path: root/block/scsi_ioctl.c
2017-03-22block: allow WRITE_SAME commands with the SG_IO ioctlMauricio Faria de Oliveira
[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ] The WRITE_SAME commands are not present in the blk_default_cmd_filter write_ok list, and thus are failed with -EPERM when the SG_IO ioctl() is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users). [ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ] The problem can be reproduced with the sg_write_same command # sg_write_same --num 1 --xferlen 512 /dev/sda # # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_same --num 1 --xferlen 512 /dev/sda' Write same: pass through os error: Operation not permitted # For comparison, the WRITE_VERIFY command does not observe this problem, since it is in that list: # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda' # So, this patch adds the WRITE_SAME commands to the list, in order for the SG_IO ioctl to finish successfully: # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_same --num 1 --xferlen 512 /dev/sda' # That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices (qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]), which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu). In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls, which are translated to write-same calls in the guest kernel, and then into SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest: [...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current] [...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated [...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00 [...] blk_update_request: I/O error, dev sda, sector 17096824 Links: [1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52 [2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device') Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com> Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com> Reported-by: Manjunatha H R <manjuhr1@in.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-06mm, page_alloc: rename __GFP_WAIT to __GFP_RECLAIMMel Gorman
__GFP_WAIT was used to signal that the caller was in atomic context and could not sleep. Now it is possible to distinguish between true atomic context and callers that are not willing to sleep. The latter should clear __GFP_DIRECT_RECLAIM so kswapd will still wake. As clearing __GFP_WAIT behaves differently, there is a risk that people will clear the wrong flags. This patch renames __GFP_WAIT to __GFP_RECLAIM to clearly indicate what it does -- setting it allows all reclaim activity, clearing them prevents it. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-27block: fix bogus EFAULT error from SG_IO ioctlPaolo Bonzini
Whenever blk_fill_sghdr_rq fails, its errno code is ignored and changed to EFAULT. This can cause very confusing errors: $ sg_persist -k /dev/sda persistent reservation in: pass through os error: Bad address The fix is trivial, just propagate the return value from blk_fill_sghdr_rq. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-11sg_io(): use import_iovec()Al Viro
... and don't skip access_ok() validation. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-05block: pass iov_iter to the BLOCK_PC mapping functionsKent Overstreet
Make use of a new interface provided by iov_iter, backed by scatter-gather list of iovec, instead of the old interface based on sg_iovec. Also use iov_iter_advance() instead of manual iteration. This commit should contain only literal replacements, without functional changes. Cc: Christoph Hellwig <hch@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Kent Overstreet <kmo@daterainc.com> [dpark: add more description in commit message] Signed-off-by: Dongsu Park <dongsu.park@profitbricks.com> [hch: fixed to do a deep clone of the iov_iter, and to properly use the iov_iter direction] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-08Merge remote-tracking branch 'scsi-queue/core-for-3.19' into for-linusJames Bottomley
2014-11-24scsi: rename SERVICE_ACTION_IN to SERVICE_ACTION_IN_16Hannes Reinecke
SPC-3 defines SERVICE ACTION IN(12) and SERVICE ACTION IN(16). So rename SERVICE_ACTION_IN to SERVICE_ACTION_IN_16 to be consistent with SPC and to allow for better distinction. Signed-off-by: Hannes Reinecke <hare@suse.de> Tested-by: Robert Elliott <elliott@hp.com> Reviewed-by: Robert Elliott <elliott@hp.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-10scsi: Fix more error handling in SCSI_IOCTL_SEND_COMMANDTony Battersby
Fix an error path in SCSI_IOCTL_SEND_COMMAND that calls blk_put_request(rq) on an invalid IS_ERR(rq) pointer. Fixes: a492f075450f ("block,scsi: fixup blk_get_request dead queue scenarios") Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-22scsi: Fix error handling in SCSI_IOCTL_SEND_COMMANDJan Kara
When sg_scsi_ioctl() fails to prepare request to submit in blk_rq_map_kern() we jump to a label where we just end up copying (luckily zeroed-out) kernel buffer to userspace instead of reporting error. Fix the problem by jumping to the right label. CC: Jens Axboe <axboe@kernel.dk> CC: linux-scsi@vger.kernel.org CC: stable@vger.kernel.org Coverity-id: 1226871 Signed-off-by: Jan Kara <jack@suse.cz> Fixed up the, now unused, out label. Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-11Merge branch 'for-linus' into for-3.18/coreJens Axboe
A bit of churn on the for-linus side that would be nice to have in the core bits for 3.18, so pull it in to catch us up and make forward progress easier. Signed-off-by: Jens Axboe <axboe@fb.com> Conflicts: block/scsi_ioctl.c
2014-08-28block,scsi: fixup blk_get_request dead queue scenariosJoe Lawrence
The blk_get_request function may fail in low-memory conditions or during device removal (even if __GFP_WAIT is set). To distinguish between these errors, modify the blk_get_request call stack to return the appropriate ERR_PTR. Verify that all callers check the return status and consider IS_ERR instead of a simple NULL pointer check. For consistency, make a similar change to the blk_mq_alloc_request leg of blk_get_request. It may fail if the queue is dead, or the caller was unwilling to wait. Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com> Acked-by: Jiri Kosina <jkosina@suse.cz> [for pktdvd] Acked-by: Boaz Harrosh <bharrosh@panasas.com> [for osd] Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-26block,scsi: verify return pointer from blk_get_requestJoe Lawrence
The blk-core dead queue checks introduce an error scenario to blk_get_request that returns NULL if the request queue has been shutdown. This affects the behavior for __GFP_WAIT callers, who should verify the return value before dereferencing. Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com> Acked-by: Jiri Kosina <jkosina@suse.cz> [for pktdvd] Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-26block: fix error handling in sg_ioSabrina Dubroca
Before commit 2cada584b200 ("block: cleanup error handling in sg_io"), we had ret = 0 before entering the last big if block of sg_io. Since 2cada584b200, ret = -EFAULT, which breaks hdparm: /dev/sda: setting Advanced Power Management level to 0xc8 (200) HDIO_DRIVE_CMD failed: Bad address APM_level = 128 Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Fixes: 2cada584b200 ("block: cleanup error handling in sg_io") Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-22fix regression in SCSI_IOCTL_SEND_COMMANDTony Battersby
blk_rq_set_block_pc() memsets rq->cmd to 0, so it should come immediately after blk_get_request() to avoid overwriting the user-supplied CDB. Also check for failure to allocate rq. Fixes: f27b087b81b7 ("block: add blk_rq_set_block_pc()") Cc: <stable@vger.kernel.org> # 3.16.x Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-21block: support > 16 byte CDBs for SG_IOChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Boaz Harrosh <boaz@plexistor.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-21block: cleanup error handling in sg_ioChristoph Hellwig
Make sure we always clean up through the out label and just have a single place to put the request. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-07-01block SG_IO: add SG_FLAG_Q_AT_HEAD flagDouglas Gilbert
After the SG_IO ioctl was copied into the block layer and later into the bsg driver, subtle differences emerged. One difference is the way injected commands are queued through the block layer (i.e. this is not SCSI device queueing nor SATA NCQ). Summarizing: - SG_IO on block layer device: blk_exec*(at_head=false) - sg device SG_IO: at_head=true - bsg device SG_IO: at_head=true Some time ago Boaz Harrosh introduced a sg v4 flag called BSG_FLAG_Q_AT_TAIL to override the bsg driver default. A recent patch titled: "sg: add SG_FLAG_Q_AT_TAIL flag" allowed the sg driver default to be overridden. This patch allows a SG_IO ioctl sent to a block layer device to have its default overridden. ChangeLog: - introduce SG_FLAG_Q_AT_HEAD flag in sg.h to cause commands that are injected via a block layer device SG_IO ioctl to set at_head=true - make comments clearer about queueing in sg.h since the header is used both by the sg device and block layer device implementations of the SG_IO ioctl. - introduce BSG_FLAG_Q_AT_HEAD in bsg.h for compatibility (it does nothing) and update comments. Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-07-01block: fix SG_[GS]ET_RESERVED_SIZE ioctl when max_sectors is hugeAkinobu Mita
SG_GET_RESERVED_SIZE and SG_SET_RESERVED_SIZE ioctls access a reserved buffer in bytes as int type. The value needs to be capped at the request queue's max_sectors. But integer overflow is not correctly handled in the calculation when converting max_sectors from sectors to bytes. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: linux-scsi@vger.kernel.org Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-06-06block: add blk_rq_set_block_pc()Jens Axboe
With the optimizations around not clearing the full request at alloc time, we are leaving some of the needed init for REQ_TYPE_BLOCK_PC up to the user allocating the request. Add a blk_rq_set_block_pc() that sets the command type to REQ_TYPE_BLOCK_PC, and properly initializes the members associated with this type of request. Update callers to use this function instead of manipulating rq->cmd_type directly. Includes fixes from Christoph Hellwig <hch@lst.de> for my half-assed attempt. Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-29block: remove dead code in scsi_ioctl:blk_verify_commandDave Jones
filter gets assigned the address of blk_default_cmd_filter on entry to this function, so the !filter condition can never be true. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-01-21block: Fix memory leak in rw_copy_check_uvector() handlingChristian Engelmayer
Fix a memory leak in the error handling path of function sg_io() that is used during the processing of scsi ioctl. Memory already allocated by rw_copy_check_uvector() needs to be freed correctly. Detected by Coverity: CID 1128953. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08block: Use rw_copy_check_uvector()Kent Overstreet
No need for silly open coding - and struct sg_iovec has exactly the same layout as struct iovec... Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-15scsi: Silence unnecessary warnings about ioctl to partitionJan Kara
Sometimes, warnings about ioctls to partition happen often enough that they form majority of the warnings in the kernel log and users complain. In some cases warnings are about ioctls such as SG_IO so it's not good to get rid of the warnings completely as they can ease debugging of userspace problems when ioctl is refused. Since I have seen warnings from lots of commands, including some proprietary userspace applications, I don't think disallowing the ioctls for processes with CAP_SYS_RAWIO will happen in the near future if ever. So lets just stop warning for processes with CAP_SYS_RAWIO for which ioctl is allowed. CC: Paolo Bonzini <pbonzini@redhat.com> CC: James Bottomley <JBottomley@parallels.com> CC: linux-scsi@vger.kernel.org Acked-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-14block: fail SCSI passthrough ioctls on partition devicesPaolo Bonzini
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and will pass the command to the underlying block device. This is well-known, but it is also a large security problem when (via Unix permissions, ACLs, SELinux or a combination thereof) a program or user needs to be granted access only to part of the disk. This patch lets partitions forward a small set of harmless ioctls; others are logged with printk so that we can see which ioctls are actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred. Of course it was being sent to a (partition on a) hard disk, so it would have failed with ENOTTY and the patch isn't changing anything in practice. Still, I'm treating it specially to avoid spamming the logs. In principle, this restriction should include programs running with CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and /dev/sdb, it still should not be able to read/write outside the boundaries of /dev/sda2 independent of the capabilities. However, for now programs with CAP_SYS_RAWIO will still be allowed to send the ioctls. Their actions will still be logged. This patch does not affect the non-libata IDE driver. That driver however already tests for bd != bd->bd_contains before issuing some ioctl; it could be restricted further to forbid these ioctls even for programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> [ Make it also print the command name when warning - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-14block: add and use scsi_blk_cmd_ioctlPaolo Bonzini
Introduce a wrapper around scsi_cmd_ioctl that takes a block device. The function will then be enhanced to detect partition block devices and, in that case, subject the ioctls to whitelisting. Cc: linux-scsi@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: James Bottomley <JBottomley@parallels.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-19block: drop unnecessary blk_get/put_queue() in scsi_cmd_ioctl() and blk_get_tg()Tejun Heo
blk_get/put_queue() in scsi_cmd_ioctl() and throtl_get_tg() are completely bogus. The caller must have a reference to the queue on entry and taking an extra reference doesn't change anything. For scsi_cmd_ioctl(), the only effect is that it ends up checking QUEUE_FLAG_DEAD on entry; however, this is bogus as queue can die right after blk_get_queue(). Dead queue should be and is handled in request issue path (it's somewhat broken now but that's a separate problem and doesn't affect this one much). throtl_get_tg() incorrectly assumes that q is rcu freed. Also, it doesn't check return value of blk_get_queue(). If the queue is already dead, it ends up doing an extra put. Drop them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2010-11-10block: take care not to overflow when calculating total iov lengthJens Axboe
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-11-04block/scsi_ioctl.c: quiet sparse noiseH Hartley Sweeten
Quiet sparse noise about symbol's not being declared. Symbol blk_default_cmd_filter is only used locally and should be static. The function blk_scsi_ioctl_init() is a fs_initcall and should also be static. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: call blk_scsi_ioctl_init()FUJITA Tomonori
Currently, blk_scsi_ioctl_init() is not called since it lacks an initcall marking. This causes the command table to be unitialized, hence somce commands are block when they should not have been. This fixes a regression introduced by commit 018e0446890661504783f92388ecce7138c1566d Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: get rid of queue-private command filterJens Axboe
The initial patches to support this through sysfs export were broken and have been if 0'ed out in any release. So lets just kill the code and reclaim some space in struct request_queue, if anyone would later like to fixup the sysfs bits, the git history can easily restore the removed bits. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: add rq->resid_lenTejun Heo
rq->data_len served two purposes - the length of data buffer on issue and the residual count on completion. This duality creates some headaches. First of all, block layer and low level drivers can't really determine what rq->data_len contains while a request is executing. It could be the total request length or it coulde be anything else one of the lower layers is using to keep track of residual count. This complicates things because blk_rq_bytes() and thus [__]blk_end_request_all() relies on rq->data_len for PC commands. Drivers which want to report residual count should first cache the total request length, update rq->data_len and then complete the request with the cached data length. Secondly, it makes requests default to reporting full residual count, ie. reporting that no data transfer occurred. The residual count is an exception not the norm; however, the driver should clear rq->data_len to zero to signify the normal cases while leaving it alone means no data transfer occurred at all. This reverse default behavior complicates code unnecessarily and renders block PC on some drivers (ide-tape/floppy) unuseable. This patch adds rq->resid_len which is used only for residual count. While at it, remove now unnecessasry blk_rq_bytes() caching in ide_pc_intr() as rq->data_len is not changed anymore. Boaz : spotted missing conversion in osd Sergei : spotted too early conversion to blk_rq_bytes() in ide-tape [ Impact: cleanup residual count handling, report 0 resid by default ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Doug Gilbert <dgilbert@interlog.com> Cc: Mike Miller <mike.miller@hp.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: don't init rq fields unnecessarilyTejun Heo
blk_get_request() always returns properly zeroed requests. Don't set fields to zero/NULL unnecessarily. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: kill rq->dataTejun Heo
Now that all block request data transfer is done via bio, rq->data isn't used. Kill it. While at it, make the roles of rq->special and buffer clear. [ Impact: drop now unncessary field from struct request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com>
2009-04-22block: fix SG_IO vector request data length handlingTejun Heo
Impact: fix SG_IO behavior such that it matches the documentation SG_IO howto says that if ->dxfer_len and sum of iovec disagress, the shorter one wins. However, the current implementation returns -EINVAL for such cases. Trim iovc if it's longer than ->dxfer_len. This patch uses iov_*() helpers which take struct iovec * by casting struct sg_iovec * to it. sg_iovec is always identical to iovec and this will be further cleaned up with later patches. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15block: fix SG_IO to return a proper error valueFUJITA Tomonori
blk_rq_unmap_user() returns -EFAULT if a program passes an invalid address to kernel. SG_IO path needs to pass the returned value to user space instead of ignoring it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26block: WARN in __blk_put_request() for potential bio leakBoaz Harrosh
Put a WARN_ON in __blk_put_request if it is about to leak bio(s). This is a serious bug that can happen in error handling code paths. For this to work I have fixed a couple of places in block/ where request->bio != NULL ownership was not honored. And a small cleanup at sg_io() while at it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29scsi-ioctl: use clock_t <> jiffiesMilton Miller
Convert the timeout ioctl scalling to use the clock_t functions which are much more accurate with some USER_HZ vs HZ combinations. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-05Enforce a minimum SG_IO timeoutLinus Torvalds
There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] switch sg_scsi_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] pass mode instead of file to sg_io()Al Viro
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09SG_IO block filter whitelist missing MMC SET READ AHEAD commandxiphmont@xiph.org
I have another request for the block filter SG_IO command whitelist, specifically the MMC streaming command set SET READ AHEAD command. The command applies only to MMC CDROM/DVDROM drives with the streaming optional feature set. The command is useful to cdparanoia in that it allows explicit cache control side effects that are, on many drives, cdparanoia's most efficient way to flush/disable the media cache on cdrom drives. I am aware of no reason why it should not be accessible from usespace. Also note that the command is already fully accessible through the SCSI-native version of the SG_IO ioctl as well as the traditional SG interface. The command is only being refused on block devices. That means that on a typical stock distro, the command is available through /dev/sg* but not /dev/scd* although both are typically available and accessible. Filtering the command is not providing any protection, only a confusing inconsistency. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: rename blk_scsi_cmd_filter to blk_cmd_filterFUJITA Tomonori
Technically, the cmd_filter would be applied to other protocols though it's unlikely to happen. Putting SCSI stuff to request_queue is kinda layer violation. So let's rename it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-27block: move cmdfilter from gendisk to request_queueFUJITA Tomonori
cmd_filter works only for the block layer SG_IO with SCSI block devices. It breaks scsi/sg.c, bsg, and the block layer SG_IO with SCSI character devices (such as st). We hit a kernel crash with them. The problem is that cmd_filter code accesses to gendisk (having struct blk_scsi_cmd_filter) via inode->i_bdev->bd_disk. It works for only SCSI block device files. With character device files, inode->i_bdev leads you to struct cdev. inode->i_bdev->bd_disk->blk_scsi_cmd_filter isn't safe. SCSI ULDs don't expose gendisk; they keep it private. bsg needs to be independent on any protocols. We shouldn't change ULDs to expose their gendisk. This patch moves struct blk_scsi_cmd_filter from gendisk to request_queue, a common object, which eveyone can access to. The user interface doesn't change; users can change the filters via /sys/block/. gendisk has a pointer to request_queue so the cmd_filter code accesses to struct blk_scsi_cmd_filter. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-30[SCSI] block: Fix miscalculation of sg_io timeout in CDROM_SEND_PACKET handler.Tim Wright
It seems cdrwtool in the udftools has been unusable on "modern" kernels for some time. A Google search reveals many people with the same issue but no solution (cdrwtool fails to format the disk). After spending some time tracking down the issue, it comes down to the following: The udftools still use the older CDROM_SEND_PACKET interface to send things like FORMAT_UNIT through to the drive. They should really be updated, but that's another story. Since most distros are using libata now, the cd or dvd burner appears as a SCSI device, and we wind up in block/scsi_ioctl.c. Here, the code tries to take the "struct cdrom_generic_command" and translate it and stuff it into a "struct sg_io_hdr" structure so it can pass it to the modern sg_io() routine instead. Unfortunately, there is one error, or rather an omission in the translation. The timeout that is passed in in the "struct cdrom_generic_command" is in HZ=100 units, and this is modified and correctly converted to jiffies by use of clock_t_to_jiffies(). However, a little further down, this cgc.timeout value in jiffies is simply copied into the sg_io_hdr timeout, which should be in milliseconds. Since most modern x86 kernels seems to be getting build with HZ=250, the timeout that is passed to sg_io and eventually converted to the timeout_per_command member of the scsi_cmnd structure is now four times too small. Since cdrwtool tries to set the timeout to one hour for the FORMAT_UNIT command, and it takes about 20 minutes to format a 4x CDRW, the SCSI error-handler kicks in after the FORMAT_UNIT completes because it took longer than the incorrectly-calculated timeout. [jejb: fix up whitespace] Signed-off-by: Tim Wright <timw@splhi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
