path: root/certs
2021-09-22certs: Trigger creation of RSA module signing key if it's not an RSA keyStefan Berger
[ Upstream commit ea35e0d5df6c92fa2e124bb1b91d09b2240715ba ] Address a kbuild issue where a developer created an ECDSA key for signing kernel modules and then builds an older version of the kernel, when bi- secting the kernel for example, that does not support ECDSA keys. If openssl is installed, trigger the creation of an RSA module signing key if it is not an RSA key. Fixes: cfc411e7fff3 ("Move certificate handling to its own directory") Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Stefan Berger <stefanb@linux.ibm.com> Reviewed-by: Jarkko Sakkinen <jarkko@kernel.org> Tested-by: Jarkko Sakkinen <jarkko@kernel.org> Signed-off-by: Jarkko Sakkinen <jarkko@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-02-25modsign: hide openssl output in silent buildsArnd Bergmann
commit 5d06ee20b662a78417245714fc576cba90e6374f upstream. When a user calls 'make -s', we can assume they don't want to see any output except for warnings and errors, but instead they see this for a warning free build: ### ### Now generating an X.509 key pair to be used for signing modules. ### ### If this takes a long time, you might wish to run rngd in the ### background to keep the supply of entropy topped up. It ### needs to be run as root, and uses a hardware random ### number generator if one is available. ### Generating a 4096 bit RSA private key .................................................................................................................................................................................................................................++ ..............................................................................................................................++ writing new private key to 'certs/signing_key.pem' ----- ### ### Key pair generated. ### The output can confuse simple build testing scripts that just check for an empty build log. This patch silences all the output: - "echo" is changed to "@$(kecho)", which is dropped when "-s" gets passed - the openssl command itself is only printed with V=1, using the $(Q) macro - The output of openssl gets redirected to /dev/null on "-s" builds. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-21certs: add .gitignore to stop git nagging about x509_certificate_listPaul Gortmaker
Currently we see this in "git status" if we build in the source dir: Untracked files: (use "git add <file>..." to include in what will be committed) certs/x509_certificate_list It looks like it used to live in kernel/ so we squash that .gitignore entry at the same time. I didn't bother to dig through git history to see when it moved, since it is just a minor annoyance at most. Cc: David Woodhouse <dwmw2@infradead.org> Cc: keyrings@linux-nfs.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-14modsign: Handle signing key in source treeDavid Woodhouse
Since commit 1329e8cc69 ("modsign: Extract signing cert from CONFIG_MODULE_SIG_KEY if needed"), the build system has carefully coped with the signing key being specified as a relative path in either the source or or the build trees. However, the actual signing of modules has not worked if the filename is relative to the source tree. Fix that by moving the config_filename helper into scripts/Kbuild.include so that it can be used from elsewhere, and then using it in the top-level Makefile to find the signing key file. Kill the intermediate $(MODPUBKEY) and $(MODSECKEY) variables too, while we're at it. There's no need for them. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-14modsign: Use if_changed rule for extracting cert from module signing keyDavid Woodhouse
We couldn't use if_changed for this before, because it didn't live in the kernel/ directory so we couldn't add it to $(targets). It was easier just to leave it as it was. Now it's in the certs/ directory we can use if_changed, the same as we do for the trusted certificate list. Aside from making things consistent, this means we don't need to depend explicitly on the include/config/module/sig/key.h file. And we also get to automatically do the right thing and re-extract the cert if the user does odd things like using a relative filename and then playing silly buggers with adding/removing that file in both the source and object trees. We always favour the one in the object tree if it exists, and now we'll correctly re-extract the cert when it changes. Previously we'd *only* re-extract the cert if the config option changed, even if the actual file we're using did change. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-14Move certificate handling to its own directoryDavid Howells
Move certificate handling out of the kernel/ directory and into a certs/ directory to get all the weird stuff in one place and move the generated signing keys into this directory. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
