path: root/block/bsg-lib.c
2011-08-02bsg-lib: add module.h includeJens Axboe
Due to conflicts with the moduleh tree in linux-next, we run into an include file mess. We really need export.h in that tree, but if we add module.h locally then the issue is easier to resolve. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-31block: add bsg helper libraryMike Christie
This moves the FC classes bsg code to the block layer and makes it a lib so that other classes like iscsi and SAS can use it. It is helpful because working with the request queue, bios, creating scatterlists, etc are a pain that the LLD does not have to worry about with normal IOs and should not have to worry about for bsg requests. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
