path: root/crypto/anubis.c
2019-06-13crypto: make all generic algorithms set cra_driver_nameEric Biggers
Most generic crypto algorithms declare a driver name ending in "-generic". The rest don't declare a driver name and instead rely on the crypto API automagically appending "-generic" upon registration. Having multiple conventions is unnecessarily confusing and makes it harder to grep for all generic algorithms in the kernel source tree. But also, allowing NULL driver names is problematic because sometimes people fail to set it, e.g. the case fixed by commit 417980364300 ("crypto: cavium/zip - fix collision with generic cra_driver_name"). Of course, people can also incorrectly name their drivers "-generic". But that's much easier to notice / grep for. Therefore, let's make cra_driver_name mandatory. In preparation for this, this patch makes all generic algorithms set cra_driver_name. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2019-04-18crypto: run initcalls for generic implementations earlierEric Biggers
Use subsys_initcall for registration of all templates and generic algorithm implementations, rather than module_init. Then change cryptomgr to use arch_initcall, to place it before the subsys_initcalls. This is needed so that when both a generic and optimized implementation of an algorithm are built into the kernel (not loadable modules), the generic implementation is registered before the optimized one. Otherwise, the self-tests for the optimized implementation are unable to allocate the generic implementation for the new comparison fuzz tests. Note that on arm, a side effect of this change is that self-tests for generic implementations may run before the unaligned access handler has been installed. So, unaligned accesses will crash the kernel. This is arguably a good thing as it makes it easier to detect that type of bug. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cleanup - remove unneeded crypto_alg.cra_list initializationsJussi Kivilinna
Initialization of cra_list is currently mixed, most ciphers initialize this field and most shashes do not. Initialization however is not needed at all since cra_list is initialized/overwritten in __crypto_register_alg() with list_add(). Therefore perform cleanup to remove all unneeded initializations of this field in 'crypto/'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: anubis - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-21[CRYPTO] api: Get rid of flags argument to setkeyHerbert Xu
Now that the tfm is passed directly to setkey instead of the ctx, we no longer need to pass the &tfm->crt_flags pointer. This patch also gets rid of a few unnecessary checks on the key length for ciphers as the cipher layer guarantees that the key length is within the bounds specified by the algorithm. Rather than testing dia_setkey every time, this patch does it only once during crypto_alloc_tfm. The redundant check from crypto_digest_setkey is also removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] cipher: Set alignmask for multi-byte loadsHerbert Xu
Many cipher implementations use 4-byte/8-byte loads/stores which require alignment on some architectures. This patch explicitly sets the alignment requirements for them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
