This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit e26cc08265dda37d2acc8394604f220ef412299d ]
blk_exit_queue will free elevator_data, while blk_mq_requeue_work
will access it. Move cancel of requeue_work to the front of
blk_exit_queue to avoid use-after-free.
blk_exit_queue blk_mq_requeue_work
__elevator_exit blk_mq_run_hw_queues
blk_mq_exit_sched blk_mq_run_hw_queue
dd_exit_queue blk_mq_hctx_has_pending
kfree(elevator_data) blk_mq_sched_has_work
dd_has_work
Fixes: fbc2a15e3433 ("blk-mq: move cancel of requeue_work into blk_mq_release")
Cc: stable@vger.kernel.org
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: zhengbin <zhengbin13@huawei.com>
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
[ Upstream commit fbc2a15e3433058582e5635aabe48a3011a644a8 ]
With holding queue's kobject refcount, it is safe for driver
to schedule requeue. However, blk_mq_kick_requeue_list() may
be called after blk_sync_queue() is done because of concurrent
requeue activities, then requeue work may not be completed when
freeing queue, and kernel oops is triggered.
So moving the cancel of requeue_work into blk_mq_release() for
avoiding race between requeue and freeing queue.
Cc: Dongli Zhang <dongli.zhang@oracle.com>
Cc: James Smart <james.smart@broadcom.com>
Cc: Bart Van Assche <bart.vanassche@wdc.com>
Cc: linux-scsi@vger.kernel.org,
Cc: Martin K . Petersen <martin.petersen@oracle.com>,
Cc: Christoph Hellwig <hch@lst.de>,
Cc: James E . J . Bottomley <jejb@linux.vnet.ibm.com>,
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Tested-by: James Smart <james.smart@broadcom.com>
Signed-off-by: Ming Lei <ming.lei@redhat.com>
That we we can also poll non blk-mq queues. Mostly needed for
the NVMe multipath code, but could also be useful elsewhere.
(cherry picked from commit ea435e1b9392a33deceaea2a16ebaa3397bead93)
commit 587562d0c7cd6861f4f90a2eb811cccb1a376f5f upstream.
trace_block_unplug() takes true for explicit unplugs and false for
implicit unplugs. schedule() unplugs are implicit and should be
reported as timer unplugs. While correct in the legacy code, this has
been inverted in blk-mq since 4.11.
Fixes: bd166ef183c2 ("blk-mq-sched: add framework for MQ capable IO schedulers")
Reviewed-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit a347c7ad8edf4c5685154f3fdc3c12fc1db800ba upstream.
It is not allowed to reinit q->tag_set_list list entry while RCU grace
period has not completed yet, otherwise the following soft lockup in
blk_mq_sched_restart() happens:
[ 1064.252652] watchdog: BUG: soft lockup - CPU#12 stuck for 23s! [fio:9270]
[ 1064.254445] task: ffff99b912e8b900 task.stack: ffffa6d54c758000
[ 1064.254613] RIP: 0010:blk_mq_sched_restart+0x96/0x150
[ 1064.256510] Call Trace:
[ 1064.256664] <IRQ>
[ 1064.256824] blk_mq_free_request+0xea/0x100
[ 1064.256987] msg_io_conf+0x59/0xd0 [ibnbd_client]
[ 1064.257175] complete_rdma_req+0xf2/0x230 [ibtrs_client]
[ 1064.257340] ? ibtrs_post_recv_empty+0x4d/0x70 [ibtrs_core]
[ 1064.257502] ibtrs_clt_rdma_done+0xd1/0x1e0 [ibtrs_client]
[ 1064.257669] ib_create_qp+0x321/0x380 [ib_core]
[ 1064.257841] ib_process_cq_direct+0xbd/0x120 [ib_core]
[ 1064.258007] irq_poll_softirq+0xb7/0xe0
[ 1064.258165] __do_softirq+0x106/0x2a2
[ 1064.258328] irq_exit+0x92/0xa0
[ 1064.258509] do_IRQ+0x4a/0xd0
[ 1064.258660] common_interrupt+0x7a/0x7a
[ 1064.258818] </IRQ>
Meanwhile another context frees other queue but with the same set of
shared tags:
[ 1288.201183] INFO: task bash:5910 blocked for more than 180 seconds.
[ 1288.201833] bash D 0 5910 5820 0x00000000
[ 1288.202016] Call Trace:
[ 1288.202315] schedule+0x32/0x80
[ 1288.202462] schedule_timeout+0x1e5/0x380
[ 1288.203838] wait_for_completion+0xb0/0x120
[ 1288.204137] __wait_rcu_gp+0x125/0x160
[ 1288.204287] synchronize_sched+0x6e/0x80
[ 1288.204770] blk_mq_free_queue+0x74/0xe0
[ 1288.204922] blk_cleanup_queue+0xc7/0x110
[ 1288.205073] ibnbd_clt_unmap_device+0x1bc/0x280 [ibnbd_client]
[ 1288.205389] ibnbd_clt_unmap_dev_store+0x169/0x1f0 [ibnbd_client]
[ 1288.205548] kernfs_fop_write+0x109/0x180
[ 1288.206328] vfs_write+0xb3/0x1a0
[ 1288.206476] SyS_write+0x52/0xc0
[ 1288.206624] do_syscall_64+0x68/0x1d0
[ 1288.206774] entry_SYSCALL_64_after_hwframe+0x3d/0xa2
What happened is the following:
1. There are several MQ queues with shared tags.
2. One queue is about to be freed and now task is in
blk_mq_del_queue_tag_set().
3. Other CPU is in blk_mq_sched_restart() and loops over all queues in
tag list in order to find hctx to restart.
Because linked list entry was modified in blk_mq_del_queue_tag_set()
without proper waiting for a grace period, blk_mq_sched_restart()
never ends, spining in list_for_each_entry_rcu_rr(), thus soft lockup.
Fix is simple: reinit list entry after an RCU grace period elapsed.
Fixes: Fixes: 705cda97ee3a ("blk-mq: Make it safe to use RCU to iterate over blk_mq_tag_set.tag_list")
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: linux-block@vger.kernel.org
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com>
[ Upstream commit bf0ddaba65ddbb2715af97041da8e7a45b2d8628 ]
When the blk-mq inflight implementation was added, /proc/diskstats was
converted to use it, but /sys/block/$dev/inflight was not. Fix it by
adding another helper to count in-flight requests by data direction.
Fixes: f299b7c7a9de ("blk-mq: provide internal in-flight variant")
Signed-off-by: Omar Sandoval <osandov@fb.com>
[ Upstream commit 7df938fbc4ee641e70e05002ac67c24b19e86e74 ]
We know this WARN_ON is harmless and in reality it may be trigged,
so convert it to printk() and dump_stack() to avoid to confusing
people.
Also add comment about two releated races here.
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Stefan Haberland <sth@linux.vnet.ibm.com>
Cc: "jianchao.wang" <jianchao.w.wang@oracle.com>
[ Upstream commit 8ab0b7dc73e1b3e2987d42554b2bff503f692772 ]
HW queues may be unmapped in some cases, such as blk_mq_update_nr_hw_queues(),
then we need to check it before calling blk_mq_tag_idle(), otherwise
the following kernel oops can be triggered, so fix it by checking if
the hw queue is unmapped since it doesn't make sense to idle the tags
any more after hw queues are unmapped.
[ 440.771298] Workqueue: nvme-wq nvme_rdma_del_ctrl_work [nvme_rdma]
[ 440.779104] task: ffff894bae755ee0 ti: ffff893bf9bc8000 task.ti: ffff893bf9bc8000
[ 440.788359] RIP: 0010:[<ffffffffb730e2b4>] [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 440.798697] RSP: 0018:ffff893bf9bcbd10 EFLAGS: 00010286
[ 440.805538] RAX: 0000000000000000 RBX: ffff895bb131dc00 RCX: 000000000000011f
[ 440.814426] RDX: 00000000ffffffff RSI: 0000000000000120 RDI: ffff895bb131dc00
[ 440.823301] RBP: ffff893bf9bcbd10 R08: 000000000001b860 R09: 4a51d361c00c0000
[ 440.832193] R10: b5907f32b4cc7003 R11: ffffd6cabfb57000 R12: ffff894bafd1e008
[ 440.841091] R13: 0000000000000001 R14: ffff895baf770000 R15: 0000000000000080
[ 440.849988] FS: 0000000000000000(0000) GS:ffff894bbdcc0000(0000) knlGS:0000000000000000
[ 440.859955] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 440.867274] CR2: 0000000000000008 CR3: 000000103d098000 CR4: 00000000001407e0
[ 440.876169] Call Trace:
[ 440.879818] [<ffffffffb7309d68>] blk_mq_exit_hctx+0xd8/0xe0
[ 440.887051] [<ffffffffb730dc40>] blk_mq_free_queue+0xf0/0x160
[ 440.894465] [<ffffffffb72ff679>] blk_cleanup_queue+0xd9/0x150
[ 440.901881] [<ffffffffc08a802b>] nvme_ns_remove+0x5b/0xb0 [nvme_core]
[ 440.910068] [<ffffffffc08a811b>] nvme_remove_namespaces+0x3b/0x60 [nvme_core]
[ 440.919026] [<ffffffffc08b817b>] __nvme_rdma_remove_ctrl+0x2b/0xb0 [nvme_rdma]
[ 440.928079] [<ffffffffc08b8237>] nvme_rdma_del_ctrl_work+0x17/0x20 [nvme_rdma]
[ 440.937126] [<ffffffffb70ab58a>] process_one_work+0x17a/0x440
[ 440.944517] [<ffffffffb70ac3a8>] worker_thread+0x278/0x3c0
[ 440.951607] [<ffffffffb70ac130>] ? manage_workers.isra.24+0x2a0/0x2a0
[ 440.959760] [<ffffffffb70b352f>] kthread+0xcf/0xe0
[ 440.966055] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.973715] [<ffffffffb76d8658>] ret_from_fork+0x58/0x90
[ 440.980586] [<ffffffffb70b3460>] ? insert_kthread_work+0x40/0x40
[ 440.988229] Code: 5b 41 5c 5d c3 66 90 0f 1f 44 00 00 48 8b 87 20 01 00 00 f0 0f ba 77 40 01 19 d2 85 d2 75 08 c3 0f 1f 80 00 00 00 00 55 48 89 e5 <f0> ff 48 08 48 8d 78 10 e8 7f 0f 05 00 5d c3 0f 1f 00 66 2e 0f
[ 441.011620] RIP [<ffffffffb730e2b4>] __blk_mq_tag_idle+0x24/0x40
[ 441.019301] RSP <ffff893bf9bcbd10>
[ 441.024052] CR2: 0000000000000008
Reported-by: Zhang Yi <yizhan@redhat.com>
Tested-by: Zhang Yi <yizhan@redhat.com>
[ Upstream commit fb350e0ad99359768e1e80b4784692031ec340e4 ]
In both elevator_switch_mq() and blk_mq_update_nr_hw_queues(), sched tags
can be allocated, and q->nr_hw_queue is used, and race is inevitable, for
example: blk_mq_init_sched() may trigger use-after-free on hctx, which is
freed in blk_mq_realloc_hw_ctxs() when nr_hw_queues is decreased.
This patch fixes the race be holding q->sysfs_lock.
Reported-by: Yi Zhang <yi.zhang@redhat.com>
Tested-by: Yi Zhang <yi.zhang@redhat.com>
[ Upstream commit 7d4901a90d02500c8011472a060f9b2e60e6e605 ]
blk_mq_pci_map_queues() may not map one CPU into any hw queue, but its
previous map isn't cleared yet, and may point to one stale hw queue
index.
This patch fixes the following issue by clearing the mapping table before
setting it up in blk_mq_pci_map_queues().
This patches fixes this following issue reported by Zhang Yi:
[ 101.202734] BUG: unable to handle kernel NULL pointer dereference at 0000000094d3013f
[ 101.211487] IP: blk_mq_map_swqueue+0xbc/0x200
[ 101.216346] PGD 0 P4D 0
[ 101.219171] Oops: 0000 [#1] SMP
[ 101.222674] Modules linked in: sunrpc ipmi_ssif vfat fat intel_rapl sb_edac x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel intel_cstate intel_uncore mxm_wmi intel_rapl_perf iTCO_wdt ipmi_si ipmi_devintf pcspkr iTCO_vendor_support sg dcdbas ipmi_msghandler wmi mei_me lpc_ich shpchp mei acpi_power_meter dm_multipath ip_tables xfs libcrc32c sd_mod mgag200 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm ahci libahci crc32c_intel libata tg3 nvme nvme_core megaraid_sas ptp i2c_core pps_core dm_mirror dm_region_hash dm_log dm_mod
[ 101.284881] CPU: 0 PID: 504 Comm: kworker/u25:5 Not tainted 4.15.0-rc2 #1
[ 101.292455] Hardware name: Dell Inc. PowerEdge R730xd/072T6D, BIOS 2.5.5 08/16/2017
[ 101.301001] Workqueue: nvme-wq nvme_reset_work [nvme]
[ 101.306636] task: 00000000f2c53190 task.stack: 000000002da874f9
[ 101.313241] RIP: 0010:blk_mq_map_swqueue+0xbc/0x200
[ 101.318681] RSP: 0018:ffffc9000234fd70 EFLAGS: 00010282
[ 101.324511] RAX: ffff88047ffc9480 RBX: ffff88047e130850 RCX: 0000000000000000
[ 101.332471] RDX: ffffe8ffffd40580 RSI: ffff88047e509b40 RDI: ffff88046f37a008
[ 101.340432] RBP: 000000000000000b R08: ffff88046f37a008 R09: 0000000011f94280
[ 101.348392] R10: ffff88047ffd4d00 R11: 0000000000000000 R12: ffff88046f37a008
[ 101.356353] R13: ffff88047e130f38 R14: 000000000000000b R15: ffff88046f37a558
[ 101.364314] FS: 0000000000000000(0000) GS:ffff880277c00000(0000) knlGS:0000000000000000
[ 101.373342] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 101.379753] CR2: 0000000000000098 CR3: 000000047f409004 CR4: 00000000001606f0
[ 101.387714] Call Trace:
[ 101.390445] blk_mq_update_nr_hw_queues+0xbf/0x130
[ 101.395791] nvme_reset_work+0x6f4/0xc06 [nvme]
[ 101.400848] ? pick_next_task_fair+0x290/0x5f0
[ 101.405807] ? __switch_to+0x1f5/0x430
[ 101.409988] ? put_prev_entity+0x2f/0xd0
[ 101.414365] process_one_work+0x141/0x340
[ 101.418836] worker_thread+0x47/0x3e0
[ 101.422921] kthread+0xf5/0x130
[ 101.426424] ? rescuer_thread+0x380/0x380
[ 101.430896] ? kthread_associate_blkcg+0x90/0x90
[ 101.436048] ret_from_fork+0x1f/0x30
[ 101.440034] Code: 48 83 3c ca 00 0f 84 2b 01 00 00 48 63 cd 48 8b 93 10 01 00 00 8b 0c 88 48 8b 83 20 01 00 00 4a 03 14 f5 60 04 af 81 48 8b 0c c8 <48> 8b 81 98 00 00 00 f0 4c 0f ab 30 8b 81 f8 00 00 00 89 42 44
[ 101.461116] RIP: blk_mq_map_swqueue+0xbc/0x200 RSP: ffffc9000234fd70
[ 101.468205] CR2: 0000000000000098
[ 101.471907] ---[ end trace 5fe710f98228a3ca ]---
[ 101.482489] Kernel panic - not syncing: Fatal exception
[ 101.488505] Kernel Offset: disabled
[ 101.497752] ---[ end Kernel panic - not syncing: Fatal exception
Suggested-by: Christoph Hellwig <hch@lst.de>
commit 105976f517791aed3b11f8f53b308a2069d42055 upstream.
__blk_mq_requeue_request() covers two cases:
- one is that the requeued request is added to hctx->dispatch, such as
blk_mq_dispatch_rq_list()
- another case is that the request is requeued to io scheduler, such as
blk_mq_requeue_request().
We should call io sched's .requeue_request callback only for the 2nd
case.
Cc: Paolo Valente <paolo.valente@linaro.org>
Cc: Omar Sandoval <osandov@fb.com>
Acked-by: Paolo Valente <paolo.valente@linaro.org>
[ Upstream commit 454be724f6f99cc7e7bbf15067128be9868186c6 ]
Now we track legacy requests with .q_usage_counter in commit 055f6e18e08f
("block: Make q_usage_counter also track legacy requests"), but that
commit never runs and drains legacy queue before waiting for this counter
becoming zero, then IO hang is caused in the test of pulling disk during IO.
This patch fixes the issue by draining requests before waiting for
q_usage_counter becoming zero, both Mauricio and chenxiang reported this
issue, and observed that it can be fixed by this patch.
Link: https://marc.info/?l=linux-block&m=151192424731797&w=2
Fixes: 055f6e18e08f("block: Make q_usage_counter also track legacy requests")
Cc: Wen Xiong <wenxiong@us.ibm.com>
Tested-by: "chenxiang (M)" <chenxiang66@hisilicon.com>
Tested-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com>
A NULL pointer crash was reported for the case of having the BFQ IO
scheduler attached to the underlying blk-mq paths of a DM multipath
device. The crash occured in blk_mq_sched_insert_request()'s call to
e->type->ops.mq.insert_requests().
Paolo Valente correctly summarized why the crash occured with:
"the call chain (dm_mq_queue_rq -> map_request -> setup_clone ->
blk_rq_prep_clone) creates a cloned request without invoking
e->type->ops.mq.prepare_request for the target elevator e. The cloned
request is therefore not initialized for the scheduler, but it is
however inserted into the scheduler by blk_mq_sched_insert_request."
All said, a request-based DM multipath device's IO scheduler should be
the only one used -- when the original requests are issued to the
underlying paths as cloned requests they are inserted directly in the
underlying dispatch queue(s) rather than through an additional elevator.
But commit bd166ef18 ("blk-mq-sched: add framework for MQ capable IO
schedulers") switched blk_insert_cloned_request() from using
blk_mq_insert_request() to blk_mq_sched_insert_request(). Which
incorrectly added elevator machinery into a call chain that isn't
supposed to have any.
To fix this introduce a blk-mq private blk_mq_request_bypass_insert()
that blk_insert_cloned_request() calls to insert the request without
involving any elevator that may be attached to the cloned request's
request_queue.
Reported-by: Bart Van Assche <Bart.VanAssche@wdc.com>
Tested-by: Mike Snitzer <snitzer@redhat.com>
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
Since patch "blk-mq: switch .queue_rq return value to blk_status_t"
.queue_rq() returns a BLK_STS_* value instead of a BLK_MQ_RQ_*
value. Hence refer to the former in comments about .queue_rq()
return values.
Fixes: commit 39a70c76b89b ("blk-mq: clarify dispatch may not be drained/blocked by stopping queue")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
blk_mq_get_request() does not release the callers queue usage counter
when allocation fails. The caller still needs to account for its own
queue usage when it is unable to allocate a request.
Fixes: 1ad43c0078b7 ("blk-mq: don't leak preempt counter/q_usage_counter when allocating rq failed")
Reported-by: Max Gurtovoy <maxg@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Tested-by: Max Gurtovoy <maxg@mellanox.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
The blk_mq_delay_kick_requeue_list() function is used by the device
mapper and only by the device mapper to rerun the queue and requeue
list after a delay. This function is called once per request that
gets requeued. Modify this function such that the queue is run once
per path change event instead of once per request that is requeued.
Fixes: commit 2849450ad39d ("blk-mq: introduce blk_mq_delay_kick_requeue_list()")
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Laurence Oberman <loberman@redhat.com>
Cc: <stable@vger.kernel.org>
Modify blk_mq_in_flight() to count both a partition and root at
the same time. Then we only have to call it once, instead of
potentially looping the tags twice.
We don't have to inc/dec some counter, since we can just
iterate the tags. That makes inc/dec a noop, but means we
have to iterate busy tags to get an in-flight count.
When blk_mq_get_request() failed, preempt counter isn't
released, and blk_mq_make_request() doesn't release the counter
too.
This patch fixes the issue, and makes sure that preempt counter
is only held if rq is allocated successfully. The same policy is
applied on .q_usage_counter too.
Signed-off-by: Ming Lei <minlei@redhat.com>
We recently had a bug in the IPR SCSI driver, where it would end up
making the SCSI mid layer run the mq hardware queue with interrupts
disabled. This isn't legal, since the software queue locking relies
on never being grabbed from interrupt context. Additionally, drivers
that set BLK_MQ_F_BLOCKING may schedule from this context.
Add a WARN_ON_ONCE() to catch bad users up front.
We know we're in process context, so don't bother using the
IRQ safe versions of the spin lock.
Pull more block updates from Jens Axboe:
"This is a followup for block changes, that didn't make the initial
pull request. It's a bit of a mixed bag, this contains:
- A followup pull request from Sagi for NVMe. Outside of fixups for
NVMe, it also includes a series for ensuring that we properly
quiesce hardware queues when browsing live tags.
- Set of integrity fixes from Dmitry (mostly), fixing various issues
for folks using DIF/DIX.
- Fix for a bug introduced in cciss, with the req init changes. From
Christoph.
- Fix for a bug in BFQ, from Paolo.
- Two followup fixes for lightnvm/pblk from Javier.
- Depth fix from Ming for blk-mq-sched.
- Also from Ming, performance fix for mtip32xx that was introduced
with the dynamic initialization of commands"
* 'for-linus' of git://git.kernel.dk/linux-block: (44 commits)
block: call bio_uninit in bio_endio
nvmet: avoid unneeded assignment of submit_bio return value
nvme-pci: add module parameter for io queue depth
nvme-pci: compile warnings in nvme_alloc_host_mem()
nvmet_fc: Accept variable pad lengths on Create Association LS
nvme_fc/nvmet_fc: revise Create Association descriptor length
lightnvm: pblk: remove unnecessary checks
lightnvm: pblk: control I/O flow also on tear down
cciss: initialize struct scsi_req
null_blk: fix error flow for shared tags during module_init
block: Fix __blkdev_issue_zeroout loop
nvme-rdma: unconditionally recycle the request mr
nvme: split nvme_uninit_ctrl into stop and uninit
virtio_blk: quiesce/unquiesce live IO when entering PM states
mtip32xx: quiesce request queues to make sure no submissions are inflight
nbd: quiesce request queues to make sure no submissions are inflight
nvme: kick requeue list when requeueing a request instead of when starting the queues
nvme-pci: quiesce/unquiesce admin_q instead of start/stop its hw queues
nvme-loop: quiesce/unquiesce admin_q instead of start/stop its hw queues
nvme-fc: quiesce/unquiesce admin_q instead of start/stop its hw queues
Pull irq updates from Thomas Gleixner:
"The irq department delivers:
- Expand the generic infrastructure handling the irq migration on CPU
hotplug and convert X86 over to it. (Thomas Gleixner)
Aside of consolidating code this is a preparatory change for:
- Finalizing the affinity management for multi-queue devices. The
main change here is to shut down interrupts which are affine to a
outgoing CPU and reenabling them when the CPU comes online again.
That avoids moving interrupts pointlessly around and breaking and
reestablishing affinities for no value. (Christoph Hellwig)
Note: This contains also the BLOCK-MQ and NVME changes which depend
on the rework of the irq core infrastructure. Jens acked them and
agreed that they should go with the irq changes.
- Consolidation of irq domain code (Marc Zyngier)
- State tracking consolidation in the core code (Jeffy Chen)
- Add debug infrastructure for hierarchical irq domains (Thomas
Gleixner)
- Infrastructure enhancement for managing generic interrupt chips via
devmem (Bartosz Golaszewski)
- Constification work all over the place (Tobias Klauser)
- Two new interrupt controller drivers for MVEBU (Thomas Petazzoni)
- The usual set of fixes, updates and enhancements all over the
place"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (112 commits)
irqchip/or1k-pic: Fix interrupt acknowledgement
irqchip/irq-mvebu-gicp: Allocate enough memory for spi_bitmap
irqchip/gic-v3: Fix out-of-bound access in gic_set_affinity
nvme: Allocate queues for all possible CPUs
blk-mq: Create hctx for each present CPU
blk-mq: Include all present CPUs in the default queue mapping
genirq: Avoid unnecessary low level irq function calls
genirq: Set irq masked state when initializing irq_desc
genirq/timings: Add infrastructure for estimating the next interrupt arrival time
genirq/timings: Add infrastructure to track the interrupt timings
genirq/debugfs: Remove pointless NULL pointer check
irqchip/gic-v3-its: Don't assume GICv3 hardware supports 16bit INTID
irqchip/gic-v3-its: Add ACPI NUMA node mapping
irqchip/gic-v3-its-platform-msi: Make of_device_ids const
irqchip/gic-v3-its: Make of_device_ids const
irqchip/irq-mvebu-icu: Add new driver for Marvell ICU
irqchip/irq-mvebu-gicp: Add new driver for Marvell GICP
dt-bindings/interrupt-controller: Add DT binding for the Marvell ICU
genirq/irqdomain: Remove auto-recursive hierarchy support
irqchip/MSI: Use irq_domain_update_bus_token instead of an open coded access
Currently all integrity prep hooks are open-coded, and if prepare fails
we ignore it's code and fail bio with EIO. Let's return real error to
upper layer, so later caller may react accordingly.
In fact no one want to use bio_integrity_prep() w/o bio_integrity_enabled,
so it is reasonable to fold it in to one function.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
[hch: merged with the latest block tree,
return bool from bio_integrity_prep]
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Add the SYSTEM_SCHEDULING bootup state to move various scheduler
debug checks earlier into the bootup. This turns silent and
sporadically deadly bugs into nice, deterministic splats. Fix some
of the splats that triggered. (Thomas Gleixner)
- A round of restructuring and refactoring of the load-balancing and
topology code (Peter Zijlstra)
- Another round of consolidating ~20 of incremental scheduler code
history: this time in terms of wait-queue nomenclature. (I didn't
get much feedback on these renaming patches, and we can still
easily change any names I might have misplaced, so if anyone hates
a new name, please holler and I'll fix it.) (Ingo Molnar)
- sched/numa improvements, fixes and updates (Rik van Riel)
- Another round of x86/tsc scheduler clock code improvements, in hope
of making it more robust (Peter Zijlstra)
- Improve NOHZ behavior (Frederic Weisbecker)
- Deadline scheduler improvements and fixes (Luca Abeni, Daniel
Bristot de Oliveira)
- Simplify and optimize the topology setup code (Lauro Ramos
Venancio)
- Debloat and decouple scheduler code some more (Nicolas Pitre)
- Simplify code by making better use of llist primitives (Byungchul
Park)
- ... plus other fixes and improvements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (103 commits)
sched/cputime: Refactor the cputime_adjust() code
sched/debug: Expose the number of RT/DL tasks that can migrate
sched/numa: Hide numa_wake_affine() from UP build
sched/fair: Remove effective_load()
sched/numa: Implement NUMA node level wake_affine()
sched/fair: Simplify wake_affine() for the single socket case
sched/numa: Override part of migrate_degrades_locality() when idle balancing
sched/rt: Move RT related code from sched/core.c to sched/rt.c
sched/deadline: Move DL related code from sched/core.c to sched/deadline.c
sched/cpuset: Only offer CONFIG_CPUSETS if SMP is enabled
sched/fair: Spare idle load balancing on nohz_full CPUs
nohz: Move idle balancer registration to the idle path
sched/loadavg: Generalize "_idle" naming to "_nohz"
sched/core: Drop the unused try_get_task_struct() helper function
sched/fair: WARN() and refuse to set buddy when !se->on_rq
sched/debug: Fix SCHED_WARN_ON() to return a value on !CONFIG_SCHED_DEBUG as well
sched/wait: Disambiguate wq_entry->task_list and wq_head->task_list naming
sched/wait: Move bit_wait_table[] and related functionality from sched/core.c to sched/wait_bit.c
sched/wait: Split out the wait_bit*() APIs from <linux/wait.h> into <linux/wait_bit.h>
sched/wait: Re-adjust macro line continuation backslashes in <linux/wait.h>
Currently we only create hctx for online CPUs, which can lead to a lot
of churn due to frequent soft offline / online operations. Instead
allocate one for each present CPU to avoid this and dramatically simplify
the code.
Reviewed-by: Jens Axboe <axboe@kernel.dk>
Cc: Keith Busch <keith.busch@intel.com>
Cc: linux-nvme@lists.infradead.org
Link: http://lkml.kernel.org/r/20170626102058.10200-3-hch@lst.de
For historical reasons we default to bouncing highmem pages for all block
queues. But the blk-mq drivers are easy to audit to ensure that we don't
need this - scsi and mtip32xx set explicit limits and everyone else doesn't
have any particular ones.
We only call blk_queue_bounce for request-based drivers, so stop messing
with it for make_request based drivers.
Pull in the fix for shared tags, as it conflicts with the pending
changes in for-4.13/block. We already pulled in v4.12-rc5 to solve
other conflicts or get fixes that went into 4.12, so not a lot
of changes in this merge.
hwctx's queue_num has been set prior call blk_mq_init_hctx, so no need
set it again.
Signed-off-by: weiping <zhangweiping@didichuxing.com>
Since blk_mq_quiesce_queue_nowait() can be called from interrupt
context, make this safe. Since this function is not in the hot
path, uninline it.
Fixes: commit f4560ffe8cec ("blk-mq: use QUEUE_FLAG_QUIESCED to quiesce queue")
Cc: Hannes Reinecke <hare@suse.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
If we have shared tags enabled, then every IO completion will trigger
a full loop of every queue belonging to a tag set, and every hardware
queue for each of those queues, even if nothing needs to be done.
This causes a massive performance regression if you have a lot of
shared devices.
Instead of doing this huge full scan on every IO, add an atomic
counter to the main queue that tracks how many hardware queues have
been marked as needing a restart. With that, we can avoid looking for
restartable queues, if we don't have to.
Max reports that this restores performance. Before this patch, 4K
IOPS was limited to 22-23K IOPS. With the patch, we are running at
950-970K IOPS.
Fixes: 6d8c6c0f97ad ("blk-mq: Restart a single queue if tag sets are shared")
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Tested-by: Bart Van Assche <bart.vanassche@wdc.com>
A queue must be frozen while the mapped state of a hardware queue
is changed. Additionally, any change of the mapped state is
followed by a call to blk_mq_map_swqueue() (see also
blk_mq_init_allocated_queue() and blk_mq_update_nr_hw_queues()).
Since blk_mq_map_swqueue() does not map any unmapped hardware
queue onto any software queue, no attempt will be made to run
an unmapped hardware queue. Hence issue a warning upon attempts
to run an unmapped hardware queue.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Document the locking assumptions in functions that modify
blk_mq_ctx.rq_list to make it easier for humans to verify
this code.
Initialization of blk-mq requests is a bit weird: blk_mq_rq_ctx_init()
is called after a value has been assigned to .rq_flags and .rq_flags
is initialized in __blk_mq_finish_request(). Initialize .rq_flags in
blk_mq_rq_ctx_init() instead of relying on __blk_mq_finish_request().
Moving the initialization of .rq_flags is fine because all changes
and tests of .rq_flags occur between blk_get_request() and finishing
a request.
Instead of declaring the second argument of blk_*_get_request()
as int and passing it to functions that expect an unsigned int,
declare that second argument as unsigned int. Also because of
consistency, rename that second argument from 'rw' into 'op'.
This patch does not change any functionality.
Since the srcu structure is rather large (184 bytes on an x86-64
system with kernel debugging disabled), only allocate it if needed.
Reported-by: Ming Lei <ming.lei@redhat.com>
A new bio operation flag REQ_NOWAIT is introduced to identify bio's
orignating from iocb with IOCB_NOWAIT. This flag indicates
to return immediately if a request cannot be made instead
of retrying.
Stacked devices such as md (the ones with make_request_fn hooks)
currently are not supported because it may block for housekeeping.
For example, an md can have a part of the device suspended.
For this reason, only request based devices are supported.
In the future, this feature will be expanded to stacked devices
by teaching them how to handle the REQ_NOWAIT flags.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
So I've noticed a number of instances where it was not obvious from the
code whether ->task_list was for a wait-queue head or a wait-queue entry.
Furthermore, there's a number of wait-queue users where the lists are
not for 'tasks' but other entities (poll tables, etc.), in which case
the 'task_list' name is actively confusing.
To clear this all up, name the wait-queue head and entry list structure
fields unambiguously:
struct wait_queue_head::task_list => ::head
struct wait_queue_entry::task_list => ::entry
For example, this code:
rqw->wait.task_list.next != &wait->task_list
... is was pretty unclear (to me) what it's doing, while now it's written this way:
rqw->wait.head.next != &wait->entry
... which makes it pretty clear that we are iterating a list until we see the head.
Other examples are:
list_for_each_entry_safe(pos, next, &x->task_list, task_list) {
list_for_each_entry(wq, &fence->wait.task_list, task_list) {
... where it's unclear (to me) what we are iterating, and during review it's
hard to tell whether it's trying to walk a wait-queue entry (which would be
a bug), while now it's written as:
list_for_each_entry_safe(pos, next, &x->head, entry) {
list_for_each_entry(wq, &fence->wait.head, entry) {
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
This patch reverts commit 2719aa217e0d02(blk-mq: don't use
sync workqueue flushing from drivers) because only
blk_mq_quiesce_queue() need the sync flush, and now
we don't need to stop queue any more, so revert it.
Also changes to cancel_delayed_work() in blk_mq_stop_hw_queue().
Reviewed-by: Bart Van Assche <Bart.VanAssche@sandisk.com>
BLK_MQ_S_STOPPED may not be observed in other concurrent I/O paths,
we can't guarantee that dispatching won't happen after returning
from the APIs of stopping queue.
So clarify the fact and avoid potential misuse.
Queue can be started by other blk-mq APIs and can be used in
different cases, this limits uses of blk_mq_quiesce_queue()
if it is based on stopping queue, and make its usage very
difficult, especially users have to use the stop queue APIs
carefully for avoiding to break blk_mq_quiesce_queue().
We have applied the QUIESCED flag for draining and blocking
dispatch, so it isn't necessary to stop queue any more.
After stopping queue is removed, blk_mq_quiesce_queue() can
be used safely and easily, then users won't worry about queue
restarting during quiescing at all.
Actually what we want to get from blk_mq_quiesce_queue()
isn't only to wait for completion of all ongoing .queue_rq().
In the typical context of canceling requests, we need to
make sure that the following is done in the dispatch path
before starting to cancel requests:
- failed dispatched request is finished
- busy dispatched request is requeued, and the STARTED
flag is cleared
So update comment to keep code, doc and our expection consistent.
It is required that no dispatch can happen any more once
blk_mq_quiesce_queue() returns, and we don't have such requirement
on APIs of stopping queue.
But blk_mq_quiesce_queue() still may not block/drain dispatch in the
the case of BLK_MQ_S_START_ON_RUN, so use the new introduced flag of
QUEUE_FLAG_QUIESCED and evaluate it inside RCU read-side critical
sections for fixing this issue.
Also blk_mq_quiesce_queue() is implemented via stopping queue, which
limits its uses, and easy to cause race, because any queue restart in
other paths may break blk_mq_quiesce_queue(). With the introduced
flag of QUEUE_FLAG_QUIESCED, we don't need to depend on stopping queue
for quiescing any more.
blk_mq_start_stopped_hw_queues() is used implictly
as counterpart of blk_mq_quiesce_queue() for unquiescing queue,
so we introduce blk_mq_unquiesce_queue() and make it
as counterpart of blk_mq_quiesce_queue() explicitly.
This function is for improving the current quiescing mechanism
in the following patches.
