commit a534dbe96e9929c7245924d8252d89048c23d569 upstream.
blk_rq_timed_out_timer() relied on blk_add_timer() never returning a
timer value of zero, but commit 7838c15b8dd18e78a523513749e5b54bda07b0cb
removed the code that bumped this value when it was zero.
Therefore when jiffies is near wrap we could get unlucky & not set the
timeout value correctly.
This patch uses a flag to indicate that the timeout value was set and so
handles jiffies wrap correctly, and it keeps all the logic in one
function so should be easier to maintain in the future.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
This reverts commit fb1e75389bd06fd5987e9cda1b4e0305c782f854.
"Benjamin S." <sbenni@gmx.de> reports that the patch in question
causes a big drop in sequential throughput for him, dropping from
200MB/sec down to only 70MB/sec.
Needs to be investigated more fully, for now lets just revert the
offending commit.
include/linux/blkdev.h
Currently we split seeky coop queues after 1s, which is too big. Below patch
marks seeky coop queue split_coop flag after one slice. After that, if new
requests come in, the queues will be splitted. Patch is suggested by Corrado.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Corrado Zoccolo <czoccolo@gmail.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Few weeks back, Shaohua Li had posted similar patch. I am reposting it
with more test results.
This patch does two things.
- Do not idle on async queues.
- It also changes the write queue depth CFQ drives (cfq_may_dispatch()).
Currently, we seem to driving queue depth of 1 always for WRITES. This is
true even if there is only one write queue in the system and all the logic
of infinite queue depth in case of single busy queue as well as slowly
increasing queue depth based on last delayed sync request does not seem to
be kicking in at all.
This patch will allow deeper WRITE queue depths (subjected to the other
WRITE queue depth contstraints like cfq_quantum and last delayed sync
request).
Shaohua Li had reported getting more out of his SSD. For me, I have got
one Lun exported from an HP EVA and when pure buffered writes are on, I
can get more out of the system. Following are test results of pure
buffered writes (with end_fsync=1) with vanilla and patched kernel. These
results are average of 3 sets of run with increasing number of threads.
AVERAGE[bufwfs][vanilla]
job Set NR ReadBW(KB/s) MaxClat(us) WriteBW(KB/s) MaxClat(us)
bufwfs 3 1 0 0 95349 474141
bufwfs 3 2 0 0 100282 806926
bufwfs 3 4 0 0 109989 2.7301e+06
bufwfs 3 8 0 0 116642 3762231
bufwfs 3 16 0 0 118230 6902970
AVERAGE[bufwfs] [patched kernel]
bufwfs 3 1 0 0 270722 404352
bufwfs 3 2 0 0 206770 1.06552e+06
bufwfs 3 4 0 0 195277 1.62283e+06
bufwfs 3 8 0 0 260960 2.62979e+06
bufwfs 3 16 0 0 299260 1.70731e+06
I also ran buffered writes along with some sequential reads and some
buffered reads going on in the system on a SATA disk because the potential
risk could be that we should not be driving queue depth higher in presence
of sync IO going to keep the max clat low.
With some random and sequential reads going on in the system on one SATA
disk I did not see any significant increase in max clat. So it looks like
other WRITE queue depth control logic is doing its job. Here are the
results.
AVERAGE[brr, bsr, bufw together] [vanilla]
brr 3 1 850 546345 0 0
bsr 3 1 14650 729543 0 0
bufw 3 1 0 0 23908 8274517
brr 3 2 981.333 579395 0 0
bsr 3 2 14149.7 1175689 0 0
bufw 3 2 0 0 21921 1.28108e+07
brr 3 4 898.333 1.75527e+06 0 0
bsr 3 4 12230.7 1.40072e+06 0 0
bufw 3 4 0 0 19722.3 2.4901e+07
brr 3 8 900 3160594 0 0
bsr 3 8 9282.33 1.91314e+06 0 0
bufw 3 8 0 0 18789.3 23890622
AVERAGE[brr, bsr, bufw mixed] [patched kernel]
brr 3 1 837 417973 0 0
bsr 3 1 14357.7 591275 0 0
bufw 3 1 0 0 24869.7 8910662
brr 3 2 1038.33 543434 0 0
bsr 3 2 13351.3 1205858 0 0
bufw 3 2 0 0 18626.3 13280370
brr 3 4 913 1.86861e+06 0 0
bsr 3 4 12652.3 1430974 0 0
bufw 3 4 0 0 15343.3 2.81305e+07
brr 3 8 890 2.92695e+06 0 0
bsr 3 8 9635.33 1.90244e+06 0 0
bufw 3 8 0 0 17200.3 24424392
So looks like it might make sense to include this patch.
Vivek
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
I triggered a lockdep warning as following.
[ INFO: possible circular locking dependency detected ]
2.6.33-rc2 #1
test_io_control/7357 is trying to acquire lock:
(blkio_list_lock){+.+...}, at: [<c053a990>] blkiocg_weight_write+0x82/0x9e
but task is already holding lock:
(&(&blkcg->lock)->rlock){......}, at: [<c053a949>] blkiocg_weight_write+0x3b/0x9e
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (&(&blkcg->lock)->rlock){......}:
[<c04583b7>] validate_chain+0x8bc/0xb9c
[<c0458dba>] __lock_acquire+0x723/0x789
[<c0458eb0>] lock_acquire+0x90/0xa7
[<c0692b0a>] _raw_spin_lock_irqsave+0x27/0x5a
[<c053a4e1>] blkiocg_add_blkio_group+0x1a/0x6d
[<c053cac7>] cfq_get_queue+0x225/0x3de
[<c053eec2>] cfq_set_request+0x217/0x42d
[<c052c8a6>] elv_set_request+0x17/0x26
[<c0532a0f>] get_request+0x203/0x2c5
[<c0532ae9>] get_request_wait+0x18/0x10e
[<c0533470>] __make_request+0x2ba/0x375
[<c0531985>] generic_make_request+0x28d/0x30f
[<c0532da7>] submit_bio+0x8a/0x8f
[<c04d827a>] submit_bh+0xf0/0x10f
[<c04d91d2>] ll_rw_block+0xc0/0xf9
[<f86e9705>] ext3_find_entry+0x319/0x544 [ext3]
[<f86eae58>] ext3_lookup+0x2c/0xb9 [ext3]
[<c04c3e1b>] do_lookup+0xd3/0x172
[<c04c56c8>] link_path_walk+0x5fb/0x95c
[<c04c5a65>] path_walk+0x3c/0x81
[<c04c5b63>] do_path_lookup+0x21/0x8a
[<c04c66cc>] do_filp_open+0xf0/0x978
[<c04c0c7e>] open_exec+0x1b/0xb7
[<c04c1436>] do_execve+0xbb/0x266
[<c04081a9>] sys_execve+0x24/0x4a
[<c04028a2>] ptregs_execve+0x12/0x18
-> #1 (&(&q->__queue_lock)->rlock){..-.-.}:
[<c053dd2a>] cfq_unlink_blkio_group+0x17/0x41
[<c053a6eb>] blkiocg_destroy+0x72/0xc7
[<c0467df0>] cgroup_diput+0x4a/0xb2
[<c04ca473>] dentry_iput+0x93/0xb7
[<c04ca4b3>] d_kill+0x1c/0x36
[<c04cb5c5>] dput+0xf5/0xfe
[<c04c6084>] do_rmdir+0x95/0xbe
[<c04c60ec>] sys_rmdir+0x10/0x12
[<c04027cc>] sysenter_do_call+0x12/0x32
-> #0 (blkio_list_lock){+.+...}:
[<c0458117>] validate_chain+0x61c/0xb9c
[<c06929fd>] _raw_spin_lock+0x1e/0x4e
[<c0467f1e>] cgroup_file_write+0xc6/0x1c0
[<c04bd2f3>] vfs_write+0x8c/0x116
[<c04bd7c6>] sys_write+0x3b/0x60
1 lock held by test_io_control/7357:
#0: (&(&blkcg->lock)->rlock){......}, at: [<c053a949>] blkiocg_weight_write+0x3b/0x9e
stack backtrace:
Pid: 7357, comm: test_io_control Not tainted 2.6.33-rc2 #1
Call Trace:
[<c045754f>] print_circular_bug+0x91/0x9d
[<c053a990>] ? blkiocg_weight_write+0x82/0x9e
[<c0454df5>] ? trace_hardirqs_off+0xb/0xd
[<c044d93a>] ? cpu_clock+0x2e/0x44
[<c050e6ec>] ? security_file_permission+0xf/0x11
[<c04bcdda>] ? rw_verify_area+0x8a/0xad
[<c0467e58>] ? cgroup_file_write+0x0/0x1c0
To prevent deadlock, we should take locks as following sequence:
blkio_list_lock -> queue_lock -> blkcg_lock.
The following patch should fix this bug.
Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
In cfq_should_preempt(), we currently allow some cases where a non-RT request
can preempt an ongoing RT cfqq timeslice. This should not happen.
Examples include:
o A sync_noidle wl type non-RT request pre-empting a sync_noidle wl type cfqq
on which we are idling.
o Once we have per-cgroup async queues, a non-RT sync request pre-empting a RT
async cfqq.
Signed-off-by: Divyesh Shah<dpshah@google.com>
It isn't used anymore, since AS was deleted.
DM does not want to know about partition offsets. Add a partition-aware
wrapper that DM can use when stacking block devices.
Acked-by: Mike Snitzer <snitzer@redhat.com>
Reviewed-by: Alasdair G Kergon <agk@redhat.com>
Discard alignment reporting for partitions was incorrect. Update to
match the algorithm used elsewhere.
The alignment can be negative (misaligned). Fix format string
accordingly.
The top device misalignment flag would not be set if the added bottom
device was already misaligned as opposed to causing a stacking failure.
Also massage the reporting so that an error is only returned if adding
the bottom device caused the misalignment. I.e. don't return an error
if the top is already flagged as misaligned.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
queue_sector_alignment_offset returned the wrong value which caused
partitions to report an incorrect alignment_offset. Since offset
alignment calculation is needed several places it has been split into a
separate helper function. The topology stacking function has been
updated accordingly.
Furthermore, comments have been added to clarify how the stacking
function works.
Tested-by: Mike Snitzer <snitzer@redhat.com>
seek_mean could be very big sometimes, using it as close criteria is meaningless
as this doen't improve any performance. So if it's big, let's fallback to
default value.
Signed-off-by: Shaohua Li<shaohua.li@intel.com>
The stacking code incorrectly scaled up the data offset in some cases
causing misaligned devices to report alignment. Rewrite the stacking
algorithm to remedy this and apply the same alignment principles to the
discard handling.
o CFQ now internally divides cfq queues in therr workload categories. sync-idle,
sync-noidle and async. Which workload to run depends primarily on rb_key
offset across three service trees. Which is a combination of mulitiple things
including what time queue got queued on the service tree.
There is one exception though. That is if we switched the prio class, say
we served some RT tasks and again started serving BE class, then with-in
BE class we always started with sync-noidle workload irrespective of rb_key
offset in service trees.
This can provide better latencies for sync-noidle workload in the presence
of RT tasks.
o This patch gets rid of that exception and which workload to run with-in
class always depends on lowest rb_key across service trees. The reason
being that now we have multiple BE class groups and if we always switch
to sync-noidle workload with-in group, we can potentially starve a sync-idle
workload with-in group. Same is true for async workload which will be in
root group. Also the workload-switching with-in group will become very
unpredictable as it now depends whether some RT workload was running in
the system or not.
Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
Acked-by: Corrado Zoccolo <czoccolo@gmail.com>
o Currently code does not seem to be using cfqd->nr_groups. Get rid of it.
o allow_merge() already checks if submitting task is pointing to same cfqq
as rq has been queued in. If everything is fine, we should not be having
a task in one cgroup and having a pointer to cfqq in other cgroup.
Well I guess in some situations it can happen and that is, when a random
IO queue has been moved into root cgroup for group_isolation=0. In
this case, tasks's cgroup/group is different from where actually cfqq is,
but this is intentional and in this case merging should be allowed.
The second situation is where due to close cooperator patches, multiple
processes can be sharing a cfqq. If everything implemented right, we should
not end up in a situation where tasks from different processes in different
groups are sharing the same cfqq as we allow merging of cooperating queues
only if they are in same group.
Commit 86b37281411cf1e9bc0a6b5406c45edb7bd9ea5d adds a check for
misaligned stacking offsets, but it's buggy since the defaults are 0.
Hence all dm devices that pass in a non-zero starting offset will
be marked as misaligned amd dm will complain.
A real fix is coming, in the mean time disable the discard granularity
check so that users don't worry about dm reporting about misaligned
devices.
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block:
cfq: set workload as expired if it doesn't have any slice left
Fix a CFQ crash in "for-2.6.33" branch of block tree
cfq: Remove wait_request flag when idle time is being deleted
cfq-iosched: commenting non-obvious initialization
cfq-iosched: Take care of corner cases of group losing share due to deletion
cfq-iosched: Get rid of cfqq wait_busy_done flag
cfq: Optimization for close cooperating queue searching
block,xd: Delay allocation of DMA buffers until device is known
drbd: Following the hmac change to SHASH (see linux commit 8bd1209cfff)
cfq-iosched: reduce write depth only if sync was delayed
When a group is resumed, if it doesn't have workload slice left,
we should set workload_expires as expired. Otherwise, we might
start from where we left in previous group by error.
Thanks the idea from Corrado.
I think my previous patch introduced a bug which can lead to CFQ hitting
BUG_ON().
The offending commit in for-2.6.33 branch is.
commit 7667aa0630407bc07dc38dcc79d29cc0a65553c1
Author: Vivek Goyal <vgoyal@redhat.com>
Date: Tue Dec 8 17:52:58 2009 -0500
While doing some stress testing on my box, I enountered following.
login: [ 3165.148841] BUG: scheduling while
atomic: swapper/0/0x10000100
[ 3165.149821] Modules linked in: cfq_iosched dm_multipath qla2xxx igb
scsi_transport_fc dm_snapshot [last unloaded: scsi_wait_scan]
[ 3165.149821] Pid: 0, comm: swapper Not tainted
2.6.32-block-for-33-merged-new #3
[ 3165.149821] Call Trace:
[ 3165.149821] <IRQ> [<ffffffff8103fab8>] __schedule_bug+0x5c/0x60
[ 3165.149821] [<ffffffff8103afd7>] ? __wake_up+0x44/0x4d
[ 3165.149821] [<ffffffff8153a979>] schedule+0xe3/0x7bc
[ 3165.149821] [<ffffffff8103a796>] ? cpumask_next+0x1d/0x1f
[ 3165.149821] [<ffffffffa000b21d>] ? cfq_dispatch_requests+0x6ba/0x93e
[cfq_iosched]
[ 3165.149821] [<ffffffff810422d8>] __cond_resched+0x2a/0x35
[cfq_iosched]
[ 3165.149821] [<ffffffff8153b1ee>] _cond_resched+0x2c/0x37
[ 3165.149821] [<ffffffff8100e2db>] is_valid_bugaddr+0x16/0x2f
[ 3165.149821] [<ffffffff811e4161>] report_bug+0x18/0xac
[ 3165.149821] [<ffffffff8100f1fc>] die+0x39/0x63
[ 3165.149821] [<ffffffff8153cde1>] do_trap+0x11a/0x129
[ 3165.149821] [<ffffffff8100d470>] do_invalid_op+0x96/0x9f
[cfq_iosched]
[ 3165.149821] [<ffffffff81034b4d>] ? enqueue_task+0x5c/0x67
[ 3165.149821] [<ffffffff8103ae83>] ? task_rq_unlock+0x11/0x13
[ 3165.149821] [<ffffffff81041aae>] ? try_to_wake_up+0x292/0x2a4
[ 3165.149821] [<ffffffff8100c935>] invalid_op+0x15/0x20
[cfq_iosched]
[ 3165.149821] [<ffffffff810df5a6>] ? virt_to_head_page+0xe/0x2f
[ 3165.149821] [<ffffffff811d8c2a>] blk_peek_request+0x191/0x1a7
[ 3165.149821] [<ffffffff811e5b8d>] ? kobject_get+0x1a/0x21
[ 3165.149821] [<ffffffff812c8d4c>] scsi_request_fn+0x82/0x3df
[ 3165.149821] [<ffffffff8110b2de>] ? bio_fs_destructor+0x15/0x17
[ 3165.149821] [<ffffffff811d931f>] __blk_run_queue+0x42/0x71
[ 3165.149821] [<ffffffff811d9403>] blk_run_queue+0x26/0x3a
[ 3165.149821] [<ffffffff812c8761>] scsi_run_queue+0x2de/0x375
[ 3165.149821] [<ffffffff812b60ac>] ? put_device+0x17/0x19
[ 3165.149821] [<ffffffff812c92d7>] scsi_next_command+0x3b/0x4b
[ 3165.149821] [<ffffffff812c9b9f>] scsi_io_completion+0x1c9/0x3f5
[ 3165.149821] [<ffffffff812c3c36>] scsi_finish_command+0xb5/0xbe
I think I have hit following BUG_ON() in cfq_dispatch_request().
BUG_ON(RB_EMPTY_ROOT(&cfqq->sort_list));
Please find attached the patch to fix it. I have done some stress testing
with it and have not seen it happening again.
o We should wait on a queue even after slice expiry only if it is empty. If
queue is not empty then continue to expire it.
o If we decide to keep the queue then make cfqq=NULL. Otherwise select_queue()
will return a valid cfqq and cfq_dispatch_request() can hit following
BUG_ON().
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Remove wait_request flag when idle time is being deleted, otherwise
it'll hit this path every time when a request is enqueued.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
Added a comment to explain the initialization of last_delayed_sync.
Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com>
If there is a sequential reader running in a group, we wait for next request
to come in that group after slice expiry and once new request is in, we expire
the queue. Otherwise we delete the group from service tree and group looses
its fair share.
So far I was marking a queue as wait_busy if it had consumed its slice and
it was last queue in the group. But this condition did not cover following
two cases.
1.If a request completed and slice has not expired yet. Next request comes
in and is dispatched to disk. Now select_queue() hits and slice has expired.
This group will be deleted. Because request is still in the disk, this queue
will never get a chance to wait_busy.
2.If request completed and slice has not expired yet. Before next request
comes in (delay due to think time), select_queue() hits and expires the
queue hence group. This queue never got a chance to wait busy.
Gui was hitting the boundary condition 1 and not getting fairness numbers
proportional to weight.
This patch puts the checks for above two conditions and improves the fairness
numbers for sequential workload on rotational media. Check in select_queue()
takes care of case 1 and additional check in should_wait_busy() takes care
of case 2.
Reported-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
o Get rid of wait_busy_done flag. This flag only tells we were doing wait
busy on a queue and that queue got request so expire it. That information
can easily be obtained by (cfq_cfqq_wait_busy() && queue_is_not_empty). So
remove this flag and keep code simple.
It doesn't make any sense to try to find out a close cooperating
queue if current cfqq is the only one in the group.
The introduction of ramp-up formula for async queue depths has
slowed down dirty page reclaim, by reducing async write performance.
This patch makes sure the formula kicks in only when sync request
was recently delayed.
Fix a crash during boot reported by Jeff Moyer. Fix the issue of accessing
cfqq after freeing it.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@carl.(none)>
After the merge of the IO controller patches, booting on my megaraid
box ran much slower. Vivek Goyal traced it down to megaraid discovery
creating tons of devices, each suffering a grace period when they later
kill that queue (if no device is found).
So lets use call_rcu() to batch these deferred frees, instead of taking
the grace period hit for each one.
o Now issues of blkio controller and CFQ in module mode should be fixed.
Enable the cfq group scheduling support in module mode.
o One of the goals of block IO controller is that it should be able to
support mulitple io control policies, some of which be operational at
higher level in storage hierarchy.
o To begin with, we had one io controlling policy implemented by CFQ, and
I hard coded the CFQ functions called by blkio. This created issues when
CFQ is compiled as module.
o This patch implements a basic dynamic io controlling policy registration
functionality in blkio. This is similar to elevator functionality where
ioschedulers register the functions dynamically.
o Now in future, when more IO controlling policies are implemented, these
can dynakically register with block IO controller.
o blkio controller is inside the kernel and cfq makes use of interfaces
exported by blkio. CFQ can be a module too, hence export symbols used
by CFQ.
With CLONE_IO, parent's io_context->nr_tasks is incremented, but never
decremented whenever copy_process() fails afterwards, which prevents
exit_io_context() from calling IO schedulers exit functions.
Give a task_struct to exit_io_context(), and call exit_io_context() instead of
put_io_context() in copy_process() cleanup path.
Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com>
With CLONE_IO, copy_io() increments both ioc->refcount and ioc->nr_tasks.
However exit_io_context() only decrements ioc->refcount if ioc->nr_tasks
reaches 0.
Always call put_io_context() in exit_io_context().
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
cfq_arm_slice_timer() has logic to disable idle window for SSD device. The same
thing should be done at cfq_select_queue() too, otherwise we will still see
idle window. This makes the nonrot check logic consistent in cfq.
Tests in a intel SSD with low_latency knob close, below patch can triple disk
thoughput for muti-thread sequential read.
It's currently not an allowed configuration, so express that in Kconfig.
They should not be declared inside some other file that's not related
to CFQ.
o rq_noidle() is supposed to tell cfq that do not expect a request after this
one, hence don't idle. But this does not seem to work very well. For example
for direct random readers, rq_noidle = 1 but there is next request coming
after this. Not idling, leads to a group not getting its share even if
group_isolation=1.
o The right solution for this issue is to scan the higher layers and set
right flag (WRITE_SYNC or WRITE_ODIRECT). For the time being, this single
line fix helps. This should not have any significant impact when we are
not using cgroups. I will later figure out IO paths in higher layer and
fix it.
o If a group is running only a random reader, then it will not have enough
traffic to keep disk busy and we will reduce overall throughput. This
should result in better latencies for random reader though. If we don't
idle on random reader service tree, then this random reader will experience
large latencies if there are other groups present in system with sequential
readers running in these.
o One solution suggested by corrado is that by default keep the random readers
or sync-noidle workload in root group so that during one dispatch round
we idle only once on sync-noidle tree. This means that all the sync-idle
workload queues will be in their respective group and we will see service
differentiation in those but not on sync-noidle workload.
o Provide a tunable group_isolation. If set, this will make sure that even
sync-noidle queues go in their respective group and we wait on these. This
provides stronger isolation between groups but at the expense of throughput
if group does not have enough traffic to keep the disk busy.
o By default group_isolation = 0
o Async queues are not per group. Instead these are system wide and maintained
in root group. Hence their workload slice length should be calculated
based on total number of queues in the system and not just queues in the
root group.
o As root group's default weight is 1000, make sure to charge async queue
more in terms of vtime so that it does not get more time on disk because
root group has higher weight.
o If a queue consumes its slice and then gets deleted from service tree, its
associated group will also get deleted from service tree if this was the
only queue in the group. That will make group loose its share.
o For the queues on which we have idling on and if these have used their
slice, wait a bit for these queues to get backlogged again and then
expire these queues so that group does not loose its share.
o Propagate blkio cgroup weight updation to associated cfq groups.
o If a task changes cgroup, drop reference to the cfqq associated with io
context and set cfqq pointer stored in ioc to NULL so that upon next request
arrival we will allocate a new queue in new group.
o Do not allow following three operations across groups for isolation.
- selection of co-operating queues
- preemtpions across groups
- request merging across groups.
o Async queues are currently global and not per group. Allow preemption of
an async queue if a sync queue in other group gets backlogged.
o Export disk time and sector used by a group to user space through cgroup
interface.
o Also export a "dequeue" interface to cgroup which keeps track of how many
a times a group was deleted from service tree. Helps in debugging.
o Some debugging aids for CFQ.
