commit d82ae52e68892338068e7559a0c0657193341ce4 upstream.
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE
(65536) even if the underlying device(s) have a larger value -- this is
due to blk_stack_limits() using min_not_zero() when stacking the
max_segment_size limit.
1073741824
before patch:
65536
after patch:
1073741824
Reported-by: Lukasz Flis <l.flis@cyfronet.pl>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 4912aa6c11e6a5d910264deedbec2075c6f1bb73 upstream.
crocode i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma dca be2net sg ses enclosure ext4 mbcache jbd2 sd_mod crc_t10dif ahci megaraid_sas(U) dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 491, comm: scsi_eh_0 Tainted: G W ---------------- 2.6.32-220.13.1.el6.x86_64 #1 IBM -[8722PAX]-/00D1461
RIP: 0010:[<ffffffff8124e424>] [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP: 0018:ffff881057eefd60 EFLAGS: 00010012
RAX: ffff881d99e3e8a8 RBX: ffff881d99e3e780 RCX: ffff881d99e3e8a8
RDX: ffff881d99e3e8a8 RSI: ffff881d99e3e780 RDI: ffff881d99e3e780
RBP: ffff881057eefd80 R08: ffff881057eefe90 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff881057f92338
R13: 0000000000000000 R14: ffff881057f92338 R15: ffff883058188000
FS: 0000000000000000(0000) GS:ffff880040200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d3ec0 CR3: 000000302cd7d000 CR4: 00000000000406b0
Process scsi_eh_0 (pid: 491, threadinfo ffff881057eee000, task ffff881057e29540)
Stack:
0000000000001057 0000000000000286 ffff8810275efdc0 ffff881057f16000
<0> ffff881057eefdd0 ffffffff81362323 ffff881057eefe20 ffffffff8135f393
<0> ffff881057e29af8 ffff8810275efdc0 ffff881057eefe78 ffff881057eefe90
Call Trace:
[<ffffffff81362323>] __scsi_queue_insert+0xa3/0x150
[<ffffffff8135f393>] ? scsi_eh_ready_devs+0x5e3/0x850
[<ffffffff81362a23>] scsi_queue_insert+0x13/0x20
[<ffffffff8135e4d4>] scsi_eh_flush_done_q+0x104/0x160
[<ffffffff8135fb6b>] scsi_error_handler+0x35b/0x660
[<ffffffff8135f810>] ? scsi_error_handler+0x0/0x660
[<ffffffff810908c6>] kthread+0x96/0xa0
[<ffffffff8100c14a>] child_rip+0xa/0x20
[<ffffffff81090830>] ? kthread+0x0/0xa0
[<ffffffff8100c140>] ? child_rip+0x0/0x20
Code: 00 00 eb d1 4c 8b 2d 3c 8f 97 00 4d 85 ed 74 bf 49 8b 45 00 49 83 c5 08 48 89 de 4c 89 e7 ff d0 49 8b 45 00 48 85 c0 75 eb eb a4 <0f> 0b eb fe 0f 1f 84 00 00 00 00 00 55 48 89 e5 0f 1f 44 00 00
RIP [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP <ffff881057eefd60>
The RIP is this line:
BUG_ON(blk_queued_rq(rq));
After digging through the code, I think there may be a race between the
request completion and the timer handler running.
A timer is started for each request put on the device's queue (see
blk_start_request->blk_add_timer). If the request does not complete
before the timer expires, the timer handler (blk_rq_timed_out_timer)
will mark the request complete atomically:
static inline int blk_mark_rq_complete(struct request *rq)
return test_and_set_bit(REQ_ATOM_COMPLETE, &rq->atomic_flags);
and then call blk_rq_timed_out. The latter function will call
scsi_times_out, which will return one of BLK_EH_HANDLED,
BLK_EH_RESET_TIMER or BLK_EH_NOT_HANDLED. If BLK_EH_RESET_TIMER is
returned, blk_clear_rq_complete is called, and blk_add_timer is again
called to simply wait longer for the request to complete.
Now, if the request happens to complete while this is going on, what
happens? Given that we know the completion handler will bail if it
finds the REQ_ATOM_COMPLETE bit set, we need to focus on the completion
handler running after that bit is cleared. So, from the above
paragraph, after the call to blk_clear_rq_complete. If the completion
sets REQ_ATOM_COMPLETE before the BUG_ON in blk_add_timer, we go boom
there (I haven't seen this in the cores). Next, if we get the
completion before the call to list_add_tail, then the timer will
eventually fire for an old req, which may either be freed or reallocated
(there is evidence that this might be the case). Finally, if the
completion comes in *after* the addition to the timeout list, I think
it's harmless. The request will be removed from the timeout list,
req_atom_complete will be set, and all will be well.
This will only actually explain the coredumps *IF* the request
structure was freed, reallocated *and* queued before the error handler
thread had a chance to process it. That is possible, but it may make
sense to keep digging for another race. I think that if this is what
was happening, we would see other instances of this problem showing up
as null pointer or garbage pointer dereferences, for example when the
request structure was not re-used. It looks like we actually do run
into that situation in other reports.
This patch moves the BUG_ON(test_bit(REQ_ATOM_COMPLETE,
&req->atomic_flags)); from blk_add_timer to the only caller that could
trip over it (blk_start_request). It then inverts the calls to
blk_clear_rq_complete and blk_add_timer in blk_rq_timed_out to address
the race. I've boot tested this patch, but nothing more.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Hannes Reinecke <hare@suse.de>
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
commit c678ef5286ddb5cf70384ad5af286b0afc9b73e1 upstream.
As found by gcc-4.8, the QUEUE_SYSFS_BIT_FNS macro creates functions
that use a value generated by queue_var_store independent of whether
that value was set or not.
block/blk-sysfs.c: In function 'queue_store_nonrot':
block/blk-sysfs.c:244:385: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
Unlike most other such warnings, this one is not a false positive,
writing any non-number string into the sysfs files indeed has
an undefined result, rather than returning an error.
commit ce23bba842aee98092225d9576dba47c82352521 upstream.
idr allocation in blk_alloc_devt() wasn't synchronized against lookup
and removal, and its limit check was off by one - 1 << MINORBITS is
the number of minors allowed, not the maximum allowed minor.
Add locking and rename MAX_EXT_DEVT to NR_EXT_DEVT and fix limit
checking.
Acked-by: Jens Axboe <axboe@kernel.dk>
commit 7b74e912785a11572da43292786ed07ada7e3e0c upstream.
While adding and removing a lot of disks disks and partitions this
sometimes shows up:
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name:
sysfs: cannot create duplicate filename '/dev/block/259:751'
Modules linked in: raid1 autofs4 bnx2fc cnic uio fcoe libfcoe libfc 8021q scsi_transport_fc scsi_tgt garp stp llc sunrpc cpufreq_ondemand powernow_k8 freq_table mperf ipv6 dm_mirror dm_region_hash dm_log power_meter microcode dcdbas serio_raw amd64_edac_mod edac_core edac_mce_amd i2c_piix4 i2c_core k10temp bnx2 sg ixgbe dca mdio ext4 mbcache jbd2 dm_round_robin sr_mod cdrom sd_mod crc_t10dif ata_generic pata_acpi pata_atiixp ahci mptsas mptscsih mptbase scsi_transport_sas dm_multipath dm_mod [last unloaded: scsi_wait_scan]
Pid: 44103, comm: async/16 Not tainted 2.6.32-195.el6.x86_64 #1
Call Trace:
warn_slowpath_common+0x87/0xc0
warn_slowpath_fmt+0x46/0x50
sysfs_do_create_link+0x12b/0x170
sysfs_create_link+0x13/0x20
device_add+0x317/0x650
idr_get_new+0x13/0x50
add_partition+0x21c/0x390
rescan_partitions+0x32b/0x470
sd_open+0x81/0x1f0 [sd_mod]
__blkdev_get+0x1b6/0x3c0
blkdev_get+0x10/0x20
register_disk+0x155/0x170
add_disk+0xa6/0x160
sd_probe_async+0x13b/0x210 [sd_mod]
add_wait_queue+0x46/0x60
async_thread+0x102/0x250
default_wake_function+0x0/0x20
async_thread+0x0/0x250
kthread+0x96/0xa0
child_rip+0xa/0x20
kthread+0x0/0xa0
child_rip+0x0/0x20
This most likely happens because dev_t is freed while the number is
still used and idr_get_new() is not protected on every use. The fix
adds a mutex where it wasn't before and moves the dev_t free function so
it is called after device del.
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
commit 6d9359280753d2955f86d6411047516a9431eb51 upstream.
Sometimes, warnings about ioctls to partition happen often enough that they
form majority of the warnings in the kernel log and users complain. In some
cases warnings are about ioctls such as SG_IO so it's not good to get rid of
the warnings completely as they can ease debugging of userspace problems
when ioctl is refused.
Since I have seen warnings from lots of commands, including some proprietary
userspace applications, I don't think disallowing the ioctls for processes
with CAP_SYS_RAWIO will happen in the near future if ever. So lets just
stop warning for processes with CAP_SYS_RAWIO for which ioctl is allowed.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: James Bottomley <JBottomley@parallels.com>
Cc: satoru takeuchi <satoru.takeuchi@gmail.com>
commit 60ea8226cbd5c8301f9a39edc574ddabcb8150e0 upstream.
A queue newly allocated with blk_alloc_queue_node() has only
QUEUE_FLAG_BYPASS set. For request-based drivers,
blk_init_allocated_queue() is called and q->queue_flags is overwritten
with QUEUE_FLAG_DEFAULT which doesn't include BYPASS even though the
initial bypass is still in effect.
In blk_init_allocated_queue(), or QUEUE_FLAG_DEFAULT to q->queue_flags
instead of overwriting.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
6d1d8050b4bc8 "block, partition: add partition_meta_info to hd_struct"
added part_unpack_uuid() which assumes that the passed in buffer has
enough space for sprintfing "%pU" - 37 characters including '\0'.
Unfortunately, b5af921ec0233 "init: add support for root devices
specified by partition UUID" supplied 33 bytes buffer to the function
leading to the following panic with stackprotector enabled.
Kernel panic - not syncing: stack-protector: Kernel stack corrupted in: ffffffff81b14c7e
[<ffffffff815e226b>] panic+0xba/0x1c6
[<ffffffff81b14c7e>] ? printk_all_partitions+0x259/0x26xb
[<ffffffff810566bb>] __stack_chk_fail+0x1b/0x20
[<ffffffff81b15c7e>] printk_all_paritions+0x259/0x26xb
[<ffffffff81aedfe0>] mount_block_root+0x1bc/0x27f
[<ffffffff81aee0fa>] mount_root+0x57/0x5b
[<ffffffff81aee23b>] prepare_namespace+0x13d/0x176
[<ffffffff8107eec0>] ? release_tgcred.isra.4+0x330/0x30
[<ffffffff81aedd60>] kernel_init+0x155/0x15a
[<ffffffff81087b97>] ? schedule_tail+0x27/0xb0
[<ffffffff815f4d24>] kernel_thread_helper+0x5/0x10
[<ffffffff81aedc0b>] ? start_kernel+0x3c5/0x3c5
[<ffffffff815f4d20>] ? gs_change+0x13/0x13
Increase the buffer size, remove the dangerous part_unpack_uuid() and
use snprintf() directly from printk_all_partitions().
Reported-by: Szymon Gruszczynski <sz.gruszczynski@googlemail.com>
Cc: Will Drewry <wad@chromium.org>
Cc: stable@vger.kernel.org
Pull block core bits from Jens Axboe:
"It's a nice and quiet round this time, since most of the tricky stuff
has been pushed to 3.5 to give it more time to mature. After a few
hectic block IO core changes for 3.3 and 3.2, I'm quite happy with a
slow round.
Really minor stuff in here, the only real functional change is making
the auto-unplug threshold a per-queue entity. The threshold is set so
that it's low enough that we don't hold off IO for too long, but still
big enough to get a nice benefit from the batched insert (and hence
queue lock cost reduction). For raid configurations, this currently
breaks down."
* 'for-3.4/core' of git://git.kernel.dk/linux-block:
block: make auto block plug flush threshold per-disk based
Documentation: Add sysfs ABI change for cfq's target latency.
block: Make cfq_target_latency tunable through sysfs.
block: use lockdep_assert_held for queue locking
block: blk_alloc_queue_node(): use caller's GFP flags instead of GFP_KERNEL
We do auto block plug flush to reduce latency, the threshold is 16
requests. This works well if the task is accessing one or two drives.
The problem is if the task is accessing a raid 0 device and the raid
disk number is big, say 8 or 16, 16/8 = 2 or 16/16=1, we will have
heavy lock contention.
This patch makes the threshold per-disk based. The latency should be
still ok accessing one or two drives. The setup with application
accessing a lot of drives in the meantime uaually is big machine,
avoiding lock contention is more important, because any contention
will actually increase latency.
Signed-off-by: Shaohua Li <shli@fusionio.com>
In cfq, when we calculate a time slice for a process(or a cfqq to
be precise), we have to consider the cfq_target_latency so that all the
sync request have an estimated latency(300ms) and it is controlled by
cfq_target_latency. But in some hadoop test, we have found that if
there are many processes doing sequential read(24 for example), the
throughput is bad because every process can only work for about 25ms
and the cfqq is switched. That leads to a higher disk seek. We can
achive the good throughput by setting low_latency=0, but then some
read's latency is too much for the application.
So this patch makes cfq_target_latency tunable through sysfs so that
we can tune it and find some magic number which is not bad for both
the throughput and the read latency.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Instead of an ugly open coded variant.
Cc: axboe@kernel.dk
We should use the GFP flags that the caller specified instead of picking
our own. All the callers specify GFP_KERNEL so this doesn't make a
difference to how the kernel runs, it's just a cleanup.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup changes from Tejun Heo:
"Out of the 8 commits, one fixes a long-standing locking issue around
tasklist walking and others are cleanups."
* 'for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Walk task list under tasklist_lock in cgroup_enable_task_cg_list
cgroup: Remove wrong comment on cgroup_enable_task_cg_list()
cgroup: remove cgroup_subsys argument from callbacks
cgroup: remove extra calls to find_existing_css_set
cgroup: replace tasklist_lock with rcu_read_lock
cgroup: simplify double-check locking in cgroup_attach_proc
cgroup: move struct cgroup_pidlist out from the header file
cgroup: remove cgroup_attach_task_current_cg()
Pull scheduler changes for v3.4 from Ingo Molnar
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
printk: Make it compile with !CONFIG_PRINTK
sched/x86: Fix overflow in cyc2ns_offset
sched: Fix nohz load accounting -- again!
sched: Update yield() docs
printk/sched: Introduce special printk_sched() for those awkward moments
sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer
sched: Cleanup cpu_active madness
sched: Fix load-balance wreckage
sched: Clean up parameter passing of proc_sched_autogroup_set_nice()
sched: Ditch per cgroup task lists for load-balancing
sched: Rename load-balancing fields
sched: Move load-balancing arguments into helper struct
sched/rt: Do not submit new work when PI-blocked
sched/rt: Prevent idle task boosting
sched/wait: Add __wake_up_all_locked() API
sched/rt: Document scheduler related skip-resched-check sites
sched/rt: Use schedule_preempt_disabled()
sched/rt: Add schedule_preempt_disabled()
sched/rt: Do not throttle when PI boosting
sched/rt: Keep period timer ticking when rt throttling is active
Pull block fixes from Jens Axboe:
"Been sitting on this for a while, but lets get this out the door.
This fixes various important bugs for 3.3 final, along with a few more
trivial ones. Please pull!"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: fix ioc leak in put_io_context
block, sx8: fix pointer math issue getting fw version
Block: use a freezable workqueue for disk-event polling
drivers/block/DAC960: fix -Wuninitialized warning
drivers/block/DAC960: fix DAC960_V2_IOCTL_Opcode_T -Wenum-compare warning
block: fix __blkdev_get and add_disk race condition
block: Fix setting bio flags in drivers (sd_dif/floppy)
block: Fix NULL pointer dereference in sd_revalidate_disk
block: exit_io_context() should call elevator_exit_icq_fn()
block: simplify ioc_release_fn()
block: replace icq->changed with icq->flags
When put_io_context is called, if ioc->icq_list is empty and refcount
is 1, kernel will not free the ioc.
This is caught by following kmemleak:
unreferenced object 0xffff880036349fe0 (size 216):
comm "sh", pid 2137, jiffies 4294931140 (age 290579.412s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
01 00 01 00 ad 4e ad de ff ff ff ff 00 00 00 00 .....N..........
backtrace:
[<ffffffff8169f926>] kmemleak_alloc+0x26/0x50
[<ffffffff81195a9c>] kmem_cache_alloc_node+0x1cc/0x2a0
[<ffffffff81356b67>] create_io_context_slowpath+0x27/0x130
[<ffffffff81356d2b>] get_task_io_context+0xbb/0xf0
[<ffffffff81055f0e>] copy_process+0x188e/0x18b0
[<ffffffff8105609b>] do_fork+0x11b/0x420
[<ffffffff810247f8>] sys_clone+0x28/0x30
[<ffffffff816d3373>] stub_clone+0x13/0x20
[<ffffffffffffffff>] 0xffffffffffffffff
ioc should be freed if ioc->icq_list is empty.
Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com>
Acked-by: Tejun Heo <tj@kernel.org>
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
The following situation might occur:
__blkdev_get: add_disk:
register_disk()
get_gendisk()
disk_block_events()
disk->ev == NULL
disk_add_events()
__disk_unblock_events()
disk->ev != NULL
--ev->block
Then we unblock events, when they are suppose to be blocked. This can
trigger events related block/genhd.c warnings, but also can crash in
sd_check_events() or other places.
I'm able to reproduce crashes with the following scripts (with
connected usb dongle as sdb disk).
<snip>
DEV=/dev/sdb
ENABLE=/sys/bus/usb/devices/1-2/bConfigurationValue
function stop_me()
for i in `jobs -p` ; do kill $i 2> /dev/null ; done
exit
trap stop_me SIGHUP SIGINT SIGTERM
for ((i = 0; i < 10; i++)) ; do
while true; do fdisk -l $DEV 2>&1 > /dev/null ; done &
done
while true ; do
echo 1 > $ENABLE
sleep 1
echo 0 > $ENABLE
done
</snip>
I use the script to verify patch fixing oops in sd_revalidate_disk
http://marc.info/?l=linux-scsi&m=132935572512352&w=2
Without Jun'ichi Nomura patch titled "Fix NULL pointer dereference in
sd_revalidate_disk" or this one, script easily crash kernel within
a few seconds. With both patches applied I do not observe crash.
Unfortunately after some time (dozen of minutes), script will hung in:
[ 1563.906432] [<c08354f5>] schedule_timeout_uninterruptible+0x15/0x20
[ 1563.906437] [<c04532d5>] msleep+0x15/0x20
[ 1563.906443] [<c05d60b2>] blk_drain_queue+0x32/0xd0
[ 1563.906447] [<c05d6e00>] blk_cleanup_queue+0xd0/0x170
[ 1563.906454] [<c06d278f>] scsi_free_queue+0x3f/0x60
[ 1563.906459] [<c06d7e6e>] __scsi_remove_device+0x6e/0xb0
[ 1563.906463] [<c06d4aff>] scsi_forget_host+0x4f/0x60
[ 1563.906468] [<c06cd84a>] scsi_remove_host+0x5a/0xf0
[ 1563.906482] [<f7f030fb>] quiesce_and_remove_host+0x5b/0xa0 [usb_storage]
[ 1563.906490] [<f7f03203>] usb_stor_disconnect+0x13/0x20 [usb_storage]
Anyway I think this patch is some step forward.
As drawback, I do not teardown on sysfs file create error, because I do
not know how to nullify disk->ev (since it can be used). However add_disk
error handling practically does not exist too, and things will work
without this sysfs file, except events will not be exported to user
space.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: stable@kernel.org
Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(),
__blkdev_get() calls rescan_partitions() to remove
in-kernel partition structures and raise KOBJ_CHANGE uevent.
However it ends up calling driver's revalidate_disk without open
and could cause oops.
In the case of SCSI:
process A process B
sys_open
__blkdev_get
sd_open
returns -ENOMEDIUM
scsi_remove_device
<scsi_device torn down>
rescan_partitions
sd_revalidate_disk
<oops>
Oopses are reported here:
http://marc.info/?l=linux-scsi&m=132388619710052
This patch separates the partition invalidation from rescan_partitions()
and use it for -ENOMEDIUM case.
Reported-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Merge reason: we'll queue up dependent patches.
Extended VBLKs (those larger than the preset VBLK size) are divided
into fragments, each with its own VBLK header. Our LDM implementation
generally assumes that each VBLK is contiguous in memory, so these
fragments must be assembled before further processing.
Currently the reassembly seems to be done quite wrongly - no VBLK
header is copied into the contiguous buffer, and the length of the
header is subtracted twice from each fragment. Also the total
length of the reassembled VBLK is calculated incorrectly.
Signed-off-by: Anton Altaparmakov <anton@tuxera.com>
While updating locking, b2efa05265 "block, cfq: unlink
cfq_io_context's immediately" moved elevator_exit_icq_fn() invocation
from exit_io_context() to the final ioc put. While this doesn't cause
catastrophic failure, it effectively removes task exit notification to
elevator and cause noticeable IO performance degradation with CFQ.
On task exit, CFQ used to immediately expire the slice if it was being
used by the exiting task as no more IO would be issued by the task;
however, after b2efa05265, the notification is lost and disk could sit
idle needlessly, leading to noticeable IO performance degradation for
certain workloads.
This patch renames ioc_exit_icq() to ioc_destroy_icq(), separates
elevator_exit_icq_fn() invocation into ioc_exit_icq() and invokes it
from exit_io_context(). ICQ_EXITED flag is added to avoid invoking
the callback more than once for the same icq.
Walking icq_list from ioc side and invoking elevator callback requires
reverse double locking. This may be better implemented using RCU;
unfortunately, using RCU isn't trivial. e.g. RCU protection would
need to cover request_queue and queue_lock switch on cleanup makes
grabbing queue_lock from RCU unsafe. Reverse double locking should
do, at least for now.
Reported-and-bisected-by: Shaohua Li <shli@kernel.org>
LKML-Reference: <CANejiEVzs=pUhQSTvUppkDcc2TNZyfohBRLygW5zFmXyk5A-xQ@mail.gmail.com>
Tested-by: Shaohua Li <shaohua.li@intel.com>
Reverse double lock dancing in ioc_release_fn() can be simplified by
just using trylock on the queue_lock and back out from ioc lock on
trylock failure. Simplify it.
icq->changed was used for ICQ_*_CHANGED bits. Rename it to flags and
access it under ioc->lock instead of using atomic bitops.
ioc_get_changed() is added so that the changed part can be fetched and
cleared as before.
icq->flags will be used to carry other flags.
11a3122f6c "block: strip out locking optimization in put_io_context()"
removed ioc_lock depth lockdep annoation along with locking
optimization; however, while recursing from put_io_context() is no
longer possible, ioc_release_fn() may still end up putting the last
reference of another ioc through elevator, which wlil grab ioc->lock
triggering spurious (as the ioc is always different one) A-A deadlock
warning.
As this can only happen one time from ioc_release_fn(), using non-zero
subclass from ioc_release_fn() is enough. Use subclass 1.
We create "bsg" link if q->kobj.sd is not NULL, so remove it only
when the same condition is true.
Fixes:
WARNING: at fs/sysfs/inode.c:323 sysfs_hash_and_remove+0x2b/0x77()
sysfs: can not remove 'bsg', no directory
Call Trace:
[<c0429683>] warn_slowpath_common+0x6a/0x7f
[<c0537a68>] ? sysfs_hash_and_remove+0x2b/0x77
[<c042970b>] warn_slowpath_fmt+0x2b/0x2f
[<c0537a68>] sysfs_hash_and_remove+0x2b/0x77
[<c053969a>] sysfs_remove_link+0x20/0x23
[<c05d88f1>] bsg_unregister_queue+0x40/0x6d
[<c0692263>] __scsi_remove_device+0x31/0x9d
[<c069149f>] scsi_forget_host+0x41/0x52
[<c0689fa9>] scsi_remove_host+0x71/0xe0
[<f7de5945>] quiesce_and_remove_host+0x51/0x83 [usb_storage]
[<f7de5a1e>] usb_stor_disconnect+0x18/0x22 [usb_storage]
[<c06c29de>] usb_unbind_interface+0x4e/0x109
[<c067a80f>] __device_release_driver+0x6b/0xa6
[<c067a861>] device_release_driver+0x17/0x22
[<c067a46a>] bus_remove_device+0xd6/0xe6
[<c06785e2>] device_del+0xf2/0x137
[<c06c101f>] usb_disable_device+0x94/0x1a0
Plug merge calls two elevator callbacks outside queue lock -
elevator_allow_merge_fn() and elevator_bio_merged_fn(). Although
attempt_plug_merge() suggests that elevator is guaranteed to be there
through the existing request on the plug list, nothing prevents plug
merge from calling into dying or initializing elevator.
For regular merges, bypass ensures elvpriv count to reach zero, which
in turn prevents merges as all !ELVPRIV requests get REQ_SOFTBARRIER
from forced back insertion. Plug merge doesn't check ELVPRIV, and, as
the requests haven't gone through elevator insertion yet, it doesn't
have SOFTBARRIER set allowing merges on a bypassed queue.
This, for example, leads to the following crash during elevator
switch.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff813b34e9>] cfq_allow_merge+0x49/0xa0
PGD 112cbc067 PUD 115d5c067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
CPU 1
Modules linked in: deadline_iosched
Pid: 819, comm: dd Not tainted 3.3.0-rc2-work+ #76 Bochs Bochs
RIP: 0010:[<ffffffff813b34e9>] [<ffffffff813b34e9>] cfq_allow_merge+0x49/0xa0
RSP: 0018:ffff8801143a38f8 EFLAGS: 00010297
RAX: 0000000000000000 RBX: ffff88011817ce28 RCX: ffff880116eb6cc0
RDX: 0000000000000000 RSI: ffff880118056e20 RDI: ffff8801199512f8
RBP: ffff8801143a3908 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffff880118195708
R13: ffff880118052aa0 R14: ffff8801143a3d50 R15: ffff880118195708
FS: 00007f19f82cb700(0000) GS:ffff88011fc80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 0000000112c6a000 CR4: 00000000000006e0
Process dd (pid: 819, threadinfo ffff8801143a2000, task ffff880116eb6cc0)
Stack:
ffff88011817ce28 ffff880118195708 ffff8801143a3928 ffffffff81391bba
ffff88011817ce28 ffff880118195708 ffff8801143a3948 ffffffff81391bf1
ffff88011817ce28 0000000000000000 ffff8801143a39a8 ffffffff81398e3e
Call Trace:
[<ffffffff81391bba>] elv_rq_merge_ok+0x4a/0x60
[<ffffffff81391bf1>] elv_try_merge+0x21/0x40
[<ffffffff81398e3e>] blk_queue_bio+0x8e/0x390
[<ffffffff81396a5a>] generic_make_request+0xca/0x100
[<ffffffff81396b04>] submit_bio+0x74/0x100
[<ffffffff811d45c2>] __blockdev_direct_IO+0x1ce2/0x3450
[<ffffffff811d0dc7>] blkdev_direct_IO+0x57/0x60
[<ffffffff811460b5>] generic_file_aio_read+0x6d5/0x760
[<ffffffff811986b2>] do_sync_read+0xe2/0x120
[<ffffffff81199345>] vfs_read+0xc5/0x180
[<ffffffff81199501>] sys_read+0x51/0x90
[<ffffffff81aeac12>] system_call_fastpath+0x16/0x1b
There are multiple ways to fix this including making plug merge check
ELVPRIV; however,
* Calling into elevator outside queue lock is confusing and
error-prone.
* Requests on plug list aren't known to the elevator. They aren't on
the elevator yet, so there's no elevator specific state to update.
* Given the nature of plug merges - collecting bio's for the same
purpose from the same issuer - elevator specific restrictions aren't
applicable.
So, simply don't call into elevator methods from plug merge by moving
elv_bio_merged() from bio_attempt_*_merge() to blk_queue_bio(), and
using blk_try_merge() in attempt_plug_merge().
This is based on Jens' patch to skip elevator_allow_merge_fn() from
plug merge.
Note that this makes per-cgroup merged stats skip plug merging.
LKML-Reference: <4F16F3CA.90904@kernel.dk>
Original-patch-by: Jens Axboe <axboe@kernel.dk>
functions
blk_rq_merge_ok() is the elevator-neutral part of merge eligibility
test. blk_try_merge() determines merge direction and expects the
caller to have tested elv_rq_merge_ok() previously.
elv_rq_merge_ok() now wraps blk_rq_merge_ok() and then calls
elv_iosched_allow_merge(). elv_try_merge() is removed and the two
callers are updated to call elv_rq_merge_ok() explicitly followed by
blk_try_merge(). While at it, make rq_merge_ok() functions return
bool.
This is to prepare for plug merge update and doesn't introduce any
behavior change.
plug merge.
put_io_context() performed a complex trylock dancing to avoid
deferring ioc release to workqueue. It was also broken on UP because
trylock was always assumed to succeed which resulted in unbalanced
preemption count.
While there are ways to fix the UP breakage, even the most
pathological microbench (forced ioc allocation and tight fork/exit
loop) fails to show any appreciable performance benefit of the
optimization. Strip it out. If there turns out to be workloads which
are affected by this change, simpler optimization from the discussion
thread can be applied later.
LKML-Reference: <1328514611.21268.66.camel@sli10-conroe>
Meelis reported a warning:
WARNING: at kernel/timer.c:1122 run_timer_softirq+0x199/0x1ec()
Hardware name: 939Dual-SATA2
timer: cfq_idle_slice_timer+0x0/0xaa preempt leak: 00000102 -> 00000103
Modules linked in: sr_mod cdrom videodev media drm_kms_helper ohci_hcd ehci_hcd v4l2_compat_ioctl32 usbcore i2c_ali15x3 snd_seq drm snd_timer snd_seq
Pid: 0, comm: swapper Not tainted 3.3.0-rc2-00110-gd125666 #176
Call Trace:
<IRQ> [<ffffffff81022aaa>] warn_slowpath_common+0x7e/0x96
[<ffffffff8114c485>] ? cfq_slice_expired+0x1d/0x1d
[<ffffffff81022b56>] warn_slowpath_fmt+0x41/0x43
[<ffffffff8114c526>] ? cfq_idle_slice_timer+0xa1/0xaa
[<ffffffff8102c124>] run_timer_softirq+0x199/0x1ec
[<ffffffff81047a53>] ? timekeeping_get_ns+0x12/0x31
[<ffffffff810145fd>] ? apic_write+0x11/0x13
[<ffffffff81027475>] __do_softirq+0x74/0xfa
[<ffffffff812f337a>] call_softirq+0x1a/0x30
[<ffffffff81002ff9>] do_softirq+0x31/0x68
[<ffffffff810276cf>] irq_exit+0x3d/0xa3
[<ffffffff81014aca>] smp_apic_timer_interrupt+0x6b/0x77
[<ffffffff812f2de9>] apic_timer_interrupt+0x69/0x70
<EOI> [<ffffffff81040136>] ? sched_clock_cpu+0x73/0x7d
[<ffffffff8100801f>] ? default_idle+0x1e/0x32
[<ffffffff81008019>] ? default_idle+0x18/0x32
[<ffffffff810008b1>] cpu_idle+0x87/0xd1
[<ffffffff812de861>] rest_init+0x85/0x89
[<ffffffff81659a4d>] start_kernel+0x2eb/0x2f8
[<ffffffff8165926e>] x86_64_start_reservations+0x7e/0x82
[<ffffffff81659362>] x86_64_start_kernel+0xf0/0xf7
this_q == locked_q is possible. There are two problems here:
1. In UP case, there is preemption counter issue as spin_trylock always
successes.
2. In SMP case, the loop breaks too earlier.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reported-by: Meelis Roos <mroos@linux.ee>
Reported-by: Knut Petersen <Knut_Petersen@t-online.de>
Tested-by: Knut Petersen <Knut_Petersen@t-online.de>
The argument is not used at all, and it's not necessary, because
a specific callback handler of course knows which subsys it
belongs to.
Now only ->pupulate() takes this argument, because the handlers of
this callback always call cgroup_add_file()/cgroup_add_files().
So we reduce a few lines of code, though the shrinking of object size
is minimal.
16 files changed, 113 insertions(+), 162 deletions(-)
5486240 656987 7039960 13183187 c928d3 vmlinux.o.orig
5486170 656987 7039960 13183117 c9288d vmlinux.o
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
The block layer has some code trying to determine if two CPUs share a
cache, the scheduler has a similar function. Expose the function used
by the scheduler and make the block layer use it, thereby removing the
block layers usage of CONFIG_SCHED* and topology bits.
Link: http://lkml.kernel.org/r/1327579450.2446.95.camel@twins
Vivek reported a kernel crash:
[ 94.217015] BUG: unable to handle kernel NULL pointer dereference at 000000000000001c
[ 94.218004] IP: [<ffffffff81142fae>] kmem_cache_free+0x5e/0x200
[ 94.218004] PGD 13abda067 PUD 137d52067 PMD 0
[ 94.218004] Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 94.218004] CPU 0
[ 94.218004] Modules linked in: [last unloaded: scsi_wait_scan]
[ 94.218004]
[ 94.218004] Pid: 0, comm: swapper/0 Not tainted 3.2.0+ #16 Hewlett-Packard HP xw6600 Workstation/0A9Ch
[ 94.218004] RIP: 0010:[<ffffffff81142fae>] [<ffffffff81142fae>] kmem_cache_free+0x5e/0x200
[ 94.218004] RSP: 0018:ffff88013fc03de0 EFLAGS: 00010006
[ 94.218004] RAX: ffffffff81e0d020 RBX: ffff880138b3c680 RCX: 00000001801c001b
[ 94.218004] RDX: 00000000003aac1d RSI: ffff880138b3c680 RDI: ffffffff81142fae
[ 94.218004] RBP: ffff88013fc03e10 R08: ffff880137830238 R09: 0000000000000001
[ 94.218004] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 94.218004] R13: ffffea0004e2cf00 R14: ffffffff812f6eb6 R15: 0000000000000246
[ 94.218004] FS: 0000000000000000(0000) GS:ffff88013fc00000(0000) knlGS:0000000000000000
[ 94.218004] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 94.218004] CR2: 000000000000001c CR3: 00000001395ab000 CR4: 00000000000006f0
[ 94.218004] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 94.218004] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 94.218004] Process swapper/0 (pid: 0, threadinfo ffffffff81e00000, task ffffffff81e0d020)
[ 94.218004] Stack:
[ 94.218004] 0000000000000102 ffff88013fc0db20 ffffffff81e22700 ffff880139500f00
[ 94.218004] 0000000000000001 000000000000000a ffff88013fc03e20 ffffffff812f6eb6
[ 94.218004] ffff88013fc03e90 ffffffff810c8da2 ffffffff81e01fd8 ffff880137830240
[ 94.218004] Call Trace:
[ 94.218004] <IRQ>
[ 94.218004] [<ffffffff812f6eb6>] icq_free_icq_rcu+0x16/0x20
[ 94.218004] [<ffffffff810c8da2>] __rcu_process_callbacks+0x1c2/0x420
[ 94.218004] [<ffffffff810c9038>] rcu_process_callbacks+0x38/0x250
[ 94.218004] [<ffffffff810405ee>] __do_softirq+0xce/0x3e0
[ 94.218004] [<ffffffff8108ed04>] ? clockevents_program_event+0x74/0x100
[ 94.218004] [<ffffffff81090104>] ? tick_program_event+0x24/0x30
[ 94.218004] [<ffffffff8183ed1c>] call_softirq+0x1c/0x30
[ 94.218004] [<ffffffff8100422d>] do_softirq+0x8d/0xc0
[ 94.218004] [<ffffffff81040c3e>] irq_exit+0xae/0xe0
[ 94.218004] [<ffffffff8183f4be>] smp_apic_timer_interrupt+0x6e/0x99
[ 94.218004] [<ffffffff8183e330>] apic_timer_interrupt+0x70/0x80
Once a queue is quiesced, it's not supposed to have any elvpriv data or
icq's, and elevator switching depends on that. Request alloc path
followed the rule for elvpriv data but forgot apply it to icq's
leading to the following crash during elevator switch. Fix it by not
allocating icq's if ELVPRIV is not set for the request.
Reported-by: Vivek Goyal <vgoyal@redhat.com>
Tested-by: Vivek Goyal <vgoyal@redhat.com>
cfq_slice_expired will change saved_workload_slice. It should be called
first so saved_workload_slice is correctly set to 0 after workload type
is changed.
This fixes the code order changed by 54b466e44b1c7.
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
With the changes in life time management between the cfq IO contexts
and the cfq queues, we now risk having cfqd->active_queue being
freed when cfq_slice_expired() is being called. cfq_preempt_queue()
caches this queue and uses it after calling said function, causing
a use-after-free condition. This triggers the following oops,
when cfqq_type() attempts to dereference it:
BUG: unable to handle kernel paging request at ffff8800746c4f0c
IP: [<ffffffff81266d59>] cfqq_type+0xb/0x20
PGD 18d4063 PUD 1fe15067 PMD 1ffb9067 PTE 80000000746c4160
CPU 3
Modules linked in:
Pid: 1, comm: init Not tainted 3.2.0-josef+ #367 Bochs Bochs
RIP: 0010:[<ffffffff81266d59>] [<ffffffff81266d59>] cfqq_type+0xb/0x20
RSP: 0018:ffff880079c11778 EFLAGS: 00010046
RAX: 0000000000000000 RBX: ffff880076f3df08 RCX: 0000000000000000
RDX: 0000000000000006 RSI: ffff880074271888 RDI: ffff8800746c4f08
RBP: ffff880079c11778 R08: 0000000000000078 R09: 0000000000000001
R10: 09f911029d74e35b R11: 09f911029d74e35b R12: ffff880076f337f0
R13: ffff8800746c4f08 R14: ffff8800746c4f08 R15: 0000000000000002
FS: 00007f62fd44f700(0000) GS:ffff88007cd80000(0000) knlGS:0000000000000000
CR2: ffff8800746c4f0c CR3: 0000000076c21000 CR4: 00000000000006e0
Process init (pid: 1, threadinfo ffff880079c10000, task ffff880079c0a040)
Stack:
ffff880079c117c8 ffffffff812683d8 ffff880079c117a8 ffffffff8125de43
ffff8800744fcf48 ffff880074b43e98 ffff8800770c8828 ffff880074b43e98
0000000000000003 0000000000000000 ffff880079c117f8 ffffffff81254149
Call Trace:
[<ffffffff812683d8>] cfq_insert_request+0x3f5/0x47c
[<ffffffff8125de43>] ? blk_recount_segments+0x20/0x31
[<ffffffff81254149>] __elv_add_request+0x1ca/0x200
[<ffffffff8125aa99>] blk_queue_bio+0x2ef/0x312
[<ffffffff81258f7b>] generic_make_request+0x9f/0xe0
[<ffffffff8125907b>] submit_bio+0xbf/0xca
[<ffffffff81136ec7>] submit_bh+0xdf/0xfe
[<ffffffff81176d04>] ext3_bread+0x50/0x99
[<ffffffff811785b3>] dx_probe+0x38/0x291
[<ffffffff81178864>] ext3_dx_find_entry+0x58/0x219
[<ffffffff81178ad5>] ext3_find_entry+0xb0/0x406
[<ffffffff8110c4d5>] ? cache_alloc_debugcheck_after.isra.46+0x14d/0x1a0
[<ffffffff8110cfbd>] ? kmem_cache_alloc+0xef/0x191
[<ffffffff8117a330>] ext3_lookup+0x39/0xe1
[<ffffffff81119461>] d_alloc_and_lookup+0x45/0x6c
[<ffffffff8111ac41>] do_lookup+0x1e4/0x2f5
[<ffffffff8111aef6>] link_path_walk+0x1a4/0x6ef
[<ffffffff8111b557>] path_lookupat+0x59/0x5ea
[<ffffffff8127406c>] ? __strncpy_from_user+0x30/0x5a
[<ffffffff8111bce0>] do_path_lookup+0x23/0x59
[<ffffffff8111cfd6>] user_path_at_empty+0x53/0x99
[<ffffffff8107b37b>] ? remove_wait_queue+0x51/0x56
[<ffffffff8111d02d>] user_path_at+0x11/0x13
[<ffffffff811141f5>] vfs_fstatat+0x3a/0x64
[<ffffffff8111425a>] vfs_stat+0x1b/0x1d
[<ffffffff81114359>] sys_newstat+0x1a/0x33
[<ffffffff81060e12>] ? task_stopped_code+0x42/0x42
[<ffffffff815d6712>] system_call_fastpath+0x16/0x1b
Code: 89 e6 48 89 c7 e8 fa ca fe ff 85 c0 74 06 4c 89 2b 41 b6 01 5b 44 89 f0 41 5c 41 5d 41 5e 5d c3 55 48 89 e5 66 66 66 66 90 31 c0 <8b> 57 04 f6 c6 01 74 0b 83 e2 20 83 fa 01 19 c0 83 c0 02 5d c3
RIP [<ffffffff81266d59>] cfqq_type+0xb/0x20
RSP <ffff880079c11778>
Get rid of the caching of cfqd->active_queue, and reorder the
check so that it happens before we expire the active queue.
Thanks to Tejun for pin pointing the error location.
Reported-by: Chris Mason <chris.mason@oracle.com>
Tested-by: Chris Mason <chris.mason@oracle.com>
* 'for-3.3/core' of git://git.kernel.dk/linux-block: (37 commits)
Revert "block: recursive merge requests"
block: Stop using macro stubs for the bio data integrity calls
blockdev: convert some macros to static inlines
fs: remove unneeded plug in mpage_readpages()
block: Add BLKROTATIONAL ioctl
block: Introduce blk_set_stacking_limits function
block: remove WARN_ON_ONCE() in exit_io_context()
block: an exiting task should be allowed to create io_context
block: ioc_cgroup_changed() needs to be exported
block, cfq: fix empty queue crash caused by request merge
block, cfq: move icq creation and rq->elv.icq association to block core
block, cfq: restructure io_cq creation path for io_context interface cleanup
block, cfq: move io_cq exit/release to blk-ioc.c
block, cfq: move icq cache management to block core
block, cfq: move io_cq lookup to blk-ioc.c
block, cfq: move cfqd->icq_list to request_queue and add request->elv.icq
block, cfq: reorganize cfq_io_context into generic and cfq specific parts
block: remove elevator_queue->ops
block: reorder elevator switch sequence
Fix up conflicts in:
- block/blk-cgroup.c
Switch from can_attach_task to can_attach
- block/cfq-iosched.c
conflict with now removed cic index changes (we now use q->id instead)
This reverts commit 274193224cdabd687d804a26e0150bb20f2dd52c.
We have some problems related to selection of empty queues
that need to be resolved, evidence so far points to the
recursive merge logic making either being the cause or at
least the accelerator for this. So revert it for now, until
we figure this out.
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and
will pass the command to the underlying block device. This is
well-known, but it is also a large security problem when (via Unix
permissions, ACLs, SELinux or a combination thereof) a program or user
needs to be granted access only to part of the disk.
This patch lets partitions forward a small set of harmless ioctls;
others are logged with printk so that we can see which ioctls are
actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred.
Of course it was being sent to a (partition on a) hard disk, so it would
have failed with ENOTTY and the patch isn't changing anything in
practice. Still, I'm treating it specially to avoid spamming the logs.
In principle, this restriction should include programs running with
CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and
/dev/sdb, it still should not be able to read/write outside the
boundaries of /dev/sda2 independent of the capabilities. However, for
now programs with CAP_SYS_RAWIO will still be allowed to send the
ioctls. Their actions will still be logged.
This patch does not affect the non-libata IDE driver. That driver
however already tests for bd != bd->bd_contains before issuing some
ioctl; it could be restricted further to forbid these ioctls even for
programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO.
Cc: linux-scsi@vger.kernel.org
Cc: James Bottomley <JBottomley@parallels.com>
[ Make it also print the command name when warning - Linus ]
Introduce a wrapper around scsi_cmd_ioctl that takes a block device.
The function will then be enhanced to detect partition block devices
and, in that case, subject the ioctls to whitelisting.
Introduce an ioctl which permits applications to query whether a block
device is rotational.
Stacking driver queue limits are typically bounded exclusively by the
capabilities of the low level devices, not by the stacking driver
itself.
This patch introduces blk_set_stacking_limits() which has more liberal
metrics than the default queue limits function. This allows us to
inherit topology parameters from bottom devices without manually
tweaking the default limits in each driver prior to calling the stacking
function.
Since there is now a clear distinction between stacking and low-level
devices, blk_set_default_limits() has been modified to carry the more
conservative values that we used to manually set in
blk_queue_make_request().
Acked-by: Mike Snitzer <snitzer@redhat.com>
* 'for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits)
cgroup: fix to allow mounting a hierarchy by name
cgroup: move assignement out of condition in cgroup_attach_proc()
cgroup: Remove task_lock() from cgroup_post_fork()
cgroup: add sparse annotation to cgroup_iter_start() and cgroup_iter_end()
cgroup: mark cgroup_rmdir_waitq and cgroup_attach_proc() as static
cgroup: only need to check oldcgrp==newgrp once
cgroup: remove redundant get/put of task struct
cgroup: remove redundant get/put of old css_set from migrate
cgroup: Remove unnecessary task_lock before fetching css_set on migration
cgroup: Drop task_lock(parent) on cgroup_fork()
cgroups: remove redundant get/put of css_set from css_set_check_fetched()
resource cgroups: remove bogus cast
cgroup: kill subsys->can_attach_task(), pre_attach() and attach_task()
cgroup, cpuset: don't use ss->pre_attach()
cgroup: don't use subsys->can_attach_task() or ->attach_task()
cgroup: introduce cgroup_taskset and use it in subsys->can_attach(), cancel_attach() and attach()
cgroup: improve old cgroup handling in cgroup_attach_proc()
cgroup: always lock threadgroup during migration
threadgroup: extend threadgroup_lock() to cover exit and exec
threadgroup: rename signal->threadgroup_fork_lock to ->group_rwsem
Fix up conflict in kernel/cgroup.c due to commit e0197aae59e5: "cgroups:
fix a css_set not found bug in cgroup_attach_proc" that already
mentioned that the bug is fixed (differently) in Tejun's cgroup
patchset. This one, in other words.
* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits)
reiserfs: Properly display mount options in /proc/mounts
vfs: prevent remount read-only if pending removes
vfs: count unlinked inodes
vfs: protect remounting superblock read-only
vfs: keep list of mounts for each superblock
vfs: switch ->show_options() to struct dentry *
vfs: switch ->show_path() to struct dentry *
vfs: switch ->show_devname() to struct dentry *
vfs: switch ->show_stats to struct dentry *
switch security_path_chmod() to struct path *
vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb
vfs: trim includes a bit
switch mnt_namespace ->root to struct mount
vfs: take /proc/*/mounts and friends to fs/proc_namespace.c
vfs: opencode mntget() mnt_set_mountpoint()
vfs: spread struct mount - remaining argument of next_mnt()
vfs: move fsnotify junk to struct mount
vfs: move mnt_devname
vfs: move mnt_list to struct mount
vfs: switch pnode.h macros to struct mount *
We're doing some odd things there, which already messes up various users
(see the net/socket.c code that this removes), and it was going to add
yet more crud to the block layer because of the incorrect error code
translation.
ENOIOCTLCMD is not an error return that should be returned to user mode
from the "ioctl()" system call, but it should *not* be translated as
EINVAL ("Invalid argument"). It should be translated as ENOTTY
("Inappropriate ioctl for device").
That EINVAL confusion has apparently so permeated some code that the
block layer actually checks for it, which is sad. We continue to do so
for now, but add a big comment about how wrong that is, and we should
remove it entirely eventually. In the meantime, this tries to keep the
changes localized to just the EINVAL -> ENOTTY fix, and removing code
that makes it harder to do the right thing.
both callers of device_get_devnode() are only interested in lower 16bits
and nobody tries to return anything wider than 16bit anyway.
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export
kill_bdev as well, so brd doesn't have to open code it. Reduce
buffer_head.h requirement accordingly.
Removed a rather large comment from invalidate_bdev, as it looked a bit
obsolete to bother moving. The small comment replacing it says enough.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
