commit a6a48c565f6f112c6983e2a02b1602189ed6e26e upstream.
This patch forbids the calling of bind(2) when there are child
sockets created by accept(2) in existence, even if they are created
on the nokey path.
This is needed as those child sockets have references to the tfm
object which bind(2) will destroy.
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream.
This patch allows af_alg_release_parent to be called even for
nokey sockets.
commit 37766586c965d63758ad542325a96d5384f4a8c9 upstream.
This patch adds a compatibility path to support old applications
that do acept(2) before setkey.
commit a383292c86663bbc31ac62cc0c04fc77504636a6 upstream.
When we fail an accept(2) call we will end up freeing the socket
twice, once due to the direct sk_free call and once again through
newsock.
This patch fixes this by removing the sk_free call.
commit c840ac6af3f8713a71b4d2363419145760bd6044 upstream.
Each af_alg parent socket obtained by socket(2) corresponds to a
tfm object once bind(2) has succeeded. An accept(2) call on that
parent socket creates a context which then uses the tfm object.
Therefore as long as any child sockets created by accept(2) exist
the parent socket must not be modified or freed.
This patch guarantees this by using locks and a reference count
on the parent socket. Any attempt to modify the parent socket will
fail with EBUSY.
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
The bit CRYPTO_ALG_INTERNAL was added to stop af_alg from accessing
internal algorithms. However, af_alg itself was never modified to
actually stop that bit from being used by the user. Therefore the
user could always override it by specifying the relevant bit in the
type and/or mask.
This patch silently discards the bit in both type and mask.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
Use EXPORT_SYMBOL_GPL instead of EXPORT_SYMBOL.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Allow to link af_alg sgls.
Pull crypto update from Herbert Xu:
"Here is the crypto update for 3.20:
- Added 192/256-bit key support to aesni GCM.
- Added MIPS OCTEON MD5 support.
- Fixed hwrng starvation and race conditions.
- Added note that memzero_explicit is not a subsitute for memset.
- Added user-space interface for crypto_rng.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits)
crypto: tcrypt - do not allocate iv on stack for aead speed tests
crypto: testmgr - limit IV copy length in aead tests
crypto: tcrypt - fix buflen reminder calculation
crypto: testmgr - mark rfc4106(gcm(aes)) as fips_allowed
crypto: caam - fix resource clean-up on error path for caam_jr_init
crypto: caam - pair irq map and dispose in the same function
crypto: ccp - terminate ccp_support array with empty element
crypto: caam - remove unused local variable
crypto: caam - remove dead code
crypto: caam - don't emit ICV check failures to dmesg
hwrng: virtio - drop extra empty line
crypto: replace scatterwalk_sg_next with sg_next
crypto: atmel - Free memory in error path
crypto: doc - remove colons in comments
crypto: seqiv - Ensure that IV size is at least 8 bytes
crypto: cts - Weed out non-CBC algorithms
MAINTAINERS: add linux-crypto to hw random
crypto: cts - Remove bogus use of seqiv
crypto: qat - don't need qat_auth_state struct
crypto: algif_rng - fix sparse non static symbol warning
Commit 1d10eb2f156f ("crypto: switch af_alg_make_sg() to iov_iter")
broke af_alg_make_sg() and skcipher_recvmsg() in the process of moving
them to the iov_iter interfaces. The 'npages' calculation in the formar
calculated the number of *bytes* in the pages, and in the latter case
the conversion didn't re-read the value of 'ctx->used' after waiting for
it to become non-zero.
This reverts to the original code for both these cases.
With that, all ->sendmsg() instances are converted to iov_iter primitives
and are agnostic wrt the kind of iov_iter they are working with.
So's the last remaining ->recvmsg() instance that wasn't kind-agnostic yet.
All ->sendmsg() and ->recvmsg() advance ->msg_iter by the amount actually
copied and none of them modifies the underlying iovec, etc.
Cc: linux-crypto@vger.kernel.org
alg_setkey should zeroize the sensitive data after use.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Use setsockopt on the tfm FD to provide the authentication tag size for
an AEAD cipher. This is achieved by adding a callback function which is
intended to be used by the AEAD AF_ALG implementation.
The optlen argument of the setsockopt specifies the authentication tag
size to be used with the AEAD tfm.
Fixed style error identified by checkpatch.
ERROR: space required before the open parenthesis '('
+ switch(cmsg->cmsg_type) {
Signed-off-by: Joshua I. James <joshua@cybercrimetech.com>
If a request is backlogged, it's complete() handler will get called
twice: once with -EINPROGRESS, and once with the final error code.
af_alg's complete handler, unlike other users, does not handle the
-EINPROGRESS but instead always completes the completion that recvmsg()
is waiting on. This can lead to a return to user space while the
request is still pending in the driver. If userspace closes the sockets
before the requests are handled by the driver, this will lead to
use-after-frees (and potential crashes) in the kernel due to the tfm
having been freed.
The crashes can be easily reproduced (for example) by reducing the max
queue length in cryptod.c and running the following (from
http://www.chronox.de/libkcapi.html) on AES-NI capable hardware:
$ while true; do kcapi -x 1 -e -c '__ecb-aes-aesni' \
-k 00000000000000000000000000000000 \
-p 00000000000000000000000000000000 >/dev/null & done
Cc: stable@vger.kernel.org
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
- The crypto API is now documented :)
- Disallow arbitrary module loading through crypto API.
- Allow get request with empty driver name through crypto_user.
- Allow speed testing of arbitrary hash functions.
- Add caam support for ctr(aes), gcm(aes) and their derivatives.
- nx now supports concurrent hashing properly.
- Add sahara support for SHA1/256.
- Add ARM64 version of CRC32.
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (77 commits)
crypto: tcrypt - Allow speed testing of arbitrary hash functions
crypto: af_alg - add user space interface for AEAD
crypto: qat - fix problem with coalescing enable logic
crypto: sahara - add support for SHA1/256
crypto: sahara - replace tasklets with kthread
crypto: sahara - add support for i.MX53
crypto: sahara - fix spinlock initialization
crypto: arm - replace memset by memzero_explicit
crypto: powerpc - replace memset by memzero_explicit
crypto: sha - replace memset by memzero_explicit
crypto: sparc - replace memset by memzero_explicit
crypto: algif_skcipher - initialize upon init request
crypto: algif_skcipher - removed unneeded code
crypto: algif_skcipher - Fixed blocking recvmsg
crypto: drbg - use memzero_explicit() for clearing sensitive data
crypto: drbg - use MODULE_ALIAS_CRYPTO
crypto: include crypto- module prefix in template
crypto: user - add MODULE_ALIAS
crypto: sha-mb - remove a bogus NULL check
crytpo: qat - Fix 64 bytes requests
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating
cmsghdr from msghdr, just cleanup.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
AEAD requires the caller to specify the following information separate
from the data stream. This information allows the AEAD interface handler
to identify the AAD, ciphertext/plaintext and the authentication tag:
* Associated authentication data of arbitrary length and
length
* Length of authentication tag for encryption
Th AF_ALG socket was missing a security label (e.g. SELinux)
which means that socket was in "unlabeled" state.
This was recently demonstrated in the cryptsetup package
(cryptsetup v1.6.5 and later.)
See https://bugzilla.redhat.com/show_bug.cgi?id=1115120
This patch clones the sock's label from the parent sock
and resolves the issue (similar to AF_BLUETOOTH protocol family).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Change data type to fix warning:
crypto/af_alg.c:35: warning: initialization from incompatible pointer type
Signed-off-by: Miloslav Trmač <mitr@redhat.com>
This patch creates the backbone of the user-space interface for
the Crypto API, through a new socket family AF_ALG.
Each session corresponds to one or more connections obtained from
that socket. The number depends on the number of inputs/outputs
of that particular type of operation. For most types there will
be a s ingle connection/file descriptor that is used for both input
and output. AEAD is one of the few that require two inputs.
Each algorithm type will provide its own implementation that plugs
into af_alg. They're keyed using a string such as "skcipher" or
"hash".
IOW this patch only contains the boring bits that is required
to hold everything together.
Thakns to Miloslav Trmac for reviewing this and contributing
fixes and improvements.
Tested-by: Martin Willi <martin@strongswan.org>
