path: root/block
2017-10-21Revert "bsg-lib: don't free job in bsg_prepare_job"Greg Kroah-Hartman
This reverts commit eb4375e1969c48d454998b2a284c2e6a5dc9eb68 which was commit f507b54dccfd8000c517d740bc45f20c74532d18 upstream. Ben reports: That function doesn't exist here (it was introduced in 4.13). Instead, this backport has modified bsg_create_job(), creating a leak. Please revert this on the 3.18, 4.4 and 4.9 stable branches. So I'm dropping it from here. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Ming Lei <ming.lei@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
2017-10-18bio_copy_user_iov(): don't ignore ->iov_offsetAl Viro
commit 1cfd0ddd82232804e03f3023f6a58b50dfef0574 upstream. Since "block: support large requests in blk_rq_map_user_iov" we started to call it with partially drained iter; that works fine on the write side, but reads create a copy of iter for completion time. And that needs to take the possibility of ->iov_iter != 0 into account... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18more bio_map_user_iov() leak fixesAl Viro
commit 2b04e8f6bbb196cab4b232af0f8d48ff2c7a8058 upstream. we need to take care of failure exit as well - pages already in bio should be dropped by analogue of bio_unmap_pages(), since their refcounts had been bumped only once per reference in bio. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18fix unbalanced page refcounting in bio_map_user_iovVitaly Mayatskikh
commit 95d78c28b5a85bacbc29b8dba7c04babb9b0d467 upstream. bio_map_user_iov and bio_unmap_user do unbalanced pages refcounting if IO vector has small consecutive buffers belonging to the same page. bio_add_pc_page merges them into one, but the page reference is never dropped. Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-08partitions/efi: Fix integer overflow in GPT size calculationAlden Tondettar
[ Upstream commit c5082b70adfe8e1ea1cf4a8eff92c9f260e364d2 ] If a GUID Partition Table claims to have more than 2**25 entries, the calculation of the partition table size in alloc_read_gpt_entries() will overflow a 32-bit integer and not enough space will be allocated for the table. Nothing seems to get written out of bounds, but later efi_partition() will read up to 32768 bytes from a 128 byte buffer, possibly OOPSing or exposing information to /proc/partitions and uevents. The problem exists on both 64-bit and 32-bit platforms. Fix the overflow and also print a meaningful debug message if the table size is too large. Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05bsg-lib: don't free job in bsg_prepare_jobChristoph Hellwig
commit f507b54dccfd8000c517d740bc45f20c74532d18 upstream. The job structure is allocated as part of the request, so we should not free it in the error path of bsg_prepare_job. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27block: Relax a check in blk_start_queue()Bart Van Assche
commit 4ddd56b003f251091a67c15ae3fe4a5c5c5e390a upstream. Calling blk_start_queue() from interrupt context with the queue lock held and without disabling IRQs, as the skd driver does, is safe. This patch avoids that loading the skd driver triggers the following warning: WARNING: CPU: 11 PID: 1348 at block/blk-core.c:283 blk_start_queue+0x84/0xa0 RIP: 0010:blk_start_queue+0x84/0xa0 Call Trace: skd_unquiesce_dev+0x12a/0x1d0 [skd] skd_complete_internal+0x1e7/0x5a0 [skd] skd_complete_other+0xc2/0xd0 [skd] skd_isr_completion_posted.isra.30+0x2a5/0x470 [skd] skd_isr+0x14f/0x180 [skd] irq_forced_thread_fn+0x2a/0x70 irq_thread+0x144/0x1a0 kthread+0x125/0x140 ret_from_fork+0x2a/0x40 Fixes: commit a038e2536472 ("[PATCH] blk_start_queue() must be called with irq disabled - add warning") Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Andrew Morton <akpm@osdl.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24blk-mq-pci: add a fallback when pci_irq_get_affinity returns NULLChristoph Hellwig
commit c005390374957baacbc38eef96ea360559510aa7 upstream. While pci_irq_get_affinity should never fail for SMP kernel that implement the affinity mapping, it will always return NULL in the UP case, so provide a fallback mapping of all queues to CPU 0 in that case. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17partitions/msdos: FreeBSD UFS2 file systems are not recognizedRichard
commit 223220356d5ebc05ead9a8d697abb0c0a906fc81 upstream. The code in block/partitions/msdos.c recognizes FreeBSD, OpenBSD and NetBSD partitions and does a reasonable job picking out OpenBSD and NetBSD UFS subpartitions. But for FreeBSD the subpartitions are always "bad". Kernel: <bsd:bad subpartition - ignored Though all 3 of these BSD systems use UFS as a file system, only FreeBSD uses relative start addresses in the subpartition declarations. The following patch fixes this for FreeBSD partitions and leaves the code for OpenBSD and NetBSD intact: Signed-off-by: Richard Narron <comet.berkeley@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14cfq-iosched: fix the delay of cfq_group's vdisktime under iops modeHou Tao
commit 5be6b75610cefd1e21b98a218211922c2feb6e08 upstream. When adding a cfq_group into the cfq service tree, we use CFQ_IDLE_DELAY as the delay of cfq_group's vdisktime if there have been other cfq_groups already. When cfq is under iops mode, commit 9a7f38c42c2b ("cfq-iosched: Convert from jiffies to nanoseconds") could result in a large iops delay and lead to an abnormal io schedule delay for the added cfq_group. To fix it, we just need to revert to the old CFQ_IDLE_DELAY value: HZ / 5 when iops mode is enabled. Despite having the same value, the delay of a cfq_queue in idle class and the delay of cfq_group are different things, so I define two new macros for the delay of a cfq_group under time-slice mode and iops mode. Fixes: 9a7f38c42c2b ("cfq-iosched: Convert from jiffies to nanoseconds") Signed-off-by: Hou Tao <houtao1@huawei.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20block: fix blk_integrity_register to use template's interval_exp if not 0Mike Snitzer
commit 2859323e35ab5fc42f351fbda23ab544eaa85945 upstream. When registering an integrity profile: if the template's interval_exp is not 0 use it, otherwise use the ilog2() of logical block size of the provided gendisk. This fixes a long-standing DM linear target bug where it cannot pass integrity data to the underlying device if its logical block size conflicts with the underlying device's logical block size. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14block: get rid of blk_integrity_revalidate()Ilya Dryomov
commit 19b7ccf8651df09d274671b53039c672a52ad84d upstream. Commit 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk") introduced blk_integrity_revalidate(), which seems to assume ownership of the stable pages flag and unilaterally clears it if no blk_integrity profile is registered: if (bi->profile) disk->queue->backing_dev_info->capabilities |= BDI_CAP_STABLE_WRITES; else disk->queue->backing_dev_info->capabilities &= ~BDI_CAP_STABLE_WRITES; It's called from revalidate_disk() and rescan_partitions(), making it impossible to enable stable pages for drivers that support partitions and don't use blk_integrity: while the call in revalidate_disk() can be trivially worked around (see zram, which doesn't support partitions and hence gets away with zram_revalidate_disk()), rescan_partitions() can be triggered from userspace at any time. This breaks rbd, where the ceph messenger is responsible for generating/verifying CRCs. Since blk_integrity_{un,}register() "must" be used for (un)registering the integrity profile with the block layer, move BDI_CAP_STABLE_WRITES setting there. This way drivers that call blk_integrity_register() and use integrity infrastructure won't interfere with drivers that don't but still want stable pages. Fixes: 25520d55cdb6 ("block: Inline blk_integrity in struct gendisk") Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Mike Snitzer <snitzer@redhat.com> Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> [idryomov@gmail.com: backport to < 4.11: bdi is embedded in queue] Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-18blk-mq: Avoid memory reclaim when remapping queuesGabriel Krisman Bertazi
commit 36e1f3d107867b25c616c2fd294f5a1c9d4e5d09 upstream. While stressing memory and IO at the same time we changed SMT settings, we were able to consistently trigger deadlocks in the mm system, which froze the entire machine. I think that under memory stress conditions, the large allocations performed by blk_mq_init_rq_map may trigger a reclaim, which stalls waiting on the block layer remmaping completion, thus deadlocking the system. The trace below was collected after the machine stalled, waiting for the hotplug event completion. The simplest fix for this is to make allocations in this path non-reclaimable, with GFP_NOIO. With this patch, We couldn't hit the issue anymore. This should apply on top of Jens's for-next branch cleanly. Changes since v1: - Use GFP_NOIO instead of GFP_NOWAIT. Call Trace: [c000000f0160aaf0] [c000000f0160ab50] 0xc000000f0160ab50 (unreliable) [c000000f0160acc0] [c000000000016624] __switch_to+0x2e4/0x430 [c000000f0160ad20] [c000000000b1a880] __schedule+0x310/0x9b0 [c000000f0160ae00] [c000000000b1af68] schedule+0x48/0xc0 [c000000f0160ae30] [c000000000b1b4b0] schedule_preempt_disabled+0x20/0x30 [c000000f0160ae50] [c000000000b1d4fc] __mutex_lock_slowpath+0xec/0x1f0 [c000000f0160aed0] [c000000000b1d678] mutex_lock+0x78/0xa0 [c000000f0160af00] [d000000019413cac] xfs_reclaim_inodes_ag+0x33c/0x380 [xfs] [c000000f0160b0b0] [d000000019415164] xfs_reclaim_inodes_nr+0x54/0x70 [xfs] [c000000f0160b0f0] [d0000000194297f8] xfs_fs_free_cached_objects+0x38/0x60 [xfs] [c000000f0160b120] [c0000000003172c8] super_cache_scan+0x1f8/0x210 [c000000f0160b190] [c00000000026301c] shrink_slab.part.13+0x21c/0x4c0 [c000000f0160b2d0] [c000000000268088] shrink_zone+0x2d8/0x3c0 [c000000f0160b380] [c00000000026834c] do_try_to_free_pages+0x1dc/0x520 [c000000f0160b450] [c00000000026876c] try_to_free_pages+0xdc/0x250 [c000000f0160b4e0] [c000000000251978] __alloc_pages_nodemask+0x868/0x10d0 [c000000f0160b6f0] [c000000000567030] blk_mq_init_rq_map+0x160/0x380 [c000000f0160b7a0] [c00000000056758c] blk_mq_map_swqueue+0x33c/0x360 [c000000f0160b820] [c000000000567904] blk_mq_queue_reinit+0x64/0xb0 [c000000f0160b850] [c00000000056a16c] blk_mq_queue_reinit_notify+0x19c/0x250 [c000000f0160b8a0] [c0000000000f5d38] notifier_call_chain+0x98/0x100 [c000000f0160b8f0] [c0000000000c5fb0] __cpu_notify+0x70/0xe0 [c000000f0160b930] [c0000000000c63c4] notify_prepare+0x44/0xb0 [c000000f0160b9b0] [c0000000000c52f4] cpuhp_invoke_callback+0x84/0x250 [c000000f0160ba10] [c0000000000c570c] cpuhp_up_callbacks+0x5c/0x120 [c000000f0160ba60] [c0000000000c7cb8] _cpu_up+0xf8/0x1d0 [c000000f0160bac0] [c0000000000c7eb0] do_cpu_up+0x120/0x150 [c000000f0160bb40] [c0000000006fe024] cpu_subsys_online+0x64/0xe0 [c000000f0160bb90] [c0000000006f5124] device_online+0xb4/0x120 [c000000f0160bbd0] [c0000000006f5244] online_store+0xb4/0xc0 [c000000f0160bc20] [c0000000006f0a68] dev_attr_store+0x68/0xa0 [c000000f0160bc60] [c0000000003ccc30] sysfs_kf_write+0x80/0xb0 [c000000f0160bca0] [c0000000003cbabc] kernfs_fop_write+0x17c/0x250 [c000000f0160bcf0] [c00000000030fe6c] __vfs_write+0x6c/0x1e0 [c000000f0160bd90] [c000000000311490] vfs_write+0xd0/0x270 [c000000f0160bde0] [c0000000003131fc] SyS_write+0x6c/0x110 [c000000f0160be30] [c000000000009204] system_call+0x38/0xec Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Cc: Brian King <brking@linux.vnet.ibm.com> Cc: Douglas Miller <dougmill@linux.vnet.ibm.com> Cc: linux-block@vger.kernel.org Cc: linux-scsi@vger.kernel.org Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08blk: Ensure users for current->bio_list can see the full list.NeilBrown
commit f5fe1b51905df7cfe4fdfd85c5fb7bc5b71a094f upstream. Commit 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()") changed current->bio_list so that it did not contain *all* of the queued bios, but only those submitted by the currently running make_request_fn. There are two places which walk the list and requeue selected bios, and others that check if the list is empty. These are no longer correct. So redefine current->bio_list to point to an array of two lists, which contain all queued bios, and adjust various code to test or walk both lists. Signed-off-by: NeilBrown <neilb@suse.com> Fixes: 79bd99596b73 ("blk: improve order of bio handling in generic_make_request()") Signed-off-by: Jens Axboe <axboe@fb.com> Cc: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08blk: improve order of bio handling in generic_make_request()NeilBrown
commit 79bd99596b7305ab08109a8bf44a6a4511dbf1cd upstream. To avoid recursion on the kernel stack when stacked block devices are in use, generic_make_request() will, when called recursively, queue new requests for later handling. They will be handled when the make_request_fn for the current bio completes. If any bios are submitted by a make_request_fn, these will ultimately be handled seqeuntially. If the handling of one of those generates further requests, they will be added to the end of the queue. This strict first-in-first-out behaviour can lead to deadlocks in various ways, normally because a request might need to wait for a previous request to the same device to complete. This can happen when they share a mempool, and can happen due to interdependencies particular to the device. Both md and dm have examples where this happens. These deadlocks can be erradicated by more selective ordering of bios. Specifically by handling them in depth-first order. That is: when the handling of one bio generates one or more further bios, they are handled immediately after the parent, before any siblings of the parent. That way, when generic_make_request() calls make_request_fn for some particular device, we can be certain that all previously submited requests for that device have been completely handled and are not waiting for anything in the queue of requests maintained in generic_make_request(). An easy way to achieve this would be to use a last-in-first-out stack instead of a queue. However this will change the order of consecutive bios submitted by a make_request_fn, which could have unexpected consequences. Instead we take a slightly more complex approach. A fresh queue is created for each call to a make_request_fn. After it completes, any bios for a different device are placed on the front of the main queue, followed by any bios for the same device, followed by all bios that were already on the queue before the make_request_fn was called. This provides the depth-first approach without reordering bios on the same level. This, by itself, it not enough to remove all deadlocks. It just makes it possible for drivers to take the extra step required themselves. To avoid deadlocks, drivers must never risk waiting for a request after submitting one to generic_make_request. This includes never allocing from a mempool twice in the one call to a make_request_fn. A common pattern in drivers is to call bio_split() in a loop, handling the first part and then looping around to possibly split the next part. Instead, a driver that finds it needs to split a bio should queue (with generic_make_request) the second part, handle the first part, and then return. The new code in generic_make_request will ensure the requests to underlying bios are processed first, then the second bio that was split off. If it splits again, the same process happens. In each case one bio will be completely handled before the next one is attempted. With this is place, it should be possible to disable the punt_bios_to_recover() recovery thread for many block devices, and eventually it may be possible to remove it completely. Ref: http://www.spinics.net/lists/raid/msg54680.html Tested-by: Jinpu Wang <jinpu.wang@profitbricks.com> Inspired-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com> Cc: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-30blk-mq: don't complete un-started request in timeout handlerMing Lei
commit 95a49603707d982b25d17c5b70e220a05556a2f9 upstream. When iterating busy requests in timeout handler, if the STARTED flag of one request isn't set, that means the request is being processed in block layer or driver, and isn't submitted to hardware yet. In current implementation of blk_mq_check_expired(), if the request queue becomes dying, un-started requests are handled as being completed/freed immediately. This way is wrong, and can cause rq corruption or double allocation[1][2], when doing I/O and removing&resetting NVMe device at the sametime. This patch fixes several issues reported by Yi Zhang. [1]. oops log 1 [ 581.789754] ------------[ cut here ]------------ [ 581.789758] kernel BUG at block/blk-mq.c:374! [ 581.789760] invalid opcode: 0000 [#1] SMP [ 581.789761] Modules linked in: vfat fat ipmi_ssif intel_rapl sb_edac edac_core x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm nvme irqbypass crct10dif_pclmul nvme_core crc32_pclmul ghash_clmulni_intel intel_cstate ipmi_si mei_me ipmi_devintf intel_uncore sg ipmi_msghandler intel_rapl_perf iTCO_wdt mei iTCO_vendor_support mxm_wmi lpc_ich dcdbas shpchp pcspkr acpi_power_meter wmi nfsd auth_rpcgss nfs_acl lockd dm_multipath grace sunrpc ip_tables xfs libcrc32c sd_mod mgag200 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm ahci libahci crc32c_intel tg3 libata megaraid_sas i2c_core ptp fjes pps_core dm_mirror dm_region_hash dm_log dm_mod [ 581.789796] CPU: 1 PID: 1617 Comm: kworker/1:1H Not tainted 4.10.0.bz1420297+ #4 [ 581.789797] Hardware name: Dell Inc. PowerEdge R730xd/072T6D, BIOS 2.2.5 09/06/2016 [ 581.789804] Workqueue: kblockd blk_mq_timeout_work [ 581.789806] task: ffff8804721c8000 task.stack: ffffc90006ee4000 [ 581.789809] RIP: 0010:blk_mq_end_request+0x58/0x70 [ 581.789810] RSP: 0018:ffffc90006ee7d50 EFLAGS: 00010202 [ 581.789811] RAX: 0000000000000001 RBX: ffff8802e4195340 RCX: ffff88028e2f4b88 [ 581.789812] RDX: 0000000000001000 RSI: 0000000000001000 RDI: 0000000000000000 [ 581.789813] RBP: ffffc90006ee7d60 R08: 0000000000000003 R09: ffff88028e2f4b00 [ 581.789814] R10: 0000000000001000 R11: 0000000000000001 R12: 00000000fffffffb [ 581.789815] R13: ffff88042abe5780 R14: 000000000000002d R15: ffff88046fbdff80 [ 581.789817] FS: 0000000000000000(0000) GS:ffff88047fc00000(0000) knlGS:0000000000000000 [ 581.789818] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 581.789819] CR2: 00007f64f403a008 CR3: 000000014d078000 CR4: 00000000001406e0 [ 581.789820] Call Trace: [ 581.789825] blk_mq_check_expired+0x76/0x80 [ 581.789828] bt_iter+0x45/0x50 [ 581.789830] blk_mq_queue_tag_busy_iter+0xdd/0x1f0 [ 581.789832] ? blk_mq_rq_timed_out+0x70/0x70 [ 581.789833] ? blk_mq_rq_timed_out+0x70/0x70 [ 581.789840] ? __switch_to+0x140/0x450 [ 581.789841] blk_mq_timeout_work+0x88/0x170 [ 581.789845] process_one_work+0x165/0x410 [ 581.789847] worker_thread+0x137/0x4c0 [ 581.789851] kthread+0x101/0x140 [ 581.789853] ? rescuer_thread+0x3b0/0x3b0 [ 581.789855] ? kthread_park+0x90/0x90 [ 581.789860] ret_from_fork+0x2c/0x40 [ 581.789861] Code: 48 85 c0 74 0d 44 89 e6 48 89 df ff d0 5b 41 5c 5d c3 48 8b bb 70 01 00 00 48 85 ff 75 0f 48 89 df e8 7d f0 ff ff 5b 41 5c 5d c3 <0f> 0b e8 71 f0 ff ff 90 eb e9 0f 1f 40 00 66 2e 0f 1f 84 00 00 [ 581.789882] RIP: blk_mq_end_request+0x58/0x70 RSP: ffffc90006ee7d50 [ 581.789889] ---[ end trace bcaf03d9a14a0a70 ]--- [2]. oops log2 [ 6984.857362] BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 [ 6984.857372] IP: nvme_queue_rq+0x6e6/0x8cd [nvme] [ 6984.857373] PGD 0 [ 6984.857374] [ 6984.857376] Oops: 0000 [#1] SMP [ 6984.857379] Modules linked in: ipmi_ssif vfat fat intel_rapl sb_edac edac_core x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel ipmi_si iTCO_wdt iTCO_vendor_support mxm_wmi ipmi_devintf intel_cstate sg dcdbas intel_uncore mei_me intel_rapl_perf mei pcspkr lpc_ich ipmi_msghandler shpchp acpi_power_meter wmi nfsd auth_rpcgss dm_multipath nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod mgag200 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect crc32c_intel sysimgblt fb_sys_fops ttm nvme drm nvme_core ahci libahci i2c_core tg3 libata ptp megaraid_sas pps_core fjes dm_mirror dm_region_hash dm_log dm_mod [ 6984.857416] CPU: 7 PID: 1635 Comm: kworker/7:1H Not tainted 4.10.0-2.el7.bz1420297.x86_64 #1 [ 6984.857417] Hardware name: Dell Inc. PowerEdge R730xd/072T6D, BIOS 2.2.5 09/06/2016 [ 6984.857427] Workqueue: kblockd blk_mq_run_work_fn [ 6984.857429] task: ffff880476e3da00 task.stack: ffffc90002e90000 [ 6984.857432] RIP: 0010:nvme_queue_rq+0x6e6/0x8cd [nvme] [ 6984.857433] RSP: 0018:ffffc90002e93c50 EFLAGS: 00010246 [ 6984.857434] RAX: 0000000000000000 RBX: ffff880275646600 RCX: 0000000000001000 [ 6984.857435] RDX: 0000000000000fff RSI: 00000002fba2a000 RDI: ffff8804734e6950 [ 6984.857436] RBP: ffffc90002e93d30 R08: 0000000000002000 R09: 0000000000001000 [ 6984.857437] R10: 0000000000001000 R11: 0000000000000000 R12: ffff8804741d8000 [ 6984.857438] R13: 0000000000000040 R14: ffff880475649f80 R15: ffff8804734e6780 [ 6984.857439] FS: 0000000000000000(0000) GS:ffff88047fcc0000(0000) knlGS:0000000000000000 [ 6984.857440] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 6984.857442] CR2: 0000000000000010 CR3: 0000000001c09000 CR4: 00000000001406e0 [ 6984.857443] Call Trace: [ 6984.857451] ? mempool_free+0x2b/0x80 [ 6984.857455] ? bio_free+0x4e/0x60 [ 6984.857459] blk_mq_dispatch_rq_list+0xf5/0x230 [ 6984.857462] blk_mq_process_rq_list+0x133/0x170 [ 6984.857465] __blk_mq_run_hw_queue+0x8c/0xa0 [ 6984.857467] blk_mq_run_work_fn+0x12/0x20 [ 6984.857473] process_one_work+0x165/0x410 [ 6984.857475] worker_thread+0x137/0x4c0 [ 6984.857478] kthread+0x101/0x140 [ 6984.857480] ? rescuer_thread+0x3b0/0x3b0 [ 6984.857481] ? kthread_park+0x90/0x90 [ 6984.857489] ret_from_fork+0x2c/0x40 [ 6984.857490] Code: 8b bd 70 ff ff ff 89 95 50 ff ff ff 89 8d 58 ff ff ff 44 89 95 60 ff ff ff e8 b7 dd 12 e1 8b 95 50 ff ff ff 48 89 85 68 ff ff ff <4c> 8b 48 10 44 8b 58 18 8b 8d 58 ff ff ff 44 8b 95 60 ff ff ff [ 6984.857511] RIP: nvme_queue_rq+0x6e6/0x8cd [nvme] RSP: ffffc90002e93c50 [ 6984.857512] CR2: 0000000000000010 [ 6984.895359] ---[ end trace 2d7ceb528432bf83 ]--- Reported-by: Yi Zhang <yizhan@redhat.com> Tested-by: Yi Zhang <yizhan@redhat.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22block: allow WRITE_SAME commands with the SG_IO ioctlMauricio Faria de Oliveira
[ Upstream commit 25cdb64510644f3e854d502d69c73f21c6df88a9 ] The WRITE_SAME commands are not present in the blk_default_cmd_filter write_ok list, and thus are failed with -EPERM when the SG_IO ioctl() is executed without CAP_SYS_RAWIO capability (e.g., unprivileged users). [ sg_io() -> blk_fill_sghdr_rq() > blk_verify_command() -> -EPERM ] The problem can be reproduced with the sg_write_same command # sg_write_same --num 1 --xferlen 512 /dev/sda # # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_same --num 1 --xferlen 512 /dev/sda' Write same: pass through os error: Operation not permitted # For comparison, the WRITE_VERIFY command does not observe this problem, since it is in that list: # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_verify --num 1 --ilen 512 --lba 0 /dev/sda' # So, this patch adds the WRITE_SAME commands to the list, in order for the SG_IO ioctl to finish successfully: # capsh --drop=cap_sys_rawio -- -c \ 'sg_write_same --num 1 --xferlen 512 /dev/sda' # That case happens to be exercised by QEMU KVM guests with 'scsi-block' devices (qemu "-device scsi-block" [1], libvirt "<disk type='block' device='lun'>" [2]), which employs the SG_IO ioctl() and runs as an unprivileged user (libvirt-qemu). In that scenario, when a filesystem (e.g., ext4) performs its zero-out calls, which are translated to write-same calls in the guest kernel, and then into SG_IO ioctls to the host kernel, SCSI I/O errors may be observed in the guest: [...] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [...] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current] [...] sd 0:0:0:0: [sda] tag#0 Add. Sense: I/O process terminated [...] sd 0:0:0:0: [sda] tag#0 CDB: Write Same(10) 41 00 01 04 e0 78 00 00 08 00 [...] blk_update_request: I/O error, dev sda, sector 17096824 Links: [1] http://git.qemu.org/?p=qemu.git;a=commit;h=336a6915bc7089fb20fea4ba99972ad9a97c5f52 [2] https://libvirt.org/formatdomain.html#elementsDisks (see 'disk' -> 'device') Signed-off-by: Mauricio Faria de Oliveira <mauricfo@linux.vnet.ibm.com> Signed-off-by: Brahadambal Srinivasan <latha@linux.vnet.ibm.com> Reported-by: Manjunatha H R <manjuhr1@in.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19blk-mq: Always schedule hctx->next_cpuGabriel Krisman Bertazi
commit c02ebfdddbafa9a6a0f52fbd715e6bfa229af9d3 upstream. Commit 0e87e58bf60e ("blk-mq: improve warning for running a queue on the wrong CPU") attempts to avoid triggering the WARN_ON in __blk_mq_run_hw_queue when the expected CPU is dead. Problem is, in the last batch execution before round robin, blk_mq_hctx_next_cpu can schedule a dead CPU and also update next_cpu to the next alive CPU in the mask, which will trigger the WARN_ON despite the previous workaround. The following patch fixes this scenario by always scheduling the value in hctx->next_cpu. This changes the moment when we round-robin the CPU running the hctx, but it really doesn't matter, since it still executes BLK_MQ_CPU_WORK_BATCH times in a row before switching to another CPU. Fixes: 0e87e58bf60e ("blk-mq: improve warning for running a queue on the wrong CPU") Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19block: cfq_cpd_alloc() should use @gfpTejun Heo
commit ebc4ff661fbe76781c6b16dfb7b754a5d5073f8e upstream. cfq_cpd_alloc() which is the cpd_alloc_fn implementation for cfq was incorrectly hard coding GFP_KERNEL instead of using the mask specified through the @gfp parameter. This currently doesn't cause any actual issues because all current callers specify GFP_KERNEL. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: e4a9bde9589f ("blkcg: replace blkcg_policy->cpd_size with ->cpd_alloc/free_fn() methods") Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09sg_write()/bsg_write() is not fit to be called under KERNEL_DSAl Viro
commit 128394eff343fc6d2f32172f03e24829539c5835 upstream. Both damn things interpret userland pointers embedded into the payload; worse, they are actually traversing those. Leaving aside the bad API design, this is very much _not_ safe to call with KERNEL_DS. Bail out early if that happens. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06blk-mq: Do not invoke .queue_rq() for a stopped queueBart Van Assche
commit bc27c01b5c46d3bfec42c96537c7a3fae0bb2cc4 upstream. The meaning of the BLK_MQ_S_STOPPED flag is "do not call .queue_rq()". Hence modify blk_mq_make_request() such that requests are queued instead of issued if a queue has been stopped. Reported-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-07Don't feed anything but regular iovec's to blk_rq_map_user_iovLinus Torvalds
In theory we could map other things, but there's a reason that function is called "user_iov". Using anything else (like splice can do) just confuses it. Reported-and-tested-by: Johannes Thumshirn <jthumshirn@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-27blk-mq: update hardware and software queues for sleeping allocJens Axboe
If we end up sleeping due to running out of requests, we should update the hardware and software queues in the map ctx structure. Otherwise we could end up having rq->mq_ctx point to the pre-sleep context, and risk corrupting ctx->rq_list since we'll be grabbing the wrong lock when inserting the request. Reported-by: Dave Jones <davej@codemonkey.org.uk> Reported-by: Chris Mason <clm@fb.com> Tested-by: Chris Mason <clm@fb.com> Fixes: 63581af3f31e ("blk-mq: remove non-blocking pass in blk_mq_map_request") Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-26block: flush: fix IO hang in case of flood fua reqMing Lei
This patch fixes one issue reported by Kent, which can be triggered in bcachefs over sata disk. Actually it is a generic issue in block flush vs. blk-tag. Cc: Christoph Hellwig <hch@infradead.org> Reported-by: Kent Overstreet <kent.overstreet@gmail.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-21badblocks: badblocks_set/clear update unacked_existShaohua Li
When bandblocks_set acknowledges a range or badblocks_clear a range, it's possible all badblocks are acknowledged. We should update unacked_exist if this occurs. Signed-off-by: Shaohua Li <shli@fb.com> Reviewed-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com> Tested-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-21Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A set of fixes that missed the merge window, mostly due to me being away around that time. Nothing major here, a mix of nvme cleanups and fixes, and one fix for the badblocks handling" * 'for-linus' of git://git.kernel.dk/linux-block: nvmet: use symbolic constants for CNS values nvme: use symbolic constants for CNS values nvme.h: add an enum for cns values nvme.h: don't use uuid_be nvme.h: resync with nvme-cli nvme: Add tertiary number to NVME_VS nvme : Add sysfs entry for NVMe CMBs when appropriate nvme: don't schedule multiple resets nvme: Delete created IO queues on reset nvme: Stop probing a removed device badblocks: fix overlapping check for clearing
2016-10-15Merge tag 'gcc-plugins-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull gcc plugins update from Kees Cook: "This adds a new gcc plugin named "latent_entropy". It is designed to extract as much possible uncertainty from a running system at boot time as possible, hoping to capitalize on any possible variation in CPU operation (due to runtime data differences, hardware differences, SMP ordering, thermal timing variation, cache behavior, etc). At the very least, this plugin is a much more comprehensive example for how to manipulate kernel code using the gcc plugin internals" * tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: latent_entropy: Mark functions with __latent_entropy gcc-plugins: Add latent_entropy plugin
2016-10-14Merge branch 'for-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - tracepoints for basic cgroup management operations added - kernfs and cgroup path formatting functions updated to behave in the style of strlcpy() - non-critical bug fixes * 'for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: blkcg: Unlock blkcg_pol_mutex only once when cpd == NULL cgroup: fix error handling regressions in proc_cgroup_show() and cgroup_release_agent() cpuset: fix error handling regression in proc_cpuset_show() cgroup: add tracepoints for basic operations cgroup: make cgroup_path() and friends behave in the style of strlcpy() kernfs: remove kernfs_path_len() kernfs: make kernfs_path*() behave in the style of strlcpy() kernfs: add dummy implementation of kernfs_path_from_node()
2016-10-12badblocks: fix overlapping check for clearingTomasz Majchrzak
Current bad block clear implementation assumes the range to clear overlaps with at least one bad block already stored. If given range to clear precedes first bad block in a list, the first entry is incorrectly updated. Check not only if stored block end is past clear block end but also if stored block start is before clear block end. Signed-off-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com> Acked-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-11block: require write_same and discard requests align to logical block sizeDarrick J. Wong
Make sure that the offset and length arguments that we're using to construct WRITE SAME and DISCARD requests are actually aligned to the logical block size. Failure to do this causes other errors in other parts of the block layer or the SCSI layer because disks don't support partial logical block writes. Link: http://lkml.kernel.org/r/147518379026.22791.4437508871355153928.stgit@birch.djwong.org Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mike Snitzer <snitzer@redhat.com> # tweaked header Cc: Brian Foster <bfoster@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11block: invalidate the page cache when issuing BLKZEROOUTDarrick J. Wong
Patch series "fallocate for block devices", v11. This is a patchset to fix page cache coherency with BLKZEROOUT and implement fallocate for block devices. The first patch is a fix to the existing BLKZEROOUT ioctl to invalidate the page cache if the zeroing command to the underlying device succeeds. Without this patch we still have the pagecache coherence bug that's been in the kernel forever. The second patch changes the internal block device functions to reject attempts to discard or zeroout that are not aligned to the logical block size. Previously, we only checked that the start/len parameters were 512-byte aligned, which caused kernel BUG_ONs for unaligned IOs to 4k-LBA devices. The third patch creates an fallocate handler for block devices, wires up the FALLOC_FL_PUNCH_HOLE flag to zeroing-discard, and connects FALLOC_FL_ZERO_RANGE to write-same so that we can have a consistent fallocate interface between files and block devices. It also allows the combination of PUNCH_HOLE and NO_HIDE_STALE to invoke non-zeroing discard. Test cases for the new block device fallocate are now in xfstests as generic/349-351. This patch (of 3): Invalidate the page cache (as a regular O_DIRECT write would do) to avoid returning stale cache contents at a later time. Link: http://lkml.kernel.org/r/147518378313.22791.16649519283678515021.stgit@birch.djwong.org Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Brian Foster <bfoster@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10latent_entropy: Mark functions with __latent_entropyEmese Revfy
The __latent_entropy gcc attribute can be used only on functions and variables. If it is on a function then the plugin will instrument it for gathering control-flow entropy. If the attribute is on a variable then the plugin will initialize it with random contents. The variable must be an integer, an integer array type or a structure with integer fields. These specific functions have been selected because they are init functions (to help gather boot-time entropy), are called at unpredictable times, or they have variable loops, each of which provide some level of latent entropy. Signed-off-by: Emese Revfy <re.emese@gmail.com> [kees: expanded commit message] Signed-off-by: Kees Cook <keescook@chromium.org>
2016-10-09Merge branch 'for-4.9/block-smp' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull blk-mq CPU hotplug update from Jens Axboe: "This is the conversion of blk-mq to the new hotplug state machine" * 'for-4.9/block-smp' of git://git.kernel.dk/linux-block: blk-mq: fixup "Convert to new hotplug state machine" blk-mq: Convert to new hotplug state machine blk-mq/cpu-notif: Convert to new hotplug state machine
2016-10-09Merge branch 'for-4.9/block-irq' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull blk-mq irq/cpu mapping updates from Jens Axboe: "This is the block-irq topic branch for 4.9-rc. It's mostly from Christoph, and it allows drivers to specify their own mappings, and more importantly, to share the blk-mq mappings with the IRQ affinity mappings. It's a good step towards making this work better out of the box" * 'for-4.9/block-irq' of git://git.kernel.dk/linux-block: blk_mq: linux/blk-mq.h does not include all the headers it depends on blk-mq: kill unused blk_mq_create_mq_map() blk-mq: get rid of the cpumask in struct blk_mq_tags nvme: remove the post_scan callout nvme: switch to use pci_alloc_irq_vectors blk-mq: provide a default queue mapping for PCI device blk-mq: allow the driver to pass in a queue mapping blk-mq: remove ->map_queue blk-mq: only allocate a single mq_map per tag_set blk-mq: don't redistribute hardware queues on a CPU hotplug event
2016-10-07Merge branch 'for-4.9/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer updates from Jens Axboe: "This is the main pull request for block layer changes in 4.9. As mentioned at the last merge window, I've changed things up and now do just one branch for core block layer changes, and driver changes. This avoids dependencies between the two branches. Outside of this main pull request, there are two topical branches coming as well. This pull request contains: - A set of fixes, and a conversion to blk-mq, of nbd. From Josef. - Set of fixes and updates for lightnvm from Matias, Simon, and Arnd. Followup dependency fix from Geert. - General fixes from Bart, Baoyou, Guoqing, and Linus W. - CFQ async write starvation fix from Glauber. - Add supprot for delayed kick of the requeue list, from Mike. - Pull out the scalable bitmap code from blk-mq-tag.c and make it generally available under the name of sbitmap. Only blk-mq-tag uses it for now, but the blk-mq scheduling bits will use it as well. From Omar. - bdev thaw error progagation from Pierre. - Improve the blk polling statistics, and allow the user to clear them. From Stephen. - Set of minor cleanups from Christoph in block/blk-mq. - Set of cleanups and optimizations from me for block/blk-mq. - Various nvme/nvmet/nvmeof fixes from the various folks" * 'for-4.9/block' of git://git.kernel.dk/linux-block: (54 commits) fs/block_dev.c: return the right error in thaw_bdev() nvme: Pass pointers, not dma addresses, to nvme_get/set_features() nvme/scsi: Remove power management support nvmet: Make dsm number of ranges zero based nvmet: Use direct IO for writes admin-cmd: Added smart-log command support. nvme-fabrics: Add host_traddr options field to host infrastructure nvme-fabrics: revise host transport option descriptions nvme-fabrics: rework nvmf_get_address() for variable options nbd: use BLK_MQ_F_BLOCKING blkcg: Annotate blkg_hint correctly cfq: fix starvation of asynchronous writes blk-mq: add flag for drivers wanting blocking ->queue_rq() blk-mq: remove non-blocking pass in blk_mq_map_request blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue() block: export bio_free_pages to other modules lightnvm: propagate device_add() error code lightnvm: expose device geometry through sysfs lightnvm: control life of nvm_dev in driver blk-mq: register device instead of disk ...
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-09-30blkcg: Unlock blkcg_pol_mutex only once when cpd == NULLBart Van Assche
Unlocking a mutex twice is wrong. Hence modify blkcg_policy_register() such that blkcg_pol_mutex is unlocked once if cpd == NULL. This patch avoids that smatch reports the following error: block/blk-cgroup.c:1378: blkcg_policy_register() error: double unlock 'mutex:&blkcg_pol_mutex' Fixes: 06b285bd1125 ("blkcg: fix blkcg_policy_data allocation bug") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Tejun Heo <tj@kernel.org> Cc: <stable@vger.kernel.org> # v4.2+ Signed-off-by: Tejun Heo <tj@kernel.org>
2016-09-23blk-mq: skip unmapped queues in blk_mq_alloc_request_hctxChristoph Hellwig
This provides the caller a feedback that a given hctx is not mapped and thus no command can be sent on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-23cfq: fix starvation of asynchronous writesGlauber Costa
While debugging timeouts happening in my application workload (ScyllaDB), I have observed calls to open() taking a long time, ranging everywhere from 2 seconds - the first ones that are enough to time out my application - to more than 30 seconds. The problem seems to happen because XFS may block on pending metadata updates under certain circumnstances, and that's confirmed with the following backtrace taken by the offcputime tool (iovisor/bcc): ffffffffb90c57b1 finish_task_switch ffffffffb97dffb5 schedule ffffffffb97e310c schedule_timeout ffffffffb97e1f12 __down ffffffffb90ea821 down ffffffffc046a9dc xfs_buf_lock ffffffffc046abfb _xfs_buf_find ffffffffc046ae4a xfs_buf_get_map ffffffffc046babd xfs_buf_read_map ffffffffc0499931 xfs_trans_read_buf_map ffffffffc044a561 xfs_da_read_buf ffffffffc0451390 xfs_dir3_leaf_read.constprop.16 ffffffffc0452b90 xfs_dir2_leaf_lookup_int ffffffffc0452e0f xfs_dir2_leaf_lookup ffffffffc044d9d3 xfs_dir_lookup ffffffffc047d1d9 xfs_lookup ffffffffc0479e53 xfs_vn_lookup ffffffffb925347a path_openat ffffffffb9254a71 do_filp_open ffffffffb9242a94 do_sys_open ffffffffb9242b9e sys_open ffffffffb97e42b2 entry_SYSCALL_64_fastpath 00007fb0698162ed [unknown] Inspecting my run with blktrace, I can see that the xfsaild kthread exhibit very high "Dispatch wait" times, on the dozens of seconds range and consistent with the open() times I have saw in that run. Still from the blktrace output, we can after searching a bit, identify the request that wasn't dispatched: 8,0 11 152 81.092472813 804 A WM 141698288 + 8 <- (8,1) 141696240 8,0 11 153 81.092472889 804 Q WM 141698288 + 8 [xfsaild/sda1] 8,0 11 154 81.092473207 804 G WM 141698288 + 8 [xfsaild/sda1] 8,0 11 206 81.092496118 804 I WM 141698288 + 8 ( 22911) [xfsaild/sda1] <==== 'I' means Inserted (into the IO scheduler) ===================================> 8,0 0 289372 96.718761435 0 D WM 141698288 + 8 (15626265317) [swapper/0] <==== Only 15s later the CFQ scheduler dispatches the request ======================> As we can see above, in this particular example CFQ took 15 seconds to dispatch this request. Going back to the full trace, we can see that the xfsaild queue had plenty of opportunity to run, and it was selected as the active queue many times. It would just always be preempted by something else (example): 8,0 1 0 81.117912979 0 m N cfq1618SN / insert_request 8,0 1 0 81.117913419 0 m N cfq1618SN / add_to_rr 8,0 1 0 81.117914044 0 m N cfq1618SN / preempt 8,0 1 0 81.117914398 0 m N cfq767A / slice expired t=1 8,0 1 0 81.117914755 0 m N cfq767A / resid=40 8,0 1 0 81.117915340 0 m N / served: vt=1948520448 min_vt=1948520448 8,0 1 0 81.117915858 0 m N cfq767A / sl_used=1 disp=0 charge=0 iops=1 sect=0 where cfq767 is the xfsaild queue and cfq1618 corresponds to one of the ScyllaDB IO dispatchers. The requests preempting the xfsaild queue are synchronous requests. That's a characteristic of ScyllaDB workloads, as we only ever issue O_DIRECT requests. While it can be argued that preempting ASYNC requests in favor of SYNC is part of the CFQ logic, I don't believe that doing so for 15+ seconds is anyone's goal. Moreover, unless I am misunderstanding something, that breaks the expectation set by the "fifo_expire_async" tunable, which in my system is set to the default. Looking at the code, it seems to me that the issue is that after we make an async queue active, there is no guarantee that it will execute any request. When the queue itself tests if it cfq_may_dispatch() it can bail if it sees SYNC requests in flight. An incoming request from another queue can also preempt it in such situation before we have the chance to execute anything (as seen in the trace above). This patch sets the must_dispatch flag if we notice that we have requests that are already fifo_expired. This flag is always cleared after cfq_dispatch_request() returns from cfq_dispatch_requests(), so it won't pin the queue for subsequent requests (unless they are themselves expired) Care is taken during preempt to still allow rt requests to preempt us regardless. Testing my workload with this patch applied produces much better results. From the application side I see no timeouts, and the open() latency histogram generated by systemtap looks much better, with the worst outlier at 131ms: Latency histogram of xfs_buf_lock acquisition (microseconds): value |-------------------------------------------------- count 0 | 11 1 |@@@@ 161 2 |@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 1966 4 |@ 54 8 | 36 16 | 7 32 | 0 64 | 0 ~ 1024 | 0 2048 | 0 4096 | 1 8192 | 1 16384 | 2 32768 | 0 65536 | 0 131072 | 1 262144 | 0 524288 | 0 Signed-off-by: Glauber Costa <glauber@scylladb.com> CC: Jens Axboe <axboe@kernel.dk> CC: linux-block@vger.kernel.org CC: linux-kernel@vger.kernel.org Signed-off-by: Glauber Costa <glauber@scylladb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-23blk-mq: fixup "Convert to new hotplug state machine"Sebastian Andrzej Siewior
The "blk_mq_queue_reinit_dead()" just cleared the cpumask instead doing a copy. Since we might never had an online callback we could end up with a ZERO mask which in turn leads to crash as test robot demonstarted. Fixes: 65d5291eee66 ("blk-mq: Convert to new hotplug state machine") Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-22blk-mq: add flag for drivers wanting blocking ->queue_rq()Jens Axboe
If a driver sets BLK_MQ_F_BLOCKING, it is allowed to block in its ->queue_rq() handler. For that case, blk-mq ensures that we always calls it from a safe context. Signed-off-by: Jens Axboe <axboe@fb.com> Tested-by: Josef Bacik <jbacik@fb.com>
2016-09-22blk-mq: remove non-blocking pass in blk_mq_map_requestChristoph Hellwig
bt_get already does a non-blocking pass as well as running the queue when scheduling internally, no need to duplicate it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-22blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue()Jens Axboe
Two cases: 1) blk_mq_alloc_request() needlessly re-runs the queue, after calling into the tag allocation without NOWAIT set. We don't need to do that. 2) blk_mq_map_request() should just use blk_mq_run_hw_queue() with the async flag set to false. Signed-off-by: Jens Axboe <axboe@fb.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2016-09-22blk-mq: Convert to new hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine so we can phase out the cpu hotplug notifiers mess. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-block@vger.kernel.org Cc: rt@linutronix.de Cc: Christoph Hellwing <hch@lst.de> Link: http://lkml.kernel.org/r/20160919212601.180033814@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-22blk-mq/cpu-notif: Convert to new hotplug state machineThomas Gleixner
Replace the block-mq notifier list management with the multi instance facility in the cpu hotplug state machine. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-block@vger.kernel.org Cc: rt@linutronix.de Cc: Christoph Hellwing <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-22block: export bio_free_pages to other modulesGuoqing Jiang
bio_free_pages is introduced in commit 1dfa0f68c040 ("block: add a helper to free bio bounce buffer pages"), we can reuse the func in other modules after it was imported. Cc: Christoph Hellwig <hch@infradead.org> Cc: Jens Axboe <axboe@fb.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Shaohua Li <shli@fb.com> Signed-off-by: Guoqing Jiang <gqjiang@suse.com> Acked-by: Kent Overstreet <kent.overstreet@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-21blk-mq: register device instead of diskMatias Bjørling
Enable devices without a gendisk instance to register itself with blk-mq and expose the associated multi-queue sysfs entries. Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-19blk-throttle: Extend slice if throttle group is not emptyVivek Goyal
Right now, if slice is expired, we start a new slice. If a bio is queued, we keep on extending slice by throtle_slice interval (100ms). This worked well as long as pending timer function got executed with-in few milli seconds of scheduled time. But looks like with recent changes in timer subsystem, slack can be much longer depending on the expiry time of the scheduled timer. commit 500462a9de65 ("timers: Switch to a non-cascading wheel") This means, by the time timer function gets executed, it is possible the delay from scheduled time is more than 100ms. That means current code will conclude that existing slice has expired and a new one needs to be started. New slice will be 100ms by default and that will not be sufficient to meet rate requirement of group given the bio size and bio will not be dispatched and we will start a new timer function to wait. And when that timer expires, same process will repeat and we will wait again and this can easily be an infinite loop. Solve this issue by starting a new slice only if throttle gropup is empty. If it is not empty, that means there should be an active slice going on. Ideally it should not be expired but given the slack, it is possible that it has expired. Reported-by: Hou Tao <houtao1@huawei.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-19block/softirq: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160906170457.32393-9-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-19blk_mq: linux/blk-mq.h does not include all the headers it depends onStephen Rothwell
and building block/blk-mq-pci.o should depend on CONFIG_BLOCK Fixes: 973c4e372c8f ("blk-mq: provide a default queue mapping for PCI device") Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
