path: root/block/cfq-iosched.c
2013-10-01cfq: explicitly use 64bit divide operation for 64bit argumentsAnatol Pomozov
commit f3cff25f05f2ac29b2ee355e611b0657482f6f1d upstream. 'samples' is 64bit operant, but do_div() second parameter is 32. do_div silently truncates high 32 bits and calculated result is invalid. In case if low 32bit of 'samples' are zeros then do_div() produces kernel crash. Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Jonghwan Choi <jhbird.choi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20elevator: Fix a race in elevator switchingJianpeng Ma
commit d50235b7bc3ee0a0427984d763ea7534149531b4 upstream. There's a race between elevator switching and normal io operation. Because the allocation of struct elevator_queue and struct elevator_data don't in a atomic operation.So there are have chance to use NULL ->elevator_data. For example: Thread A: Thread B blk_queu_bio elevator_switch spin_lock_irq(q->queue_block) elevator_alloc elv_merge elevator_init_fn Because call elevator_alloc, it can't hold queue_lock and the ->elevator_data is NULL.So at the same time, threadA call elv_merge and nedd some info of elevator_data.So the crash happened. Move the elevator_alloc into func elevator_init_fn, it make the operations in a atomic operation. Using the follow method can easy reproduce this bug 1:dd if=/dev/sdb of=/dev/null 2:while true;do echo noop > scheduler;echo deadline > scheduler;done The test method also use this method. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-23block: Add bio_end_sector()Kent Overstreet
Just a little convenience macro - main reason to add it now is preparing for immutable bio vecs, it'll reduce the size of the patch that puts bi_sector/bi_size/bi_idx into a struct bvec_iter. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: Lars Ellenberg <drbd-dev@lists.linbit.com> CC: Jiri Kosina <jkosina@suse.cz> CC: Alasdair Kergon <agk@redhat.com> CC: dm-devel@redhat.com CC: Neil Brown <neilb@suse.de> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: linux-s390@vger.kernel.org CC: Chris Mason <chris.mason@fusionio.com> CC: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com>
2013-02-28Merge branch 'for-3.9/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO core bits from Jens Axboe: "Below are the core block IO bits for 3.9. It was delayed a few days since my workstation kept crashing every 2-8h after pulling it into current -git, but turns out it is a bug in the new pstate code (divide by zero, will report separately). In any case, it contains: - The big cfq/blkcg update from Tejun and and Vivek. - Additional block and writeback tracepoints from Tejun. - Improvement of the should sort (based on queues) logic in the plug flushing. - _io() variants of the wait_for_completion() interface, using io_schedule() instead of schedule() to contribute to io wait properly. - Various little fixes. You'll get two trivial merge conflicts, which should be easy enough to fix up" Fix up the trivial conflicts due to hlist traversal cleanups (commit b67bfe0d42ca: "hlist: drop the node parameter from iterators"). * 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits) block: remove redundant check to bd_openers() block: use i_size_write() in bd_set_size() cfq: fix lock imbalance with failed allocations drivers/block/swim3.c: fix null pointer dereference block: don't select PERCPU_RWSEM block: account iowait time when waiting for completion of IO request sched: add wait_for_completion_io[_timeout] writeback: add more tracepoints block: add block_{touch|dirty}_buffer tracepoint buffer: make touch_buffer() an exported function block: add @req to bio_{front|back}_merge tracepoints block: add missing block_bio_complete() tracepoint block: Remove should_sort judgement when flush blk_plug block,elevator: use new hashtable implementation cfq-iosched: add hierarchical cfq_group statistics cfq-iosched: collect stats from dead cfqgs cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats() blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock block: RCU free request_queue blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge() ...
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22cfq: fix lock imbalance with failed allocationsGlauber Costa
While stress-running very-small container scenarios with the Kernel Memory Controller, I've run into a lockdep-detected lock imbalance in cfq-iosched.c. I'll apologize beforehand for not posting a backlog: I didn't anticipate it would be so hard to reproduce, so I didn't save my serial output and went directly on debugging. Turns out that it did not happen again in more than 20 runs, making it a quite rare pattern. But here is my analysis: When we are in very low-memory situations, we will arrive at cfq_find_alloc_queue and may not find a queue, having to resort to the oom queue, in an rcu-locked condition: if (!cfqq || cfqq == &cfqd->oom_cfqq) [ ... ] Next, we will release the rcu lock, and try to allocate a queue, retrying if we succeed: rcu_read_unlock(); spin_unlock_irq(cfqd->queue->queue_lock); new_cfqq = kmem_cache_alloc_node(cfq_pool, gfp_mask | __GFP_ZERO, cfqd->queue->node); spin_lock_irq(cfqd->queue->queue_lock); if (new_cfqq) goto retry; We are unlocked at this point, but it should be fine, since we will reacquire the rcu_read_lock when we retry. Except of course, that we may not retry: the allocation may very well fail and we'll keep on going through the flow: The next branch is: if (cfqq) { [ ... ] } else cfqq = &cfqd->oom_cfqq; And right before exiting, we'll issue rcu_read_unlock(). Being already unlocked, this is the likely source of our imbalance. Since cfqq is either already NULL or made NULL in the first statement of the outter branch, the only viable alternative here seems to be to return the oom queue right away in case of allocation failure. Please review the following patch and apply if you agree with my analysis. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-01-09cfq-iosched: add hierarchical cfq_group statisticsTejun Heo
Unfortunately, at this point, there's no way to make the existing statistics hierarchical without creating nasty surprises for the existing users. Just create recursive counterpart of the existing stats. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: collect stats from dead cfqgsTejun Heo
To support hierarchical stats, it's necessary to remember stats from dead children. Add cfqg->dead_stats and make a dying cfqg transfer its stats to the parent's dead-stats. The transfer happens form ->pd_offline_fn() and it is possible that there are some residual IOs completing afterwards. Currently, we lose these stats. Given that cgroup removal isn't a very high frequency operation and the amount of residual IOs on offline are likely to be nil or small, this shouldn't be a big deal and the complexity needed to handle residual IOs - another callback and rather elaborate synchronization to reach and lock the matching q - doesn't seem justified. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats()Tejun Heo
Separate out cfqg_stats_reset() which takes struct cfqg_stats * from cfq_pd_reset_stats() and move the latter to where other pd methods are defined. cfqg_stats_reset() will be used to implement hierarchical stats. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09blkcg: s/blkg_rwstat_sum()/blkg_rwstat_total()/Tejun Heo
Rename blkg_rwstat_sum() to blkg_rwstat_total(). sum will be used for summing up stats from multiple blkgs. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: enable full blkcg hierarchy supportTejun Heo
With the previous two patches, all cfqg scheduling decisions are based on vfraction and ready for hierarchy support. The only thing which keeps the behavior flat is cfqg_flat_parent() which makes vfraction calculation consider all non-root cfqgs children of the root cfqg. Replace it with cfqg_parent() which returns the real parent. This enables full blkcg hierarchy support for cfq-iosched. For example, consider the following hierarchy. root / \ A:500 B:250 / \ AA:500 AB:1000 For simplicity, let's say all the leaf nodes have active tasks and are on service tree. For each leaf node, vfraction would be AA: (500 / 1500) * (500 / 750) =~ 0.2222 AB: (1000 / 1500) * (500 / 750) =~ 0.4444 B: (250 / 750) =~ 0.3333 and vdisktime will be distributed accordingly. For more detail, please refer to Documentation/block/cfq-iosched.txt. v2: cfq-iosched.txt updated to describe group scheduling as suggested by Vivek. v3: blkio-controller.txt updated. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: convert cfq_group_slice() to use cfqg->vfractionTejun Heo
cfq_group_slice() calculates slice by taking a fraction of cfq_target_latency according to the ratio of cfqg->weight against service_tree->total_weight. This currently works only because all cfqgs are treated to be at the same level. To prepare for proper hierarchy support, convert cfq_group_slice() to base the calculation on cfqg->vfraction. As cfqg->vfraction is always a fraction of 1 and represents the fraction allocated to the cfqg with hierarchy considered, the slice can be simply calculated by multiplying cfqg->vfraction to cfq_target_latency (with fixed point shift factored in). As vfraction calculation currently treats all non-root cfqgs as children of the root cfqg, this patch doesn't introduce noticeable behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: implement hierarchy-ready cfq_group charge scalingTejun Heo
Currently, cfqg charges are scaled directly according to cfqg->weight. Regardless of the number of active cfqgs or the amount of active weights, a given weight value always scales charge the same way. This works fine as long as all cfqgs are treated equally regardless of their positions in the hierarchy, which is what cfq currently implements. It can't work in hierarchical settings because the interpretation of a given weight value depends on where the weight is located in the hierarchy. This patch reimplements cfqg charge scaling so that it can be used to support hierarchy properly. The scheme is fairly simple and light-weight. * When a cfqg is added to the service tree, v(disktime)weight is calculated. It walks up the tree to root calculating the fraction it has in the hierarchy. At each level, the fraction can be calculated as cfqg->weight / parent->level_weight By compounding these, the global fraction of vdisktime the cfqg has claim to - vfraction - can be determined. * When the cfqg needs to be charged, the charge is scaled inversely proportionally to the vfraction. The new scaling scheme uses the same CFQ_SERVICE_SHIFT for fixed point representation as before; however, the smallest scaling factor is now 1 (ie. 1 << CFQ_SERVICE_SHIFT). This is different from before where 1 was for CFQ_WEIGHT_DEFAULT and higher weight would result in smaller scaling factor. While this shifts the global scale of vdisktime a bit, it doesn't change the relative relationships among cfqgs and the scheduling result isn't different. cfq_group_notify_queue_add uses fixed CFQ_IDLE_DELAY when appending new cfqg to the service tree. The specific value of CFQ_IDLE_DELAY didn't have any relevance to vdisktime before and is unlikely to cause any visible behavior difference now especially as the scale shift isn't that large. As the new scheme now makes proper distinction between cfqg->weight and ->leaf_weight, reverse the weight aliasing for root cfqgs. For root, both weights are now mapped to ->leaf_weight instead of the other way around. Because we're still using cfqg_flat_parent(), this patch shouldn't change the scheduling behavior in any noticeable way. v2: Beefed up comments on vfraction as requested by Vivek. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: implement cfq_group->nr_active and ->children_weightTejun Heo
To prepare for blkcg hierarchy support, add cfqg->nr_active and ->children_weight. cfqg->nr_active counts the number of active cfqgs at the cfqg's level and ->children_weight is sum of weights of those cfqgs. The level covers itself (cfqg->leaf_weight) and immediate children. The two values are updated when a cfqg enters and leaves the group service tree. Unless the hierarchy is very deep, the added overhead should be negligible. Currently, the parent is determined using cfqg_flat_parent() which makes the root cfqg the parent of all other cfqgs. This is to make the transition to hierarchy-aware scheduling gradual. Scheduling logic will be converted to use cfqg->children_weight without actually changing the behavior. When everything is ready, blkcg_weight_parent() will be replaced with proper parent function. This patch doesn't introduce any behavior chagne. v2: s/cfqg->level_weight/cfqg->children_weight/ as per Vivek. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2013-01-09cfq-iosched: add leaf_weightTejun Heo
cfq blkcg is about to grow proper hierarchy handling, where a child blkg's weight would nest inside the parent's. This makes tasks in a blkg to compete against both tasks in the sibling blkgs and the tasks of child blkgs. We're gonna use the existing weight as the group weight which decides the blkg's weight against its siblings. This patch introduces a new weight - leaf_weight - which decides the weight of a blkg against the child blkgs. It's named leaf_weight because another way to look at it is that each internal blkg nodes have a hidden child leaf node which contains all its tasks and leaf_weight is the weight of the leaf node and handled the same as the weight of the child blkgs. This patch only adds leaf_weight fields and exposes it to userland. The new weight isn't actually used anywhere yet. Note that cfq-iosched currently offcially supports only single level hierarchy and root blkgs compete with the first level blkgs - ie. root weight is basically being used as leaf_weight. For root blkgs, the two weights are kept in sync for backward compatibility. v2: cfqd->root_group->leaf_weight initialization was missing from cfq_init_queue() causing divide by zero when !CONFIG_CFQ_GROUP_SCHED. Fix it. Reported by Fengguang. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Fengguang Wu <fengguang.wu@intel.com>
2013-01-09cfq-iosched: Print sync-noidle information in blktrace messagesVivek Goyal
Currently we attach a character "S" or "A" to the cfqq<pid>, to represent whether queues is sync or async. Add one more character "N" to represent whether it is sync-noidle queue or sync queue. So now three different type of queues will look as follows. cfq1234S --> sync queus cfq1234SN --> sync noidle queue cfq1234A --> Async queue Previously S/A classification was being printed only if group scheduling was enabled. This patch also makes sure that this classification is displayed even if group idling is disabled. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-09cfq-iosched: Get rid of unnecessary local variableVivek Goyal
Use of local varibale "n" seems to be unnecessary. Remove it. This brings it inline with function __cfq_group_st_add(), which is also doing the similar operation of adding a group to a rb tree. No functionality change here. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-09cfq-iosched: Rename few functions related to selecting workloadVivek Goyal
choose_service_tree() selects/sets both wl_class and wl_type. Rename it to choose_wl_class_and_type() to make it very clear. cfq_choose_wl() only selects and sets wl_type. It is easy to confuse it with choose_st(). So rename it to cfq_choose_wl_type() to make it clear what does it do. Just renaming. No functionality change. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-09cfq-iosched: Rename "service_tree" to "st" at some placesVivek Goyal
At quite a few places we use the keyword "service_tree". At some places, especially local variables, I have abbreviated it to "st". Also at couple of places moved binary operator "+" from beginning of line to end of previous line, as per Tejun's feedback. v2: Reverted most of the service tree name change based on Jeff Moyer's feedback. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-09cfq-iosched: More renaming to better represent wl_class and wl_typeVivek Goyal
Some more renaming. Again making the code uniform w.r.t use of wl_class/class to represent IO class (RT, BE, IDLE) and using wl_type/type to represent subclass (SYNC, SYNC-IDLE, ASYNC). At places this patch shortens the string "workload" to "wl". Renamed "saved_workload" to "saved_wl_type". Renamed "saved_serving_class" to "saved_wl_class". For uniformity with "saved_wl_*" variables, renamed "serving_class" to "serving_wl_class" and renamed "serving_type" to "serving_wl_type". Again, just trying to improve upon code uniformity and improve readability. No functional change. v2: - Restored the usage of keyword "service" based on Jeff Moyer's feedback. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-09cfq-iosched: Properly name all references to IO classVivek Goyal
Currently CFQ has three IO classes, RT, BE and IDLE. At many a places we are calling workloads belonging to these classes as "prio". This gets very confusing as one starts to associate it with ioprio. So this patch just does bunch of renaming so that reading code becomes easier. All reference to RT, BE and IDLE workload are done using keyword "class" and all references to subclass, SYNC, SYNC-IDLE, ASYNC are made using keyword "type". This makes me feel much better while I am reading the code. There is no functionality change due to this patch. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-11-06block CFQ: avoid moving request to different queueShaohua Li
request is queued in cfqq->fifo list. Looks it's possible we are moving a request from one cfqq to another in request merge case. In such case, adjusting the fifo list order doesn't make sense and is impossible if we don't iterate the whole fifo list. My test does hit one case the two cfqq are different, but didn't cause kernel crash, maybe it's because fifo list isn't used frequently. Anyway, from the code logic, this is buggy. I thought we can re-enable the recusive merge logic after this is fixed. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-06-04block: blkcg_policy_cfq shouldn't be used if !CONFIG_CFQ_GROUP_IOSCHEDTejun Heo
cfq may be built w/ or w/o blkcg support depending on CONFIG_CFQ_CGROUP_IOSCHED. If blkcg support is disabled, most of related code is ifdef'd out but some part is left dangling - blkcg_policy_cfq is left zero-filled and blkcg_policy_[un]register() calls are made on it. Feeding zero filled policy to blkcg_policy_register() is incorrect and triggers the following WARN_ON() if CONFIG_BLK_CGROUP && !CONFIG_CFQ_GROUP_IOSCHED. ------------[ cut here ]------------ WARNING: at block/blk-cgroup.c:867 Modules linked in: Modules linked in: CPU: 3 Not tainted 3.4.0-09547-gfb21aff #1 Process swapper/0 (pid: 1, task: 000000003ff80000, ksp: 000000003ff7f8b8) Krnl PSW : 0704100180000000 00000000003d76ca (blkcg_policy_register+0xca/0xe0) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0 EA:3 Krnl GPRS: 0000000000000000 00000000014b85ec 00000000014b85b0 0000000000000000 000000000096fb60 0000000000000000 00000000009a8e78 0000000000000048 000000000099c070 0000000000b6f000 0000000000000000 000000000099c0b8 00000000014b85b0 0000000000667580 000000003ff7fd98 000000003ff7fd70 Krnl Code: 00000000003d76be: a7280001 lhi %r2,1 00000000003d76c2: a7f4ffdf brc 15,3d7680 #00000000003d76c6: a7f40001 brc 15,3d76c8 >00000000003d76ca: a7c8ffea lhi %r12,-22 00000000003d76ce: a7f4ffce brc 15,3d766a 00000000003d76d2: a7f40001 brc 15,3d76d4 00000000003d76d6: a7c80000 lhi %r12,0 00000000003d76da: a7f4ffc2 brc 15,3d765e Call Trace: ([<0000000000b6f000>] initcall_debug+0x0/0x4) [<0000000000989e8a>] cfq_init+0x62/0xd4 [<00000000001000ba>] do_one_initcall+0x3a/0x170 [<000000000096fb60>] kernel_init+0x214/0x2bc [<0000000000623202>] kernel_thread_starter+0x6/0xc [<00000000006231fc>] kernel_thread_starter+0x0/0xc no locks held by swapper/0/1. Last Breaking-Event-Address: [<00000000003d76c6>] blkcg_policy_register+0xc6/0xe0 ---[ end trace b8ef4903fcbf9dd3 ]--- This patch fixes the problem by ensuring all blkcg support code is inside CONFIG_CFQ_GROUP_IOSCHED. * blkcg_policy_cfq declaration and blkg_to_cfqg() definition are moved inside the first CONFIG_CFQ_GROUP_IOSCHED block. __maybe_unused is dropped from blkcg_policy_cfq decl. * blkcg_deactivate_poilcy() invocation is moved inside ifdef. This also makes the activation logic match cfq_init_queue(). * All blkcg_policy_[un]register() invocations are moved inside ifdef. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> LKML-Reference: <20120601112954.GC3535@osiris.boeblingen.de.ibm.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-06-04block: fix return value on cfq_init() failureTejun Heo
cfq_init() would return zero after kmem cache creation failure. Fix so that it returns -ENOMEM. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-05-01Merge tag 'v3.4-rc5' into for-3.5/coreJens Axboe
The core branch is behind driver commits that we want to build on for 3.5, hence I'm pulling in a later -rc. Linux 3.4-rc5 Conflicts: Documentation/feature-removal-schedule.txt Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: collapse blkcg_policy_ops into blkcg_policyTejun Heo
There's no reason to keep blkcg_policy_ops separate. Collapse it into blkcg_policy. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: embed struct blkg_policy_data in policy specific dataTejun Heo
Currently blkg_policy_data carries policy specific data as char flex array instead of being embedded in policy specific data. This was forced by oddities around blkg allocation which are all gone now. This patch makes blkg_policy_data embedded in policy specific data - throtl_grp and cfq_group so that it's more conventional and consistent with how io_cq is handled. * blkcg_policy->pdata_size is renamed to ->pd_size. * Functions which used to take void *pdata now takes struct blkg_policy_data *pd. * blkg_to_pdata/pdata_to_blkg() updated to blkg_to_pd/pd_to_blkg(). * Dummy struct blkg_policy_data definition added. Dummy pdata_to_blkg() definition was unused and inconsistent with the non-dummy version - correct dummy pd_to_blkg() added. * throtl and cfq updated accordingly. * As dummy blkg_to_pd/pd_to_blkg() are provided, blkg_to_cfqg/cfqg_to_blkg() don't need to be ifdef'd. Moved outside ifdef block. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: mass rename of blkcg APITejun Heo
During the recent blkcg cleanup, most of blkcg API has changed to such extent that mass renaming wouldn't cause any noticeable pain. Take the chance and cleanup the naming. * Rename blkio_cgroup to blkcg. * Drop blkio / blkiocg prefixes and consistently use blkcg. * Rename blkio_group to blkcg_gq, which is consistent with io_cq but keep the blkg prefix / variable name. * Rename policy method type and field names to signify they're dealing with policy data. * Rename blkio_policy_type to blkcg_policy. This patch doesn't cause any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: remove blkio_group->path[]Tejun Heo
blkio_group->path[] stores the path of the associated cgroup and is used only for debug messages. Just format the path from blkg->cgroup when printing debug messages. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: drop stuff unused after per-queue policy activation updateTejun Heo
* All_q_list is unused. Drop all_q_{mutex|list}. * @for_root of blkg_lookup_create() is always %false when called from outside blk-cgroup.c proper. Factor out __blkg_lookup_create() so that it doesn't check whether @q is bypassing and use the underscored version for the @for_root callsite. * blkg_destroy_all() is used only from blkcg proper and @destroy_root is always %true. Make it static and drop @destroy_root. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: implement per-queue policy activationTejun Heo
All blkcg policies were assumed to be enabled on all request_queues. Due to various implementation obstacles, during the recent blkcg core updates, this was temporarily implemented as shooting down all !root blkgs on elevator switch and policy [de]registration combined with half-broken in-place root blkg updates. In addition to being buggy and racy, this meant losing all blkcg configurations across those events. Now that blkcg is cleaned up enough, this patch replaces the temporary implementation with proper per-queue policy activation. Each blkcg policy should call the new blkcg_[de]activate_policy() to enable and disable the policy on a specific queue. blkcg_activate_policy() allocates and installs policy data for the policy for all existing blkgs. blkcg_deactivate_policy() does the reverse. If a policy is not enabled for a given queue, blkg printing / config functions skip the respective blkg for the queue. blkcg_activate_policy() also takes care of root blkg creation, and cfq_init_queue() and blk_throtl_init() are updated accordingly. This replaces blkcg_bypass_{start|end}() and update_root_blkg_pd() unnecessary. Dropped. v2: cfq_init_queue() was returning uninitialized @ret on root_group alloc failure if !CONFIG_CFQ_GROUP_IOSCHED. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: add request_queue->root_blkgTejun Heo
With per-queue policy activation, root blkg creation will be moved to blkcg core. Add q->root_blkg in preparation. For blk-throtl, this replaces throtl_data->root_tg; however, cfq needs to keep cfqd->root_group for !CONFIG_CFQ_GROUP_IOSCHED. This is to prepare for per-queue policy activation and doesn't cause any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: make blkg_conf_prep() take @pol and return with queue lock heldTejun Heo
Add @pol to blkg_conf_prep() and let it return with queue lock held (to be released by blkg_conf_finish()). Note that @pol isn't used yet. This is to prepare for per-queue policy activation and doesn't cause any visible difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: remove static policy ID enumsTejun Heo
Remove BLKIO_POLICY_* enums and let blkio_policy_register() allocate @pol->plid dynamically on registration. The maximum number of blkcg policies which can be registered at the same time is defined by BLKCG_MAX_POLS constant added to include/linux/blkdev.h. Note that blkio_policy_register() now may fail. Policy init functions updated accordingly and unnecessary ifdefs removed from cfq_init(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20blkcg: use @pol instead of @plid in update_root_blkg_pd() and ↵Tejun Heo
blkcg_print_blkgs() The two functions were taking "enum blkio_policy_id plid". Make them take "const struct blkio_policy_type *pol" instead. This is to prepare for per-queue policy activation and doesn't cause any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-20cfq: fix build breakage & warningsTejun Heo
* CFQ_WEIGHT_* defined inside CONFIG_BLK_CGROUP causes cfq-iosched.c compile failure when the config is disabled. Move it outside the ifdef block. * Dummy cfqg_stats_*() definitions were lacking inline modifiers causing unused functions warning if !CONFIG_CFQ_GROUP_IOSCHED. Add them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-01blkcg: drop BLKCG_STAT_{PRIV|POL|OFF} macrosTejun Heo
Now that all stat handling code lives in policy implementations, there's no need to encode policy ID in cft->private. * Export blkcg_prfill_[rw]stat() from blkcg, remove blkcg_print_[rw]stat(), and implement cfqg_print_[rw]stat() which use hard-code BLKIO_POLICY_PROP. * Use cft->private for offset of the target field directly and drop BLKCG_STAT_{PRIV|POL|OFF}(). Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: pass around pd->pdata instead of pd itself in prfill functionsTejun Heo
Now that all conf and stat fields are moved into policy specific blkio_policy_data->pdata areas, there's no reason to use blkio_policy_data itself in prfill functions. Pass around @pd->pdata instead of @pd. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: move blkio_group_conf->weight to cfqTejun Heo
blkio_group_conf->weight is owned by cfq and has no reason to be defined in blkcg core. Replace it with cfq_group->dev_weight and let conf setting functions directly set it. If dev_weight is zero, the cfqg doesn't have device specific weight configured. Also, rename BLKIO_WEIGHT_* constants to CFQ_WEIGHT_* and rename blkio_cgroup->weight to blkio_cgroup->cfq_weight. We eventually want per-policy storage in blkio_cgroup but just mark the ownership of the field for now. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: move blkio_group_stats to cfq-iosched.cTejun Heo
blkio_group_stats contains only fields used by cfq and has no reason to be defined in blkcg core. * Move blkio_group_stats to cfq-iosched.c and rename it to cfqg_stats. * blkg_policy_data->stats is replaced with cfq_group->stats. blkg_prfill_[rw]stat() are updated to use offset against pd->pdata instead. * All related macros / functions are renamed so that they have cfqg_ prefix and the unnecessary @pol arguments are dropped. * All stat functions now take cfq_group * instead of blkio_group *. * lockdep assertion on queue lock dropped. Elevator runs under queue lock by default. There isn't much to be gained by adding lockdep assertions at stat function level. * cfqg_stats_reset() implemented for blkio_reset_group_stats_fn method so that cfqg->stats can be reset. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: cfq doesn't need per-cpu dispatch statsTejun Heo
blkio_group_stats_cpu is used to count dispatch stats using per-cpu counters. This is used by both blk-throtl and cfq-iosched but the sharing is rather silly. * cfq-iosched doesn't need per-cpu dispatch stats. cfq always updates those stats while holding queue_lock. * blk-throtl needs per-cpu dispatch stats but only service_bytes and serviced. It doesn't make use of sectors. This patch makes cfq add and use global stats for service_bytes, serviced and sectors, removes per-cpu sectors counter and moves per-cpu stat printing code to blk-throttle.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: move statistics update code to policiesTejun Heo
As with conf/stats file handling code, there's no reason for stat update code to live in blkcg core with policies calling into update them. The current organization is both inflexible and complex. This patch moves stat update code to specific policies. All blkiocg_update_*_stats() functions which deal with BLKIO_POLICY_PROP stats are collapsed into their cfq_blkiocg_update_*_stats() counterparts. blkiocg_update_dispatch_stats() is used by both policies and duplicated as throtl_update_dispatch_stats() and cfq_blkiocg_update_dispatch_stats(). This will be cleaned up later. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01cfq: collapse cfq.h into cfq-iosched.cTejun Heo
block/cfq.h contains some functions which interact with blkcg; however, this is only part of it and cfq-iosched.c already has quite some #ifdef CONFIG_CFQ_GROUP_IOSCHED. With conf/stat handling being moved to specific policies, having these relay functions isolated in cfq.h doesn't make much sense. Collapse cfq.h into cfq-iosched.c for now. Let's split blkcg support properly later if necessary. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: move conf/stat file handling code to policiesTejun Heo
blkcg conf/stat handling is convoluted in that details which belong to specific policy implementations are all out in blkcg core and then policies hook into core layer to access and manipulate confs and stats. This sadly achieves both inflexibility (confs/stats can't be modified without messing with blkcg core) and complexity (all the call-ins and call-backs). The previous patches restructured conf and stat handling code such that they can be separated out. This patch relocates the file handling part. All conf/stat file handling code which belongs to BLKIO_POLICY_PROP is moved to cfq-iosched.c and all BKLIO_POLICY_THROTL code to blk-throtl.c. The move is verbatim except for blkio_update_group_{weight|bps|iops}() callbacks which relays conf changes to policies. The configuration settings are handled in policies themselves so the relaying isn't necessary. Conf setting functions are modified to directly call per-policy update functions and the relaying mechanism is dropped. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01blkcg: remove unused @pol and @plid parametersTejun Heo
@pol to blkg_to_pdata() and @plid to blkg_lookup_create() are no longer necessary. Drop them. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-04-01block: Make cfq_target_latency tunable through sysfs.Tao Ma
In cfq, when we calculate a time slice for a process(or a cfqq to be precise), we have to consider the cfq_target_latency so that all the sync request have an estimated latency(300ms) and it is controlled by cfq_target_latency. But in some hadoop test, we have found that if there are many processes doing sequential read(24 for example), the throughput is bad because every process can only work for about 25ms and the cfqq is switched. That leads to a higher disk seek. We can achive the good throughput by setting low_latency=0, but then some read's latency is too much for the application. So this patch makes cfq_target_latency tunable through sysfs so that we can tune it and find some magic number which is not bad for both the throughput and the read latency. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-23cfq: fix cfqg ref handling when BLK_CGROUP && !CFQ_GROUP_IOSCHEDTejun Heo
When BLK_CGROUP is enabled but CFQ_GROUP_IOSCHED is, cfq ends up calling blkg_get/put() on dummy cfqg leading to the following crash. BUG: unable to handle kernel NULL pointer dereference at 00000000000000b0 IP: [<ffffffff813d44d8>] cfq_init_queue+0x258/0x430 PGD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Modules linked in: Pid: 1, comm: swapper/0 Not tainted 3.3.0-rc6-work+ #125 Bochs Bochs RIP: 0010:[<ffffffff813d44d8>] [<ffffffff813d44d8>] cfq_init_queue+0x258/0x430 RSP: 0018:ffff88001f9dfd80 EFLAGS: 00010046 RAX: ffff88001aefbbf0 RBX: ffff88001aeedbf0 RCX: 0000000000000100 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff820ffd40 RBP: ffff88001f9dfdd0 R08: 0000000000000000 R09: 0000000000000001 R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000009 R14: ffff88001aefbc30 R15: 0000000000000003 FS: 0000000000000000(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000000b0 CR3: 000000000206f000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper/0 (pid: 1, threadinfo ffff88001f9de000, task ffff88001f9dc040) Stack: ffff88001aeedbf0 ffff88001aefbdb0 ffff88001aef1548 ffff88001aefbbf0 ffff88001f9dfdd0 ffff88001aef1548 ffffffff820d6320 ffffffff8165ce30 ffffffff82c555e0 ffff88001aeebbf0 ffff88001f9dfe00 ffffffff813b0507 Call Trace: [<ffffffff813b0507>] elevator_init+0xd7/0x140 [<ffffffff813b83d5>] blk_init_allocated_queue+0x125/0x150 [<ffffffff813b94d3>] blk_init_queue_node+0x43/0x80 [<ffffffff813b9523>] blk_init_queue+0x13/0x20 [<ffffffff821aec00>] floppy_init+0x82/0xec7 [<ffffffff810001d2>] do_one_initcall+0x42/0x170 [<ffffffff821835fc>] kernel_init+0xcb/0x14f [<ffffffff81b40b24>] kernel_thread_helper+0x4/0x10 Code: 00 e8 1d 9e 76 00 48 8b 43 48 48 85 c0 48 89 83 28 03 00 00 74 07 4c 8b a0 10 ff ff ff 8b 15 b0 2e d0 00 85 d2 0f 85 49 01 00 00 <41> 8b 84 24 b0 00 00 00 85 c0 0f 8e 8c 01 00 00 83 e8 01 85 c0 RIP [<ffffffff813d44d8>] cfq_init_queue+0x258/0x430 Because cfq's blkcg support has a on/off switch, CFQ_GROUP_IOSCHED, separate from BLK_CGROUP, blkg access through cfqg needs to be conditioned on it. * Make blkg_to_cfqg() and cfqg_to_blkg() conditioned on CFQ_GROUP_IOSCHED. If disabled, they always return %NULL. * Introduce cfqg_get() and cfqg_put() conditioned on CFQ_GROUP_IOSCHED. If disabled, they are noops. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-20cfq: don't use icq_get_changed()Tejun Heo
cfq caches the associated cfqq's for a given cic. The cache needs to be flushed if the cic's ioprio or blkcg has changed. It is currently done by requiring the changing action to set the respective ICQ_*_CHANGED bit in the icq and testing it from cfq_set_request(), which involves iterating through all the affected icqs. All cfq wants to know is whether ioprio and/or blkcg have changed since the last flush and can be easily achieved by just remembering the current ioprio and blkcg ID in cic. This patch adds cic->{ioprio|blkcg_id}, updates all ioprio users to use the remembered value instead, and updates cfq_set_request() path such that, instead of using icq_get_changed(), the current values are compared against the remembered ones and trigger appropriate flush action if not. Condition tests are moved inside both _changed functions which are now named check_ioprio_changed() and check_blkcg_changed(). ioprio.h::task_ioprio*() can't be used anymore and replaced with open-coded IOPRIO_CLASS_NONE case in cfq_async_queue_prio(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-20cfq: pass around cfq_io_cq instead of io_contextTejun Heo
Now that io_cq is managed by block core and guaranteed to exist for any in-flight request, it is easier and carries more information to pass around cfq_io_cq than io_context. This patch updates cfq_init_prio_data(), cfq_find_alloc_queue() and cfq_get_queue() to take @cic instead of @ioc. This change removes a duplicate cfq_cic_lookup() from cfq_find_alloc_queue(). This change enables the use of cic-cached ioprio in the next patch. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06block: make block cgroup policies follow bio task associationTejun Heo
Implement bio_blkio_cgroup() which returns the blkcg associated with the bio if exists or %current's blkcg, and use it in blk-throttle and cfq-iosched propio. This makes both cgroup policies honor task association for the bio instead of always assuming %current. As nobody is using bio_set_task() yet, this doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
