path: root/block/bsg.c
2012-03-12bsg: fix sysfs link remove warningStanislaw Gruszka
commit 37b40adf2d1b4a5e51323be73ccf8ddcf3f15dd3 upstream. We create "bsg" link if q->kobj.sd is not NULL, so remove it only when the same condition is true. Fixes: WARNING: at fs/sysfs/inode.c:323 sysfs_hash_and_remove+0x2b/0x77() sysfs: can not remove 'bsg', no directory Call Trace: [<c0429683>] warn_slowpath_common+0x6a/0x7f [<c0537a68>] ? sysfs_hash_and_remove+0x2b/0x77 [<c042970b>] warn_slowpath_fmt+0x2b/0x2f [<c0537a68>] sysfs_hash_and_remove+0x2b/0x77 [<c053969a>] sysfs_remove_link+0x20/0x23 [<c05d88f1>] bsg_unregister_queue+0x40/0x6d [<c0692263>] __scsi_remove_device+0x31/0x9d [<c069149f>] scsi_forget_host+0x41/0x52 [<c0689fa9>] scsi_remove_host+0x71/0xe0 [<f7de5945>] quiesce_and_remove_host+0x51/0x83 [usb_storage] [<f7de5a1e>] usb_stor_disconnect+0x18/0x22 [usb_storage] [<c06c29de>] usb_unbind_interface+0x4e/0x109 [<c067a80f>] __device_release_driver+0x6b/0xa6 [<c067a861>] device_release_driver+0x17/0x22 [<c067a46a>] bus_remove_device+0xd6/0xe6 [<c06785e2>] device_del+0xf2/0x137 [<c06c101f>] usb_disable_device+0x94/0x1a0 Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-12-09[SCSI] bsg: correct fault if queue object removed while dev_t openJames Smart
This patch corrects an issue in bsg that results in a general protection fault if an LLD is removed while an application is using an open file handle to a bsg device, and the application issues an ioctl. The fault occurs because the class_dev is NULL, having been cleared in bsg_unregister_queue() when the driver was removed. With this patch, a check is made for the class_dev, and the application will receive ENXIO if the related object is gone. Signed-off-by: Carl Lajeunesse <carl.lajeunesse@emulex.com> Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: block: autoconvert trivial BKL users to private mutex drivers: autoconvert trivial BKL users to private mutex ipmi: autoconvert trivial BKL users to private mutex mac: autoconvert trivial BKL users to private mutex mtd: autoconvert trivial BKL users to private mutex scsi: autoconvert trivial BKL users to private mutex Fix up trivial conflicts (due to addition of private mutex right next to deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
2010-10-15[SCSI] bsg: fix incorrect device_status valueFUJITA Tomonori
bsg incorrectly returns sg's masked_status value for device_status. [jejb: fix up expression logic] Reported-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-11block: jiffies fixesRandy Dunlap
Use HZ-independent calculation of milliseconds. Add jiffies.h where it was missing since functions or macros from it are used. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-01block: get rid of queue-private command filterJens Axboe
The initial patches to support this through sysfs export were broken and have been if 0'ed out in any release. So lets just kill the code and reclaim some space in struct request_queue, if anyone would later like to fixup the sysfs bits, the git history can easily restore the removed bits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-21block: revert "bsg: setting rq->bio to NULL"FUJITA Tomonori
The SMP handler (sas_smp_request) was fixed to use the block API properly, so we don't need this workaround to avoid blk_put_request() warning. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15Driver Core: bsg: add nodename for bsg driverKay Sievers
This adds support to the BSG driver to report the proper device name to userspace for the bsg devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-09bsg: setting rq->bio to NULLFUJITA Tomonori
Due to commit 1cd96c242a829d52f7a5ae98f554ca9775429685 ("block: WARN in __blk_put_request() for potential bio leak"), BSG SMP requests get the false warnings: WARNING: at block/blk-core.c:1068 __blk_put_request+0x52/0xc0() This sets rq->bio to NULL to avoid that false warnings. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: add rq->resid_lenTejun Heo
rq->data_len served two purposes - the length of data buffer on issue and the residual count on completion. This duality creates some headaches. First of all, block layer and low level drivers can't really determine what rq->data_len contains while a request is executing. It could be the total request length or it coulde be anything else one of the lower layers is using to keep track of residual count. This complicates things because blk_rq_bytes() and thus [__]blk_end_request_all() relies on rq->data_len for PC commands. Drivers which want to report residual count should first cache the total request length, update rq->data_len and then complete the request with the cached data length. Secondly, it makes requests default to reporting full residual count, ie. reporting that no data transfer occurred. The residual count is an exception not the norm; however, the driver should clear rq->data_len to zero to signify the normal cases while leaving it alone means no data transfer occurred at all. This reverse default behavior complicates code unnecessarily and renders block PC on some drivers (ide-tape/floppy) unuseable. This patch adds rq->resid_len which is used only for residual count. While at it, remove now unnecessasry blk_rq_bytes() caching in ide_pc_intr() as rq->data_len is not changed anymore. Boaz : spotted missing conversion in osd Sergei : spotted too early conversion to blk_rq_bytes() in ide-tape [ Impact: cleanup residual count handling, report 0 resid by default ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26bsg: Remove bogus check against request_queue->max_sectorsBoaz Harrosh
bsg submits REQ_TYPE_BLOCK_PC so the right check is max_hw_sectors. But I've removed this check because right after, bsg proceeds with calling blk_rq_map_user() which does all the right checks. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24bsg: add support for tail queuingBoaz Harrosh
Currently inherited from sg.c bsg will submit asynchronous request at the head-of-the-queue, (using "at_head" set in the call to blk_execute_rq_nowait()). This is bad in situation where the queues are full, requests will execute out of order, and can cause starvation of the first submitted requests. The sg_io_v4->flags member is used and a bit is allocated to denote the Q_AT_TAIL. Zero is to queue at_head as before, to be compatible with old code at the write/read path. SG_IO code path behavior was changed so to be the same as write/read behavior. SG_IO was very rarely used and breaking compatibility with it is OK at this stage. sg_io_hdr at sg.h also has a flags member and uses 3 bits from the first nibble and one bit from the last nibble. Even though none of these bits are supported by bsg, The second nibble is allocated for use by bsg. Just in case. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-18bsg: Fix sense buffer bug in SG_IOBoaz Harrosh
When submitting requests via SG_IO, which does a sync io, a bsg_command is not allocated. So an in-Kernel sense_buffer was not set. However when calling blk_execute_rq() with no sense buffer one is provided from the stack. Now bsg at blk_complete_sgv4_hdr_rq() would check if rq->sense_len and a sense was requested by sg_io_v4 the rq->sense was copy_user() back, but by now it is already mangled stack memory. I have fixed that by forcing a sense_buffer when calling bsg_map_hdr(). The bsg_command->sense is provided in the write/read path like before, and on-the-stack buffer is provided when doing SG_IO. I have also fixed a dprintk message to print rq->errors in hex because of the scsi bit-field use of this member. For other block devices it does not matter anyway. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-06block: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05Enforce a minimum SG_IO timeoutLinus Torvalds
There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-16device create: block: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: move cmdfilter from gendisk to request_queueFUJITA Tomonori
cmd_filter works only for the block layer SG_IO with SCSI block devices. It breaks scsi/sg.c, bsg, and the block layer SG_IO with SCSI character devices (such as st). We hit a kernel crash with them. The problem is that cmd_filter code accesses to gendisk (having struct blk_scsi_cmd_filter) via inode->i_bdev->bd_disk. It works for only SCSI block device files. With character device files, inode->i_bdev leads you to struct cdev. inode->i_bdev->bd_disk->blk_scsi_cmd_filter isn't safe. SCSI ULDs don't expose gendisk; they keep it private. bsg needs to be independent on any protocols. We shouldn't change ULDs to expose their gendisk. This patch moves struct blk_scsi_cmd_filter from gendisk to request_queue, a common object, which eveyone can access to. The user interface doesn't change; users can change the filters via /sys/block/. gendisk has a pointer to request_queue so the cmd_filter code accesses to struct blk_scsi_cmd_filter. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-21device create: block: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits) [SCSI] scsi_dh: fix kconfig related build errors [SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of [SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h [SCSI] make struct scsi_{host,target}_type static [SCSI] fix locking in host use of blk_plug_device() [SCSI] zfcp: Cleanup external header file [SCSI] zfcp: Cleanup code in zfcp_erp.c [SCSI] zfcp: zfcp_fsf cleanup. [SCSI] zfcp: consolidate sysfs things into one file. [SCSI] zfcp: Cleanup of code in zfcp_aux.c [SCSI] zfcp: Cleanup of code in zfcp_scsi.c [SCSI] zfcp: Move status accessors from zfcp to SCSI include file. [SCSI] zfcp: Small QDIO cleanups [SCSI] zfcp: Adapter reopen for large number of unsolicited status [SCSI] zfcp: Fix error checking for ELS ADISC requests [SCSI] zfcp: wait until adapter is finished with ERP during auto-port [SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver [SCSI] sg: Add target reset support [SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC [SCSI] sd: Move scsi_disk() accessor function to sd.h ...
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-14Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (37 commits) splice: fix generic_file_splice_read() race with page invalidation ramfs: enable splice write drivers/block/pktcdvd.c: avoid useless memset cdrom: revert commit 22a9189 (cdrom: use kmalloced buffers instead of buffers on stack) scsi: sr avoids useless buffer allocation block: blk_rq_map_kern uses the bounce buffers for stack buffers block: add blk_queue_update_dma_pad DAC960: push down BKL pktcdvd: push BKL down into driver paride: push ioctl down into driver block: use get_unaligned_* helpers block: extend queue_flag bitops block: request_module(): use format string Add bvec_merge_data to handle stacked devices and ->merge_bvec() block: integrity flags can't use bit ops on unsigned short cmdfilter: extend default read filter sg: fix odd style (extra parenthesis) introduced by cmd filter patch block: add bounce support to blk_rq_map_user_iov cfq-iosched: get rid of enable_idle being unused warning allow userspace to modify scsi command filter on per device basis ...
2008-07-12[SCSI] bsg: fix oops on removeJames Bottomley
If you do a modremove of any sas driver, you run into an oops on shutdown when the host is removed (coming from the host bsg device). The root cause seems to be that there's a use after free of the bsg_class_device: In bsg_kref_release_function, this is used (to do a put_device(bcg->parent) after bcg->release has been called. In sas (and possibly many other things) bcd->release frees the queue which contains the bsg_class_device, so we get a put_device on unreferenced memory. Fix this by taking a copy of the pointer to the parent before releasing bsg. Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] bsg: fix bsg_mutex hang with device removalFUJITA Tomonori
We don't need to hold bsg_mutex during bsg_complete_all_commands(). It leads to a problem that we block bsg_unregister_queue during bsg_complete_all_commands (untill all the outstanding commands complete). Thanks to Pete Wyckoff for finding the bug and testing the patch. The detailed bug report is: http://marc.info/?l=linux-scsi&m=121182137132145&w=2 Tested-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-03allow userspace to modify scsi command filter on per device basisAdel Gadllah
This patch exports the per-gendisk command filter to user space through sysfs, so it can be changed by the system administrator. All users of the old cmd filter have been converted to use the new one. Original patch from Peter Jones. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Signed-off-by: Peter Jones <pjones@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-18bsg: cdev lock_kernel() pushdownJonathan Corbet
Push the cdev lock_kernel call into bsg_open(). Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] bsg: add large command supportFUJITA Tomonori
This enables bsg to handle the request length larger than BLK_MAX_CDB (mainly for the variable length CDB format). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-01block: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[SCSI] bsg: add release callback supportFUJITA Tomonori
This patch adds release callback support, which is called when a bsg device goes away. bsg_register_queue() takes a pointer to a callback function. This feature is useful for stuff like sas_host that can't use the release callback in struct device. If a caller doesn't need bsg's release callback, it can call bsg_register_queue() with NULL pointer (e.g. scsi devices can use release callback in struct device so they don't need bsg's callback). With this patch, bsg uses kref for refcounts on bsg devices instead of get/put_device in fops->open/release. bsg calls put_device and the caller's release callback (if it was registered) in kref_put's release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18[SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commandsFUJITA Tomonori
Before bsg_complete_all_commands is called, BSG_F_BLOCK bit is always set. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: remove minor in struct bsg_deviceFUJITA Tomonori
minor in struct bsg_device is used as identifier to find the corresponding struct bsg_device_class. However, request_queuse can be used as identifier for that and the minor in struct bsg_device is unnecessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: use better helper list functionsFUJITA Tomonori
This replace hlist_for_each and list_entry with hlist_for_each_entry and list_first_entry respectively. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: replace kobject_get with blk_get_queueFUJITA Tomonori
Both takes a ref to a queue. But blk_get_queue checks QUEUE_FLAG_DEAD and is more appropriate interface here. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: takes a ref to struct device in fops->openFUJITA Tomonori
bsg_register_queue() takes a ref to struct device that a caller passes. For example, bsg takes a ref to the sdev_gendev for scsi devices. However, bsg doesn't inrease the refcount in fops->open. So while an application opens a bsg device, the scsi device that the bsg device holds can go away (bsg also takes a ref to a queue, but it doesn't prevent the device from going away). With this patch, bsg increases the refcount of struct device in fops->open and decreases it in fops->release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-04block: restore the meaning of rq->data_len to the true data lengthFUJITA Tomonori
The meaning of rq->data_len was changed to the length of an allocated buffer from the true data length. It breaks SG_IO friends and bsg. This patch restores the meaning of rq->data_len to the true data length and adds rq->extra_len to store an extended length (due to drain buffer and padding). This patch also removes the code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa. The commit adjusts bio according to memory alignment (queue_dma_alignment). However, memory alignment is NOT padding alignment. This adjustment also breaks SG_IO friends and bsg. Padding alignment needs to be fixed in a proper way (by a separate patch). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19block: add request->raw_data_lenTejun Heo
With padding and draining moved into it, block layer now may extend requests as directed by queue parameters, so now a request has two sizes - the original request size and the extended size which matches the size of area pointed to by bios and later by sgs. The latter size is what lower layers are primarily interested in when allocating, filling up DMA tables and setting up the controller. Both padding and draining extend the data area to accomodate controller characteristics. As any controller which speaks SCSI can handle underflows, feeding larger data area is safe. So, this patch makes the primary data length field, request->data_len, indicate the size of full data area and add a separate length field, request->raw_data_len, for the unmodified request size. The latter is used to report to higher layer (userland) and where the original request size should be fed to the controller or device. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-30[SCSI] bsg: copy the cmd_type field to the subordinate request for bidiJames Bottomley
This fixes a problem in SCSI where we use the (previously uninitialised) cmd_type via blk_pc_request() to set up the transfer in scsi_init_sgtable(). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
