path: root/block/compat_ioctl.c
2010-08-12block: add secure discardAdrian Hunter
Secure discard is the same as discard except that all copies of the discarded sectors (perhaps created by garbage collection) must also be erased. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07block: push BKL into blktrace ioctlsArnd Bergmann
The blktrace driver currently needs the BKL, but we should not need to take that in the block layer, so just push it down into the driver itself. It is quite likely that the BKL is not actually required in blktrace code and could be removed in a follow-on patch. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03block: Allow devices to indicate whether discarded blocks are zeroedMartin K. Petersen
The discard ioctl is used by mkfs utilities to clear a block device prior to putting metadata down. However, not all devices return zeroed blocks after a discard. Some drives return stale data, potentially containing old superblocks. It is therefore important to know whether discarded blocks are properly zeroed. Both ATA and SCSI drives have configuration bits that indicate whether zeroes are returned after a discard operation. Implement a block level interface that allows this information to be bubbled up the stack and queried via a new block device ioctl. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-03block: Topology ioctlsMartin K. Petersen
Not all users of the topology information want to use libblkid. Provide the topology information through bdev ioctls. Also clarify sector size comments for existing BLK ioctls. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-16blktrace: support per-partition tracingShawn Du
Though one can specify '-d /dev/sda1' when using blktrace, it still traces the whole sda. To support per-partition tracing, when we start tracing, we initialize bt->start_lba and bt->end_lba to the start and end sector of that partition. Note some actions are per device, thus we don't filter 0-sector events. The original patch and discussion can be found here: http://marc.info/?l=linux-btrace&m=122949374214540&w=2 Signed-off-by: Shawn Du <duyuyang@gmail.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49E42620.4050701@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-29block: don't take lock on changing ra_pagesWu Fengguang
There's no need to take queue_lock or kernel_lock when modifying bdi->ra_pages. So remove them. Also remove out of date comment for queue_max_sectors_store(). Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] Fix block dev compat ioctl handlingAndreas Schwab
Commit 33c2dca4957bd0da3e1af7b96d0758d97e708ef6 (trim file propagation in block/compat_ioctl.c) removed the handling of some ioctls from compat_blkdev_driver_ioctl. That caused them to be rejected as unknown by the compat layer. Signed-off-by: Andreas Schwab <schwab@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23compat_blkdev_driver_ioctl: Remove unused variable warningLinus Torvalds
Variable 'ret' is no longer used. Don't declare it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] kill the rest of struct file propagation in block ioctlsAl Viro
Now we can switch blkdev_ioctl() block_device/mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] get rid of blkdev_locked_ioctl()Al Viro
Most of that stuff doesn't need BKL at all; expand in the (only) caller, merge the switch into one there and leave BKL only around the stuff that might actually need it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] trim file propagation in block/compat_ioctl.cAl Viro
... and remove the handling of cases when it falls back to native without changing arguments. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] end of methods switch: remove the old onesAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-09Add BLKDISCARD ioctl to allow userspace to discard sectorsDavid Woodhouse
We may well want mkfs tools to use this to mark the whole device as unwanted before they format it, for example. The ioctl takes a pair of uint64_ts, which are start offset and length in _bytes_. Although at the moment it might make sense for them both to be in 512-byte sectors, I don't want to limit the ABI to that. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-13Fix misuses of bdevname()Jean Delvare
bdevname() fills the buffer that it is given as a parameter, so calling strcpy() or snprintf() on the returned value is redundant (and probably not guaranteed to work - I don't think strcpy and snprintf support overlapping buffers.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stephen Tweedie <sct@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18ide: remove broken/dangerous HDIO_[UNREGISTER,SCAN]_HWIF ioctls (take 3)Bartlomiej Zolnierkiewicz
hdparm explicitely marks HDIO_[UNREGISTER,SCAN]_HWIF ioctls as DANGEROUS and given the number of bugs we can assume that there are no real users: * DMA has no chance of working because DMA resources are released by ide_unregister() and they are never allocated again. * Since ide_init_hwif_ports() is used for ->io_ports[] setup the ioctls don't work for almost all hosts with "non-standard" (== non ISA-like) layout of IDE taskfile registers (there is a lot of such host drivers). * ide_port_init_devices() is not called when probing IDE devices so: - drive->autotune is never set and IDE host/devices are not programmed for the correct PIO/DMA transfer modes (=> possible data corruption) - host specific I/O 32-bit and IRQ unmasking settings are not applied (=> possible data corruption) - host specific ->port_init_devs method is not called (=> no luck with ht6560b, qd65xx and opti621 host drivers) * ->rw_disk method is not preserved (=> no HPT3xxN chipsets support). * ->serialized flag is not preserved (=> possible data corruption when using icside, aec62xx (ATP850UF chipset), cmd640, cs5530, hpt366 (HPT3xxN chipsets), rz1000, sc1200, dtc2278 and ht6560b host drivers). * ->ack_intr method is not preserved (=> needed by ide-cris, buddha, gayle and macide host drivers). * ->sata_scr[] and sata_misc[] is cleared by ide_unregister() and it isn't initialized again (SiI3112 support needs them). * To issue an ioctl() there need to be at least one IDE device present in the system. * ->cable_detect method is not preserved + it is not called when probing IDE devices so cable detection is broken (however since DMA support is also broken it doesn't really matter ;-). * Some objects which may have already been freed in ide_unregister() are restored by ide_hwif_restore() (i.e. ->hwgroup). * ide_register_hw() may unregister unrelated IDE ports if free ide_hwifs[] slot cannot be found. * When IDE host drivers are modular unregistered port may be re-used by different host driver that owned it first causing subtle bugs. Since we now have a proper warm-plug support remove these ioctls, then remove no longer needed: - ide_register_hw() and ide_hwif_restore() functions - 'init_default' and 'restore' arguments of ide_unregister() - zeroeing of hwif->{dma,extra}_* fields in ide_unregister() As an added bonus IDE core code size shrinks by ~3kB (x86-32). v2: * fix ide_unregister() arguments in cleanup_module() (Andrew Morton). v3: * fix ide_unregister() arguments in palm_bk3710.c. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-28blktrace: Add blktrace ioctls to SCSI generic devicesChristof Schmitt
Since the SCSI layer uses the request queues from the block layer, blktrace can also be used to trace the requests to all SCSI devices (like SCSI tape drives), not only disks. The only missing part is the ioctl interface to start and stop tracing. This patch adds the SETUP, START, STOP and TEARDOWN ioctls from blktrace to the sg device files. With this change, blktrace can be used for SCSI devices like for disks, e.g.: blktrace -d /dev/sg1 -o - | blkparse -i - Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-29compat_ioctl: fix block device compat ioctl regressionPhilip Langdale
The conversion of handlers to compat_blkdev_ioctl accidentally disabled handling of most ioctl numbers on block devices because of a typo. Fix the one line to enable it all again. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2007-10-10compat_ioctl: move floppy handlers to block/compat_ioctl.cArnd Bergmann
The floppy ioctls are used by multiple drivers, so they should be handled in a shared location. Also, add minor cleanups. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move cdrom handlers to block/compat_ioctl.cArnd Bergmann
These are shared by all cd-rom drivers and should have common handlers. Do slight cosmetic cleanups in the process. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move BLKPG handling to block/compat_ioctl.cArnd Bergmann
BLKPG is common to all block devices, so it should be handled by common code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move hdio calls to block/compat_ioctl.cArnd Bergmann
These are common to multiple block drivers, so they should be handled by the block layer. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: handle blk_trace ioctlsArnd Bergmann
blk_trace_setup is broken on x86_64 compat systems, this makes the code work correctly on all 64 bit architectures in compat mode. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: add compat_blkdev_driver_ioctl()Arnd Bergmann
Handle those blockdev ioctl calls that are compatible directly from the compat_blkdev_ioctl() function, instead of having to go through the compat_ioctl hash lookup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move common block ioctls to compat_blkdev_ioctlArnd Bergmann
Make compat_blkdev_ioctl and blkdev_ioctl reflect the respective native versions. This is somewhat more efficient and makes it easier to keep the two in sync. Also get rid of the bogus handling for broken_blkgetsize and the duplicate entry for BLKRASET. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
