently counts the total
number of blkg's in the system, allocates the matching number of
policy data on a list and installs them during a single iteration.
This can be simplified by using speculative GFP_NOWAIT allocations
while iterating and falling back to a preallocated policy data on
failure. If the preallocated one has already been consumed, it
releases the lock, preallocate with GFP_KERNEL and then restarts the
iteration. This can be a bit more expensive than before but policy
activation is a very cold path and shouldn't matter.
blkcg_css_alloc() bypasses policy data allocation and blkcg_css_free()
bypasses policy data and blkcg freeing for blkcg_root. There's no
reason to to treat policy data any differently for blkcg_root. If the
root css gets allocated after policies are registered, policy
registration path will add policy data; otherwise, the alloc path
will. The free path isn't never invoked for root csses.
This patch removes the unnecessary special handling of blkcg_root from
css_alloc/free paths.
When blkcg_init_queue() fails midway after creating a new blkg, it
performs kfree() directly; however, this doesn't free the policy data
areas. Make it use blkg_free() instead. In turn, blkg_free() is
updated to handle root request_list special case.
While this fixes a possible memory leak, it's on an unlikely failure
path of an already cold path and the size leaked per occurrence is
miniscule too. I don't think it needs to be tagged for -stable.
allocations
blkcg performs several allocations to track IOs per cgroup and enforce
resource control. Most of these allocations are performed lazily on
demand in the IO path and thus can't involve reclaim path. Currently,
these allocations use GFP_ATOMIC; however, blkcg can gracefully deal
with occassional failures of these allocations by punting IOs to the
root cgroup and there's no reason to reach into the emergency reserve.
This patch replaces GFP_ATOMIC with GFP_NOWAIT for the following
allocations.
* bdi_writeback_congested and blkcg_gq allocations in blkg_create().
* radix tree node allocations for blkcg->blkg_tree.
* cfq_queue allocation on ioprio changes.
Suggested-and-Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Suggested-by: Vivek Goyal <vgoyal@redhat.com>
When a blkcg configuration is targeted to a partition rather than a
whole device, blkg_conf_prep fails with -EINVAL; unfortunately, it
forgets to put the gendisk ref in that case. Fix it.
e48453c386f3 ("block, cgroup: implement policy-specific per-blkcg
data") updated per-blkcg policy data to be dynamically allocated.
When a policy is registered, its policy data aren't created. Instead,
when the policy is activated on a queue, the policy data are allocated
if there are blkg's (blkcg_gq's) which are attached to a given blkcg.
This is buggy. Consider the following scenario.
1. A blkcg is created. No blkg's attached yet.
2. The policy is registered. No policy data is allocated.
3. The policy is activated on a queue. As the above blkcg doesn't
have any blkg's, it won't allocate the matching blkcg_policy_data.
4. An IO is issued from the blkcg and blkg is created and the blkcg
still doesn't have the matching policy data allocated.
With cfq-iosched, this leads to an oops.
It also doesn't free policy data on policy unregistration assuming
that freeing of all policy data on blkcg destruction should take care
of it; however, this also is incorrect.
1. A blkcg has policy data.
2. The policy gets unregistered but the policy data remains.
3. Another policy gets registered on the same slot.
4. Later, the new policy tries to allocate policy data on the previous
blkcg but the slot is already occupied and gets skipped. The
policy ends up operating on the policy data of the previous policy.
There's no reason to manage blkcg_policy_data lazily. The reason we
do lazy allocation of blkg's is that the number of all possible blkg's
is the product of cgroups and block devices which can reach a
surprising level. blkcg_policy_data is contrained by the number of
cgroups and shouldn't be a problem.
This patch makes blkcg_policy_data to be allocated for all existing
blkcg's on policy registration and freed on unregistration and removes
blkcg_policy_data handling from policy [de]activation paths. This
makes that blkcg_policy_data are created and removed with the policy
they belong to and fixes the above described problems.
Fixes: e48453c386f3 ("block, cgroup: implement policy-specific per-blkcg data")
Add all_blkcgs list goes through blkcg->all_blkcgs_node and is
protected by blkcg_pol_mutex. This will be used to fix
blkcg_policy_data allocation bug.
blkcg_policy[]
An entry in blkcg_policy[] is stable while there are non-bypassing
in-flight IOs on a request_queue which has the policy activated. This
is why most derefs of blkcg_policy[] don't need explicit locking;
however, blkcg_css_alloc() isn't invoked from IO path and thus doesn't
have this protection and may race policies being added and removed.
Fix it by adding explicit blkcg_pol_mutex protection around
blkcg_policy[] iteration in blkcg_css_alloc().
