commit b8839b8c55f3fdd60dc36abcda7e0266aff7985c upstream.
The math in both blk_stack_limits() and queue_limit_alignment_offset()
assume that a block device's io_min (aka minimum_io_size) is always a
power-of-2. Fix the math such that it works for non-power-of-2 io_min.
This issue (of alignment_offset != 0) became apparent when testing
dm-thinp with a thinp blocksize that matches a RAID6 stripesize of
1280K. Commit fdfb4c8c1 ("dm thin: set minimum_io_size to pool's data
block size") unlocked the potential for alignment_offset != 0 due to
the dm-thin-pool's io_min possibly being a non-power-of-2.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Now that we've got code for raid5/6 stripe awareness, bcache just needs
to know about the stripes and when writing partial stripes is expensive
- we probably don't want to enable this optimization for raid1 or 10,
even though they have stripes. So add a flag to queue_limits.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Pull block IO core updates from Jens Axboe:
"This is the pull request for the core changes in the block layer for
3.13. It contains:
- The new blk-mq request interface.
This is a new and more scalable queueing model that marries the
best part of the request based interface we currently have (which
is fully featured, but scales poorly) and the bio based "interface"
which the new drivers for high IOPS devices end up using because
it's much faster than the request based one.
The bio interface has no block layer support, since it taps into
the stack much earlier. This means that drivers end up having to
implement a lot of functionality on their own, like tagging,
timeout handling, requeue, etc. The blk-mq interface provides all
these. Some drivers even provide a switch to select bio or rq and
has code to handle both, since things like merging only works in
the rq model and hence is faster for some workloads. This is a
huge mess. Conversion of these drivers nets us a substantial code
reduction. Initial results on converting SCSI to this model even
shows an 8x improvement on single queue devices. So while the
model was intended to work on the newer multiqueue devices, it has
substantial improvements for "classic" hardware as well. This code
has gone through extensive testing and development, it's now ready
to go. A pull request is coming to convert virtio-blk to this
model will be will be coming as well, with more drivers scheduled
for 3.14 conversion.
- Two blktrace fixes from Jan and Chen Gang.
- A plug merge fix from Alireza Haghdoost.
- Conversion of __get_cpu_var() from Christoph Lameter.
- Fix for sector_div() with 64-bit divider from Geert Uytterhoeven.
- A fix for a race between request completion and the timeout
handling from Jeff Moyer. This is what caused the merge conflict
with blk-mq/core, in case you are looking at that.
- A dm stacking fix from Mike Snitzer.
- A code consolidation fix and duplicated code removal from Kent
Overstreet.
- A handful of block bug fixes from Mikulas Patocka, fixing a loop
crash and memory corruption on blk cg.
- Elevator switch bug fix from Tomoki Sekiyama.
A heads-up that I had to rebase this branch. Initially the immutable
bio_vecs had been queued up for inclusion, but a week later, it became
clear that it wasn't fully cooked yet. So the decision was made to
pull this out and postpone it until 3.14. It was a straight forward
rebase, just pruning out the immutable series and the later fixes of
problems with it. The rest of the patches applied directly and no
further changes were made"
* 'for-3.13/core' of git://git.kernel.dk/linux-block: (31 commits)
block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
block: Do not call sector_div() with a 64-bit divisor
kernel: trace: blktrace: remove redundent memcpy() in compat_blk_trace_setup()
block: Consolidate duplicated bio_trim() implementations
block: Use rw_copy_check_uvector()
block: Enable sysfs nomerge control for I/O requests in the plug list
block: properly stack underlying max_segment_size to DM device
elevator: acquire q->sysfs_lock in elevator_change()
elevator: Fix a race in elevator switching and md device initialization
block: Replace __get_cpu_var uses
bdi: test bdi_init failure
block: fix a probe argument to blk_register_region
loop: fix crash if blk_alloc_queue fails
blk-core: Fix memory corruption if blkcg_init_queue fails
block: fix race between request completion and timeout handling
blktrace: Send BLK_TN_PROCESS events to all running traces
blk-mq: don't disallow request merges for req->special being set
blk-mq: mq plug list breakage
blk-mq: fix for flush deadlock
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE
(65536) even if the underlying device(s) have a larger value -- this is
due to blk_stack_limits() using min_not_zero() when stacking the
max_segment_size limit.
1073741824
before patch:
65536
after patch:
1073741824
Reported-by: Lukasz Flis <l.flis@cyfronet.pl>
Cc: stable@vger.kernel.org # v3.3+
blk_queue_bounce_limit()
The blk_queue_bounce_limit() API parameter 'dma_mask' is actually the
maximum address the device can handle rather than a dma_mask. Rename
it accordingly to avoid it being interpreted as dma_mask.
No functional change.
The idea is to fix the bad assumptions about dma_mask wherever it could
be miss-interpreted.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
In MD raid case, discard granularity might not be power of 2, for example, a
4-disk raid5 has 3*chunk_size discard granularity. Correct the calculation for
such cases.
Reported-by: Neil Brown <neilb@suse.de>
Signed-off-by: Shaohua Li <shli@fusionio.com>
The WRITE SAME command supported on some SCSI devices allows the same
block to be efficiently replicated throughout a block range. Only a
single logical block is transferred from the host and the storage device
writes the same data to all blocks described by the I/O.
This patch implements support for WRITE SAME in the block layer. The
blkdev_issue_write_same() function can be used by filesystems and block
drivers to replicate a buffer across a block range. This can be used to
efficiently initialize software RAID devices, etc.
Acked-by: Mike Snitzer <snitzer@redhat.com>
blk_set_stacking_limits is intended to allow stacking drivers to build
up the limits of the stacked device based on the underlying devices'
limits. But defaulting 'max_sectors' to BLK_DEF_MAX_SECTORS (1024)
doesn't allow the stacking driver to inherit a max_sectors larger than
1024 -- due to blk_stack_limits' use of min_not_zero.
It is now clear that this artificial limit is getting in the way so
change blk_set_stacking_limits's max_sectors to UINT_MAX (which allows
stacking drivers like dm-multipath to inherit 'max_sectors' from the
underlying paths).
Reported-by: Vijay Chauhan <vijay.chauhan@netapp.com>
Tested-by: Vijay Chauhan <vijay.chauhan@netapp.com>
Stacking driver queue limits are typically bounded exclusively by the
capabilities of the low level devices, not by the stacking driver
itself.
This patch introduces blk_set_stacking_limits() which has more liberal
metrics than the default queue limits function. This allows us to
inherit topology parameters from bottom devices without manually
tweaking the default limits in each driver prior to calling the stacking
function.
Since there is now a clear distinction between stacking and low-level
devices, blk_set_default_limits() has been modified to carry the more
conservative values that we used to manually set in
blk_queue_make_request().
In some cases we would end up stacking discard_zeroes_data incorrectly.
Fix this by enabling the feature by default for stacking drivers and
clearing it for low-level drivers. Incorporating a device that does not
support dzd will then cause the feature to be disabled in the stacking
driver.
Also ensure that the maximum discard value does not overflow when
exported in sysfs and return 0 in the alignment and dzd fields for
devices that don't support discard.
Reported-by: Lukas Czerner <lczerner@redhat.com>
Cc: stable@kernel.org
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
flush request isn't queueable in some drives. Add a flag to let driver
notify block layer about this. We can optimize flush performance with the
knowledge.
Stable: 2.6.39 only
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Acked-by: Tejun Heo <tj@kernel.org>
MD can't use this since it really requires us to be able to
keep more than a single piece of state for the unplug. Commit
048c9374 added the required support for MD, so get rid of this
now unused code.
This reverts commit f75664570d8b75469cc468f23c2b27220984983b.
block/blk-core.c
MD would like to know when a queue is unplugged, so it can flush
it's bitmap writes. Add such a callback.
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
There does not seem to be a clear convention whether q->queue_lock is
initialized or not when blk_cleanup_queue() is called. In the past it
was not necessary but now blk_throtl_exit() takes up queue lock by
default and needs queue lock to be available.
In fact elevator_exit() code also has similar requirement just that it
is less stringent in the sense that elevator_exit() is called only if
elevator is initialized.
Two problems have been noticed because of ambiguity about spin lock
status.
- If a driver calls blk_alloc_queue() and then soon calls
blk_cleanup_queue() almost immediately, (because some other
driver structure allocation failed or some other error happened)
then blk_throtl_exit() will run into issues as queue lock is not
initialized. Loop driver ran into this issue recently and I
noticed error paths in md driver too. Similar error paths should
exist in other drivers too.
- If some driver provided external spin lock and zapped the lock
before blk_cleanup_queue(), then it can lead to issues.
So this patch initializes the default queue lock at queue allocation time.
block throttling code is one of the users of queue lock and it is
initialized at the queue allocation time, so it makes sense to
initialize ->queue_lock also to internal lock. A driver can overide that
lock later. This will take care of the issue where a driver does not have
to worry about initializing the queue lock to default before calling
blk_cleanup_queue()
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Implement blk_limits_max_hw_sectors() and make
blk_queue_max_hw_sectors() a wrapper around it.
DM needs this to avoid setting queue_limits' max_hw_sectors and
max_sectors directly. dm_set_device_limits() now leverages
blk_limits_max_hw_sectors() logic to establish the appropriate
max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was
incorrectly setting max_sectors rather than max_hw_sectors (which
caused dm_merge_bvec()'s max_hw_sectors check to be ineffective).
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
Physical block size was declared unsigned int to accomodate the maximum
size reported by READ CAPACITY(16). Make sure we use the right type in
the related functions.
The bounce_pfn of the request queue in 64 bit systems is set to the
current max_low_pfn. Adding more memory later makes this incorrect.
Memory allocated beyond this boot time max_low_pfn appear to require
bounce buffers (bounce buffers are actually not allocated but used in
calculating segments that may result in "over max segments limit"
errors).
Signed-off-by: Malahal Naineni <malahal@us.ibm.com>
Revert "block: set the bounce_pfn to the actual DMA limit rather than to max memory"
This reverts commit c49825facfd4969585224a896a5e717f88450cad.
errors).
Some controllers have a hardware limit on the number of protection
information scatter-gather list segments they can handle.
Introduce a max_integrity_segments limit in the block layer and provide
a new scsi_host_template setting that allows HBA drivers to provide a
value suitable for the hardware.
Add support for honoring the integrity segment limit when merging both
bios and requests.
Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
We have several users of min_not_zero, each of them using their own
definition. Move the define to kernel.h.
Barrier is deemed too heavy and will soon be replaced by FLUSH/FUA
requests. Deprecate barrier. All REQ_HARDBARRIERs are failed with
-EOPNOTSUPP and blk_queue_ordered() is replaced with simpler
blk_queue_flush().
blk_queue_flush() takes combinations of REQ_FLUSH and FUA. If a
device has write cache and can flush it, it should set REQ_FLUSH. If
the device can handle FUA writes, it should also set REQ_FUA.
All blk_queue_ordered() users are converted.
* ORDERED_DRAIN is mapped to 0 which is the default value.
* ORDERED_DRAIN_FLUSH is mapped to REQ_FLUSH.
* ORDERED_DRAIN_FLUSH_FUA is mapped to REQ_FLUSH | REQ_FUA.
Acked-by: Boaz Harrosh <bharrosh@panasas.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: Pierre Ossman <drzeus@drzeus.cx>
Cc: Stefan Weinhuber <wein@de.ibm.com>
Reviewed-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits)
cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch
loop: Update mtime when writing using aops
block: expose the statistics in blkio.time and blkio.sectors for the root cgroup
backing-dev: Handle class_create() failure
Block: Fix block/elevator.c elevator_get() off-by-one error
drbd: lc_element_by_index() never returns NULL
cciss: unlock on error path
cfq-iosched: Do not merge queues of BE and IDLE classes
cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging
i2o: Remove the dangerous kobj_to_i2o_device macro
block: remove 16 bytes of padding from struct request on 64bits
cfq-iosched: fix a kbuild regression
block: make CONFIG_BLK_CGROUP visible
Remove GENHD_FL_DRIVERFS
block: Export max number of segments and max segment size in sysfs
block: Finalize conversion of block limits functions
block: Fix overrun in lcm() and move it to lib
vfs: improve writeback_inodes_wb()
paride: fix off-by-one test
drbd: fix al-to-on-disk-bitmap for 4k logical_block_size
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
lcm() was defined to take integer-sized arguments. The supplied
arguments are multiplied, however, causing us to overflow given
sufficiently large input. That in turn led to incorrect optimal I/O
size reporting in some cases (RAID over RAID).
Switch lcm() over to unsigned long similar to gcd() and move the
function from blk-settings.c to lib.
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
Add a BLK_ prefix to block layer constants.
blk_queue_max_hw_sectors is no longer called by any subsystem and can be
removed.
Clarify blk_queue_max_sectors and update documentation.
All callers of the stacking functions use 512-byte sector units rather
than byte offsets. Simplify the code so the stacking functions take
sectors when specifying data offsets.
DM does not want to know about partition offsets. Add a partition-aware
wrapper that DM can use when stacking block devices.
Reviewed-by: Alasdair G Kergon <agk@redhat.com>
The top device misalignment flag would not be set if the added bottom
device was already misaligned as opposed to causing a stacking failure.
Also massage the reporting so that an error is only returned if adding
the bottom device caused the misalignment. I.e. don't return an error
if the top is already flagged as misaligned.
queue_sector_alignment_offset returned the wrong value which caused
partitions to report an incorrect alignment_offset. Since offset
alignment calculation is needed several places it has been split into a
separate helper function. The topology stacking function has been
updated accordingly.
Furthermore, comments have been added to clarify how the stacking
function works.
Tested-by: Mike Snitzer <snitzer@redhat.com>
The stacking code incorrectly scaled up the data offset in some cases
causing misaligned devices to report alignment. Rewrite the stacking
algorithm to remedy this and apply the same alignment principles to the
discard handling.
Commit 86b37281411cf1e9bc0a6b5406c45edb7bd9ea5d adds a check for
misaligned stacking offsets, but it's buggy since the defaults are 0.
Hence all dm devices that pass in a non-zero starting offset will
be marked as misaligned amd dm will complain.
A real fix is coming, in the mean time disable the discard granularity
check so that users don't worry about dm reporting about misaligned
devices.
The discard ioctl is used by mkfs utilities to clear a block device
prior to putting metadata down. However, not all devices return zeroed
blocks after a discard. Some drives return stale data, potentially
containing old superblocks. It is therefore important to know whether
discarded blocks are properly zeroed.
Both ATA and SCSI drives have configuration bits that indicate whether
zeroes are returned after a discard operation. Implement a block level
interface that allows this information to be bubbled up the stack and
queried via a new block device ioctl.
Use HZ-independent calculation of milliseconds.
Add jiffies.h where it was missing since functions or macros
from it are used.
While SSDs track block usage on a per-sector basis, RAID arrays often
have allocation blocks that are bigger. Allow the discard granularity
and alignment to be set and teach the topology stacking logic how to
handle them.
Fix kernel-doc notation in blk-settings.c::blk_queue_max_discard_sectors().
Currently we set the bio size to the byte equivalent of the blocks to
be trimmed when submitting the initial DISCARD ioctl. That means it
is subject to the max_hw_sectors limitation of the HBA which is
much lower than the size of a DISCARD request we can support.
Add a separate max_discard_sectors tunable to limit the size for discard
requests.
We limit the max discard request size in bytes to 32bit as that is the
limit for bio->bi_size. This could be much larger if we had a way to pass
that information through the block layer.
prepare_discard_fn() was being called in a place where memory allocation
was effectively impossible. This makes it inappropriate for all but
the most trivial translations of Linux's DISCARD operation to the block
command set. Additionally adding a payload there makes the ownership
of the bio backing unclear as it's now allocated by the device driver
and not the submitter as usual.
It is replaced with QUEUE_FLAG_DISCARD which is used to indicate whether
the queue supports discard operations or not. blkdev_issue_discard now
allocates a one-page, sector-length payload which is the right thing
for the common ATA and SCSI implementations.
The mtd implementation of prepare_discard_fn() is replaced with simply
checking for the request being a discard.
Largely based on a previous patch from Matthew Wilcox <matthew@wil.cx>
which did the prepare_discard_fn but not the different payload allocation
yet.
Stacking devices do not have an inherent max_hw_sector limit. Set the
default to INT_MAX so we are bounded only by capabilities of the
underlying storage.
The topology changes unintentionally caused SAFE_MAX_SECTORS to be set
for stacking devices. Set the default limit to BLK_DEF_MAX_SECTORS and
provide SAFE_MAX_SECTORS in blk_queue_make_request() for legacy hw
drivers that depend on the old behavior.
Implement blk_limits_io_opt() and make blk_queue_io_opt() a wrapper
around it. DM needs this to avoid poking at the queue_limits directly.
