use FIELD_SIZEOF instead of open coding
Signed-off-by: Maninder Singh <maninder1.s@samsung.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
"Apologies for not pressing this request-based DM partial completion
issue further, it was an oversight on my part. We'll have to get it
fixed up properly and revisit for a future release.
- Revert block and DM core changes the removed request-based DM's
ability to handle partial request completions -- otherwise with the
current SCSI LLDs these changes could lead to silent data
corruption.
- Fix two DM version bumps that were missing from the initial 4.2 DM
pull request (enabled userspace lvm2 to know certain changes have
been made)"
* tag 'dm-4.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm cache policy smq: fix "default" version to be 1.4.0
dm: bump the ioctl version to 4.32.0
Revert "block, dm: don't copy bios for request clones"
Revert "dm: do not allocate any mempools for blk-mq request-based DM"
This reverts commit 5f1b670d0bef508a5554d92525f5f6d00d640b38.
Justification for revert as reported in this dm-devel post:
https://www.redhat.com/archives/dm-devel/2015-June/msg00160.html
this change should not be pushed to mainline yet.
Firstly, Christoph has a newer version of the patch that fixes silent
data corruption problem:
https://www.redhat.com/archives/dm-devel/2015-May/msg00229.html
And the new version still depends on LLDDs to always complete requests
to the end when error happens, while block API doesn't enforce such a
requirement. If the assumption is ever broken, the inconsistency between
request and bio (e.g. rq->__sector and rq->bio) will cause silent data
corruption:
https://www.redhat.com/archives/dm-devel/2015-June/msg00022.html
Reported-by: Junichi Nomura <j-nomura@ce.jp.nec.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Pull cgroup writeback support from Jens Axboe:
"This is the big pull request for adding cgroup writeback support.
This code has been in development for a long time, and it has been
simmering in for-next for a good chunk of this cycle too. This is one
of those problems that has been talked about for at least half a
decade, finally there's a solution and code to go with it.
Also see last weeks writeup on LWN:
http://lwn.net/Articles/648292/"
* 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits)
writeback, blkio: add documentation for cgroup writeback support
vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB
writeback: do foreign inode detection iff cgroup writeback is enabled
v9fs: fix error handling in v9fs_session_init()
bdi: fix wrong error return value in cgwb_create()
buffer: remove unusued 'ret' variable
writeback: disassociate inodes from dying bdi_writebacks
writeback: implement foreign cgroup inode bdi_writeback switching
writeback: add lockdep annotation to inode_to_wb()
writeback: use unlocked_inode_to_wb transaction in inode_congested()
writeback: implement unlocked_inode_to_wb transaction and use it for stat updates
writeback: implement [locked_]inode_to_wb_and_lock_list()
writeback: implement foreign cgroup inode detection
writeback: make writeback_control track the inode being written back
writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb()
mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use
writeback: implement memcg writeback domain based throttling
writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes
writeback: implement memcg wb_domain
writeback: update wb_over_bg_thresh() to use wb_domain aware operations
Pull core block IO update from Jens Axboe:
"Nothing really major in here, mostly a collection of smaller
optimizations and cleanups, mixed with various fixes. In more detail,
this contains:
- Addition of policy specific data to blkcg for block cgroups. From
Arianna Avanzini.
- Various cleanups around command types from Christoph.
- Cleanup of the suspend block I/O path from Christoph.
- Plugging updates from Shaohua and Jeff Moyer, for blk-mq.
- Eliminating atomic inc/dec of both remaining IO count and reference
count in a bio. From me.
- Fixes for SG gap and chunk size support for data-less (discards)
IO, so we can merge these better. From me.
- Small restructuring of blk-mq shared tag support, freeing drivers
from iterating hardware queues. From Keith Busch.
- A few cfq-iosched tweaks, from Tahsin Erdogan and me. Makes the
IOPS mode the default for non-rotational storage"
* 'for-4.2/core' of git://git.kernel.dk/linux-block: (35 commits)
cfq-iosched: fix other locations where blkcg_to_cfqgd() can return NULL
cfq-iosched: fix sysfs oops when attempting to read unconfigured weights
cfq-iosched: move group scheduling functions under ifdef
cfq-iosched: fix the setting of IOPS mode on SSDs
blktrace: Add blktrace.c to BLOCK LAYER in MAINTAINERS file
block, cgroup: implement policy-specific per-blkcg data
block: Make CFQ default to IOPS mode on SSDs
block: add blk_set_queue_dying() to blkdev.h
blk-mq: Shared tag enhancements
block: don't honor chunk sizes for data-less IO
block: only honor SG gap prevention for merges that contain data
block: fix returnvar.cocci warnings
block: remove management of bi_remaining when restoring original bi_end_io
block: replace trylock with mutex_lock in blkdev_reread_part()
block: export blkdev_reread_part() and __blkdev_reread_part()
suspend: simplify block I/O handling
block: collapse bio bit space
block: remove unused BIO_RW_BLOCK and BIO_EOF flags
block: remove BIO_EOPNOTSUPP
Now that bdi layer can handle per-blkcg bdi_writeback_congested state,
blk_{set|clear}_congested() can propagate non-root blkcg congestion
state to them.
This can be easily achieved by disabling the root_rl tests in
blk_{set|clear}_congested(). Note that we still need those tests when
!CONFIG_CGROUP_WRITEBACK as otherwise we'll end up flipping root blkcg
wb's congestion state for events happening on other blkcgs.
v2: Updated for bdi_writeback_congested.
Cc: Jan Kara <jack@suse.cz>
Cc: Vivek Goyal <vgoyal@redhat.com>
blk_{set|clear}_queue_congested() take @q and set or clear,
respectively, the congestion state of its bdi's root wb. Because bdi
used to be able to handle congestion state only on the root wb, the
callers of those functions tested whether the congestion is on the
root blkcg and skipped if not.
This is cumbersome and makes implementation of per cgroup
bdi_writeback congestion state propagation difficult. This patch
renames blk_{set|clear}_queue_congested() to
blk_{set|clear}_congested(), and makes them take request_list instead
of request_queue and test whether the specified request_list is the
root one before updating bdi_writeback congestion state. This makes
the tests in the callers unnecessary and simplifies them.
As there are no external users of these functions, the definitions are
moved from include/linux/blkdev.h to block/blk-core.c.
This patch doesn't introduce any noticeable behavior difference.
cgroup writeback requires support from both bdi and filesystem sides.
Add BDI_CAP_CGROUP_WRITEBACK and FS_CGROUP_WRITEBACK to indicate
support and enable BDI_CAP_CGROUP_WRITEBACK on block based bdi's by
default. Also, define CONFIG_CGROUP_WRITEBACK which is enabled if
both MEMCG and BLK_CGROUP are enabled.
inode_cgwb_enabled() which determines whether a given inode's both bdi
and fs support cgroup writeback is added.
Currently, a bdi (backing_dev_info) embeds single wb (bdi_writeback)
and the role of the separation is unclear. For cgroup support for
writeback IOs, a bdi will be updated to host multiple wb's where each
wb serves writeback IOs of a different cgroup on the bdi. To achieve
that, a wb should carry all states necessary for servicing writeback
IOs for a cgroup independently.
This patch moves bdi->state into wb.
* enum bdi_state is renamed to wb_state and the prefix of all enums is
changed from BDI_ to WB_.
* Explicit zeroing of bdi->state is removed without adding zeoring of
wb->state as the whole data structure is zeroed on init anyway.
* As there's still only one bdi_writeback per backing_dev_info, all
uses of bdi->state are mechanically replaced with bdi->wb.state
introducing no behavior changes.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: drbd-dev@lists.linbit.com
Cc: Neil Brown <neilb@suse.de>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
cgroup aware writeback support will require exposing some of blkcg
details. In preprataion, move block/blk-cgroup.h to
include/linux/blk-cgroup.h. This patch is pure file move.
Currently dm-multipath has to clone the bios for every request sent
to the lower devices, which wastes cpu cycles and ties down memory.
This patch instead adds a new REQ_CLONE flag that instructs req_bio_endio
to not complete bios attached to a request, which we set on clone
requests similar to bios in a flush sequence. With this change I/O
errors on a path failure only get propagated to dm-multipath, which
can then either resubmit the I/O or complete the bios on the original
request.
I've done some basic testing of this on a Linux target with ALUA support,
and it survives path failures during I/O nicely.
Acked-by: Tejun Heo <tj@kernel.org>
With commit ff36ab345 ("dm: remove request-based logic from
make_request_fn wrapper") DM no longer calls blk_queue_bio() directly,
so remove its export. Doing so required a forward declaration in
blk-core.c.
Last patch makes plug work for multiple queue case. However it only
works for single disk case, because it assumes only one request in the
plug list. If a task is accessing multiple disks, eg MD/DM, the
assumption is wrong. Let blk_attempt_plug_merge() record request from
the same queue.
V2: use NULL parameter in !mq case. Fix a bug. Add comments in
blk_attempt_plug_merge to make it less (hopefully) confusion.
Cc: Jens Axboe <axboe@fb.com>
Signed-off-by: Shaohua Li <shli@fb.com>
Current code looks like inner plug gets flushed with a
blk_finish_plug(). Actually it's a nop. All requests/callbacks are added
to current->plug, while only outmost plug is assigned to current->plug.
So inner plug always has empty request/callback list, which makes
blk_flush_plug_list() a nop. This tries to make the code more clear.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
This removes the request types and hacks from the block code and into the
old IDE driver. There is a small amunt of code duplication due to this,
but it's not too bad.
Because of the peculiar way that md devices are created (automatically
when the device node is opened), a new device can be created and
registered immediately after the
blk_unregister_region(disk_devt(disk), disk->minors);
call in del_gendisk().
Therefore it is important that all visible artifacts of the previous
device are removed before this call. In particular, the 'bdi'.
Since:
commit c4db59d31e39ea067c32163ac961e9c80198fd37
Author: Christoph Hellwig <hch@lst.de>
fs: don't reassign dirty inodes to default_backing_dev_info
moved the
device_unregister(bdi->dev);
call from bdi_unregister() to bdi_destroy() it has been quite easy to
lose a race and have a new (e.g.) "md127" be created after the
blk_unregister_region() call and before bdi_destroy() is ultimately
called by the final 'put_disk', which must come after del_gendisk().
The new device finds that the bdi name is already registered in sysfs
and complains
> [ 9627.630029] WARNING: CPU: 18 PID: 3330 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x5a/0x70()
> [ 9627.630032] sysfs: cannot create duplicate filename '/devices/virtual/bdi/9:127'
We can fix this by moving the bdi_destroy() call out of
blk_release_queue() (which can happen very late when a refcount
reaches zero) and into blk_cleanup_queue() - which happens exactly when the md
device driver calls it.
Then it is only necessary for md to call blk_cleanup_queue() before
del_gendisk(). As loop.c devices are also created on demand by
opening the device node, we make the same change there.
Fixes: c4db59d31e39ea067c32163ac961e9c80198fd37
Reported-by: Azat Khuzhin <a3at.mail@gmail.com>
Cc: stable@vger.kernel.org (v4.0)
Signed-off-by: NeilBrown <neilb@suse.de>
blk_init_rl() allocates a mempool using mempool_create_node() with node
local memory. This only allocates the mempool and element list locally
to the requeue queue node.
What we really want to do is allocate the request itself local to the
queue. To do this, we need our own alloc and free functions that will
allocate from request_cachep and pass the request queue node in to prefer
node local memory.
Signed-off-by: David Rientjes <rientjes@google.com>
Pull core block IO changes from Jens Axboe:
"This contains:
- A series from Christoph that cleans up and refactors various parts
of the REQ_BLOCK_PC handling. Contributions in that series from
Dongsu Park and Kent Overstreet as well.
- CFQ:
- A bug fix for cfq for realtime IO scheduling from Jeff Moyer.
- A stable patch fixing a potential crash in CFQ in OOM
situations. From Konstantin Khlebnikov.
- blk-mq:
- Add support for tag allocation policies, from Shaohua. This is
a prep patch enabling libata (and other SCSI parts) to use the
blk-mq tagging, instead of rolling their own.
- Various little tweaks from Keith and Mike, in preparation for
DM blk-mq support.
- Minor little fixes or tweaks from me.
- A double free error fix from Tony Battersby.
- The partition 4k issue fixes from Matthew and Boaz.
- Add support for zero+unprovision for blkdev_issue_zeroout() from
Martin"
* 'for-3.20/core' of git://git.kernel.dk/linux-block: (27 commits)
block: remove unused function blk_bio_map_sg
block: handle the null_mapped flag correctly in blk_rq_map_user_iov
blk-mq: fix double-free in error path
block: prevent request-to-request merging with gaps if not allowed
blk-mq: make blk_mq_run_queues() static
dm: fix multipath regression due to initializing wrong request
cfq-iosched: handle failure of cfq group allocation
block: Quiesce zeroout wrapper
block: rewrite and split __bio_copy_iov()
block: merge __bio_map_user_iov into bio_map_user_iov
block: merge __bio_map_kern into bio_map_kern
block: pass iov_iter to the BLOCK_PC mapping functions
block: add a helper to free bio bounce buffer pages
block: use blk_rq_map_user_iov to implement blk_rq_map_user
block: simplify bio_map_kern
block: mark blk-mq devices as stackable
block: keep established cmd_flags when cloning into a blk-mq request
block: add blk-mq support to blk_insert_cloned_request()
block: require blk_rq_prep_clone() be given an initialized clone request
blk-mq: add tag allocation policy
blk_mq_alloc_request() may establish REQ_MQ_INFLIGHT in addition to
incrementing the hctx->nr_active count. Any cmd_flags that are
established in the newly allocated clone request must be preserved in
addition to the cmd_flags that are later copied over from the original
request as part of blk_rq_prep_clone().
Otherwise, if REQ_MQ_INFLIGHT isn't set in the clone request the
hctx->nr_active count won't get decremented via blk_mq_free_request().
The only consumer of blk_rq_prep_clone() is request-based DM, which uses
blk_rq_init() prior to calling blk_rq_prep_clone() for the non-blk-mq
case. Given the cloned request's cmd_flags will be 0 it is safe to OR
them with the original request's cmd_flags for both the non-blk-mq and
blk-mq cases.
Reported-by: Bart Van Assche <bvanassche@acm.org>
Signed-off-by: Keith Busch <keith.busch@intel.com>
If the request passed to blk_insert_cloned_request() was allocated by
a blk-mq device it must be submitted using blk_mq_insert_request().
Prepare to allow blk_rq_prep_clone() to accept clone requests that were
allocated from blk-mq request queues. As such the blk_rq_prep_clone()
caller must first initialize the clone request.
Since "BDI: Provide backing device capability information [try #3]" the
backing_dev_info structure also provides flags for the kind of mmap
operation available in a nommu environment, which is entirely unrelated
to it's original purpose.
Introduce a new nommu-only file operation to provide this information to
the nommu mmap code instead. Splitting this from the backing_dev_info
structure allows to remove lots of backing_dev_info instance that aren't
otherwise needed, and entirely gets rid of the concept of providing a
backing_dev_info for a character device. It also removes the need for
the mtd_inodefs filesystem.
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Brian Norris <computersforpeace@gmail.com>
If it's dying, we can't expect new request to complete and come
in an wake up other tasks waiting for requests. So after we
have marked it as dying, wake up everybody currently waiting
for a request. Once they wake, they will retry their allocation
and fail appropriately due to the state of the queue.
Tested-by: Keith Busch <keith.busch@intel.com>
Pull block driver core update from Jens Axboe:
"This is the pull request for the core block IO changes for 3.19. Not
a huge round this time, mostly lots of little good fixes:
- Fix a bug in sysfs blktrace interface causing a NULL pointer
dereference, when enabled/disabled through that API. From Arianna
Avanzini.
- Various updates/fixes/improvements for blk-mq:
- A set of updates from Bart, mostly fixing buts in the tag
handling.
- Cleanup/code consolidation from Christoph.
- Extend queue_rq API to be able to handle batching issues of IO
requests. NVMe will utilize this shortly. From me.
- A few tag and request handling updates from me.
- Cleanup of the preempt handling for running queues from Paolo.
- Prevent running of unmapped hardware queues from Ming Lei.
- Move the kdump memory limiting check to be in the correct
location, from Shaohua.
- Initialize all software queues at init time from Takashi. This
prevents a kobject warning when CPUs are brought online that
weren't online when a queue was registered.
- Single writeback fix for I_DIRTY clearing from Tejun. Queued with
the core IO changes, since it's just a single fix.
- Version X of the __bio_add_page() segment addition retry from
Maurizio. Hope the Xth time is the charm.
- Documentation fixup for IO scheduler merging from Jan.
- Introduce (and use) generic IO stat accounting helpers for non-rq
drivers, from Gu Zheng.
- Kill off artificial limiting of max sectors in a request from
Christoph"
* 'for-3.19/core' of git://git.kernel.dk/linux-block: (26 commits)
bio: modify __bio_add_page() to accept pages that don't start a new segment
blk-mq: Fix uninitialized kobject at CPU hotplugging
blktrace: don't let the sysfs interface remove trace from running list
blk-mq: Use all available hardware queues
blk-mq: Micro-optimize bt_get()
blk-mq: Fix a race between bt_clear_tag() and bt_get()
blk-mq: Avoid that __bt_get_word() wraps multiple times
blk-mq: Fix a use-after-free
blk-mq: prevent unmapped hw queue from being scheduled
blk-mq: re-check for available tags after running the hardware queue
blk-mq: fix hang in bt_get()
blk-mq: move the kdump check to blk_mq_alloc_tag_set
blk-mq: cleanup tag free handling
blk-mq: use 'nr_cpu_ids' as highest CPU ID count for hwq <-> cpu map
blk: introduce generic io stat accounting help function
blk-mq: handle the single queue case in blk_mq_hctx_next_cpu
genhd: check for int overflow in disk_expand_part_tbl()
blk-mq: add blk_mq_free_hctx_request()
blk-mq: export blk_mq_free_request()
blk-mq: use get_cpu/put_cpu instead of preempt_disable/preempt_enable
Pull ACPI and power management updates from Rafael Wysocki:
"This time we have some more new material than we used to have during
the last couple of development cycles.
The most important part of it to me is the introduction of a unified
interface for accessing device properties provided by platform
firmware. It works with Device Trees and ACPI in a uniform way and
drivers using it need not worry about where the properties come from
as long as the platform firmware (either DT or ACPI) makes them
available. It covers both devices and "bare" device node objects
without struct device representation as that turns out to be necessary
in some cases. This has been in the works for quite a few months (and
development cycles) and has been approved by all of the relevant
maintainers.
On top of that, some drivers are switched over to the new interface
(at25, leds-gpio, gpio_keys_polled) and some additional changes are
made to the core GPIO subsystem to allow device drivers to manipulate
GPIOs in the "canonical" way on platforms that provide GPIO
information in their ACPI tables, but don't assign names to GPIO lines
(in which case the driver needs to do that on the basis of what it
knows about the device in question). That also has been approved by
the GPIO core maintainers and the rfkill driver is now going to use
it.
Second is support for hardware P-states in the intel_pstate driver.
It uses CPUID to detect whether or not the feature is supported by the
processor in which case it will be enabled by default. However, it
can be disabled entirely from the kernel command line if necessary.
Next is support for a platform firmware interface based on ACPI
operation regions used by the PMIC (Power Management Integrated
Circuit) chips on the Intel Baytrail-T and Baytrail-T-CR platforms.
That interface is used for manipulating power resources and for
thermal management: sensor temperature reporting, trip point setting
and so on.
Also the ACPI core is now going to support the _DEP configuration
information in a limited way. Basically, _DEP it supposed to reflect
off-the-hierarchy dependencies between devices which may be very
indirect, like when AML for one device accesses locations in an
operation region handled by another device's driver (usually, the
device depended on this way is a serial bus or GPIO controller). The
support added this time is sufficient to make the ACPI battery driver
work on Asus T100A, but it is general enough to be able to cover some
other use cases in the future.
Finally, we have a new cpufreq driver for the Loongson1B processor.
In addition to the above, there are fixes and cleanups all over the
place as usual and a traditional ACPICA update to a recent upstream
release.
As far as the fixes go, the ACPI LPSS (Low-power Subsystem) driver for
Intel platforms should be able to handle power management of the DMA
engine correctly, the cpufreq-dt driver should interact with the
thermal subsystem in a better way and the ACPI backlight driver should
handle some more corner cases, among other things.
On top of the ACPICA update there are fixes for race conditions in the
ACPICA's interrupt handling code which might lead to some random and
strange looking failures on some systems.
In the cleanups department the most visible part is the series of
commits targeted at getting rid of the CONFIG_PM_RUNTIME configuration
option. That was triggered by a discussion regarding the generic
power domains code during which we realized that trying to support
certain combinations of PM config options was painful and not really
worth it, because nobody would use them in production anyway. For
this reason, we decided to make CONFIG_PM_SLEEP select
CONFIG_PM_RUNTIME and that lead to the conclusion that the latter
became redundant and CONFIG_PM could be used instead of it. The
material here makes that replacement in a major part of the tree, but
there will be at least one more batch of that in the second part of
the merge window.
Specifics:
- Support for retrieving device properties information from ACPI _DSD
device configuration objects and a unified device properties
interface for device drivers (and subsystems) on top of that. As
stated above, this works with Device Trees and ACPI and allows
device drivers to be written in a platform firmware (DT or ACPI)
agnostic way. The at25, leds-gpio and gpio_keys_polled drivers are
now going to use this new interface and the GPIO subsystem is
additionally modified to allow device drivers to assign names to
GPIO resources returned by ACPI _CRS objects (in case _DSD is not
present or does not provide the expected data). The changes in
this set are mostly from Mika Westerberg, Rafael J Wysocki, Aaron
Lu, and Darren Hart with some fixes from others (Fabio Estevam,
Geert Uytterhoeven).
- Support for Hardware Managed Performance States (HWP) as described
in Volume 3, section 14.4, of the Intel SDM in the intel_pstate
driver. CPUID is used to detect whether or not the feature is
supported by the processor. If supported, it will be enabled
automatically unless the intel_pstate=no_hwp switch is present in
the kernel command line. From Dirk Brandewie.
- New Intel Broadwell-H ID for intel_pstate (Dirk Brandewie).
- Support for firmware interface based on ACPI operation regions used
by the PMIC chips on the Intel Baytrail-T and Baytrail-T-CR
platforms for power resource control and thermal management (Aaron
Lu).
- Limited support for retrieving off-the-hierarchy dependencies
between devices from ACPI _DEP device configuration objects and
deferred probing support for the ACPI battery driver based on the
_DEP information to make that driver work on Asus T100A (Lan
Tianyu).
- New cpufreq driver for the Loongson1B processor (Kelvin Cheung).
- ACPICA update to upstream revision 20141107 which only affects
tools (Bob Moore).
- Fixes for race conditions in the ACPICA's interrupt handling code
and in the ACPI code related to system suspend and resume (Lv Zheng
and Rafael J Wysocki).
- ACPI core fix for an RCU-related issue in the ioremap() regions
management code that slowed down significantly after CPUs had been
allowed to enter idle states even if they'd had RCU callbakcs
queued and triggered some problems in certain proprietary graphics
driver (and elsewhere). The fix replaces synchronize_rcu() in that
code with synchronize_rcu_expedited() which makes the issue go
away. From Konstantin Khlebnikov.
- ACPI LPSS (Low-Power Subsystem) driver fix to handle power
management of the DMA engine included into the LPSS correctly. The
problem is that the DMA engine doesn't have ACPI PM support of its
own and it simply is turned off when the last LPSS device having
ACPI PM support goes into D3cold. To work around that, the PM
domain used by the ACPI LPSS driver is redesigned so at least one
device with ACPI PM support will be on as long as the DMA engine is
in use. From Andy Shevchenko.
- ACPI backlight driver fix to avoid using it on "Win8-compatible"
systems where it doesn't work and where it was used by default by
mistake (Aaron Lu).
- Assorted minor ACPI core fixes and cleanups from Tomasz Nowicki,
Sudeep Holla, Huang Rui, Hanjun Guo, Fabian Frederick, and Ashwin
Chaugule (mostly related to the upcoming ARM64 support).
- Intel RAPL (Running Average Power Limit) power capping driver fixes
and improvements including new processor IDs (Jacob Pan).
- Generic power domains modification to power up domains after
attaching devices to them to meet the expectations of device
drivers and bus types assuming devices to be accessible at probe
time (Ulf Hansson).
- Preliminary support for controlling device clocks from the generic
power domains core code and modifications of the ARM/shmobile
platform to use that feature (Ulf Hansson).
- Assorted minor fixes and cleanups of the generic power domains core
code (Ulf Hansson, Geert Uytterhoeven).
- Assorted minor fixes and cleanups of the device clocks control code
in the PM core (Geert Uytterhoeven, Grygorii Strashko).
- Consolidation of device power management Kconfig options by making
CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and removing the latter
which is now redundant (Rafael J Wysocki and Kevin Hilman). That
is the first batch of the changes needed for this purpose.
- Core device runtime power management support code cleanup related
to the execution of callbacks (Andrzej Hajda).
- cpuidle ARM support improvements (Lorenzo Pieralisi).
- cpuidle cleanup related to the CPUIDLE_FLAG_TIME_VALID flag and a
new MAINTAINERS entry for ARM Exynos cpuidle (Daniel Lezcano and
Bartlomiej Zolnierkiewicz).
- New cpufreq driver callback (->ready) to be executed when the
cpufreq core is ready to use a given policy object and cpufreq-dt
driver modification to use that callback for cooling device
registration (Viresh Kumar).
- cpufreq core fixes and cleanups (Viresh Kumar, Vince Hsu, James
Geboski, Tomeu Vizoso).
- Assorted fixes and cleanups in the cpufreq-pcc, intel_pstate,
cpufreq-dt, pxa2xx cpufreq drivers (Lenny Szubowicz, Ethan Zhao,
Stefan Wahren, Petr Cvek).
- OPP (Operating Performance Points) framework modification to allow
OPPs to be removed too and update of a few cpufreq drivers
(cpufreq-dt, exynos5440, imx6q, cpufreq) to remove OPPs (added
during initialization) on driver removal (Viresh Kumar).
- Hibernation core fixes and cleanups (Tina Ruchandani and Markus
Elfring).
- PM Kconfig fix related to CPU power management (Pankaj Dubey).
- cpupower tool fix (Prarit Bhargava)"
* tag 'pm+acpi-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (120 commits)
i2c-omap / PM: Drop CONFIG_PM_RUNTIME from i2c-omap.c
dmaengine / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
tools: cpupower: fix return checks for sysfs_get_idlestate_count()
drivers: sh / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
e1000e / igb / PM: Eliminate CONFIG_PM_RUNTIME
MMC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
MFD / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
misc / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
media / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
input / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
leds: leds-gpio: Fix multiple instances registration without 'label' property
iio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
hsi / OMAP / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
i2c-hid / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
drm / exynos / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
gpio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
hwrandom / exynos / PM: Use CONFIG_PM in #ifdef
block / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM
USB / PM: Drop CONFIG_PM_RUNTIME from the USB core
PM: Merge the SET*_RUNTIME_PM_OPS() macros
blk-mq users are allowed to free the memory request_queue.tag_set
points at after blk_cleanup_queue() has finished but before
blk_release_queue() has started. This can happen e.g. in the SCSI
core. The SCSI core namely embeds the tag_set structure in a SCSI
host structure. The SCSI host structure is freed by
scsi_host_dev_release(). This function is called after
blk_cleanup_queue() finished but can be called before
blk_release_queue().
This means that it is not safe to access request_queue.tag_set from
inside blk_release_queue(). Hence remove the blk_sync_queue() call
from blk_release_queue(). This call is not necessary - outstanding
requests must have finished before blk_release_queue() is
called. Additionally, move the blk_mq_free_queue() call from
blk_release_queue() to blk_cleanup_queue() to avoid that struct
request_queue.tag_set gets accessed after it has been freed.
This patch avoids that the following kernel oops can be triggered
when deleting a SCSI host for which scsi-mq was enabled:
Call Trace:
[<ffffffff8109a7c4>] lock_acquire+0xc4/0x270
[<ffffffff814ce111>] mutex_lock_nested+0x61/0x380
[<ffffffff812575f0>] blk_mq_free_queue+0x30/0x180
[<ffffffff8124d654>] blk_release_queue+0x84/0xd0
[<ffffffff8126c29b>] kobject_cleanup+0x7b/0x1a0
[<ffffffff8126c140>] kobject_put+0x30/0x70
[<ffffffff81245895>] blk_put_queue+0x15/0x20
[<ffffffff8125c409>] disk_release+0x99/0xd0
[<ffffffff8133d056>] device_release+0x36/0xb0
[<ffffffff8125a78a>] put_disk+0x1a/0x20
[<ffffffff811d4cb5>] __blkdev_put+0x135/0x1b0
[<ffffffff811d56a0>] blkdev_put+0x50/0x160
[<ffffffff81199eb4>] kill_block_super+0x44/0x70
[<ffffffff8119a2a4>] deactivate_locked_super+0x44/0x60
[<ffffffff8119a87e>] deactivate_super+0x4e/0x70
[<ffffffff811b9833>] cleanup_mnt+0x43/0x90
[<ffffffff811b98d2>] __cleanup_mnt+0x12/0x20
[<ffffffff8107252c>] task_work_run+0xac/0xe0
[<ffffffff81002c01>] do_notify_resume+0x61/0xa0
[<ffffffff814d2c58>] int_signal+0x12/0x17
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Robert Elliott <elliott@hp.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Alexander Gordeev <agordeev@redhat.com>
Cc: <stable@vger.kernel.org> # v3.13+
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM in the block device core.
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Currently scsi piggy backs on the block layer to define the concept
of a tagged command. But we want to be able to have block-level host-wide
tags assigned even for untagged commands like the initial INQUIRY, so add
a new SCSI-level flag for commands that are tagged at the scsi level, so
that even commands without that set can have tags assigned to them. Note
that this alredy is the case for the blk-mq code path, and this just lets
the old path catch up with it.
We also set this flag based upon sdev->simple_tags instead of the block
queue flag, so that it is entirely independent of the block layer tagging,
and thus always correct even if a driver doesn't use block level tagging
yet.
Also remove the old blk_rq_tagged; it was only used by SCSI drivers, and
removing it forces them to look for the proper replacement.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
In __get_request calls to printk_ratelimited, include the function name so
the callbacks suppressed message matches the messages that are printed,
and add "dev" before the device name so it matches other block layer
messages.
Signed-off-by: Robert Elliott <elliott@hp.com>
Reviewed-by: Webb Scales <webbnh@hp.com>
In blk_update_request, change the printk_ratelimited
prefix from end_request to blk_update_request so it
matches the name printed if rate limiting occurs.
Old:
[10234.933106] blk_update_request: 174 callbacks suppressed
[10234.934940] end_request: critical target error, dev sdr, sector 16
[10234.949788] end_request: critical target error, dev sdr, sector 16
New:
[16863.445173] blk_update_request: 398 callbacks suppressed
[16863.447029] blk_update_request: critical target error, dev sdr, sector
1442066176
[16863.449383] blk_update_request: critical target error, dev sdr, sector
802802888
[16863.451680] blk_update_request: critical target error, dev sdr, sector
1609535456
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
Request cloning clones bios in the request to track the completion
of each bio.
For that purpose, we can use bio_clone_fast() instead of bio_clone()
to avoid unnecessary allocation and copy of bvecs.
This patch reduces memory footprint of request-based device-mapper
(about 1-4KB for each request) and is a preparation for further
reduction of memory usage by removing unused bvec mempool.
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
The rq_complete tracepoint was never issued for empty requests,
causing the resulting blktrace information to never show any
completion for those request.
Signed-off-by: Hannes Reinecke <hare@suse.de>
This patch supports to run one single flush machinery for
each blk-mq dispatch queue, so that:
- current init_request and exit_request callbacks can
cover flush request too, then the buggy copying way of
initializing flush request's pdu can be fixed
- flushing performance gets improved in case of multi hw-queue
In fio sync write test over virtio-blk(4 hw queues, ioengine=sync,
iodepth=64, numjobs=4, bs=4K), it is observed that througput gets
increased a lot over my test environment:
- throughput: +70% in case of virtio-blk over null_blk
- throughput: +30% in case of virtio-blk over SSD image
The multi virtqueue feature isn't merged to QEMU yet, and patches for
the feature can be found in below tree:
git://kernel.ubuntu.com/ming/qemu.git v2.1.0-mq.4
And simply passing 'num_queues=4 vectors=5' should be enough to
enable multi queue(quad queue) feature for QEMU virtio-blk.
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This patch adds 'blk_mq_ctx' parameter to blk_get_flush_queue(),
so that this function can find the corresponding blk_flush_queue
bound with current mq context since the flush queue will become
per hw-queue.
For legacy queue, the parameter can be simply 'NULL'.
For multiqueue case, the parameter should be set as the context
from which the related request is originated. With this context
info, the hw queue and related flush queue can be found easily.
Now mission of the two helpers is over, and just call
blk_alloc_flush_queue() and blk_free_flush_queue() directly.
This patch introduces 'struct blk_flush_queue' and puts all
flush machinery related fields into this structure, so that
- flush implementation details aren't exposed to driver
- it is easy to convert to per dispatch-queue flush machinery
This patch is basically a mechanical replacement.
These fields are always used with the flush request, so
initialize them together.
These two temporary functions are introduced for holding flush
initialization and de-initialization, so that we can
introduce 'flush queue' easier in the following patch. And
once 'flush queue' and its allocation/free functions are ready,
they will be removed for sake of code readability.
A bit of churn on the for-linus side that would be nice to have
in the core bits for 3.18, so pull it in to catch us up and make
forward progress easier.
block/scsi_ioctl.c
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
bdev_get_queue() returns the request_queue associated with the
specified block_device. blk_get_backing_dev_info() makes use of
bdev_get_queue() to determine the associated bdi given a block_device.
All the callers of bdev_get_queue() including
blk_get_backing_dev_info() assume that bdev_get_queue() may return
NULL and implement NULL handling; however, bdev_get_queue() requires
the passed in block_device is opened and attached to its gendisk.
Because an active gendisk always has a valid request_queue associated
with it, bdev_get_queue() can never return NULL and neither can
blk_get_backing_dev_info().
Make it clear that neither of the two functions can return NULL and
remove NULL handling from all the callers.
Cc: Chris Mason <clm@fb.com>
The blk_get_request function may fail in low-memory conditions or during
device removal (even if __GFP_WAIT is set). To distinguish between these
errors, modify the blk_get_request call stack to return the appropriate
ERR_PTR. Verify that all callers check the return status and consider
IS_ERR instead of a simple NULL pointer check.
For consistency, make a similar change to the blk_mq_alloc_request leg
of blk_get_request. It may fail if the queue is dead, or the caller was
unwilling to wait.
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Acked-by: Jiri Kosina <jkosina@suse.cz> [for pktdvd]
Acked-by: Boaz Harrosh <bharrosh@panasas.com> [for osd]
This patch fixes code such as the following with scsi-mq enabled:
rq = blk_get_request(...);
blk_rq_set_block_pc(rq);
rq->cmd = my_cmd_buffer; /* separate CDB buffer */
blk_execute_rq_nowait(...);
Code like this appears in e.g. sg_start_req() in drivers/scsi/sg.c (for
large CDBs only). Without this patch, scsi_mq_prep_fn() will set
rq->cmd back to rq->__cmd, causing the wrong CDB to be sent to the device.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
blk_mq freezing is entangled with generic bypassing which bypasses
blkcg and io scheduler and lets IO requests fall through the block
layer to the drivers in FIFO order. This allows forward progress on
IOs with the advanced features disabled so that those features can be
configured or altered without worrying about stalling IO which may
lead to deadlock through memory allocation.
However, generic bypassing doesn't quite fit blk-mq. blk-mq currently
doesn't make use of blkcg or ioscheds and it maps bypssing to
freezing, which blocks request processing and drains all the in-flight
ones. This causes problems as bypassing assumes that request
processing is online. blk-mq works around this by conditionally
allowing request processing for the problem case - during queue
initialization.
Another weirdity is that except for during queue cleanup, bypassing
started on the generic side prevents blk-mq from processing new
requests but doesn't drain the in-flight ones. This shouldn't break
anything but again highlights that something isn't quite right here.
The root cause is conflating blk-mq freezing and generic bypassing
which are two different mechanisms. The only intersecting purpose
that they serve is during queue cleanup. Let's properly separate
blk-mq freezing from generic bypassing and simply use it where
necessary.
* request_queue->mq_freeze_depth is added and
blk_mq_[un]freeze_queue() now operate on this counter instead of
->bypass_depth. The replacement for QUEUE_FLAG_BYPASS isn't added
but the counter is tested directly. This will be further updated by
later changes.
* blk_mq_drain_queue() is dropped and "__" prefix is dropped from
blk_mq_freeze_queue(). Queue cleanup path now calls
blk_mq_freeze_queue() directly.
* blk_queue_enter()'s fast path condition is simplified to simply
check @q->mq_freeze_depth. Previously, the condition was
!blk_queue_dying(q) &&
(!blk_queue_bypass(q) || !blk_queue_init_done(q))
mq_freeze_depth is incremented right after dying is set and
blk_queue_init_done() exception isn't necessary as blk-mq doesn't
start frozen, which only leaves the blk_queue_bypass() test which
can be replaced by @q->mq_freeze_depth test.
This change simplifies the code and reduces confusion in the area.
Cc: Nicholas A. Bellinger <nab@linux-iscsi.org>
Currently, both blk_queue_bypass_start() and blk_mq_freeze_queue()
skip queue draining if bypass_depth was already above zero. The
assumption is that the one which bumped the bypass_depth should have
performed draining already; however, there's nothing which prevents a
new instance of bypassing/freezing from starting before the previous
one finishes draining. The current code may allow the later
bypassing/freezing instances to complete while there still are
in-flight requests which haven't finished draining.
Fix it by draining regardless of bypass_depth. We still skip draining
from blk_queue_bypass_start() while the queue is initializing to avoid
introducing excessive delays during boot. INIT_DONE setting is moved
above the initial blk_queue_bypass_end() so that bypassing attempts
can't slip inbetween.
Pull block fixes from Jens Axboe:
"A smaller collection of fixes for the block core that would be nice to
have in -rc2. This pull request contains:
- Fixes for races in the wait/wakeup logic used in blk-mq from
Alexander. No issues have been observed, but it is definitely a
bit flakey currently. Alternatively, we may drop the cyclic
wakeups going forward, but that needs more testing.
- Some cleanups from Christoph.
- Fix for an oops in null_blk if queue_mode=1 and softirq completions
are used. From me.
- A fix for a regression caused by the chunk size setting. It
inadvertently used max_hw_sectors instead of max_sectors, which is
incorrect, and causes hangs on btrfs multi-disk setups (where hw
sectors apparently isn't set). From me.
- Removal of WQ_POWER_EFFICIENT in the kblockd creation. This was a
recent addition as well, but it actually breaks blk-mq which relies
on strict scheduling. If the workqueue power_efficient mode is
turned on, this breaks blk-mq. From Matias.
- null_blk module parameter description fix from Mike"
* 'for-linus' of git://git.kernel.dk/linux-block:
blk-mq: bitmap tag: fix races in bt_get() function
blk-mq: bitmap tag: fix race on blk_mq_bitmap_tags::wake_cnt
blk-mq: bitmap tag: fix races on shared ::wake_index fields
block: blk_max_size_offset() should check ->max_sectors
null_blk: fix softirq completions for queue_mode == 1
blk-mq: merge blk_mq_drain_queue and __blk_mq_drain_queue
blk-mq: properly drain stopped queues
block: remove WQ_POWER_EFFICIENT from kblockd
null_blk: fix name and description of 'queue_mode' module parameter
block: remove elv_abort_queue and blk_abort_flushes
