Linux 4.1.42
* tag 'v4.1.42': (146 commits)
Linux 4.1.42
mm: fix new crash in unmapped_area_topdown()
mm: larger stack guard gap, between vmas
alarmtimer: Rate limit periodic intervals
MIPS: Fix bnezc/jialc return address calculation
usb: dwc3: exynos fix axius clock error path to do cleanup
genirq: Release resources in __setup_irq() error path
swap: cond_resched in swap_cgroup_prepare()
mm/memory-failure.c: use compound_head() flags for huge pages
USB: gadgetfs, dummy-hcd, net2280: fix locking for callbacks
usb: xhci: ASMedia ASM1042A chipset need shorts TX quirk
drivers/misc/c2port/c2port-duramar2150.c: checking for NULL instead of IS_ERR()
usb: r8a66597-hcd: decrease timeout
usb: r8a66597-hcd: select a different endpoint on timeout
USB: gadget: dummy_hcd: fix hub-descriptor removable fields
[media] pvrusb2: reduce stack usage pvr2_eeprom_analyze()
usb: core: fix potential memory leak in error path during hcd creation
USB: hub: fix SS max number of ports
iio: proximity: as3935: recalibrate RCO after resume
staging: rtl8188eu: prevent an underflow in rtw_check_beacon_data()
[ Upstream commit 223220356d5ebc05ead9a8d697abb0c0a906fc81 ]
The code in block/partitions/msdos.c recognizes FreeBSD, OpenBSD
and NetBSD partitions and does a reasonable job picking out OpenBSD
and NetBSD UFS subpartitions.
But for FreeBSD the subpartitions are always "bad".
Kernel: <bsd:bad subpartition - ignored
Though all 3 of these BSD systems use UFS as a file system, only
FreeBSD uses relative start addresses in the subpartition
declarations.
The following patch fixes this for FreeBSD partitions and leaves
the code for OpenBSD and NetBSD intact:
Signed-off-by: Richard Narron <comet.berkeley@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Linux 4.1.41
* tag 'v4.1.41': (473 commits)
Linux 4.1.41
mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp
xc2028: Fix use-after-free bug properly
iio: proximity: as3935: fix as3935_write
ipx: call ipxitf_put() in ioctl error path
sched/fair: Initialize throttle_count for new task-groups lazily
sched/fair: Do not announce throttled next buddy in dequeue_task_fair()
iio: dac: ad7303: fix channel description
mwifiex: pcie: fix cmd_buf use-after-free in remove/reset
rtlwifi: rtl8821ae: setup 8812ae RFE according to device type
ARM: tegra: paz00: Mark panel regulator as enabled on boot
fs/xattr.c: zero out memory copied to userspace in getxattr
vfio/type1: Remove locked page accounting workqueue
crypto: algif_aead - Require setkey before accept(2)
staging: gdm724x: gdm_mux: fix use-after-free on module unload
drm/ttm: fix use-after-free races in vm fault handling
f2fs: sanity check segment count
ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf
ipv6: initialize route null entry in addrconf_init()
rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit ac34f15e0c6d2fd58480052b6985f6991fb53bcc ]
When tearing down a block device early in its lifetime, userspace may
still be performing discovery actions like blkdev_ioctl() to re-read
partitions.
The nvdimm_revalidate_disk() implementation depends on
disk->driverfs_dev to be valid at entry. However, it is set to NULL in
del_gendisk() and fatally this is happening *before* the disk device is
deleted from userspace view.
There's no reason for del_gendisk() to clear ->driverfs_dev. That
device is the parent of the disk. It is guaranteed to not be freed
until the disk, as a child, drops its ->parent reference.
We could also fix this issue locally in nvdimm_revalidate_disk() by
using disk_to_dev(disk)->parent, but lets fix it globally since
->driverfs_dev follows the lifetime of the parent. Longer term we
should probably just add a @parent parameter to add_disk(), and stop
carrying this pointer in the gendisk.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffffa00340a8>] nvdimm_revalidate_disk+0x18/0x90 [libnvdimm]
CPU: 2 PID: 538 Comm: systemd-udevd Tainted: G O 4.4.0-rc5 #2257
Call Trace:
[<ffffffff8143e5c7>] rescan_partitions+0x87/0x2c0
[<ffffffff810f37f9>] ? __lock_is_held+0x49/0x70
[<ffffffff81438c62>] __blkdev_reread_part+0x72/0xb0
[<ffffffff81438cc5>] blkdev_reread_part+0x25/0x40
[<ffffffff8143982d>] blkdev_ioctl+0x4fd/0x9c0
[<ffffffff811246c9>] ? current_kernel_time64+0x69/0xd0
[<ffffffff812916dd>] block_ioctl+0x3d/0x50
[<ffffffff81264c38>] do_vfs_ioctl+0x308/0x560
[<ffffffff8115dbd1>] ? __audit_syscall_entry+0xb1/0x100
[<ffffffff810031d6>] ? do_audit_syscall_entry+0x66/0x70
[<ffffffff81264f09>] SyS_ioctl+0x79/0x90
[<ffffffff81902672>] entry_SYSCALL_64_fastpath+0x12/0x76
Reported-by: Robert Hu <robert.hu@intel.com>
[ Upstream commit 994b78327458ea14a1743196ee0560c73ace37f3 ]
When blkcg_init_queue() fails midway after creating a new blkg, it
performs kfree() directly; however, this doesn't free the policy data
areas. Make it use blkg_free() instead. In turn, blkg_free() is
updated to handle root request_list special case.
While this fixes a possible memory leak, it's on an unlikely failure
path of an already cold path and the size leaked per occurrence is
miniscule too. I don't think it needs to be tagged for -stable.
Cc: Vivek Goyal <vgoyal@redhat.com>
[ Upstream commit ec13b1d6f0a0457312e615335ce8ceb07da50a11 ]
Currently, blkcg does a minor optimization where the root blkcg is
created when the first blkcg policy is activated on a queue and
destroyed on the deactivation of the last. On systems where blkcg is
configured but not used, this saves one blkcg_gq struct per queue. On
systems where blkcg is actually used, there's no difference. The only
case where this can lead to any meaninful, albeit still minute, save
in memory consumption is when all blkcg policies are deactivated after
being widely used in the system, which is a hihgly unlikely scenario.
The conditional existence of root blkcg_gq has already created several
bugs in blkcg and became an issue once again for the new per-cgroup
wb_congested mechanism for cgroup writeback support leading to a NULL
dereference when no blkcg policy is active. This is really not worth
bothering with. This patch makes blkcg always allocate and link the
root blkcg_gq and release it only on queue destruction.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Linux 4.1.38
* tag 'v4.1.38': (109 commits)
Linux 4.1.38
gro: Allow tunnel stacking in the case of FOU/GUE
tunnels: Don't apply GRO to multiple layers of encapsulation.
net: ipv4: Convert IP network timestamps to be y2038 safe
ipip: Properly mark ipip GRO packets as encapsulated.
sg_write()/bsg_write() is not fit to be called under KERNEL_DS
fs: exec: apply CLOEXEC before changing dumpable task flags
IB/cma: Fix a race condition in iboe_addr_get_sgid()
Revert "ALSA: usb-audio: Fix race at stopping the stream"
kvm: nVMX: Allow L1 to intercept software exceptions (#BP and #OF)
drivers/gpu/drm/ast: Fix infinite loop if read fails
target/user: Fix use-after-free of tcmu_cmds if they are expired
kernel/debug/debug_core.c: more properly delay for secondary CPUs
scsi: avoid a permanent stop of the scsi device's request queue
IB/multicast: Check ib_find_pkey() return value
IPoIB: Avoid reading an uninitialized member variable
block_dev: don't test bdev->bd_contains when it is not stable
btrfs: limit async_work allocation and worker func duration
mm/vmscan.c: set correct defer count for shrinker
Input: drv260x - fix input device's parent assignment
[ Upstream commit 128394eff343fc6d2f32172f03e24829539c5835 ]
Both damn things interpret userland pointers embedded into the payload;
worse, they are actually traversing those. Leaving aside the bad
API design, this is very much _not_ safe to call with KERNEL_DS.
Bail out early if that happens.
Cc: stable@vger.kernel.org
Linux 4.1.33
* tag 'v4.1.33': (1760 commits)
Linux 4.1.33
Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()"
x86/AMD: Apply erratum 665 on machines without a BIOS fix
x86/paravirt: Do not trace _paravirt_ident_*() functions
ovl: listxattr: use strnlen()
ovl: remove posix_acl_default from workdir
serial: 8250: added acces i/o products quad and octal serial cards
sysfs: correctly handle read offset on PREALLOC attrs
sysfs: correctly handle short reads on PREALLOC attrs.
kernfs: don't depend on d_find_any_alias() when generating notifications
dm crypt: fix free of bad values after tfm allocation failure
dm crypt: fix error with too large bios
dm log writes: fix check of kthread_run() return value
dm log writes: fix bug with too large bios
dm log writes: move IO accounting earlier to fix error path
NFSv4.x: Fix a refcount leak in nfs_callback_up_net
xfs: prevent dropping ioend completions during buftarg wait
xfs: fix superblock inprogress check
USB: serial: option: add WeTelecom 0x6802 and 0x6803 products
USB: avoid left shift by -1
[ Upstream commit 1b856086813be9371929b6cc62045f9fd470f5a0 ]
blk_set_queue_dying() can be called while another thread is
submitting I/O or changing queue flags, e.g. through dm_stop_queue().
Hence protect the QUEUE_FLAG_DYING flag change with locking.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 77da160530dd1dc94f6ae15a981f24e5f0021e84 ]
I got a KASAN report of use-after-free:
BUG: KASAN: use-after-free in klist_iter_exit+0x61/0x70 at addr ffff8800b6581508
Read of size 8 by task trinity-c1/315
BUG kmalloc-32 (Not tainted): kasan: bad access detected
Disabling lock debugging due to kernel taint
INFO: Allocated in disk_seqf_start+0x66/0x110 age=144 cpu=1 pid=315
___slab_alloc+0x4f1/0x520
__slab_alloc.isra.58+0x56/0x80
kmem_cache_alloc_trace+0x260/0x2a0
traverse+0x176/0x860
seq_read+0x7e3/0x11a0
proc_reg_read+0xbc/0x180
do_loop_readv_writev+0x134/0x210
do_readv_writev+0x565/0x660
vfs_readv+0x67/0xa0
do_preadv+0x126/0x170
SyS_preadv+0xc/0x10
do_syscall_64+0x1a1/0x460
return_from_SYSCALL_64+0x0/0x6a
INFO: Freed in disk_seqf_stop+0x42/0x50 age=160 cpu=1 pid=315
__slab_free+0x17a/0x2c0
kfree+0x20a/0x220
traverse+0x3b5/0x860
vfs_readv+0x67/0xa0
SyS_preadv+0xc/0x10
CPU: 1 PID: 315 Comm: trinity-c1 Tainted: G B 4.7.0+ #62
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
ffffea0002d96000 ffff880119b9f918 ffffffff81d6ce81 ffff88011a804480
ffff8800b6581500 ffff880119b9f948 ffffffff8146c7bd ffff88011a804480
ffffea0002d96000 ffff8800b6581500 fffffffffffffff4 ffff880119b9f970
Call Trace:
[<ffffffff81d6ce81>] dump_stack+0x65/0x84
[<ffffffff8146c7bd>] print_trailer+0x10d/0x1a0
[<ffffffff814704ff>] object_err+0x2f/0x40
[<ffffffff814754d1>] kasan_report_error+0x221/0x520
[<ffffffff8147590e>] __asan_report_load8_noabort+0x3e/0x40
[<ffffffff83888161>] klist_iter_exit+0x61/0x70
[<ffffffff82404389>] class_dev_iter_exit+0x9/0x10
[<ffffffff81d2e8ea>] disk_seqf_stop+0x3a/0x50
[<ffffffff8151f812>] seq_read+0x4b2/0x11a0
[<ffffffff815f8fdc>] proc_reg_read+0xbc/0x180
[<ffffffff814b24e4>] do_loop_readv_writev+0x134/0x210
[<ffffffff814b4c45>] do_readv_writev+0x565/0x660
[<ffffffff814b8a17>] vfs_readv+0x67/0xa0
[<ffffffff814b8de6>] do_preadv+0x126/0x170
[<ffffffff814b92ec>] SyS_preadv+0xc/0x10
This problem can occur in the following situation:
open()
- pread()
- .seq_start()
- iter = kmalloc() // succeeds
- seqf->private = iter
- .seq_stop()
- kfree(seqf->private)
- pread()
- .seq_start()
- iter = kmalloc() // fails
- .seq_stop()
- class_dev_iter_exit(seqf->private) // boom! old pointer
As the comment in disk_seqf_stop() says, stop is called even if start
failed, so we need to reinitialise the private pointer to NULL when seq
iteration stops.
An alternative would be to set the private pointer to NULL when the
kmalloc() in disk_seqf_start() fails.
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Tejun Heo <tj@kernel.org>
[ Upstream commit 8ba8682107ee2ca3347354e018865d8e1967c5f4 ]
get_task_ioprio() accesses the task->io_context without holding the task
lock and thus can race with exit_io_context(), leading to a
use-after-free. The reproducer below hits this within a few seconds on
my 4-core QEMU VM:
#define _GNU_SOURCE
#include <assert.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <sys/wait.h>
int main(int argc, char **argv)
pid_t pid, child;
long nproc, i;
/* ioprio_set(IOPRIO_WHO_PROCESS, 0, IOPRIO_PRIO_VALUE(IOPRIO_CLASS_IDLE, 0)); */
syscall(SYS_ioprio_set, 1, 0, 0x6000);
nproc = sysconf(_SC_NPROCESSORS_ONLN);
for (i = 0; i < nproc; i++) {
pid = fork();
assert(pid != -1);
if (pid == 0) {
for (;;) {
pid = fork();
assert(pid != -1);
if (pid == 0) {
_exit(0);
} else {
child = wait(NULL);
assert(child == pid);
pid = fork();
assert(pid != -1);
if (pid == 0) {
for (;;) {
/* ioprio_get(IOPRIO_WHO_PGRP, 0); */
syscall(SYS_ioprio_get, 2, 0);
for (;;) {
return 0;
This gets us KASAN dumps like this:
[ 35.526914] ==================================================================
[ 35.530009] BUG: KASAN: out-of-bounds in get_task_ioprio+0x7b/0x90 at addr ffff880066f34e6c
[ 35.530009] Read of size 2 by task ioprio-gpf/363
[ 35.530009] =============================================================================
[ 35.530009] BUG blkdev_ioc (Not tainted): kasan: bad access detected
[ 35.530009] -----------------------------------------------------------------------------
[ 35.530009] Disabling lock debugging due to kernel taint
[ 35.530009] INFO: Allocated in create_task_io_context+0x2b/0x370 age=0 cpu=0 pid=360
[ 35.530009] ___slab_alloc+0x55d/0x5a0
[ 35.530009] __slab_alloc.isra.20+0x2b/0x40
[ 35.530009] kmem_cache_alloc_node+0x84/0x200
[ 35.530009] create_task_io_context+0x2b/0x370
[ 35.530009] get_task_io_context+0x92/0xb0
[ 35.530009] copy_process.part.8+0x5029/0x5660
[ 35.530009] _do_fork+0x155/0x7e0
[ 35.530009] SyS_clone+0x19/0x20
[ 35.530009] do_syscall_64+0x195/0x3a0
[ 35.530009] return_from_SYSCALL_64+0x0/0x6a
[ 35.530009] INFO: Freed in put_io_context+0xe7/0x120 age=0 cpu=0 pid=1060
[ 35.530009] __slab_free+0x27b/0x3d0
[ 35.530009] kmem_cache_free+0x1fb/0x220
[ 35.530009] put_io_context+0xe7/0x120
[ 35.530009] put_io_context_active+0x238/0x380
[ 35.530009] exit_io_context+0x66/0x80
[ 35.530009] do_exit+0x158e/0x2b90
[ 35.530009] do_group_exit+0xe5/0x2b0
[ 35.530009] SyS_exit_group+0x1d/0x20
[ 35.530009] entry_SYSCALL_64_fastpath+0x1a/0xa4
[ 35.530009] INFO: Slab 0xffffea00019bcd00 objects=20 used=4 fp=0xffff880066f34ff0 flags=0x1fffe0000004080
[ 35.530009] INFO: Object 0xffff880066f34e58 @offset=3672 fp=0x0000000000000001
Fix it by grabbing the task lock while we poke at the io_context.
Signed-off-by: Omar Sandoval <osandov@fb.com>
[ Upstream commit 6acfe68bac7e6f16dc312157b1fa6e2368985013 ]
Request-based DM's blk-mq support (dm-mq) was reported to be 50% slower
than if an underlying null_blk device were used directly. One of the
reasons for this drop in performance is that blk_insert_clone_request()
was calling blk_mq_insert_request() with @async=true. This forced the
use of kblockd_schedule_delayed_work_on() to run the blk-mq hw queues
which ushered in ping-ponging between process context (fio in this case)
and kblockd's kworker to submit the cloned request. The ftrace
function_graph tracer showed:
kworker-2013 => fio-12190
fio-12190 => kworker-2013
Fixing blk_insert_clone_request()'s blk_mq_insert_request() call to
_not_ use kblockd to submit the cloned requests isn't enough to
eliminate the observed context switches.
In addition to this dm-mq specific blk-core fix, there are 2 DM core
fixes to dm-mq that (when paired with the blk-core fix) completely
eliminate the observed context switching:
1) don't blk_mq_run_hw_queues in blk-mq request completion
Motivated by desire to reduce overhead of dm-mq, punting to kblockd
just increases context switches.
In my testing against a really fast null_blk device there was no benefit
to running blk_mq_run_hw_queues() on completion (and no other blk-mq
driver does this). So hopefully this change doesn't induce the need for
yet another revert like commit 621739b00e16ca2d !
2) use blk_mq_complete_request() in dm_complete_request()
blk_complete_request() doesn't offer the traditional q->mq_ops vs
.request_fn branching pattern that other historic block interfaces
do (e.g. blk_get_request). Using blk_mq_complete_request() for
blk-mq requests is important for performance. It should be noted
that, like blk_complete_request(), blk_mq_complete_request() doesn't
natively handle partial completions -- but the request-based
DM-multipath target does provide the required partial completion
support by dm.c:end_clone_bio() triggering requeueing of the request
via dm-mpath.c:multipath_end_io()'s return of DM_ENDIO_REQUEUE.
dm-mq fix #2 is _much_ more important than #1 for eliminating the
context switches.
Before: cpu : usr=15.10%, sys=59.39%, ctx=7905181, majf=0, minf=475
After: cpu : usr=20.60%, sys=79.35%, ctx=2008, majf=0, minf=472
With these changes multithreaded async read IOPs improved from ~950K
to ~1350K for this dm-mq stacked on null_blk test-case. The raw read
IOPs of the underlying null_blk device for the same workload is ~1950K.
Fixes: 7fb4898e0 ("block: add blk-mq support to blk_insert_cloned_request()")
Fixes: bfebd1cdb ("dm: add full blk-mq support to request-based DM")
Cc: stable@vger.kernel.org # 4.1+
Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
[ Upstream commit 2d99b55d378c996b9692a0c93dd25f4ed5d58934 ]
Commit 35dc248383bbab0a7203fca4d722875bc81ef091 introduced a check for
current->mm to see if we have a user space context and only copies data
if we do. Now if an IO gets interrupted by a signal data isn't copied
into user space any more (as we don't have a user space context) but
user space isn't notified about it.
This patch modifies the behaviour to return -EINTR from bio_uncopy_user()
to notify userland that a signal has interrupted the syscall, otherwise
it could lead to a situation where the caller may get a buffer with
no data returned.
This can be reproduced by issuing SG_IO ioctl()s in one thread while
constantly sending signals to it.
Fixes: 35dc248 [SCSI] sg: Fix user memory corruption when SG_IO is interrupted by a signal
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Cc: stable@vger.kernel.org # v.3.11+
errata:
When a read command returns less data than specified in the PRDs (for
example, there are two PRDs for this command, but the device returns a
number of bytes which is less than in the first PRD), the second PRD of
this command is not read out of the PRD FIFO, causing the next command
to use this PRD erroneously.
workaround
- forces sg_tablesize = 1
- modified the sg_io function in block/scsi_ioctl.c to use a 64k buffer
allocated with dma_alloc_coherent during the probe in ahci_imx
- In order to fix the scsi/sata hang, when CD_ROM and HDD are
accessed simultaneously after the workaround is applied.
Do not go to sleep in scsi_eh_handler, when there is host failed.
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
commit 596f5aad2a704b72934e5abec1b1b4114c16f45b upstream.
There may be lots of pending requests so that the buffer of PAGE_SIZE
can't hold them at all.
One typical example is scsi-mq, the queue depth(.can_queue) of
scsi_host and blk-mq is quite big but scsi_device's queue_depth
is a bit small(.cmd_per_lun), then it is quite easy to have lots
of pending requests in hw queue.
This patch fixes the following warning and the related memory
destruction.
[ 359.025101] fill_read_buffer: blk_mq_hw_sysfs_show+0x0/0x7d returned bad count^M
[ 359.055595] irq event stamp: 15537^M
[ 359.055606] general protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC ^M
[ 359.055614] Dumping ftrace buffer:^M
[ 359.055660] (ftrace buffer empty)^M
[ 359.055672] Modules linked in: nbd ipv6 kvm_intel kvm serio_raw^M
[ 359.055678] CPU: 4 PID: 21631 Comm: stress-ng-sysfs Not tainted 4.2.0-rc5-next-20150805 #434^M
[ 359.055679] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011^M
[ 359.055682] task: ffff8802161cc000 ti: ffff88021b4a8000 task.ti: ffff88021b4a8000^M
[ 359.055693] RIP: 0010:[<ffffffff811541c5>] [<ffffffff811541c5>] __kmalloc+0xe8/0x152^M
Signed-off-by: Ming Lei <ming.lei@canonical.com>
commit 4f258a46346c03fa0bbb6199ffaf4e1f9f599660 upstream.
Commit bcdb247c6b6a ("sd: Limit transfer length") clamped the maximum
size of an I/O request to the MAXIMUM TRANSFER LENGTH field in the BLOCK
LIMITS VPD. This had the unfortunate effect of also limiting the maximum
size of non-filesystem requests sent to the device through sg/bsg.
Avoid using blk_queue_max_hw_sectors() and set the max_sectors queue
limit directly.
Also update the comment in blk_limits_max_hw_sectors() to clarify that
max_hw_sectors defines the limit for the I/O controller only.
Reported-by: Brian King <brking@linux.vnet.ibm.com>
Tested-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit e56f698bd0720e17f10f39e8b0b5b446ad0ab22c upstream.
It is reasonable to set default timeout of request as 30 seconds instead of
30000 ticks, which may be 300 seconds if HZ is 100, for example, some arm64
based systems may choose 100 HZ.
Fixes: c76cbbcf4044 ("blk-mq: put blk_queue_rq_timeout together in blk_mq_init_queue()"
commit 5f6c2d2b7dbb541c1e922538c49fa04c494ae3d7 upstream.
When a blkcg configuration is targeted to a partition rather than a
whole device, blkg_conf_prep fails with -EINVAL; unfortunately, it
forgets to put the gendisk ref in that case. Fix it.
commit bb8bd38b9a1685334b73e8c62e128cbedb875867 upstream.
bio_integrity_alloc() and bio_integrity_free() assume that if a bio was
allocated from a bioset that that bioset also had its bio_integrity_pool
allocated using bioset_integrity_create(). This is a very bad
assumption given that bioset_create() and bioset_integrity_create() are
completely disjoint. Not all callers of bioset_create() have been
trained to also call bioset_integrity_create() -- and they may not care
to be.
Fix this by falling back to kmalloc'ing 'struct bio_integrity_payload'
rather than force all bioset consumers to (wastefully) preallocate a
bio_integrity_pool that they very likely won't actually need (given the
niche nature of the current block integrity support).
Otherwise, a NULL pointer "Kernel BUG" with a trace like the following
will be observed (as seen on s390x using zfcp storage) because dm-io
doesn't use bioset_integrity_create() when creating its bioset:
[ 791.643338] Call Trace:
[ 791.643339] ([<00000003df98b848>] 0x3df98b848)
[ 791.643341] [<00000000002c5de8>] bio_integrity_alloc+0x48/0xf8
[ 791.643348] [<00000000002c6486>] bio_integrity_prep+0xae/0x2f0
[ 791.643349] [<0000000000371e38>] blk_queue_bio+0x1c8/0x3d8
[ 791.643355] [<000000000036f8d0>] generic_make_request+0xc0/0x100
[ 791.643357] [<000000000036f9b2>] submit_bio+0xa2/0x198
[ 791.643406] [<000003ff801f9774>] dispatch_io+0x15c/0x3b0 [dm_mod]
[ 791.643419] [<000003ff801f9b3e>] dm_io+0x176/0x2f0 [dm_mod]
[ 791.643423] [<000003ff8074b28a>] do_reads+0x13a/0x1a8 [dm_mirror]
[ 791.643425] [<000003ff8074b43a>] do_mirror+0x142/0x298 [dm_mirror]
[ 791.643428] [<0000000000154fca>] process_one_work+0x18a/0x3f8
[ 791.643432] [<000000000015598a>] worker_thread+0x132/0x3b0
[ 791.643435] [<000000000015d49a>] kthread+0xd2/0xd8
[ 791.643438] [<00000000005bc0ca>] kernel_thread_starter+0x6/0xc
[ 791.643446] [<00000000005bc0c4>] kernel_thread_starter+0x0/0xc
commit f3f5da624e0a891c34d8cd513c57f1d9b0c7dadc upstream.
This fixes a data corruption bug when using discard on top of MD linear,
raid0 and raid10 personalities.
Commit 20d0189b1012 "block: Introduce new bio_split()" permits sharing
the bio_vec between the two resulting bios. That is fine for read/write
requests where the bio_vec is immutable. For discards, however, we need
to be able to attach a payload and update the bio_vec so the page can
get mapped to a scatterlist entry. Therefore the bio_vec can not be
shared when splitting discards and we must do a full clone.
Reported-by: Seunguk Shin <seunguk.shin@samsung.com>
Tested-by: Seunguk Shin <seunguk.shin@samsung.com>
Cc: Seunguk Shin <seunguk.shin@samsung.com>
Cc: Jens Axboe <axboe@fb.com>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
[ INFO: inconsistent lock state ]
4.1.0-rc7+ #217 Tainted: G O
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/6/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(ext_devt_lock){+.?...}, at: [<ffffffff8143a60c>] blk_free_devt+0x3c/0x70
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810bf6b1>] __lock_acquire+0x461/0x1e70
[<ffffffff810c1947>] lock_acquire+0xb7/0x290
[<ffffffff818ac3a8>] _raw_spin_lock+0x38/0x50
[<ffffffff8143a07d>] blk_alloc_devt+0x6d/0xd0 <-- take the lock in process context
[<ffffffff810bf64e>] __lock_acquire+0x3fe/0x1e70
[<ffffffff810c00ad>] ? __lock_acquire+0xe5d/0x1e70
[<ffffffff8143a60c>] ? blk_free_devt+0x3c/0x70
[<ffffffff8143a60c>] blk_free_devt+0x3c/0x70 <-- take the lock in softirq
[<ffffffff8143bfec>] part_release+0x1c/0x50
[<ffffffff8158edf6>] device_release+0x36/0xb0
[<ffffffff8145ac2b>] kobject_cleanup+0x7b/0x1a0
[<ffffffff8145aad0>] kobject_put+0x30/0x70
[<ffffffff8158f147>] put_device+0x17/0x20
[<ffffffff8143c29c>] delete_partition_rcu_cb+0x16c/0x180
[<ffffffff8143c130>] ? read_dev_sector+0xa0/0xa0
[<ffffffff810e0e0f>] rcu_process_callbacks+0x2ff/0xa90
[<ffffffff810e0dcf>] ? rcu_process_callbacks+0x2bf/0xa90
[<ffffffff81067e2e>] __do_softirq+0xde/0x600
Neil sees this in his tests and it also triggers on pmem driver unbind
for the libnvdimm tests. This fix is on top of an initial fix by Keith
for incorrect usage of mutex_lock() in this path: 2da78092dda1 "block:
Fix dev_t minor allocation lifetime". Both this and 2da78092dda1 are
candidates for -stable.
Fixes: 2da78092dda1 ("block: Fix dev_t minor allocation lifetime")
Cc: <stable@vger.kernel.org>
Cc: Keith Busch <keith.busch@intel.com>
Reported-by: NeilBrown <neilb@suse.de>
Now blk_cleanup_queue() can be called before calling
del_gendisk()[1], inside which hctx->ctxs is touched
from blk_mq_unregister_hctx(), but the variable has
been freed by blk_cleanup_queue() at that time.
So this patch moves freeing of hctx->ctxs into queue's
release handler for fixing the oops reported by Stefan.
[1], 6cd18e711dd8075 (block: destroy bdi before blockdev is
unregistered)
Reported-by: Stefan Seyfried <stefan.seyfried@googlemail.com>
Cc: NeilBrown <neilb@suse.de>
Cc: stable@vger.kernel.org (v4.0)
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
bdi_unregister() now contains very little functionality.
It contains a "WARN_ON" if bdi->dev is NULL. This warning is of no
real consequence as bdi->dev isn't needed by anything else in the function,
and it triggers if
blk_cleanup_queue() -> bdi_destroy()
is called before bdi_unregister, which happens since
Commit: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.")
So this isn't wanted.
It also calls bdi_set_min_ratio(). This needs to be called after
writes through the bdi have all been flushed, and before the bdi is destroyed.
Calling it early is better than calling it late as it frees up a global
resource.
Calling it immediately after bdi_wb_shutdown() in bdi_destroy()
perfectly fits these requirements.
So bdi_unregister() can be discarded with the important content moved to
bdi_destroy(), as can the
writeback_bdi_unregister
event which is already not used.
Reported-by: Mike Snitzer <snitzer@redhat.com>
Fixes: c4db59d31e39 ("fs: don't reassign dirty inodes to default_backing_dev_info")
Fixes: 6cd18e711dd8 ("block: destroy bdi before blockdev is unregistered.")
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Tested-by: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
With commit ff36ab345 ("dm: remove request-based logic from
make_request_fn wrapper") DM no longer calls blk_queue_bio() directly,
so remove its export. Doing so required a forward declaration in
blk-core.c.
Normally if driver is busy to dispatch a request the logic is like below:
block layer: driver:
__blk_mq_run_hw_queue
a. blk_mq_stop_hw_queue
b. rq add to ctx->dispatch
later:
1. blk_mq_start_hw_queue
2. __blk_mq_run_hw_queue
But it's possible step 1-2 runs between a and b. And since rq isn't in
ctx->dispatch yet, step 2 will not run rq. The rq might get lost if
there are no subsequent requests kick in.
Signed-off-by: Shaohua Li <shli@fb.com>
Because of the peculiar way that md devices are created (automatically
when the device node is opened), a new device can be created and
registered immediately after the
blk_unregister_region(disk_devt(disk), disk->minors);
call in del_gendisk().
Therefore it is important that all visible artifacts of the previous
device are removed before this call. In particular, the 'bdi'.
Since:
commit c4db59d31e39ea067c32163ac961e9c80198fd37
Author: Christoph Hellwig <hch@lst.de>
moved the
device_unregister(bdi->dev);
call from bdi_unregister() to bdi_destroy() it has been quite easy to
lose a race and have a new (e.g.) "md127" be created after the
blk_unregister_region() call and before bdi_destroy() is ultimately
called by the final 'put_disk', which must come after del_gendisk().
The new device finds that the bdi name is already registered in sysfs
and complains
> [ 9627.630029] WARNING: CPU: 18 PID: 3330 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x5a/0x70()
> [ 9627.630032] sysfs: cannot create duplicate filename '/devices/virtual/bdi/9:127'
We can fix this by moving the bdi_destroy() call out of
blk_release_queue() (which can happen very late when a refcount
reaches zero) and into blk_cleanup_queue() - which happens exactly when the md
device driver calls it.
Then it is only necessary for md to call blk_cleanup_queue() before
del_gendisk(). As loop.c devices are also created on demand by
opening the device node, we make the same change there.
Fixes: c4db59d31e39ea067c32163ac961e9c80198fd37
Reported-by: Azat Khuzhin <a3at.mail@gmail.com>
value of NR_BOUNCE
Commit d2c5e30c9a1420902262aa923794d2ae4e0bc391
("[PATCH] zoned vm counters: conversion of nr_bounce to per zone counter")
convert statistic of nr_bounce to per zone and one global value in vm_stat,
but it call inc_|dec_zone_page_state on different pages, then different
zones, and cause us to get unexpected value of NR_BOUNCE.
Below is the result on my machine:
Mar 2 09:26:08 udknight kernel: [144766.778265] Mem-Info:
Mar 2 09:26:08 udknight kernel: [144766.778266] DMA per-cpu:
Mar 2 09:26:08 udknight kernel: [144766.778268] CPU 0: hi: 0, btch: 1 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778269] CPU 1: hi: 0, btch: 1 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778270] Normal per-cpu:
Mar 2 09:26:08 udknight kernel: [144766.778271] CPU 0: hi: 186, btch: 31 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778273] CPU 1: hi: 186, btch: 31 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778274] HighMem per-cpu:
Mar 2 09:26:08 udknight kernel: [144766.778275] CPU 0: hi: 186, btch: 31 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778276] CPU 1: hi: 186, btch: 31 usd: 0
Mar 2 09:26:08 udknight kernel: [144766.778279] active_anon:46926 inactive_anon:287406 isolated_anon:0
Mar 2 09:26:08 udknight kernel: [144766.778279] active_file:105085 inactive_file:139432 isolated_file:0
Mar 2 09:26:08 udknight kernel: [144766.778279] unevictable:653 dirty:0 writeback:0 unstable:0
Mar 2 09:26:08 udknight kernel: [144766.778279] free:178957 slab_reclaimable:6419 slab_unreclaimable:9966
Mar 2 09:26:08 udknight kernel: [144766.778279] mapped:4426 shmem:305277 pagetables:784 bounce:0
Mar 2 09:26:08 udknight kernel: [144766.778279] free_cma:0
Mar 2 09:26:08 udknight kernel: [144766.778286] DMA free:3324kB min:68kB low:84kB high:100kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15976kB managed:15900kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
Mar 2 09:26:08 udknight kernel: [144766.778287] lowmem_reserve[]: 0 822 3754 3754
Mar 2 09:26:08 udknight kernel: [144766.778293] Normal free:26828kB min:3632kB low:4540kB high:5448kB active_anon:4872kB inactive_anon:68kB active_file:1796kB inactive_file:1796kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:892920kB managed:842560kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:4144kB slab_reclaimable:25676kB slab_unreclaimable:39864kB kernel_stack:1944kB pagetables:3136kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2412612 all_unreclaimable? yes
Mar 2 09:26:08 udknight kernel: [144766.778294] lowmem_reserve[]: 0 0 23451 23451
Mar 2 09:26:08 udknight kernel: [144766.778299] HighMem free:685676kB min:512kB low:3748kB high:6984kB active_anon:182832kB inactive_anon:1149556kB active_file:418544kB inactive_file:555932kB unevictable:2612kB isolated(anon):0kB isolated(file):0kB present:3001732kB managed:3001732kB mlocked:0kB dirty:0kB writeback:0kB mapped:17704kB shmem:1216964kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:75771152kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Mar 2 09:26:08 udknight kernel: [144766.778300] lowmem_reserve[]: 0 0 0 0
You can see bounce:75771152kB for HighMem, but bounce:0 for lowmem and global.
This patch fix it.
Signed-off-by: Wang YanQing <udknight@gmail.com>
Our issue is descripted in below call path:
->elevator_init
->elevator_init_fn
->{cfq,deadline,noop}_init_queue
->elevator_alloc
->kzalloc_node
fail to call kzalloc_node and then put module in elevator_alloc;
fail to call elevator_init_fn and then put module again in elevator_init.
Remove elevator_put invoking in error path of elevator_alloc to avoid
double release issue.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
hctx->tags has to be set as NULL in case that it is to be unmapped
no matter if set->tags[hctx->queue_num] is NULL or not in blk_mq_map_swqueue()
because shared tags can be freed already from another request queue.
The same situation has to be considered during handling CPU online too.
Unmapped hw queue can be remapped after CPU topo is changed, so we need
to allocate tags for the hw queue in blk_mq_map_swqueue(). Then tags
allocation for hw queue can be removed in hctx cpu online notifier, and it
is reasonable to do that after mapping is updated.
Reported-by: Dongsu Park <dongsu.park@profitbricks.com>
Tested-by: Dongsu Park <dongsu.park@profitbricks.com>
Firstly during CPU hotplug, even queue is freezed, timeout
handler still may come and access hctx->tags, which may cause
use after free, so this patch deactivates timeout handler
inside CPU hotplug notifier.
Secondly, tags can be shared by more than one queues, so we
have to check if the hctx has been unmapped, otherwise
still use-after-free on tags can be triggered.
Commit 889fa31f00b2 was a bit too eager in reducing the loop count,
so we ended up missing queues in some configurations. Ensure that
our division rounds up, so that's not the case.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Fixes: 889fa31f00b2 ("blk-mq: reduce unnecessary software queue looping")
Pull block layer core bits from Jens Axboe:
"This is the core pull request for 4.1. Not a lot of stuff in here for
this round, mostly little fixes or optimizations. This pull request
contains:
- An optimization that speeds up queue runs on blk-mq, especially for
the case where there's a large difference between nr_cpu_ids and
the actual mapped software queues on a hardware queue. From Chong
Yuan.
- Honor node local allocations for requests on legacy devices. From
David Rientjes.
- Cleanup of blk_mq_rq_to_pdu() from me.
- exit_aio() fixup from me, greatly speeding up exiting multiple IO
contexts off exit_group(). For my particular test case, fio exit
took ~6 seconds. A typical case of both exposing RCU grace periods
to user space, and serializing exit of them.
- Make blk_mq_queue_enter() honor the gfp mask passed in, so we only
wait if __GFP_WAIT is set. From Keith Busch.
- blk-mq exports and two added helpers from Mike Snitzer, which will
be used by the dm-mq code.
- Cleanups of blk-mq queue init from Wei Fang and Xiaoguang Wang"
* 'for-4.1/core' of git://git.kernel.dk/linux-block:
aio: fix serial draining in exit_aio()
blk-mq: cleanup blk_mq_rq_to_pdu()
block: remove redundant check about 'set->nr_hw_queues' in blk_mq_alloc_tag_set()
block: allocate request memory local to request queue
blk-mq: don't wait in blk_mq_queue_enter() if __GFP_WAIT isn't set
blk-mq: export blk_mq_run_hw_queues
blk-mq: add blk_mq_init_allocated_queue and export blk_mq_register_disk
In flush_busy_ctxs() and blk_mq_hctx_has_pending(), regardless of how many
ctxs assigned to one hctx, they will all loop hctx->ctx_map.map_size
times. Here hctx->ctx_map.map_size is a const ALIGN(nr_cpu_ids, 8) / 8.
Especially, flush_busy_ctxs() is in hot code path. And it's unnecessary.
Change ->map_size to contain the actually mapped software queues, so we
only loop for as many iterations as we have to.
And remove cpumask setting and nr_ctx count in blk_mq_init_cpu_queues()
since they are all re-done in blk_mq_map_swqueue().
Signed-off-by: Chong Yuan <chong.yuan@memblaze.com>
Reviewed-by: Wenbo Wang <wenbo.wang@memblaze.com>
Updated by me for formatting and commenting.
Pull vfs update from Al Viro:
"Part one:
- struct filename-related cleanups
- saner iov_iter_init() replacements (and switching the syscalls to
use of those)
- ntfs switch to ->write_iter() (Anton)
- aio cleanups and splitting iocb into common and async parts
(Christoph)
- assorted fixes (me, bfields, Andrew Elble)
There's a lot more, including the completion of switchover to
->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags
race fixes, etc, but that goes after #for-davem merge. David has
pulled it, and once it's in I'll send the next vfs pull request"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits)
sg_start_req(): use import_iovec()
sg_start_req(): make sure that there's not too many elements in iovec
blk_rq_map_user(): use import_single_range()
sg_io(): use import_iovec()
process_vm_access: switch to {compat_,}import_iovec()
switch keyctl_instantiate_key_common() to iov_iter
switch {compat_,}do_readv_writev() to {compat_,}import_iovec()
aio_setup_vectored_rw(): switch to {compat_,}import_iovec()
vmsplice_to_user(): switch to import_iovec()
kill aio_setup_single_vector()
aio: simplify arguments of aio_setup_..._rw()
aio: lift iov_iter_init() into aio_setup_..._rw()
lift iov_iter into {compat_,}do_readv_writev()
NFS: fix BUG() crash in notify_change() with patch to chown_common()
dcache: return -ESTALE not -EBUSY on distributed fs race
NTFS: Version 2.1.32 - Update file write from aio_write to write_iter.
VFS: Add iov_iter_fault_in_multipages_readable()
drop bogus check in file_open_root()
switch security_inode_getattr() to struct path *
constify tomoyo_realpath_from_path()
... and don't skip access_ok() validation.
Jan Engelhardt reports a strange oops with an invalid ->sense_buffer
pointer in scsi_init_cmd_errh() with the blk-mq code.
The sense_buffer pointer should have been initialized by the call to
scsi_init_request() from blk_mq_init_rq_map(), but there seems to be
some non-repeatable memory corruptor.
This patch makes sure we initialize the whole struct request allocation
(and the associated 'struct scsi_cmnd' for the SCSI case) to zero, by
using __GFP_ZERO in the allocation. The old code initialized a couple
of individual fields, leaving the rest undefined (although many of them
are then initialized in later phases, like blk_mq_rq_ctx_init() etc.
It's not entirely clear why this matters, but it's the rigth thing to do
regardless, and with 4.0 imminent this is the defensive "let's just make
sure everything is initialized properly" patch.
Tested-by: Jan Engelhardt <jengelh@inai.de>
Linux 3.19 commit 69c953c ("lib/lcm.c: lcm(n,0)=lcm(0,n) is 0, not n")
caused blk_stack_limits() to not properly stack queue_limits for stacked
devices (e.g. DM).
Fix this regression by establishing lcm_not_zero() and switching
blk_stack_limits() over to using it.
DM uses blk_set_stacking_limits() to establish the initial top-level
queue_limits that are then built up based on underlying devices' limits
using blk_stack_limits(). In the case of optimal_io_size (io_opt)
blk_set_stacking_limits() establishes a default value of 0. With commit
69c953c, lcm(0, n) is no longer n, which compromises proper stacking of
the underlying devices' io_opt.
Test:
$ modprobe scsi_debug dev_size_mb=10 num_tgts=1 opt_blks=1536
$ cat /sys/block/sde/queue/optimal_io_size
786432
$ dmsetup create node --table "0 100 linear /dev/sde 0"
Before this fix:
$ cat /sys/block/dm-5/queue/optimal_io_size
0
After this fix:
786432
Cc: stable@vger.kernel.org # 3.19+
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Don't assign ->rq_timeout twice.
Signed-off-by: Wei Fang <fangwei1@huawei.com>
At the beginning of blk_mq_alloc_tag_set(), we have already checked whether
'set->nr_hw_queues' is zero, so here remove this redundant check.
Signed-off-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
blk_init_rl() allocates a mempool using mempool_create_node() with node
local memory. This only allocates the mempool and element list locally
to the requeue queue node.
What we really want to do is allocate the request itself local to the
queue. To do this, we need our own alloc and free functions that will
allocate from request_cachep and pass the request queue node in to prefer
node local memory.
Signed-off-by: David Rientjes <rientjes@google.com>
Use the right array index to reference the last
element of rq->biotail->bi_io_vec[]
Signed-off-by: Wenbo Wang <wenbo.wang@memblaze.com>
Reviewed-by: Chong Yuan <chong.yuan@memblaze.com>
Fixes: 66cb45aa41315 ("block: add support for limiting gaps in SG lists")
Cc: stable@kernel.org
When allocating from the reserved tags pool, bt_get() is called with
a NULL hctx. If all tags are in use, the hw queue is kicked to push
out any pending IO, potentially freeing tags, and tag allocation is
retried. The problem is that blk_mq_run_hw_queue() doesn't check for
a NULL hctx. So we avoid it with a simple NULL hctx test.
Tested by hammering mtip32xx with concurrent smartctl/hdparm.
Signed-off-by: Sam Bradshaw <sbradshaw@micron.com>
Signed-off-by: Selvan Mani <smani@micron.com>
Fixes: b32232073e80 ("blk-mq: fix hang in bt_get()")
Added appropriate comment.
Return -EBUSY if we're unable to enter a queue immediately when
allocating a blk-mq request without __GFP_WAIT.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Rename blk_mq_run_queues to blk_mq_run_hw_queues, add async argument,
and export it.
DM's suspend support must be able to run the queue without starting
stopped hw queues.
Add a variant of blk_mq_init_queue that allows a previously allocated
queue to be initialized. blk_mq_init_allocated_queue models
blk_init_allocated_queue -- which was also created for DM's use.
DM's approach to device creation requires a placeholder request_queue be
allocated for use with alloc_dev() but the decision about what type of
request_queue will be ultimately created is deferred until all component
devices referenced in the DM table are processed to determine the table
type (request-based, blk-mq request-based, or bio-based).
Also, because of DM's late finalization of the request_queue type
the call to blk_mq_register_disk() doesn't happen during alloc_dev().
Must export blk_mq_register_disk() so that DM can backfill the 'mq' dir
once the blk-mq queue is fully allocated.
Reviewed-by: Ming Lei <ming.lei@canonical.com>
If percpu_ref_init() fails the allocated q and hctxs must get cleaned
up; using 'err_map' doesn't allow that to happen.
When reading blkio.throttle.io_serviced in a recently created blkio
cgroup, it's possible to race against the creation of a throttle policy,
which delays the allocation of stats_cpu.
Like other functions in the throttle code, just checking for a NULL
stats_cpu prevents the following oops caused by that race.
[ 1117.285199] Unable to handle kernel paging request for data at address 0x7fb4d0020
[ 1117.285252] Faulting instruction address: 0xc0000000003efa2c
[ 1137.733921] Oops: Kernel access of bad area, sig: 11 [#1]
[ 1137.733945] SMP NR_CPUS=2048 NUMA PowerNV
[ 1137.734025] Modules linked in: bridge stp llc kvm_hv kvm binfmt_misc autofs4
[ 1137.734102] CPU: 3 PID: 5302 Comm: blkcgroup Not tainted 3.19.0 #5
[ 1137.734132] task: c000000f1d188b00 ti: c000000f1d210000 task.ti: c000000f1d210000
[ 1137.734167] NIP: c0000000003efa2c LR: c0000000003ef9f0 CTR: c0000000003ef980
[ 1137.734202] REGS: c000000f1d213500 TRAP: 0300 Not tainted (3.19.0)
[ 1137.734230] MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR: 42008884 XER: 20000000
[ 1137.734325] CFAR: 0000000000008458 DAR: 00000007fb4d0020 DSISR: 40000000 SOFTE: 0
GPR00: c0000000003ed3a0 c000000f1d213780 c000000000c59538 0000000000000000
GPR04: 0000000000000800 0000000000000000 0000000000000000 0000000000000000
GPR08: ffffffffffffffff 00000007fb4d0020 00000007fb4d0000 c000000000780808
GPR12: 0000000022000888 c00000000fdc0d80 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 000001003e120200 c000000f1d5b0cc0 0000000000000200 0000000000000000
GPR24: 0000000000000001 c000000000c269e0 0000000000000020 c000000f1d5b0c80
GPR28: c000000000ca3a08 c000000000ca3dec c000000f1c667e00 c000000f1d213850
[ 1137.734886] NIP [c0000000003efa2c] .tg_prfill_cpu_rwstat+0xac/0x180
[ 1137.734915] LR [c0000000003ef9f0] .tg_prfill_cpu_rwstat+0x70/0x180
[ 1137.734943] Call Trace:
[ 1137.734952] [c000000f1d213780] [d000000005560520] 0xd000000005560520 (unreliable)
[ 1137.734996] [c000000f1d2138a0] [c0000000003ed3a0] .blkcg_print_blkgs+0xe0/0x1a0
[ 1137.735039] [c000000f1d213960] [c0000000003efb50] .tg_print_cpu_rwstat+0x50/0x70
[ 1137.735082] [c000000f1d2139e0] [c000000000104b48] .cgroup_seqfile_show+0x58/0x150
[ 1137.735125] [c000000f1d213a70] [c0000000002749dc] .kernfs_seq_show+0x3c/0x50
[ 1137.735161] [c000000f1d213ae0] [c000000000218630] .seq_read+0xe0/0x510
[ 1137.735197] [c000000f1d213bd0] [c000000000275b04] .kernfs_fop_read+0x164/0x200
[ 1137.735240] [c000000f1d213c80] [c0000000001eb8e0] .__vfs_read+0x30/0x80
[ 1137.735276] [c000000f1d213cf0] [c0000000001eb9c4] .vfs_read+0x94/0x1b0
[ 1137.735312] [c000000f1d213d90] [c0000000001ebb38] .SyS_read+0x58/0x100
[ 1137.735349] [c000000f1d213e30] [c000000000009218] syscall_exit+0x0/0x98
[ 1137.735383] Instruction dump:
[ 1137.735405] 7c6307b4 7f891800 409d00b8 60000000 60420000 3d420004 392a63b0 786a1f24
[ 1137.735471] 7d49502a e93e01c8 7d495214 7d2ad214 <7cead02a> e9090008 e9490010 e9290018
And here is one code that allows to easily reproduce this, although this
has first been found by running docker.
void run(pid_t pid)
int n;
int status;
int fd;
char *buffer;
buffer = memalign(BUFFER_ALIGN, BUFFER_SIZE);
n = snprintf(buffer, BUFFER_SIZE, "%d\n", pid);
fd = open(CGPATH "/test/tasks", O_WRONLY);
write(fd, buffer, n);
close(fd);
if (fork() > 0) {
fd = open("/dev/sda", O_RDONLY | O_DIRECT);
read(fd, buffer, 512);
close(fd);
wait(&status);
} else {
fd = open(CGPATH "/test/blkio.throttle.io_serviced", O_RDONLY);
n = read(fd, buffer, BUFFER_SIZE);
close(fd);
free(buffer);
exit(0);
void test(void)
int status;
mkdir(CGPATH "/test", 0666);
if (fork() > 0)
wait(&status);
else
run(getpid());
rmdir(CGPATH "/test");
int i;
for (i = 0; i < NR_TESTS; i++)
test();
return 0;
Reported-by: Ricardo Marin Matinata <rmm@br.ibm.com>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Pull block driver changes from Jens Axboe:
"This contains:
- The 4k/partition fixes for brd from Boaz/Matthew.
- A few xen front/back block fixes from David Vrabel and Roger Pau
Monne.
- Floppy changes from Takashi, cleaning the device file creation.
- Switching libata to use the new blk-mq tagging policy, removing
code (and a suboptimal implementation) from libata. This will
throw you a merge conflict, since a bug in the original libata
tagging code was fixed since this code was branched. Trivial.
From Shaohua.
- Conversion of loop to blk-mq, from Ming Lei.
- Cleanup of the io_schedule() handling in bsg from Peter Zijlstra.
He claims it improves on unreadable code, which will cost him a
beer.
- Maintainer update or NDB, now handled by Markus Pargmann.
- NVMe:
- Optimization from me that avoids a kmalloc/kfree per IO for
smaller (<= 8KB) IO. This cuts about 1% of high IOPS CPU
overhead.
- Removal of (now) dead RCU code, a relic from before NVMe was
converted to blk-mq"
* 'for-3.20/drivers' of git://git.kernel.dk/linux-block:
xen-blkback: default to X86_32 ABI on x86
xen-blkfront: fix accounting of reqs when migrating
xen-blkback,xen-blkfront: add myself as maintainer
block: Simplify bsg complete all
floppy: Avoid manual call of device_create_file()
NVMe: avoid kmalloc/kfree for smaller IO
MAINTAINERS: Update NBD maintainer
libata: make sata_sil24 use fifo tag allocator
libata: move sas ata tag allocation to libata-scsi.c
libata: use blk taging
NVMe: within nvme_free_queues(), delete RCU sychro/deferred free
null_blk: suppress invalid partition info
brd: Request from fdisk 4k alignment
brd: Fix all partitions BUGs
axonram: Fix bug in direct_access
loop: add blk-mq.h include
block: loop: don't handle REQ_FUA explicitly
block: loop: introduce lo_discard() and lo_req_flush()
block: loop: say goodby to bio
block: loop: improve performance via blk-mq
