path: root/block
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-30Merge branch 'for-3.14/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver changes from Jens Axboe: - bcache update from Kent Overstreet. - two bcache fixes from Nicholas Swenson. - cciss pci init error fix from Andrew. - underflow fix in the parallel IDE pg_write code from Dan Carpenter. I'm sure the 1 (or 0) users of that are now happy. - two PCI related fixes for sx8 from Jingoo Han. - floppy init fix for first block read from Jiri Kosina. - pktcdvd error return miss fix from Julia Lawall. - removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from Michael Opdenacker. - comment typo fix for the loop driver from Olaf Hering. - potential oops fix for null_blk from Raghavendra K T. - two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing an OOM problem and a problem with handling security locked conditions * 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits) mg_disk: Spelling s/finised/finished/ null_blk: Null pointer deference problem in alloc_page_buffers mtip32xx: Correctly handle security locked condition mtip32xx: Make SGL container per-command to eliminate high order dma allocation drivers/block/loop.c: fix comment typo in loop_config_discard drivers/block/cciss.c:cciss_init_one(): use proper errnos drivers/block/paride/pg.c: underflow bug in pg_write() drivers/block/sx8.c: remove unnecessary pci_set_drvdata() drivers/block/sx8.c: use module_pci_driver() floppy: bail out in open() if drive is not responding to block0 read bcache: Fix auxiliary search trees for key size > cacheline size bcache: Don't return -EINTR when insert finished bcache: Improve bucket_prio() calculation bcache: Add bch_bkey_equal_header() bcache: update bch_bkey_try_merge bcache: Move insert_fixup() to btree_keys_ops bcache: Convert sorting to btree_keys bcache: Convert debug code to btree_keys bcache: Convert btree_iter to struct btree_keys bcache: Refactor bset_tree sysfs stats ...
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-28block/blk-mq-cpu.c: use hotcpu_notifier()Andrew Morton
Cleaner, reduces text size when cpu hotplug is disabled. Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-23percpu_ida: Make percpu_ida_alloc + callers accept task state bitmaskKent Overstreet
This patch changes percpu_ida_alloc() + callers to accept task state bitmask for prepare_to_wait() for code like target/iscsi that needs it for interruptible sleep, that is provided in a subsequent patch. It now expects TASK_UNINTERRUPTIBLE when the caller is able to sleep waiting for a new tag, or TASK_RUNNING when the caller cannot sleep, and is forced to return a negative value when no tags are available. v2 changes: - Include blk-mq + tcm_fc + vhost/scsi + target/iscsi changes - Drop signal_pending_state() call v3 changes: - Only call prepare_to_wait() + finish_wait() when != TASK_RUNNING (PeterZ) Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: <stable@vger.kernel.org> #3.12+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-01-21block: Fix memory leak in rw_copy_check_uvector() handlingChristian Engelmayer
Fix a memory leak in the error handling path of function sg_io() that is used during the processing of scsi ioctl. Memory already allocated by rw_copy_check_uvector() needs to be freed correctly. Detected by Coverity: CID 1128953. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21block: remove unrelated header files and export symbolCaiZhiyong
Fix up the following items: - remove unrelated header files. - export interface function. - modify function cmdline_parts_parse return value, this will make it more friendly for the caller. Signed-off-by: CaiZhiyong <caizhiyong@huawei.com> Cc: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> CC: Brian Norris <computersforpeace@gmail.com> Cc: "Wanglin (Albert)" <albert.wanglin@hisilicon.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Karel Zak <kzak@redhat.com> Cc: Shmulik Ladkani <shmulik.ladkani@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-21Merge branch 'for-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "The bulk of changes are cleanups and preparations for the upcoming kernfs conversion. - cgroup_event mechanism which is and will be used only by memcg is moved to memcg. - pidlist handling is updated so that it can be served by seq_file. Also, the list is not sorted if sane_behavior. cgroup documentation explicitly states that the file is not sorted but it has been for quite some time. - All cgroup file handling now happens on top of seq_file. This is to prepare for kernfs conversion. In addition, all operations are restructured so that they map 1-1 to kernfs operations. - Other cleanups and low-pri fixes" * 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (40 commits) cgroup: trivial style updates cgroup: remove stray references to css_id doc: cgroups: Fix typo in doc/cgroups cgroup: fix fail path in cgroup_load_subsys() cgroup: fix missing unlock on error in cgroup_load_subsys() cgroup: remove for_each_root_subsys() cgroup: implement for_each_css() cgroup: factor out cgroup_subsys_state creation into create_css() cgroup: combine css handling loops in cgroup_create() cgroup: reorder operations in cgroup_create() cgroup: make for_each_subsys() useable under cgroup_root_mutex cgroup: css iterations and css_from_dir() are safe under cgroup_mutex cgroup: unify pidlist and other file handling cgroup: replace cftype->read_seq_string() with cftype->seq_show() cgroup: attach cgroup_open_file to all cgroup files cgroup: generalize cgroup_pidlist_open_file cgroup: unify read path so that seq_file is always used cgroup: unify cgroup_write_X64() and cgroup_write_string() cgroup: remove cftype->read(), ->read_map() and ->write() hugetlb_cgroup: convert away from cftype->read() ...
2014-01-08blk-mq: uses page->list incorrectlyDave Hansen
'struct page' has two list_head fields: 'lru' and 'list'. Conveniently, they are unioned together. This means that code can use them interchangably, which gets horribly confusing. The blk-mq made the logical decision to try to use page->list. But, that field was actually introduced just for the slub code. ->lru is the right field to use outside of slab/slub. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-08blk-mq: use __smp_call_function_single directlyChristoph Hellwig
__smp_call_function_single already avoids multiple IPIs by internally queing up the items, and now also is available for non-SMP builds as a trivially correct stub, so there is no need to wrap it. If the additional lock roundtrip cause problems my patch to convert the generic IPI code to llists is waiting to get merged will fix it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2014-01-08bcache/md: Use raid stripe sizeKent Overstreet
Now that we've got code for raid5/6 stripe awareness, bcache just needs to know about the stripes and when writing partial stripes is expensive - we probably don't want to enable this optimization for raid1 or 10, even though they have stripes. So add a flag to queue_limits. Signed-off-by: Kent Overstreet <kmo@daterainc.com>
2014-01-03blk-mq: fix initializing request's start timeMing Lei
blk_rq_init() is called in req's complete handler to initialize the request, so the members of start_time and start_time_ns might become inaccurate when it is allocated in future. The patch initializes the two members in blk_mq_rq_ctx_init() to fix the problem. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-31block: blk-mq: don't export blk_mq_free_queue()Ming Lei
blk_mq_free_queue() is called from release handler of queue kobject, so it needn't be called from drivers. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-31block: blk-mq: make blk_sync_queue support mqMing Lei
This patch moves synchronization on mq->delay_work from blk_mq_free_queue() to blk_sync_queue(), so that blk_sync_queue can work on mq. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-31block: blk-mq: support draining mq queueMing Lei
blk_mq_drain_queue() is introduced so that we can drain mq queue inside blk_cleanup_queue(). Also don't accept new requests any more if queue is marked as dying. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-31Merge tag 'v3.13-rc6' into for-3.14/coreJens Axboe
Needed to bring blk-mq uptodate, since changes have been going in since for-3.14/core was established. Fixup merge issues related to the immutable biovec changes. Signed-off-by: Jens Axboe <axboe@kernel.dk> Conflicts: block/blk-flush.c fs/btrfs/check-integrity.c fs/btrfs/extent_io.c fs/btrfs/scrub.c fs/logfs/dev_bdev.c
2013-12-06block: fix memory leaks on unplugging block deviceAndrey Vagin
All objects, which are allocated in blk_mq_register_disk, must be released in blk_mq_unregister_disk. I use a KVM virtual machine and virtio disk to reproduce this issue. kmemleak: 18 new suspected memory leaks (see /sys/kernel/debug/kmemleak) $ cat /sys/kernel/debug/kmemleak | head -n 30 unreferenced object 0xffff8800b6636150 (size 8): comm "kworker/0:2", pid 65, jiffies 4294809903 (age 86.358s) hex dump (first 8 bytes): 76 69 72 74 69 6f 34 00 virtio4. backtrace: [<ffffffff8165d41e>] kmemleak_alloc+0x4e/0xb0 [<ffffffff8118cfc5>] __kmalloc_track_caller+0xf5/0x260 [<ffffffff81155b11>] kstrdup+0x31/0x60 [<ffffffff812242be>] sysfs_new_dirent+0x2e/0x140 [<ffffffff81224678>] create_dir+0x38/0xe0 [<ffffffff812249e3>] sysfs_create_dir_ns+0x73/0xc0 [<ffffffff8130dfa9>] kobject_add_internal+0xc9/0x340 [<ffffffff8130e535>] kobject_add+0x65/0xb0 [<ffffffff813f34f8>] device_add+0x128/0x660 [<ffffffff813f3a4a>] device_register+0x1a/0x20 [<ffffffff813ae6f8>] register_virtio_device+0x98/0xe0 [<ffffffff813b0cce>] virtio_pci_probe+0x12e/0x1c0 [<ffffffff81340675>] local_pci_probe+0x45/0xa0 [<ffffffff81341a51>] pci_device_probe+0x121/0x130 [<ffffffff813f67f7>] driver_probe_device+0x87/0x390 [<ffffffff813f6b3b>] __device_attach+0x3b/0x40 unreferenced object 0xffff8800b65aa1d8 (size 144): Fixes: 320ae51feed5 (blk-mq: new multi-queue block IO queueing mechanism) Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-05Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes for the current series. It contains: - A fix for a use-after-free of a request in blk-mq. From Ming Lei - A fix for a blk-mq bug that could attempt to dereference a NULL rq if allocation failed - Two xen-blkfront small fixes - Cleanup of submit_bio_wait() type uses in the kernel, unifying that. From Kent - A fix for 32-bit blkg_rwstat reading. I apologize for this one looking mangled in the shortlog, it's entirely my fault for missing an empty line between the description and body of the text" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: fix use-after-free of request blk-mq: fix dereference of rq->mq_ctx if allocation fails block: xen-blkfront: Fix possible NULL ptr dereference xen-blkfront: Silence pfn maybe-uninitialized warning block: submit_bio_wait() conversions Update of blkg_stat and blkg_rwstat may happen in bh context
2013-12-05blk-mq: fix use-after-free of requestMing Lei
If accounting is on, we will do the IO completion accounting after we have freed the request. Fix that by moving it sooner instead. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-05cgroup: replace cftype->read_seq_string() with cftype->seq_show()Tejun Heo
In preparation of conversion to kernfs, cgroup file handling is updated so that it can be easily mapped to kernfs. This patch replaces cftype->read_seq_string() with cftype->seq_show() which is not limited to single_open() operation and will map directcly to kernfs seq_file interface. The conversions are mechanical. As ->seq_show() doesn't have @css and @cft, the functions which make use of them are converted to use seq_css() and seq_cft() respectively. In several occassions, e.f. if it has seq_string in its name, the function name is updated to fit the new method better. This patch does not introduce any behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Aristeu Rozanski <arozansk@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Neil Horman <nhorman@tuxdriver.com>
2013-12-03block: Really silence spurious compiler warningsKent Overstreet
The uninitialized_var() macro appears to not work on structs... Get rid of it, and manually initialize instead. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-12-03blk-mq: fix dereference of rq->mq_ctx if allocation failsJeff Moyer
If __GFP_WAIT isn't set and we fail allocating, when we go to drop the reference on the ctx, we will attempt to dereference the NULL rq. Fix that. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-26block: Silence spurious compiler warningsKent Overstreet
2013-11-24block: submit_bio_wait() conversionsKent Overstreet
It was being open coded in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Chris Mason <chris.mason@fusionio.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-23block: Kill bio_iovec_idx(), __bio_iovec()Kent Overstreet
bio_iovec_idx() and __bio_iovec() don't have any valid uses anymore - previous users have been converted to bio_iovec_iter() or other methods. __BVEC_END() has to go too - the bvec array can't be used directly for the last biovec because we might only be using the first portion of it, we have to iterate over the bvec array with bio_for_each_segment() which checks against the current value of bi_iter.bi_size. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk>
2013-11-23bio-integrity: Convert to bvec_iterKent Overstreet
The bio integrity is also stored in a bvec array, so if we use the bvec iter code we just added, the integrity code won't need to implement its own iteration stuff (bio_integrity_mark_head(), bio_integrity_mark_tail()) Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
2013-11-23block: Convert bio_for_each_segment() to bvec_iterKent Overstreet
More prep work for immutable biovecs - with immutable bvecs drivers won't be able to use the biovec directly, they'll need to use helpers that take into account bio->bi_iter.bi_bvec_done. This updates callers for the new usage without changing the implementation yet. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Paul Clements <Paul.Clements@steeleye.com> Cc: Jim Paris <jim@jtan.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com> Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Cc: support@lsi.com Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Quoc-Son Anh <quoc-sonx.anh@intel.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jan Kara <jack@suse.cz> Cc: linux-m68k@lists.linux-m68k.org Cc: linuxppc-dev@lists.ozlabs.org Cc: drbd-user@lists.linbit.com Cc: nbd-general@lists.sourceforge.net Cc: cbe-oss-dev@lists.ozlabs.org Cc: xen-devel@lists.xensource.com Cc: virtualization@lists.linux-foundation.org Cc: linux-raid@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: DL-MPTFusionLinux@lsi.com Cc: linux-scsi@vger.kernel.org Cc: devel@driverdev.osuosl.org Cc: linux-fsdevel@vger.kernel.org Cc: cluster-devel@redhat.com Cc: linux-mm@kvack.org Acked-by: Geoff Levand <geoff@infradead.org>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-23block: submit_bio_wait() conversionsKent Overstreet
2013-11-21block/partitions/efi.c: fix bound checkAntti P Miettinen
Use ARRAY_SIZE instead of sizeof to get proper max for label length. Since this is just a read out of bounds it's not that bad, but the problem becomes user-visible eg if one tries to use DEBUG_PAGEALLOC and DEBUG_RODATA, at least with some enhancements from Hiroshi. Of course the destination array can contain garbage when we read beyond the end of source array so that would be another user-visible problem. Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com> Tested-by: Hiroshi Doyu <hdoyu@nvidia.com> Cc: Will Drewry <wad@chromium.org> Cc: Matt Fleming <matt.fleming@intel.com> Acked-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-20Update of blkg_stat and blkg_rwstat may happen in bh context.Hong Zhiguo
While u64_stats_fetch_retry is only preempt_disable on 32bit UP system. This is not enough to avoid preemption by bh and may read strange 64 bit value. Signed-off-by: Hong Zhiguo <zhiguohong@tencent.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-19blk-mq: add blktrace insert event traceJens Axboe
We need it to make 'btt' from blktrace happy, otherwise we are missing one state transition. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-19blk-mq: ensure that we set REQ_IO_STAT so diskstats workJens Axboe
If disk stats are enabled on the queue, a request needs to be marked with REQ_IO_STAT for accounting to be active on that request. This fixes an issue with virtio-blk not showing up in /proc/diskstats after the conversion to blk-mq. Add QUEUE_FLAG_MQ_DEFAULT, setting stats and same cpu-group completion on by default. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-15Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull second round of block driver updates from Jens Axboe: "As mentioned in the original pull request, the bcache bits were pulled because of their dependency on the immutable bio vecs. Kent re-did this part and resubmitted it, so here's the 2nd round of (mostly) driver updates for 3.13. It contains: - The bcache work from Kent. - Conversion of virtio-blk to blk-mq. This removes the bio and request path, and substitutes with the blk-mq path instead. The end result almost 200 deleted lines. Patch is acked by Asias and Christoph, who both did a bunch of testing. - A removal of bootmem.h include from Grygorii Strashko, part of a larger series of his killing the dependency on that header file. - Removal of __cpuinit from blk-mq from Paul Gortmaker" * 'for-linus' of git://git.kernel.dk/linux-block: (56 commits) virtio_blk: blk-mq support blk-mq: remove newly added instances of __cpuinit bcache: defensively handle format strings bcache: Bypass torture test bcache: Delete some slower inline asm bcache: Use ida for bcache block dev minor bcache: Fix sysfs splat on shutdown with flash only devs bcache: Better full stripe scanning bcache: Have btree_split() insert into parent directly bcache: Move spinlock into struct time_stats bcache: Kill sequential_merge option bcache: Kill bch_next_recurse_key() bcache: Avoid deadlocking in garbage collection bcache: Incremental gc bcache: Add make_btree_freeing_key() bcache: Add btree_node_write_sync() bcache: PRECEDING_KEY() bcache: bch_(btree|extent)_ptr_invalid() bcache: Don't bother with bucket refcount for btree node allocations bcache: Debug code improvements ...
2013-11-15kernel: remove CONFIG_USE_GENERIC_SMP_HELPERSChristoph Hellwig
We've switched over every architecture that supports SMP to it, so remove the new useless config variable. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14blk-mq: remove newly added instances of __cpuinitPaul Gortmaker
The new blk-mq code added new instances of __cpuinit usage. We removed this a couple versions ago; we now want to remove the compat no-op stubs. Introducing new users is not what we want to see at this point in time, as it will break once the stubs are gone. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-14Merge branch 'for-3.13/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO core updates from Jens Axboe: "This is the pull request for the core changes in the block layer for 3.13. It contains: - The new blk-mq request interface. This is a new and more scalable queueing model that marries the best part of the request based interface we currently have (which is fully featured, but scales poorly) and the bio based "interface" which the new drivers for high IOPS devices end up using because it's much faster than the request based one. The bio interface has no block layer support, since it taps into the stack much earlier. This means that drivers end up having to implement a lot of functionality on their own, like tagging, timeout handling, requeue, etc. The blk-mq interface provides all these. Some drivers even provide a switch to select bio or rq and has code to handle both, since things like merging only works in the rq model and hence is faster for some workloads. This is a huge mess. Conversion of these drivers nets us a substantial code reduction. Initial results on converting SCSI to this model even shows an 8x improvement on single queue devices. So while the model was intended to work on the newer multiqueue devices, it has substantial improvements for "classic" hardware as well. This code has gone through extensive testing and development, it's now ready to go. A pull request is coming to convert virtio-blk to this model will be will be coming as well, with more drivers scheduled for 3.14 conversion. - Two blktrace fixes from Jan and Chen Gang. - A plug merge fix from Alireza Haghdoost. - Conversion of __get_cpu_var() from Christoph Lameter. - Fix for sector_div() with 64-bit divider from Geert Uytterhoeven. - A fix for a race between request completion and the timeout handling from Jeff Moyer. This is what caused the merge conflict with blk-mq/core, in case you are looking at that. - A dm stacking fix from Mike Snitzer. - A code consolidation fix and duplicated code removal from Kent Overstreet. - A handful of block bug fixes from Mikulas Patocka, fixing a loop crash and memory corruption on blk cg. - Elevator switch bug fix from Tomoki Sekiyama. A heads-up that I had to rebase this branch. Initially the immutable bio_vecs had been queued up for inclusion, but a week later, it became clear that it wasn't fully cooked yet. So the decision was made to pull this out and postpone it until 3.14. It was a straight forward rebase, just pruning out the immutable series and the later fixes of problems with it. The rest of the patches applied directly and no further changes were made" * 'for-3.13/core' of git://git.kernel.dk/linux-block: (31 commits) block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO block: Do not call sector_div() with a 64-bit divisor kernel: trace: blktrace: remove redundent memcpy() in compat_blk_trace_setup() block: Consolidate duplicated bio_trim() implementations block: Use rw_copy_check_uvector() block: Enable sysfs nomerge control for I/O requests in the plug list block: properly stack underlying max_segment_size to DM device elevator: acquire q->sysfs_lock in elevator_change() elevator: Fix a race in elevator switching and md device initialization block: Replace __get_cpu_var uses bdi: test bdi_init failure block: fix a probe argument to blk_register_region loop: fix crash if blk_alloc_queue fails blk-core: Fix memory corruption if blkcg_init_queue fails block: fix race between request completion and timeout handling blktrace: Send BLK_TN_PROCESS events to all running traces blk-mq: don't disallow request merges for req->special being set blk-mq: mq plug list breakage blk-mq: fix for flush deadlock ...
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-13block: Use u64_stats_init() to initialize seqcountsPeter Zijlstra
Now that seqcounts are lockdep enabled objects, we need to explicitly initialize runtime allocated seqcounts so that lockdep can track them. Without this patch, Fengguang was seeing: [ 4.127282] INFO: trying to register non-static key. [ 4.128027] the code is fine but needs lockdep annotation. [ 4.128027] turning off the locking correctness validator. [ 4.128027] CPU: 0 PID: 96 Comm: kworker/u4:1 Not tainted 3.12.0-next-20131108-10601-gbad570d #2 [ 4.128027] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ ... ] [ 4.128027] Call Trace: [ 4.128027] [<7908e744>] ? console_unlock+0x353/0x380 [ 4.128027] [<79dc7cf2>] dump_stack+0x48/0x60 [ 4.128027] [<7908953e>] __lock_acquire.isra.26+0x7e3/0xceb [ 4.128027] [<7908a1c5>] lock_acquire+0x71/0x9a [ 4.128027] [<794079aa>] ? blk_throtl_bio+0x1c3/0x485 [ 4.128027] [<7940658b>] throtl_update_dispatch_stats+0x7c/0x153 [ 4.128027] [<794079aa>] ? blk_throtl_bio+0x1c3/0x485 [ 4.128027] [<794079aa>] blk_throtl_bio+0x1c3/0x485 ... Use u64_stats_init() for all affected data structures, which initializes the seqcount. Reported-and-Tested-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Peter Zijlstra <peterz@infradead.org> [ Folded in another fix from the mailing list as well as a fix to that fix. Tweaked commit message. ] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1384314134-6895-1-git-send-email-john.stultz@linaro.org [ So I actually think that the two SOBs from PeterZ are the right depiction of the patch route. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-08block: cleanup removing dependency on bootmem headersGrygorii Strashko
Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08Merge branch 'blk-mq/core' into for-3.13/coreJens Axboe
Signed-off-by: Jens Axboe <axboe@kernel.dk> Conflicts: block/blk-timeout.c
2013-11-08block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERODuan Jiong
This patch fixes coccinelle error regarding usage of IS_ERR and PTR_ERR instead of PTR_ERR_OR_ZERO. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08block: Do not call sector_div() with a 64-bit divisorGeert Uytterhoeven
do_div() (called by sector_div() if CONFIG_LBDAF=y) is meant for divisions of 64-bit number by 32-bit numbers. Passing 64-bit divisor types caused issues in the past on 32-bit platforms, cfr. commit ea077b1b96e073eac5c3c5590529e964767fc5f7 ("m68k: Truncate base in do_div()"). As queue_limits.max_discard_sectors and .discard_granularity are unsigned int, max_discard_sectors and granularity should be unsigned int. As bdev_discard_alignment() returns int, alignment should be int. Now 2 calls to sector_div() can be replaced by 32-bit arithmetic: - The 64-bit modulo operation can become a 32-bit modulo operation, - The 64-bit division and multiplication can be replaced by a 32-bit modulo operation and a subtraction. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08block: Use rw_copy_check_uvector()Kent Overstreet
No need for silly open coding - and struct sg_iovec has exactly the same layout as struct iovec... Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08block: Enable sysfs nomerge control for I/O requests in the plug listAlireza Haghdoost
This patch enables the sysfs to control I/O request merge functionality in the plug list. While this control has been implemented for the request queue, it was dismissed in the plug list. Therefore, block layer merges requests together (or attempt to merge) even if the merge capability was disable using sysfs nomerge parameter value 2. This limitation is directly affects functionality of io_submit() system call. The system call enables user to submit a bunch of IO requests from user space using struct iocb **ios input argument. However, the unconditioned merging functionality in the plug list potentially merges these requests together down the road. Therefore, there is no way to distinguish between an application sending bunch of sequential IOs and an application sending one big IO. Ultimately, all requests generated by the former app merge within the plug list together and looks similar to the second app. While the merging functionality is a desirable feature to improve the performance of IO subsystem for some applications, it is not useful for other application like ours at all. Signed-off-by: Alireza Haghdoost <alireza@cs.umn.edu> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Coding style modified. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08block: properly stack underlying max_segment_size to DM deviceMike Snitzer
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE (65536) even if the underlying device(s) have a larger value -- this is due to blk_stack_limits() using min_not_zero() when stacking the max_segment_size limit. 1073741824 before patch: 65536 after patch: 1073741824 Reported-by: Lukasz Flis <l.flis@cyfronet.pl> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # v3.3+ Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08elevator: acquire q->sysfs_lock in elevator_change()Tomoki Sekiyama
Add locking of q->sysfs_lock into elevator_change() (an exported function) to ensure it is held to protect q->elevator from elevator_init(), even if elevator_change() is called from non-sysfs paths. sysfs path (elv_iosched_store) uses __elevator_change(), non-locking version, as the lock is already taken by elv_iosched_store(). Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-08elevator: Fix a race in elevator switching and md device initializationTomoki Sekiyama
The soft lockup below happens at the boot time of the system using dm multipath and the udev rules to switch scheduler. [ 356.127001] BUG: soft lockup - CPU#3 stuck for 22s! [sh:483] [ 356.127001] RIP: 0010:[<ffffffff81072a7d>] [<ffffffff81072a7d>] lock_timer_base.isra.35+0x1d/0x50 ... [ 356.127001] Call Trace: [ 356.127001] [<ffffffff81073810>] try_to_del_timer_sync+0x20/0x70 [ 356.127001] [<ffffffff8118b08a>] ? kmem_cache_alloc_node_trace+0x20a/0x230 [ 356.127001] [<ffffffff810738b2>] del_timer_sync+0x52/0x60 [ 356.127001] [<ffffffff812ece22>] cfq_exit_queue+0x32/0xf0 [ 356.127001] [<ffffffff812c98df>] elevator_exit+0x2f/0x50 [ 356.127001] [<ffffffff812c9f21>] elevator_change+0xf1/0x1c0 [ 356.127001] [<ffffffff812caa50>] elv_iosched_store+0x20/0x50 [ 356.127001] [<ffffffff812d1d09>] queue_attr_store+0x59/0xb0 [ 356.127001] [<ffffffff812143f6>] sysfs_write_file+0xc6/0x140 [ 356.127001] [<ffffffff811a326d>] vfs_write+0xbd/0x1e0 [ 356.127001] [<ffffffff811a3ca9>] SyS_write+0x49/0xa0 [ 356.127001] [<ffffffff8164e899>] system_call_fastpath+0x16/0x1b This is caused by a race between md device initialization by multipathd and shell script to switch the scheduler using sysfs. - multipathd: SyS_ioctl -> do_vfs_ioctl -> dm_ctl_ioctl -> ctl_ioctl -> table_load -> dm_setup_md_queue -> blk_init_allocated_queue -> elevator_init q->elevator = elevator_alloc(q, e); // not yet initialized - sh -c 'echo deadline > /sys/$DEVPATH/queue/scheduler': elevator_switch (in the call trace above) struct elevator_queue *old = q->elevator; q->elevator = elevator_alloc(q, new_e); elevator_exit(old); // lockup! (*) - multipathd: (cont.) err = e->ops.elevator_init_fn(q); // init fails; q->elevator is modified (*) When del_timer_sync() is called, lock_timer_base() will loop infinitely while timer->base == NULL. In this case, as timer will never initialized, it results in lockup. This patch introduces acquisition of q->sysfs_lock around elevator_init() into blk_init_allocated_queue(), to provide mutual exclusion between initialization of the q->scheduler and switching of the scheduler. This should fix this bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=902012 Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
