elv_iosched_show function iterates other elv_list,
hence elv_list_lock should be got.
Also the question is: in elv_iosched_show, elv_iosched_store
q->elevator->elevator_type construction is used without locking q->queue_lock.
Is it expected?..
Signed-off-by: Vasily Tarasov <vtaras@openvz.org>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Contrary to what the name misleads you to believe, SG_DXFER_TO_FROM_DEV
is really just a normal read seen from the device side.
This patch fixes http://lkml.org/lkml/2006/10/13/100
This fixes some OOMs on 64bit systems with <4GB of RAM when accessing
the cdrom.
Do a safer check for when to enable DMA. Currently we enable ISA DMA
for cases that do not need it, resulting in OOM conditions when ZONE_DMA
runs out of space.
Signed-off-by: Andi Kleen <ak@suse.de>
Signed-off-by: Jens Axboe <axboe@suse.de>
Don't recurse back into the driver even if the unplug threshold is met,
when the driver asks for a requeue. This is both silly from a logical
point of view (requeues typically happen due to driver/hardware
shortage), and also dangerous since we could hit an endless request_fn
-> requeue -> unplug -> request_fn loop and crash on stack overrun.
Also limit blk_run_queue() to one level of recursion, similar to how
blk_start_queue() works.
This patch fixed a real problem with SLES10 and lpfc, and it could hit
any SCSI lld that returns non-zero from it's ->queuecommand() handler.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Repair /proc/devices early-termination regression.
2.6.16 broke /proc/devices. An application often gets an
EOF before the end of data is reached, if that application
uses a series of short read(2)s to access the data. I have
used read buffers of varying sizes with varying degrees
of unsuccess (larger sizes get further into the data than
smaller sizes, following a simple pattern). It appears
that the only safe way to get the data is to use a single
read buffer larger than all the data in /proc/devices.
The following example demonstates the problem:
# dd if=/proc/devices bs=1
Character devices:
1 mem
27+0 records in
27+0 records out
This patch is a backport of the fix recently accepted to
Linus's tree:
commit 68eef3b4791572ecb70249c7fb145bb3742dd899
[PATCH] Simplify proc/devices and fix early termination regression
It replaces the complex, state-machine algorithm introduced
in 2.6.16 with a simple algorithm, modeled on the implementation
of /proc/interrupts.
[akpm@osdl.org: cleanups, simplifications]
Signed-off-by: Joe Korty <joe.korty@ccur.com>
The low level PCI DMA mapping functions should handle it in most cases.
This should fix problems with depleting the DMA zone early. The old
code used precious GFP_DMA memory in many cases where it was not needed.
Cc: Jens Axboe <axboe@suse.de>
During testing of SLES10, we encountered a hang in the CFQ io scheduler.
Turns out the deferred slice expiry logic is buggy, so remove that for
now. We could be left with an idle queue that would never wake up. So
kill that logic, always expire immediately. Also fix a potential timer
race condition.
Patch looks bigger than it is, because it moves a function.
q->ordcolor must only be flipped on initial queueing of a hardbarrier
request.
Constructing ordered sequence and requeueing used to pass through
__elv_add_request() which flips q->ordcolor when it sees a barrier
request.
This patch separates out elv_insert() from __elv_add_request() and uses
elv_insert() when constructing ordered sequence and requeueing.
elv_insert() inserts the given request at the specified position and
does nothing else.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Acked-by: Jens Axboe <axboe@suse.de>
When issuing an SG_IO ioctl through sd that resulted in an unrecoverable
error, a nearly infinite retry loop was discovered. This is due to the
fact that the block layer SG_IO code is not setting up rq->retries. This
patch also fixes up the sg_scsi_ioctl path.
Signed-off-by: Brian King <brking@us.ibm.com>
q->ordcolor must not be flipped on SOFTBARRIER.
Previously, if a fs request which was being drained failed and got
requeued, blk_do_ordered() didn't allow it to be reissued, which causes
queue stall. This patch makes blk_do_ordered() use the sequence of each
request to determine whether a request can be issued or not. This fixes
the bug and simplifies code.
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of
cpudata, instead of allocating memory only for possible cpus.
As a preparation for changing that, we need to convert various 0 -> NR_CPUS
loops to use for_each_cpu().
(The above only applies to users of asm-generic/percpu.h. powerpc has gone it
alone and is presently only allocating memory for present CPUs, so it's
currently corrupting memory).
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: William Irwin <wli@holomorphy.com>
Cc: Andi Kleen <ak@muc.de>
Record I/O timing statistics
The start time is added to struct dm_io, an existing structure allocated
privately internally within dm and attached to each incoming bio.
We export disk_round_stats() from block/ll_rw_blk.c instead of creating a
private clone.
Signed-off-by: Jun'ichi "Nick" Nomura <j-nomura@ce.jp.nec.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This makes XFS barrier mounts succeed on my SCSI system.
Signed-off-by: Tetsuo Takata <takatatt@intellilink.co.jp>
Jens has decided that allowing the default scheduler to be a module is
a bug, and should not be allowed under kconfig. However, I find that
scenario useful for debugging, and wish for the kernel to be able to
handle this situation without OOPSing, if I enable such an option in
the .config directly. This patch dynamically checks for the presence
of the compiled-in default, and falls back to no-op, emitting a
suitable error message, when the default is not available
Tested for a range of boot options on 2.6.16-rc1-mm2.
Signed-off-by: Nate Diller <nate.diller@gmail.com>
My previous default iosched patch did a poor job dealing with the
'elevator=' boot-time option. The old behavior falls back to the
compiled-in default if the requested one is not registered at boot
time. This patch dynamically evaluates which default
to use, and emits a suitable error message when the requested scheduler
is not available. It also does the 'as' -> 'anticipatory' conversion
before elevator registration, which along with a modified registration
function, allows it to correctly indicate which default scheduler is
in use.
It can legally be called with interrupts/preemption enabled.
IDE lba48 can support full 64k request size, which overflows the
max_hw_sectors variable.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
A Christoph suggested that the /proc/devices file be converted to use the
seq_file interface. This patch does that.
I've obxerved one or two installation that had sufficiently large sans that
they overran the 4k limit on /proc/devices.
Signed-off-by: Neil Horman <nhorman@redhat.com>
If ordered tag isn't supported, request ordering for barrier
sequencing is performed by queue draining, which basically hangs the
request queue until elv_completed_request() reports completion of all
previous fs requests.
The condition check in elv_completed_request() was only performed for
fs requests. If a special request is queued between the last
to-be-drained request and the barrier sequence, draining is never
completed and the queue is stalled forever.
This patch moves the end-of-draining condition check such that it's
performed for all requests.
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Manual merge for trivial #include changes
Request completion can be a quite heavy process, since it needs to
iterate through the entire request and complete the bio's it holds.
This patch adds blk_complete_request() which moves this processing
into a dedicated block softirq.
It's a broken interface, it's done way too late. And apparently it triggers
slab problems in recent kernels as well (most likely after the generic dispatch
code was merged). So kill it, ide-cd is the only user of it.
elv_try_last_merge().
Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com>
linux/blkdev.h included twice
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
HDIO_GETGEO is implemented in most block drivers, and all of them have to
duplicate the code to copy the structure to userspace, as well as getting
the start sector. This patch moves that to common code [1] and adds a
->getgeo method to fill out the raw kernel hd_geometry structure. For many
drivers this means ->ioctl can go away now.
[1] the s390 block drivers are odd in this respect. xpram sets ->start
to 4 always which seems more than odd, and the dasd driver shifts
the start offset around, probably because of it's non-standard
sector size.
Cc: <mike.miller@hp.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Manual fixup for merge with Jens' "Suspend support for libata", commit
ID 9b847548663ef1039dd49f0eb4463d001e596bc3.
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X,
ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by
S390, 64BIT and COMPAT.
Reimplement handling of barrier requests.
* Flexible handling to deal with various capabilities of
target devices.
* Retry support for falling back.
* Tagged queues which don't support ordered tag can do ordered.
Separate out bio initialization part from __make_request. It
will be used by the following blk_ordered_reimpl.
add @uptodate argument to end_that_request_last() and @error
to rq_end_io_fn(). there's no generic way to pass error code
to request completion function, making generic error handling
of non-fs request difficult (rq->errors is driver-specific and
each driver uses it differently). this patch adds @uptodate
to end_that_request_last() and @error to rq_end_io_fn().
for fs requests, this doesn't really matter, so just using the
same uptodate argument used in the last call to
end_that_request_first() should suffice. imho, this can also
help the generic command-carrying request jens is working on.
Signed-off-by: tejun heo <htejun@gmail.com>
Signed-Off-By: Jens Axboe <axboe@suse.de>
the patch below marks various read-only variables in block/* as const,
so that gcc can optimize the use of them; eg gcc will replace the use by
the value directly now and will even remove the memory usage of these.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Originally from: Nick Piggin <nickpiggin@yahoo.com.au>
Move current_io_context out of the get_request fastpth. Also try to
streamline a few other things in this area.
Unlike other ioscheds, as-iosched handles alias by chaing them using
rq->queuelist. As aliased requests are very rare in the first place,
this complicates merge/dispatch handling without meaningful
performance improvement. This patch updates as-iosched to dump
aliased requests into dispatch queue as other ioscheds do.
Trivial manual merge fixup for usb_find_interface clashes.
Leave the overloaded "hotplug" word to susbsystems which are handling
real devices. The driver core does not "plug" anything, it just exports
the state to userspace and generates events.
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
This is just a basic cleanup. No change in functionality.
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
- export __blk_put_request and blk_execute_rq_nowait
needed for async REQ_BLOCK_PC requests
- seperate max_hw_sectors and max_sectors for block/scsi_ioctl.c and
SG_IO bio.c helpers per Jens's last comments. Since block/scsi_ioctl.c SG_IO was
already testing against max_sectors and SCSI-ml was setting max_sectors and
max_hw_sectors to the same value this does not change any scsi SG_IO behavior. It only
prepares ll_rw_blk.c, scsi_ioctl.c and bio.c for when SCSI-ml begins to set
a valid max_hw_sectors for all LLDs. Today if a LLD does not set it
SCSI-ml sets it to a safe default and some LLDs set it to a artificial low
value to overcome memory and feedback issues.
Note: Since we now cap max_sectors to BLK_DEF_MAX_SECTORS, which is 1024,
drivers that used to call blk_queue_max_sectors with a large value of
max_sectors will now see the fs requests capped to BLK_DEF_MAX_SECTORS.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
To send async requests we need these two functions exported.
Kill the arq->state poison statement in as_add_request(), it can trigger
for perfectly valid code that just reuses a request after io completion
instead of freeing it and allocating a new one. We probably should
introduce a blk_init_request() to start from scratch, but for now just
kill it as we will be removing the as specific poisoning soon.
Some leftover comments referring to drivers/block that are now block/.
They don't add any information we don't already have, so kill them.
With generic dispatch queue update, implicit former/latter request
handling using rq->queuelist.prev/next doesn't work as expected
anymore. Also, the only iosched dependent on this feature was
noop-iosched and it has been reimplemented to have its own
latter/former methods. This patch removes implicit former/latter
handling.
The original implementation directly used dispatch queue. As new
generic dispatch queue imposes stricter rules over ioscheds and
dispatch queue usage, this direct use becomes somewhat problematic.
This patch reimplements noop-iosched such that it complies to generic
iosched model better. Request merging with q->last_merge and
rq->queuelist.prev/next work again now.
