path: root/crypto/Kconfig
2010-09-12crypto: Kconfig - update broken web addressesJustin P. Mattock
Below is a patch to update the broken web addresses, in crypto/* that I could locate. Some are just simple typos that needed to be fixed, and some had a change in location altogether.. let me know if any of them need to be changed and such. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-09-03crypto: fips - FIPS requires algorithm self-testsChuck Ebbert
Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-06crypto: testmgr - Default to no testsHerbert Xu
On Thu, Aug 05, 2010 at 07:01:21PM -0700, Linus Torvalds wrote: > On Thu, Aug 5, 2010 at 6:40 PM, Herbert Xu <herbert@gondor.hengli.com.au> wrote: > > > > -config CRYPTO_MANAGER_TESTS > > - bool "Run algolithms' self-tests" > > - default y > > - depends on CRYPTO_MANAGER2 > > +config CRYPTO_MANAGER_DISABLE_TESTS > > + bool "Disable run-time self tests" > > + depends on CRYPTO_MANAGER2 && EMBEDDED > > Why do you still want to force-enable those tests? I was going to > complain about the "default y" anyway, now I'm _really_ complaining, > because you've now made it impossible to disable those tests. Why? As requested, this patch sets the default to y and removes the EMBEDDED dependency. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-08-06crypto: testmgr - Fix test disabling optionHerbert Xu
This patch fixes a serious bug in the test disabling patch where it can cause an spurious load of the cryptomgr module even when it's compiled in. It also negates the test disabling option so that its absence causes tests to be enabled. The Kconfig option is also now behind EMBEDDED. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: testmgr - add an option to disable cryptoalgos' self-testsAlexander Shishkin
By default, CONFIG_CRYPTO_MANAGER_TESTS will be enabled and thus self-tests will still run, but it is now possible to disable them to gain some time during bootup. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: pcomp - Fix illegal Kconfig configurationHerbert Xu
The PCOMP Kconfig entry current allows the following combination which is illegal: ZLIB=y PCOMP=y ALGAPI=m ALGAPI2=y MANAGER=m MANAGER2=m This patch fixes this by adding PCOMP2 so that PCOMP can select ALGAPI to propagate the setting to MANAGER2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-05crypto: fix typo in Kconfig help textJiri Kosina
Reported-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-27crypto: ghash-intel - Fix building failure on x86_32Huang Ying
CLMUL-NI accelerated GHASH should be turned off on non-x86_64 machine. Reported-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-19crypto: ghash - Add PCLMULQDQ accelerated implementationHuang Ying
PCLMULQDQ is used to accelerate the most time-consuming part of GHASH, carry-less multiplication. More information about PCLMULQDQ can be found at: http://software.intel.com/en-us/articles/carry-less-multiplication-and-its-usage-for-computing-the-gcm-mode/ Because PCLMULQDQ changes XMM state, its usage must be enclosed with kernel_fpu_begin/end, which can be used only in process context, the acceleration is implemented as crypto_ahash. That is, request in soft IRQ context will be defered to the cryptd kernel thread. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-20crypto: fips - Depend on ansi_cprngNeil Horman
What about something like this? It defaults the CPRNG to m and makes FIPS dependent on the CPRNG. That way you get a module build by default, but you can change it to y manually during config and still satisfy the dependency, and if you select N it disables FIPS as well. I rather like that better than making FIPS a tristate. I just tested it out here and it seems to work well. Let me know what you think Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13Revert crypto: fips - Select CPRNGHerbert Xu
This reverts commit 215ccd6f55a2144bd553e0a3d12e1386f02309fd. It causes CPRNG and everything selected by it to be built-in whenever FIPS is enabled. The problem is that it is selecting a tristate from a bool, which is usually not what is intended. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: gcm - Use GHASH digest algorithmHuang Ying
Remove the dedicated GHASH implementation in GCM, and uses the GHASH digest algorithm instead. This will make GCM uses hardware accelerated GHASH implementation automatically if available. ahash instead of shash interface is used, because some hardware accelerated GHASH implementation needs asynchronous interface. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: ghash - Add GHASH digest algorithm for GCMHuang Ying
GHASH is implemented as a shash algorithm. The actual implementation is copied from gcm.c. This makes it possible to add architecture/hardware accelerated GHASH implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-21crypto: fips - Select CPRNGNeil Horman
The ANSI CPRNG has no dependence on FIPS support. FIPS support however, requires the use of the CPRNG. Adjust that depedency relationship in Kconfig. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-19crypto: ansi_cprng - Do not select FIPSHerbert Xu
The RNG should work with FIPS disabled. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: aes-ni - Add support for more modesHuang Ying
Because kernel_fpu_begin() and kernel_fpu_end() operations are too slow, the performance gain of general mode implementation + aes-aesni is almost all compensated. The AES-NI support for more modes are implemented as follow: - Add a new AES algorithm implementation named __aes-aesni without kernel_fpu_begin/end() - Use fpu(<mode>(AES)) to provide kenrel_fpu_begin/end() invoking - Add <mode>(AES) ablkcipher, which uses cryptd(fpu(<mode>(AES))) to defer cryption to cryptd context in soft_irq context. Now the ctr, lrw, pcbc and xts support are added. Performance testing based on dm-crypt shows that cryption time can be reduced to 50% of general mode implementation + aes-aesni implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: fpu - Add template for blkcipher touching FPUHuang Ying
Blkcipher touching FPU need to be enclosed by kernel_fpu_begin() and kernel_fpu_end(). If they are invoked in cipher algorithm implementation, they will be invoked for each block, so that performance will be hurt, because they are "slow" operations. This patch implements "fpu" template, which makes these operations to be invoked for each request. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - add zlib testGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: zlib - New zlib crypto module, using pcompGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: compress - Add pcomp interfaceGeert Uytterhoeven
The current "comp" crypto interface supports one-shot (de)compression only, i.e. the whole data buffer to be (de)compressed must be passed at once, and the whole (de)compressed data buffer will be received at once. In several use-cases (e.g. compressed file systems that store files in big compressed blocks), this workflow is not suitable. Furthermore, the "comp" type doesn't provide for the configuration of (de)compression parameters, and always allocates workspace memory for both compression and decompression, which may waste memory. To solve this, add a "pcomp" partial (de)compression interface that provides the following operations: - crypto_compress_{init,update,final}() for compression, - crypto_decompress_{init,update,final}() for decompression, - crypto_{,de}compress_setup(), to configure (de)compression parameters (incl. allocating workspace memory). The (de)compression methods take a struct comp_request, which was mimicked after the z_stream object in zlib, and contains buffer pointer and length pairs for input and output. The setup methods take an opaque parameter pointer and length pair. Parameters are supposed to be encoded using netlink attributes, whose meanings depend on the actual (name of the) (de)compression algorithm. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: chainiv - Use kcrypto_wq instead of keventd_wqHuang Ying
keventd_wq has potential starvation problem, so use dedicated kcrypto_wq instead. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: cryptd - Per-CPU thread implementation based on kcrypto_wqHuang Ying
Original cryptd thread implementation has scalability issue, this patch solve the issue with a per-CPU thread implementation. struct cryptd_queue is defined to be a per-CPU queue, which holds one struct cryptd_cpu_queue for each CPU. In struct cryptd_cpu_queue, a struct crypto_queue holds all requests for the CPU, a struct work_struct is used to run all requests for the CPU. Testing based on dm-crypt on an Intel Core 2 E6400 (two cores) machine shows 19.2% performance gain. The testing script is as follow: -------------------- script begin --------------------------- #!/bin/sh dmc_create() { # Create a crypt device using dmsetup dmsetup create $2 --table "0 `blockdev --getsize $1` crypt cbc(aes-asm)?cryptd?plain:plain babebabebabebabebabebabebabebabe 0 $1 0" } dmsetup remove crypt0 dmsetup remove crypt1 dd if=/dev/zero of=/dev/ram0 bs=1M count=4 >& /dev/null dd if=/dev/zero of=/dev/ram1 bs=1M count=4 >& /dev/null dmc_create /dev/ram0 crypt0 dmc_create /dev/ram1 crypt1 cat >tr.sh <<EOF #!/bin/sh for n in \$(seq 10); do dd if=/dev/dm-0 of=/dev/null >& /dev/null & dd if=/dev/dm-1 of=/dev/null >& /dev/null & done wait EOF for n in $(seq 10); do /usr/bin/time sh tr.sh done rm tr.sh -------------------- script end --------------------------- The separator of dm-crypt parameter is changed from "-" to "?", because "-" is used in some cipher driver name too, and cryptds need to specify cipher driver name instead of cipher name. The test result on an Intel Core2 E6400 (two cores) is as follow: without patch: -----------------wo begin -------------------------- 0.04user 0.38system 0:00.39elapsed 107%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6566minor)pagefaults 0swaps 0.07user 0.35system 0:00.35elapsed 121%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6567minor)pagefaults 0swaps 0.06user 0.34system 0:00.30elapsed 135%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.37system 0:00.36elapsed 119%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6607minor)pagefaults 0swaps 0.06user 0.36system 0:00.35elapsed 120%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.37system 0:00.31elapsed 136%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6594minor)pagefaults 0swaps 0.04user 0.34system 0:00.30elapsed 126%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6597minor)pagefaults 0swaps 0.06user 0.32system 0:00.31elapsed 125%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6571minor)pagefaults 0swaps 0.06user 0.34system 0:00.31elapsed 134%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6581minor)pagefaults 0swaps 0.05user 0.38system 0:00.31elapsed 138%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6600minor)pagefaults 0swaps -----------------wo end -------------------------- with patch: ------------------w begin -------------------------- 0.02user 0.31system 0:00.24elapsed 141%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6554minor)pagefaults 0swaps 0.05user 0.34system 0:00.31elapsed 127%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6606minor)pagefaults 0swaps 0.07user 0.33system 0:00.26elapsed 155%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6559minor)pagefaults 0swaps 0.07user 0.32system 0:00.26elapsed 151%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.34system 0:00.26elapsed 150%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6603minor)pagefaults 0swaps 0.03user 0.36system 0:00.31elapsed 124%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.04user 0.35system 0:00.26elapsed 147%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6586minor)pagefaults 0swaps 0.03user 0.37system 0:00.27elapsed 146%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.04user 0.36system 0:00.26elapsed 154%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6594minor)pagefaults 0swaps 0.04user 0.35system 0:00.26elapsed 154%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6557minor)pagefaults 0swaps ------------------w end -------------------------- The middle value of elapsed time is: wo cryptwq: 0.31 w cryptwq: 0.26 The performance gain is about (0.31-0.26)/0.26 = 0.192. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: api - Use dedicated workqueue for crypto subsystemHuang Ying
Use dedicated workqueue for crypto subsystem A dedicated workqueue named kcrypto_wq is created to be used by crypto subsystem. The system shared keventd_wq is not suitable for encryption/decryption, because of potential starvation problem. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: aes-ni - Add support to Intel AES-NI instructions for x86_64 platformHuang Ying
Intel AES-NI is a new set of Single Instruction Multiple Data (SIMD) instructions that are going to be introduced in the next generation of Intel processor, as of 2009. These instructions enable fast and secure data encryption and decryption, using the Advanced Encryption Standard (AES), defined by FIPS Publication number 197. The architecture introduces six instructions that offer full hardware support for AES. Four of them support high performance data encryption and decryption, and the other two instructions support the AES key expansion procedure. The white paper can be downloaded from: http://softwarecommunity.intel.com/isn/downloads/intelavx/AES-Instructions-Set_WP.pdf AES may be used in soft_irq context, but MMX/SSE context can not be touched safely in soft_irq context. So in_interrupt() is checked, if in IRQ or soft_irq context, the general x86_64 implementation are used instead. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha512 - Switch to shash Adrian-Ken Rueegsegger
This patch changes sha512 and sha384 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: michael_mic - Switch to shashAdrian-Ken Rueegsegger
This patch changes michael_mic to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: wp512 - Switch to shashAdrian-Ken Rueegsegger
This patch changes wp512, wp384 and wp256 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: tgr192 - Switch to shashAdrian-Ken Rueegsegger
This patch changes tgr192, tgr160 and tgr128 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha256 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha256 and sha224 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md5 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md5 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md4 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md4 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha1 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha1 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd320 - Switch to shashHerbert Xu
This patch changes rmd320 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd256 - Switch to shashHerbert Xu
This patch changes rmd256 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd160 - Switch to shashHerbert Xu
This patch changes rmd160 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd128 - Switch to shashHerbert Xu
This patch changes rmd128 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: null - Switch to shashHerbert Xu
This patch changes digest_null to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25libcrc32c: Move implementation to crypto crc32cHerbert Xu
This patch swaps the role of libcrc32c and crc32c. Previously the implementation was in libcrc32c and crc32c was a wrapper. Now the code is in crc32c and libcrc32c just calls the crypto layer. The reason for the change is to tap into the algorithm selection capability of the crypto API so that optimised implementations such as the one utilising Intel's CRC32C instruction can be used where available. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-10crypto: api - Disallow cryptomgr as a module if algorithms are built-inHerbert Xu
If we have at least one algorithm built-in then it no longer makes sense to have the testing framework, and hence cryptomgr to be a module. It should be either on or off, i.e., built-in or disabled. This just happens to stop a potential runaway modprobe loop that seems to trigger on at least one distro. With fixes from Evgeniy Polyakov. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: crc32c - Use Intel CRC32 instructionAustin Zhang
From NHM processor onward, Intel processors can support hardware accelerated CRC32c algorithm with the new CRC32 instruction in SSE 4.2 instruction set. The patch detects the availability of the feature, and chooses the most proper way to calculate CRC32c checksum. Byte code instructions are used for compiler compatibility. No MMX / XMM registers is involved in the implementation. Signed-off-by: Austin Zhang <austin.zhang@intel.com> Signed-off-by: Kent Liu <kent.liu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: Kconfig - Replace leading spaces with tabsAdrian Bunk
Instead of tabs there were two spaces. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-15Revert crypto: prng - Deterministic CPRNGHerbert Xu
This patch is clearly not ready yet for prime time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
