path: root/crypto/Makefile
2013-12-05crypto: more robust crypto_memneqCesar Eduardo Barros
Disabling compiler optimizations can be fragile, since a new optimization could be added to -O0 or -Os that breaks the assumptions the code is making. Instead of disabling compiler optimizations, use a dummy inline assembly (based on RELOC_HIDE) to block the problematic kinds of optimization, while still allowing other optimizations to be applied to the code. The dummy inline assembly is added after every OR, and has the accumulator variable as its input and output. The compiler is forced to assume that the dummy inline assembly could both depend on the accumulator variable and change the accumulator variable, so it is forced to compute the value correctly before the inline assembly, and cannot assume anything about its value after the inline assembly. This change should be enough to make crypto_memneq work correctly (with data-independent timing) even if it is inlined at its call sites. That can be done later in a followup patch. Compile-tested on x86_64. Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.eti.br> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Made x86 ablk_helper generic for ARM - Phase out chainiv in favour of eseqiv (affects IPsec) - Fixed aes-cbc IV corruption on s390 - Added constant-time crypto_memneq which replaces memcmp - Fixed aes-ctr in omap-aes - Added OMAP3 ROM RNG support - Add PRNG support for MSM SoC's - Add and use Job Ring API in caam - Misc fixes [ NOTE! This pull request was sent within the merge window, but Herbert has some questionable email sending setup that makes him public enemy #1 as far as gmail is concerned. So most of his emails seem to be trapped by gmail as spam, resulting in me not seeing them. - Linus ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (49 commits) crypto: s390 - Fix aes-cbc IV corruption crypto: omap-aes - Fix CTR mode counter length crypto: omap-sham - Add missing modalias padata: make the sequence counter an atomic_t crypto: caam - Modify the interface layers to use JR API's crypto: caam - Add API's to allocate/free Job Rings crypto: caam - Add Platform driver for Job Ring hwrng: msm - Add PRNG support for MSM SoC's ARM: DT: msm: Add Qualcomm's PRNG driver binding document crypto: skcipher - Use eseqiv even on UP machines crypto: talitos - Simplify key parsing crypto: picoxcell - Simplify and harden key parsing crypto: ixp4xx - Simplify and harden key parsing crypto: authencesn - Simplify key parsing crypto: authenc - Export key parsing helper function crypto: mv_cesa: remove deprecated IRQF_DISABLED hwrng: OMAP3 ROM Random Number Generator support crypto: sha256_ssse3 - also test for BMI2 crypto: mv_cesa - Remove redundant of_match_ptr crypto: sahara - Remove redundant of_match_ptr ...
2013-10-25crypto: provide single place for hash algo informationDmitry Kasatkin
This patch provides a single place for information about hash algorithms, such as hash sizes and kernel driver names, which will be used by IMA and the public key code. Changelog: - Fix sparse and checkpatch warnings - Move hash algo enums to uapi for userspace signing functions. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-10-07crypto: crypto_memneq - add equality testing of memory regions w/o timing leaksJames Yonan
When comparing MAC hashes, AEAD authentication tags, or other hash values in the context of authentication or integrity checking, it is important not to leak timing information to a potential attacker, i.e. when communication happens over a network. Bytewise memory comparisons (such as memcmp) are usually optimized so that they return a nonzero value as soon as a mismatch is found. E.g, on x86_64/i5 for 512 bytes this can be ~50 cyc for a full mismatch and up to ~850 cyc for a full match (cold). This early-return behavior can leak timing information as a side channel, allowing an attacker to iteratively guess the correct result. This patch adds a new method crypto_memneq ("memory not equal to each other") to the crypto API that compares memory areas of the same length in roughly "constant time" (cache misses could change the timing, but since they don't reveal information about the content of the strings being compared, they are effectively benign). Iow, best and worst case behaviour take the same amount of time to complete (in contrast to memcmp). Note that crypto_memneq (unlike memcmp) can only be used to test for equality or inequality, NOT for lexicographical order. This, however, is not an issue for its use-cases within the crypto API. We tried to locate all of the places in the crypto API where memcmp was being used for authentication or integrity checking, and convert them over to crypto_memneq. crypto_memneq is declared noinline, placed in its own source file, and compiled with optimizations that might increase code size disabled ("Os") because a smart compiler (or LTO) might notice that the return value is always compared against zero/nonzero, and might then reintroduce the same early-return optimization that we are trying to avoid. Using #pragma or __attribute__ optimization annotations of the code for disabling optimization was avoided as it seems to be considered broken or unmaintained for long time in GCC [1]. Therefore, we work around that by specifying the compile flag for memneq.o directly in the Makefile. We found that this seems to be most appropriate. As we use ("Os"), this patch also provides a loop-free "fast-path" for frequently used 16 byte digests. Similarly to kernel library string functions, leave an option for future even further optimized architecture specific assembler implementations. This was a joint work of James Yonan and Daniel Borkmann. Also thanks for feedback from Florian Weimer on this and earlier proposals [2]. [1] http://gcc.gnu.org/ml/gcc/2012-07/msg00211.html [2] https://lkml.org/lkml/2013/2/10/131 Signed-off-by: James Yonan <james@openvpn.net> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Florian Weimer <fw@deneb.enyo.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-24crypto: create generic version of ablk_helperArd Biesheuvel
Create a generic version of ablk_helper so it can be reused by other architectures. Acked-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-12crypto: crct10dif - Add fallback for broken initrdsHerbert Xu
Unfortunately, even with a softdep some distros fail to include the necessary modules in the initrd. Therefore this patch adds a fallback path to restore existing behaviour where we cannot load the new crypto crct10dif algorithm. In order to do this, the underlying crct10dif has been split out from the crypto implementation so that it can be used on the fallback path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This push fixes a memory corruption issue in caam, as well as reverting the new optimised crct10dif implementation as it breaks boot on initrd systems. Hopefully crct10dif will be reinstated once the supporting code is added so that it doesn't break boot" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" crypto: caam - Fixed the memory out of bound overwrite issue
2013-07-24Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This reverts commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Unfortunately this change broke boot on some systems that used an initrd which does not include the newly created crct10dif modules. As these modules are required by sd_mod under certain configurations this is a serious problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-09crypto: add lz4 Cryptographic APIChanho Min
Add support for lz4 and lz4hc compression algorithm using the lib/lz4/* codebase. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Chanho Min <chanho.min@lge.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Richard Weinberger <richard@nod.at> Cc: Herbert Xu <herbert@gondor.hengli.com.au> Cc: Yann Collet <yann.collet.73@gmail.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-20crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform ↵Tim Chen
framework When CRC T10 DIF is calculated using the crypto transform framework, we wrap the crc_t10dif function call to utilize it. This allows us to take advantage of any accelerated CRC T10 DIF transform that is plugged into the crypto framework. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: add CMAC support to CryptoAPIJussi Kivilinna
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI. This work is based on Tom St Denis' earlier patch, http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2 Cc: Tom St Denis <tstdenis@elliptictech.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: crc32 - add crc32 pclmulqdq implementation and wrappers for table ↵Alexander Boyko
implementation This patch adds crc32 algorithms to shash crypto api. One is wrapper to gerneric crc32_le function. Second is crc32 pclmulqdq implementation. It use hardware provided PCLMULQDQ instruction to accelerate the CRC32 disposal. This instruction present from Intel Westmere and AMD Bulldozer CPUs. For intel core i5 I got 450MB/s for table implementation and 2100MB/s for pclmulqdq implementation. Signed-off-by: Alexander Boyko <alexander_boyko@xyratex.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: cast5/cast6 - move lookup tables to shared moduleJussi Kivilinna
CAST5 and CAST6 both use same lookup tables, which can be moved shared module 'cast_common'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Implement asymmetric key typeDavid Howells
Create a key type that can be used to represent an asymmetric key type for use in appropriate cryptographic operations, such as encryption, decryption, signature generation and signature verification. The key type is "asymmetric" and can provide access to a variety of cryptographic algorithms. Possibly, this would be better as "public_key" - but that has the disadvantage that "public key" is an overloaded term. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-08-01powerpc/crypto: add 842 crypto driverSeth Jennings
This patch add the 842 cryptographic API driver that submits compression requests to the 842 hardware compression accelerator driver (nx-compress). If the hardware accelerator goes offline for any reason (dynamic disable, migration, etc...), this driver will use LZO as a software failover for all future compression requests. For decompression requests, the 842 hardware driver contains a software implementation of the 842 decompressor to support the decompression of data that was compressed before the accelerator went offline. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cast6 - prepare generic module for optimized implementationsJohannes Goetzfried
Rename cast6 module to cast6_generic to allow autoloading of optimized implementations. Generic functions and s-boxes are exported to be able to use them within optimized implementations. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cast5 - prepare generic module for optimized implementationsJohannes Goetzfried
Rename cast5 module to cast5_generic to allow autoloading of optimized implementations. Generic functions and s-boxes are exported to be able to use them within optimized implementations. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: camellia - rename camellia.c to camellia_generic.cJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: camellia - rename camellia module to camellia_genericJussi Kivilinna
Rename camellia module to camellia_generic to allow optimized assembler implementations to autoload with module-alias. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent - rename serpent.c to serpent_generic.cJussi Kivilinna
Now that serpent.c has been cleaned from checkpatch warnings, we can do clean rename. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: serpent - rename module from serpent to serpent_genericJussi Kivilinna
Rename module from serpent.ko to serpent_generic.ko and add module alias. This is to allow assembler implementation to autoload on 'modprobe serpent'. Also add driver_name and priority for serpent cipher. CC: Dag Arne Osvik <osvik@ii.uib.no> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add userspace configuration APISteffen Klassert
This patch adds a basic userspace configuration API for the crypto layer. With this it is possible to instantiate, remove and to show crypto algorithms from userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-09-22crypto: blowfish - rename C-version to blowfish_genericJussi Kivilinna
Rename blowfish to blowfish_generic so that assembler versions of blowfish cipher can autoload. Module alias 'blowfish' is added. Also fix checkpatch warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-09-22crypto: blowfish - split generic and common c codeJussi Kivilinna
Patch splits up the blowfish crypto routine into a common part (key setup) which will be used by blowfish crypto modules (x86_64 assembly and generic-c). Also fixes errors/warnings reported by checkpatch. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-03-13crypto: authencesn - Add algorithm to handle IPsec extended sequence numbersSteffen Klassert
ESP with separate encryption/authentication algorithms needs a special treatment for the associated data. This patch add a new algorithm that handles esp with extended sequence numbers. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27crypto: Makefile clean upTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-11-26crypto: algif_skcipher - User-space interface for skcipher operationsHerbert Xu
This patch adds the af_alg plugin for symmetric key ciphers, corresponding to the ablkcipher kernel operation type. Keys can optionally be set through the setsockopt interface. Once a sendmsg call occurs without MSG_MORE no further writes may be made to the socket until all previous data has been read. IVs and and whether encryption/decryption is performed can be set through the setsockopt interface or as a control message to sendmsg. The interface is completely synchronous, all operations are carried out in recvmsg(2) and will complete prior to the system call returning. The splice(2) interface support reading the user-space data directly without copying (except that the Crypto API itself may copy the data if alignment is off). The recvmsg(2) interface supports directly writing to user-space without additional copying, i.e., the kernel crypto interface will receive the user-space address as its output SG list. Thakns to Miloslav Trmac for reviewing this and contributing fixes and improvements. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net>
2010-11-19crypto: algif_hash - User-space interface for hash operationsHerbert Xu
This patch adds the af_alg plugin for hash, corresponding to the ahash kernel operation type. Keys can optionally be set through the setsockopt interface. Each sendmsg call will finalise the hash unless sent with a MSG_MORE flag. Partial hash states can be cloned using accept(2). The interface is completely synchronous, all operations will complete prior to the system call returning. Both sendmsg(2) and splice(2) support reading the user-space data directly without copying (except that the Crypto API itself may copy the data if alignment is off). For now only the splice(2) interface supports performing digest instead of init/update/final. In future the sendmsg(2) interface will also be modified to use digest/finup where possible so that hardware that cannot return a partial hash state can still benefit from this interface. Thakns to Miloslav Trmac for reviewing this and contributing fixes and improvements. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Martin Willi <martin@strongswan.org>
2010-11-19crypto: af_alg - User-space interface for Crypto APIHerbert Xu
This patch creates the backbone of the user-space interface for the Crypto API, through a new socket family AF_ALG. Each session corresponds to one or more connections obtained from that socket. The number depends on the number of inputs/outputs of that particular type of operation. For most types there will be a s ingle connection/file descriptor that is used for both input and output. AEAD is one of the few that require two inputs. Each algorithm type will provide its own implementation that plugs into af_alg. They're keyed using a string such as "skcipher" or "hash". IOW this patch only contains the boring bits that is required to hold everything together. Thakns to Miloslav Trmac for reviewing this and contributing fixes and improvements. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Martin Willi <martin@strongswan.org>
2010-06-03crypto: twofish: Rename twofish to twofish_generic and add an aliasJoachim Fritschi
This fixes the broken autoloading of the corresponding twofish assembler ciphers on x86 and x86_64 if they are available. The module name of the generic implementation was in conflict with the alias in the assembler modules. The generic twofish c implementation is renamed to twofish_generic according to the other algorithms with assembler implementations and an module alias is added for 'twofish'. You can now load 'twofish' giving you the best implementation by priority, 'twofish-generic' to get the c implementation or 'twofish-asm' to get the assembler version of cipher. Signed-off-by: Joachim Fritschi <jfritschi@freenet.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-06-03crypto: pcomp - Fix illegal Kconfig configurationHerbert Xu
The PCOMP Kconfig entry current allows the following combination which is illegal: ZLIB=y PCOMP=y ALGAPI=m ALGAPI2=y MANAGER=m MANAGER2=m This patch fixes this by adding PCOMP2 so that PCOMP can select ALGAPI to propagate the setting to MANAGER2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: ghash - Add GHASH digest algorithm for GCMHuang Ying
GHASH is implemented as a shash algorithm. The actual implementation is copied from gcm.c. This makes it possible to add architecture/hardware accelerated GHASH implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Remove legacy hash/digest implementaionHerbert Xu
This patch removes the implementation of hash and digest now that no algorithms use them anymore. The interface though will remain until the users are converted across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: zlib - New zlib crypto module, using pcompGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: compress - Add pcomp interfaceGeert Uytterhoeven
The current "comp" crypto interface supports one-shot (de)compression only, i.e. the whole data buffer to be (de)compressed must be passed at once, and the whole (de)compressed data buffer will be received at once. In several use-cases (e.g. compressed file systems that store files in big compressed blocks), this workflow is not suitable. Furthermore, the "comp" type doesn't provide for the configuration of (de)compression parameters, and always allocates workspace memory for both compression and decompression, which may waste memory. To solve this, add a "pcomp" partial (de)compression interface that provides the following operations: - crypto_compress_{init,update,final}() for compression, - crypto_decompress_{init,update,final}() for decompression, - crypto_{,de}compress_setup(), to configure (de)compression parameters (incl. allocating workspace memory). The (de)compression methods take a struct comp_request, which was mimicked after the z_stream object in zlib, and contains buffer pointer and length pairs for input and output. The setup methods take an opaque parameter pointer and length pair. Parameters are supposed to be encoded using netlink attributes, whose meanings depend on the actual (name of the) (de)compression algorithm. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: api - Use dedicated workqueue for crypto subsystemHuang Ying
Use dedicated workqueue for crypto subsystem A dedicated workqueue named kcrypto_wq is created to be used by crypto subsystem. The system shared keventd_wq is not suitable for encryption/decryption, because of potential starvation problem. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add shash interfaceHerbert Xu
The shash interface replaces the current synchronous hash interface. It improves over hash in two ways. Firstly shash is reentrant, meaning that the same tfm may be used by two threads simultaneously as all hashing state is stored in a local descriptor. The other enhancement is that shash no longer takes scatter list entries. This is because shash is specifically designed for synchronous algorithms and as such scatter lists are unnecessary. All existing hash users will be converted to shash once the algorithms have been completely converted. There is also a new finup function that combines update with final. This will be extended to ahash once the algorithm conversion is done. This is also the first time that an algorithm type has their own registration function. Existing algorithm types will be converted to this way in due course. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-10crypto: api - Disallow cryptomgr as a module if algorithms are built-inHerbert Xu
If we have at least one algorithm built-in then it no longer makes sense to have the testing framework, and hence cryptomgr to be a module. It should be either on or off, i.e., built-in or disabled. This just happens to stop a potential runaway modprobe loop that seems to trigger on at least one distro. With fixes from Evgeniy Polyakov. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: skcipher - Move IV generators into their own modulesHerbert Xu
This patch moves the default IV generators into their own modules in order to break a dependency loop between cryptomgr, rng, and blkcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-15Revert crypto: prng - Deterministic CPRNGHerbert Xu
This patch is clearly not ready yet for prime time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: prng - Deterministic CPRNGNeil Horman
This patch adds a cryptographic pseudo-random number generator based on CTR(AES-128). It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] hash: Add asynchronous hash supportLoc Ho
This patch adds asynchronous hash and digest support. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Add support for RIPEMD-256 and RIPEMD-320Adrian-Ken Rueegsegger
This patch adds support for the extended RIPEMD hash algorithms RIPEMD-256 and RIPEMD-320. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
