path: root/block
2010-08-12block: add secure discardAdrian Hunter
Secure discard is the same as discard except that all copies of the discarded sectors (perhaps created by garbage collection) must also be erased. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-08blkdev: fix blkdev_issue_zeroout return valueDmitry Monakhov
- If function called without barrier option retvalue is incorrect Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-08block: update request stacking methods to support discardsike Snitzer
Propagate REQ_DISCARD in cmd_flags when cloning a discard request. Skip blk_rq_check_limits's existing checks for discard requests because discard limits will have already been checked in blkdev_issue_discard. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: set up rq->rq_disk properly for flush requestsFUJITA Tomonori
q->bar_rq.rq_disk is NULL. Use the rq_disk of the original request instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: set REQ_TYPE_FS on flush requestsFUJITA Tomonori
the block layer doesn't set rq->cmd_type on flush requests. By definition, it should be REQ_TYPE_FS (the lower layers build a command and interpret the result of it, that is, the block layer doesn't know the details). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: fix problem with sending down discard that isn't of correct granularityJens Axboe
If the queue doesn't have a limit set, or it just set UINT_MAX like we default to, we coud be sending down a discard request that isn't of the correct granularity if the block size is > 512b. Fix this by adjusting max_discard_sectors down to the proper alignment. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07blkdev: check for valid request queue before issuing flushDave Chinner
Issuing a blkdev_issue_flush() on an unconfigured loop device causes a panic as q->make_request_fn is not configured. This can occur when trying to mount the unconfigured loop device as an XFS filesystem. There are no guards that catch the bio before the request function is called because we don't add a payload to the bio. Instead, manually check this case as soon as we have a pointer to the queue to flush. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove BKL from partition ioctlsArnd Bergmann
The blkpg_ioctl and blkdev_reread_part access fields of the bdev and gendisk structures, yet they always do so under the protection of bdev->bd_mutex, which seems sufficient. Signed-off-by: Arnd Bergmann <arnd@arndb.de> cked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove BKL from BLKROSET and BLKFLSBUFArnd Bergmann
We only call the functions set_device_ro(), invalidate_bdev(), sync_filesystem() and sync_blockdev() while holding the BKL in these commands. All of these are also done in other code paths without the BKL, which leads me to the conclusion that the BKL is not needed here either. The reason we hold it here is that it was originally pushed down into the ioctl function from vfs_ioctl. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push BKL into blktrace ioctlsArnd Bergmann
The blktrace driver currently needs the BKL, but we should not need to take that in the block layer, so just push it down into the driver itself. It is quite likely that the BKL is not actually required in blktrace code and could be removed in a follow-on patch. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove q->prepare_flush_fn completelyFUJITA Tomonori
This removes q->prepare_flush_fn completely (changes the blk_queue_ordered API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: permit PREFLUSH and POSTFLUSH without prepare_flush_fnFUJITA Tomonori
This is preparation for removing q->prepare_flush_fn. Temporarily, blk_queue_ordered() permits QUEUE_ORDERED_DO_PREFLUSH and QUEUE_ORDERED_DO_POSTFLUSH without prepare_flush_fn. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: introduce REQ_FLUSH flagFUJITA Tomonori
SCSI-ml needs a way to mark a request as flush request in q->prepare_flush_fn because it needs to identify them later (e.g. in q->request_fn or prep_rq_fn). queue_flush sets REQ_HARDBARRIER in rq->cmd_flags however the block layer also sends normal REQ_TYPE_FS requests with REQ_HARDBARRIER. So SCSI-ml can't use REQ_HARDBARRIER to identify flush requests. We could change the block layer to clear REQ_HARDBARRIER bit before sending non flush requests to the lower layers. However, intorudcing the new flag looks cleaner (surely easier). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@suse.de> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: implement an unprep function corresponding directly to prepJames Bottomley
Reviewed-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: fixup missing conversion from BIO_RW_DISCARD to REQ_DISCARDJens Axboe
Didn't cause a merge conflict, so fixed this one up manually post merge. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07gcc-4.6: block: fix unused but set variables in blk-mergeAndi Kleen
Just some dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: don't allocate a payload for discard requestChristoph Hellwig
Allocating a fixed payload for discard requests always was a horrible hack, and it's not coming to byte us when adding support for discard in DM/MD. So change the code to leave the allocation of a payload to the lowlevel driver. Unfortunately that means we'll need another hack, which allows us to update the various block layer length fields indicating that we have a payload. Instead of hiding this in sd.c, which we already partially do for UNMAP support add a documented helper in the core block layer for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: add helpers for the trivial queue flag sysfs show/store entriesJens Axboe
The code for nonrot, random, and io stats are completely identical. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: add sysfs knob for turning off disk entropy contributionsJens Axboe
There are two reasons for doing this: - On SSD disks, the completion times aren't as random as they are for rotational drives. So it's questionable whether they should contribute to the random pool in the first place. - Calling add_disk_randomness() has a lot of overhead. This adds /sys/block/<dev>/queue/add_random that will allow you to switch off on a per-device basis. The default setting is on, so there should be no functional changes from this patch. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-24block: Don't count_vm_events for discard bio in submit_bio.Tao Ma
In submit_bio, we count vm events by check READ/WRITE. But actually DISCARD_NOBARRIER also has the WRITE flag set. It looks as if in blkdev_issue_discard, we also add a page as the payload and the bio_has_data check isn't enough. So add another check for discard bio. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-21cfq: fix recursive call in cfq_blkiocg_update_completion_stats()Jens Axboe
e98ef89b has a typo, causing cfq_blkiocg_update_completion_stats() to call itself instead of blkiocg_update_completion_stats(). Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-18cfq-iosched: Fixed boot warning with BLK_CGROUP=y and CFQ_GROUP_IOSCHED=nVivek Goyal
Hi Jens, Few days back Ingo noticed a CFQ boot time warning. This patch fixes it. The issue here is that with CFQ_GROUP_IOSCHED=n, CFQ should not really be making blkio stat related calls. > Hm, it's still not entirely fixed, as of 2.6.35-rc2-00131-g7908a9e. With > some > configs i get bad spinlock warnings during bootup: > > [ 28.968013] initcall net_olddevs_init+0x0/0x82 returned 0 after 93750 > usecs > [ 28.972003] calling b44_init+0x0/0x55 @ 1 > [ 28.976009] bus: 'pci': add driver b44 > [ 28.976374] sda: > [ 28.978157] BUG: spinlock bad magic on CPU#1, async/0/117 > [ 28.980000] lock: 7e1c5bbc, .magic: 00000000, .owner: <none>/-1, +.owner_cpu: 0 > [ 28.980000] Pid: 117, comm: async/0 Not tainted +2.6.35-rc2-tip-01092-g010e7ef-dirty #8183 > [ 28.980000] Call Trace: > [ 28.980000] [<41ba6d55>] ? printk+0x20/0x24 > [ 28.980000] [<4134b7b7>] spin_bug+0x7c/0x87 > [ 28.980000] [<4134b853>] do_raw_spin_lock+0x1e/0x123 > [ 28.980000] [<41ba92ca>] ? _raw_spin_lock_irqsave+0x12/0x20 > [ 28.980000] [<41ba92d2>] _raw_spin_lock_irqsave+0x1a/0x20 > [ 28.980000] [<4133476f>] blkiocg_update_io_add_stats+0x25/0xfb > [ 28.980000] [<41335dae>] ? cfq_prio_tree_add+0xb1/0xc1 > [ 28.980000] [<41337bc7>] cfq_insert_request+0x8c/0x425 Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-17cfq: Don't allow queue merges for queues that have no process referencesJeff Moyer
Hi, A user reported a kernel bug when running a particular program that did the following: created 32 threads - each thread took a mutex, grabbed a global offset, added a buffer size to that offset, released the lock - read from the given offset in the file - created a new thread to do the same - exited The result is that cfq's close cooperator logic would trigger, as the threads were issuing I/O within the mean seek distance of one another. This workload managed to routinely trigger a use after free bug when walking the list of merge candidates for a particular cfqq (cfqq->new_cfqq). The logic used for merging queues looks like this: static void cfq_setup_merge(struct cfq_queue *cfqq, struct cfq_queue *new_cfqq) { int process_refs, new_process_refs; struct cfq_queue *__cfqq; /* Avoid a circular list and skip interim queue merges */ while ((__cfqq = new_cfqq->new_cfqq)) { if (__cfqq == cfqq) return; new_cfqq = __cfqq; } process_refs = cfqq_process_refs(cfqq); /* * If the process for the cfqq has gone away, there is no * sense in merging the queues. */ if (process_refs == 0) return; /* * Merge in the direction of the lesser amount of work. */ new_process_refs = cfqq_process_refs(new_cfqq); if (new_process_refs >= process_refs) { cfqq->new_cfqq = new_cfqq; atomic_add(process_refs, &new_cfqq->ref); } else { new_cfqq->new_cfqq = cfqq; atomic_add(new_process_refs, &cfqq->ref); } } When a merge candidate is found, we add the process references for the queue with less references to the queue with more. The actual merging of queues happens when a new request is issued for a given cfqq. In the case of the test program, it only does a single pread call to read in 1MB, so the actual merge never happens. Normally, this is fine, as when the queue exits, we simply drop the references we took on the other cfqqs in the merge chain: /* * If this queue was scheduled to merge with another queue, be * sure to drop the reference taken on that queue (and others in * the merge chain). See cfq_setup_merge and cfq_merge_cfqqs. */ __cfqq = cfqq->new_cfqq; while (__cfqq) { if (__cfqq == cfqq) { WARN(1, "cfqq->new_cfqq loop detected\n"); break; } next = __cfqq->new_cfqq; cfq_put_queue(__cfqq); __cfqq = next; } However, there is a hole in this logic. Consider the following (and keep in mind that each I/O keeps a reference to the cfqq): q1->new_cfqq = q2 // q2 now has 2 process references q3->new_cfqq = q2 // q2 now has 3 process references // the process associated with q2 exits // q2 now has 2 process references // queue 1 exits, drops its reference on q2 // q2 now has 1 process reference // q3 exits, so has 0 process references, and hence drops its references // to q2, which leaves q2 also with 0 process references q4 comes along and wants to merge with q3 q3->new_cfqq still points at q2! We follow that link and end up at an already freed cfqq. So, the fix is to not follow a merge chain if the top-most queue does not have a process reference, otherwise any queue in the chain could be already freed. I also changed the logic to disallow merging with a queue that does not have any process references. Previously, we did this check for one of the merge candidates, but not the other. That doesn't really make sense. Without the attached patch, my system would BUG within a couple of seconds of running the reproducer program. With the patch applied, my system ran the program for over an hour without issues. This addresses the following bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16217 Thanks a ton to Phil Carns for providing the bug report and an excellent reproducer. [ Note for stable: this applies to 2.6.32/33/34 ]. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-by: Phil Carns <carns@mcs.anl.gov> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-17block: fix DISCARD_BARRIER requestsChristoph Hellwig
Filesystems assume that DISCARD_BARRIER are full barriers, so that they don't have to track in-progress discard operation when submitting new I/O. But currently we only treat them as elevator barriers, which don't actually do the nessecary queue drains. Also remove the unlikely around both the DISCARD and BARRIER requests - the happen far too often for a static mispredict. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-04block: make blk_init_free_list and elevator_init idempotentMike Snitzer
blk_init_allocated_queue_node may fail and the caller _could_ retry. Accommodate the unlikely event that blk_init_allocated_queue_node is called on an already initialized (possibly partially) request_queue. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-04block: avoid unconditionally freeing previously allocated request_queueMike Snitzer
On blk_init_allocated_queue_node failure, only free the request_queue if it is wasn't previously allocated outside the block layer (e.g. blk_init_queue_node was blk_init_allocated_queue_node caller). This addresses an interface bug introduced by the following commit: 01effb0 block: allow initialization of previously allocated request_queue Otherwise the request_queue may be free'd out from underneath a caller that is managing the request_queue directly (e.g. caller uses blk_alloc_queue + blk_init_allocated_queue_node). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-25cfq-iosched: fix an oops caused by slab leakShaohua Li
I got below oops when unloading cfq-iosched. Considering scenario: queue A merge to B, C merge to D and B will be merged to D. Before B is merged to D, we do split B. We should put B's reference for D. [ 807.768536] ============================================================================= [ 807.768539] BUG cfq_queue: Objects remaining on kmem_cache_close() [ 807.768541] ----------------------------------------------------------------------------- [ 807.768543] [ 807.768546] INFO: Slab 0xffffea0003e6b4e0 objects=26 used=1 fp=0xffff88011d584fd8 flags=0x200000000004082 [ 807.768550] Pid: 5946, comm: rmmod Tainted: G W 2.6.34-07097-gf4b87de-dirty #724 [ 807.768552] Call Trace: [ 807.768560] [<ffffffff81104e8d>] slab_err+0x8f/0x9d [ 807.768564] [<ffffffff811059e1>] ? flush_cpu_slab+0x0/0x93 [ 807.768569] [<ffffffff8164be52>] ? add_preempt_count+0xe/0xca [ 807.768572] [<ffffffff8164bd9c>] ? sub_preempt_count+0xe/0xb6 [ 807.768577] [<ffffffff81648871>] ? _raw_spin_unlock+0x15/0x30 [ 807.768580] [<ffffffff8164bd9c>] ? sub_preempt_count+0xe/0xb6 [ 807.768584] [<ffffffff811061bc>] list_slab_objects+0x9b/0x19f [ 807.768588] [<ffffffff8164bf0a>] ? add_preempt_count+0xc6/0xca [ 807.768591] [<ffffffff81109e27>] kmem_cache_destroy+0x13f/0x21d [ 807.768597] [<ffffffffa000ff13>] cfq_slab_kill+0x1a/0x43 [cfq_iosched] [ 807.768601] [<ffffffffa000ffcf>] cfq_exit+0x93/0x9e [cfq_iosched] [ 807.768606] [<ffffffff810973a2>] sys_delete_module+0x1b1/0x219 [ 807.768612] [<ffffffff8102fb5b>] system_call_fastpath+0x16/0x1b [ 807.768618] INFO: Object 0xffff88011d584618 @offset=1560 [ 807.768622] INFO: Allocated in cfq_get_queue+0x11e/0x274 [cfq_iosched] age=7173 cpu=1 pid=5496 [ 807.768626] ============================================================================= Cc: stable@kernel.org Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-24block: Adjust elv_iosched_show to return "none" for bio-based DMMike Snitzer
Bio-based DM doesn't use an elevator (queue is !blk_queue_stackable()). Longer-term DM will not allocate an elevator for bio-based DM. But even then there will be small potential for an elevator to be allocated for a request-based DM table only to have a bio-based table be loaded in the end. Displaying "none" for bio-based DM will help avoid user confusion. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-24cfq-iosched: compact io_context radix_treeKonstantin Khlebnikov
Use small consequent indexes as radix tree keys instead of sparse cfqd address. This change will reduce radix tree depth from 11 (6 for 32-bit hosts) to 1 if host have <=64 disks under cfq control, or to 0 if there only one disk. So, this patch save 10*560 bytes for each process (5*296 for 32-bit hosts) For each cfqd allocate cic index from ida. To unlink dead cic from tree without cfqd access store index into ->key. (bit 0 -- dead mark, bits 1..30 -- index: ida produce id in range 0..2^31-1) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-24cfq-iosched: remove dead_key from cfq_io_contextKonstantin Khlebnikov
Remove ->dead_key field from cfq_io_context to shrink its size to 128 bytes. (64 bytes for 32-bit hosts) Use lower bit in ->key as dead-mark, instead of moving key to separate field. After this for dead cfq_io_context we got cic->key != cfqd automatically. Thus, io_context's last-hit cache should work without changing. Now to check ->key for non-dead state compare it with cfqd, instead of checking ->key for non-null value as it was before. Plus remove obsolete race protection in cfq_cic_lookup. This race gone after v2.6.24-1728-g4ac845a Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21block: remove all rcu head initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-11block: allow initialization of previously allocated request_queueMike Snitzer
blk_init_queue() allocates the request_queue structure and then initializes it as needed (request_fn, elevator, etc). Split initialization out to blk_init_allocated_queue_node. Introduce blk_init_allocated_queue wrapper function to model existing blk_init_queue and blk_init_queue_node interfaces. Export elv_register_queue to allow a newly added elevator to be registered with sysfs. Export elv_unregister_queue for symmetry. These changes allow DM to initialize a device's request_queue with more precision. In particular, DM no longer unconditionally initializes a full request_queue (elevator et al). It only does so for a request-based DM device. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-07blk-cgroup: Fix an RCU warning in blkiocg_create()Li Zefan
with CONFIG_PROVE_RCU=y, a warning can be triggered: # mount -t cgroup -o blkio xxx /mnt # mkdir /mnt/subgroup ... kernel/cgroup.c:4442 invoked rcu_dereference_check() without protection! ... To fix this, we avoid caling css_depth() here, which is a bit simpler than the original code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-06blk-cgroup: Fix RCU correctness warning in cfq_init_queue()Vivek Goyal
It is necessary to be in an RCU read-side critical section when invoking css_id(), so this patch adds one to blkiocg_add_blkio_group(). This is actually a false positive, because this is called at initialization time and hence always refers to the root cgroup, which cannot go away. [ 103.790505] =================================================== [ 103.790509] [ INFO: suspicious rcu_dereference_check() usage. ] [ 103.790511] --------------------------------------------------- [ 103.790514] kernel/cgroup.c:4432 invoked rcu_dereference_check() without protection! [ 103.790517] [ 103.790517] other info that might help us debug this: [ 103.790519] [ 103.790521] [ 103.790521] rcu_scheduler_active = 1, debug_locks = 1 [ 103.790524] 4 locks held by bash/4422: [ 103.790526] #0: (&buffer->mutex){+.+.+.}, at: [<ffffffff8114befa>] sysfs_write_file+0x3c/0x144 [ 103.790537] #1: (s_active#102){.+.+.+}, at: [<ffffffff8114bfa5>] sysfs_write_file+0xe7/0x144 [ 103.790544] #2: (&q->sysfs_lock){+.+.+.}, at: [<ffffffff812263b1>] queue_attr_store+0x49/0x8f [ 103.790552] #3: (&(&blkcg->lock)->rlock){......}, at: [<ffffffff8122e4db>] blkiocg_add_blkio_group+0x2b/0xad [ 103.790560] [ 103.790561] stack backtrace: [ 103.790564] Pid: 4422, comm: bash Not tainted 2.6.34-rc4-blkio-second-crash #81 [ 103.790567] Call Trace: [ 103.790572] [<ffffffff81068f57>] lockdep_rcu_dereference+0x9d/0xa5 [ 103.790577] [<ffffffff8107fac1>] css_id+0x44/0x57 [ 103.790581] [<ffffffff8122e503>] blkiocg_add_blkio_group+0x53/0xad [ 103.790586] [<ffffffff81231936>] cfq_init_queue+0x139/0x32c [ 103.790591] [<ffffffff8121f2d0>] elv_iosched_store+0xbf/0x1bf [ 103.790595] [<ffffffff812263d8>] queue_attr_store+0x70/0x8f [ 103.790599] [<ffffffff8114bfa5>] ? sysfs_write_file+0xe7/0x144 [ 103.790603] [<ffffffff8114bfc6>] sysfs_write_file+0x108/0x144 [ 103.790609] [<ffffffff810f527f>] vfs_write+0xae/0x10b [ 103.790612] [<ffffffff81069863>] ? trace_hardirqs_on_caller+0x10c/0x130 [ 103.790616] [<ffffffff810f539c>] sys_write+0x4a/0x6e [ 103.790622] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 103.790625] Located-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-03block: kill some useless goto's in blk-cgroup.cJens Axboe
goto has its place, but lets cut back on some of the more frivolous uses of it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-29block: fix bad use of min() on different typesJens Axboe
Just cast the page size to sector_t, that will always fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28cfq-iosched: fix broken cfq_ref_get_cfqf() for CONFIG_BLK_CGROUP=y && ↵Dmitry Monakhov
CFQ_GROUP_IOSCHED=n We should return the cfq_group for this case, not NULL. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: add blkdev_issue_zeroout helper functionDmitry Monakhov
- Add bio_batch helper primitive. This is rather generic primitive for submitting/waiting a complex request which consists of several bios. - blkdev_issue_zeroout() generate number of zero filed write bios. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: move blkdev_issue helper functions to separate fileDmitry Monakhov
Move blkdev_issue_discard from blk-barrier.c because it is not barrier related. Later the file will be populated by other helpers. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: allow async blkdev_issue_flush requestsDmitry Monakhov
In some places caller don't want to wait a request to complete. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: generalize flags for blkdev_issue_fn functionsDmitry Monakhov
The patch just convert all blkdev_issue_xxx function to common set of flags. Wait/allocation semantics preserved. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blk-cgroup: config options re-arrangementVivek Goyal
This patch fixes few usability and configurability issues. o All the cgroup based controller options are configurable from "Genral Setup/Control Group Support/" menu. blkio is the only exception. Hence make this option visible in above menu and make it configurable from there to bring it inline with rest of the cgroup based controllers. o Get rid of CONFIG_DEBUG_CFQ_IOSCHED. This option currently does two things. - Enable printing of cgroup paths in blktrace - Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat files in cgroup. If we are using group scheduling, blktrace data is of not really much use if cgroup information is not present. To get this data, currently one has to also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of all the additional debug stat files which is not desired. Hence, this patch moves printing of cgroup paths under CONFIG_CFQ_GROUP_IOSCHED. This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which can be enabled through config menu. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-26blkio: Fix another BUG_ON() crash due to cfqq movement across groupsVivek Goyal
o Once in a while, I was hitting a BUG_ON() in blkio code. empty_time was assuming that upon slice expiry, group can't be marked empty already (except forced dispatch). But this assumption is broken if cfqq can move (group_isolation=0) across groups after receiving a request. I think most likely in this case we got a request in a cfqq and accounted the rq in one group, later while adding the cfqq to tree, we moved the queue to a different group which was already marked empty and after dispatch from slice we found group already marked empty and raised alarm. This patch does not error out if group is already marked empty. This can introduce some empty_time stat error only in case of group_isolation=0. This is better than crashing. In case of group_isolation=1 we should still get same stats as before this patch. [ 222.308546] ------------[ cut here ]------------ [ 222.309311] kernel BUG at block/blk-cgroup.c:236! [ 222.309311] invalid opcode: 0000 [#1] SMP [ 222.309311] last sysfs file: /sys/devices/virtual/block/dm-3/queue/scheduler [ 222.309311] CPU 1 [ 222.309311] Modules linked in: dm_round_robin dm_multipath qla2xxx scsi_transport_fc dm_zero dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] [ 222.309311] [ 222.309311] Pid: 4780, comm: fio Not tainted 2.6.34-rc4-blkio-config #68 0A98h/HP xw8600 Workstation [ 222.309311] RIP: 0010:[<ffffffff8121ad88>] [<ffffffff8121ad88>] blkiocg_set_start_empty_time+0x50/0x83 [ 222.309311] RSP: 0018:ffff8800ba6e79f8 EFLAGS: 00010002 [ 222.309311] RAX: 0000000000000082 RBX: ffff8800a13b7990 RCX: ffff8800a13b7808 [ 222.309311] RDX: 0000000000002121 RSI: 0000000000000082 RDI: ffff8800a13b7a30 [ 222.309311] RBP: ffff8800ba6e7a18 R08: 0000000000000000 R09: 0000000000000001 [ 222.309311] R10: 000000000002f8c8 R11: ffff8800ba6e7ad8 R12: ffff8800a13b78ff [ 222.309311] R13: ffff8800a13b7990 R14: 0000000000000001 R15: ffff8800a13b7808 [ 222.309311] FS: 00007f3beec476f0(0000) GS:ffff880001e40000(0000) knlGS:0000000000000000 [ 222.309311] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 222.309311] CR2: 000000000040e7f0 CR3: 00000000a12d5000 CR4: 00000000000006e0 [ 222.309311] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 222.309311] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 222.309311] Process fio (pid: 4780, threadinfo ffff8800ba6e6000, task ffff8800b3d6bf00) [ 222.309311] Stack: [ 222.309311] 0000000000000001 ffff8800bab17a48 ffff8800bab17a48 ffff8800a13b7800 [ 222.309311] <0> ffff8800ba6e7a68 ffffffff8121da35 ffff880000000001 00ff8800ba5c5698 [ 222.309311] <0> ffff8800ba6e7a68 ffff8800a13b7800 0000000000000000 ffff8800bab17a48 [ 222.309311] Call Trace: [ 222.309311] [<ffffffff8121da35>] __cfq_slice_expired+0x2af/0x3ec [ 222.309311] [<ffffffff8121fd7b>] cfq_dispatch_requests+0x2c8/0x8e8 [ 222.309311] [<ffffffff8120f1cd>] ? spin_unlock_irqrestore+0xe/0x10 [ 222.309311] [<ffffffff8120fb1a>] ? blk_insert_cloned_request+0x70/0x7b [ 222.309311] [<ffffffff81210461>] blk_peek_request+0x191/0x1a7 [ 222.309311] [<ffffffffa0002799>] dm_request_fn+0x38/0x14c [dm_mod] [ 222.309311] [<ffffffff810ae61f>] ? sync_page_killable+0x0/0x35 [ 222.309311] [<ffffffff81210fd4>] __generic_unplug_device+0x32/0x37 [ 222.309311] [<ffffffff81211274>] generic_unplug_device+0x2e/0x3c [ 222.309311] [<ffffffffa00011a6>] dm_unplug_all+0x42/0x5b [dm_mod] [ 222.309311] [<ffffffff8120ca37>] blk_unplug+0x29/0x2d [ 222.309311] [<ffffffff8120ca4d>] blk_backing_dev_unplug+0x12/0x14 [ 222.309311] [<ffffffff81109a7a>] block_sync_page+0x35/0x39 [ 222.309311] [<ffffffff810ae616>] sync_page+0x41/0x4a [ 222.309311] [<ffffffff810ae62d>] sync_page_killable+0xe/0x35 [ 222.309311] [<ffffffff8158aa59>] __wait_on_bit_lock+0x46/0x8f [ 222.309311] [<ffffffff810ae4f5>] __lock_page_killable+0x66/0x6d [ 222.309311] [<ffffffff81056f9c>] ? wake_bit_function+0x0/0x33 [ 222.309311] [<ffffffff810ae528>] lock_page_killable+0x2c/0x2e [ 222.309311] [<ffffffff810afbc5>] generic_file_aio_read+0x361/0x4f0 [ 222.309311] [<ffffffff810ea044>] do_sync_read+0xcb/0x108 [ 222.309311] [<ffffffff811e42f7>] ? security_file_permission+0x16/0x18 [ 222.309311] [<ffffffff810ea6ab>] vfs_read+0xab/0x108 [ 222.309311] [<ffffffff810ea7c8>] sys_read+0x4a/0x6e [ 222.309311] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 222.309311] Code: 58 01 00 00 00 48 89 c6 75 0a 48 83 bb 60 01 00 00 00 74 09 48 8d bb a0 00 00 00 eb 35 41 fe cc 74 0d f6 83 c0 01 00 00 04 74 04 <0f> 0b eb fe 48 89 75 e8 e8 be e0 de ff 66 83 8b c0 01 00 00 04 [ 222.309311] RIP [<ffffffff8121ad88>] blkiocg_set_start_empty_time+0x50/0x83 [ 222.309311] RSP <ffff8800ba6e79f8> [ 222.309311] ---[ end trace 32b4f71dffc15712 ]--- Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21blkio: Fix blkio crash during rq stat updateVivek Goyal
blkio + cfq was crashing even when two sequential readers were put in two separate cgroups (group_isolation=0). The reason being that cfqq can migrate across groups based on its being sync-noidle or not, it can happen that at request insertion time, cfqq belonged to one cfqg and at request dispatch time, it belonged to root group. In this case request stats per cgroup can go wrong and it also runs into BUG_ON(). This patch implements rq stashing away a cfq group pointer and not relying on cfqq->cfqg pointer alone for rq stat accounting. [ 65.163523] ------------[ cut here ]------------ [ 65.164301] kernel BUG at block/blk-cgroup.c:117! [ 65.164301] invalid opcode: 0000 [#1] SMP [ 65.164301] last sysfs file: /sys/devices/pci0000:00/0000:00:05.0/0000:60:00.1/host9/rport-9:0-0/target9:0:0/9:0:0:2/block/sde/stat [ 65.164301] CPU 1 [ 65.164301] Modules linked in: dm_round_robin dm_multipath qla2xxx scsi_transport_fc dm_zero dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] [ 65.164301] [ 65.164301] Pid: 4505, comm: fio Not tainted 2.6.34-rc4-blk-for-35 #34 0A98h/HP xw8600 Workstation [ 65.164301] RIP: 0010:[<ffffffff8121924f>] [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP: 0018:ffff8800ba5a79e8 EFLAGS: 00010046 [ 65.164301] RAX: 0000000000000096 RBX: ffff8800bb268d60 RCX: 0000000000000000 [ 65.164301] RDX: ffff8800bb268eb8 RSI: 0000000000000000 RDI: ffff8800bb268e00 [ 65.164301] RBP: ffff8800ba5a7a08 R08: 0000000000000064 R09: 0000000000000001 [ 65.164301] R10: 0000000000079640 R11: ffff8800a0bd5bf0 R12: ffff8800bab4af01 [ 65.164301] R13: ffff8800bab4af00 R14: ffff8800bb1d8928 R15: 0000000000000000 [ 65.164301] FS: 00007f18f75056f0(0000) GS:ffff880001e40000(0000) knlGS:0000000000000000 [ 65.164301] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 65.164301] CR2: 000000000040e7f0 CR3: 00000000ba52b000 CR4: 00000000000006e0 [ 65.164301] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 65.164301] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 65.164301] Process fio (pid: 4505, threadinfo ffff8800ba5a6000, task ffff8800ba45ae80) [ 65.164301] Stack: [ 65.164301] ffff8800ba5a7a08 ffff8800ba722540 ffff8800bab4af68 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba5a7a38 ffffffff8121d814 ffff8800ba722540 ffff8800bab4af68 [ 65.164301] <0> ffff8800ba722540 ffff8800a08f6800 ffff8800ba5a7a68 ffffffff8121d8ca [ 65.164301] Call Trace: [ 65.164301] [<ffffffff8121d814>] cfq_remove_request+0xe4/0x116 [ 65.164301] [<ffffffff8121d8ca>] cfq_dispatch_insert+0x84/0xe1 [ 65.164301] [<ffffffff8121e833>] cfq_dispatch_requests+0x767/0x8e8 [ 65.164301] [<ffffffff8120e524>] ? submit_bio+0xc3/0xcc [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120ea8d>] blk_peek_request+0x191/0x1a7 [ 65.164301] [<ffffffffa000109c>] ? dm_get_live_table+0x44/0x4f [dm_mod] [ 65.164301] [<ffffffffa0002799>] dm_request_fn+0x38/0x14c [dm_mod] [ 65.164301] [<ffffffff810ad657>] ? sync_page_killable+0x0/0x35 [ 65.164301] [<ffffffff8120f600>] __generic_unplug_device+0x32/0x37 [ 65.164301] [<ffffffff8120f8a0>] generic_unplug_device+0x2e/0x3c [ 65.164301] [<ffffffffa00011a6>] dm_unplug_all+0x42/0x5b [dm_mod] [ 65.164301] [<ffffffff8120b063>] blk_unplug+0x29/0x2d [ 65.164301] [<ffffffff8120b079>] blk_backing_dev_unplug+0x12/0x14 [ 65.164301] [<ffffffff81108a82>] block_sync_page+0x35/0x39 [ 65.164301] [<ffffffff810ad64e>] sync_page+0x41/0x4a [ 65.164301] [<ffffffff810ad665>] sync_page_killable+0xe/0x35 [ 65.164301] [<ffffffff81589027>] __wait_on_bit_lock+0x46/0x8f [ 65.164301] [<ffffffff810ad52d>] __lock_page_killable+0x66/0x6d [ 65.164301] [<ffffffff81055fd4>] ? wake_bit_function+0x0/0x33 [ 65.164301] [<ffffffff810ad560>] lock_page_killable+0x2c/0x2e [ 65.164301] [<ffffffff810aebfd>] generic_file_aio_read+0x361/0x4f0 [ 65.164301] [<ffffffff810e906c>] do_sync_read+0xcb/0x108 [ 65.164301] [<ffffffff811e32a3>] ? security_file_permission+0x16/0x18 [ 65.164301] [<ffffffff810e96d3>] vfs_read+0xab/0x108 [ 65.164301] [<ffffffff810e97f0>] sys_read+0x4a/0x6e [ 65.164301] [<ffffffff81002b5b>] system_call_fastpath+0x16/0x1b [ 65.164301] Code: 00 74 1c 48 8b 8b 60 01 00 00 48 85 c9 75 04 0f 0b eb fe 48 ff c9 48 89 8b 60 01 00 00 eb 1a 48 8b 8b 58 01 00 00 48 85 c9 75 04 <0f> 0b eb fe 48 ff c9 48 89 8b 58 01 00 00 45 84 e4 74 16 48 8b [ 65.164301] RIP [<ffffffff8121924f>] blkiocg_update_io_remove_stats+0x5b/0xaf [ 65.164301] RSP <ffff8800ba5a79e8> [ 65.164301] ---[ end trace 1b2b828753032e68 ]--- Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21block: ensure jiffies wrap is handled correctly in blk_rq_timed_out_timerRichard Kennedy
blk_rq_timed_out_timer() relied on blk_add_timer() never returning a timer value of zero, but commit 7838c15b8dd18e78a523513749e5b54bda07b0cb removed the code that bumped this value when it was zero. Therefore when jiffies is near wrap we could get unlucky & not set the timeout value correctly. This patch uses a flag to indicate that the timeout value was set and so handles jiffies wrap correctly, and it keeps all the logic in one function so should be easier to maintain in the future. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-16blkio: Initialize blkg->stats_lock for the root cfqg tooDivyesh Shah
This fixes the lockdep warning reported by Gui Jianfeng. Signed-off-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
