path: root/block
2007-04-21elevator: move clearing of unplug flag earlierLinas Vepstas
A flag was recently added to the elevator code to avoid performing an unplug when reuests are being re-queued. The goal of this flag was to avoid a deep recursion that can occur when re-queueing requests after a SCSI device/host reset. See http://lkml.org/lkml/2006/5/17/254 However, that fix added the flag near the bottom of a case statement, where an earlier break (in an if statement) could transport one out of the case, without setting the flag. This patch sets the flag earlier in the case statement. I re-discovered the deep recursion recently during testing; I was told that it was a known problem, and the fix to it was in the kernel I was testing. Indeed it was ... but it didn't fix the bug. With the patch below, I no longer see the bug. Signed-off by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-17scsi: clear garbage after CDBs on SG_IOTejun Heo
ATAPI devices transfer fixed number of bytes for CDBs (12 or 16). Some ATAPI devices choke when shorter CDB is used and the left bytes contain garbage. Block SG_IO cleared left bytes but SCSI SG_IO didn't. This patch makes SCSI SG_IO clear it and simplify CDB clearing in block SG_IO. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-29block layer: elv_iosched_show should get elv_list_lockVasily Tarasov
elv_iosched_show function iterates other elv_list, hence elv_list_lock should be got. Also the question is: in elv_iosched_show, elv_iosched_store q->elevator->elevator_type construction is used without locking q->queue_lock. Is it expected?.. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-29block: Fix bad data direction in SG_IOJens Axboe
Contrary to what the name misleads you to believe, SG_DXFER_TO_FROM_DEV is really just a normal read seen from the device side. This patch fixes http://lkml.org/lkml/2006/10/13/100 Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-07BLOCK: Fix bounce limit address checkAndi Kleen
This fixes some OOMs on 64bit systems with <4GB of RAM when accessing the cdrom. Do a safer check for when to enable DMA. Currently we enable ISA DMA for cases that do not need it, resulting in OOM conditions when ZONE_DMA runs out of space. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-20[PATCH] limit request_fn recursionJens Axboe
Don't recurse back into the driver even if the unplug threshold is met, when the driver asks for a requeue. This is both silly from a logical point of view (requeues typically happen due to driver/hardware shortage), and also dangerous since we could hit an endless request_fn -> requeue -> unplug -> request_fn loop and crash on stack overrun. Also limit blk_run_queue() to one level of recursion, similar to how blk_start_queue() works. This patch fixed a real problem with SLES10 and lpfc, and it could hit any SCSI lld that returns non-zero from it's ->queuecommand() handler. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-05-01[PATCH] Simplify proc/devices and fix early termination regressionAndrew Morton
Repair /proc/devices early-termination regression. 2.6.16 broke /proc/devices. An application often gets an EOF before the end of data is reached, if that application uses a series of short read(2)s to access the data. I have used read buffers of varying sizes with varying degrees of unsuccess (larger sizes get further into the data than smaller sizes, following a simple pattern). It appears that the only safe way to get the data is to use a single read buffer larger than all the data in /proc/devices. The following example demonstates the problem: # dd if=/proc/devices bs=1 Character devices: 1 mem 27+0 records in 27+0 records out This patch is a backport of the fix recently accepted to Linus's tree: commit 68eef3b4791572ecb70249c7fb145bb3742dd899 [PATCH] Simplify proc/devices and fix early termination regression It replaces the complex, state-machine algorithm introduced in 2.6.16 with a simple algorithm, modeled on the implementation of /proc/interrupts. [akpm@osdl.org: cleanups, simplifications] Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-08[PATCH] block: disable block layer bouncing for most memory on 64bit systemsAndi Kleen
The low level PCI DMA mapping functions should handle it in most cases. This should fix problems with depleting the DMA zone early. The old code used precious GFP_DMA memory in many cases where it was not needed. Signed-off-by: Andi Kleen <ak@suse.de> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] cfq-iosched: slice expiry fixupsJens Axboe
During testing of SLES10, we encountered a hang in the CFQ io scheduler. Turns out the deferred slice expiry logic is buggy, so remove that for now. We could be left with an idle queue that would never wake up. So kill that logic, always expire immediately. Also fix a potential timer race condition. Patch looks bigger than it is, because it moves a function. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
2006-02-08[PATCH] block: implement elv_insert and use it (fix ordcolor flipping bug)Tejun Heo
q->ordcolor must only be flipped on initial queueing of a hardbarrier request. Constructing ordered sequence and requeueing used to pass through __elv_add_request() which flips q->ordcolor when it sees a barrier request. This patch separates out elv_insert() from __elv_add_request() and uses elv_insert() when constructing ordered sequence and requeueing. elv_insert() inserts the given request at the specified position and does nothing else. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08[PATCH] blk: Fix SG_IO ioctl failure retry loopingJens Axboe
When issuing an SG_IO ioctl through sd that resulted in an unrecoverable error, a nearly infinite retry loop was discovered. This is due to the fact that the block layer SG_IO code is not setting up rq->retries. This patch also fixes up the sg_scsi_ioctl path. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-02-05[PATCH] block: request_queue->ordcolor must not be flipped on SOFTBARRIERTejun Heo
q->ordcolor must not be flipped on SOFTBARRIER. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] fix ordering on requeued request drainageJens Axboe
Previously, if a fs request which was being drained failed and got requeued, blk_do_ordered() didn't allow it to be reissued, which causes queue stall. This patch makes blk_do_ordered() use the sequence of each request to determine whether a request can be issued or not. This fixes the bug and simplifies code. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] percpu data: only iterate over possible CPUsEric Dumazet
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of cpudata, instead of allocating memory only for possible cpus. As a preparation for changing that, we need to convert various 0 -> NR_CPUS loops to use for_each_cpu(). (The above only applies to users of asm-generic/percpu.h. powerpc has gone it alone and is presently only allocating memory for present CPUs, so it's currently corrupting memory). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Cc: Anton Blanchard <anton@samba.org> Acked-by: William Irwin <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] device-mapper disk statistics: timingJun'ichi "Nick" Nomura
Record I/O timing statistics The start time is added to struct dm_io, an existing structure allocated privately internally within dm and attached to each incoming bio. We export disk_round_stats() from block/ll_rw_blk.c instead of creating a private clone. Signed-off-by: Jun'ichi "Nick" Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[BLOCK] A few kerneldoc fixupsJens Axboe
2006-01-24[BLOCK] ll_rw_blk: fix setting of ->ordered on initTetsuo Takata
This makes XFS barrier mounts succeed on my SCSI system. Signed-off-by: Tetsuo Takata <takatatt@intellilink.co.jp> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-24[BLOCK] elevator: allow default scheduler to potentially be modularNate Diller
Jens has decided that allowing the default scheduler to be a module is a bug, and should not be allowed under kconfig. However, I find that scenario useful for debugging, and wish for the kernel to be able to handle this situation without OOPSing, if I enable such an option in the .config directly. This patch dynamically checks for the presence of the compiled-in default, and falls back to no-op, emitting a suitable error message, when the default is not available Tested for a range of boot options on 2.6.16-rc1-mm2. Signed-off-by: Nate Diller <nate.diller@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-24[BLOCK] elevator: default choice selectionNate Diller
My previous default iosched patch did a poor job dealing with the 'elevator=' boot-time option. The old behavior falls back to the compiled-in default if the requested one is not registered at boot time. This patch dynamically evaluates which default to use, and emits a suitable error message when the requested scheduler is not available. It also does the 'as' -> 'anticipatory' conversion before elevator registration, which along with a modified registration function, allows it to correctly indicate which default scheduler is in use. Tested for a range of boot options on 2.6.16-rc1-mm2. Signed-off-by: Nate Diller <nate.diller@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-24[BLOCK] ll_rw_blk: use preempt-disabling disk_stat_add() in completionJens Axboe
It can legally be called with interrupts/preemption enabled. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-24[BLOCK] ll_rw_blk: make max_sectors and max_hw_sectors unsigned intsJens Axboe
IDE lba48 can support full 64k request size, which overflows the max_hw_sectors variable. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-16[BLOCK] elevator: if specified scheduler is not found, fall back to defaultJens Axboe
2006-01-16[BLOCK] elevator: Make elevator=as work again for anticipatoryChuck Ebbert
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-14[PATCH] convert /proc/devices to use seq_file interfaceNeil Horman
A Christoph suggested that the /proc/devices file be converted to use the seq_file interface. This patch does that. I've obxerved one or two installation that had sufficiently large sans that they overran the 4k limit on /proc/devices. Signed-off-by: Neil Horman <nhorman@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] fix queue stalling while barrier sequencingTejun Heo
If ordered tag isn't supported, request ordering for barrier sequencing is performed by queue draining, which basically hangs the request queue until elv_completed_request() reports completion of all previous fs requests. The condition check in elv_completed_request() was only performed for fs requests. If a special request is queued between the last to-be-drained request and the barrier sequence, draining is never completed and the queue is stalled forever. This patch moves the end-of-draining condition check such that it's performed for all requests. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge branch 'blk-softirq' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual merge for trivial #include changes
2006-01-09[BLOCK] ll_rw_blk: Enable out-of-order request completions through softirqJens Axboe
Request completion can be a quite heavy process, since it needs to iterate through the entire request and complete the bio's it holds. This patch adds blk_complete_request() which moves this processing into a dedicated block softirq. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK] Kill blk_attempt_remerge()Jens Axboe
It's a broken interface, it's done way too late. And apparently it triggers slab problems in recent kernels as well (most likely after the generic dispatch code was merged). So kill it, ide-cd is the only user of it. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK] scsi_ioctl: file can be NULL from ioctl_by_bdev()Jens Axboe
2006-01-09make elv_try_merge() static, kill the dead declaration ofCoywolf Qi Hunt
elv_try_last_merge(). Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK][TRIVIAL] ll_rw_blk: header included twiceNicolas Kaiser
linux/blkdev.h included twice Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-08[PATCH] Add block_device_operations.getgeo block device methodChristoph Hellwig
HDIO_GETGEO is implemented in most block drivers, and all of them have to duplicate the code to copy the structure to userspace, as well as getting the start sector. This patch moves that to common code [1] and adds a ->getgeo method to fill out the raw kernel hd_geometry structure. For many drivers this means ->ioctl can go away now. [1] the s390 block drivers are odd in this respect. xpram sets ->start to 4 always which seems more than odd, and the dasd driver shifts the start offset around, probably because of it's non-standard sector size. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jens Axboe <axboe@suse.de> Cc: <mike.miller@hp.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06Merge branch 'post-2.6.15' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual fixup for merge with Jens' "Suspend support for libata", commit ID 9b847548663ef1039dd49f0eb4463d001e596bc3. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[BLOCK] reimplement handling of barrier requestTejun Heo
Reimplement handling of barrier requests. * Flexible handling to deal with various capabilities of target devices. * Retry support for falling back. * Tagged queues which don't support ordered tag can do ordered. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] ll_rw_blk: separate out bio init part from __make_requestTejun Heo
Separate out bio initialization part from __make_request. It will be used by the following blk_ordered_reimpl. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] add @uptodate to end_that_request_last() and @error to rq_end_io_fn()Tejun Heo
add @uptodate argument to end_that_request_last() and @error to rq_end_io_fn(). there's no generic way to pass error code to request completion function, making generic error handling of non-fs request difficult (rq->errors is driver-specific and each driver uses it differently). this patch adds @uptodate to end_that_request_last() and @error to rq_end_io_fn(). for fs requests, this doesn't really matter, so just using the same uptodate argument used in the last call to end_that_request_first() should suffice. imho, this can also help the generic command-carrying request jens is working on. Signed-off-by: tejun heo <htejun@gmail.com> Signed-Off-By: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] mark some block/ variables consArjan van de Ven
the patch below marks various read-only variables in block/* as const, so that gcc can optimize the use of them; eg gcc will replace the use by the value directly now and will even remove the memory usage of these. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] ll_rw_blk: fastpath get_request()Jens Axboe
Originally from: Nick Piggin <nickpiggin@yahoo.com.au> Move current_io_context out of the get_request fastpth. Also try to streamline a few other things in this area. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] as-iosched: update alias handlingTejun Heo
Unlike other ioscheds, as-iosched handles alias by chaing them using rq->queuelist. As aliased requests are very rare in the first place, this complicates merge/dispatch handling without meaningful performance improvement. This patch updates as-iosched to dump aliased requests into dispatch queue as other ioscheds do. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-19[PATCH] block: Cleanup CDROMEJECT ioctlBen Collins
This is just a basic cleanup. No change in functionality. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[SCSI] seperate max_sectors from max_hw_sectorsMike Christie
- export __blk_put_request and blk_execute_rq_nowait needed for async REQ_BLOCK_PC requests - seperate max_hw_sectors and max_sectors for block/scsi_ioctl.c and SG_IO bio.c helpers per Jens's last comments. Since block/scsi_ioctl.c SG_IO was already testing against max_sectors and SCSI-ml was setting max_sectors and max_hw_sectors to the same value this does not change any scsi SG_IO behavior. It only prepares ll_rw_blk.c, scsi_ioctl.c and bio.c for when SCSI-ml begins to set a valid max_hw_sectors for all LLDs. Today if a LLD does not set it SCSI-ml sets it to a safe default and some LLDs set it to a artificial low value to overcome memory and feedback issues. Note: Since we now cap max_sectors to BLK_DEF_MAX_SECTORS, which is 1024, drivers that used to call blk_queue_max_sectors with a large value of max_sectors will now see the fs requests capped to BLK_DEF_MAX_SECTORS. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-14[SCSI] export blk layer functions needed for blk_execute_rq_nowaitMike Christie
To send async requests we need these two functions exported. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-21[PATCH] as-iosched: remove state assertion in as_add_request()Jens Axboe
Kill the arq->state poison statement in as_add_request(), it can trigger for perfectly valid code that just reuses a request after io completion instead of freeing it and allocating a new one. We probably should introduce a blk_init_request() to start from scratch, but for now just kill it as we will be removing the as specific poisoning soon. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[BLOCK] new block/ directory comment tidyCoywolf Qi Hunt
Some leftover comments referring to drivers/block that are now block/. They don't add any information we don't already have, so kill them. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Jens Axboe <axboe@suse.de>
