path: root/crypto/algif_aead.c
2017-05-20crypto: algif_aead - Require setkey before accept(2)Stephan Mueller
commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Fixes: 400c40cf78da ("crypto: algif - add AEAD support") Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21crypto: algif_aead - Fix bogus request dereference in completion functionHerbert Xu
commit e6534aebb26e32fbab14df9c713c65e8507d17e4 upstream. The algif_aead completion function tries to deduce the aead_request from the crypto_async_request argument. This is broken because the API does not guarantee that the same request will be pased to the completion function. Only the value of req->data can be used in the completion function. This patch fixes it by storing a pointer to sk in areq and using that instead of passing in sk through req->data. Fixes: 83094e5e9e49 ("crypto: af_alg - add async support to...") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14crypto: algif_aead - Fix kernel panic on list_delHarsh Jain
commit 0b529f143e8baad441a5aac9ad55ec2434d8fb46 upstream. Kernel panics when userspace program try to access AEAD interface. Remove node from Linked List before freeing its memory. Signed-off-by: Harsh Jain <harsh@chelsio.com> Reviewed-by: Stephan Müller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08crypto: algif_aead - fix uninitialized variable warningStephan Mueller
In case the user provided insufficient data, the code may return prematurely without any operation. In this case, the processed data indicated with outlen is zero. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-12-07crypto: algif_aead - fix AEAD tag memory handlingStephan Mueller
For encryption, the AEAD ciphers require AAD || PT as input and generate AAD || CT || Tag as output and vice versa for decryption. Prior to this patch, the AF_ALG interface for AEAD ciphers requires the buffer to be present as input for encryption. Similarly, the output buffer for decryption required the presence of the tag buffer too. This implies that the kernel reads / writes data buffers from/to kernel space even though this operation is not required. This patch changes the AF_ALG AEAD interface to be consistent with the in-kernel AEAD cipher requirements. Due to this handling, he changes are transparent to user space with one exception: the return code of recv indicates the mount of output buffer. That output buffer has a different size compared to before the patch which implies that the return code of recv will also be different. For example, a decryption operation uses 16 bytes AAD, 16 bytes CT and 16 bytes tag, the AF_ALG AEAD interface before showed a recv return code of 48 (bytes) whereas after this patch, the return code is 32 since the tag is not returned any more. Reported-by: Mat Martineau <mathew.j.martineau@linux.intel.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-04-05crypto: af_alg - add async support to algif_aeadTadeusz Struk
Following the async change for algif_skcipher this patch adds similar async read to algif_aead. changes in v3: - add call to aead_reset_ctx directly from aead_put_sgl instead of calling them separatelly one after the other - remove wait from aead_sock_destruct function as it is not needed when sock_hold is used changes in v2: - change internal data structures from fixed size arrays, limited to RSGL_MAX_ENTRIES, to linked list model with no artificial limitation. - use sock_kmalloc instead of kmalloc for memory allocation - use sock_hold instead of separate atomic ctr to wait for outstanding request Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from Davic Miller: 1) Support busy polling generically, for all NAPI drivers. From Eric Dumazet. 2) Add byte/packet counter support to nft_ct, from Floriani Westphal. 3) Add RSS/XPS support to mvneta driver, from Gregory Clement. 4) Implement IPV6_HDRINCL socket option for raw sockets, from Hannes Frederic Sowa. 5) Add support for T6 adapter to cxgb4 driver, from Hariprasad Shenai. 6) Add support for VLAN device bridging to mlxsw switch driver, from Ido Schimmel. 7) Add driver for Netronome NFP4000/NFP6000, from Jakub Kicinski. 8) Provide hwmon interface to mlxsw switch driver, from Jiri Pirko. 9) Reorganize wireless drivers into per-vendor directories just like we do for ethernet drivers. From Kalle Valo. 10) Provide a way for administrators "destroy" connected sockets via the SOCK_DESTROY socket netlink diag operation. From Lorenzo Colitti. 11) Add support to add/remove multicast routes via netlink, from Nikolay Aleksandrov. 12) Make TCP keepalive settings per-namespace, from Nikolay Borisov. 13) Add forwarding and packet duplication facilities to nf_tables, from Pablo Neira Ayuso. 14) Dead route support in MPLS, from Roopa Prabhu. 15) TSO support for thunderx chips, from Sunil Goutham. 16) Add driver for IBM's System i/p VNIC protocol, from Thomas Falcon. 17) Rationalize, consolidate, and more completely document the checksum offloading facilities in the networking stack. From Tom Herbert. 18) Support aborting an ongoing scan in mac80211/cfg80211, from Vidyullatha Kanchanapally. 19) Use per-bucket spinlock for bpf hash facility, from Tom Leiming. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1375 commits) net: bnxt: always return values from _bnxt_get_max_rings net: bpf: reject invalid shifts phonet: properly unshare skbs in phonet_rcv() dwc_eth_qos: Fix dma address for multi-fragment skbs phy: remove an unneeded condition mdio: remove an unneed condition mdio_bus: NULL dereference on allocation error net: Fix typo in netdev_intersect_features net: freescale: mac-fec: Fix build error from phy_device API change net: freescale: ucc_geth: Fix build error from phy_device API change bonding: Prevent IPv6 link local address on enslaved devices IB/mlx5: Add flow steering support net/mlx5_core: Export flow steering API net/mlx5_core: Make ipv4/ipv6 location more clear net/mlx5_core: Enable flow steering support for the IB driver net/mlx5_core: Initialize namespaces only when supported by device net/mlx5_core: Set priority attributes net/mlx5_core: Connect flow tables net/mlx5_core: Introduce modify flow table command net/mlx5_core: Managing root flow table ...
2016-01-12Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto update from Herbert Xu: "Algorithms: - Add RSA padding algorithm Drivers: - Add GCM mode support to atmel - Add atmel support for SAMA5D2 devices - Add cipher modes to talitos - Add rockchip driver for rk3288 - Add qat support for C3XXX and C62X" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (103 commits) crypto: hifn_795x, picoxcell - use ablkcipher_request_cast crypto: qat - fix SKU definiftion for c3xxx dev crypto: qat - Fix random config build issue crypto: ccp - use to_pci_dev and to_platform_device crypto: qat - Rename dh895xcc mmp firmware crypto: 842 - remove WARN inside printk crypto: atmel-aes - add debug facilities to monitor register accesses. crypto: atmel-aes - add support to GCM mode crypto: atmel-aes - change the DMA threshold crypto: atmel-aes - fix the counter overflow in CTR mode crypto: atmel-aes - fix atmel-ctr-aes driver for RFC 3686 crypto: atmel-aes - create sections to regroup functions by usage crypto: atmel-aes - fix typo and indentation crypto: atmel-aes - use SIZE_IN_WORDS() helper macro crypto: atmel-aes - improve performances of data transfer crypto: atmel-aes - fix atmel_aes_remove() crypto: atmel-aes - remove useless AES_FLAGS_DMA flag crypto: atmel-aes - reduce latency of DMA completion crypto: atmel-aes - remove unused 'err' member of struct atmel_aes_dev crypto: atmel-aes - rework crypto request completion ...
2015-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/renesas/ravb_main.c kernel/bpf/syscall.c net/ipv4/ipmr.c All three conflicts were cases of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01net: rename SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATAEric Dumazet
This patch is a cleanup to make following patch easier to review. Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA from (struct socket)->flags to a (struct socket_wq)->flags to benefit from RCU protection in sock_wake_async() To ease backports, we rename both constants. Two new helpers, sk_set_bit(int nr, struct sock *sk) and sk_clear_bit(int net, struct sock *sk) are added so that following patch can change their implementation. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-30net: Generalise wq_has_sleeper helperHerbert Xu
The memory barrier in the helper wq_has_sleeper is needed by just about every user of waitqueue_active. This patch generalises it by making it take a wait_queue_head_t directly. The existing helper is renamed to skwq_has_sleeper. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17crypto: algif - Change some variable to size_tLABBE Corentin
Some variable are set as int but store only positive values. Furthermore there are used in operation/function that wait for unsigned value. This patch set them as size_t. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-25crypto: algif_aead - fix for multiple operations on AF_ALG socketsLars Persson
The tsgl scatterlist must be re-initialized after each operation. Otherwise the sticky bits in the page_link will corrupt the list with pre-mature termination or false chaining. Signed-off-by: Lars Persson <larper@axis.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-17crypto: aead - Remove CRYPTO_ALG_AEAD_NEW flagHerbert Xu
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone has been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-22crypto: algif_aead - Temporarily disable all AEAD algorithmsHerbert Xu
As the AEAD conversion is still ongoing, we do not yet wish to export legacy AEAD implementations to user-space, as their calling convention will change. This patch actually disables all AEAD algorithms because some of them (e.g., cryptd) will need to be modified to propagate this flag. Subsequent patches will reenable them on an individual basis. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28crypto: algif_aead - Switch to new AEAD interfaceHerbert Xu
This patch makes use of the new AEAD interface which uses a single SG list instead of separate lists for the AD and plain text. Note that the user-space interface now requires both input and output to be of the same length, and both must include space for the AD as well as the authentication tag. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Herbert Xu
Merge the crypto tree for 4.1 to pull in the changeset that disables algif_aead.
2015-05-18crypto: algif_aead - fix invalid sgl linkingTadeusz Struk
This patch fixes it. Also minor updates to comments. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-23crypto: algif_aead - Include crypto/aead.hHerbert Xu
All users of AEAD should include crypto/aead.h instead of include/linux/crypto.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: David S. Miller <davem@davemloft.net>
2015-04-15crypto: fix mis-merge with the networking mergeLinus Torvalds
The networking updates from David Miller removed the iocb argument from sendmsg and recvmsg (in commit 1b784140474e: "net: Remove iocb argument from sendmsg and recvmsg"), but the crypto code had added new instances of them. When I pulled the crypto update, it was a silent semantic mis-merge, and I overlooked the new warning messages in my test-build. I try to fix those in the merge itself, but that relies on me noticing. Oh well. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-04crypto: algif - add AEAD supportStephan Mueller
This patch adds the AEAD support for AF_ALG. The implementation is based on algif_skcipher, but contains heavy modifications to streamline the interface for AEAD uses. To use AEAD, the user space consumer has to use the salg_type named "aead". The AEAD implementation includes some overhead to calculate the size of the ciphertext, because the AEAD implementation of the kernel crypto API makes implied assumption on the location of the authentication tag. When performing an encryption, the tag will be added to the created ciphertext (note, the tag is placed adjacent to the ciphertext). For decryption, the caller must hand in the ciphertext with the tag appended to the ciphertext. Therefore, the selection of the used memory needs to add/subtract the tag size from the source/destination buffers depending on the encryption type. The code is provided with comments explaining when and how that operation is performed. A fully working example using all aspects of AEAD is provided at http://www.chronox.de/libkcapi.html Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
