path: root/crypto/ahash.c
2010-08-06crypto: hash - Fix handling of small unaligned buffersSzilveszter Ördög
If a scatterwalk chain contains an entry with an unaligned offset then hash_walk_next() will cut off the next step at the next alignment point. However, if the entry ends before the next alignment point then we a loop, which leads to a kernel oops. Fix this by checking whether the next aligment point is before the end of the current entry. Signed-off-by: Szilveszter Ördög <slipszi@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-03crypto: hash - Fix handling of unaligned buffersSzilveszter Ördög
The correct way to calculate the start of the aligned part of an unaligned buffer is: offset = ALIGN(offset, alignmask + 1); However, crypto_hash_walk_done() has: offset += alignmask - 1; offset = ALIGN(offset, alignmask + 1); which actually skips a whole block unless offset % (alignmask + 1) == 1. This patch fixes the problem. Signed-off-by: Szilveszter Ördög <slipszi@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: ahash - Use GFP_KERNEL on allocation if the request can sleepSteffen Klassert
ahash_op_unaligned() and ahash_def_finup() allocate memory atomically, regardless whether the request can sleep or not. This patch changes this to use GFP_KERNEL if the request can sleep. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Fix setkey crashHerbert Xu
When the alignment check was made unconditional for ahash we may end up crashing on shash algorithms because we're always calling alg->setkey instead of tfm->setkey. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Add unaligned handling and default operationsHerbert Xu
This patch exports the finup operation where available and adds a default finup operation for ahash. The operations final, finup and digest also will now deal with unaligned result pointers by copying it. Finally export/import operations are will now be exported too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Use GFP_KERNEL in unaligned setkeyHerbert Xu
We currently use GFP_ATOMIC in the unaligned setkey function to allocate the temporary aligned buffer. Since setkey must be called in a sleepable context, we can use GFP_KERNEL instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Zap unaligned buffersHerbert Xu
Some unaligned buffers on the stack weren't zapped properly which may cause secret data to be leaked. This patch fixes them by doing a zero memset. It is also possible for us to place random kernel stack contents in the digest buffer if a digest operation fails. This is fixed by only copying if the operation succeeded. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Remove old_ahash_algHerbert Xu
Now that all ahash implementations have been converted to the new ahash type, we can remove old_ahash_alg and its associated support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Add instance/spawn supportHerbert Xu
This patch adds support for creating ahash instances and using ahash as spawns. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Convert to new style algorithmsHerbert Xu
This patch converts crypto_ahash to the new style. The old ahash algorithm type is retained until the existing ahash implementations are also converted. All ahash users will automatically get the new crypto_ahash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-05-31crypto: hash - Fix handling of sg entry that crosses page boundaryHerbert Xu
A quirk that we've always supported is having an sg entry that's bigger than a page, or more generally an sg entry that crosses page boundaries. Even though it would be better to explicitly have to sg entries for this, we need to support it for the existing users, in particular, IPsec. The new ahash sg walking code did try to handle this, but there was a bug where we didn't increment the page so kept on walking on the first page over an dover again. This patch fixes it. Tested-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: ahash - Fix digest size in /proc/cryptoLee Nipper
crypto_ahash_show changed to use cra_ahash for digestsize reference. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Make setkey optionalHerbert Xu
Since most cryptographic hash algorithms have no keys, this patch makes the setkey function optional for ahash and shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Export shash through hashHerbert Xu
This patch allows shash algorithms to be used through the old hash interface. This is a transitional measure so we can convert the underlying algorithms to shash before converting the users across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add import/export interfaceHerbert Xu
It is often useful to save the partial state of a hash function so that it can be used as a base for two or more computations. The most prominent example is HMAC where all hashes start from a base determined by the key. Having an import/export interface means that we only have to compute that base once rather than for each message. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Added scatter list walking helperHerbert Xu
This patch adds the walking helpers for hash algorithms akin to those of block ciphers. This is a necessary step before we can reimplement existing hash algorithms using the new ahash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Removed vestigial ahash fieldsHerbert Xu
The base field in ahash_tfm appears to have been cut-n-pasted from ablkcipher. It isn't needed here at all. Similarly, the info field in ahash_request also appears to have originated from its cipher counter-part and is vestigial. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Fixed digest size checkHerbert Xu
The digest size check on hash algorithms is incorrect. It's perfectly valid for hash algorithms to have a digest length longer than their block size. For example crc32c has a block size of 1 and a digest size of 4. Rather than having it lie about its block size, this patch fixes the checks to do what they really should which is to bound the digest size so that code placing the digest on the stack continue to work. HMAC however still needs to check this as it's only defined for such algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] hash: Add asynchronous hash supportLoc Ho
This patch adds asynchronous hash and digest support. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
