path: root/block
2007-05-01cfq-iosched: fix alias + front merge bugJens Axboe
There's a really rare and obscure bug in CFQ, that causes a crash in cfq_dispatch_insert() due to rq == NULL. One example of that is seen here: http://lkml.org/lkml/2007/4/15/41 Neil correctly diagnosed the situation for how this can happen, read that analysis here: http://lkml.org/lkml/2007/4/25/57 This looks like it requires md to trigger, even though it should potentially be possible to due with O_DIRECT (at least if you edit the kernel and doctor some of the unplug calls). The fix is to move the ->next_rq update to when we add a request to the rbtree. Then we remove the possibility for a request to exist in the rbtree code, but not have ->next_rq correctly updated. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09export blk_recount_segmentsNeil Brown
On Monday February 12, marcm@liquid-nexus.net wrote: > > > > Thanks for the quick response Neil unfortunately the kernel doesn't build with > > this patch due to a missing symbol: > > > > WARNING: "blk_recount_segments" [drivers/md/raid456.ko] undefined! > > > > Is that in another file that needs patching or within raid5.c? Yes. I keep forgetting about that bit. Sorry. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-29[PATCH] Fix SG_IO timeout jiffy conversionMike Christie
Commit 85e04e371b5a321b5df2bc3f8e0099a64fb087d7 cleaned up the timeout conversion, but did it exactly the wrong way. We get msecs from user space, and should convert them into jiffies. Not the other way around. Here is a fix with the overflow check sg.c has added in. This fixes DVD burnign with Nero. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [ "you'll be wanting a comma there" - Andrew ] Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] elevator: move clearing of unplug flag earlierLinas Vepstas
A flag was recently added to the elevator code to avoid performing an unplug when reuests are being re-queued. The goal of this flag was to avoid a deep recursion that can occur when re-queueing requests after a SCSI device/host reset. See http://lkml.org/lkml/2006/5/17/254 However, that fix added the flag near the bottom of a case statement, where an earlier break (in an if statement) could transport one out of the case, without setting the flag. This patch sets the flag earlier in the case statement. I re-discovered the deep recursion recently during testing; I was told that it was a known problem, and the fix to it was in the kernel I was testing. Indeed it was ... but it didn't fix the bug. With the patch below, I no longer see the bug. Signed-off by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jens Axboe <axboe@suse.de> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-02[PATCH] cfq-iosched: merging problemJens Axboe
Two issues: - The final return 1 should be a return 0, otherwise comparing cfqq is a noop. - bio_sync() only checks the sync flag, while rq_is_sync() checks both for READ and sync. The latter is what we want. Expand the bio check to include reads, and relax the restriction to allow merging of async io into sync requests. In the future we want to clean up the SYNC logic, right now it means both sync request (such as READ and O_DIRECT WRITE) and unplug-on-issue. Leave that for later. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] cfq-iosched: tighten allow merge criteriaJens Axboe
The logic in cfq_allow_merge() wasn't clear enough - basically allow merging for the same queues only. Do a fast check for 'rq and bio both sync/async' before doing the cfqq hash lookup. This is verified to work with the fixed elv_try_merge() from commit bb4067e34159648d394943d5e2a011f838bff22f. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] elevator: fixup typo in merge logicJens Axboe
The recent io scheduler allow_merge commit left the block layer with no merging, oops. This patch fixes that up. That means the CFQ change needs to be verified again, it might not fix the original bug now. But that's a seperate thing, I'll double check that tomorrow. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-20[PATCH] cfq-iosched: don't allow sync merges across queuesJens Axboe
Currently we allow any merge, even if the io originates from different processes. This can cause really bad starvation and unfairness, if those ios happen to be synchronous (reads or direct writes). So add a allow_merge hook to the io scheduler ops, so an io scheduler can help decide whether a bio/process combination may be merged with an existing request. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] Fixup blk_rq_unmap_user() APIJens Axboe
The blk_rq_unmap_user() API is not very nice. It expects the caller to know that rq->bio has to be reset to the original bio, and it will silently do nothing if that is not done. Instead make it explicit that we need to pass in the first bio, by expecting a bio argument. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] __blk_rq_unmap_user() fails to return errorJens Axboe
If the bio is user copied, the copy back could return -EFAULT. Make sure we return any error seen during unmapping. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] __blk_rq_map_user() doesn't need to grab the queue_lockJens Axboe
It was for driver private back_merge_fn hooks, but they don't exist anymore. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] Remove queue merging hooksJens Axboe
We have full flexibility of merging parameters now, so we can remove the hooks that define back/front/request merge strategies. Nobody is using them anymore. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-19[PATCH] ->nr_sectors and ->hard_nr_sectors are not used for BLOCK_PC requestsJens Axboe
It's a file system thing, for block requests the only size used in the io paths is ->data_len as it is in bytes, not sectors. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] Allow as-iosched to be unloadedJens Axboe
We implemented the missing bits to allow this some time ago, and they are integrated in AS. So remove the __module_get() to allow the module to be unloaded. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] Propagate down request sync flagJens Axboe
We need to do this, otherwise the io schedulers don't get access to the sync flag. Then they cannot tell the difference between a regular write and an O_DIRECT write, which can cause a performance loss. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-12[PATCH] remove unnecessary blk_queue_bounce in SG_IOFUJITA Tomonori
When I converted the original patch, I left unnecessary blk_queue_bounce in SG_IO. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-12[PATCH] fix SG_IO bio leakFUJITA Tomonori
This patch fixes bio leaks in SG_IO. rq->bio can be changed after io completion, so we need to reset rq->bio before calling blk_rq_unmap_user() http://marc.theaimsgroup.com/?l=linux-kernel&m=116570666807983&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-12[PATCH] remove blk_queue_activity_fnBoaz Harrosh
While working on bidi support at struct request level I have found that blk_queue_activity_fn is actually never used. The only user is in ide-probe.c with this code: /* enable led activity for disk drives only */ if (drive->media == ide_disk && hwif->led_act) blk_queue_activity_fn(q, hwif->led_act, drive); And led_act is never initialized anywhere. (Looking back at older kernels it was used in the PPC arch, but was removed around 2.6.18) Unless it is all for future use off course. (this patch is against linux-2.6-block.git as off 2006/12/4) Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-10[PATCH] io-accounting: read accountingAndrew Morton
Wire up read accounting for block devices, within submit_bio(). Cc: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: David Wright <daw@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fault-injection capability for disk IOAkinobu Mita
This patch provides fault-injection capability for disk IO. Boot option: fail_make_request=<probability>,<interval>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where disk IO can be issued safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/fail_make_request/interval /debug/fail_make_request/probability /debug/fail_make_request/specifies /debug/fail_make_request/times Example: fail_make_request=10,100,0,-1 echo 1 > /sys/blocks/hda/hda1/make-it-fail generic_make_request() on /dev/hda1 fails once per 10 times. Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert blockJosef Sipek
2006-12-08[PATCH] remove the old bd_mutex lockdep annotationPeter Zijlstra
Remove the old complex and crufty bd_mutex annotation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Allow NULL pointers in percpu_freeAlan Stern
The patch (as824b) makes percpu_free() ignore NULL arguments, as one would expect for a deallocation routine. (Note that free_percpu is #defined as percpu_free in include/linux/percpu.h.) A few callers are updated to remove now-unneeded tests for NULL. A few other callers already seem to assume that passing a NULL pointer to percpu_free() is okay! The patch also removes an unnecessary NULL check in percpu_depopulate(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (73 commits) [SCSI] aic79xx: Add ASC-29320LPE ids to driver [SCSI] stex: version update [SCSI] stex: change wait loop code [SCSI] stex: add new device type support [SCSI] stex: update device id info [SCSI] stex: adjust default queue length [SCSI] stex: add value check in hard reset routine [SCSI] stex: fix controller_info command handling [SCSI] stex: fix biosparam calculation [SCSI] megaraid: fix MMIO casts [SCSI] tgt: fix undefined flush_dcache_page() problem [SCSI] libsas: better error handling in sas_expander.c [SCSI] lpfc 8.1.11 : Change version number to 8.1.11 [SCSI] lpfc 8.1.11 : Misc Fixes [SCSI] lpfc 8.1.11 : Add soft_wwnn sysfs attribute, rename soft_wwn_enable [SCSI] lpfc 8.1.11 : Removed decoding of PCI Subsystem Id [SCSI] lpfc 8.1.11 : Add MSI (Message Signalled Interrupts) support [SCSI] lpfc 8.1.11 : Adjust LOG_FCP logging [SCSI] lpfc 8.1.11 : Fix Memory leaks [SCSI] lpfc 8.1.11 : Fix lpfc_multi_ring_support ...
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] Centralise definitions of sector_t and blkcnt_tMatthew Wilcox
CONFIG_LBD and CONFIG_LSF are spread into asm/types.h for no particularly good reason. Centralising the definition in linux/types.h means that arch maintainers don't need to bother adding it, as well as fixing the problem with x86-64 users being asked to make a decision that has absolutely no effect. The H8/300 porters seem particularly confused since I'm not aware of any microcontrollers that need to support 2TB filesystems. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] blktrace: don't return blktrace_seq from trace_note()Jens Axboe
Only the process notifier needs it, and it can set it manually. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-04[PATCH] blktrace: uninline trace_note()Jens Axboe
It's too large to inline. Additionally clean it up, by fast pathing the likely path. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[BLOCK] Cleanup unused variable passingJens Axboe
- ->init_queue() does not need the elevator passed in - ->put_request() is a hot path and need not have the queue passed in - cfq_update_io_seektime() does not need cfqd passed in Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] block: support larger block pc requestsMike Christie
This patch modifies blk_rq_map/unmap_user() and the cdrom and scsi_ioctl.c users so that it supports requests larger than bio by chaining them together. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] blktrace: add timestamp messageOlaf Kirch
This adds a new timestamp message to blktrace, giving the timeofday when we starting tracing. This helps user space correlate block trace events with eg an application strace. This requires a (compatible) update to blkparse. The changed blkparse is still able to process traces generated by older kernels, and older versions of blkparse should silently ignore the new records (because they have a pid of 0). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-11-22Merge ../scsi-rc-fixes-2.6James Bottomley
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-16[PATCH] scsi: clear garbage after CDBs on SG_IOTejun Heo
ATAPI devices transfer fixed number of bytes for CDBs (12 or 16). Some ATAPI devices choke when shorter CDB is used and the left bytes contain garbage. Block SG_IO cleared left bytes but SCSI SG_IO didn't. This patch makes SCSI SG_IO clear it and simplify CDB clearing in block SG_IO. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mathieu Fluhr <mfluhr@nero.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Douglas Gilbert <dougg@torque.net> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-15[SCSI] block: convert jiffies to msecs in scsi_ioctl()Hannes Reinecke
Use the proper conversion function for convert jiffies to msecs in sg_io(). Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-13[PATCH] Fix bad data direction in SG_IOJens Axboe
Contrary to what the name misleads you to believe, SG_DXFER_TO_FROM_DEV is really just a normal read seen from the device side. This patch fixes http://lkml.org/lkml/2006/10/13/100 Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] tidy "md: check bio address after mapping through partitions"Andrew Morton
Neil's xterms are too wide. Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] CFQ: request <-> request merging rr_list fixupJens Axboe
In very rare circumstances would we be pruning a merged request and at the same time delete the implicated cfqq from the rr_list, and not readd it when the merged request got added. This could cause io stalls until that process issued io again. Fix it up by putting the rr_list add handling into cfq_add_rq_rb(), identical to how pruning is handled in cfq_del_rq_rb(). This fixes a hang reproducible with fsx-linux. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] md: check bio address after mapping through partitions.NeilBrown
Partitions are not limited to live within a device. So we should range check after partition mapping. Note that 'maxsector' was being used for two different things. I have split off the second usage into 'old_sector' so that maxsector can be still be used for it's primary usage later in the function. Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] CFQ: bad locking in changed_ioprio()Jens Axboe
When the ioprio code recently got juggled a bit, a bug was introduced. changed_ioprio() is no longer called with interrupts disabled, so using plain spin_lock() on the queue_lock is a bug. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] CFQ: use irq safe locking in cfq_cic_link()Jens Axboe
If cfq_set_request() is called for a new process AND a non-fs io request (so that __GFP_WAIT may not be set), cfq_cic_link() may use spin_lock_irq() and spin_unlock_irq() with interrupts already disabled. Fix is to always use irq safe locking in cfq_cic_link() Acked-By: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] export clear_queue_congested and set_queue_congestedThomas Maier
Export the clear_queue_congested() and set_queue_congested() functions located in ll_rw_blk.c The functions are renamed to blk_clear_queue_congested() and blk_set_queue_congested(). (needed in the pktcdvd driver's bio write congestion control) Signed-off-by: Thomas Maier <balagi@justmail.de> Cc: Peter Osterlund <petero2@telia.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-12[PATCH] block layer: elv_iosched_show should get elv_list_lockVasily Tarasov
elv_iosched_show function iterates other elv_list, hence elv_list_lock should be got. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Signed-off-by: Vasily Tarasov <jens.axboe@oracle.com>
2006-10-12[PATCH] block layer: elevator_find function cleanupVasily Tarasov
We can easily produce search through the elevator list without introducing additional elevator_type variable. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
