commit c8123f8c9cb517403b51aa41c3c46ff5e10b2c17 upstream.
When mkfs issues a full device discard and the device only
supports discards of a smallish size, we can loop in
blkdev_issue_discard() for a long time. If preempt isn't enabled,
this can turn into a softlock situation and the kernel will
start complaining.
Add an explicit cond_resched() at the end of the loop to avoid
that.
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 556ee818c06f37b2e583af0363e6b16d0e0270de upstream.
request_queue bypassing is used to suppress higher-level function of a
request_queue so that they can be switched, reconfigured and shut
down. A request_queue does the followings while bypassing.
* bypasses elevator and io_cq association and queues requests directly
to the FIFO dispatch queue.
* bypasses block cgroup request_list lookup and always uses the root
request_list.
Once confirmed to be bypassing, specific elevator and block cgroup
policy implementations can assume that nothing is in flight for them
and perform various operations which would be dangerous otherwise.
Such confirmation is acheived by short-circuiting all new requests
directly to the dispatch queue and waiting for all the requests which
were issued before to finish. Unfortunately, while the request
allocating and draining sides were properly handled, we forgot to
actually plug the request dispatch path. Even after bypassing mode is
confirmed, if the attached driver tries to fetch a request and the
dispatch queue is empty, __elv_next_request() would invoke the current
elevator's elevator_dispatch_fn() callback. As all in-flight requests
were drained, the elevator wouldn't contain any request but once
bypass is confirmed we don't even know whether the elevator is even
there. It might be in the process of being switched and half torn
down.
Frank Mayhar reports that this actually happened while switching
elevators, leading to an oops.
Let's fix it by making __elv_next_request() avoid invoking the
elevator_dispatch_fn() callback if the queue is bypassing. It already
avoids invoking the callback if the queue is dying. As a dying queue
is guaranteed to be bypassing, we can simply replace blk_queue_dying()
check with blk_queue_bypass().
Reported-by: Frank Mayhar <fmayhar@google.com>
References: http://lkml.kernel.org/g/1390319905.20232.38.camel@bobble.lax.corp.google.com
Tested-by: Frank Mayhar <fmayhar@google.com>
u64_stats_fetch_retry is only preempt_disable on 32bit UP system. This is not enough to avoid preemption by bh and may read strange 64 bit value.
commit 2c575026fae6e63771bd2a4c1d407214a8096a89 upstream.
Signed-off-by: Hong Zhiguo <zhiguohong@tencent.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 7c8a3679e3d8e9d92d58f282161760a0e247df97 upstream.
Add locking of q->sysfs_lock into elevator_change() (an exported function)
to ensure it is held to protect q->elevator from elevator_init(), even if
elevator_change() is called from non-sysfs paths.
sysfs path (elv_iosched_store) uses __elevator_change(), non-locking
version, as the lock is already taken by elv_iosched_store().
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@hds.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit eb1c160b22655fd4ec44be732d6594fd1b1e44f4 upstream.
The soft lockup below happens at the boot time of the system using dm
multipath and the udev rules to switch scheduler.
[ 356.127001] BUG: soft lockup - CPU#3 stuck for 22s! [sh:483]
[ 356.127001] RIP: 0010:[<ffffffff81072a7d>] [<ffffffff81072a7d>] lock_timer_base.isra.35+0x1d/0x50
[ 356.127001] Call Trace:
[ 356.127001] [<ffffffff81073810>] try_to_del_timer_sync+0x20/0x70
[ 356.127001] [<ffffffff8118b08a>] ? kmem_cache_alloc_node_trace+0x20a/0x230
[ 356.127001] [<ffffffff810738b2>] del_timer_sync+0x52/0x60
[ 356.127001] [<ffffffff812ece22>] cfq_exit_queue+0x32/0xf0
[ 356.127001] [<ffffffff812c98df>] elevator_exit+0x2f/0x50
[ 356.127001] [<ffffffff812c9f21>] elevator_change+0xf1/0x1c0
[ 356.127001] [<ffffffff812caa50>] elv_iosched_store+0x20/0x50
[ 356.127001] [<ffffffff812d1d09>] queue_attr_store+0x59/0xb0
[ 356.127001] [<ffffffff812143f6>] sysfs_write_file+0xc6/0x140
[ 356.127001] [<ffffffff811a326d>] vfs_write+0xbd/0x1e0
[ 356.127001] [<ffffffff811a3ca9>] SyS_write+0x49/0xa0
[ 356.127001] [<ffffffff8164e899>] system_call_fastpath+0x16/0x1b
This is caused by a race between md device initialization by multipathd and
shell script to switch the scheduler using sysfs.
- multipathd:
SyS_ioctl -> do_vfs_ioctl -> dm_ctl_ioctl -> ctl_ioctl -> table_load
-> dm_setup_md_queue -> blk_init_allocated_queue -> elevator_init
q->elevator = elevator_alloc(q, e); // not yet initialized
- sh -c 'echo deadline > /sys/$DEVPATH/queue/scheduler':
elevator_switch (in the call trace above)
struct elevator_queue *old = q->elevator;
q->elevator = elevator_alloc(q, new_e);
elevator_exit(old); // lockup! (*)
- multipathd: (cont.)
err = e->ops.elevator_init_fn(q); // init fails; q->elevator is modified
(*) When del_timer_sync() is called, lock_timer_base() will loop infinitely
while timer->base == NULL. In this case, as timer will never initialized,
it results in lockup.
This patch introduces acquisition of q->sysfs_lock around elevator_init()
into blk_init_allocated_queue(), to provide mutual exclusion between
initialization of the q->scheduler and switching of the scheduler.
This should fix this bugzilla:
https://bugzilla.redhat.com/show_bug.cgi?id=902012
commit fff4996b7db7955414ac74386efa5e07fd766b50 upstream.
If blkcg_init_queue fails, blk_alloc_queue_node doesn't call bdi_destroy
to clean up structures allocated by the backing dev.
WARNING: at lib/debugobjects.c:260 debug_print_object+0x85/0xa0()
ODEBUG: free active (active state 0) object type: percpu_counter hint: (null)
Modules linked in: dm_loop dm_mod ip6table_filter ip6_tables uvesafb cfbcopyarea cfbimgblt cfbfillrect fbcon font bitblit fbcon_rotate fbcon_cw fbcon_ud fbcon_ccw softcursor fb fbdev ipt_MASQUERADE iptable_nat nf_nat_ipv4 msr nf_conntrack_ipv4 nf_defrag_ipv4 xt_state ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp llc tun ipv6 cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_ondemand cpufreq_conservative spadfs fuse hid_generic usbhid hid raid0 md_mod dmi_sysfs nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack lm85 hwmon_vid snd_usb_audio snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_hwdep snd_usbmidi_lib snd_rawmidi snd soundcore acpi_cpufreq freq_table mperf sata_svw serverworks kvm_amd ide_core ehci_pci ohci_hcd libata ehci_hcd kvm usbcore tg3 usb_common libphy k10temp pcspkr ptp i2c_piix4 i2c_core evdev microcode hwmon rtc_cmos pps_core e100 skge floppy mii processor button unix
CPU: 0 PID: 2739 Comm: lvchange Tainted: G W
3.10.15-devel #14
Hardware name: empty empty/S3992-E, BIOS 'V1.06 ' 06/09/2009
0000000000000009 ffff88023c3c1ae8 ffffffff813c8fd4 ffff88023c3c1b20
ffffffff810399eb ffff88043d35cd58 ffffffff81651940 ffff88023c3c1bf8
ffffffff82479d90 0000000000000005 ffff88023c3c1b80 ffffffff81039a67
Call Trace:
[<ffffffff813c8fd4>] dump_stack+0x19/0x1b
[<ffffffff810399eb>] warn_slowpath_common+0x6b/0xa0
[<ffffffff81039a67>] warn_slowpath_fmt+0x47/0x50
[<ffffffff8122aaaf>] ? debug_check_no_obj_freed+0xcf/0x250
[<ffffffff81229a15>] debug_print_object+0x85/0xa0
[<ffffffff8122abe3>] debug_check_no_obj_freed+0x203/0x250
[<ffffffff8113c4ac>] kmem_cache_free+0x20c/0x3a0
[<ffffffff811f6709>] blk_alloc_queue_node+0x2a9/0x2c0
[<ffffffff811f672e>] blk_alloc_queue+0xe/0x10
[<ffffffffa04c0093>] dm_create+0x1a3/0x530 [dm_mod]
[<ffffffffa04c6bb0>] ? list_version_get_info+0xe0/0xe0 [dm_mod]
[<ffffffffa04c6c07>] dev_create+0x57/0x2b0 [dm_mod]
[<ffffffffa04c6528>] ctl_ioctl+0x268/0x500 [dm_mod]
[<ffffffff81097662>] ? get_lock_stats+0x22/0x70
[<ffffffffa04c67ce>] dm_ctl_ioctl+0xe/0x20 [dm_mod]
[<ffffffff81161aad>] do_vfs_ioctl+0x2ed/0x520
[<ffffffff8116cfc7>] ? fget_light+0x377/0x4e0
[<ffffffff81161d2b>] SyS_ioctl+0x4b/0x90
[<ffffffff813cff16>] system_call_fastpath+0x1a/0x1f
---[ end trace 4b5ff0d55673d986 ]---
This fix should be backported to stable kernels starting with 2.6.37. Note
that in the kernels prior to 3.5 the affected code is different, but the
bug is still there - bdi_init is called and bdi_destroy isn't.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit d82ae52e68892338068e7559a0c0657193341ce4 upstream.
Without this patch all DM devices will default to BLK_MAX_SEGMENT_SIZE
(65536) even if the underlying device(s) have a larger value -- this is
due to blk_stack_limits() using min_not_zero() when stacking the
max_segment_size limit.
1073741824
before patch:
65536
after patch:
1073741824
Reported-by: Lukasz Flis <l.flis@cyfronet.pl>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 4912aa6c11e6a5d910264deedbec2075c6f1bb73 upstream.
crocode i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma dca be2net sg ses enclosure ext4 mbcache jbd2 sd_mod crc_t10dif ahci megaraid_sas(U) dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan]
Pid: 491, comm: scsi_eh_0 Tainted: G W ---------------- 2.6.32-220.13.1.el6.x86_64 #1 IBM -[8722PAX]-/00D1461
RIP: 0010:[<ffffffff8124e424>] [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP: 0018:ffff881057eefd60 EFLAGS: 00010012
RAX: ffff881d99e3e8a8 RBX: ffff881d99e3e780 RCX: ffff881d99e3e8a8
RDX: ffff881d99e3e8a8 RSI: ffff881d99e3e780 RDI: ffff881d99e3e780
RBP: ffff881057eefd80 R08: ffff881057eefe90 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff881057f92338
R13: 0000000000000000 R14: ffff881057f92338 R15: ffff883058188000
FS: 0000000000000000(0000) GS:ffff880040200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000000006d3ec0 CR3: 000000302cd7d000 CR4: 00000000000406b0
Process scsi_eh_0 (pid: 491, threadinfo ffff881057eee000, task ffff881057e29540)
Stack:
0000000000001057 0000000000000286 ffff8810275efdc0 ffff881057f16000
<0> ffff881057eefdd0 ffffffff81362323 ffff881057eefe20 ffffffff8135f393
<0> ffff881057e29af8 ffff8810275efdc0 ffff881057eefe78 ffff881057eefe90
Call Trace:
[<ffffffff81362323>] __scsi_queue_insert+0xa3/0x150
[<ffffffff8135f393>] ? scsi_eh_ready_devs+0x5e3/0x850
[<ffffffff81362a23>] scsi_queue_insert+0x13/0x20
[<ffffffff8135e4d4>] scsi_eh_flush_done_q+0x104/0x160
[<ffffffff8135fb6b>] scsi_error_handler+0x35b/0x660
[<ffffffff8135f810>] ? scsi_error_handler+0x0/0x660
[<ffffffff810908c6>] kthread+0x96/0xa0
[<ffffffff8100c14a>] child_rip+0xa/0x20
[<ffffffff81090830>] ? kthread+0x0/0xa0
[<ffffffff8100c140>] ? child_rip+0x0/0x20
Code: 00 00 eb d1 4c 8b 2d 3c 8f 97 00 4d 85 ed 74 bf 49 8b 45 00 49 83 c5 08 48 89 de 4c 89 e7 ff d0 49 8b 45 00 48 85 c0 75 eb eb a4 <0f> 0b eb fe 0f 1f 84 00 00 00 00 00 55 48 89 e5 0f 1f 44 00 00
RIP [<ffffffff8124e424>] blk_requeue_request+0x94/0xa0
RSP <ffff881057eefd60>
The RIP is this line:
BUG_ON(blk_queued_rq(rq));
After digging through the code, I think there may be a race between the
request completion and the timer handler running.
A timer is started for each request put on the device's queue (see
blk_start_request->blk_add_timer). If the request does not complete
before the timer expires, the timer handler (blk_rq_timed_out_timer)
will mark the request complete atomically:
static inline int blk_mark_rq_complete(struct request *rq)
return test_and_set_bit(REQ_ATOM_COMPLETE, &rq->atomic_flags);
and then call blk_rq_timed_out. The latter function will call
scsi_times_out, which will return one of BLK_EH_HANDLED,
BLK_EH_RESET_TIMER or BLK_EH_NOT_HANDLED. If BLK_EH_RESET_TIMER is
returned, blk_clear_rq_complete is called, and blk_add_timer is again
called to simply wait longer for the request to complete.
Now, if the request happens to complete while this is going on, what
happens? Given that we know the completion handler will bail if it
finds the REQ_ATOM_COMPLETE bit set, we need to focus on the completion
handler running after that bit is cleared. So, from the above
paragraph, after the call to blk_clear_rq_complete. If the completion
sets REQ_ATOM_COMPLETE before the BUG_ON in blk_add_timer, we go boom
there (I haven't seen this in the cores). Next, if we get the
completion before the call to list_add_tail, then the timer will
eventually fire for an old req, which may either be freed or reallocated
(there is evidence that this might be the case). Finally, if the
completion comes in *after* the addition to the timeout list, I think
it's harmless. The request will be removed from the timeout list,
req_atom_complete will be set, and all will be well.
This will only actually explain the coredumps *IF* the request
structure was freed, reallocated *and* queued before the error handler
thread had a chance to process it. That is possible, but it may make
sense to keep digging for another race. I think that if this is what
was happening, we would see other instances of this problem showing up
as null pointer or garbage pointer dereferences, for example when the
request structure was not re-used. It looks like we actually do run
into that situation in other reports.
This patch moves the BUG_ON(test_bit(REQ_ATOM_COMPLETE,
&req->atomic_flags)); from blk_add_timer to the only caller that could
trip over it (blk_start_request). It then inverts the calls to
blk_clear_rq_complete and blk_add_timer in blk_rq_timed_out to address
the race. I've boot tested this patch, but nothing more.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Hannes Reinecke <hare@suse.de>
commit f3cff25f05f2ac29b2ee355e611b0657482f6f1d upstream.
'samples' is 64bit operant, but do_div() second parameter is 32.
do_div silently truncates high 32 bits and calculated result
is invalid.
In case if low 32bit of 'samples' are zeros then do_div() produces
kernel crash.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Cc: Jonghwan Choi <jhbird.choi@gmail.com>
commit d50235b7bc3ee0a0427984d763ea7534149531b4 upstream.
There's a race between elevator switching and normal io operation.
Because the allocation of struct elevator_queue and struct elevator_data
don't in a atomic operation.So there are have chance to use NULL
->elevator_data.
For example:
Thread A: Thread B
blk_queu_bio elevator_switch
spin_lock_irq(q->queue_block) elevator_alloc
elv_merge elevator_init_fn
Because call elevator_alloc, it can't hold queue_lock and the
->elevator_data is NULL.So at the same time, threadA call elv_merge and
nedd some info of elevator_data.So the crash happened.
Move the elevator_alloc into func elevator_init_fn, it make the
operations in a atomic operation.
Using the follow method can easy reproduce this bug
1:dd if=/dev/sdb of=/dev/null
2:while true;do echo noop > scheduler;echo deadline > scheduler;done
The test method also use this method.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
In blk_post_runtime_resume, an autosuspend request will be initiated for
the device. Since we are holding the queue lock, we can't sleep and thus
we should use the async version to initiate an autosuspend, i.e.
pm_request_suspend instead of pm_runtime_suspend, which might sleep.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Pull block core updates from Jens Axboe:
- Major bit is Kents prep work for immutable bio vecs.
- Stable candidate fix for a scheduling-while-atomic in the queue
bypass operation.
- Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging
discard bios.
- Tejuns changes to convert the writeback thread pool to the generic
workqueue mechanism.
- Runtime PM framework, SCSI patches exists on top of these in James'
tree.
- A few random fixes.
* 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits)
relay: move remove_buf_file inside relay_close_buf
partitions/efi.c: replace useless kzalloc's by kmalloc's
fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read()
block: fix max discard sectors limit
blkcg: fix "scheduling while atomic" in blk_queue_bypass_start
Documentation: cfq-iosched: update documentation help for cfq tunables
writeback: expose the bdi_wq workqueue
writeback: replace custom worker pool implementation with unbound workqueue
writeback: remove unused bdi_pending_list
aoe: Fix unitialized var usage
bio-integrity: Add explicit field for owner of bip_buf
block: Add an explicit bio flag for bios that own their bvec
block: Add bio_alloc_pages()
block: Convert some code to bio_for_each_segment_all()
block: Add bio_for_each_segment_all()
bounce: Refactor __blk_queue_bounce to not use bi_io_vec
raid1: use bio_copy_data()
pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage
pktcdvd: use bio_copy_data()
block: Add bio_copy_data()
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: cache last cpu we ran on.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
In alloc_read_gpt_entries and alloc_read_gpt_header, the kzalloc'ated
zones are either totally overwritten by the following read_lba call,
or freed. As kmalloc is cheaper than kzalloc, use kmalloc.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Cc: Matt Domsch <Matt_Domsch@dell.com>
Cc: Panagiotis Issaris <takis@issaris.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- Fixes and a lot of cleanups. Locking cleanup is finally complete.
cgroup_mutex is no longer exposed to individual controlelrs which
used to cause nasty deadlock issues. Li fixed and cleaned up quite a
bit including long standing ones like racy cgroup_path().
- device cgroup now supports proper hierarchy thanks to Aristeu.
- perf_event cgroup now supports proper hierarchy.
- A new mount option "__DEVEL__sane_behavior" is added. As indicated
by the name, this option is to be used for development only at this
point and generates a warning message when used. Unfortunately,
cgroup interface currently has too many brekages and inconsistencies
to implement a consistent and unified hierarchy on top. The new flag
is used to collect the behavior changes which are necessary to
implement consistent unified hierarchy. It's likely that this flag
won't be used verbatim when it becomes ready but will be enabled
implicitly along with unified hierarchy.
The option currently disables some of broken behaviors in cgroup core
and also .use_hierarchy switch in memcg (will be routed through -mm),
which can be used to make very unusual hierarchy where nesting is
partially honored. It will also be used to implement hierarchy
support for blk-throttle which would be impossible otherwise without
introducing a full separate set of control knobs.
This is essentially versioning of interface which isn't very nice but
at this point I can't see any other options which would allow keeping
the interface the same while moving towards hierarchy behavior which
is at least somewhat sane. The planned unified hierarchy is likely
to require some level of adaptation from userland anyway, so I think
it'd be best to take the chance and update the interface such that
it's supportable in the long term.
Maintaining the existing interface does complicate cgroup core but
shouldn't put too much strain on individual controllers and I think
it'd be manageable for the foreseeable future. Maybe we'll be able
to drop it in a decade.
Fix up conflicts (including a semantic one adding a new #include to ppc
that was uncovered by header the file changes) as per Tejun.
* 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits)
cpuset: fix compile warning when CONFIG_SMP=n
cpuset: fix cpu hotplug vs rebuild_sched_domains() race
cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()
cgroup: restore the call to eventfd->poll()
cgroup: fix use-after-free when umounting cgroupfs
cgroup: fix broken file xattrs
devcg: remove parent_cgroup.
memcg: force use_hierarchy if sane_behavior
cgroup: remove cgrp->top_cgroup
cgroup: introduce sane_behavior mount option
move cgroupfs_root to include/linux/cgroup.h
cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix
cgroup: make cgroup_path() not print double slashes
Revert "cgroup: remove bind() method from cgroup_subsys."
perf: make perf_event cgroup hierarchical
cgroup: implement cgroup_is_descendant()
cgroup: make sure parent won't be destroyed before its children
devcg: remove broken_hierarchy tag
cgroup: remove cgroup_lock_is_held()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg Kroah-Hartman:
"Here's the merge request for the driver core tree for 3.10-rc1
It's pretty small, just a number of driver core and sysfs updates and
fixes, all of which have been in linux-next for a while now.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed conflict in kernel/rtmutex-tester.c, the locking tree had a better
fix for the same sysfs file mode problem.
* tag 'driver-core-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
PM / Runtime: Idle devices asynchronously after probe|release
driver core: handle user namespaces properly with the uid/gid devtmpfs change
driver core: devtmpfs: fix compile failure with CONFIG_UIDGID_STRICT_TYPE_CHECKS
devtmpfs: add base.h include
driver core: add uid and gid to devtmpfs
sysfs: check if one entry has been removed before freeing
sysfs: fix crash_notes_size build warning
sysfs: fix use after free in case of concurrent read/write and readdir
rtmutex-tester: fix mode of sysfs files
Documentation: Add ABI entry for crash_notes and crash_notes_size
sysfs: Add crash_notes_size to export percpu note size
driver core: platform_device.h: fix checkpatch errors and warnings
driver core: platform.c: fix checkpatch errors and warnings
driver core: warn that platform_driver_probe can not use deferred probing
sysfs: use atomic_inc_unless_negative in sysfs_get_active
base: core: WARN() about bogus permissions on device attributes
device: separate all subsys mutexes
This reverts commit 3a366e614d0837d9fc23f78cdb1a1186ebc3387f.
Wanlong Gao reports that it causes a kernel panic on his machine several
minutes after boot. Reverting it removes the panic.
Jens says:
"It's not quite clear why that is yet, so I think we should just revert
the commit for 3.9 final (which I'm assuming is pretty close).
The wifi is crap at the LSF hotel, so sending this email instead of
queueing up a revert and pull request."
Reported-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Requested-by: Jens Axboe <axboe@kernel.dk>
Cc: Tejun Heo <tj@kernel.org>
Now that devtmpfs is caring about uid/gid, we need to use the correct
internal types so users who have USER_NS enabled will have things work
properly for them.
Thanks to Eric for pointing this out, and the patch review.
Reported-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Ming Lei <ming.lei@canonical.com>
Since 749fefe677 in v3.7 ("block: lift the initial queue bypass mode
on blk_register_queue() instead of blk_init_allocated_queue()"),
the following warning appears when multipath is used with CONFIG_PREEMPT=y.
This patch moves blk_queue_bypass_start() before radix_tree_preload()
to avoid the sleeping call while preemption is disabled.
BUG: scheduling while atomic: multipath/2460/0x00000002
1 lock held by multipath/2460:
#0: (&md->type_lock){......}, at: [<ffffffffa019fb05>] dm_lock_md_type+0x17/0x19 [dm_mod]
Modules linked in: ...
Pid: 2460, comm: multipath Tainted: G W 3.7.0-rc2 #1
Call Trace:
[<ffffffff810723ae>] __schedule_bug+0x6a/0x78
[<ffffffff81428ba2>] __schedule+0xb4/0x5e0
[<ffffffff814291e6>] schedule+0x64/0x66
[<ffffffff8142773a>] schedule_timeout+0x39/0xf8
[<ffffffff8108ad5f>] ? put_lock_stats+0xe/0x29
[<ffffffff8108ae30>] ? lock_release_holdtime+0xb6/0xbb
[<ffffffff814289e3>] wait_for_common+0x9d/0xee
[<ffffffff8107526c>] ? try_to_wake_up+0x206/0x206
[<ffffffff810c0eb8>] ? kfree_call_rcu+0x1c/0x1c
[<ffffffff81428aec>] wait_for_completion+0x1d/0x1f
[<ffffffff810611f9>] wait_rcu_gp+0x5d/0x7a
[<ffffffff81061216>] ? wait_rcu_gp+0x7a/0x7a
[<ffffffff8106fb18>] ? complete+0x21/0x53
[<ffffffff810c0556>] synchronize_rcu+0x1e/0x20
[<ffffffff811dd903>] blk_queue_bypass_start+0x5d/0x62
[<ffffffff811ee109>] blkcg_activate_policy+0x73/0x270
[<ffffffff81130521>] ? kmem_cache_alloc_node_trace+0xc7/0x108
[<ffffffff811f04b3>] cfq_init_queue+0x80/0x28e
[<ffffffffa01a1600>] ? dm_blk_ioctl+0xa7/0xa7 [dm_mod]
[<ffffffff811d8c41>] elevator_init+0xe1/0x115
[<ffffffff811e229f>] ? blk_queue_make_request+0x54/0x59
[<ffffffff811dd743>] blk_init_allocated_queue+0x8c/0x9e
[<ffffffffa019ffcd>] dm_setup_md_queue+0x36/0xaa [dm_mod]
[<ffffffffa01a60e6>] table_load+0x1bd/0x2c8 [dm_mod]
[<ffffffffa01a7026>] ctl_ioctl+0x1d6/0x236 [dm_mod]
[<ffffffffa01a5f29>] ? table_clear+0xaa/0xaa [dm_mod]
[<ffffffffa01a7099>] dm_ctl_ioctl+0x13/0x17 [dm_mod]
[<ffffffff811479fc>] do_vfs_ioctl+0x3fb/0x441
[<ffffffff811b643c>] ? file_has_perm+0x8a/0x99
[<ffffffff81147aa0>] sys_ioctl+0x5e/0x82
[<ffffffff812010be>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff814310d9>] system_call_fastpath+0x16/0x1b
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: stable@kernel.org
Some drivers want to tell userspace what uid and gid should be used for
their device nodes, so allow that information to percolate through the
driver core to userspace in order to make this happen. This means that
some systems (i.e. Android and friends) will not need to even run a
udev-like daemon for their device node manager and can just rely in
devtmpfs fully, reducing their footprint even more.
Signed-off-by: Kay Sievers <kay@vrfy.org>
This reverts commit 8761a3dc1f07b163414e2215a2cadbb4cfe2a107.
There are situations where the destruction path is called
with the bdev->bd_mutex already held, which then deadlocks in
loop_clr_fd(). The normal partition cleanup does a trylock()
on the mutex, but it'd be nice to have a more bullet proof
method in loop. So punt this more involved fix to the next
merge window, and just back out this buggy fix for now.
As found by gcc-4.8, the QUEUE_SYSFS_BIT_FNS macro creates functions
that use a value generated by queue_var_store independent of whether
that value was set or not.
block/blk-sysfs.c: In function 'queue_store_nonrot':
block/blk-sysfs.c:244:385: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
Unlike most other such warnings, this one is not a false positive,
writing any non-number string into the sysfs files indeed has
an undefined result, rather than returning an error.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq into for-3.10/core
Tejun writes:
This is the pull request for the earlier patchset[1] with the same
name. It's only three patches (the first one was committed to
workqueue tree) but the merge strategy is a bit involved due to the
dependencies.
* Because the conversion needs features from wq/for-3.10,
block/for-3.10/core is based on rc3, and wq/for-3.10 has conflicts
with rc3, I pulled mainline (rc5) into wq/for-3.10 to prevent those
workqueue conflicts from flaring up in block tree.
* Resolving the issue that Jan and Dave raised about debugging
requires arch-wide changes. The patchset is being worked on[2] but
it'll have to go through -mm after these changes show up in -next,
and not included in this pull request.
The three commits are located in the following git branch.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git writeback-workqueue
Pulling it into block/for-3.10/core produces a conflict in
drivers/md/raid5.c between the following two commits.
e3620a3ad5 ("MD RAID5: Avoid accessing gendisk or queue structs when not available")
2f6db2a707 ("raid5: use bio_reset()")
The conflict is trivial - one removes an "if ()" conditional while the
other removes "rbi->bi_next = NULL" right above it. We just need to
remove both. The merged branch is available at
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq.git block-test-merge
so that you can use it for verification. The test merge commit has
proper merge description.
While these changes are a bit of pain to route, they make code simpler
and even have, while minute, measureable performance gain[3] even on a
workload which isn't particularly favorable to showing the benefits of
this conversion.
Fixed up the conflict.
drivers/md/raid5.c
for-3.10/core
This contains Kents prep work for the immutable bio_vecs.
Just a little convenience macro - main reason to add it now is preparing
for immutable bio vecs, it'll reduce the size of the patch that puts
bi_sector/bi_size/bi_idx into a struct bvec_iter.
CC: Jens Axboe <axboe@kernel.dk>
CC: Lars Ellenberg <drbd-dev@lists.linbit.com>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Alasdair Kergon <agk@redhat.com>
CC: dm-devel@redhat.com
CC: Neil Brown <neilb@suse.de>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
CC: linux-s390@vger.kernel.org
CC: Chris Mason <chris.mason@fusionio.com>
CC: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Converts it to use bio_advance(), simplifying it quite a bit in the
process.
Note that req_bio_endio() now always calls bio_advance() - which means
it always loops over the biovec, not just on partial completions. Don't
expect it to affect performance, but worth noting.
Tested it by forcing partial updates, and dumping before and after on
various bio/bvec fields when doing a partial update.
When a request is added:
If device is suspended or is suspending and the request is not a
PM request, resume the device.
When the last request finishes:
Call pm_runtime_mark_last_busy().
When pick a request:
If device is resuming/suspending, then only PM request is allowed
to go.
The idea and API is designed by Alan Stern and described here:
http://marc.info/?l=linux-scsi&m=133727953625963&w=2
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Add runtime pm helper functions:
void blk_pm_runtime_init(struct request_queue *q, struct device *dev)
- Initialization function for drivers to call.
int blk_pre_runtime_suspend(struct request_queue *q)
- If any requests are in the queue, mark last busy and return -EBUSY.
Otherwise set q->rpm_status to RPM_SUSPENDING and return 0.
void blk_post_runtime_suspend(struct request_queue *q, int err)
- If the suspend succeeded then set q->rpm_status to RPM_SUSPENDED.
Otherwise set it to RPM_ACTIVE and mark last busy.
void blk_pre_runtime_resume(struct request_queue *q)
- Set q->rpm_status to RPM_RESUMING.
void blk_post_runtime_resume(struct request_queue *q, int err)
- If the resume succeeded then set q->rpm_status to RPM_ACTIVE
and call __blk_run_queue, then mark last busy and autosuspend.
Otherwise set q->rpm_status to RPM_SUSPENDED.
Fixed code indent should use tabs where possible.
Signed-off-by: Alice Ferrazzi <alice.ferrazzi@gmail.com>
Any partitions added by user space to the loop device were being
left in place after detaching the loop device. This was because
the detach path issued a BLKRRPART to clean up partitions if
LO_FLAGS_PARTSCAN was set, meaning that the partitions were auto
scanned on attach. Replace this BLKRRPART with code that
unconditionally cleans up partitions on detach instead.
Signed-off-by: Phillip Susi <psusi@ubuntu.com>
Modified by Jens to export delete_partition().
This is useful in places that recycle the same scatterlist multiple
times, and do not want to incur the cost of sg_init_table every
time in hot paths.
Acked-by: Jens Axboe <axboe@kernel.dk>
rename() will change dentry->d_name. The result of this race can
be worse than seeing partially rewritten name, but we might access
a stale pointer because rename() will re-allocate memory to hold
a longer name.
As accessing dentry->name must be protected by dentry->d_lock or
parent inode's i_mutex, while on the other hand cgroup-path() can
be called with some irq-safe spinlocks held, we can't generate
cgroup path using dentry->d_name.
Alternatively we make a copy of dentry->d_name and save it in
cgrp->name when a cgroup is created, and update cgrp->name at
rename().
v5: use flexible array instead of zero-size array.
v4: - allocate root_cgroup_name and all root_cgroup->name points to it.
- add cgroup_name() wrapper.
v3: use kfree_rcu() instead of synchronize_rcu() in user-visible path.
v2: make cgrp->name RCU safe.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Pull block IO core bits from Jens Axboe:
"Below are the core block IO bits for 3.9. It was delayed a few days
since my workstation kept crashing every 2-8h after pulling it into
current -git, but turns out it is a bug in the new pstate code (divide
by zero, will report separately). In any case, it contains:
- The big cfq/blkcg update from Tejun and and Vivek.
- Additional block and writeback tracepoints from Tejun.
- Improvement of the should sort (based on queues) logic in the plug
flushing.
- _io() variants of the wait_for_completion() interface, using
io_schedule() instead of schedule() to contribute to io wait
properly.
- Various little fixes.
You'll get two trivial merge conflicts, which should be easy enough to
fix up"
Fix up the trivial conflicts due to hlist traversal cleanups (commit
b67bfe0d42ca: "hlist: drop the node parameter from iterators").
* 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits)
block: remove redundant check to bd_openers()
block: use i_size_write() in bd_set_size()
cfq: fix lock imbalance with failed allocations
drivers/block/swim3.c: fix null pointer dereference
block: don't select PERCPU_RWSEM
block: account iowait time when waiting for completion of IO request
sched: add wait_for_completion_io[_timeout]
writeback: add more tracepoints
block: add block_{touch|dirty}_buffer tracepoint
buffer: make touch_buffer() an exported function
block: add @req to bio_{front|back}_merge tracepoints
block: add missing block_bio_complete() tracepoint
block: Remove should_sort judgement when flush blk_plug
block,elevator: use new hashtable implementation
cfq-iosched: add hierarchical cfq_group statistics
cfq-iosched: collect stats from dead cfqgs
cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats()
blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock
block: RCU free request_queue
blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge()
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Currently, sizeof(struct parsed_partitions) may be 64KB in 32bit arch, so
it is easy to trigger page allocation failure by check_partition,
especially in hotplug block device situation(such as, USB mass storage,
MMC card, ...), and Felipe Balbi has observed the failure.
This patch does below optimizations on the allocation of struct
parsed_partitions to try to address the issue:
- make parsed_partitions.parts as pointer so that the pointed memory can
fit in 32KB buffer, then approximate 32KB memory can be saved
- vmalloc the buffer pointed by parsed_partitions.parts because 32KB is
still a bit big for kmalloc
- given that many devices have the partition count limit, so only
allocate disk_max_parts() partitions instead of 256 partitions always
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Reported-by: Felipe Balbi <balbi@ti.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
It isn't necessary to read the information of partitions whose number is
equal and more than state->limit since only maximum state->limit
partitions will be added inside rescan_partitions().
That is also what other kind of partitions are doing.
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
the structure.
UEFI 2.3.1D will include a change to the spec language mandating that a
GPT header must be greater than *or equal to* the size of the defined
structure. While verifying that this would work on Linux, I discovered
that we're not actually checking the minimum bound at all.
The result of this is that when we verify the checksum, it's possible that
on a malformed header (with header_size of 0), we won't actually verify
any data.
[akpm@linux-foundation.org: fix printk warning]
Signed-off-by: Peter Jones <pjones@redhat.com>
Acked-by: Matt Fleming <matt.fleming@intel.com>
Cc: Stephen Warren <swarren@nvidia.com>
AIX formatted disks do not always have the MSDOS 55aa signature.
This happens e.g. for unbootable AIX disks.
Up to now, such disks were not recognized as AIX disks, because of the
missing 55aa. Fix that by inverting the two tests. Let's first
check for the AIX magic strings, and only if that fails check for
the MSDOS magic word.
Cc: Andreas Mohr <andi@lisas.de>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Olaf Hering <olh@suse.de>
Convert to the much saner new idr interface. Both bsg and genhd
protect idr w/ mutex making preloading unnecessary.
idr allocation in blk_alloc_devt() wasn't synchronized against lookup
and removal, and its limit check was off by one - 1 << MINORBITS is
the number of minors allowed, not the maximum allowed minor.
Add locking and rename MAX_EXT_DEVT to NR_EXT_DEVT and fix limit
checking.
Cc: <stable@vger.kernel.org>
While adding and removing a lot of disks disks and partitions this
sometimes shows up:
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name:
sysfs: cannot create duplicate filename '/dev/block/259:751'
Modules linked in: raid1 autofs4 bnx2fc cnic uio fcoe libfcoe libfc 8021q scsi_transport_fc scsi_tgt garp stp llc sunrpc cpufreq_ondemand powernow_k8 freq_table mperf ipv6 dm_mirror dm_region_hash dm_log power_meter microcode dcdbas serio_raw amd64_edac_mod edac_core edac_mce_amd i2c_piix4 i2c_core k10temp bnx2 sg ixgbe dca mdio ext4 mbcache jbd2 dm_round_robin sr_mod cdrom sd_mod crc_t10dif ata_generic pata_acpi pata_atiixp ahci mptsas mptscsih mptbase scsi_transport_sas dm_multipath dm_mod [last unloaded: scsi_wait_scan]
Pid: 44103, comm: async/16 Not tainted 2.6.32-195.el6.x86_64 #1
Call Trace:
warn_slowpath_common+0x87/0xc0
warn_slowpath_fmt+0x46/0x50
sysfs_do_create_link+0x12b/0x170
sysfs_create_link+0x13/0x20
device_add+0x317/0x650
idr_get_new+0x13/0x50
add_partition+0x21c/0x390
rescan_partitions+0x32b/0x470
sd_open+0x81/0x1f0 [sd_mod]
__blkdev_get+0x1b6/0x3c0
blkdev_get+0x10/0x20
register_disk+0x155/0x170
add_disk+0xa6/0x160
sd_probe_async+0x13b/0x210 [sd_mod]
add_wait_queue+0x46/0x60
async_thread+0x102/0x250
default_wake_function+0x0/0x20
async_thread+0x0/0x250
kthread+0x96/0xa0
child_rip+0xa/0x20
kthread+0x0/0xa0
child_rip+0x0/0x20
This most likely happens because dev_t is freed while the number is
still used and idr_get_new() is not protected on every use. The fix
adds a mutex where it wasn't before and moves the dev_t free function so
it is called after device del.
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
Apply the introduced pm_runtime_set_memalloc_noio on block device so
that PM core will teach mm to not allocate memory with GFP_IOFS when
calling the runtime_resume and runtime_suspend callback for block
devices and its ancestors.
Cc: Minchan Kim <minchan@kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: Jiri Kosina <jiri.kosina@suse.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Greg KH <greg@kroah.com>
Cc: David Decotigny <david.decotigny@google.com>
Cc: Tom Herbert <therbert@google.com>
While stress-running very-small container scenarios with the Kernel Memory
Controller, I've run into a lockdep-detected lock imbalance in
cfq-iosched.c.
I'll apologize beforehand for not posting a backlog: I didn't anticipate
it would be so hard to reproduce, so I didn't save my serial output and
went directly on debugging. Turns out that it did not happen again in
more than 20 runs, making it a quite rare pattern.
But here is my analysis:
When we are in very low-memory situations, we will arrive at
cfq_find_alloc_queue and may not find a queue, having to resort to the oom
queue, in an rcu-locked condition:
if (!cfqq || cfqq == &cfqd->oom_cfqq)
Next, we will release the rcu lock, and try to allocate a queue, retrying
if we succeed:
rcu_read_unlock();
spin_unlock_irq(cfqd->queue->queue_lock);
new_cfqq = kmem_cache_alloc_node(cfq_pool,
gfp_mask | __GFP_ZERO,
cfqd->queue->node);
spin_lock_irq(cfqd->queue->queue_lock);
if (new_cfqq)
goto retry;
We are unlocked at this point, but it should be fine, since we will
reacquire the rcu_read_lock when we retry.
Except of course, that we may not retry: the allocation may very well fail
and we'll keep on going through the flow:
The next branch is:
if (cfqq) {
} else
cfqq = &cfqd->oom_cfqq;
And right before exiting, we'll issue rcu_read_unlock().
Being already unlocked, this is the likely source of our imbalance. Since
cfqq is either already NULL or made NULL in the first statement of the
outter branch, the only viable alternative here seems to be to return the
oom queue right away in case of allocation failure.
Please review the following patch and apply if you agree with my analysis.
Signed-off-by: Glauber Costa <glommer@parallels.com>
The block device doesn't use percpu rw-semaphore anymore, so don't select
it for compilation.
This provides a band-aid to provide stable page writes on jbd without
needing to backport the fixed locking and page writeback bit handling
schemes of jbd2. The band-aid works by using bounce buffers to snapshot
page contents instead of waiting.
For those wondering about the ext3 bandage -- fixing the jbd locking
(which was done as part of ext4dev years ago) is a lot of surgery, and
setting PG_writeback on data pages when we actually hold the page lock
dropped ext3 performance by nearly an order of magnitude. If we're
going to migrate iscsi and raid to use stable page writes, the
complaints about high latency will likely return. We might as well
centralize their page snapshotting thing to one place.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Tested-by: Andy Lutomirski <luto@amacapital.net>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
This patchset ("stable page writes, part 2") makes some key
modifications to the original 'stable page writes' patchset. First, it
provides creators (devices and filesystems) of a backing_dev_info a flag
that declares whether or not it is necessary to ensure that page
contents cannot change during writeout. It is no longer assumed that
this is true of all devices (which was never true anyway). Second, the
flag is used to relaxed the wait_on_page_writeback calls so that wait
only occurs if the device needs it. Third, it fixes up the remaining
disk-backed filesystems to use this improved conditional-wait logic to
provide stable page writes on those filesystems.
It is hoped that (for people not using checksumming devices, anyway)
this patchset will give back unnecessary performance decreases since the
original stable page write patchset went into 3.0. Sorry about not
fixing it sooner.
Complaints were registered by several people about the long write
latencies introduced by the original stable page write patchset.
Generally speaking, the kernel ought to allocate as little extra memory
as possible to facilitate writeout, but for people who simply cannot
wait, a second page stability strategy is (re)introduced: snapshotting
page contents. The waiting behavior is still the default strategy; to
enable page snapshotting, a superblock flag (MS_SNAP_STABLE) must be
set. This flag is used to bandaid^Henable stable page writeback on
ext3[1], and is not used anywhere else.
Given that there are already a few storage devices and network FSes that
have rolled their own page stability wait/page snapshot code, it would
be nice to move towards consolidating all of these. It seems possible
that iscsi and raid5 may wish to use the new stable page write support
to enable zero-copy writeout.
Thank you to Jan Kara for helping fix a couple more filesystems.
Per Andrew Morton's request, here are the result of using dbench to measure
latencies on ext2:
3.8.0-rc3:
Operation Count AvgLat MaxLat
WriteX 109347 0.028 59.817
ReadX 347180 0.004 3.391
Flush 15514 29.828 287.283
Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms
3.8.0-rc3 + patches:
WriteX 105556 0.029 4.273
ReadX 335004 0.005 4.112
Flush 14982 30.540 298.634
Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms
As you can see, for ext2 the maximum write latency decreases from ~60ms
on a laptop hard disk to ~4ms. I'm not sure why the flush latencies
increase, though I suspect that being able to dirty pages faster gives
the flusher more work to do.
On ext4, the average write latency decreases as well as all the maximum
latencies:
3.8.0-rc3:
WriteX 85624 0.152 33.078
ReadX 272090 0.010 61.210
Flush 12129 36.219 168.260
Throughput 44.8618 MB/sec 4 clients 4 procs max_latency=168.276 ms
WriteX 86082 0.141 30.928
ReadX 273358 0.010 36.124
Flush 12214 34.800 165.689
Throughput 44.9941 MB/sec 4 clients 4 procs max_latency=165.722 ms
XFS seems to exhibit similar latency improvements as ext2:
3.8.0-rc3:
WriteX 125739 0.028 104.343
ReadX 399070 0.005 4.115
Flush 17851 25.004 131.390
Throughput 66.0024 MB/sec 4 clients 4 procs max_latency=131.406 ms
WriteX 123529 0.028 6.299
ReadX 392434 0.005 4.287
Flush 17549 25.120 188.687
Throughput 64.9113 MB/sec 4 clients 4 procs max_latency=188.704 ms
...and btrfs, just to round things out, also shows some latency
decreases:
3.8.0-rc3:
WriteX 67122 0.083 82.355
ReadX 212719 0.005 2.828
Flush 9547 47.561 147.418
Throughput 35.3391 MB/sec 4 clients 4 procs max_latency=147.433 ms
WriteX 64898 0.101 71.631
ReadX 206673 0.005 7.123
Flush 9190 47.963 219.034
Throughput 34.0795 MB/sec 4 clients 4 procs max_latency=219.044 ms
Before this patchset, all filesystems would block, regardless of whether
or not it was necessary. ext3 would wait, but still generate occasional
checksum errors. The network filesystems were left to do their own
thing, so they'd wait too.
After this patchset, all the disk filesystems except ext3 and btrfs will
wait only if the hardware requires it. ext3 (if necessary) snapshots
pages instead of blocking, and btrfs provides its own bdi so the mm will
never wait. Network filesystems haven't been touched, so either they
provide their own wait code, or they don't block at all. The blocking
behavior is back to what it was before 3.0 if you don't have a disk
requiring stable page writes.
This patchset has been tested on 3.8.0-rc3 on x64 with ext3, ext4, and
xfs. I've spot-checked 3.8.0-rc4 and seem to be getting the same
results as -rc3.
[1] The alternative fixes to ext3 include fixing the locking order and
page bit handling like we did for ext4 (but then why not just use
ext4?), or setting PG_writeback so early that ext3 becomes extremely
slow. I tried that, but the number of write()s I could initiate dropped
by nearly an order of magnitude. That was a bit much even for the
author of the stable page series! :)
This patch:
Creates a per-backing-device flag that tracks whether or not pages must
be held immutable during writeout. Eventually it will be used to waive
wait_for_page_writeback() if nothing requires stable pages.
Pull async changes from Tejun Heo:
"These are followups for the earlier deadlock issue involving async
ending up waiting for itself through block requesting module[1]. The
following changes are made by these commits.
- Instead of requesting default elevator on each request_queue init,
block now requests it once early during boot.
- Kmod triggers warning if invoked from an async worker.
- Async synchronization implementation has been reimplemented. It's
a lot simpler now."
* 'for-3.9-async' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
async: initialise list heads to fix crash
async: replace list of active domains with global list of pending items
async: keep pending tasks on async_domain and remove async_pending
async: use ULLONG_MAX for infinity cookie value
async: bring sanity to the use of words domain and running
async, kmod: warn on synchronous request_module() from async workers
block: don't request module during elevator init
init, block: try to load default elevator module early during boot
