path: root/crypto/Kconfig
2008-12-25crypto: sha512 - Switch to shash Adrian-Ken Rueegsegger
This patch changes sha512 and sha384 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: michael_mic - Switch to shashAdrian-Ken Rueegsegger
This patch changes michael_mic to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: wp512 - Switch to shashAdrian-Ken Rueegsegger
This patch changes wp512, wp384 and wp256 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: tgr192 - Switch to shashAdrian-Ken Rueegsegger
This patch changes tgr192, tgr160 and tgr128 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha256 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha256 and sha224 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md5 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md5 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md4 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md4 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha1 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha1 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd320 - Switch to shashHerbert Xu
This patch changes rmd320 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd256 - Switch to shashHerbert Xu
This patch changes rmd256 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd160 - Switch to shashHerbert Xu
This patch changes rmd160 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd128 - Switch to shashHerbert Xu
This patch changes rmd128 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: null - Switch to shashHerbert Xu
This patch changes digest_null to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25libcrc32c: Move implementation to crypto crc32cHerbert Xu
This patch swaps the role of libcrc32c and crc32c. Previously the implementation was in libcrc32c and crc32c was a wrapper. Now the code is in crc32c and libcrc32c just calls the crypto layer. The reason for the change is to tap into the algorithm selection capability of the crypto API so that optimised implementations such as the one utilising Intel's CRC32C instruction can be used where available. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-10crypto: api - Disallow cryptomgr as a module if algorithms are built-inHerbert Xu
If we have at least one algorithm built-in then it no longer makes sense to have the testing framework, and hence cryptomgr to be a module. It should be either on or off, i.e., built-in or disabled. This just happens to stop a potential runaway modprobe loop that seems to trigger on at least one distro. With fixes from Evgeniy Polyakov. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: crc32c - Use Intel CRC32 instructionAustin Zhang
From NHM processor onward, Intel processors can support hardware accelerated CRC32c algorithm with the new CRC32 instruction in SSE 4.2 instruction set. The patch detects the availability of the feature, and chooses the most proper way to calculate CRC32c checksum. Byte code instructions are used for compiler compatibility. No MMX / XMM registers is involved in the implementation. Signed-off-by: Austin Zhang <austin.zhang@intel.com> Signed-off-by: Kent Liu <kent.liu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: Kconfig - Replace leading spaces with tabsAdrian Bunk
Instead of tabs there were two spaces. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-15Revert crypto: prng - Deterministic CPRNGHerbert Xu
This patch is clearly not ready yet for prime time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: crc32c - Add ahash implementationHerbert Xu
This patch reimplements crc32c using the ahash interface. This allows one tfm to be used by an unlimited number of users provided that they all use the same key (which all current crc32c users do). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: prng - Deterministic CPRNGNeil Horman
This patch adds a cryptographic pseudo-random number generator based on CTR(AES-128). It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] cryptd: Add asynchronous hash supportLoc Ho
This patch adds asynchronous hash support to crypto daemon. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Add Kconfig entries for extended RIPEMD hash algorithmsAdrian-Ken Rueegsegger
This patch adds Kconfig entries for RIPEMD-256 and RIPEMD-320. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Add Kconfig entries for RIPEMD hash algorithmsAdrian-Ken Rueegsegger
This patch adds Kconfig entries for RIPEMD-128 and RIPEMD-160. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] kconfig: Ordering cleanupSebastian Siewior
Ciphers, block modes, name it, are grouped together and sorted. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] api: Make the crypto subsystem fully modularSebastian Siewior
2008-04-21[CRYPTO] cts: Add CTS mode required for Kerberos AES supportKevin Coffman
Implement CTS wrapper for CBC mode required for support of AES encryption support for Kerberos (rfc3962). Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-02-23[CRYPTO] authenc: Add missing Kconfig dependency on BLKCIPHERHerbert Xu
The authenc algorithm requires BLKCIPHER to be present. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-02-18[CRYPTO] null: Add missing Kconfig dependency on BLKCIPHERAdrian Bunk
This patch fixes the following build error caused by commit 3631c650c495d61b1dabf32eb26b46873636e918: <-- snip --> ... LD .tmp_vmlinux1 crypto/built-in.o: In function `skcipher_null_crypt': crypto_null.c:(.text+0x3d14): undefined reference to `blkcipher_walk_virt' crypto_null.c:(.text+0x3d14): relocation truncated to fit: R_MIPS_26 against `blkcipher_walk_virt' crypto/built-in.o: In function `$L32': crypto_null.c:(.text+0x3d54): undefined reference to `blkcipher_walk_done' crypto_null.c:(.text+0x3d54): relocation truncated to fit: R_MIPS_26 against `blkcipher_walk_done' crypto/built-in.o:(.data+0x2e8): undefined reference to `crypto_blkcipher_type' make[1]: *** [.tmp_vmlinux1] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-02-15[CRYPTO] tcrypt: Add missing Kconfig dependency on BLKCIPHERFrederik Deweerdt
Building latest git fails with the following error: ERROR: "crypto_alloc_ablkcipher" [crypto/tcrypt.ko] undefined! This appears to happen because CONFIG_CRYPTO_TEST is set while CONFIG_CRYPTO_BLKCIPHER is not. The following patch fixes the problem for me. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20-asm: Remove unnecessary dependency on CRYPTO_SALSA20Tan Swee Heng
Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] tcrypt: Add select of AEADSebastian Siewior
ERROR: "crypto_aead_setauthsize" [crypto/tcrypt.ko] undefined! ERROR: "crypto_alloc_aead" [crypto/tcrypt.ko] undefined! Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20: Add x86-64 assembly versionTan Swee Heng
This is the x86-64 version of the Salsa20 stream cipher algorithm. The original assembly code came from <http://cr.yp.to/snuffle/salsa20/amd64-3/salsa20.s>. It has been reformatted for clarity. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20_i586: Salsa20 stream cipher algorithm (i586 version)Tan Swee Heng
This patch contains the salsa20-i586 implementation. The original assembly code came from <http://cr.yp.to/snuffle/salsa20/x86-pm/salsa20.s>. I have reformatted it (added indents) so that it matches the other algorithms in arch/x86/crypto. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add select AEAD in KconfigHerbert Xu
Now that seqiv supports AEAD algorithms it needs to select the AEAD option. Thanks to Erez Zadok for pointing out the problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ccm: Added CCM modeJoy Latten
This patch adds Counter with CBC-MAC (CCM) support. RFC 3610 and NIST Special Publication 800-38C were referenced. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add Sequence Number IV GeneratorHerbert Xu
This generator generates an IV based on a sequence number by xoring it with a salt. This algorithm is mainly useful for CTR and similar modes. This patch also sets it as the default IV generator for ctr. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] blkcipher: Merge ablkcipher and blkcipher into one option/moduleHerbert Xu
With the impending addition of the givcipher type, both blkcipher and ablkcipher algorithms will use it to create givcipher objects. As such it no longer makes sense to split the system between ablkcipher and blkcipher. In particular, both ablkcipher.c and blkcipher.c would need to use the givcipher type which has to reside in ablkcipher.c since it shares much code with it. This patch merges the two Kconfig options as well as the modules into one. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Select HASH in KconfigBorislav Petkov
i get here: ---- LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map Building modules, stage 2. MODPOST 226 modules ERROR: "crypto_hash_type" [crypto/authenc.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 --- which fails because crypto_hash_type is declared in crypto/hash.c. You might wanna fix it like so: Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] lzo: Add LZO compression algorithm supportZoltan Sogor
Add LZO compression algorithm support Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: New algorithmMikko Herranen
Add GCM/GMAC support to cryptoapi. GCM (Galois/Counter Mode) is an AEAD mode of operations for any block cipher with a block size of 16. The typical example is AES-GCM. Signed-off-by: Mikko Herranen <mh1@iki.fi> Reviewed-by: Mika Kukkonen <mika.kukkonen@nsn.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] salsa20: Salsa20 stream cipherTan Swee Heng
This patch implements the Salsa20 stream cipher using the blkcipher interface. The core cipher code comes from Daniel Bernstein's submission to eSTREAM: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ref/ The test vectors comes from: http://www.ecrypt.eu.org/stream/svn/viewcvs.cgi/ecrypt/trunk/submissions/salsa20/full/ It has been tested successfully with "modprobe tcrypt mode=34" on an UML instance. Signed-off-by: Tan Swee Heng <thesweeheng@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] sha256-generic: Extend sha256_generic.c to support SHA-224Jonathan Lynch
Resubmitting this patch which extends sha256_generic.c to support SHA-224 as described in FIPS 180-2 and RFC 3874. HMAC-SHA-224 as described in RFC4231 is then supported through the hmac interface. Patch includes test vectors for SHA-224 and HMAC-SHA-224. SHA-224 chould be chosen as a hash algorithm when 112 bits of security strength is required. Patch generated against the 2.6.24-rc1 kernel and tested against 2.6.24-rc1-git14 which includes fix for scatter gather implementation for HMAC. Signed-off-by: Jonathan Lynch <jonathan.lynch@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes-i586: Remove setkeySebastian Siewior
The setkey() function can be shared with the generic algorithm. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Remove default MSebastian Siewior
NO other block mode is M by default. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes-x86-64: Remove setkeySebastian Siewior
2008-01-11[CRYPTO] ctr: Add CTR (Counter) block cipher modeJoy Latten
This patch implements CTR mode for IPsec. It is based off of RFC 3686. Please note: 1. CTR turns a block cipher into a stream cipher. Encryption is done in blocks, however the last block may be a partial block. A "counter block" is encrypted, creating a keystream that is xor'ed with the plaintext. The counter portion of the counter block is incremented after each block of plaintext is encrypted. Decryption is performed in same manner. 2. The CTR counterblock is composed of, nonce + IV + counter The size of the counterblock is equivalent to the blocksize of the cipher. sizeof(nonce) + sizeof(IV) + sizeof(counter) = blocksize The CTR template requires the name of the cipher algorithm, the sizeof the nonce, and the sizeof the iv. ctr(cipher,sizeof_nonce,sizeof_iv) So for example, ctr(aes,4,8) specifies the counterblock will be composed of 4 bytes from a nonce, 8 bytes from the iv, and 4 bytes for counter since aes has a blocksize of 16 bytes. 3. The counter portion of the counter block is stored in big endian for conformance to rfc 3686. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
