path: root/block
2008-06-16Merge branch 'linus' into core/softirqtip-core-softirq-2008-06-16_09.24_MonIngo Molnar
2008-06-12block: disable IRQs until data is written to relay channelCarl Henrik Lunde
As we may run relay_reserve from interrupt context we must always disable IRQs. This is because a call to relay_reserve may expose previously written data to use space. Updated new message code and an old but related comment. Signed-off-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-09Fix invalid access errors in blk_lookup_devtLinus Torvalds
Commit 30f2f0eb4bd2c43d10a8b0d872c6e5ad8f31c9a0 ("block: do_mounts - accept root=<non-existant partition>") extended blk_lookup_devt() to be able to look up partitions that had not yet been registered, but in the process made the assumption that the '&block_class.devices' list only contains disk devices and that you can do 'dev_to_disk(dev)' on them. That isn't actually true. The block_class device list also contains the partitions we've discovered so far, and you can't just do a 'dev_to_disk()' on those. So make sure to only work on devices that block/genhd.c has registered itself, something we can test by checking the 'dev->type' member. This makes the loop in blk_lookup_devt() match the other such loops in this file. [ We may want to do an alternate version that knows to handle _either_ whole-disk devices or partitions, but for now this is the minimal fix for a series of crashes reported by Mariusz Kozlowski in http://lkml.org/lkml/2008/5/25/25 and Ingo in http://lkml.org/lkml/2008/6/9/39 ] Reported-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Neil Brown <neilb@suse.de> Cc: Joao Luis Meloni Assirati <assirati@nonada.if.usp.br> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28cfq-iosched: fix RCU problem in cfq_cic_lookup()Jens Axboe
cfq_cic_lookup() needs to properly protect ioc->ioc_data before dereferencing it and also exclude updaters of ioc->ioc_data as well. Also add a number of comments documenting why the existing RCU usage is OK. Thanks a lot to "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> for review and comments! Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28block: make blktrace use per-cpu buffers for message notesJens Axboe
Currently it uses a single static char array, but that risks being corrupted when multiple users issue message notes at the same time. Make the buffers dynamically allocated when the trace is setup and make them per-cpu instead. The default max message size of 1k is also very large, the interface is mainly for small text notes. So shrink it to 128 bytes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in elevator switch message to blktrace streamAlan D. Brunelle
Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in MESSAGE notes for blktracesAlan D. Brunelle
Allows messages to be inserted into blktrace streams. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28block: reorder cfq_queue to save space on 64bit buildsRichard Kennedy
saves 8 bytes of padding & increases objects/slab from 30 to 32 on my AMD64 config Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28block: Move the second call to get_request to the end of the loopZhang, Yanmin
In function get_request_wait, the second call to get_request could be moved to the end of the while loop, because if the first call to get_request fails, the second call will fail without sleep. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-25Remove argument from open_softirq which is always NULLCarlos R. Mafra
As git-grep shows, open_softirq() is always called with the last argument being NULL block/blk-core.c: open_softirq(BLOCK_SOFTIRQ, blk_done_softirq, NULL); kernel/hrtimer.c: open_softirq(HRTIMER_SOFTIRQ, run_hrtimer_softirq, NULL); kernel/rcuclassic.c: open_softirq(RCU_SOFTIRQ, rcu_process_callbacks, NULL); kernel/rcupreempt.c: open_softirq(RCU_SOFTIRQ, rcu_process_callbacks, NULL); kernel/sched.c: open_softirq(SCHED_SOFTIRQ, run_rebalance_domains, NULL); kernel/softirq.c: open_softirq(TASKLET_SOFTIRQ, tasklet_action, NULL); kernel/softirq.c: open_softirq(HI_SOFTIRQ, tasklet_hi_action, NULL); kernel/timer.c: open_softirq(TIMER_SOFTIRQ, run_timer_softirq, NULL); net/core/dev.c: open_softirq(NET_TX_SOFTIRQ, net_tx_action, NULL); net/core/dev.c: open_softirq(NET_RX_SOFTIRQ, net_rx_action, NULL); This observation has already been made by Matthew Wilcox in June 2002 (http://www.cs.helsinki.fi/linux/linux-kernel/2002-25/0687.html) "I notice that none of the current softirq routines use the data element passed to them." and the situation hasn't changed since them. So it appears we can safely remove that extra argument to save 128 (54) bytes of kernel data (text). Signed-off-by: Carlos R. Mafra <crmafra@ift.unesp.br> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-14Remove blkdev warning triggered by using mdNeil Brown
As setting and clearing queue flags now requires that we hold a spinlock on the queue, and as blk_queue_stack_limits is called without that lock, get the lock inside blk_queue_stack_limits. For blk_queue_stack_limits to be able to find the right lock, each md personality needs to set q->queue_lock to point to the appropriate lock. Those personalities which didn't previously use a spin_lock, us q->__queue_lock. So always initialise that lock when allocated. With this in place, setting/clearing of the QUEUE_FLAG_PLUGGED bit will no longer cause warnings as it will be clear that the proper lock is held. Thanks to Dan Williams for review and fixing the silly bugs. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Jacek Luczak <difrost.kernel@gmail.com> Cc: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14block: do_mounts - accept root=<non-existant partition>Kay Sievers
Some devices, like md, may create partitions only at first access, so allow root= to be set to a valid non-existant partition of an existing disk. This applies only to non-initramfs root mounting. This fixes a regression from 2.6.24 which did allow this to happen and broke some users machines :( Acked-by: Neil Brown <neilb@suse.de> Tested-by: Joao Luis Meloni Assirati <assirati@nonada.if.usp.br> Cc: stable <stable@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-13Fix misuses of bdevname()Jean Delvare
bdevname() fills the buffer that it is given as a parameter, so calling strcpy() or snprintf() on the returned value is redundant (and probably not guaranteed to work - I don't think strcpy and snprintf support overlapping buffers.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Stephen Tweedie <sct@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-07block: avoid duplicate calls to get_part() in disk stat codeJens Axboe
get_part() is fairly expensive, as it O(N) loops over partitions to find the right one. In lots of normal IO paths we end up looking up the partition twice, to make matters even worse. Change the stat add code to accept a passed in partition instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07cfq-iosched: make io priorities inherit CPU scheduling class as well as niceJens Axboe
We currently set all processes to the best-effort scheduling class, regardless of what CPU scheduling class they belong to. Improve that so that we correctly track idle and rt scheduling classes as well. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: optimize generic_unplug_device()Jens Axboe
Original patch from Mikulas Patocka <mpatocka@redhat.com> Mike Anderson was doing an OLTP benchmark on a computer with 48 physical disks mapped to one logical device via device mapper. He found that there was a slowdown on request_queue->lock in function generic_unplug_device. The slowdown is caused by the fact that when some code calls unplug on the device mapper, device mapper calls unplug on all physical disks. These unplug calls take the lock, find that the queue is already unplugged, release the lock and exit. With the below patch, performance of the benchmark was increased by 18% (the whole OLTP application, not just block layer microbenchmarks). So I'm submitting this patch for upstream. I think the patch is correct, because when more threads call simultaneously plug and unplug, it is unspecified, if the queue is or isn't plugged (so the patch can't make this worse). And the caller that plugged the queue should unplug it anyway. (if it doesn't, there's 3ms timeout). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: get rid of likely/unlikely predictions in merge logicJens Axboe
They tend to depend a lot on the workload, so not a clear-cut likely or unlikely fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07cfq-iosched: fix RCU race in the cfq io_context destructor handlingJens Axboe
put_io_context() drops the RCU read lock before calling into cfq_dtor(), however we need to hold off freeing there before grabbing and dereferencing the first object on the list. So extend the rcu_read_lock() scope to cover the calling of cfq_dtor(), and optimize cfq_free_io_context() to use a new variant for call_for_each_cic() that assumes the RCU read lock is already held. Hit in the wild by Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: adjust tagging function queue bit lockingJens Axboe
For most initialization purposes, calling blk_queue_init_tags() without the queue lock held is OK. Only if called for resizing an existing map must the lock be held. Ditto for tag cleanup, the maps are reference counted. So switch the general queue flag setting to the unlocked variant, but retain the locked variant for resizing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: sysfs store function needs to grab queue_lock and use queue_flag_*()Jens Axboe
Concurrency isn't a big deal here since we have requests in flight at this point, but do the locked variant to set a better example. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] add support for variable length extended commandsBoaz Harrosh
Add support for variable-length, extended, and vendor specific CDBs to scsi-ml. It is now possible for initiators and ULD's to issue these types of commands. LLDs need not change much. All they need is to raise the .max_cmd_len to the longest command they support (see iscsi patch). - clean-up some code paths that did not expect commands to be larger than 16, and change cmd_len members' type to short as char is not enough. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] bsg: add large command supportFUJITA Tomonori
This enables bsg to handle the request length larger than BLK_MAX_CDB (mainly for the variable length CDB format). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-01block: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29block: Skip I/O merges when disabledAlan D. Brunelle
The block I/O + elevator + I/O scheduler code spend a lot of time trying to merge I/Os -- rightfully so under "normal" circumstances. However, if one were to know that the incoming I/O stream was /very/ random in nature, the cycles are wasted. This patch adds a per-request_queue tunable that (when set) disables merge attempts (beyond the simple one-hit cache check), thus freeing up a non-trivial amount of CPU cycles. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: add large command supportFUJITA Tomonori
This patch changes rq->cmd from the static array to a pointer to support large commands. We rarely handle large commands. So for optimization, a struct request still has a static array for a command. rq_init sets rq->cmd pointer to the static array. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: replace sizeof(rq->cmd) with BLK_MAX_CDBFUJITA Tomonori
This is a preparation for changing rq->cmd from the static array to a pointer. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: rename and export rq_init()FUJITA Tomonori
This rename rq_init() blk_rq_init() and export it. Any path that hands the request to the block layer needs to call it to initialize the request. This is a preparation for large command support, which needs to initialize the request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: no need to initialize rq->cmd with blk_get_requestFUJITA Tomonori
blk_get_request initializes rq->cmd (rq_init does) so the users don't need to do that. The purpose of this patch is to remove sizeof(rq->cmd) and &rq->cmd, as a preparation for large command support, which changes rq->cmd from the static array to a pointer. sizeof(rq->cmd) will not make sense and &rq->cmd won't work. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block/blk-barrier.c:blk_ordered_cur_seq() mustn't be inlineAdrian Bunk
This patch fixes the following build error with UML and gcc 4.3: <-- snip --> ... CC block/blk-barrier.o /home/bunk/linux/kernel-2.6/git/linux-2.6/block/blk-barrier.c: In function ‘blk_do_ordered’: /home/bunk/linux/kernel-2.6/git/linux-2.6/block/blk-barrier.c:57: sorry, unimplemented: inlining failed in call to ‘blk_ordered_cur_seq’: function body not available /home/bunk/linux/kernel-2.6/git/linux-2.6/block/blk-barrier.c:252: sorry, unimplemented: called from here /home/bunk/linux/kernel-2.6/git/linux-2.6/block/blk-barrier.c:57: sorry, unimplemented: inlining failed in call to ‘blk_ordered_cur_seq’: function body not available /home/bunk/linux/kernel-2.6/git/linux-2.6/block/blk-barrier.c:253: sorry, unimplemented: called from here make[2]: *** [block/blk-barrier.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block/elevator.c:elv_rq_merge_ok() mustn't be inlineAdrian Bunk
This patch fixes the following build error with UML and gcc 4.3: <-- snip --> ... CC block/elevator.o /home/bunk/linux/kernel-2.6/git/linux-2.6/block/elevator.c: In function ‘elv_merge’: /home/bunk/linux/kernel-2.6/git/linux-2.6/block/elevator.c:73: sorry, unimplemented: inlining failed in call to ‘elv_rq_merge_ok’: function body not available /home/bunk/linux/kernel-2.6/git/linux-2.6/block/elevator.c:103: sorry, unimplemented: called from here /home/bunk/linux/kernel-2.6/git/linux-2.6/block/elevator.c:73: sorry, unimplemented: inlining failed in call to ‘elv_rq_merge_ok’: function body not available /home/bunk/linux/kernel-2.6/git/linux-2.6/block/elevator.c:495: sorry, unimplemented: called from here make[2]: *** [block/elevator.o] Error 1 make[1]: *** [block] Error 2 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: make queue flags non-atomicNick Piggin
We can save some atomic ops in the IO path, if we clearly define the rules of how to modify the queue flags. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: add dma alignment and padding support to blk_rq_map_kernFUJITA Tomonori
This patch adds bio_copy_kern similar to bio_copy_user. blk_rq_map_kern uses bio_copy_kern instead of bio_map_kern if necessary. bio_copy_kern uses temporary pages and the bi_end_io callback frees these pages. bio_copy_kern saves the original kernel buffer at bio->bi_private it doesn't use something like struct bio_map_data to store the information about the caller. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29unexport blk_max_pfnAdrian Bunk
blk_max_pfn can now be unexported. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: make rq_init() do a full memset()FUJITA Tomonori
This requires moving rq_init() from get_request() to blk_alloc_request(). The upside is that we can now require an rq_init() from any path that wishes to hand the request to the block layer. rq_init() will be exported for the code that uses struct request without blk_get_request. This is a preparation for large command support, which needs to initialize struct request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-22[SCSI] bsg: add release callback supportFUJITA Tomonori
This patch adds release callback support, which is called when a bsg device goes away. bsg_register_queue() takes a pointer to a callback function. This feature is useful for stuff like sas_host that can't use the release callback in struct device. If a caller doesn't need bsg's release callback, it can call bsg_register_queue() with NULL pointer (e.g. scsi devices can use release callback in struct device so they don't need bsg's callback). With this patch, bsg uses kref for refcounts on bsg devices instead of get/put_device in fops->open/release. bsg calls put_device and the caller's release callback (if it was registered) in kref_put's release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-21Merge branch 'for-2.6.26' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.26' of git://git.kernel.dk/linux-2.6-block: block: fix blk_register_queue() return value block: fix memory hotplug and bouncing in block layer block: replace remaining __FUNCTION__ occurrences Kconfig: clean up block/Kconfig help descriptions cciss: fix warning oops on rmmod of driver cciss: Fix race between disk-adding code and interrupt handler block: move the padding adjustment to blk_rq_map_sg block: add bio_copy_user_iov support to blk_rq_map_user_iov block: convert bio_copy_user to bio_copy_user_iov loop: manage partitions in disk image cdrom: use kmalloced buffers instead of buffers on stack cdrom: make unregister_cdrom() return void cdrom: use list_head for cdrom_device_info list cdrom: protect cdrom_device_info list by mutex cdrom: cleanup hardcoded error-code cdrom: remove ifdef CONFIG_SYSCTL
2008-04-21block: fix blk_register_queue() return valueAkinobu Mita
blk_register_queue() returns -ENXIO when queue->request_fn is NULL. But there are some block drivers that call blk_register_queue() via add_disk() with queue->request_fn == NULL. (For example, brd, loop) Although no one checks return value of blk_register_queue(), this patch makes it return 0 instead of -ENXIO when queue->request_fn is NULL, Also this patch adds warning when blk_register_queue() and blk_unregister_queue() are called with queue == NULL rather than ignore invalid usage silently. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21Kconfig: clean up block/Kconfig help descriptionsNick Andrew
Modify the help descriptions of block/Kconfig for clarity, accuracy and consistency. Refactor the BLOCK description a bit. The wording "This permits ... to be removed" isn't quite right; the block layer is removed when the option is disabled, whereas most descriptions talk about what happens when the option is enabled. Reformat the list of what is affected by disabling the block layer. Add more examples of large block devices to LBD and strive for technical accuracy; block devices of size _exactly_ 2TB require CONFIG_LBD, not only "bigger than 2TB". Also try to say (perhaps not very clearly) that the config option is only needed when you want to have individual block devices of size >= 2TB, for example if you had 3 x 1TB disks in your computer you'd have a total storage size of 3TB but you wouldn't need the option unless you want to aggregate those disks into a RAID or LVM. Improve terminology and grammar on BLK_DEV_IO_TRACE. I also added the boilerplate "If unsure, say N" to most options. Precisely say "2TB and larger" for LSF. Indent the help text for BLK_DEV_BSG by 2 spaces in accordance with the standard. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21block: move the padding adjustment to blk_rq_map_sgFUJITA Tomonori
blk_rq_map_user adjusts bi_size of the last bio. It breaks the rule that req->data_len (the true data length) is equal to sum(bio). It broke the scsi command completion code. commit e97a294ef6938512b655b1abf17656cf2b26f709 was introduced to fix the above issue. However, the partial completion code doesn't work with it. The commit is also a layer violation (scsi mid-layer should not know about the block layer's padding). This patch moves the padding adjustment to blk_rq_map_sg (suggested by James). The padding works like the drain buffer. This patch breaks the rule that req->data_len is equal to sum(sg), however, the drain buffer already broke it. So this patch just restores the rule that req->data_len is equal to sub(bio) without breaking anything new. Now when a low level driver needs padding, blk_rq_map_user and blk_rq_map_user_iov guarantee there's enough room for padding. blk_rq_map_sg can safely extend the last entry of a scatter list. blk_rq_map_sg must extend the last entry of a scatter list only for a request that got through bio_copy_user_iov. This patches introduces new REQ_COPY_USER flag. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21block: add bio_copy_user_iov support to blk_rq_map_user_iovFUJITA Tomonori
With this patch, blk_rq_map_user_iov uses bio_copy_user_iov when a low level driver needs padding or a buffer in sg_iovec isn't aligned. That is, it uses temporary kernel buffers instead of mapping user pages directly. When a LLD needs padding, later blk_rq_map_sg needs to extend the last entry of a scatter list. bio_copy_user_iov guarantees that there is enough space for padding by using temporary kernel buffers instead of user pages. blk_rq_map_user_iov needs buffers in sg_iovec to be aligned. The comment in blk_rq_map_user_iov indicates that drivers/scsi/sg.c also needs buffers in sg_iovec to be aligned. Actually, drivers/scsi/sg.c works with unaligned buffers in sg_iovec (it always uses temporary kernel buffers). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (137 commits) [SCSI] iscsi: bidi support for iscsi_tcp [SCSI] iscsi: bidi support at the generic libiscsi level [SCSI] iscsi: extended cdb support [SCSI] zfcp: Fix error handling for blocked unit for send FCP command [SCSI] zfcp: Remove zfcp_erp_wait from slave destory handler to fix deadlock [SCSI] zfcp: fix 31 bit compile warnings [SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commands [SCSI] bsg: remove minor in struct bsg_device [SCSI] bsg: use better helper list functions [SCSI] bsg: replace kobject_get with blk_get_queue [SCSI] bsg: takes a ref to struct device in fops->open [SCSI] qla1280: remove version check [SCSI] libsas: fix endianness bug in sas_ata [SCSI] zfcp: fix compiler warning caused by poking inside new semaphore (linux-next) [SCSI] aacraid: Do not describe check_reset parameter with its value [SCSI] aacraid: Fix down_interruptible() to check the return value [SCSI] sun3_scsi_vme: add MODULE_LICENSE [SCSI] st: rename flush_write_buffer() [SCSI] tgt: use KMEM_CACHE macro [SCSI] initio: fix big endian problems for auto request sense ...
2008-04-18[SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commandsFUJITA Tomonori
Before bsg_complete_all_commands is called, BSG_F_BLOCK bit is always set. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: remove minor in struct bsg_deviceFUJITA Tomonori
minor in struct bsg_device is used as identifier to find the corresponding struct bsg_device_class. However, request_queuse can be used as identifier for that and the minor in struct bsg_device is unnecessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: use better helper list functionsFUJITA Tomonori
This replace hlist_for_each and list_entry with hlist_for_each_entry and list_first_entry respectively. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: replace kobject_get with blk_get_queueFUJITA Tomonori
Both takes a ref to a queue. But blk_get_queue checks QUEUE_FLAG_DEAD and is more appropriate interface here. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] bsg: takes a ref to struct device in fops->openFUJITA Tomonori
bsg_register_queue() takes a ref to struct device that a caller passes. For example, bsg takes a ref to the sdev_gendev for scsi devices. However, bsg doesn't inrease the refcount in fops->open. So while an application opens a bsg device, the scsi device that the bsg device holds can go away (bsg also takes a ref to a queue, but it doesn't prevent the device from going away). With this patch, bsg increases the refcount of struct device in fops->open and decreases it in fops->release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18ide: remove broken/dangerous HDIO_[UNREGISTER,SCAN]_HWIF ioctls (take 3)Bartlomiej Zolnierkiewicz
hdparm explicitely marks HDIO_[UNREGISTER,SCAN]_HWIF ioctls as DANGEROUS and given the number of bugs we can assume that there are no real users: * DMA has no chance of working because DMA resources are released by ide_unregister() and they are never allocated again. * Since ide_init_hwif_ports() is used for ->io_ports[] setup the ioctls don't work for almost all hosts with "non-standard" (== non ISA-like) layout of IDE taskfile registers (there is a lot of such host drivers). * ide_port_init_devices() is not called when probing IDE devices so: - drive->autotune is never set and IDE host/devices are not programmed for the correct PIO/DMA transfer modes (=> possible data corruption) - host specific I/O 32-bit and IRQ unmasking settings are not applied (=> possible data corruption) - host specific ->port_init_devs method is not called (=> no luck with ht6560b, qd65xx and opti621 host drivers) * ->rw_disk method is not preserved (=> no HPT3xxN chipsets support). * ->serialized flag is not preserved (=> possible data corruption when using icside, aec62xx (ATP850UF chipset), cmd640, cs5530, hpt366 (HPT3xxN chipsets), rz1000, sc1200, dtc2278 and ht6560b host drivers). * ->ack_intr method is not preserved (=> needed by ide-cris, buddha, gayle and macide host drivers). * ->sata_scr[] and sata_misc[] is cleared by ide_unregister() and it isn't initialized again (SiI3112 support needs them). * To issue an ioctl() there need to be at least one IDE device present in the system. * ->cable_detect method is not preserved + it is not called when probing IDE devices so cable detection is broken (however since DMA support is also broken it doesn't really matter ;-). * Some objects which may have already been freed in ide_unregister() are restored by ide_hwif_restore() (i.e. ->hwgroup). * ide_register_hw() may unregister unrelated IDE ports if free ide_hwifs[] slot cannot be found. * When IDE host drivers are modular unregistered port may be re-used by different host driver that owned it first causing subtle bugs. Since we now have a proper warm-plug support remove these ioctls, then remove no longer needed: - ide_register_hw() and ide_hwif_restore() functions - 'init_default' and 'restore' arguments of ide_unregister() - zeroeing of hwif->{dma,extra}_* fields in ide_unregister() As an added bonus IDE core code size shrinks by ~3kB (x86-32). v2: * fix ide_unregister() arguments in cleanup_module() (Andrew Morton). v3: * fix ide_unregister() arguments in palm_bk3710.c. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
