path: root/block/blk-map.c
2010-11-29block: check for proper length of iov entries earlier in blk_rq_map_user_iov()Xiaotian Feng
commit 9284bcf checks for proper length of iov entries in blk_rq_map_user_iov(). But if the map is unaligned, kernel will break out the loop without checking for the proper length. So we need to check the proper length before the unalign check. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: check for proper length of iov entries in blk_rq_map_user_iov()Jens Axboe
Ensure that we pass down properly validated iov segments before calling into the mapping or copy functions. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-09-21block: fix blk_rq_map_kern bio direction flagBenny Halevy
This bug was introduced in 7b6d91daee5cac6402186ff224c3af39d79f4a0e "block: unify flags for struct bio and struct request" Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-15block: fix an address space warning in blk-map.cNamhyung Kim
Change type of 2nd parameter of blk_rq_aligned() into unsigned long and remove unnecessary casting. Now we can call it with 'uaddr' instead of 'ubuf' in __blk_rq_map_user() so that it can remove following warnings from sparse: block/blk-map.c:57:31: warning: incorrect type in argument 2 (different address spaces) block/blk-map.c:57:31: expected void *addr block/blk-map.c:57:31: got void [noderef] <asn:1>*ubuf However blk_rq_map_kern() needs one more local variable to handle it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19block: Un-export blk_rq_append_bioBoaz Harrosh
OSD was the last in-tree user of blk_rq_append_bio(). Now that it is fixed blk_rq_append_bio is un-exported and is only used internally by block layer. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19block: allow blk_rq_map_kern to append to requestsJames Bottomley
Use blk_rq_append_bio() internally instead of blk_rq_bio_prep() so blk_rq_map_kern can be called multiple times, to map multiple buffers. This is in the effort to un-export blk_rq_append_bio() Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: hide request sector and data_lenTejun Heo
Block low level drivers for some reason have been pretty good at abusing block layer API. Especially struct request's fields tend to get violated in all possible ways. Make it clear that low level drivers MUST NOT access or manipulate rq->sector and rq->data_len directly by prefixing them with double underscores. This change is also necessary to break build of out-of-tree codes which assume the previous block API where internal fields can be manipulated and rq->data_len carries residual count on completion. [ Impact: hide internal fields, block API change ] Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: kill rq->dataTejun Heo
Now that all block request data transfer is done via bio, rq->data isn't used. Kill it. While at it, make the roles of rq->special and buffer clear. [ Impact: drop now unncessary field from struct request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com>
2009-01-02[SCSI] block: make blk_rq_map_user take a NULL user-space buffer for WRITEFUJITA Tomonori
The commit 818827669d85b84241696ffef2de485db46b0b5e (block: make blk_rq_map_user take a NULL user-space buffer) extended blk_rq_map_user to accept a NULL user-space buffer with a READ command. It was necessary to convert sg to use the block layer mapping API. This patch extends blk_rq_map_user again for a WRITE command. It is necessary to convert st and osst drivers to use the block layer apping API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] block: fix the partial mappings with struct rq_map_dataFUJITA Tomonori
This fixes bio_copy_user_iov to properly handle the partial mappings with struct rq_map_data (which only sg uses for now but st and osst will shortly). It adds the offset member to struct rq_map_data and changes blk_rq_map_user to update it so that bio_copy_user_iov can add an appropriate page frame via bio_add_pc_page(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-03When block layer fails to map iov, it calls bio_unmap_user to undoPetr Vandrovec
mapping. Which is good if pages were mapped - but if they were provided by someone else and just copied then bad things happen - pages are released once here, and once by caller, leading to user triggerable BUG at include/linux/mm.h:246. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18block: hold extra reference to bio in blk_rq_map_user_iov()Jens Axboe
If the size passed in is OK but we end up mapping too many segments, we call the unmap path directly like from IO completion. But from IO completion we have an extra reference to the bio, so this error case goes OOPS when it attempts to free and already free bio. Fix it by getting an extra reference to the bio before calling the unmap failure case. Reported-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: make blk_rq_map_user take a NULL user-space bufferFUJITA Tomonori
This patch changes blk_rq_map_user to accept a NULL user-space buffer with a READ command if rq_map_data is not NULL. Thus a caller can pass page frames to lk_rq_map_user to just set up a request and bios with page frames propely. bio_uncopy_user (called via blk_rq_unmap_user) doesn't copy data to user space with such request. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add blk_rq_aligned helper functionFUJITA Tomonori
This adds blk_rq_aligned helper function to see if alignment and padding requirement is satisfied for DMA transfer. This also converts blk_rq_map_kern and __blk_rq_map_user to use the helper function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26block/blk-map.c: use the new object_is_on_stack() helperFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04block: blk_rq_map_kern uses the bounce buffers for stack buffersFUJITA Tomonori
blk_rq_map_kern is used for kernel internal I/Os. Some callers use this function with stack buffers but DMA to/from the stack buffers leads to memory corruption on a non-coherent platform. This patch make blk_rq_map_kern uses the bounce buffers if a caller passes a stack buffer (on the all platforms for simplicity). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: add bounce support to blk_rq_map_user_iovFUJITA Tomonori
blk_rq_map_user_iov can't handle the bounce buffer (it means that the bio_map_user_iov path doesn't work with a LLD that needs GFP_DMA). This patch fixes blk_rq_map_user_iov to support the bounce buffer. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: add dma alignment and padding support to blk_rq_map_kernFUJITA Tomonori
This patch adds bio_copy_kern similar to bio_copy_user. blk_rq_map_kern uses bio_copy_kern instead of bio_map_kern if necessary. bio_copy_kern uses temporary pages and the bi_end_io callback frees these pages. bio_copy_kern saves the original kernel buffer at bio->bi_private it doesn't use something like struct bio_map_data to store the information about the caller. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21block: move the padding adjustment to blk_rq_map_sgFUJITA Tomonori
blk_rq_map_user adjusts bi_size of the last bio. It breaks the rule that req->data_len (the true data length) is equal to sum(bio). It broke the scsi command completion code. commit e97a294ef6938512b655b1abf17656cf2b26f709 was introduced to fix the above issue. However, the partial completion code doesn't work with it. The commit is also a layer violation (scsi mid-layer should not know about the block layer's padding). This patch moves the padding adjustment to blk_rq_map_sg (suggested by James). The padding works like the drain buffer. This patch breaks the rule that req->data_len is equal to sum(sg), however, the drain buffer already broke it. So this patch just restores the rule that req->data_len is equal to sub(bio) without breaking anything new. Now when a low level driver needs padding, blk_rq_map_user and blk_rq_map_user_iov guarantee there's enough room for padding. blk_rq_map_sg can safely extend the last entry of a scatter list. blk_rq_map_sg must extend the last entry of a scatter list only for a request that got through bio_copy_user_iov. This patches introduces new REQ_COPY_USER flag. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21block: add bio_copy_user_iov support to blk_rq_map_user_iovFUJITA Tomonori
With this patch, blk_rq_map_user_iov uses bio_copy_user_iov when a low level driver needs padding or a buffer in sg_iovec isn't aligned. That is, it uses temporary kernel buffers instead of mapping user pages directly. When a LLD needs padding, later blk_rq_map_sg needs to extend the last entry of a scatter list. bio_copy_user_iov guarantees that there is enough space for padding by using temporary kernel buffers instead of user pages. blk_rq_map_user_iov needs buffers in sg_iovec to be aligned. The comment in blk_rq_map_user_iov indicates that drivers/scsi/sg.c also needs buffers in sg_iovec to be aligned. Actually, drivers/scsi/sg.c works with unaligned buffers in sg_iovec (it always uses temporary kernel buffers). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: fix shadowed variable warning in blk-map.cHarvey Harrison
Introduced between 2.6.25-rc2 and -rc3 block/blk-map.c:154:14: warning: symbol 'bio' shadows an earlier one block/blk-map.c:110:13: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04unexport blk_rq_map_user_iovAdrian Bunk
This patch removes the unused export of blk_rq_map_user_iov. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: separate out padding from alignmentTejun Heo
Block layer alignment was used for two different purposes - memory alignment and padding. This causes problems in lower layers because drivers which only require memory alignment ends up with adjusted rq->data_len. Separate out padding such that padding occurs iff driver explicitly requests it. Tomo: restorethe code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa according to padding alignment. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: restore the meaning of rq->data_len to the true data lengthFUJITA Tomonori
The meaning of rq->data_len was changed to the length of an allocated buffer from the true data length. It breaks SG_IO friends and bsg. This patch restores the meaning of rq->data_len to the true data length and adds rq->extra_len to store an extended length (due to drain buffer and padding). This patch also removes the code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa. The commit adjusts bio according to memory alignment (queue_dma_alignment). However, memory alignment is NOT padding alignment. This adjustment also breaks SG_IO friends and bsg. Padding alignment needs to be fixed in a proper way (by a separate patch). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19block: add request->raw_data_lenTejun Heo
With padding and draining moved into it, block layer now may extend requests as directed by queue parameters, so now a request has two sizes - the original request size and the extended size which matches the size of area pointed to by bios and later by sgs. The latter size is what lower layers are primarily interested in when allocating, filling up DMA tables and setting up the controller. Both padding and draining extend the data area to accomodate controller characteristics. As any controller which speaks SCSI can handle underflows, feeding larger data area is safe. So, this patch makes the primary data length field, request->data_len, indicate the size of full data area and add a separate length field, request->raw_data_len, for the unmodified request size. The latter is used to report to higher layer (userland) and where the original request size should be fed to the controller or device. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: update bio according to DMA alignment paddingTejun Heo
DMA start address and transfer size alignment for PC requests are achieved using bio_copy_user() instead of bio_map_user(). This works because bio_copy_user() always uses full pages and block DMA alignment isn't allowed to go over PAGE_SIZE. However, the implementation didn't update the last bio of the request to make this padding visible to lower layers. This patch makes blk_rq_map_user() extend the last bio such that it includes the padding area and the size of area pointed to by the request is properly aligned. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: make blk_rq_map_user() clear ->bio if it unmaps itJens Axboe
That way the interface is symmetric, and calling blk_rq_unmap_user() on the request wont oops. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
