path: root/crypto/algapi.c
2015-01-29crypto: include crypto- module prefix in templateKees Cook
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream. This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03crypto: sanitize argument for format stringKees Cook
The template lookup interface does not provide a way to use format strings, so make sure that the interface cannot be abused accidentally. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-04crypto: use ERR_CASTJulia Lawall
Replace PTR_ERR followed by ERR_PTR by ERR_CAST, to be more concise. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression err,x; @@ - err = PTR_ERR(x); if (IS_ERR(x)) - return ERR_PTR(err); + return ERR_CAST(x); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-22crypto: algapi - Move larval completion into algbossHerbert Xu
It has been observed that sometimes the crypto allocation code will get stuck for 60 seconds or multiples thereof. This is usually caused by an algorithm failing to pass the self-test. If an algorithm fails to be constructed, we will immediately notify all larval waiters. However, if it succeeds in construction, but then fails the self-test, we won't notify anyone at all. This patch fixes this by merging the notification in the case where the algorithm fails to be constructed with that of the the case where it pases the self-test. This way regardless of what happens, we'll give the larval waiters an answer. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-26crypto: Add bulk algorithm registration interfaceMark Brown
Hardware crypto engines frequently need to register a selection of different algorithms with the core. Simplify their code slightly, especially the error handling, by providing functions to register a number of algorithms in a single call. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: Unlink and free instances when deletedSteffen Klassert
We leak the crypto instance when we unregister an instance with crypto_del_alg(). Therefore we introduce crypto_unregister_instance() to unlink the crypto instance from the template's instances list and to free the recources of the instance properly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Export crypto_remove_finalSteffen Klassert
The upcomming crypto usrerspace configuration api needs to remove the spawns on top on an algorithm, so export crypto_remove_final. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Export crypto_remove_spawnsSteffen Klassert
The upcomming crypto usrerspace configuration api needs to remove the spawns on top on an algorithm, so export crypto_remove_spawns. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add a flag to identify crypto instancesSteffen Klassert
The upcomming crypto user configuration api needs to identify crypto instances. This patch adds a flag that is set if the algorithm is an instance that is build from templates. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
2010-05-03crypto: algapi - Remove unneeded null checkDan Carpenter
We don't check "frontend" consistently in crypto_init_spawn2(). We check it at the start of the function but then we dereference it unconditionally in the parameter list when we call crypto_init_spawn(). I looked at the places that call crypto_init_spawn2() and "frontend" is always a valid pointer so I removed the check for null. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16crypto: algapi - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits) crypto: sha-s390 - Fix warnings in import function crypto: vmac - New hash algorithm for intel_txt support crypto: api - Do not displace newly registered algorithms crypto: ansi_cprng - Fix module initialization crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx crypto: fips - Depend on ansi_cprng crypto: blkcipher - Do not use eseqiv on stream ciphers crypto: ctr - Use chainiv on raw counter mode Revert crypto: fips - Select CPRNG crypto: rng - Fix typo crypto: talitos - add support for 36 bit addressing crypto: talitos - align locks on cache lines crypto: talitos - simplify hmac data size calculation crypto: mv_cesa - Add support for Orion5X crypto engine crypto: cryptd - Add support to access underlaying shash crypto: gcm - Use GHASH digest algorithm crypto: ghash - Add GHASH digest algorithm for GCM crypto: authenc - Convert to ahash crypto: api - Fix aligned ctx helper crypto: hmac - Prehash ipad/opad ...
2009-08-31crypto: api - Do not displace newly registered algorithmsHerbert Xu
We have a mechanism where newly registered algorithms of a higher priority can displace existing instances that use a different implementation of the same algorithm with a lower priority. Unfortunately the same mechanism can cause a newly registered algorithm to displace itself if it depends on an existing version of the same algorithm. This patch fixes this by keeping all algorithms that the newly reigstered algorithm depends on, thus protecting them from being removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-29crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL testHerbert Xu
As struct skcipher_givcrypt_request includes struct crypto_request at a non-zero offset, testing for NULL after converting the pointer returned by crypto_dequeue_request does not work. This can result in IPsec crashes when the queue is depleted. This patch fixes it by doing the pointer conversion only when the return value is non-NULL. In particular, we create a new function __crypto_dequeue_request that does the pointer conversion. Reported-by: Brad Bosch <bradbosch@comcast.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-09crypto: api - Fix crypto_drop_spawn crash on blank spawnsHerbert Xu
This patch allows crypto_drop_spawn to be called on spawns that have not been initialised or have failed initialisation. This fixes potential crashes during initialisation without adding special case code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: api - Add crypto_attr_alg2 helperHerbert Xu
This patch adds the helper crypto_attr_alg2 which is similar to crypto_attr_alg but takes an extra frontend argument. This is intended to be used by new style algorithm types such as shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: api - Add new style spawn supportHerbert Xu
This patch modifies the spawn infrastructure to support new style algorithms like shash. In particular, this means storing the frontend type in the spawn and using crypto_create_tfm to allocate the tfm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-07crypto: api - Add crypto_alloc_instance2Herbert Xu
This patch adds a new argument to crypto_alloc_instance which sets aside some space before the instance for use by algorithms such as shash that place type-specific data before crypto_alg. For compatibility the function has been renamed so that existing users aren't affected. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-01-28crypto: api - Fix algorithm test race that broke aead initialisationHerbert Xu
When we complete a test we'll notify everyone waiting on it, drop the mutex, and then remove the test larval (after reacquiring the mutex). If one of the notified parties tries to register another algorithm with the same driver name prior to the removal of the test larval, they will fail with EEXIST as only one algorithm of a given name can be tested at any time. This broke the initialisation of aead and givcipher algorithms as they will register two algorithms with the same driver name, in sequence. This patch fixes the problem by marking the larval as dead before we drop the mutex, and also ignoring all dead or dying algorithms on the registration path. Tested-by: Andreas Steffen <andreas.steffen@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Use test infrastructureHerbert Xu
This patch makes use of the new testing infrastructure by requiring algorithms to pass a run-time test before they're made available to users. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookupHerbert Xu
Since the only user of __crypto_alg_lookup is doing exactly what crypto_alg_lookup does, we can now the latter in lieu of the former. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] api: Add crypto_attr_alg_nameHerbert Xu
This patch adds a new helper crypto_attr_alg_name which is basically the first half of crypto_attr_alg. That is, it returns an algorithm name parameter as a string without looking it up. The caller can then look it up immediately or defer it until later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] api: Add crypto_inc and crypto_xorHerbert Xu
With the addition of more stream ciphers we need to curb the proliferation of ad-hoc xor functions. This patch creates a generic pair of functions, crypto_inc and crypto_xor which does big-endian increment and exclusive or, respectively. For optimum performance, they both use u32 operations so alignment must be as that of u32 even though the arguments are of type u8 *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-23[CRYPTO] api: Fix potential race in crypto_remove_spawnHerbert Xu
As it is crypto_remove_spawn may try to unregister an instance which is yet to be registered. This patch fixes this by checking whether the instance has been registered before attempting to remove it. It also removes a bogus cra_destroy check in crypto_register_instance as 1) it's outside the mutex; 2) we have a check in __crypto_register_alg already. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] api: Explain the comparison on larval cra_nameHerbert Xu
This patch adds a comment to explain why we compare the cra_driver_name of the algorithm being registered against the cra_name of a larval as opposed to the cra_driver_name of the larval. In fact larvals have only one name, cra_name which is the name that was requested by the user. The test here is simply trying to find out whether the algorithm being registered can or can not satisfy the larval. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] blkcipher: Remove alignment restriction on block sizeHerbert Xu
Previously we assumed for convenience that the block size is a multiple of the algorithm's required alignment. With the pending addition of CTR this will no longer be the case as the block size will be 1 due to it being a stream cipher. However, the alignment requirement will be that of the underlying implementation which will most likely be greater than 1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] aead: Add authencHerbert Xu
This patch adds the authenc algorithm which constructs an AEAD algorithm from an asynchronous block cipher and a hash. The construction is done by concatenating the encrypted result from the cipher with the output from the hash, as is used by the IPsec ESP protocol. The authenc algorithm exists as a template with four parameters: authenc(auth, authsize, enc, enckeylen). The authentication algorithm, the authentication size (i.e., truncating the output of the authentication algorithm), the encryption algorithm, and the encryption key length. Both the size field and the key length field are in bytes. For example, AES-128 with SHA1-HMAC would be represented by authenc(hmac(sha1), 12, cbc(aes), 16) The key for the authenc algorithm is the concatenation of the keys for the authentication algorithm with the encryption algorithm. For the above example, if a key of length 36 bytes is given, then hmac(sha1) would receive the first 20 bytes while the last 16 would be given to cbc(aes). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] api: Add support for multiple template parametersHerbert Xu
This patch adds support for having multiple parameters to a template, separated by a comma. It also adds support for integer parameters in addition to the current algorithm parameter type. This will be used by the authenc template which will have four parameters: the authentication algorithm, the encryption algorithm, the authentication size and the encryption key length. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-07-11[CRYPTO] api: Wake up all waiters when larval completesHerbert Xu
Right now when a larval matures or when it dies of an error we only wake up one waiter. This would cause other waiters to timeout unnecessarily. This patch changes it to use complete_all to wake up all waiters. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] api: Do not remove users unless new algorithm matchesHerbert Xu
As it is whenever a new algorithm with the same name is registered users of the old algorithm will be removed so that they can take advantage of the new algorithm. This presents a problem when the new algorithm is not equivalent to the old algorithm. In particular, the new algorithm might only function on top of the existing one. Hence we should not remove users unless they can make use of the new algorithm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] api: Add async blkcipher typeHerbert Xu
This patch adds the mid-level interface for asynchronous block ciphers. It also includes a generic queueing mechanism that can be used by other asynchronous crypto operations in future. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] templates: Pass type/mask when creating instancesHerbert Xu
This patch passes the type/mask along when constructing instances of templates. This is in preparation for templates that may support multiple types of instances depending on what is requested. For example, the planned software async crypto driver will use this construct. For the moment this allows us to check whether the instance constructed is of the correct type and avoid returning success if the type does not match. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] api: Allow multiple frontends per backendHerbert Xu
This patch adds support for multiple frontend types for each backend algorithm by passing the type and mask through to the backend type init function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] api: Add type-safe spawnsHerbert Xu
This patch allows spawns of specific types (e.g., cipher) to be allocated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] api: Remove deprecated interfaceHerbert Xu
This patch removes the old cipher interface and related code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] api: Add common instance initialisation codeHerbert Xu
This patch adds the helpers crypto_get_attr_alg and crypto_alloc_instance which can be used by simple one-argument templates like hmac to process input parameters and allocate instances. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] api: Added spawnsHerbert Xu
Spawns lock a specific crypto algorithm in place. They can then be used with crypto_spawn_tfm to allocate a tfm for that algorithm. When the base algorithm of a spawn is deregistered, all its spawns will be automatically removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] api: Allow algorithm lookup by typeHerbert Xu
This patch also adds the infrastructure to pick an algorithm based on their type. For example, this allows you to select the encryption algorithm "aes", instead of any algorithm registered under the name "aes". For now this is only accessible internally. Eventually it will be made available through crypto_alloc_tfm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] api: Added event notificationHerbert Xu
This patch adds a notifier chain for algorithm/template registration events. This will be used to register compound algorithms such as cbc(aes). In future this will also be passed onto user-space through netlink. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] api: Add template registrationHerbert Xu
A crypto_template generates a crypto_alg object when given a set of parameters. this patch adds the basic data structure fo templates and code to handle their registration/deregistration. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] api: Split out low-level APIHerbert Xu
The crypto API is made up of the part facing users such as IPsec and the low-level part which is used by cryptographic entities such as algorithms. This patch splits out the latter so that the two APIs are more clearly delineated. As a bonus the low-level API can now be modularised if all algorithms are built as modules. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
