path: root/block/blk-ioc.c
2011-06-02block: Use hlist_entry() for io_context.cic_list.firstPaul Bolle
list_entry() and hlist_entry() are both simply aliases for container_of(), but since io_context.cic_list.first is an hlist_node one should at least use the correct alias. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-23blk-cgroup: Initialize ioc->cgroup_changed at ioc creation timeVivek Goyal
If we don't explicitly initialize it to zero, CFQ might think that cgroup of ioc has changed and it generates lots of unnecessary calls to call_for_each_cic(changed_cgroup). Fix it. cfq_get_io_context() cfq_ioc_set_cgroup() call_for_each_cic(ioc, changed_cgroup) Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-21block: Clean up exit_io_context() source code.Bart Van Assche
This patch fixes a spelling error in a source code comment and removes superfluous braces in the function exit_io_context(). Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-11block: remove unused copy_io_context()Jens Axboe
Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01block: don't access jiffies when initialising io_contextRichard Kennedy
As the comment says the initial value of last_waited is never used, so there is no need to initialise it with the current jiffies. Jiffies is hot enough without accessing it for no reason. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-11block: removed unused as_io_contextKirill Afonshin
It isn't used anymore, since AS was deleted. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-04block: Fix io_context leak after failure of clone with CLONE_IOLouis Rilling
With CLONE_IO, parent's io_context->nr_tasks is incremented, but never decremented whenever copy_process() fails afterwards, which prevents exit_io_context() from calling IO schedulers exit functions. Give a task_struct to exit_io_context(), and call exit_io_context() instead of put_io_context() in copy_process() cleanup path. Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-04block: Fix io_context leak after clone with CLONE_IOLouis Rilling
With CLONE_IO, copy_io() increments both ioc->refcount and ioc->nr_tasks. However exit_io_context() only decrements ioc->refcount if ioc->nr_tasks reaches 0. Always call put_io_context() in exit_io_context(). Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-10block: prevent possible io_context->refcount overflowNikanth Karthikesan
Currently io_context has an atomic_t(32-bit) as refcount. In the case of cfq, for each device against whcih a task does I/O, a reference to the io_context would be taken. And when there are multiple process sharing io_contexts(CLONE_IO) would also have a reference to the same io_context. Theoretically the possible maximum number of processes sharing the same io_context + the number of disks/cfq_data referring to the same io_context can overflow the 32-bit counter on a very high-end machine. Even though it is an improbable case, let us make it atomic_long_t. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07cfq-iosched: fix RCU race in the cfq io_context destructor handlingJens Axboe
put_io_context() drops the RCU read lock before calling into cfq_dtor(), however we need to hold off freeing there before grabbing and dereferencing the first object on the list. So extend the rcu_read_lock() scope to cover the calling of cfq_dtor(), and optimize cfq_free_io_context() to use a new variant for call_for_each_cic() that assumes the RCU read lock is already held. Hit in the wild by Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19cfq-iosched: add hlist for browsing parallel to the radix treeJens Axboe
It's cumbersome to browse a radix tree from start to finish, especially since we modify keys when a process exits. So add a hlist for the single purpose of browsing over all known cfq_io_contexts, used for exit, io prio change, etc. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=9948 Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19make blk_ioc_init() staticAdrian Bunk
blk_ioc_init() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-01block: kill swap_io_context()Jens Axboe
It blindly copies everything in the io_context, including the lock. That doesn't work so well for either lock ordering or lockdep. There seems zero point in swapping io contexts on a request to request merge, so the best point of action is to just remove it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
